Hi sir
I used the uuu with the lst script to flash the images, it seems ok, as blew:
But it seems can't boot, the error log as blew:
Could you give me the solution ?
Solved! Go to Solution.
Seems like there is a problem with the boot.img, could you please share which Android version you are using?
I assume that you are building your own image, could you please share the procedure you follow to build it?
Thank you,
Aldo.
Hi AIdo
Thank you very much. Yes, you are right, it seems the u-boot.img and the boot.img build under the different enviorment, It seems ok when I rebuild all the images under the same enviorment, and download them, it seems ok.
Hello everyone
Is there anything update ?
Hello
Does everyone meet this issue before ?
