Imx93 GPIO interrupt
frebourg
How to use GPIO interrupt on kernel driver (on linux 6.6)
Is somebody  can share sample code of linux driver using interrupt on GPIO
Technical Department | Development Engineer
Einea | Z.I. rue Lavoisier, 76260 Eu
Manuel_Salas
Hello @frebourg
I hope you are doing well.
Unfortunately this is difficult to achieve, it is preferable to assing resources to be used from Cortex A and from Cortex M.
Maybe you can make an application for Cortex M and communicate the cores in RPMSG.
You can take a look to this post as started point:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/GPIOs-Interrupt-i-MX93-M33/ta-p/1909424
I hope this information can helps to you.
Salas.
frebourg
Adding current driver source and dts.
gpio_interrupt  declared in /proc/interrupts
root@board:~# cat /proc/interrupts
           CPU0       CPU1
 13:      36966      43746     GICv3  26 Level     arch_timer
 14:      11423      14496     GICv3 106 Level     timer@44290000
 96:          0          0     GICv3  98 Level     42560000.spi
 99:       7450          0     GICv3 119 Level     mmc1
100:          0          0  gpio-vf610   0 Edge      42860000.mmc cd
101:          0          0  gpio-vf610  10 Edge      gpio_interrupt
Err:          0
in /sys/kernel/debug/gpio ,  GPIO sees OK .
root@board:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 512-543, parent: platform/43810000.gpio, 43810000.gpio:
 gpio-522 (IRQ_AEMPTY          |gpio_interrupt      ) in  hi IRQ
 gpio-523 (IRQ_AFULL           )
Everithing seems ok,  Checked GPIO change with scope.   But no interrupt detected .
Any idea  ?
frebourg
Interrupt is ok  if cortex-M not started.
Is it possible to have interruption on Cortex-A and Cortex-M  on the same GPIO (GPIO2) ?
Manuel_Salas
Hello @frebourg
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-1965666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EImx93%20GPIO%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1965666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20to%20use%20GPIO%20interrupt%20on%20kernel%20driver%20(on%20linux%206.6)%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20somebody%26nbsp%3B%20can%20share%20sample%20code%20of%20linux%20driver%20using%20interrupt%20on%20GPIO%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1968103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Imx93%20GPIO%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1968103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205634%22%20target%3D%22_blank%22%3E%40frebourg%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3EUnfortunately%20this%20is%20difficult%20to%20achieve%2C%20it%20is%20preferable%20to%20assing%20resources%20to%20be%20used%20from%20Cortex%20A%20and%20from%20Cortex%20M.%3C%2FP%3E%0A%3CP%3EMaybe%20you%20can%20make%20an%20application%20for%20Cortex%20M%20and%20communicate%20the%20cores%20in%20RPMSG.%3C%2FP%3E%0A%3CP%3EYou%20can%20take%20a%20look%20to%20this%20post%20as%20started%20point%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGPIOs-Interrupt-i-MX93-M33%2Fta-p%2F1909424%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FGPIOs-Interrupt-i-MX93-M33%2Fta-p%2F1909424%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20hope%20this%20information%20can%20helps%20to%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1967692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Imx93%20GPIO%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1967692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EInterrupt%20is%20ok%26nbsp%3B%20if%20cortex-M%20not%20started.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20it%20possible%20to%20have%20interruption%20on%20Cortex-A%20and%20Cortex-M%26nbsp%3B%20on%20the%20same%20GPIO%20(GPIO2)%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1965724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Imx93%20GPIO%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1965724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAdding%20current%20driver%20source%20and%20dts.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3Egpio_interrupt%26nbsp%3B%20declared%20in%20%2Fproc%2Finterrupts%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eroot%40board%3A~%23%20cat%20%2Fproc%2Finterrupts%0A%20%20%20%20%20%20%20%20%20%20%20CPU0%20%20%20%20%20%20%20CPU1%0A%2013%3A%20%20%20%20%20%2036966%20%20%20%20%20%2043746%20%20%20%20%20GICv3%20%2026%20Level%20%20%20%20%20arch_timer%0A%2014%3A%20%20%20%20%20%2011423%20%20%20%20%20%2014496%20%20%20%20%20GICv3%20106%20Level%20%20%20%20%20timer%4044290000%0A...%0A%2096%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20%2098%20Level%20%20%20%20%2042560000.spi%0A%2099%3A%20%20%20%20%20%20%207450%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20119%20Level%20%20%20%20%20mmc1%0A100%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20gpio-vf610%20%20%200%20Edge%20%20%20%20%20%2042860000.mmc%20cd%0A101%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20gpio-vf610%20%2010%20Edge%20%20%20%20%20%20gpio_interrupt%0A...%0AErr%3A%20%20%20%20%20%20%20%20%20%200%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3Ein%20%2Fsys%2Fkernel%2Fdebug%2Fgpio%20%2C%26nbsp%3B%20GPIO%20sees%20OK%20.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eroot%40board%3A~%23%20cat%20%2Fsys%2Fkernel%2Fdebug%2Fgpio%0Agpiochip0%3A%20GPIOs%20512-543%2C%20parent%3A%20platform%2F43810000.gpio%2C%2043810000.gpio%3A%0A..%0A%20gpio-522%20(IRQ_AEMPTY%20%20%20%20%20%20%20%20%20%20%7Cgpio_interrupt%20%20%20%20%20%20)%20in%20%20hi%20IRQ%0A%20gpio-523%20(IRQ_AFULL%20%20%20%20%20%20%20%20%20%20%20)%0A..%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3EEverithing%20seems%20ok%2C%26nbsp%3B%20Checked%20GPIO%20change%20with%20scope.%26nbsp%3B%20%26nbsp%3BBut%20no%20interrupt%20detected%20.%3CBR%20%2F%3E%3CBR%20%2F%3EAny%20idea%26nbsp%3B%20%3F%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
