Import project(s) from file system MCUXpresso IDE Build Error
1,285 次查看
bobhi009
1. Use "Import SDK example(s)... "Import project 'evkmimxrt1020_lwip_udpecho_freertos' to compile.
2. Delete in Project Explorer (but do not delete the project in the workspace).
3. Use "import project(s) from file system" to import the project from the workspace again.
4. The compilation fails
1,243 次查看
jingpan
Hi @bobhi009 ,
I made a same test but didn't see the problem. What's the version of MCUXpresso and SDK?
Jing
1,233 次查看
bobhi009
MCUXpresso IDE v11.5.1 and SDK_2_11_0_EVK-MIMXRT1020
It seems that only projects that include lwip have this problem.
1,230 次查看
jingpan
Hi @bobhi009 ,
You can try to update IDE to 11.7.
Jing
