IMX8MP eMMC IOMUX issues
已解决
跳至解决方案
5,640 次查看
petertseng
Our customer's IMX8MP board replaced the eMMC IOMUX pins.
&usdhc3 {
	assigned-clocks = <&clk IMX8MP_CLK_USDHC3>;
	assigned-clock-rates = <400000000>;
	pinctrl-names = "default", "state_100mhz", "state_200mhz";
	pinctrl-0 = <&pinctrl_usdhc3>;
	pinctrl-1 = <&pinctrl_usdhc3_100mhz>;
	pinctrl-2 = <&pinctrl_usdhc3_200mhz>;
	bus-width = <8>;
	non-removable;
	status = "okay";
&iomuxc {
	pinctrl_usdhc3: usdhc3grp {
		fsl,pins = <
			MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK		0x190
			MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD		0x1d0
			MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0	0x1d0
			MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1		0x1d0
			MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2	0x1d0
			MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3		0x1d0
			MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4		0x1d0
			MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5	0x1d0
			MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6		0x1d0
			MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7		0x1d0
			MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE	0x190
	pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp {
		fsl,pins = <
			MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK		0x194
			MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD		0x1d4
			MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0	0x1d4
			MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1		0x1d4
			MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2	0x1d4
			MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3		0x1d4
			MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4		0x1d4
			MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5	0x1d4
			MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6		0x1d4
			MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7		0x1d4
			MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE	0x194
	pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp {
		fsl,pins = <
			MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK		0x196
			MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD		0x1d6
			MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0	0x1d6
			MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1		0x1d6
			MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2	0x1d6
			MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3		0x1d6
			MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4		0x1d6
			MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5	0x1d6
			MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6		0x1d6
			MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7		0x1d6
			MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE	0x196
But the clock is still measured on the NAND_WE_B pin.
Please help me in resolving this error
Thanks in advance,
Best Regards
Peter
1 解答
5,550 次查看
Zhiming_Liu
Hi @petertseng
Yes, the behavior of bootrom is fixed, we can't let it boot from ENET pins. The usdhc3 clock can only from NAND_WE_B.alt2 when boot.
Best Regards
Zhiming
在原帖中查看解决方案
9 回复数
5,604 次查看
Zhiming_Liu
Hi @petertseng
Does customer comment the iomux about NAND_WE_B ?
Best Regards
Zhiming
5,589 次查看
petertseng
Hi Zhiming,
The customer specifies NAND_WE_B as a general GPIO.
Best Regards
Peter
5,585 次查看
Zhiming_Liu
Hi @petertseng
Can customer share their device tree file?
Best Regards
Zhiming
5,580 次查看
petertseng
Hi Zhiming,
MX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17 0x194
Best Regards
Peter
5,567 次查看
Zhiming_Liu
Hi @petertseng
Customer can try pinctrl value: 0x16
5,564 次查看
petertseng
Hi Zhiming,
Is that what you mean?
MX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17 0x16
Best Regards
Peter
5,562 次查看
Zhiming_Liu
Hi @petertseng
Yes.
Best Regards
Zhiming
5,554 次查看
petertseng
Hi Zhiming,
I think you misunderstood me.
What I want is to connect the eMMC (uSDHC3) to the Ethernet pin (ENET) of the IMX8MP.
And hope to boot from eMMC.
But it seems that IMX8MP cannot do this:
https://community.nxp.com/t5/i-MX-Processors/IMX8MP-Boot-from-eMMC-at-Ethernet-Port/m-p/1295356#M175...
Thank you very much for your reply.
Best Regards
Peter
5,551 次查看
Zhiming_Liu
Hi @petertseng
Best Regards
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-1887631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20eMMC%20IOMUX%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1887631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%AE%A2%E6%88%B7%E7%9A%84%20IMX8MP%20%E6%9D%BF%E5%8F%96%E4%BB%A3%E4%BA%86%20eMMC%20IOMUX%20%E5%BC%95%E8%84%9A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Busdhc3%20%7B%0A%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_USDHC3%26gt%3B%3B%0A%09assigned-clock-rates%20%3D%20%26lt%3B400000000%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3%26gt%3B%3B%0A%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_100mhz%26gt%3B%3B%0A%09pinctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_200mhz%26gt%3B%3B%0A%09bus-width%20%3D%20%26lt%3B8%26gt%3B%3B%0A%09non-removable%3B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Biomuxc%20%7B%0A%09pinctrl_usdhc3%3A%20usdhc3grp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK%09%090x190%0A%09%09%09MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7%09%090x1d0%0A%09%09%09MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE%090x190%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%0A%09pinctrl_usdhc3_100mhz%3A%20usdhc3-100mhzgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK%09%090x194%0A%09%09%09MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7%09%090x1d4%0A%09%09%09MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE%090x194%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%0A%09pinctrl_usdhc3_200mhz%3A%20usdhc3-200mhzgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK%09%090x196%0A%09%09%09MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7%09%090x1d6%0A%09%09%09MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE%090x196%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%97%B6%E9%92%9F%E4%BB%8D%E5%9C%A8NAND_WE_B%E5%BC%95%E8%84%9A%E4%B8%8A%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BD%BC%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1887631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F58032%22%20target%3D%22_blank%22%3E%40petertseng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8Cbootrom%20%E7%9A%84%E8%A1%8C%E4%B8%BA%E5%B7%B2%E4%BF%AE%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B8%8D%E8%83%BD%E8%AE%A9%E5%AE%83%E4%BB%8E%3CSPAN%3EENET%20%E5%BC%95%E8%84%9A%E5%90%AF%E5%8A%A8%E3%80%82%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8Cusdhc3%20%E6%97%B6%E9%92%9F%E5%8F%AA%E8%83%BD%E4%BB%8E%20NAND_WE_B.alt2%20%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E4%BD%A0%E8%AF%AF%E8%A7%A3%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E6%98%AF%E5%B0%86%20eMMC%EF%BC%88uSDHC3%EF%BC%89%E8%BF%9E%E6%8E%A5%E5%88%B0%20IMX8MP%20%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%BC%95%E8%84%9A%EF%BC%88ENET%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%B8%8C%E6%9C%9B%E4%BB%8EeMMC%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86IMX8MP%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FIMX8MP-Boot-from-eMMC-at-Ethernet-Port%2Fm-p%2F1295356%23M175784%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FIMX8MP-Boot-from-eMMC-at-Ethernet-Port%2Fmp%2F1295356%23M175784%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E5%BD%BC%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F58032%22%20target%3D%22_blank%22%3E%40petertseng%3C%2FA%3E%3CBR%20%2F%3E%E6%98%AF%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E6%98%AF%E8%BF%99%E4%B8%AA%E6%84%8F%E6%80%9D%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17%200x16%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BD%BC%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F58032%22%20target%3D%22_blank%22%3E%40petertseng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%AE%A2%E6%88%B7%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%20pinctrl%20%E5%80%BC%EF%BC%9A%20%3CSPAN%3E0x16%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17%200x194%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BD%BC%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F58032%22%20target%3D%22_blank%22%3E%40petertseng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%AE%A2%E6%88%B7%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%BB%96%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%E5%BF%97%E6%98%8E%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AE%A2%E6%88%B7%E6%8C%87%E5%AE%9ANAND_WE_B%E4%B8%BA%E9%80%9A%E7%94%A8GPIO%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BD%BC%E5%BE%97%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20eMMC%20IOMUX%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F58032%22%20target%3D%22_blank%22%3E%40petertseng%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%AE%A2%E6%88%B7%E5%AF%B9%20NAND_WE_B%20%E7%9A%84%20iomux%20%E6%9C%89%E4%BD%95%E8%AF%84%E8%AE%BA%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
