DDR changes in uboot for i.MX8 M
yashavanthashet
Contributor V
According to i.MX8M documentation, DDR changes are need to be done in u-boot SPL.
Can anybody let me know, in which and all files in uboot, the DDR changes are need to be done?
Is there any documents are available for the same
Thanks in advance,
Yashavantha
Hi Yashavantha
changes are described in attached document p.12 from i.MX8M ddr tool package
i.MX 8M DDR Tool Release
Hi Yashavantha
yashavanthashet
Contributor V
Hi Igor,
In i.MX8QM "register_programming_aid" excel file,  'DDR CFG file' sheet was there, which is missing in i.MX8MQ "register programming aid" excel sheet. Is that not needed in case of i.MX8MQ?
Kindly let me know.
Thanks and Regards,
Yashavantha
yashavanthashet
Contributor V
Dear Igor,
Kindly let me know what bl31.bin (ATF binary) does?
In what case we need to do changes in 'lpddr4_ddrc_cfg.c' file?
Thanks in advance.
Yashavantha
yashavanthashet
Contributor V
Hi Igor,
Very well explained document.
Thank you.
Yashavantha
