IMX8X ADC_IN0 Configuration Problem
1,018 次查看
jack_huang1
Dear:
       In IMX8QX scheme, ADC_IN0 needs to be multiplexed as GPIO. When configured as output, no matter the output is 0 or 1, the voltage on the pin does not change. The configuration is as follows:
        SC_P_ADC_IN0_LSIO_GPIO1_IO10 0x0600006C /*phy1_reset*/
         or
          SC_P_ADC_IN0_LSIO_GPIO1_IO10 0x0600004C /*phy1_reset*/
       Please confirm whether there is a problem when ADC_IN0 is reused as gpio. Because other pins we normally configure for gpio multiplexing have no problem, but now this ADC_IN0 after multiplexing control has no reaction?
        Thank you!
         Best Regards!
998 次查看
joanxie
966 次查看
jack_huang1
Dears:
          The problem has been solved. Thanks!
Best  Regards!
