IMX8QXP drmModeGetResources failed (Operation not supported) REEOR
3,760 次查看
wang12zhe
environment
IMX8QXP EVK
Yocto:L5.10.35_2.0.0
I'm trying to run QT application on IMX8QXP EVK board,but get below error:
root@imx8qxpmek:~#
root@imx8qxpmek:~#
root@imx8qxpmek:~# ./TestVideo -platform eglfs
QML debugging is enabled. Only use this in a safe environment.
Cannot create window: no screens available[ 494.233153] audit: type=1701 audit(1616582007.628:9): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=624 comm="TestVideo" exe="/home/root/TestVideo" sig=6 res=1
Aborted
root@imx8qxpmek:~# dmesg -c
root@imx8qxpmek:~#
please give me any suggestion,thanks very much
3,296 次查看
f1engmin11
@wang12zhe
Excuse me, have your problem solved?    I met the same problem on imx8mmini  EVK . @Zhiming_Liu
3,755 次查看
Zhiming_Liu
@wang12zhe
Do you try other drm card node?
