Imx8mq how to use hardware video decoding?
2,968 次查看
传策薛
Hi community:
   I use yocto morty with  4.9.51_ga, Is there an example of hardware video decoding (we need to use two video decoding)?
Thanks a lot!
2,699 次查看
Hi 传策 薛
one can try to follow sect.6.6.2.3 Unit test attached Linux Manual.
2,700 次查看
Hi 传策 薛
2,699 次查看
传策薛
Thank you , I found it ,it is ""imx-vpu-hantro
2,699 次查看
传策薛
Hi igorpadykov:
   Thanks, Well, is there a link to download the source code of these unit tests?
