IMX8MP LVDS does not work
3,410 次查看
koo_sensei
Hello.
I'm trying to work with mistubishi LVDS panel directly connected to LVDS of i.MX8m PLUS.
I'm working with custom board but it is based on imx8mp evk.
I refered to imx8mp-evk-jdi-wuxga-lvds-panel.dts, so this is the .dts what I made.
	lvds0_panel {
        compatible = "panel-lvds";
	    backlight = <&lvds_backlight>;
		status = "okay";
		data-mapping = "jeida-24";
		width-mm = <160>;
		height-mm = <120>;
		panel-timing {
	                clock-frequency = <50000000>;
        	        hactive = <320>;
	                vactive = <240>;
        	        hback-porch = <65>;
	                hfront-porch = <65>;
        	        vback-porch = <14>;
                	vfront-porch = <3>;
	                hsync-len = <32>;
        	        vsync-len = <5>;
                	hsync-active = <0>;
	                vsync-active = <0>;
        	        de-active = <1>;
                	pixelclk-active = <0>;
	                power-on-delay = <40>;
        	        power-off-delay = <16>;
                	relax-delay = <1000>;
        port {
              	panel_lvds_in: endpoint {
					remote-endpoint = <&lvds_out>;
&lcdif1 {
	status = "okay";
&lcdif2 {
	status = "okay";
&lcdif3 {
	status = "okay";
	thres-low  = <1 2>;             /* (FIFO * 1 / 2) */
	thres-high =  4>;             /* (FIFO * 3 / 4) */
&ldb_phy {
	status = "okay";
&ldb {
	status = "okay";
	fsl,dual-channel;
        lvds-channel@0 {
                fsl,data-mapping = "spwg";
		status = "okay";
		/delete-node/ port@1;
                port@1 {
                        reg = <1>;
                        lvds_out: endpoint {
                                remote-endpoint = <&panel_lvds_in>;
And according to dmesg log, panel-lvds probe completed. as I know, there should be the file something like /sys/class/drm/card1-LVDS-1, but there's file list of /sys/class/drm/ in my situation is pretty different.
root@imx8mpevk:/sys/class/drm# ls
card0 renderD128 version
So, when I excute 'weston-flower' after weston-start, there's errors that says cannot find display.
root@imx8mpevk:~# weston-start
root@imx8mpevk:~# weston-flower
failed to connect to Wayland display: No such file or directory
failed to create display: No such file or directory
I read many of NXP community articles that similar of my case, but any of them was not helpful.
Can I get any clue of this situation?
标记 (1)
1,083 次查看
SanthoshRajavel
@Zhiming_Liu  Iam also facing the same problem in IMX8MPlus . Can you guide that
3,363 次查看
Zhiming_Liu
The lvds driver isn't probed correctly.
For single channel panel, the dts node should like below.
&ldb {
	status = "okay";
	lvds-channel@0 {
		fsl,data-width = <24>;
		status = "okay";
		port@1 {
			reg = <1>;
				remote-endpoint = <&xxxxx>;
 You should confirm the pixel format, jeida or spwg in panel-lvds
3,353 次查看
koo_sensei
Dear @Zhiming_Liu .
I did you advised, but it does not work.
I'm using Kernel 5.4.70, and I checked some source code below /drivers/gpu.
Properties like 'fsl,data-mapping' and 'fsl,data-width' are used in "of_get_bus_format()" in /drivers/gpu/drm/bridge/fsl-imx-ldb.c. I add printk msg in "of_get_bus_format()" function but I cannot find my printk msg at dmesg log.
And of_get_bus_format() functions is called by function binds ldb, but Kernel does not call this function.
I also checked imx8mp_ldb_bind() in drivers/gpu/imx/imx8mp-ldb.c, and I don't know why imx8mp_ldb_bind() does not called.
Can you advise how can I bind LDB interface in 5.4.70 Kernel?
%3CLINGO-SUB%20id%3D%22lingo-sub-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20LVDS%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%20i.MX8m%20PLUS%20%E7%9A%84%20LVDS%20%E7%9A%84%20mistubishi%20LVDS%20%E9%9D%A2%E6%9D%BF%E3%80%82%20%20%20%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%AE%83%E6%98%AF%E5%9F%BA%E4%BA%8E%20imx8mp%20evk%20%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%8F%90%E5%88%B0%E4%BA%86%20imx8mp-evk-jdi-wuxga-lvds-panel.dts%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E6%98%AF%20.dts%E6%88%91%E5%81%9A%E4%BA%86%E4%BB%80%E4%B9%88%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%09lvds0_panel%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22panel-lvds%22%3B%0A%09%20%20%20%20backlight%20%3D%20%26lt%3B%26amp%3Blvds_backlight%26gt%3B%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09data-mapping%20%3D%20%22jeida-24%22%3B%0A%09%09width-mm%20%3D%20%26lt%3B160%26gt%3B%3B%0A%09%09height-mm%20%3D%20%26lt%3B120%26gt%3B%3B%0A%0A%09%09panel-timing%20%7B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B50000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B320%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B240%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B65%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B65%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B14%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B32%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09hsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20de-active%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09pixelclk-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20power-on-delay%20%3D%20%26lt%3B40%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20power-off-delay%20%3D%20%26lt%3B16%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09relax-delay%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%20%20%20%20%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09panel_lvds_in%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%0A%26amp%3Blcdif1%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Blcdif2%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Blcdif3%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09thres-low%20%20%3D%20%26lt%3B1%202%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20(FIFO%20*%201%20%2F%202)%20*%2F%0A%09thres-high%20%3D%20%3CLI-EMOJI%20id%3D%22lia_red-heart%22%20title%3D%22%3Ared_heart%3A%22%3E%3C%2FLI-EMOJI%3E%204%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20(FIFO%20*%203%20%2F%204)%20*%2F%0A%7D%3B%0A%0A%26amp%3Bldb_phy%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Bldb%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%09fsl%2Cdual-channel%3B%0A%0A%20%20%20%20%20%20%20%20lvds-channel%400%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fsl%2Cdata-mapping%20%3D%20%22spwg%22%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%2Fdelete-node%2F%20port%401%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20lvds_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel_lvds_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%A0%B9%E6%8D%AE%20dmesg%20%E6%97%A5%E5%BF%97%EF%BC%8Cpanel-lvds%20%E6%8E%A2%E6%B5%8B%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%9C%89%E7%B1%BB%E4%BC%BC%2Fsys%2Fclass%2Fdrm%2Fcard1-LVDS-1%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%2Fsys%2Fclass%2Fdrm%2F%E7%9A%84%E6%96%87%E4%BB%B6%E5%88%97%E8%A1%A8%E4%B8%8E%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E5%BE%88%E4%B8%8D%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fsys%2Fclass%2Fdrm%23%20ls%0Acard0%20renderD128%20version%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BD%93%E6%88%91%E5%9C%A8%20weston-start%20%E4%B9%8B%E5%90%8E%E6%89%A7%E8%A1%8C%20%22west-on-flower%20%22%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A~%23%20weston-start%0Aroot%40imx8mpevk%3A~%23%20weston-flower%0Afailed%20to%20connect%20to%20Wayland%20display%3A%20No%20such%20file%20or%20directory%0Afailed%20to%20create%20display%3A%20No%20such%20file%20or%20directory%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E8%AE%B8%E5%A4%9A%E4%B8%8E%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E6%96%87%E7%AB%A0%EF%BC%8C%E4%BD%86%E9%83%BD%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%83%BD%E5%BE%97%E5%88%B0%E6%9C%89%E5%85%B3%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E7%9A%84%E4%BB%BB%E4%BD%95%E7%BA%BF%E7%B4%A2%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%E6%88%91%E5%9C%A8%20IMX8MPlus%20%E4%B8%AD%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E6%8C%87%E5%AF%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1651634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1651634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40%E5%88%98%E5%BF%97%E6%98%8E%3C%2FA%3E.%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E5%81%9A%E4%BA%86%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%86%85%E6%A0%B8%205.4.70%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20%2Fdrivers%2Fgpu%20%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%B8%80%E4%BA%9B%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3Efsl%2Cdata-mapping%20%22%E5%92%8C%20%22fsl%2Cdata-width%20%22%E7%AD%89%E5%B1%9E%E6%80%A7%E7%94%A8%E4%BA%8E%20%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Ffsl-imx-ldb.c%20%E4%B8%AD%22%20%E7%9A%84%22of_get_bus_format()%E3%80%82%E6%88%91%E5%9C%A8%22of_get_bus_format()%22%20%E5%87%BD%E6%95%B0%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20printk%20msg%EF%BC%8C%E4%BD%86%E5%9C%A8%20dmesg%20%E6%97%A5%E5%BF%97%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%20printk%20msg%E3%80%82%3C%2FP%3E%3CP%3Eof_get_bus_format()%20%E5%87%BD%E6%95%B0%E7%94%B1%E7%BB%91%E5%AE%9A%20ldb%20%E7%9A%84%E5%87%BD%E6%95%B0%E8%B0%83%E7%94%A8%EF%BC%8C%E4%BD%86%E5%86%85%E6%A0%B8%E4%B8%8D%E8%B0%83%E7%94%A8%E8%AF%A5%E5%87%BD%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E6%A3%80%E6%9F%A5%E4%BA%86%20drivers%2Fgpu%2Fimx%2Fimx8mp-ldb.c%20%E4%B8%AD%E7%9A%84%20imx8mp_ldb_bind()%EF%BC%8C%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%20imx8mp_ldb_bind()%20%E6%B2%A1%E6%9C%89%E8%A2%AB%E8%B0%83%E7%94%A8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E5%9C%A8%205.4.70%20%E5%86%85%E6%A0%B8%E4%B8%AD%E7%BB%91%E5%AE%9A%20LDB%20%E6%8E%A5%E5%8F%A3%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1650689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1650689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Elvds%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%AA%E6%AD%A3%E7%A1%AE%E6%8E%A2%E6%B5%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E5%8D%95%E9%80%9A%E9%81%93%E9%9D%A2%E6%9D%BF%EF%BC%8Cdts%20%E8%8A%82%E7%82%B9%E5%BA%94%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bldb%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09lvds-channel%400%20%7B%0A%09%09fsl%2Cdata-mapping%20%3D%20%22spwg%22%3B%0A%09%09fsl%2Cdata-width%20%3D%20%26lt%3B24%26gt%3B%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09port%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09lvds_out%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bxxxxx%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E5%9C%A8%20panel-lvds%20%E4%B8%AD%E7%A1%AE%E8%AE%A4%E5%83%8F%E7%B4%A0%E6%A0%BC%E5%BC%8F%EF%BC%8C%E6%98%AF%20jeida%20%E8%BF%98%E6%98%AF%20spwg%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Qmiller_0-1684204146649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Qmiller_0-1684204146649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F223263i3E1A770F0B489848%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Qmiller_0-1684204146649.png%22%20alt%3D%22Qmiller_0-1684204146649.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
