IMX8MQ fastboot devices listing empty
4,555件の閲覧回数
chaitanyaarur
Hi Everyone,
In IMX8MQ, fastboot devices listing empty.
"USB Download Gadget" is found in device manager.  But, updating drivers is not working.
Please suggest.
Chaitanya.A
4,542件の閲覧回数
Zhiming_Liu
3 返答(返信)
4,527件の閲覧回数
chaitanyaarur
"USB download gadget" is still displayed in device manager after updating drivers as per the above procedure.
Updating Drivers is the only solution?.
Is there any other root cause for this?.
Chaitanya.A.
4,543件の閲覧回数
Zhiming_Liu
@chaitanyaarur
https://community.nxp.com/t5/i-MX-Processors/MX8MM-won-t-enter-fastboot-mode/m-p/937720#M140466
This should help you, you need change driver type to enter fastboot mode.
4,507件の閲覧回数
chaitanyaarur
@Zhiming_Liu
Thank you very much for reply.
In windows driver update may have issue it seems.
After switching to linux it worked out. But, we need to pass the command based on device id.
1. lsusb -> get device id.
2. fastboot -i <device id> devices.
