Imx6ull low temperature test, get CPU temperature is an error value, how to solve? Thank you!
sunzhg20
Yuri
@sunzhg20
  I've sent You the patch.
Yuri.
sunzhg20
I have received. Thank you!.
toanjunifer
Senior Contributor I
You should ask a question in English for quickly support.
sunzhg20
ok thanks!
toanjunifer
Your question seems duplicated. Refer Temperature monitor of IMX6UL doesn't work as expected
sunzhg20
但是这个连接有个补丁包,是邮件发送的,但是没公开出来,所以我就再次提问了
