Following are strace logs while starting httpd:
root@bhavesh /usr/sbin$ strace httpd
execve("/sbin/httpd", ["httpd"], [/* 13 vars */]) = 0
brk(0) = 0xa6000
uname({sys="Linux", node="bhavesh", ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001d000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/v5l/fast-mult/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v5l/fast-mult/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/v5l/fast-mult/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v5l/fast-mult", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/v5l/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v5l/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/v5l/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/v5l", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/fast-mult/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/fast-mult/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/fast-mult/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/fast-mult", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/tls/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/v5l/fast-mult/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/v5l/fast-mult/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/v5l/fast-mult/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/v5l/fast-mult", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/v5l/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/v5l/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/v5l/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/v5l", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/fast-mult/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/fast-mult/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/fast-mult/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/fast-mult", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/half/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/half", 0xbe973470) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\20V\1\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0777, st_size=1506577, ...}) = 0
mmap2(NULL, 1225932, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40026000
mprotect(0x40145000, 28672, PROT_NONE) = 0
mmap2(0x4014c000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11e) = 0x4014c000
mmap2(0x4014f000, 9420, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4014f000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001e000
syscall_983045(0x4001e140, 0x4001e817, 0x4001e818, 0x4001e140, 0x40025000, 0x40025048, 0x40025048, 0xf0005, 0xfffffe00, 0x40025048, 0, 0xbe973b0c, 0, 0xbe9739f8, 0x400114e4, 0x40002080, 0x20000010, 0x4001e140, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0) = 0
mprotect(0x4014c000, 8192, PROT_READ) = 0
mprotect(0xa2000, 4096, PROT_READ) = 0
mprotect(0x40024000, 4096, PROT_READ) = 0
getuid32() = 0
brk(0) = 0xa6000
brk(0xc7000) = 0xc7000
getcwd("/usr/sbin", 192) = 10
chdir("/usr/sbin") = 0
rt_sigaction(SIGCHLD, {SIG_IGN}, {SIG_DFL}, 8) = 0
mq_notify(2, ptrace: umoven: Input/output error
{...}) = 3
SYS_294(0x3, 0x1, 0x2, 0x858f0, 0x4) = 0
mq_getsetattr(3, {mq_flags=O_RDWR|0x50000000, mq_maxmsg=0, mq_msgsize=0, mq_curmsg=0}, ptrace: umoven: Input/output error
{...}) = 0
SYS_284(0x3, 0x9, 0xa6090, 0x1, 0xa6008) = 0
open("/etc/httpd.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("httpd.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
rt_sigaction(SIGHUP, {0x1ab38, [HUP], SA_RESTART|0x4000000}, {SIG_DFL}, 8) = 0
open("/dev/null", O_RDWR|O_LARGEFILE) = 4
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x4001dce8) = 2234
io_submit(0, 0x946c0, 0x8 <unfinished ... exit status 0>
Process 2233 detached
