Issue in integrating a aiml application
1,426 次查看
sd05
Hello Community,
IMX8M EVK / Yocto Zeus
I am trying to integrate a aiml based application, the application is dependent on CMSIS library can  I integrate the CMSIS library in Yocto? and use the same application?
What are option available for me?
Also I tried to load it on the auxilary core but when I tried compiling it i am getting following errors..
Please help. I am new to this sorry if something not correct conceptually. Please answer and help me to understand.
Thanks.
1,418 次查看
igorpadykov
Hi Sunidhi
may be useful to start with   i.MX Machine Learning User's Guide
sect.5.6.7 NXP® eIQTM machine learning    i.MX Yocto Project User’s Guide​
https://wiki.yoctoproject.org/wiki/Cookbook:Example:Adding_packages_to_your_OS_image
