Imx93 GPIO interrupt
4,864 次查看
frebourg
How to use GPIO interrupt on kernel driver (on linux 6.6)
Is somebody  can share sample code of linux driver using interrupt on GPIO
Technical Department | Development Engineer
Einea | Z.I. rue Lavoisier, 76260 Eu
4,781 次查看
Manuel_Salas
Hello @frebourg
I hope you are doing well.
Unfortunately this is difficult to achieve, it is preferable to assing resources to be used from Cortex A and from Cortex M.
Maybe you can make an application for Cortex M and communicate the cores in RPMSG.
You can take a look to this post as started point:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/GPIOs-Interrupt-i-MX93-M33/ta-p/1909424
I hope this information can helps to you.
Salas.
4,849 次查看
frebourg
Adding current driver source and dts.
gpio_interrupt  declared in /proc/interrupts
root@board:~# cat /proc/interrupts
           CPU0       CPU1
 13:      36966      43746     GICv3  26 Level     arch_timer
 14:      11423      14496     GICv3 106 Level     timer@44290000
 96:          0          0     GICv3  98 Level     42560000.spi
 99:       7450          0     GICv3 119 Level     mmc1
100:          0          0  gpio-vf610   0 Edge      42860000.mmc cd
101:          0          0  gpio-vf610  10 Edge      gpio_interrupt
Err:          0
in /sys/kernel/debug/gpio ,  GPIO sees OK .
root@board:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 512-543, parent: platform/43810000.gpio, 43810000.gpio:
 gpio-522 (IRQ_AEMPTY          |gpio_interrupt      ) in  hi IRQ
 gpio-523 (IRQ_AFULL           )
Everithing seems ok,  Checked GPIO change with scope.   But no interrupt detected .
Any idea  ?
4,797 次查看
frebourg
Interrupt is ok  if cortex-M not started.
Is it possible to have interruption on Cortex-A and Cortex-M  on the same GPIO (GPIO2) ?
4,782 次查看
Manuel_Salas
Hello @frebourg
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-1965666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EImx93%20GPIO%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1965666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8A%E4%BD%BF%E7%94%A8%20GPIO%20%E4%B8%AD%E6%96%AD%EF%BC%88%E5%9C%A8%20Linux%206.6%20%E4%B8%8A%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%BD%BF%E7%94%A8%20GPIO%20%E4%B8%AD%E6%96%AD%E7%9A%84%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1967692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AImx93%20GPIO%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1967692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%20cortex-M%20%E6%9C%AA%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%88%99%E4%B8%AD%E6%96%AD%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%90%8C%E4%B8%80%20GPIO%EF%BC%88GPIO2%EF%BC%89%E4%B8%8A%E7%9A%84%20Cortex-A%20%E5%92%8C%20Cortex-M%20%E6%98%AF%E5%90%A6%E5%8F%AF%E8%83%BD%E5%8F%91%E7%94%9F%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1965724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AImx93%20GPIO%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1965724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%BD%93%E5%89%8D%E9%A9%B1%E5%8A%A8%E6%BA%90%E5%92%8C%20dts%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Egpio_interrupt%20%E5%9C%A8%20%2Fproc%2Finterrupts%20%E4%B8%AD%E5%A3%B0%E6%98%8E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40board%3A~%23%20cat%20%2Fproc%2Finterrupts%0A%20%20%20%20%20%20%20%20%20%20%20CPU0%20%20%20%20%20%20%20CPU1%0A%2013%3A%20%20%20%20%20%2036966%20%20%20%20%20%2043746%20%20%20%20%20GICv3%20%2026%20Level%20%20%20%20%20arch_timer%0A%2014%3A%20%20%20%20%20%2011423%20%20%20%20%20%2014496%20%20%20%20%20GICv3%20106%20Level%20%20%20%20%20timer%4044290000%0A...%0A%2096%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20%2098%20Level%20%20%20%20%2042560000.spi%0A%2099%3A%20%20%20%20%20%20%207450%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20119%20Level%20%20%20%20%20mmc1%0A100%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20gpio-vf610%20%20%200%20Edge%20%20%20%20%20%2042860000.mmc%20cd%0A101%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20gpio-vf610%20%2010%20Edge%20%20%20%20%20%20gpio_interrupt%0A...%0AErr%3A%20%20%20%20%20%20%20%20%20%200%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E5%9C%A8%20%2Fsys%2Fkernel%2Fdebug%2Fgpio%20%E4%B8%AD%EF%BC%8CGPIO%20%E7%9C%8B%E5%88%B0%20OK%20%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40board%3A~%23%20cat%20%2Fsys%2Fkernel%2Fdebug%2Fgpio%0Agpiochip0%3A%20GPIOs%20512-543%2C%20parent%3A%20platform%2F43810000.gpio%2C%2043810000.gpio%3A%0A..%0A%20gpio-522%20(IRQ_AEMPTY%20%20%20%20%20%20%20%20%20%20%7Cgpio_interrupt%20%20%20%20%20%20)%20in%20%20hi%20IRQ%0A%20gpio-523%20(IRQ_AFULL%20%20%20%20%20%20%20%20%20%20%20)%0A..%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E4%B8%80%E5%88%87%E4%BC%BC%E4%B9%8E%E9%83%BD%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%A3%80%E6%9F%A5%E4%BA%86%20GPIO%20%E9%9A%8F%E8%8C%83%E5%9B%B4%E7%9A%84%E5%8F%98%E5%8C%96%E3%80%82%E4%BD%86%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%AD%E6%96%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
