IMX8MP ISP Streaming - Pink flash issue in display
942 次查看
jp4
Hello experts,
Currently we are integrating NXP ISP with imx900 sensor. We have ported our driver.
We facing one issue when pushing stream to display, we are getting pink flash along with the stream at particular interval. Currently we are pushing 60fps to display.
While we record the stream and playback we could not get this pink flash. So it seems some issue with display side.
Please let us know how can we avoid this pink flash issue.
I have attached two files along with this.
1. Stream_to_dispaly (Exactly at 6th seconds we could see pink flash)
2. recorded_stream ( We could not notice any pink flash)
Current configuration:
MIPI data rate from sensor : 1485Mbps
csis-hs-settle = 33
Thanks in advance
918 次查看
Bio_TICFSL
Don't know, We never seen this , but apparently is due to your display, try to change display to see if the software is the cause, since everything works well, the flash is not causing by the ISP.
