L2$ clock
L2$ clock
1,580 次查看
mrlantz
Is there any configuration possibility to set the L2$ clock on iMX6SDL? The L2 area seams to bee of same type as the OCMEM and I cannot find the clock source. I guess my question is if it possible to change the L2$ clock and if not what frequencies are used.
标签 (3)
1,504 次查看
AnsonHuang
Hi, Johan
     As far as I know, L2 cache's clock should be from ARM platform, on our i.MX6, it should be 1/2 of ARM freq, it is a fixed freq, can NOT be changed.
