Installing libimxvpuapi for imx6q
ソリューションへジャンプ
2,679件の閲覧回数
girijapretha
I am trying to install libimxvpuapi library for imx6q. I got the package from below link
GitHub - Freescale/libimxvpuapi: i.MX VPU API Library
When I try to configure through ./waf command, it is failing with below message,
using the vpulib backend
Checking for library vpu : not found
The configuration failed.
Can you please guide me with steps for installing above package.
Thanks in advance.
ラベル(4)
2,369件の閲覧回数
Bio_TICFSL
Hello girijapretha,
You are using a non hardware videos acceleration processor (VPU). or you have no activate the  VPU support on the kernel.
2 返答(返信)
2,370件の閲覧回数
Bio_TICFSL
Hello girijapretha,
2,369件の閲覧回数
girijapretha
Thanks Bio_TICFSL.
I enabled vpu as part of buildroot and now I am able to install the package.
