Imx6ull low temperature test, get CPU temperature is an error value, how to solve? Thank you!
4,724件の閲覧回数
sunzhg20
6 返答(返信)
4,691件の閲覧回数
Yuri
@sunzhg20
  I've sent You the patch.
Yuri.
4,687件の閲覧回数
sunzhg20
I have received. Thank you!.
4,709件の閲覧回数
toanjunifer
Senior Contributor I
You should ask a question in English for quickly support.
4,705件の閲覧回数
sunzhg20
ok thanks!
4,717件の閲覧回数
toanjunifer
Your question seems duplicated. Refer Temperature monitor of IMX6UL doesn't work as expected
4,712件の閲覧回数
sunzhg20
但是这个连接有个补丁包,是邮件发送的,但是没公开出来,所以我就再次提问了
