IMX8QXP RMII KSZ8041
1,511 次查看
Chethanbg
Currently in RMII mode we are using 25 Mhz crystal mode
The KSZ8041RNL generates the 50MHz RMII REF_CLK and outputs it to the MAC
attached is the block diagram for your reference.
In pin configuration RGMII_TXC should be configured as ENET0_RCLK50M_IN input  right?
IMX8QXP_ENET0_RGMII_TXC_CONN_ENET0_RCLK50M_IN                               0x06000061
Also let us know the pad settings  0x06000061 is correct
1,493 次查看
riteshmpatel
Hi @Chethanbg,
I hope you are doing well.
Your understanding is correct and the pad settings also seem to be correct.
Thanks & Regards,
Ritesh M Patel
