Imx93 debugging lvds screen
xiang_1001
The lvds screen is being debugged, the lvds screen is not bright, and there is no signal from the oscilloscope test. There is an error in reading the log. Excuse me, what is the problem?
The device tree configuration is shown in the figure.
Zhiming_Liu
Please restore the original file and re-modify it step by step to troubleshoot which step of the modification went wrong.
Best Regards
Zhiming
xiang_1001
There are two "fsl,imx93-ldb" in the driver. Turn on CONFIG_DRM_FSL_LDB=y and turn off CONFIG_DRM_IMX93_LDB=n, and the error will be gone.
But this 1280*800 lvds screen is still not lit.
Zhiming_Liu
You have modified too many things to be able to determine where the problem is, my suggestion is still to restore the original code and modify it step by step to determine where the problem is, as for the ldb driver problem you mentioned, the normal driver file should be the driver corresponding to CONFIG_DRM_IMX93_LDB
Best Regards
Zhiming
