IMX8MQ fastboot devices listing empty
3,636 次查看
chaitanyaarur
Hi Everyone,
In IMX8MQ, fastboot devices listing empty.
"USB Download Gadget" is found in device manager.  But, updating drivers is not working.
Please suggest.
Chaitanya.A
3,623 次查看
Zhiming_Liu
3,608 次查看
chaitanyaarur
"USB download gadget" is still displayed in device manager after updating drivers as per the above procedure.
Updating Drivers is the only solution?.
Is there any other root cause for this?.
Chaitanya.A.
3,624 次查看
Zhiming_Liu
@chaitanyaarur
https://community.nxp.com/t5/i-MX-Processors/MX8MM-won-t-enter-fastboot-mode/m-p/937720#M140466
This should help you, you need change driver type to enter fastboot mode.
3,588 次查看
chaitanyaarur
@Zhiming_Liu
Thank you very much for reply.
In windows driver update may have issue it seems.
After switching to linux it worked out. But, we need to pass the command based on device id.
1. lsusb -> get device id.
2. fastboot -i <device id> devices.
