J1939 support on CAN
3,415 次查看
riteshpatel
I am working on one project and need J1939 protocol support on CAN interface & I am new to this protocol. I am using iMX6Q processor in my application.
My question is, Which specification I need to check in CAN transceiver to support J1939 protocol on CANbus?
I am planning to use TJA1043 CAN transceiver in my design. Please suggest.
Ritesh
标记 (4)
3,028 次查看
naveenrapheal
Hi Ritesh,
I am not working in the hardware design but I have some experience in J1939 protocol.
SAE J1939 physical layer is coming under ISO 11898.In the data sheet of your TJA1043,it says it will support ISO 11898 (Fully ISO 11898-2:2003 and ISO 11898-5:2007 compliant). So I think this one will work for you.
Naveen
3,028 次查看
riteshpatel
Awaiting for response...!!
