Invalid EEPROM context - iMX93 QSB
emb-dev
I am using iMX93 QSB with latest firmware ; Linux 6.6.36_2.1.0
I want to measure power of the Board using bcu tool, I am facing this error:
Please share how to resolve this
bcu eeprom -w -board=imx93evk11
Then you can choose to replace option <-board=> with <-auto>.
NOTE: If other boards are also connected to the same host, <-auto> may break its ttyUSB function temporarily.
pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack PAC1934 cannot access!
done
version bcu_1.1.52-0-g17ab144 board model is imx93evk11
>>>>>> Registered FTDI EEPROM on board >>>>>>
Invalid EEPROM context, use -w option to write the default values.
done
emb-dev
Hi I tried this on Windows, with my iMX93 QSB
version bcu_1.1.100-0-gc34d89b
done
bcu eeprom -r -board=imx93evk11
done
I also tried this on an Ubuntu 22 Host. with my iMX93 QSB
sudo bcu eeprom -w -board=imx93evk11
No EEPROM
Checksum Error: aaaa ffff
ftdi_eeprom_decode: -1 (EEPROM checksum error)
Erase failed: No connected EEPROM or EEPROM type unknowndone
sudo ./bcu monitor -board=imx93evk11
I am facing the same issue "pac1934_write_bipolar: pac 1934 failure"
If I run board= imx93qsb
sudo ./bcu monitor -board=imx93qsb
Gives me Capture time, but does not give the Current and Power
emb-dev
done
done
No EEPROM
Manuel_Salas
Hello @emb-dev
This is expected, because in the imx93EVK board we have Current monitors to measure the lines:
You can refer to the i.MX93EVK schematics on page 12.
The QSB has not those current monitors, but it has the PCA9655EMTTXG port expander, that it can control the BOOT_MODE, Reset pines to reset board and boot from an specific device.
If you want to measure the lines I recommend to you to use the i.MX93 EVK (A0 or A1 are supported in BCU).
I hope this information can helps to you.
Salas.
emb-dev
Hi Alejandro,
I see now, Thanks for the clarification.
Manuel_Salas
Hello @emb-dev
I hope you are doing very well.
Please try with the below commands:
$ sudo bcu eeprom -w -board=imx93qsb
$ sudo bcu eeprom -r -board=imx93qsb
$ sudo bcu monitor -board=imx93qsb
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EInvalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20am%20using%20iMX93%20QSB%20with%20latest%20firmware%20%3B%20Linux%206.6.36_2.1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20want%20to%20measure%20power%20of%20the%20Board%20using%20bcu%20tool%2C%20I%20am%20facing%20this%20error%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPlease%20share%20how%20to%20resolve%20this%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThen%20you%20can%20choose%20to%20replace%20option%20%26lt%3B-board%3D%26gt%3B%20with%20%26lt%3B-auto%26gt%3B.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENOTE%3A%20If%20other%20boards%20are%20also%20connected%20to%20the%20same%20host%2C%20%26lt%3B-auto%26gt%3B%20may%20break%20its%20ttyUSB%20function%20temporarily.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_write_bipolar%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20pac1934_snapshot%3A%20pac%201934%20failure%20get%20ack%20PAC1934%20cannot%20access!%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edone%20%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%20%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E---------------------------------------%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eversion%20bcu_1.1.52-0-g17ab144%20board%20model%20is%20imx93evk11%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20Registered%20FTDI%20EEPROM%20on%20board%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EInvalid%20EEPROM%20context%2C%20use%20-w%20option%20to%20write%20the%20default%20values.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alejandro%2C%3C%2FP%3E%3CP%3EI%20see%20now%2C%20Thanks%20for%20the%20clarification.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242686%22%20target%3D%22_blank%22%3E%40emb-dev%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20is%20expected%2C%20because%20in%20the%20imx93EVK%20board%20we%20have%20Current%20monitors%20to%20measure%20the%20lines%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20style%3D%22width%3A%20354px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308004i1D866D3E19A0B468%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_0-1730426097362.png%22%20alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EYou%20can%20refer%20to%20the%20i.MX93EVK%20schematics%20on%20page%2012.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20QSB%20has%20not%20those%20current%20monitors%2C%20but%20it%20has%20the%26nbsp%3BPCA9655EMTTXG%20port%20expander%2C%20that%20it%20can%20control%20the%20BOOT_MODE%2C%20Reset%20pines%20to%20reset%20board%20and%20boot%20from%20an%20specific%20device.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIf%20you%20want%20to%20measure%20the%20lines%20I%20recommend%20to%20you%20to%20use%20the%20i.MX93%20EVK%20(A0%20or%20A1%20are%20supported%20in%20BCU).%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20hope%20this%20information%20can%20helps%20to%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EHi%20I%20tried%20this%20on%20Windows%2C%26nbsp%3Bwith%20my%20iMX93%20QSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E--------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eboard%20model%20is%20imx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20Registered%20FTDI%20EEPROM%20on%20board%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EInvalid%20EEPROM%20context%2C%20use%20-w%20option%20to%20write%20the%20default%20values.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Ebcu%20eeprom%20-r%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E---------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eboard%20model%20is%20imx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20Registered%20FTDI%20EEPROM%20on%20board%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EInvalid%20EEPROM%20context%2C%20use%20-w%20option%20to%20write%20the%20default%20values.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EI%20also%20tried%20this%20on%20an%20%3CSTRONG%3EUbuntu%2022%3C%2FSTRONG%3E%20Host.%20with%20my%20iMX93%20QSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20bcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eboard%20model%20is%20imx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20Registered%20FTDI%20EEPROM%20on%20board%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3ENo%20EEPROM%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EChecksum%20Error%3A%20aaaa%20ffff%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eftdi_eeprom_decode%3A%20-1%20(EEPROM%20checksum%20error)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EErase%20failed%3A%20No%20connected%20EEPROM%20or%20EEPROM%20type%20unknowndone%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20.%2Fbcu%20monitor%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E----------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EI%20am%20facing%20the%20same%20issue%20%22%3CSPAN%3Epac1934_write_bipolar%3A%20pac%201934%20failure%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EIf%20I%20run%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Eboard%3D%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Eimx93qsb%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20.%2Fbcu%20monitor%20-board%3Dimx93qsb%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E----------------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EGives%20me%20Capture%20time%2C%20but%20does%20not%20give%20the%20Current%20and%20Power%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242686%22%20target%3D%22_blank%22%3E%40emb-dev%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EI%20hope%20you%20are%20doing%20very%20well.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EPlease%20try%20with%20the%20below%20commands%3A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CPRE%20class%3D%22language-markup%22%3E%3CCODE%3E%24%20sudo%20bcu%20eeprom%20-w%20-board%3Dimx93qsb%0A%24%20sudo%20bcu%20eeprom%20-r%20-board%3Dimx93qsb%0A%24%20sudo%20bcu%20monitor%20-board%3Dimx93qsb%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBest%20regards%2C%3C%2FDIV%3E%0A%3CDIV%3ESalas.%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
