Issues about using GStreamer to display multiple Camera RTSP Streaming
2,305 次查看
Eric1994
I'm using the i.MX 8M Mini with Linux Yocto Project BSP 5.10.72 2.2.1 Release;
I follow the <i.MX 8 GStreamer User Guide> document in the following link:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8-GStreamer-User-Guide/ta-p/1098942
And I use GStreamer to display 2 IP camera rtsp streams like this:
gst-launch-1.0 rtspsrc location=rtsp://admin:hk123456@192.168.8.64 latency=0 ! decodebin ! glimagesink render-rectangle='<0, 0, 600, 870>' &
gst-launch-1.0 rtspsrc location=rtsp://admin:hk123456@192.168.8.66 latency=0 ! decodebin ! glimagesink render-rectangle='<620, 0, 600, 870>' &
When these is only 1 rtsp stream, the video looks fine, when I add the second rtsp stream, the video start to blink, see the IMG_6040.mp4 video in the attachment.
How to deal with this blink issue?
2,283 次查看
joanxie
what's your video resolution and frame rate? maybe you can refer to the link as below
https://community.nxp.com/t5/i-MX-Processors/Gstreamer-resize-video-window/m-p/1389083
