Imx8mq how to use hardware video decoding?
4,412件の閲覧回数
传策薛
Contributor V
Hi community:
   I use yocto morty with  4.9.51_ga, Is there an example of hardware video decoding (we need to use two video decoding)?
Thanks a lot!
4,142件の閲覧回数
igorpadykov
Hi 传策 薛
one can try to follow sect.6.6.2.3 Unit test attached Linux Manual.
3 返答(返信)
4,143件の閲覧回数
igorpadykov
Hi 传策 薛
4,142件の閲覧回数
传策薛
Contributor V
Thank you , I found it ,it is ""imx-vpu-hantro
4,142件の閲覧回数
传策薛
Contributor V
Hi igorpadykov:
   Thanks, Well, is there a link to download the source code of these unit tests?
