IMX8MP RGMII Connection with No PHY
2,219件の閲覧回数
RyanMKB
I'm trying to setup an ethernet RGMII connection to a switch without using a PHY. Based on other posts I've configured my device tree as follows:
&fec {
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_fec>, <&pinctrl_fec_phy>;
	phy-mode = "rgmii";
	status = "okay";
	fixed-link {
		speed = <1000>;
		full-duplex;
	pinctrl_fec: fecgrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC	0x14>;
	pinctrl_fec_phy: fecphygrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00		0x100>,
			   <MX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01		0x1c0>;
 ethtool shows Link detected: yes, and ifconfig shows that an ip address was assigned. However I am unable to ping to or from the board. Can you confirm if the pins are set correctly for this use case? Thanks.
タグ(1)
3 返答(返信)
2,084件の閲覧回数
joanxie
for RGMII, the current bsp supports this as default, you can refer to that
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mp-evk.dts#L39...
2,173件の閲覧回数
joanxie
pls refer to the enclosed file, which is very useful for your case
2,150件の閲覧回数
RyanMKB
Thank you for your reply, I have looked at that document already which helped me get this far. However, I still need further assistance in getting things working.
%3CLINGO-SUB%20id%3D%22lingo-sub-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20RGMII%E6%8E%A5%E7%B6%9A%EF%BC%88PHY%E3%81%AA%E3%81%97%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EPHY%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%B8%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20RGMII%20%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bfec%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_fec_phy%26gt%3B%3B%0A%09phy-mode%20%3D%20%22rgmii%22%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09fixed-link%20%7B%0A%09%09speed%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%09%09full-duplex%3B%0A%09%7D%3B%0A%0A%7D%3B%0A%0A%09pinctrl_fec%3A%20fecgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%200x14%3D%22%22%3E%3B%0A%09%7D%3B%0A%0A%09pinctrl_fec_phy%3A%20fecphygrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%200x100%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%200x1c0%3D%22%22%3E%3B%0A%09%7D%3B%3C%2FMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%3E%3C%2FMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%3E%3C%2FMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Eethtool%20%E3%81%A7%E3%81%AF%E3%80%8CLink%20detected%3A%20yes%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81ifconfig%20%E3%81%A7%E3%81%AF%20IP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AE%E9%96%93%E3%81%A7%20ping%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AECASE%E3%81%A7%E3%83%94%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8BCAN%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%81%9D%E3%81%AE%E6%96%87%E6%9B%B8%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81%E3%81%93%E3%81%93%E3%81%BE%E3%81%A7%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%89%A9%E4%BA%8B%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E9%80%B2%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%81%BE%E3%81%A0%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E6%94%AF%E6%8F%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%90%8C%E5%B0%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AECASE%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERGMII%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AEBSP%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
