IMX93 - Poky - Error on U-Boot configuration fspi
il_ciancio
Hello NXP experts,
I am following "UG10164, i.MX Yocto Project User's Guide,  Rev. LF6.12.3_1.0.0 — 31 March 2025".
I have to configure u-boot with
  • uboot_config_imx93evk="sd fspi"
as showed in chapter "5.5 U-Boot configuration".
As suggested i runned the command:
  • echo "UBOOT_CONFIG = \"sd fspi\"" >> conf/local.conf
and after i runned
  • bitbake core-image-minimal.
An error is raised during the bitbake:
ERROR: Nothing PROVIDES 'virtual/bootloader' (but /home/imx-yocto-bsp/sources/poky/meta/recipes-core/images/core-image-minimal.bb DEPENDS on or otherwise requires it)
u-boot-qoriq PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
u-boot PROVIDES virtual/bootloader but was skipped: The selected UBOOT_CONFIG key ['sd', 'fspi'] has no match in dict_keys(['sd', 'ecc', 'ld']).
u-boot-fslc PROVIDES virtual/bootloader but was skipped: The selected UBOOT_CONFIG key ['sd', 'fspi'] has no match in dict_keys(['sd', 'ecc', 'ld']).
u-boot-imx PROVIDES virtual/bootloader but was skipped: The selected UBOOT_CONFIG key ['sd', 'fspi'] has no match in dict_keys(['sd', 'ecc', 'ld']).
edk2-firmware PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
u-boot-variscite PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
u-boot-toradex PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
u-boot-kontron PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
u-boot-boundary PROVIDES virtual/bootloader but was skipped: incompatible with machine imx93-11x11-lpddr4x-evk (not in COMPATIBLE_MACHINE)
ERROR: Required build target 'core-image-minimal' has no buildable providers.
Missing or unbuildable dependency chain was: ['core-image-minimal', 'virtual/bootloader'].
This is my local.conf file:
MACHINE ??= 'imx93-11x11-lpddr4x-evk'
DISTRO ?= 'fsl-imx-wayland'
EXTRA_IMAGE_FEATURES ?= "debug-tweaks"
USER_CLASSES ?= "buildstats"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS ??= "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
HALT,${TMPDIR},100M,1K \
HALT,${DL_DIR},100M,1K \
HALT,${SSTATE_DIR},100M,1K \
HALT,/tmp,10M,1K"
PACKAGECONFIG:append:pn-qemu-system-native = " sdl"
CONF_VERSION = "2"
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = "1"
# Switch to Debian packaging and include package-management in the image
PACKAGE_CLASSES = "package_deb"
EXTRA_IMAGE_FEATURES += "package-management"
UBOOT_CONFIG = "sd fspi"
What am I missing?
Alessandro
Chavira
HI @il_ciancio!
By default is not possible you should do some modifications and we can't validate the image due to the evk board doesn't have fspi installed.
Best Regards!
Chavira
Chavira
Hi @il_ciancio!
Thank you for contacting NXP Support!
I am compiling now.
Try changing UBOOT_CONFIG = "sd fspi" to UBOOT_CONFIG ??= "sd fspi" in the local.conf file.
Best Regards!
Chavira
il_ciancio
Hi @Chavira,
with UBOOT_CONFIG ??= "sd fspi" the bitbake is finished, but in the output folder there is *.wic file but there isn't a Flex-SPI u-boot binary image.
Is there something else?
How is the result of your build?
Chavira
Hi @il_ciancio!
I found the problem!
For some reason the fspi configuration is not included.
You have to add the next lines in the imx93-11x11-lpddr4x-evk.conf file.
UBOOT_CONFIG[fspi] = "${UBOOT_CONFIG_BASENAME}_defconfig"
IMXBOOT_TARGETS_FSPI = "flash_singleboot_flexspi"
IMXBOOT_TARGETS = "${@bb.utils.contains('UBOOT_CONFIG', 'fspi', '${IMXBOOT_TARGETS_FSPI}', 'flash_singleboot', d)}"
after that you can maintain the line UBOOT_CONFIG = "sd fspi"  in local.conf file to deploy both images.
Best Regards!
Chavira
il_ciancio
Hi @Chavira ,
congratulation, great job!
Now the bitabake is finished and i have u-boot*fspi files in my deploy directory.
Just for clarification, which are the kernel/rootfs image "compatible" with fspi? It is always the *.wic file?
thanks a lot and again great work!
Chavira
Hi @il_ciancio!
You can't flash the rootfs in the flash memory.
You can boot from fspi and then use the rootfs flashed in eMMC or SD card.
Best Regards!
Chavira
il_ciancio
Ciao @Chavira.
I have a question, maybe I am misunderstanding something.
I am working with a custom board without eMMC or SD card and It has only a SPI NOR FLASH, the goal is to boot starting from data inside the SPI memory on target IMX93.
There is also this ticket:  all(bootloader, device tree, Linux kernel, rootfs)
It is made a custom UUU script in order to flash data in SPI memory:
  • uboot;
  • dtb;
  • kernel;
  • rootfs;
the flash goes well because it is checked raw data read from spi memory.
After the boot, It is read data from SPI and putted in ram (like a bridge), some env vars are setted and after with the command booti:
  • booti ${loadaddr} ${initrd_addr} ${fdt_addr}
the kernel should boot.
Why did you write "then use the rootfs flashed in eMMC or SD card."? Is it mandatory that rootfs must be in sd/emmc?
I hope that I am clear.
Thanks a lot!
Chavira
HI @il_ciancio!
Best Regards!
Chavira
il_ciancio
thanks for the support!
%3CLINGO-SUB%20id%3D%22lingo-sub-2075324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20experts%2C%3C%2FP%3E%3CP%3EI%20am%20following%20%22UG10164%2C%26nbsp%3Bi.MX%20Yocto%20Project%20User's%20Guide%2C%26nbsp%3B%26nbsp%3BRev.%20LF6.12.3_1.0.0%20%E2%80%94%2031%20March%202025%22.%3C%2FP%3E%3CP%3EI%20have%20to%20configure%20u-boot%20with%3C%2FP%3E%3CUL%3E%3CLI%3Euboot_config_imx93evk%3D%22sd%20fspi%22%3C%2FLI%3E%3C%2FUL%3E%3CP%3Eas%20showed%20in%20chapter%20%225.5%20U-Boot%20configuration%22.%3C%2FP%3E%3CP%3EAs%20suggested%20i%20runned%20the%20command%3A%3C%2FP%3E%3CUL%3E%3CLI%3Eecho%20%22UBOOT_CONFIG%20%3D%20%5C%22sd%20fspi%5C%22%22%20%26gt%3B%26gt%3B%20conf%2Flocal.conf%3C%2FLI%3E%3C%2FUL%3E%3CP%3Eand%20after%20i%20runned%3C%2FP%3E%3CUL%3E%3CLI%3Ebitbake%20core-image-minimal.%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAn%20error%20is%20raised%20during%20the%20bitbake%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EERROR%3A%20Nothing%20PROVIDES%20'virtual%2Fbootloader'%20(but%20%2Fhome%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal.bb%20DEPENDS%20on%20or%20otherwise%20requires%20it)%3CBR%20%2F%3Eu-boot-qoriq%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20The%20selected%20UBOOT_CONFIG%20key%20%5B'sd'%2C%20'fspi'%5D%20has%20no%20match%20in%20dict_keys(%5B'sd'%2C%20'ecc'%2C%20'ld'%5D).%3CBR%20%2F%3Eu-boot-fslc%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20The%20selected%20UBOOT_CONFIG%20key%20%5B'sd'%2C%20'fspi'%5D%20has%20no%20match%20in%20dict_keys(%5B'sd'%2C%20'ecc'%2C%20'ld'%5D).%3CBR%20%2F%3Eu-boot-imx%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20The%20selected%20UBOOT_CONFIG%20key%20%5B'sd'%2C%20'fspi'%5D%20has%20no%20match%20in%20dict_keys(%5B'sd'%2C%20'ecc'%2C%20'ld'%5D).%3CBR%20%2F%3Eedk2-firmware%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot-variscite%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot-toradex%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot-imx%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20The%20selected%20UBOOT_CONFIG%20key%20%5B'sd'%2C%20'fspi'%5D%20has%20no%20match%20in%20dict_keys(%5B'sd'%2C%20'ecc'%2C%20'ld'%5D).%3CBR%20%2F%3Eu-boot-kontron%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot-qoriq%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eu-boot-boundary%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3Eedk2-firmware%20PROVIDES%20virtual%2Fbootloader%20but%20was%20skipped%3A%20incompatible%20with%20machine%20imx93-11x11-lpddr4x-evk%20(not%20in%20COMPATIBLE_MACHINE)%3CBR%20%2F%3EERROR%3A%20Required%20build%20target%20'core-image-minimal'%20has%20no%20buildable%20providers.%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'core-image-minimal'%2C%20'virtual%2Fbootloader'%5D.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FBLOCKQUOTE%3E%3CP%3EThis%20is%20my%20local.conf%20file%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx93-11x11-lpddr4x-evk'%3CBR%20%2F%3EDISTRO%20%3F%3D%20'fsl-imx-wayland'%3CBR%20%2F%3EEXTRA_IMAGE_FEATURES%20%3F%3D%20%22debug-tweaks%22%3CBR%20%2F%3EUSER_CLASSES%20%3F%3D%20%22buildstats%22%3CBR%20%2F%3EPATCHRESOLVE%20%3D%20%22noop%22%3CBR%20%2F%3EBB_DISKMON_DIRS%20%3F%3F%3D%20%22%5C%3CBR%20%2F%3ESTOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3CBR%20%2F%3ESTOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3CBR%20%2F%3ESTOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3CBR%20%2F%3ESTOPTASKS%2C%2Ftmp%2C100M%2C100K%20%5C%3CBR%20%2F%3EHALT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3CBR%20%2F%3EHALT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3CBR%20%2F%3EHALT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%20%5C%3CBR%20%2F%3EHALT%2C%2Ftmp%2C10M%2C1K%22%3CBR%20%2F%3EPACKAGECONFIG%3Aappend%3Apn-qemu-system-native%20%3D%20%22%20sdl%22%3CBR%20%2F%3ECONF_VERSION%20%3D%20%222%22%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3CBR%20%2F%3EACCEPT_FSL_EULA%20%3D%20%221%22%3C%2FP%3E%3CP%3E%23%20Switch%20to%20Debian%20packaging%20and%20include%20package-management%20in%20the%20image%3CBR%20%2F%3EPACKAGE_CLASSES%20%3D%20%22package_deb%22%3CBR%20%2F%3EEXTRA_IMAGE_FEATURES%20%2B%3D%20%22package-management%22%3CBR%20%2F%3EUBOOT_CONFIG%20%3D%20%22sd%20fspi%22%3C%2FP%3E%3CBR%20%2F%3E%3C%2FBLOCKQUOTE%3E%3CP%3EWhat%20am%20I%20missing%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EAlessandro%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2075324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2079733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2079733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethanks%20for%20the%20support!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2079254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2079254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248332%22%20target%3D%22_blank%22%3E%40il_ciancio%3C%2FA%3E!%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EBy%20default%20is%20not%20possible%20you%20should%20do%20some%20modifications%20and%20we%20can't%20validate%20the%20image%20due%20to%20the%20evk%20board%20doesn't%20have%20fspi%20installed.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2079166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2079166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECiao%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E.%3C%2FP%3E%3CP%3EI%20have%20a%20question%2C%20maybe%20I%20am%20misunderstanding%20something.%3C%2FP%3E%3CP%3EI%20am%20working%20with%20a%20custom%20board%20without%20eMMC%20or%20SD%20card%20and%20It%20has%20only%20a%20SPI%20NOR%20FLASH%2C%20the%20goal%20is%20to%20boot%20starting%20from%20data%20inside%20the%20SPI%20memory%20on%20target%20IMX93.%3C%2FP%3E%3CP%3EThere%20is%20also%20this%20ticket%3A%26nbsp%3B%20all(bootloader%2C%20device%20tree%2C%20Linux%20kernel%2C%20rootfs)%3C%2FP%3E%3CUL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fall-bootloader-device-tree-Linux-kernel-rootfs-in-spi-nor-demo%2Fta-p%2F1663994%22%20target%3D%22_blank%22%3Eall(bootloader%2C%20device%20tree%2C%20Linux%20kernel%2C%20rootfs)%20in%20spi%20nor%20demo%20imx8qxpc0%20mek%20-%20NXP%20Community%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EIt%20is%20made%20a%20custom%20UUU%20script%20in%20order%20to%20flash%20data%20in%20SPI%20memory%3A%3C%2FP%3E%3CUL%3E%3CLI%3Euboot%3B%3C%2FLI%3E%3CLI%3Edtb%3B%3C%2FLI%3E%3CLI%3Ekernel%3B%3C%2FLI%3E%3CLI%3Erootfs%3B%3C%2FLI%3E%3C%2FUL%3E%3CP%3Ethe%20flash%20goes%20well%20because%20it%20is%20checked%20raw%20data%20read%20from%20spi%20memory.%3C%2FP%3E%3CP%3EAfter%20the%20boot%2C%20It%20is%20read%20data%20from%20SPI%20and%20putted%20in%20ram%20(like%20a%20bridge)%2C%20some%20env%20vars%20are%20setted%20and%20after%20with%20the%20command%20booti%3A%3C%2FP%3E%3CUL%3E%3CLI%3Ebooti%20%24%7Bloadaddr%7D%20%24%7Binitrd_addr%7D%20%24%7Bfdt_addr%7D%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CBR%20%2F%3Ethe%20kernel%20should%20boot.%3CBR%20%2F%3EWhy%20did%20you%20write%26nbsp%3B%22then%20use%20the%20rootfs%20flashed%20in%20eMMC%20or%20SD%20card.%22%3F%20Is%20it%20mandatory%20that%20rootfs%20must%20be%20in%20sd%2Femmc%3F%3C%2FP%3E%3CP%3EI%20hope%20that%20I%20am%20clear.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20a%20lot!%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2079061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2079061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248332%22%20target%3D%22_blank%22%3E%40il_ciancio%3C%2FA%3E!%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EYou%20can't%20flash%20the%20rootfs%20in%20the%20flash%20memory.%3C%2FP%3E%0A%3CP%3EYou%20can%20boot%20from%20fspi%20and%20then%20use%20the%20rootfs%20flashed%20in%20eMMC%20or%20SD%20card.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3Econgratulation%2C%20great%20job!%3C%2FP%3E%3CP%3ENow%20the%20bitabake%20is%20finished%20and%20i%20have%20u-boot*fspi%20files%20in%20my%20deploy%20directory.%3C%2FP%3E%3CP%3EJust%20for%20clarification%2C%20which%20are%20the%20kernel%2Frootfs%20image%20%22compatible%22%20with%20fspi%3F%20It%20is%20always%20the%20*.wic%20file%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks%20a%20lot%20and%20again%20great%20work!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248332%22%20target%3D%22_blank%22%3E%40il_ciancio%3C%2FA%3E!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20found%20the%20problem!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFor%20some%20reason%20the%20fspi%20configuration%20is%20not%20included.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYou%20have%20to%20add%20the%20next%20lines%20in%20the%20%3CSTRONG%3Eimx93-11x11-lpddr4x-evk.conf%20%3C%2FSTRONG%3Efile.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3EUBOOT_CONFIG%5Bfspi%5D%20%3D%20%22%24%7BUBOOT_CONFIG_BASENAME%7D_defconfig%22%0A%0AIMXBOOT_TARGETS_FSPI%20%3D%20%22flash_singleboot_flexspi%22%0A%0AIMXBOOT_TARGETS%20%3D%20%22%24%7B%40bb.utils.contains('UBOOT_CONFIG'%2C%20'fspi'%2C%20'%24%7BIMXBOOT_TARGETS_FSPI%7D'%2C%20'flash_singleboot'%2C%20d)%7D%22%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1744301229139.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1744301229139.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F332565i263D14C7F42C7438%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1744301229139.png%22%20alt%3D%22Chavira_1-1744301229139.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eafter%20that%20you%20can%20maintain%20the%20line%20%3CSTRONG%3EUBOOT_CONFIG%20%3D%20%22sd%20fspi%22%26nbsp%3B%3C%2FSTRONG%3E%20in%3CSTRONG%3E%20local.conf%3C%2FSTRONG%3E%20file%20to%20deploy%20both%20images.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_2-1744301372043.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_2-1744301372043.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F332567i905E3153099D560E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_2-1744301372043.png%22%20alt%3D%22Chavira_2-1744301372043.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2077112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2077112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206761%22%20target%3D%22_blank%22%3E%40Chavira%3C%2FA%3E%2C%3CBR%20%2F%3Ewith%20UBOOT_CONFIG%20%3F%3F%3D%20%22sd%20fspi%22%20the%20bitbake%20is%20finished%2C%20but%20in%20the%20output%20folder%20there%20is%20*.wic%20file%20but%20there%20isn't%20a%20Flex-SPI%20u-boot%20binary%20image.%3CBR%20%2F%3EIs%20there%20something%20else%3F%3CBR%20%2F%3EHow%20is%20the%20result%20of%20your%20build%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX93%20-%20Poky%20-%20Error%20on%20U-Boot%20configuration%20fspi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248332%22%20target%3D%22_blank%22%3E%40il_ciancio%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20NXP%20Support!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20am%20compiling%20now.%3C%2FP%3E%0A%3CP%3ETry%20changing%20%3CSTRONG%3EUBOOT_CONFIG%20%3D%20%22sd%20fspi%22%20%3C%2FSTRONG%3Eto%20%3CSTRONG%3EUBOOT_CONFIG%20%3F%3F%3D%20%22sd%20fspi%22%26nbsp%3B%3C%2FSTRONG%3Ein%20the%20local.conf%20file.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E
