Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block, in i.mx28 EVK using NFS
srinivasanshanm
Dear All,
Am unable to mount the roots using NFS I verified, NFS server from linux pc is getting started & running, this is straining me so much, I am trying to set statically, dont want to do it dynamically, am stcuk in this from 3 days.. could any body pls let me know hw to get rid of this problem once for all :smileysad:, I followed the I.mx28 BSP UG, u-boot_mx28, step by step user guide, but still am facing the same issue, kindly do the needful as soon as possible with fully detailed procedure to get rid of this problem
Awaiting for replies
Many Many Thanks in advance
U-Boot 2009.08 (Sep 12 2013 - 17:05:40)
Freescale i.MX28 family
CPU:   454 MHz
BUS:   151 MHz
EMI:   205 MHz
GPMI:   24 MHz
DRAM:  128 MB
MMC:   IMX_SSP_MMC: 0, IMX_SSP_MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:04:9f:02:b5:66
FEC0
Warning: FEC0 MAC addresses don't match:
Address in SROM is         00:04:9f:02:b5:66
Address in environment is  00:04:9f:00:ea:d7
Hit any key to stop autoboot:  0
MX28 U-Boot >
MX28 U-Boot >
MX28 U-Boot >
MX28 U-Boot > printenv
bootargs=console=ttyAM0,115200n8
bootcmd=run bootcmd_net
bootdelay=3
baudrate=115200
netmask=255.255.255.0
bootfile="uImage"
loadaddr=0x42000000
bootcmd_net=run bootargs_nfs; dhcp; bootm
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk0p3 rw rootwait ip=dhcp fec_mac=${ethaddr}
bootcmd_mmc=run bootargs_mmc; mmc read 0 ${loadaddr} 100 3000; bootm
ethact=FEC0
setenv=nfsroot /tools/rootfs
serverip=10.7.240.37
ipaddr=10.9.68.47
ethaddr=00:04:9F:00:EA:D7
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=10.9.68.47 nfsroot=${serverip}:${nfsroot} fec_mac=00:04:9F:00:EA:D7 gpmi
nfsroot=/tools/rootfs
gatewayip=10.7.240.1
stdin=serial
stdout=serial
stderr=serial
ver=U-Boot 2009.08 (Sep 12 2013 - 17:05:40)
Environment size: 722/130044 bytes
MX28 U-Boot > setenv ipaddr 10.7.240.39
MX28 U-Boot > saveenv
Saving Environment to MMC...
Writing to MMC(0)... done
MX28 U-Boot > setenv bootargs_nfs 'setenv bootargs ${bootargs} root=/dev/nfs ip=10.7.240.39 nfsroot=${serverip}:${nfsroot} fec_mac=00:04:9F:00:EA:D7 gpmi'
bootdelay=3
baudrate=115200
bootfile="uImage"
loadaddr=0x42000000
ethact=FEC0
stdin=serial
stdout=serial
stderr=serial
ipaddr=10.7.240.39
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=10.7.240.39 nfsroot=${serverip}:${nfsroot} fec_mac=00:04:9F:00:EA:D7 gpmi
Environment size: 724/130044 bytes
MX28 U-Boot > boot
BOOTP broadcast 1
FEC: Link is down 7809
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 10.9.67.58
Using FEC0 device
TFTP from server 10.7.240.37; our IP address is 10.9.67.58; sending through gateway 10.9.67.1
Filename 'uImage'.
Load address: 0x42000000
Loading: #################################################################
done
Bytes transferred = 1590284 (18440c hex)
## Booting kernel from Legacy Image at 42000000 ...
   Image Name:   Linux-2.6.35.3-571-gcca29a0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1590220 Bytes =  1.5 MB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Deepak Uncompressing Linux... done, booting the kernel.
Linux version 2.6.35.3-571-gcca29a0 (root@ubuntu-desktop) (gcc version 4.4.4 (4.4.4_09.06.2010) ) #5 Tue Sep 10 16:02:02 IST 2013
Kernel command line: console=ttyAM0,115200n8 root=/dev/nfs ip=10.7.240.39 nfsroot=10.7.240.37:/tools/rootfs fec_mac=00:04:9F:00:EA:D7 gpmi
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126448k/126448k available, 4624k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfde00000 - 0xffe00000   (  32 MB)
    vmalloc : 0xc8800000 - 0xf0000000   ( 632 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0027000   ( 124 kB)
      .text : 0xc0027000 - 0xc0305000   (2936 kB)
      .data : 0xc0306000 - 0xc0324d20   ( 124 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:288
console [ttyAM0] enabled
Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
pid_max: default: 32768 minimum: 301
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
regulator: vddd: 800 <--> 1575 mV at 1500 mV fast normal
regulator: vdddbo: 800 <--> 1575 mV fast normal
regulator: vdda: 1500 <--> 2275 mV at 1800 mV fast normal
vddio = 3380000, val=10
regulator: vddio: 2880 <--> 3680 mV at 3380 mV fast normal
regulator: overall_current: fast normal
regulator: vbus5v:
regulator: mxs-duart-1: fast normal
regulator: mxs-bl-1: fast normal
regulator: mxs-i2c-1: fast normal
regulator: mmc_ssp-1: fast normal
regulator: mmc_ssp-2: fast normal
regulator: charger-1: fast normal
regulator: power-test-1: fast normal
regulator: cpufreq-1: fast normal
i.MX IRAM pool: 124 KB@0xc8820000
Initializing GPMI pins
usb DR wakeup device is registered
IMX usb wakeup probe
audit: cannot initialize inotify handle
SCSI subsystem initialized
Switching to clocksource mxs clock source
Bus freq driver module loaded
mxs_cpu_init: Entering .........
mxs_cpu_init: harish cpu_clk=c030bb28
set_freq_table: harish policy->cur=454736
set_freq_table: harish policy->governor=c0322dec
set_freq_table: harish policy->min=261818
set_freq_table: harish policy->max=454736
mxs_cpu_init: cpufreq init finished
mxs_verify_speed: harish cpu_clk=(null)
mxs_target: harish freq_KHz=454736
audit: initializing netlink socket (disabled)
type=2000 audit(0.460:1): initialized
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 246
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
mxs_getspeed: harish cpu=0
mxs_target: harish target_freq=454736
mxs_target: harish ..... exiting from mxs_target
set_freq_table: harish policy->min=64000
mxs-duart.0: ttyAM0 at MMIO 0x80074000 (irq = 47) is a DebugUART
mxs-auart.0: ttySP0 at MMIO 0x8006a000 (irq = 112) is a mxs-auart.0
Found APPUART 3.1.0
mxs-auart.1: ttySP1 at MMIO 0x8006c000 (irq = 113) is a mxs-auart.1
Found APPUART 3.1.0
mxs-auart.2: ttySP2 at MMIO 0x8006e000 (irq = 114) is a mxs-auart.2
Found APPUART 3.1.0
mxs-auart.3: ttySP3 at MMIO 0x80070000 (irq = 115) is a mxs-auart.3
Found APPUART 3.1.0
brd: module loaded
loop: module loaded
Loading iSCSI transport class v2.0-870.
i.MX GPMI NFC
NFC: Version 1, 8-chip GPMI and BCH
Boot ROM: Version 1, Single-chip boot area, block mark swapping supported
Scanning for NAND Flash chips...
******************* DEEPAK Scanning for NAND Flash chips...
DEEPAK says No NAND device found.
gpmi-nfc gpmi-nfc.0: Chip scan failed
ARC USBOTG Device Controller driver (1 August 2005)
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: File-backed Storage Gadget, version: 20 November 2008
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
mice: PS/2 mouse device common for all mice
input: mxs-kbd as /devices/platform/mxs-kbd.0/input/input0
input: MXS touchscreen as /devices/virtual/input/input1
MXS RTC driver v1.0 hardware v2.3.0
mxs-rtc mxs-rtc.0: rtc core: registered mxs-rtc as rtc0
mxs-mmc: MXS SSP Controller MMC Interface driver
mxs-mmc mxs-mmc.0: mmc0: MXS SSP MMC DMAIRQ 82 ERRIRQ 96
mxs-rtc mxs-rtc.0: setting system clock to 1970-01-01 00:41:44 UTC (2504)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,255)
Backtrace:
[<c002b6e4>] (dump_backtrace+0x0/0x114) from [<c027d5d0>] (dump_stack+0x18/0x1c)
r7:c0021a14 r6:00008000 r5:c7c14000 r4:c0325c18
[<c027d5b8>] (dump_stack+0x0/0x1c) from [<c027d634>] (panic+0x60/0xdc)
[<c027d5d4>] (panic+0x0/0xdc) from [<c0008f9c>] (mount_block_root+0x25c/0x2ac)
r3:00000000 r2:00000000 r1:c7c27f60 r0:c02cbaa5
[<c0008d40>] (mount_block_root+0x0/0x2ac) from [<c0009040>] (mount_root+0x54/0x6c)
[<c0008fec>] (mount_root+0x0/0x6c) from [<c00091c4>] (prepare_namespace+0x16c/0x1c4)
r5:c0021a29 r4:c0324fe0
[<c0009058>] (prepare_namespace+0x0/0x1c4) from [<c00084e8>] (kernel_init+0x118/0x158)
r5:c00208dc r4:c0324da0
[<c00083d0>] (kernel_init+0x0/0x158) from [<c0044b68>] (do_exit+0x0/0x5f0)
r5:c00083d0 r4:00000000
Labels (2)
slay
I have been struggling quite some time as well to get nfs boot working as it should. One of the problems I finally had, was caused by not setting the "no_root_squash" option on the nfs server host side. After I added this (to the /etc/exports on Ubuntu) and restarted the nfs service, things were OK.
Ruud
LeonardoSandova
Specialist I
In the official documentation, does the "no_root_squash" string missing?
Leo
slay
No, it is there. At least in the "i.MX28_Linux_BSP_UG". But at first I had things up and running on a Debian machine.
Later I switched to a new Ubuntu and then forgot about this option.
Ruud
srinivasanshanm
Thanks a lot for your response & support the issue is resolved , after setting the appropriate bootargs & with the above configuration & ip address for board & PC
LeonardoSandova
Specialist I
Are you able to mount that folder on your HOST machine? is the NFS service running?
Leo
srinivasanshanm
Yes the service is running, am able to mount that folder on HOST
