Imx6ull low temperature test, get CPU temperature is an error value, how to solve? Thank you!
3,214 次查看
sunzhg20
6 回复数
3,181 次查看
Yuri
@sunzhg20
  I've sent You the patch.
Yuri.
3,177 次查看
sunzhg20
I have received. Thank you!.
3,199 次查看
toanjunifer
Senior Contributor I
You should ask a question in English for quickly support.
3,195 次查看
sunzhg20
ok thanks!
3,207 次查看
toanjunifer
Your question seems duplicated. Refer Temperature monitor of IMX6UL doesn't work as expected
3,202 次查看
sunzhg20
但是这个连接有个补丁包,是邮件发送的,但是没公开出来,所以我就再次提问了
