IMX8MP RGMII Connection with No PHY
RyanMKB
I'm trying to setup an ethernet RGMII connection to a switch without using a PHY. Based on other posts I've configured my device tree as follows:
&fec {
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_fec>, <&pinctrl_fec_phy>;
	phy-mode = "rgmii";
	status = "okay";
	fixed-link {
		speed = <1000>;
		full-duplex;
	pinctrl_fec: fecgrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC	0x14>;
	pinctrl_fec_phy: fecphygrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00		0x100>,
			   <MX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01		0x1c0>;
 ethtool shows Link detected: yes, and ifconfig shows that an ip address was assigned. However I am unable to ping to or from the board. Can you confirm if the pins are set correctly for this use case? Thanks.
joanxie
for RGMII, the current bsp supports this as default, you can refer to that
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mp-evk.dts#L39...
joanxie
pls refer to the enclosed file, which is very useful for your case
RyanMKB
Thank you for your reply, I have looked at that document already which helped me get this far. However, I still need further assistance in getting things working.
%3CLINGO-SUB%20id%3D%22lingo-sub-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20trying%20to%20setup%20an%20ethernet%20RGMII%20connection%20to%20a%20switch%20without%20using%20a%20PHY.%20Based%20on%20other%20posts%20I've%20configured%20my%20device%20tree%20as%20follows%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%26amp%3Bfec%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_fec_phy%26gt%3B%3B%0A%09phy-mode%20%3D%20%22rgmii%22%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09fixed-link%20%7B%0A%09%09speed%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%09%09full-duplex%3B%0A%09%7D%3B%0A%0A%7D%3B%0A%0A%09pinctrl_fec%3A%20fecgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%200x14%3D%22%22%3E%3B%0A%09%7D%3B%0A%0A%09pinctrl_fec_phy%3A%20fecphygrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%200x100%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%200x1c0%3D%22%22%3E%3B%0A%09%7D%3B%3C%2FMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%3E%3C%2FMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%3E%3C%2FMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3Bethtool%20shows%20Link%20detected%3A%20yes%2C%20and%20ifconfig%20shows%20that%20an%20ip%20address%20was%20assigned.%20However%20I%20am%20unable%20to%20ping%20to%20or%20from%20the%20board.%20Can%20you%20confirm%20if%20the%20pins%20are%20set%20correctly%20for%20this%20use%20case%3F%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20reply%2C%20I%20have%20looked%20at%20that%20document%20already%20which%20helped%20me%20get%20this%20far.%20However%2C%20I%20still%20need%20further%20assistance%20in%20getting%20things%20working.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Epls%20refer%20to%20the%20enclosed%20file%2C%20which%20is%20very%20useful%20for%20your%20case%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Efor%20RGMII%2C%20the%20current%20bsp%20supports%20this%20as%20default%2C%20you%20can%20refer%20to%20that%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
