Is it Possible to do baremetal framebuffer programming on iMX6Q sabre-sd?
1,637件の閲覧回数
ajmalali
I am trying bare-metal programming in imx6q sabre-sd board. How can i access framebuffer in bare-metal and write a value to the display? What all drivers should i need to access framebuffer? Does anyone have any sample code for the same?
Any documents or sample code is highly welcomed. Please help.
Ajmal
ラベル(3)
1,379件の閲覧回数
Bio_TICFSL
Hi ajmalali,
For display fb driver and access you can use uboot, it contains support for the LVDS display we are using in combination with i.MX6Q SABRESD board:
 Building U-boot
For complete bare metal project, i suggest to start with:
Integrating Processor Expert for i.MX and ARM GCC with Eclipse
