Building U-boot
Document created by rogeriopimentel Employee on Oct 14, 2015
Version 1Show Document
  • View in full screen mode
Building Freescale U-boot
The U-boot provided by Freescale can be downloaded in the following link:
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/
1 - Set the cross compiler environment variables. When using Yocto, it can be made by the following command (see more details at Yocto Trainning Yocto Training - HOME )
source /opt/poky/1.7/environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
2 - Download the source code using "git clone":
git clone  http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git
3 - Create a local branch based on some remote branch. In this example, lets use branch origin/imx_v2014.04_3.14.28_1.0.0_ga
cd uboot-imx
git checkout -b imx_v2014.04_3.14.28_1.0.0_ga_local origin/imx_v2014.04_3.14.28_1.0.0_ga
4 - Configure the project with the board you want to build. All board are listed on file boards.cfg. Check the exactly name of the choosen board and add "_config" to build the project. In this example, lets use mx6qsabresd
make mx6qsabresd_config
make
5 - The binary file will be generated and will be located at project root folder. The generated file in this case will be u-boot.imx
6 - More details can be found on files
doc/README.imx6
doc/README.imximage
README
Building Mainline U-boot
The U-boot project is developed and maintained by Denx Computer Systems can be downloaded in the following link:
http://git.denx.de/?p=u-boot.git;a=summary
git clone http://git.denx.de/u-boot.git
3 - Check the name of the board on "configs" folder. In this case lets use mx6qsabresd_config
make
4 - The binary file will be generated and will be located at project root folder. The generated file in this case will be u-boot.imx
6 people found this helpful
    Outcomes
