Issue with interfacing WiFi/BT Laird Sterling Module
4,109件の閲覧回数
econote_vikrant
Greetings!
I am trying to interfacing Laird's Sterling LWB module for the last 3 weeks with imx7dsabresd.
I have solved issues one after one, but now only the big issue is with me is that one of the modules is automatically getting uploaded in the kernel log, however, I have modified device tree also to debug from where this module is getting uploaded but no help from debugging. Can anyone suggest to me what's going wrong?
Following is my Kernel log as well as the status of 'lsmod'
Kindly check and help for the same
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started dnf-automatic timer.
brcmfmac: Unknown symbol cfg80211_sched_scan_results (err 0)
[  OK  ] Started dnf mabrcmfmac: Unknown symbol cfg80211_scan_done (err 0)
kecache timer.
[  OK  ] Started dnf-automatic-notifyonly timer.
brcmfmac: Unknown symbol cfg80211_sched_scan_stopped (err 0)
[  OK  ] Started dnf-aubrcmfmac: Unknown symbol cfg80211_remain_on_channel_expired (err 0)
tomatic-download timer.
imx-sdma 30bd0000.sdma: loaded firmware 4.4
[  OK  ] Reached targetbrcmfmac: Unknown symbol cfg80211_port_authorized (err 0)
 Timers.
[  OK  ] Reached targetbrcmfmac: Unknown symbol cfg80211_new_sta (err 0)
 Basic System.
brcmfmac: Unknown symbol cfg80211_disconnected (err 0)
brcmfmac: Unknown symbol wiphy_new_nm (err 0)
brcmfmac: Unknown symbol cfg80211_ready_on_channel (err 0)
brcmfmac: Unknown symbol cfg80211_classify8021d (err 0)
brcmfmac: Unknown symbol cfg80211_crit_proto_stopped (err 0)
[  OK  ] Started TEE Subrcmfmac: Unknown symbol wiphy_register (err 0)
pplicant.
brcmfmac: Unknown symbol __cfg80211_alloc_reply_skb (err 0)
         brcmfmac: Unknown symbol cfg80211_put_bss (err 0)
Starting System Logging Service...
         brcmfmac: Unknown symbol cfg80211_roamed (err 0)
Starting Login Service...
         brcmfmac: Unknown symbol cfg80211_check_combinations (err 0)
Starting Network Time Service (one-shot ntpdate mode)...
         brcmfmac: Unknown symbol cfg80211_ibss_joined (err 0)
Starting Telephony service...
brcmfmac: Unknown symbol cfg80211_michael_mic_failure (err 0)
         brcmfmac: Unknown symbol wiphy_apply_custom_regulatory (err 0)
Starting RPC Bind Service...
brcmfmac: Unknown symbol ieee80211_get_channel (err 0)
brcmfmac: Unknown symbol cfg80211_del_sta_sinfo (err 0)
brcmfmac: Unknown symbol wiphy_unregister (err 0)
brcmfmac: Unknown symbol wiphy_read_of_freq_limits (err 0)
brcmfmac: Unknown symbol cfg80211_vendor_cmd_reply (err 0)
brcmfmac: Unknown symbol cfg80211_mgmt_tx_status (err 0)
brcmfmac: Unknown symbol cfg80211_unregister_wdev (err 0)
brcmfmac: Unknown symbol ieee80211_channel_to_frequency (err 0)
brcmfmac: Unknown symbol cfg80211_rx_mgmt (err 0)
brcmfmac: Unknown symbol cfg80211_report_wowlan_wakeup (err 0)
brcmfmac: Unknown symbol cfg80211_get_p2p_attr (err 0)
brcmfmac: Unknown symbol cfg80211_inform_bss_data (err 0)
brcmfmac: Unknown symbol ieee80211_frequency_to_channel (err 0)
brcmfmac: Unknown symbol backport_dependency_symbol (err 0)
brcmfmac: Unknown symbol cfg80211_connect_done (err 0)
brcmfmac: Unknown symbol wiphy_free (err 0)
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started D-Bus FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
System Message Bus.
[  OK  ] Started Login Service.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started Network Service.
[  OK  ] Started Start Psplash Boot Screen.
[  OK  ] Started System Logging Service.
[  OK  ] Started Network Time Service (one-shot ntpdate mode).
[  OK  ] Started RPC Bind Service.
[  OK  ] Found device /dev/ttymxc0.
[  OK  ] Started Telephony service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight�…ightness of backlight:backlight...
         Starting Kernel Logging Service...
[  OK  ] Started Updates psplash to basic.
         Starting Network Name Resolution...
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target Network.
         Starting Network Time Service...
[  OK  ] Started Update psplash to network.
         Starting Terminate Psplash Boot Screen...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Started Network Time Service.
[  OK  ] Started Terminate Psplash Boot Screen.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttymxc0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
NXP i.MX Release Distro 4.14-sumo imx7dsabresd ttymxc0
imx7dsabresd login: root
root@imx7dsabresd:~# lsmod
Module                  Size  Used by
brcmutil               16384  0
ラベル(3)
3,700件の閲覧回数
johnnosky
John from Laird Connectivity here. For future reference, we provide an external layer for building the driver and firmware with custom Yocto images. Please see our layer here:
https://github.com/LairdCP/meta-laird-cp
And if support is needed, please click on the button "Open a Support Ticket" found in the link below.
https://www.lairdconnect.com/resources/support
3,799件の閲覧回数
Hi Vikrant
"brcmfmac: Unknown symbol" may mean that improper driver was used or
firmware. One can check Cypress Linux WiFi Driver Release (FMAC) [2018-... | Cypress Developer Community
and post issue on that community.
