Ball Diameter for i.MX 6ULL LFBGA289 Package
a1wolfe
Can anyone confirm the ball diameter or a recommended pad diameter for the LFBGA289 package found here?
SOT1534-2: LFBGA289 | NXP Semiconductors
The drawing show 0.45mm over 0.35mm, is this the possible range or two different nominal values?
The nominal footprint I downloaded from NXP uses 0.37mm pad diameters, while the reference design MCIMX6ULL-CM uses 0.30mm pad diameters.
I am designing with MCIMX6Y2DVM09AB specifically.
I started a chat on the website and attached the transcript. I received confirmation that the ball diameter is actually in the range of 0.38 to 0.48mm. Is this accurate and the drawing is not up to date? They also mentioned a document with recommended land patterns that could potentially be shared, and recommended a pad diameter of 0.4mm. That seems high to me, given the reference SODIMM module uses about 0.3mm
JorgeCas
These values are a possible range of ball diameter.
All of the dimensions (documentation, footprint, design files) can be “correct” according to the different land‑pattern for your design such as NSMD or SMD, I suggest you use the footprint provided in NXP website. As you mention, the reference design can use a smaller pad diameter but at the end, this can vary depending on the specific manufacturing process.
Best regards.
JorgeCas
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2308547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBall%20Diameter%20for%20i.MX%206ULL%20LFBGA289%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2308547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20anyone%20confirm%20the%20ball%20diameter%20or%20a%20recommended%20pad%20diameter%20for%20the%20LFBGA289%20package%20found%20here%3F%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpackages%2FSOT1534-2%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESOT1534-2%3A%20LFBGA289%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%3CP%3EThe%20drawing%20show%200.45mm%20over%200.35mm%2C%20is%20this%20the%20possible%20range%20or%20two%20different%20nominal%20values%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20nominal%20footprint%20I%20downloaded%20from%20NXP%20uses%200.37mm%20pad%20diameters%2C%20while%20the%20reference%20design%26nbsp%3BMCIMX6ULL-CM%20uses%200.30mm%20pad%20diameters.%3C%2FP%3E%3CP%3EI%20am%20designing%20with%20MCIMX6Y2DVM09AB%20specifically.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20started%20a%20chat%20on%20the%20website%20and%20attached%20the%20transcript.%20I%20received%20confirmation%20that%20the%20ball%20diameter%20is%20actually%20in%20the%20range%20of%200.38%20to%200.48mm.%20Is%20this%20accurate%20and%20the%20drawing%20is%20not%20up%20to%20date%3F%20They%20also%20mentioned%20a%20document%20with%20recommended%20land%20patterns%20that%20could%20potentially%20be%20shared%2C%20and%20recommended%20a%20pad%20diameter%20of%200.4mm.%20That%20seems%20high%20to%20me%2C%20given%20the%20reference%20SODIMM%20module%20uses%20about%200.3mm%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2308547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6%20All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ball%20Diameter%20for%20i.MX%206ULL%20LFBGA289%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EThe%20drawing%20show%200.45mm%20over%200.35mm%2C%20is%20this%20the%20possible%20range%20or%20two%20different%20nominal%20values%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EThese%20values%20are%20a%20possible%20range%20of%20ball%20diameter.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EIs%20this%20accurate%20and%20the%20drawing%20is%20not%20up%20to%20date%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EAll%20of%20the%20dimensions%20(documentation%2C%20footprint%2C%20design%20files)%20can%20be%20%E2%80%9Ccorrect%E2%80%9D%20according%20to%20the%20different%20land%E2%80%91pattern%20for%20your%20design%20such%20as%20NSMD%20or%20SMD%2C%20I%20suggest%20you%20use%20the%20footprint%20provided%20in%20NXP%20website.%20As%20you%20mention%2C%20the%20reference%20design%20can%20use%20a%20smaller%20pad%20diameter%20but%20at%20the%20end%2C%20this%20can%20vary%20depending%20on%20the%20specific%20manufacturing%20process.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
