IMX8MP hifi4 dsp codec library
5,365件の閲覧回数
jiada
Hello NXP support team
We are evaluating hifi4 dsp on iMX8MP, so far we are able to compile DSP framework, unit-test, from imx-audio-framework , and confirmed hifi4 dsp can be started/stopped via sysfs interface
But executing of unit-test failed with error message
root@imx8mpevk:~# dsp_test.out -f1 -d16 -itest.mp3 -otest.pcm
Cadence Audio Framework (Hostless) : 'Decoder'
Build: NON_XTENSA, RTOS: Linux, On: Jan 10 2023 23:53:16
Copyright (c) 2015-2020 Cadence Design Systems, Inc.
Lib Name : Audio Framework (Hostless)
Lib Version : 2.6
API Version : 2.0
Audio Device Ready
xaf_load_library failed, Error code : -2 (invalid value at src/xaf-fsl-dec-test.c:513)
By looking at unit-test source code and  i.MX DSP User's Guide (nxp.com)
I think this is because I am missing DSP codec and DSP codec wrapper libraries,
which needs authorization from NXP marketing or can be downloaded from yocto mirror server
(but so far I am not able to find where to download)
Could you please provide us required DSP codec and codec wrapper libraries
or let us know where to download?
DSP codec & wrapper library: (need authorization from NXP marketing)
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_codec_wrap.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_mp3_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_aac_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_bsac_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_dabplus_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_drm_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_mp2_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_sbc_dec.so
/usr/lib/imx-mm/audio-codec/dsp/lib_dsp_sbc_enc.so
/usr/lib/imx-mm/audio-codec/dsp/lib_wma10d_wrap_dsp.so
DSP codec wrapper library: (can be downloaded from yocto mirror server)
/usr/lib/imx-mm/audio-codec/dsp/lib_mp3d_wrap_dsp.so
/usr/lib/imx-mm/audio-codec/dsp/lib_aacd_wrap_dsp.so
/usr/lib/imx-mm/audio-codec/dsp/lib_vorbisd_wrap_dsp.so
/usr/lib/imx-mm/audio-codec/dsp/lib_nbamrd_wrap_dsp.so
/usr/lib/imx-mm/audio-codec/dsp/lib_wbamrd_wrap_dsp.so
(listed in “7.2 Binary files in Linux OS rootfs” of i.MX DSP User's Guide (nxp.com) )
Jiada
7 返答(返信)
4,649件の閲覧回数
panpanjiangjiang
According to the i.MX DSP User's Guide documentation our problem was solved, thank you very much。
5,329件の閲覧回数
joanxie
I have already  mailed to you, pls check the mail
4,696件の閲覧回数
praveen_yaramada
Hi @joanxie , Can you also send me a copy of the NXP's codec library ? I am stuck in the similar fashion. I could not locate the libraries or the Yocto mirror site. My platform is also a iMX8 MP EVK.
Thankyou
4,662件の閲覧回数
joanxie
pls create a new case for your request
4,750件の閲覧回数
panpanjiangjiang
Hi @joanxie
I have already resolved the previous issue, but now I want to integrate our own audio codec library because the desired codec protocol is not available. How can we integrate our own audio codec library into the DSP?
4,657件の閲覧回数
joanxie
if you still have issue about this, pls create a new case for this, and uploaded detailed your use case information
4,986件の閲覧回数
mrjacob
Hi @joanxie
I have mailed to you, pls check
Thanks.
