Invalid EEPROM context - iMX93 QSB
2,603 次查看
emb-dev
I am using iMX93 QSB with latest firmware ; Linux 6.6.36_2.1.0
I want to measure power of the Board using bcu tool, I am facing this error:
Please share how to resolve this
bcu eeprom -w -board=imx93evk11
Then you can choose to replace option <-board=> with <-auto>.
NOTE: If other boards are also connected to the same host, <-auto> may break its ttyUSB function temporarily.
pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_write_bipolar: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack pac1934_snapshot: pac 1934 failure get ack PAC1934 cannot access!
done
version bcu_1.1.52-0-g17ab144 board model is imx93evk11
>>>>>> Registered FTDI EEPROM on board >>>>>>
Invalid EEPROM context, use -w option to write the default values.
done
2,574 次查看
emb-dev
Hi I tried this on Windows, with my iMX93 QSB
version bcu_1.1.100-0-gc34d89b
done
bcu eeprom -r -board=imx93evk11
done
I also tried this on an Ubuntu 22 Host. with my iMX93 QSB
sudo bcu eeprom -w -board=imx93evk11
No EEPROM
Checksum Error: aaaa ffff
ftdi_eeprom_decode: -1 (EEPROM checksum error)
Erase failed: No connected EEPROM or EEPROM type unknowndone
sudo ./bcu monitor -board=imx93evk11
I am facing the same issue "pac1934_write_bipolar: pac 1934 failure"
If I run board= imx93qsb
sudo ./bcu monitor -board=imx93qsb
Gives me Capture time, but does not give the Current and Power
4 回复数
2,575 次查看
emb-dev
done
done
No EEPROM
2,559 次查看
Manuel_Salas
Hello @emb-dev
This is expected, because in the imx93EVK board we have Current monitors to measure the lines:
You can refer to the i.MX93EVK schematics on page 12.
The QSB has not those current monitors, but it has the PCA9655EMTTXG port expander, that it can control the BOOT_MODE, Reset pines to reset board and boot from an specific device.
If you want to measure the lines I recommend to you to use the i.MX93 EVK (A0 or A1 are supported in BCU).
I hope this information can helps to you.
Salas.
2,540 次查看
emb-dev
Hi Alejandro,
I see now, Thanks for the clarification.
2,594 次查看
Manuel_Salas
Hello @emb-dev
I hope you are doing very well.
Please try with the below commands:
$ sudo bcu eeprom -w -board=imx93qsb
$ sudo bcu eeprom -r -board=imx93qsb
$ sudo bcu monitor -board=imx93qsb
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EInvalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%E6%9C%80%E6%96%B0%E5%9B%BA%E4%BB%B6%E7%9A%84%20iMX93%20QSB%EF%BC%9BLinux%206.6.36_2.1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20bcu%20%E5%B7%A5%E5%85%B7%E6%B5%8B%E9%87%8F%E4%B8%BB%E6%9D%BF%E7%9A%84%E5%8A%9F%E7%8E%87%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%84%B6%E5%90%8E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E7%94%A8%20%26lt%3B-auto%26gt%3B%20%E6%9B%BF%E6%8D%A2%E9%80%89%E9%A1%B9%20%26lt%3B-board%3D%26gt%3B%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%A6%82%E6%9E%9C%E5%85%B6%E4%BB%96%E6%9D%BF%E4%B9%9F%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%90%8C%E4%B8%80%E4%B8%BB%E6%9C%BA%EF%BC%8C%26lt%3B-auto%26gt%3B%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9A%82%E6%97%B6%E7%A0%B4%E5%9D%8F%E5%85%B6%20ttyUSB%20%E5%8A%9F%E8%83%BD%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Epac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4%20pac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%8E%B7%E5%8F%96%E7%A1%AE%E8%AE%A4ack%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%E8%8E%B7%E5%8F%96%20ack%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%E8%8E%B7%E5%8F%96%20ack%20pac1934_snapshot%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%E8%8E%B7%E5%8F%96%20ack%20PAC1934%20%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%EF%BC%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edone%20%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%20%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E---------------------------------------%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%89%88%E6%9C%AC%20bcu_1.1.52-0-g17ab144%E6%9D%BF%E5%AD%90%E5%9E%8B%E5%8F%B7%E6%98%AFimx93evk11%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20%E6%9D%BF%E4%B8%8A%E6%B3%A8%E5%86%8C%20FTDI%20EEPROM%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%97%A0%E6%95%88%E7%9A%84%20EEPROM%20%E4%B8%8A%E4%B8%8B%E6%96%87%EF%BC%8C%E4%BD%BF%E7%94%A8%20-w%20%E9%80%89%E9%A1%B9%E5%86%99%E5%85%A5%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1984061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alejandro%2C%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242686%22%20target%3D%22_blank%22%3E%40emb-dev%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E9%A2%84%E6%96%99%E4%B9%8B%E4%B8%AD%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%20imx93EVK%20%E6%9D%BF%E4%B8%AD%E6%88%91%E4%BB%AC%E6%9C%89%E7%94%B5%E6%B5%81%E7%9B%91%E8%A7%86%E5%99%A8%E6%9D%A5%E6%B5%8B%E9%87%8F%E7%BA%BF%E8%B7%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20style%3D%22width%3A%20354px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308004i1D866D3E19A0B468%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alejandro_Salas_0-1730426097362.png%22%20alt%3D%22Alejandro_Salas_0-1730426097362.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E7%AC%AC%2012%20%E9%A1%B5%E7%9A%84%20i.MX93EVK%20%E5%8E%9F%E7%90%86%E5%9B%BE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EQSB%20%E6%B2%A1%E6%9C%89%E8%BF%99%E4%BA%9B%E7%94%B5%E6%B5%81%E7%9B%91%E8%A7%86%E5%99%A8%EF%BC%8C%E4%BD%86%E5%AE%83%E6%9C%89%20PCA9655EMTTXG%20%E7%AB%AF%E5%8F%A3%E6%89%A9%E5%B1%95%E5%99%A8%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%8E%A7%E5%88%B6%20BOOT_MODE%E3%80%81%E9%87%8D%E7%BD%AE%E5%BC%95%E8%84%9A%E4%BB%A5%E9%87%8D%E7%BD%AE%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%B9%B6%E4%BB%8E%E7%89%B9%E5%AE%9A%E8%AE%BE%E5%A4%87%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E6%B5%8B%E9%87%8F%E7%BA%BF%E8%B7%AF%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%20i.MX93%20EVK%EF%BC%88BCU%20%E6%94%AF%E6%8C%81%20A0%20%E6%88%96%20A1%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E8%83%BD%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1985731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1985731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20Windows%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E6%88%91%E7%9A%84%20iMX93%20QSB%20%E5%B0%9D%E8%AF%95%E8%BF%87%E8%BF%99%E4%B8%AA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Ebcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E--------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%BF%E5%AD%90%E5%9E%8B%E5%8F%B7%E6%98%AFimx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20%E6%9D%BF%E4%B8%8A%E6%B3%A8%E5%86%8C%20FTDI%20EEPROM%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%97%A0%E6%95%88%E7%9A%84%20EEPROM%20%E4%B8%8A%E4%B8%8B%E6%96%87%EF%BC%8C%E4%BD%BF%E7%94%A8%20-w%20%E9%80%89%E9%A1%B9%E5%86%99%E5%85%A5%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Ebcu%20eeprom%20-r%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E---------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%BF%E5%AD%90%E5%9E%8B%E5%8F%B7%E6%98%AFimx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20%E6%9D%BF%E4%B8%8A%E6%B3%A8%E5%86%8C%20FTDI%20EEPROM%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%97%A0%E6%95%88%E7%9A%84%20EEPROM%20%E4%B8%8A%E4%B8%8B%E6%96%87%EF%BC%8C%E4%BD%BF%E7%94%A8%20-w%20%E9%80%89%E9%A1%B9%E5%86%99%E5%85%A5%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Edone%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E4%B9%9F%E5%9C%A8%3CSTRONG%3EUbuntu%2022%3C%2FSTRONG%3E%20Host%20%E4%B8%8A%E5%B0%9D%E8%AF%95%E8%BF%87%E8%BF%99%E4%B8%AA%E3%80%82%E4%BD%BF%E7%94%A8%E6%88%91%E7%9A%84%20iMX93%20QSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20bcu%20eeprom%20-w%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E--------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eversion%20bcu_1.1.100-0-gc34d89b%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%BF%E5%AD%90%E5%9E%8B%E5%8F%B7%E6%98%AFimx93evk11%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20%E6%9D%BF%E4%B8%8A%E6%B3%A8%E5%86%8C%20FTDI%20EEPROM%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%97%A0%20EEPROM%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%A0%A1%E9%AA%8C%E5%92%8C%E9%94%99%E8%AF%AF%EF%BC%9Aaaaa%20ffff%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Eftdi_eeprom_decode%EF%BC%9A-1%EF%BC%88EEPROM%E6%A0%A1%E9%AA%8C%E5%92%8C%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%93%A6%E9%99%A4%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%9C%AA%E8%BF%9E%E6%8E%A5%20EEPROM%20%E6%88%96%20EEPROM%20%E7%B1%BB%E5%9E%8B%E6%9C%AA%E7%9F%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20.%2Fbcu%20monitor%20-board%3Dimx93evk11%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E----------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E2%80%9C%20%3CSPAN%3Epac1934_write_bipolar%EF%BC%9Apac%201934%20%E5%A4%B1%E8%B4%A5%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E8%BF%90%E8%A1%8C%3C%2FSPAN%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Eboard%3D%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Eimx93qsb%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3Esudo%20.%2Fbcu%20monitor%20-board%3Dimx93qsb%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3E----------------------------------------------%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E7%BB%99%E6%88%91%E6%8D%95%E8%8E%B7%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E7%94%B5%E6%B5%81%E5%92%8C%E5%8A%9F%E7%8E%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Invalid%20EEPROM%20context%20-%20iMX93%20QSB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242686%22%20target%3D%22_blank%22%3E%40emb-dev%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CPRE%20class%3D%22language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20sudo%20bcu%20eeprom%20-w%20-board%3Dimx93qsb%0A%24%20sudo%20bcu%20eeprom%20-r%20-board%3Dimx93qsb%0A%24%20sudo%20bcu%20monitor%20-board%3Dimx93qsb%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3ESalas.%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
