IMX8MP EVK Audio issue on Ubuntu Core
4,922 次查看
ammar
We are poting Ubuntu core on IMX8MP EVK. Assuming that the Yocto build directory will have already patched kerne we retrieved the kernel source from /tmp directory.
We are getting the following dmesg log.
The DTS, configs, and error log is attached
Configs:
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_AUDIT=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_PREEMPT=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_NUMA_BALANCING=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_USER_NS=y
CONFIG_SCHED_AUTOGROUP=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
# CONFIG_COMPAT_BRK is not set
CONFIG_PROFILING=y
CONFIG_ARCH_LAYERSCAPE=y
CONFIG_ARCH_MXC=y
CONFIG_ARCH_S32=y
CONFIG_SOC_S32V234=y
CONFIG_ARM64_VA_BITS_48=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_NUMA=y
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
CONFIG_CRASH_DUMP=y
CONFIG_XEN=y
CONFIG_FORCE_MAX_ZONEORDER=14
CONFIG_COMPAT=y
CONFIG_RANDOMIZE_BASE=y
CONFIG_PM_DEBUG=y
CONFIG_PM_TEST_SUSPEND=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_ENERGY_MODEL=y
CONFIG_ARM_CPUIDLE=y
CONFIG_ARM_PSCI_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_CPUFREQ_DT=y
CONFIG_ACPI_CPPC_CPUFREQ=m
CONFIG_ARM_SCPI_CPUFREQ=y
CONFIG_ARM_IMX_CPUFREQ_DT=y
CONFIG_QORIQ_CPUFREQ=y
CONFIG_ARM_SCPI_PROTOCOL=y
CONFIG_EFI_CAPSULE_LOADER=y
CONFIG_IMX_DSP=y
CONFIG_IMX_SCU=y
CONFIG_IMX_SCU_PD=y
CONFIG_ACPI=y
CONFIG_ACPI_APEI=y
CONFIG_ACPI_APEI_GHES=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=y
CONFIG_VIRTUALIZATION=y
CONFIG_KVM=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_SHA512_ARM64_CE=m
CONFIG_CRYPTO_SHA3_ARM64=m
CONFIG_CRYPTO_SM3_ARM64_CE=m
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_AES_ARM64_BS=m
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_KSM=y
CONFIG_MEMORY_FAILURE=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IPV6_SIT=m
CONFIG_NETFILTER=y
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_NET_DSA=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_LLC2=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
CONFIG_NET_SCH_TAPRIO=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_GACT=m
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_GATE=m
CONFIG_TSN=y
CONFIG_QRTR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
CONFIG_BPF_JIT=y
CONFIG_NET_PKTGEN=m
CONFIG_CAN=m
CONFIG_CAN_FLEXCAN=m
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
CONFIG_BT_LEDS=y
# CONFIG_BT_DEBUGFS is not set
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_3WIRE=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIVHCI=y
CONFIG_CFG80211=y
CONFIG_NL80211_TESTMODE=y
CONFIG_CFG80211_WEXT=y
CONFIG_MAC80211=y
CONFIG_MAC80211_LEDS=y
CONFIG_NET_9P=y
CONFIG_NET_9P_VIRTIO=y
CONFIG_NFC=m
CONFIG_NFC_NCI=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_PCI=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCI_IOV=y
CONFIG_PCI_PASID=y
CONFIG_HOTPLUG_PCI=y
CONFIG_HOTPLUG_PCI_ACPI=y
CONFIG_PCI_HOST_GENERIC=y
CONFIG_PCI_XGENE=y
CONFIG_PCIE_ALTERA=y
CONFIG_PCIE_ALTERA_MSI=y
CONFIG_PCI_HOST_THUNDER_PEM=y
CONFIG_PCI_HOST_THUNDER_ECAM=y
CONFIG_PCI_IMX6_HOST=y
CONFIG_PCI_IMX6_EP=y
CONFIG_PCI_LAYERSCAPE=y
CONFIG_PCI_HISI=y
CONFIG_PCIE_KIRIN=y
CONFIG_PCI_MESON=m
CONFIG_PCIE_LAYERSCAPE_GEN4=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=y
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_BRCMSTB_GISB_ARB=y
CONFIG_SIMPLE_PM_BUS=y
CONFIG_VEXPRESS_CONFIG=y
CONFIG_FSL_MC_UAPI_SUPPORT=y
CONFIG_MTD=y
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_CFI=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_PHYSMAP=y
CONFIG_MTD_PHYSMAP_OF=y
CONFIG_MTD_DATAFLASH=y
CONFIG_MTD_SST25L=y
CONFIG_MTD_RAW_NAND=y
CONFIG_MTD_NAND_DENALI_DT=y
CONFIG_MTD_NAND_GPMI_NAND=y
CONFIG_MTD_NAND_FSL_IFC=y
CONFIG_MTD_SPI_NOR=y
# CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set
CONFIG_MTD_UBI=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_NBD=m
CONFIG_XEN_BLKDEV_BACKEND=m
CONFIG_VIRTIO_BLK=y
CONFIG_BLK_DEV_NVME=y
CONFIG_SENSORS_FXOS8700=y
CONFIG_SENSORS_FXAS2100X=y
CONFIG_SRAM=y
CONFIG_PCI_ENDPOINT_TEST=y
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_UACCE=m
# CONFIG_SCSI_PROC_FS is not set
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_HISI_SAS=y
CONFIG_SCSI_HISI_SAS_PCI=y
CONFIG_MEGARAID_SAS=y
CONFIG_SCSI_MPT3SAS=m
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_IMX=y
CONFIG_AHCI_CEVA=y
CONFIG_AHCI_XGENE=y
CONFIG_AHCI_QORIQ=y
CONFIG_SATA_SIL24=y
CONFIG_PATA_PLATFORM=y
CONFIG_PATA_OF_PLATFORM=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_NETDEVICES=y
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
CONFIG_NET_DSA_MSCC_FELIX=m
CONFIG_AMD_XGBE=y
CONFIG_ATL1C=m
CONFIG_BCMGENET=m
CONFIG_BNX2X=m
CONFIG_MACB=y
CONFIG_THUNDER_NIC_PF=y
CONFIG_FEC=y
CONFIG_FSL_FMAN=y
CONFIG_FSL_DPAA_ETH=y
CONFIG_FSL_DPAA2_ETH=y
CONFIG_FSL_DPAA2_MAC=y
CONFIG_FSL_ENETC=y
CONFIG_FSL_ENETC_VF=y
CONFIG_FSL_ENETC_QOS=y
CONFIG_ENETC_TSN=y
CONFIG_HIX5HD2_GMAC=y
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
CONFIG_HNS3_HCLGE=y
CONFIG_HNS3_ENET=y
CONFIG_E1000=y
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGBVF=y
CONFIG_MVMDIO=y
CONFIG_SKY2=y
CONFIG_MLX4_EN=m
CONFIG_MLX5_CORE=m
CONFIG_MLX5_CORE_EN=y
CONFIG_MSCC_OCELOT_SWITCH=y
CONFIG_QCOM_EMAC=m
CONFIG_RMNET=m
CONFIG_SMC91X=y
CONFIG_SMSC911X=y
CONFIG_STMMAC_ETH=y
CONFIG_DWMAC_GENERIC=m
CONFIG_AQUANTIA_PHY=y
CONFIG_BROADCOM_PHY=m
CONFIG_INPHI_PHY=y
CONFIG_MARVELL_PHY=m
CONFIG_MARVELL_10G_PHY=m
CONFIG_MICREL_PHY=y
CONFIG_MICROSEMI_PHY=y
CONFIG_NXP_TJA11XX_PHY=y
CONFIG_AT803X_PHY=y
CONFIG_REALTEK_PHY=y
CONFIG_ROCKCHIP_PHY=y
CONFIG_VITESSE_PHY=y
CONFIG_MDIO_BITBANG=y
CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
CONFIG_MDIO_BUS_MUX_MMIOREG=y
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_HOSTAP=y
CONFIG_WL18XX=m
CONFIG_WLCORE_SDIO=m
CONFIG_XEN_NETDEV_BACKEND=m
CONFIG_IVSHMEM_NET=y
CONFIG_INPUT_EVDEV=y
CONFIG_KEYBOARD_ADC=m
CONFIG_KEYBOARD_GPIO=y
CONFIG_KEYBOARD_SNVS_PWRKEY=y
CONFIG_KEYBOARD_IMX_SC_PWRKEY=y
CONFIG_KEYBOARD_CROS_EC=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_TOUCHSCREEN_GOODIX=m
CONFIG_TOUCHSCREEN_SYNAPTICS_DSX_I2C=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_MPL3115=y
CONFIG_INPUT_ISL29023=y
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DW=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_IMX=y
CONFIG_SERIAL_IMX_CONSOLE=y
CONFIG_SERIAL_XILINX_PS_UART=y
CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
CONFIG_SERIAL_FSL_LPUART=y
CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
CONFIG_SERIAL_FSL_LINFLEXUART=y
CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_TCG_TPM=y
CONFIG_TCG_TIS_I2C_INFINEON=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_GPIO=m
CONFIG_I2C_IMX=y
CONFIG_I2C_IMX_LPI2C=y
CONFIG_I2C_RK3X=y
CONFIG_I2C_RPBUS=y
CONFIG_I2C_CROS_EC_TUNNEL=y
CONFIG_XEN_I2C_BACKEND=y
CONFIG_I2C_SLAVE=y
CONFIG_SPI=y
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_SPI_FSL_LPSPI=y
CONFIG_SPI_FSL_QUADSPI=y
CONFIG_SPI_NXP_FLEXSPI=y
CONFIG_SPI_IMX=y
CONFIG_SPI_FSL_DSPI=y
CONFIG_SPI_PL022=y
CONFIG_SPI_ROCKCHIP=y
CONFIG_SPI_SPIDEV=y
CONFIG_SPI_SLAVE=y
CONFIG_SPI_SLAVE_TIME=y
CONFIG_SPI_SLAVE_SYSTEM_CONTROL=y
CONFIG_SPMI=y
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_MAX77620=y
CONFIG_PINCTRL_IMX8MM=y
CONFIG_PINCTRL_IMX8MN=y
CONFIG_PINCTRL_IMX8MP=y
CONFIG_PINCTRL_IMX8MQ=y
CONFIG_PINCTRL_IMX8QM=y
CONFIG_PINCTRL_IMX8QXP=y
CONFIG_PINCTRL_IMX8DXL=y
CONFIG_PINCTRL_S32V234=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_ALTERA=m
CONFIG_GPIO_DWAPB=y
CONFIG_GPIO_MB86S7X=y
CONFIG_GPIO_MPC8XXX=y
CONFIG_GPIO_PL061=y
CONFIG_GPIO_WCD934X=m
CONFIG_GPIO_XGENE=y
CONFIG_GPIO_MAX732X=y
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
CONFIG_GPIO_SL28CPLD=m
CONFIG_POWER_RESET_BRCMSTB=y
CONFIG_POWER_RESET_XGENE=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_SYSCON_REBOOT_MODE=y
CONFIG_BATTERY_SBS=m
CONFIG_BATTERY_BQ27XXX=y
CONFIG_SENSORS_ARM_SCPI=y
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_SL28CPLD=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_INA3221=m
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_THERMAL_EMULATION=y
CONFIG_IMX_SC_THERMAL=y
CONFIG_IMX8MM_THERMAL=y
CONFIG_DEVICE_THERMAL=y
CONFIG_QORIQ_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_SL28CPLD_WATCHDOG=m
CONFIG_ARM_SP805_WATCHDOG=y
CONFIG_ARM_SBSA_WATCHDOG=y
CONFIG_DW_WATCHDOG=y
CONFIG_IMX2_WDT=y
CONFIG_IMX_SC_WDT=y
CONFIG_ARM_SMC_WATCHDOG=y
CONFIG_XEN_WDT=y
CONFIG_MFD_BD9571MWV=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_IMX_MIX=y
CONFIG_MFD_HI6421_PMIC=y
CONFIG_MFD_MAX77620=y
CONFIG_MFD_RK808=y
CONFIG_MFD_SEC_CORE=y
CONFIG_MFD_SL28CPLD=y
CONFIG_MFD_ROHM_BD718XX=y
CONFIG_MFD_WCD934X=m
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_AXP20X=y
CONFIG_REGULATOR_BD718XX=y
CONFIG_REGULATOR_BD9571MWV=y
CONFIG_REGULATOR_FAN53555=y
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_HI6421V530=y
CONFIG_REGULATOR_MAX77620=y
CONFIG_REGULATOR_MAX8973=y
CONFIG_REGULATOR_PCA9450=y
CONFIG_REGULATOR_PFUZE100=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_QCOM_SPMI=y
CONFIG_REGULATOR_RK808=y
CONFIG_REGULATOR_S2MPS11=y
CONFIG_REGULATOR_VCTRL=m
CONFIG_RC_CORE=m
CONFIG_RC_DECODERS=y
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_IR_IMON_DECODER=m
CONFIG_IR_RCMM_DECODER=m
CONFIG_RC_DEVICES=y
CONFIG_IR_GPIO_CIR=m
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
# CONFIG_DVB_NET is not set
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_MXC_CAPTURE=y
CONFIG_VIDEO_MX8_CAPTURE=y
CONFIG_VIDEO_MXC_CSI_CAMERA=y
CONFIG_MXC_MIPI_CSI=y
CONFIG_MXC_CAMERA_OV5640_MIPI_V2=y
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_SDR_PLATFORM_DRIVERS=y
CONFIG_VIDEO_IMX219=m
CONFIG_VIDEO_OV5640=y
CONFIG_VIDEO_OV5645=m
CONFIG_IMX_DPU_CORE=y
CONFIG_IMX_LCDIF_CORE=y
CONFIG_IMX_LCDIFV3_CORE=y
CONFIG_DRM=y
CONFIG_DRM_I2C_NXP_TDA998X=m
CONFIG_DRM_MALI_DISPLAY=m
CONFIG_DRM_NOUVEAU=m
CONFIG_DRM_RCAR_DW_HDMI=m
CONFIG_DRM_RCAR_LVDS=m
CONFIG_DRM_PANEL_LVDS=m
CONFIG_DRM_PANEL_SIMPLE=y
CONFIG_DRM_PANEL_RAYDIUM_RM67191=y
CONFIG_DRM_PANEL_SEIKO_43WVF1G=y
CONFIG_DRM_PANEL_SITRONIX_ST7703=m
CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
CONFIG_DRM_PANEL_WKS_101WX001=y
CONFIG_DRM_DISPLAY_CONNECTOR=m
CONFIG_DRM_LONTIUM_LT9611=m
CONFIG_DRM_FSL_IMX_LVDS_BRIDGE=y
CONFIG_DRM_NWL_MIPI_DSI=y
CONFIG_DRM_NXP_SEIKO_43WVFIG=y
CONFIG_DRM_SII902X=m
CONFIG_DRM_SIMPLE_BRIDGE=m
CONFIG_DRM_THINE_THC63LVD1024=m
CONFIG_DRM_TI_SN65DSI86=m
CONFIG_DRM_I2C_ADV7511=y
CONFIG_DRM_I2C_ADV7511_AUDIO=y
CONFIG_DRM_CDNS_HDMI_CEC=y
CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
CONFIG_DRM_DW_HDMI_I2S_AUDIO=m
CONFIG_DRM_DW_HDMI_GP_AUDIO=y
CONFIG_DRM_DW_HDMI_CEC=y
CONFIG_DRM_ITE_IT6263=y
CONFIG_DRM_IMX=y
CONFIG_DRM_IMX_LCDIF_MUX_DISPLAY=y
CONFIG_DRM_IMX_PARALLEL_DISPLAY=y
CONFIG_DRM_IMX_TVE=y
CONFIG_DRM_IMX_LDB=y
CONFIG_DRM_IMX8QM_LDB=y
CONFIG_DRM_IMX8QXP_LDB=y
CONFIG_DRM_IMX8MP_LDB=y
CONFIG_DRM_IMX_HDMI=y
CONFIG_DRM_IMX_SEC_DSIM=y
CONFIG_DRM_IMX_DCSS=y
CONFIG_DRM_IMX_CDNS_MHDP=y
CONFIG_DRM_ETNAVIV=m
CONFIG_DRM_HISI_HIBMC=m
CONFIG_DRM_HISI_KIRIN=m
CONFIG_DRM_MXSFB=y
CONFIG_DRM_PL111=m
CONFIG_DRM_LIMA=m
CONFIG_DRM_PANFROST=m
CONFIG_FB_ARMCLCD=y
CONFIG_FB_EFI=y
CONFIG_BACKLIGHT_PWM=y
CONFIG_BACKLIGHT_LP855X=m
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_SOC=y
CONFIG_SND_SOC_FSL_Asrc=y
CONFIG_SND_SOC_FSL_MQS=y
CONFIG_SND_SOC_FSL_EAsrc=y
CONFIG_SND_SOC_FSL_ESAI_CLIENT=y
CONFIG_SND_IMX_SOC=y
CONFIG_SND_SOC_IMX_AK4458=y
CONFIG_SND_SOC_IMX_AK5558=y
CONFIG_SND_SOC_IMX_AK4497=y
CONFIG_SND_SOC_IMX_MICFIL=y
CONFIG_SND_SOC_IMX_RPMSG=y
CONFIG_SND_SOC_IMX_SPDIF=y
CONFIG_SND_SOC_FSL_ASOC_CARD=y
CONFIG_SND_SOC_IMX_AUDMIX=y
CONFIG_SND_SOC_IMX_XCVR=y
CONFIG_SND_SOC_IMX_PCM512X=y
CONFIG_SND_SOC_IMX_PDM_MIC=y
CONFIG_SND_SOC_IMX_DSP=y
CONFIG_SND_SOC_IMX_CDNHDMI=y
CONFIG_SND_SOC_SOF_TOPLEVEL=y
CONFIG_SND_SOC_SOF_OF=m
CONFIG_SND_SOC_SOF_COMPRESS=y
CONFIG_SND_SOC_SOF_IMX_TOPLEVEL=y
CONFIG_SND_SOC_SOF_IMX8_SUPPORT=y
CONFIG_SND_SOC_SOF_IMX8M_SUPPORT=y
CONFIG_SND_SOC_AK4613=m
CONFIG_SND_SOC_BT_SCO=y
CONFIG_SND_SOC_CROS_EC_CODEC=m
CONFIG_SND_SOC_CS42XX8_I2C=y
CONFIG_SND_SOC_DMIC=m
CONFIG_SND_SOC_ES7134=m
CONFIG_SND_SOC_ES7241=m
CONFIG_SND_SOC_MAX98357A=m
CONFIG_SND_SOC_MAX98927=m
CONFIG_SND_SOC_PCM3168A_I2C=m
CONFIG_SND_SOC_SGTL5000=m
CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
CONFIG_SND_SOC_SPDIF=m
CONFIG_SND_SOC_TAS571X=m
CONFIG_SND_SOC_WCD934X=m
CONFIG_SND_SOC_WM8524=y
CONFIG_SND_SOC_WM8904=m
CONFIG_SND_SOC_WM8960=y
CONFIG_SND_SOC_WSA881X=m
CONFIG_SND_SIMPLE_CARD=y
CONFIG_SND_AUDIO_GRAPH_CARD=y
CONFIG_I2C_HID=m
CONFIG_USB_CONN_GPIO=y
CONFIG_USB=y
CONFIG_USB_OTG=y
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_HCD_TEST_MODE=y
CONFIG_USB_ACM=m
CONFIG_USB_STORAGE=y
CONFIG_USB_UAS=y
CONFIG_USB_CDNS3=y
CONFIG_USB_CDNS3_GADGET=y
CONFIG_USB_CDNS3_HOST=y
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_DWC3=y
CONFIG_USB_DWC2=y
CONFIG_USB_CHIPIDEA=y
CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_CHIPIDEA_HOST=y
CONFIG_USB_ISP1760=y
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_CONSOLE=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=y
CONFIG_USB_SERIAL_FTDI_SIO=y
CONFIG_USB_TEST=m
CONFIG_USB_EHSET_TEST_FIXTURE=y
CONFIG_USB_HSIC_USB3503=y
CONFIG_NOP_USB_XCEIV=y
CONFIG_USB_MXS_PHY=y
CONFIG_USB_ULPI=y
CONFIG_USB_GADGET=y
CONFIG_USB_SNP_UDC_PLAT=y
CONFIG_USB_BDC_UDC=y
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_UAC1=y
CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB_CONFIGFS_F_HID=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_TYPEC=y
CONFIG_TYPEC_TCPM=y
CONFIG_TYPEC_TCPCI=y
CONFIG_TYPEC_FUSB302=m
CONFIG_TYPEC_HD3SS3220=m
CONFIG_TYPEC_SWITCH_GPIO=y
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_ACPI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
CONFIG_MMC_SDHCI_OF_ESDHC=y
CONFIG_MMC_SDHCI_CADENCE=y
CONFIG_MMC_SDHCI_ESDHC_IMX=y
CONFIG_MMC_SDHCI_F_SDH30=y
CONFIG_MMC_SPI=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_EXYNOS=y
CONFIG_MMC_DW_HI3798CV200=y
CONFIG_MMC_DW_K3=y
CONFIG_MMC_SDHCI_XENON=y
CONFIG_MMC_SDHCI_AM654=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_PWM=y
CONFIG_LEDS_SYSCON=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_DISK=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_EDAC=y
CONFIG_EDAC_GHES=y
CONFIG_EDAC_SYNOPSYS=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_DS1307=m
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RK808=m
CONFIG_RTC_DRV_PCF85363=m
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RV8803=m
CONFIG_RTC_DRV_S5M=y
CONFIG_RTC_DRV_DS3232=y
CONFIG_RTC_DRV_PCF2127=m
CONFIG_RTC_DRV_EFI=y
CONFIG_RTC_DRV_CROS_EC=y
CONFIG_RTC_DRV_FSL_FTM_ALARM=y
CONFIG_RTC_DRV_PL031=y
CONFIG_RTC_DRV_SNVS=y
CONFIG_RTC_DRV_IMX_SC=y
CONFIG_DMADEVICES=y
CONFIG_BCM_SBA_RAID=m
CONFIG_FSL_EDMA=y
CONFIG_FSL_QDMA=m
CONFIG_FSL_EDMA_V3=y
CONFIG_IMX_SDMA=y
CONFIG_MV_XOR_V2=y
CONFIG_MXS_DMA=y
CONFIG_PL330_DMA=y
CONFIG_QCOM_HIDMA_MGMT=y
CONFIG_QCOM_HIDMA=y
CONFIG_FSL_DPAA2_QDMA=m
CONFIG_DMATEST=y
CONFIG_DMABUF_HEAPS=y
CONFIG_DMABUF_HEAPS_SYSTEM=y
CONFIG_DMABUF_HEAPS_CMA=y
CONFIG_UIO=y
CONFIG_UIO_PCI_GENERIC=y
CONFIG_UIO_IVSHMEM=y
CONFIG_VFIO=y
CONFIG_VFIO_PCI=y
CONFIG_VFIO_FSL_MC=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_BALLOON=y
CONFIG_VIRTIO_MMIO=y
CONFIG_VIRTIO_IVSHMEM=y
CONFIG_XEN_GNTDEV=y
CONFIG_XEN_GRANT_DEV_ALLOC=y
CONFIG_STAGING=y
CONFIG_STAGING_MEDIA=y
CONFIG_VIDEO_IMX_CAPTURE=y
CONFIG_IMX8_MEDIA_DEVICE=m
CONFIG_ION=y
CONFIG_ION_SYSTEM_HEAP=y
CONFIG_ION_CMA_HEAP=y
CONFIG_FSL_DPAA2=y
CONFIG_FSL_DPAA2_ETHSW=y
CONFIG_FSL_PPFE=y
CONFIG_FSL_PPFE_UTIL_DISABLED=y
CONFIG_CHROME_PLATFORMS=y
CONFIG_CROS_EC=y
CONFIG_CROS_EC_I2C=y
CONFIG_CROS_EC_SPI=y
CONFIG_CROS_EC_CHARDEV=m
CONFIG_COMMON_CLK_RK808=y
CONFIG_COMMON_CLK_SCPI=y
CONFIG_COMMON_CLK_CS2000_CP=y
CONFIG_COMMON_CLK_FSL_SAI=y
CONFIG_COMMON_CLK_S2MPS11=y
CONFIG_COMMON_CLK_XGENE=y
CONFIG_COMMON_CLK_PWM=y
CONFIG_COMMON_CLK_VC5=y
CONFIG_CLK_IMX8MM=y
CONFIG_CLK_IMX8MN=y
CONFIG_CLK_IMX8MP=y
CONFIG_CLK_IMX8MQ=y
CONFIG_CLK_IMX8QXP=y
CONFIG_HWSPINLOCK=y
CONFIG_ARM_MHU=y
CONFIG_IMX_MBOX=y
CONFIG_PLATFORM_MHU=y
CONFIG_ARM_SMMU=y
CONFIG_ARM_SMMU_V3=y
CONFIG_REMOTEPROC=y
CONFIG_IMX_REMOTEPROC=y
CONFIG_RPMSG_QCOM_GLINK_RPM=y
CONFIG_SOUNDWIRE=m
CONFIG_SOUNDWIRE_QCOM=m
CONFIG_SOC_BRCMSTB=y
CONFIG_FSL_DPAA=y
CONFIG_FSL_MC_DPIO=y
CONFIG_FSL_RCPM=y
CONFIG_FSL_QIXIS=y
CONFIG_SOC_TI=y
CONFIG_EXTCON_PTN5150=m
CONFIG_EXTCON_USB_GPIO=y
CONFIG_EXTCON_USBC_CROS_EC=y
CONFIG_IIO=y
CONFIG_IMX8QXP_ADC=y
CONFIG_MAX9611=m
CONFIG_QCOM_SPMI_ADC5=m
CONFIG_IIO_CROS_EC_SENSORS_CORE=m
CONFIG_IIO_CROS_EC_SENSORS=m
CONFIG_IIO_CROS_EC_LIGHT_PROX=m
CONFIG_IIO_CROS_EC_BARO=m
CONFIG_PWM=y
CONFIG_PWM_CROS_EC=m
CONFIG_PWM_FSL_FTM=m
CONFIG_PWM_IMX27=y
CONFIG_PWM_SL28CPLD=m
CONFIG_SL28CPLD_INTC=y
CONFIG_MST_IRQ=y
CONFIG_RESET_BRCMSTB_RESCAL=y
CONFIG_RESET_IMX7=y
CONFIG_PHY_XGENE=y
CONFIG_PHY_MIXEL_LVDS=y
CONFIG_PHY_MIXEL_LVDS_COMBO=y
CONFIG_PHY_CADENCE_SALVO=y
CONFIG_PHY_FSL_IMX8MP_LVDS=y
CONFIG_PHY_MIXEL_MIPI_DPHY=y
CONFIG_PHY_SAMSUNG_HDMI_PHY=y
CONFIG_PHY_QCOM_USB_HS=y
CONFIG_PHY_SAMSUNG_USB2=y
CONFIG_ARM_SMMU_V3_PMU=m
CONFIG_FSL_IMX8_DDR_PMU=y
CONFIG_HISI_PMU=y
CONFIG_NVMEM_IMX_OCOTP=y
CONFIG_NVMEM_IMX_OCOTP_SCU=y
CONFIG_FPGA=y
CONFIG_FPGA_BRIDGE=m
CONFIG_ALTERA_FREEZE_BRIDGE=m
CONFIG_FPGA_REGION=m
CONFIG_OF_FPGA_REGION=m
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_MUX_MMIO=y
CONFIG_SLIM_QCOM_CTRL=m
CONFIG_INTERCONNECT=y
CONFIG_MXC_SIM=y
CONFIG_MXC_EMVSIM=y
CONFIG_EXT2_FS=y
CONFIG_EXT3_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_OVERLAY_FS=m
CONFIG_VFAT_FS=y
CONFIG_HUGETLBFS=y
CONFIG_EFIVAR_FS=y
CONFIG_JFFS2_FS=y
CONFIG_UBIFS_FS=y
CONFIG_SQUASHFS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V4=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_ROOT_NFS=y
CONFIG_9P_FS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_SECURITY=y
CONFIG_CRYPTO_USER=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_TLS=m
CONFIG_CRYPTO_CFB=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_LRW=m
CONFIG_CRYPTO_OFB=m
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_VMAC=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_RMD128=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_RMD256=m
CONFIG_CRYPTO_RMD320=m
CONFIG_CRYPTO_STREEBOG=m
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SALSA20=m
CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO=m
CONFIG_CRYPTO_DEV_FSL_CAAM=m
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_TEST=m
CONFIG_CRYPTO_DEV_FSL_DPAA2_CAAM=m
CONFIG_CRYPTO_DEV_CCREE=m
CONFIG_CRYPTO_DEV_HISI_SEC2=m
CONFIG_CRYPTO_DEV_HISI_ZIP=m
CONFIG_CRYPTO_DEV_HISI_HPRE=m
CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
CONFIG_INDIRECT_PIO=y
CONFIG_CRC_CCITT=m
CONFIG_CMA_SIZE_MBYTES=32
CONFIG_PRINTK_TIME=y
CONFIG_DEBUG_INFO=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_KERNEL=y
# CONFIG_SCHED_DEBUG is not set
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_FTRACE is not set
CONFIG_CORESIGHT=y
CONFIG_CORESIGHT_LINK_AND_SINK_TMC=y
CONFIG_CORESIGHT_SOURCE_ETM4X=y
CONFIG_MEMTEST=y
Dmesg Logs:
ight: supply power not found, using dummy regulator
[ 0.407603] EINJ: ACPI disabled.
[ 0.412375] i.MX clk 324: register failed with -2
[ 0.412386] i.MX clk 325: register failed with -2
[ 0.412392] i.MX clk 326: register failed with -2
[ 0.412401] i.MX clk 328: register failed with -2
[ 0.412407] i.MX clk 329: register failed with -2
[ 0.412412] i.MX clk 330: register failed with -2
[ 0.412548] clk: failed to reparent gic to sys_pll2_500m: -16
[ 1.509395] imx-lcdifv3 32e80000.lcd-controller: No pix clock get: -517
[ 1.516775] imx-lcdifv3 32e90000.lcd-controller: No pix clock get: -517
[ 1.523712] imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
[ 1.534878] imx-hdmi-pavi 32fc4000.hdmi-pai-pvi: No pvi clock get
[ 2.244647] sdhci-esdhc-imx 30b50000.mmc: voltage-ranges unspecified
[ 2.248226] sdhci-esdhc-imx 30b60000.mmc: voltage-ranges unspecified
[ 2.278479] mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, using dummy regulator
[ 2.489364] fsl-sai 30c20000.sai: failed to get bus clock: -517
[ 2.497369] fsl-sai 30c30000.sai: failed to get bus clock: -517
[ 2.506629] fsl-micfil-dai 30ca0000.micfil: failed to get core clock: -517
[ 2.514201] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to get ipg clock
[ 2.521636] fsl-aud2htx 30cb0000.aud2htx: failed to get mem clock
[ 2.529868] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 2.683437] adv7511 1-003d: supply avdd not found, using dummy regulator
[ 2.690270] adv7511 1-003d: supply dvdd not found, using dummy regulator
[ 2.697020] adv7511 1-003d: supply pvdd not found, using dummy regulator
[ 2.703781] adv7511 1-003d: supply a2vdd not found, using dummy regulator
[ 2.710618] adv7511 1-003d: supply v3p3 not found, using dummy regulator
[ 2.717356] adv7511 1-003d: supply v1p2 not found, using dummy regulator
[ 2.724957] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e60000' disabled
[ 2.786780] it6263 1-004c: Probe failed. Remote port 'lvds-channel@0' disabled
[ 2.794789] ov5640 1-003c: supply DOVDD not found, using dummy regulator
[ 2.801611] ov5640 1-003c: supply AVDD not found, using dummy regulator
[ 2.808273] ov5640 1-003c: supply DVDD not found, using dummy regulator
[ 2.860605] ov5640 1-003c: ov5640_read_reg: error: reg=300a
[ 2.866197] ov5640 1-003c: ov5640_check_chip_id: failed to read chip identifier
[ 2.882126] pca953x 2-0020: error -ENODEV: reg get err
[ 2.899631] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 2.908235] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[ 2.916700] samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: -517
[ 2.926799] pwm-backlight lvds_backlight: supply power not found, using dummy regulator
[ 2.927422] imx6q-pcie 33800000.pcie: supply epdev_on not found, using dummy regulator
[ 2.971932] imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
[ 2.981337] OF: graph: no port node found in /soc@0/usb-phy@381f0040
[ 3.055252] imx6q-pcie 33800000.pcie: invalid resource
[ 3.107965] mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, using dummy regulator
[ 3.120035] sdhci-esdhc-imx 30b50000.mmc: voltage-ranges unspecified
[ 3.175785] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 3.181068] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 3.186312] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 3.198575] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 3.204597] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 3.212008] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 3.219700] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 3.227307] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 3.291590] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[ 3.299888] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[ 3.378580] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c20000.sai/tx_bitcnt'
[ 3.390509] CPU: 0 PID: 32 Comm: kworker/0:1 Not tainted 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 3.399031] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 3.404348] Workqueue: events deferred_probe_work_func
[ 3.409487] Call trace:
[ 3.411936] dump_backtrace+0x0/0x1a8
[ 3.415598] show_stack+0x18/0x68
[ 3.418914] dump_stack+0xd0/0x12c
[ 3.422316] sysfs_warn_dup+0x60/0x80
[ 3.425977] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 3.430506] internal_create_group+0x104/0x3c0
[ 3.434949] sysfs_create_group+0x18/0x28
[ 3.438959] fsl_sai_probe+0x538/0x7f0
[ 3.442708] platform_drv_probe+0x54/0xa8
[ 3.446717] really_probe+0xe4/0x3b0
[ 3.450291] driver_probe_device+0x58/0xb8
[ 3.454386] __device_attach_driver+0x84/0xc8
[ 3.458742] bus_for_each_drv+0x78/0xd0
[ 3.462577] __device_attach+0xf4/0x150
[ 3.466413] device_initial_probe+0x14/0x20
[ 3.470597] bus_probe_device+0x9c/0xa8
[ 3.474431] deferred_probe_work_func+0x80/0xb8
[ 3.478962] process_one_work+0x1bc/0x338
[ 3.482971] worker_thread+0x1f8/0x420
[ 3.486722] kthread+0x140/0x160
[ 3.489949] ret_from_fork+0x10/0x34
[ 3.493566] fsl-sai 30c20000.sai: fail to create sys group
[ 3.502099] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c30000.sai/tx_bitcnt'
[ 3.513966] CPU: 0 PID: 32 Comm: kworker/0:1 Not tainted 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 3.522487] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 3.527804] Workqueue: events deferred_probe_work_func
[ 3.532943] Call trace:
[ 3.535391] dump_backtrace+0x0/0x1a8
[ 3.539053] show_stack+0x18/0x68
[ 3.542368] dump_stack+0xd0/0x12c
[ 3.545770] sysfs_warn_dup+0x60/0x80
[ 3.549433] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 3.553963] internal_create_group+0x104/0x3c0
[ 3.558406] sysfs_create_group+0x18/0x28
[ 3.562416] fsl_sai_probe+0x538/0x7f0
[ 3.566165] platform_drv_probe+0x54/0xa8
[ 3.570173] really_probe+0xe4/0x3b0
[ 3.573747] driver_probe_device+0x58/0xb8
[ 3.577842] __device_attach_driver+0x84/0xc8
[ 3.582197] bus_for_each_drv+0x78/0xd0
[ 3.586031] __device_attach+0xf4/0x150
[ 3.589866] device_initial_probe+0x14/0x20
[ 3.594047] bus_probe_device+0x9c/0xa8
[ 3.597882] deferred_probe_work_func+0x80/0xb8
[ 3.602412] process_one_work+0x1bc/0x338
[ 3.606419] worker_thread+0x1f8/0x420
[ 3.610168] kthread+0x140/0x160
[ 3.613395] ret_from_fork+0x10/0x34
[ 3.617010] fsl-sai 30c30000.sai: fail to create sys group
[ 3.623787] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 3.629057] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 3.634300] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 3.639540] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 3.645531] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 3.652391] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 3.659898] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 3.667154] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 3.674571] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 3.681211] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 3.688779] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 3.704000] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 3.709275] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 3.714592] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 3.719855] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 3.725835] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 3.732670] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 3.740147] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 3.747435] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 3.755029] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 3.761677] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 3.769410] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 3.797280] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c20000.sai/tx_bitcnt'
[ 3.809144] CPU: 3 PID: 86 Comm: kworker/3:1 Not tainted 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 3.815732] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.824166] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 3.824177] Workqueue: events deferred_probe_work_func
[ 3.832798] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 3.838093] Call trace:
[ 3.838099] dump_backtrace+0x0/0x1a8
[ 3.838104] show_stack+0x18/0x68
[ 3.866743] dump_stack+0xd0/0x12c
[ 3.866748] sysfs_warn_dup+0x60/0x80
[ 3.866753] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 3.866757] internal_create_group+0x104/0x3c0
[ 3.866761] sysfs_create_group+0x18/0x28
[ 3.866767] fsl_sai_probe+0x538/0x7f0
[ 3.866771] platform_drv_probe+0x54/0xa8
[ 3.866774] really_probe+0xe4/0x3b0
[ 3.866777] driver_probe_device+0x58/0xb8
[ 3.866782] __device_attach_driver+0x84/0xc8
[ 3.866786] bus_for_each_drv+0x78/0xd0
[ 3.866789] __device_attach+0xf4/0x150
[ 3.866794] device_initial_probe+0x14/0x20
[ 3.866798] bus_probe_device+0x9c/0xa8
[ 3.866803] deferred_probe_work_func+0x80/0xb8
[ 3.866808] process_one_work+0x1bc/0x338
[ 3.866814] worker_thread+0x50/0x420
[ 3.866818] kthread+0x140/0x160
[ 3.866821] ret_from_fork+0x10/0x34
[ 3.866869] fsl-sai 30c20000.sai: fail to create sys group
[ 3.870338] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c30000.sai/tx_bitcnt'
[ 3.962737] CPU: 3 PID: 86 Comm: kworker/3:1 Not tainted 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 3.971259] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 3.976576] Workqueue: events deferred_probe_work_func
[ 3.981715] Call trace:
[ 3.984163] dump_backtrace+0x0/0x1a8
[ 3.987825] show_stack+0x18/0x68
[ 3.991141] dump_stack+0xd0/0x12c
[ 3.994543] sysfs_warn_dup+0x60/0x80
[ 3.998203] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 4.002733] internal_create_group+0x104/0x3c0
[ 4.007176] sysfs_create_group+0x18/0x28
[ 4.011186] fsl_sai_probe+0x538/0x7f0
[ 4.014934] platform_drv_probe+0x54/0xa8
[ 4.018943] really_probe+0xe4/0x3b0
[ 4.022515] driver_probe_device+0x58/0xb8
[ 4.026609] __device_attach_driver+0x84/0xc8
[ 4.030965] bus_for_each_drv+0x78/0xd0
[ 4.034798] __device_attach+0xf4/0x150
[ 4.038633] device_initial_probe+0x14/0x20
[ 4.042815] bus_probe_device+0x9c/0xa8
[ 4.046650] deferred_probe_work_func+0x80/0xb8
[ 4.051181] process_one_work+0x1bc/0x338
[ 4.055192] worker_thread+0x50/0x420
[ 4.058854] kthread+0x140/0x160
[ 4.062081] ret_from_fork+0x10/0x34
[ 4.065695] fsl-sai 30c30000.sai: fail to create sys group
[ 4.071357] imx6q-pcie 33800000.pcie: failed to initialize host
[ 4.077955] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 4.082719] imx6q-pcie 33800000.pcie: unable to add pcie port.
[ 4.087970] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 4.103553] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 4.108789] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 4.114729] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 4.121551] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 4.129048] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 4.136335] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 4.143753] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 4.153269] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 4.161035] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 4.844753] initrd: found more than 10% free space on disk, resizing /dev/mmcblk2p2
[ 4.852502] initrd: partition to full disk size, see /run/initramfs/resize-writable.log for details
[ 6.068602] initrd: checking filesystem for writable partition
[ 6.234258] initrd: mounting /run
[ 8.738257] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.755333] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 12.466359] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.477729] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 12.483008] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 12.489503] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 12.496483] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 12.504025] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 12.504057] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 12.511535] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 12.511563] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 12.520319] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 12.520347] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 12.529358] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 12.721770] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[ 12.734325] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c20000.sai/tx_bitcnt'
[ 12.734338] CPU: 2 PID: 92 Comm: kworker/2:1 Tainted: G C 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 12.734340] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 12.734351] Workqueue: events deferred_probe_work_func
[ 12.734356] Call trace:
[ 12.734363] dump_backtrace+0x0/0x1a8
[ 12.734367] show_stack+0x18/0x68
[ 12.734372] dump_stack+0xd0/0x12c
[ 12.734378] sysfs_warn_dup+0x60/0x80
[ 12.734382] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 12.734386] internal_create_group+0x104/0x3c0
[ 12.734390] sysfs_create_group+0x18/0x28
[ 12.734394] fsl_sai_probe+0x538/0x7f0
[ 12.734399] platform_drv_probe+0x54/0xa8
[ 12.734402] really_probe+0xe4/0x3b0
[ 12.734406] driver_probe_device+0x58/0xb8
[ 12.734409] __device_attach_driver+0x84/0xc8
[ 12.734413] bus_for_each_drv+0x78/0xd0
[ 12.734416] __device_attach+0xf4/0x150
[ 12.734419] device_initial_probe+0x14/0x20
[ 12.734423] bus_probe_device+0x9c/0xa8
[ 12.734426] deferred_probe_work_func+0x80/0xb8
[ 12.734432] process_one_work+0x1bc/0x338
[ 12.734436] worker_thread+0x50/0x420
[ 12.734440] kthread+0x140/0x160
[ 12.734444] ret_from_fork+0x10/0x34
[ 12.734470] fsl-sai 30c20000.sai: fail to create sys group
[ 12.742770] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c30000.sai/tx_bitcnt'
[ 12.742781] CPU: 2 PID: 92 Comm: kworker/2:1 Tainted: G C 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 12.742784] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 12.742794] Workqueue: events deferred_probe_work_func
[ 12.742799] Call trace:
[ 12.742805] dump_backtrace+0x0/0x1a8
[ 12.742810] show_stack+0x18/0x68
[ 12.742815] dump_stack+0xd0/0x12c
[ 12.742820] sysfs_warn_dup+0x60/0x80
[ 12.742824] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 12.742828] internal_create_group+0x104/0x3c0
[ 12.742831] sysfs_create_group+0x18/0x28
[ 12.742836] fsl_sai_probe+0x538/0x7f0
[ 12.742841] platform_drv_probe+0x54/0xa8
[ 12.742844] really_probe+0xe4/0x3b0
[ 12.742849] driver_probe_device+0x58/0xb8
[ 12.742852] __device_attach_driver+0x84/0xc8
[ 12.742856] bus_for_each_drv+0x78/0xd0
[ 12.742859] __device_attach+0xf4/0x150
[ 12.742862] device_initial_probe+0x14/0x20
[ 12.742868] bus_probe_device+0x9c/0xa8
[ 12.742873] deferred_probe_work_func+0x80/0xb8
[ 12.742878] process_one_work+0x1bc/0x338
[ 12.742882] worker_thread+0x50/0x420
[ 12.742886] kthread+0x140/0x160
[ 12.742890] ret_from_fork+0x10/0x34
[ 12.742916] fsl-sai 30c30000.sai: fail to create sys group
[ 12.749701] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 12.755003] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 12.760339] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 12.765631] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 12.771132] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 12.771165] fsl-micfil-dai 30ca0000.micfil: failed to pcm register
[ 12.778536] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 12.778563] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to pcm register
[ 12.786188] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 12.786215] fsl-aud2htx 30cb0000.aud2htx: failed to init imx pcm dma: -517
[ 12.793948] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ 12.802360] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[ 12.999806] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ 13.005998] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ 13.019549] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ 13.024864] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ 13.030782] imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
[ 13.042819] fsl-micfil-dai 30ca0000.micfil: Unbalanced pm_runtime_enable!
[ 13.043936] fsl,imx8mp-audio-xcvr 30cc0000.xcvr: Unbalanced pm_runtime_enable!
[ 13.044958] fsl-aud2htx 30cb0000.aud2htx: Unbalanced pm_runtime_enable!
[ 13.056727] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c20000.sai/tx_bitcnt'
[ 13.056740] CPU: 1 PID: 33 Comm: kworker/1:1 Tainted: G C 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 13.056743] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 13.056754] Workqueue: events deferred_probe_work_func
[ 13.056760] Call trace:
[ 13.056767] dump_backtrace+0x0/0x1a8
[ 13.056771] show_stack+0x18/0x68
[ 13.056777] dump_stack+0xd0/0x12c
[ 13.056782] sysfs_warn_dup+0x60/0x80
[ 13.056786] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 13.056790] internal_create_group+0x104/0x3c0
[ 13.056794] sysfs_create_group+0x18/0x28
[ 13.056799] fsl_sai_probe+0x538/0x7f0
[ 13.056803] platform_drv_probe+0x54/0xa8
[ 13.056807] really_probe+0xe4/0x3b0
[ 13.056810] driver_probe_device+0x58/0xb8
[ 13.056814] __device_attach_driver+0x84/0xc8
[ 13.056817] bus_for_each_drv+0x78/0xd0
[ 13.056821] __device_attach+0xf4/0x150
[ 13.056824] device_initial_probe+0x14/0x20
[ 13.056828] bus_probe_device+0x9c/0xa8
[ 13.056831] deferred_probe_work_func+0x80/0xb8
[ 13.056836] process_one_work+0x1bc/0x338
[ 13.056840] worker_thread+0x50/0x420
[ 13.056845] kthread+0x140/0x160
[ 13.056849] ret_from_fork+0x10/0x34
[ 13.056877] fsl-sai 30c20000.sai: fail to create sys group
[ 13.066160] sysfs: cannot create duplicate filename '/devices/platform/soc@0/30c00000.bus/30c00000.spba-bus/30c30000.sai/tx_bitcnt'
[ 13.066173] CPU: 1 PID: 33 Comm: kworker/1:1 Tainted: G C 5.10.35-duke-snappy+gef3f2cfc6010 #1
[ 13.066176] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 13.066187] Workqueue: events deferred_probe_work_func
[ 13.066192] Call trace:
[ 13.066199] dump_backtrace+0x0/0x1a8
[ 13.066203] show_stack+0x18/0x68
[ 13.066209] dump_stack+0xd0/0x12c
[ 13.066214] sysfs_warn_dup+0x60/0x80
[ 13.066217] sysfs_add_file_mode_ns+0x1a0/0x1a8
[ 13.066221] internal_create_group+0x104/0x3c0
[ 13.066225] sysfs_create_group+0x18/0x28
[ 13.066230] fsl_sai_probe+0x538/0x7f0
[ 13.066234] platform_drv_probe+0x54/0xa8
[ 13.066238] really_probe+0xe4/0x3b0
[ 13.066242] driver_probe_device+0x58/0xb8
[ 13.066247] __device_attach_driver+0x84/0xc8
[ 13.066250] bus_for_each_drv+0x78/0xd0
[ 13.066253] __device_attach+0xf4/0x150
[ 13.066257] device_initial_probe+0x14/0x20
[ 13.066260] bus_probe_device+0x9c/0xa8
[ 13.066264] deferred_probe_work_func+0x80/0xb8
[ 13.066270] process_one_work+0x1bc/0x338
[ 13.066274] worker_thread+0x50/0x420
[ 13.066279] kthread+0x140/0x160
[ 13.066282] ret_from_fork+0x10/0x34
[ 13.066308] fsl-sai 30c30000.sai: fail to create sys group
[ 13.085299] debugfs: File 'Playback' in directory 'dapm' already present!
[ 13.092185] debugfs: File 'Capture' in directory 'dapm' already present!
[ 13.112563] debugfs: Directory '30c90000.easrc' with parent 'wm8960-audio' already present!
[ 13.460702] caam 30900000.crypto: failed to acquire DECO 0
[ 13.466254] caam 30900000.crypto: Failed to deinstantiate RNG4 SH0
[ 13.472522] caam 30900000.crypto: failed to instantiate
DTS:
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright 2019 NXP
/dts-v1/;
#include <dt-bindings/usb/pd.h>
#include "imx8mp.dtsi"
model = "NXP i.MX8MPlus EVK board";
compatible = "fsl,imx8mp-evk", "fsl,imx8mp";
chosen {
stdout-path = &uart2;
gpio-leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_led>;
status {
label = "yellow:status";
gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>;
default-state = "on";
memory@40000000 {
device_type = "memory";
reg = <0x0 0x40000000 0 0xc0000000>,
<0x1 0x00000000 0 0xc0000000>;
reg_can1_stby: regulator-can1-stby {
compatible = "regulator-fixed";
regulator-name = "can1-stby";
pinctrl-0 = <&pinctrl_flexcan1_reg>;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio5 5 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_can2_stby: regulator-can2-stby {
regulator-name = "can2-stby";
pinctrl-0 = <&pinctrl_flexcan2_reg>;
gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_usdhc2_vmmc: regulator-usdhc2 {
pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>;
regulator-name = "VSD_3V3";
gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_audio_pwr: regulator-audio-pwr {
regulator-name = "audio-pwr";
gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>;
enable-active-high;
regulator-always-on;
bt_sco_codec: bt_sco_codec {
#sound-dai-cells = <1>;
compatible = "linux,bt-sco";
sound-bt-sco {
compatible = "simple-audio-card";
simple-audio-card,name = "bt-sco-audio";
simple-audio-card,format = "dsp_a";
simple-audio-card,bitclock-inversion;
simple-audio-card,frame-master = <&btcpu>;
simple-audio-card,bitclock-master = <&btcpu>;
btcpu: simple-audio-card,cpu {
sound-dai = <&sai2>;
dai-tdm-slot-num = <2>;
dai-tdm-slot-width = <16>;
simple-audio-card,codec {
sound-dai = <&bt_sco_codec 1>;
sound-hdmi {
compatible = "fsl,imx-audio-cdnhdmi";
model = "audio-hdmi";
audio-cpu = <&aud2htx>;
hdmi-out;
constraint-rate = <44100>,
<88200>,
<176400>,
<32000>,
<48000>,
<96000>,
<192000>;
status = "okay";
sound-wm8960 {
compatible = "fsl,imx-audio-wm8960";
model = "wm8960-audio";
audio-cpu = <&sai3>;
audio-codec = <&codec>;
audio-asrc=<&easrc>;
hp-det-gpio = <&gpio4 28 0>;
audio-routing =
"Headphone Jack", "HP_L",
"Headphone Jack", "HP_R",
"Ext Spk", "SPK_LP",
"Ext Spk", "SPK_LN",
"Ext Spk", "SPK_RP",
"Ext Spk", "SPK_RN",
"LINPUT1", "Mic Jack",
"LINPUT3", "Mic Jack",
"Mic Jack", "MICB";
sound-micfil {
compatible = "fsl,imx-audio-micfil";
model = "imx-audio-micfil";
cpu-dai = <&micfil>;
sound-xcvr {
compatible = "fsl,imx-audio-xcvr";
model = "imx-audio-xcvr";
cpu-dai = <&xcvr>;
lvds_backlight: lvds_backlight {
compatible = "pwm-backlight";
pwms = <&pwm2 0 100000>;
status = "okay";
brightness-levels = < 0 1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18 19
20 21 22 23 24 25 26 27 28 29
30 31 32 33 34 35 36 37 38 39
40 41 42 43 44 45 46 47 48 49
50 51 52 53 54 55 56 57 58 59
60 61 62 63 64 65 66 67 68 69
70 71 72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87 88 89
90 91 92 93 94 95 96 97 98 99
100>;
default-brightness-level = <80>;
cbtl04gp {
compatible = "nxp,cbtl04gp";
pinctrl-0 = <&pinctrl_typec_mux>;
switch-gpios = <&gpio4 20 GPIO_ACTIVE_LOW>;
orientation-switch;
port {
usb3_data_ss: endpoint {
remote-endpoint = <&typec_con_ss>;
&A53_0 {
cpu-supply = <&buck2>;
&A53_1 {
&A53_2 {
&A53_3 {
&dsp {
status = "okay";
&pwm1 {
pinctrl-0 = <&pinctrl_pwm1>;
status = "okay";
&pwm2 {
pinctrl-0 = <&pinctrl_pwm2>;
status = "okay";
&pwm4 {
pinctrl-0 = <&pinctrl_pwm4>;
status = "okay";
&aud2htx {
status = "okay";
&ecspi2 {
#address-cells = <1>;
#size-cells = <0>;
fsl,spi-num-chipselects = <1>;
pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>;
cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>;
status = "okay";
spidev1: spi@0 {
reg = <0>;
compatible = "rohm,dh2228fv";
spi-max-frequency = <500000>;
&eqos {
pinctrl-0 = <&pinctrl_eqos>;
phy-mode = "rgmii-id";
phy-handle = <&ethphy0>;
status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#size-cells = <0>;
ethphy0: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <1>;
eee-broken-1000t;
rtl821x,aldps-disable;
rtl821x,clkout-disable;
&fec {
pinctrl-0 = <&pinctrl_fec>;
phy-handle = <&ethphy1>;
fsl,magic-packet;
status = "okay";
mdio {
#size-cells = <0>;
ethphy1: ethernet-phy@1 {
reg = <1>;
eee-broken-1000t;
&flexspi {
pinctrl-0 = <&pinctrl_flexspi0>;
status = "okay";
flash0: mt25qu256aba@0 {
reg = <0>;
#size-cells = <1>;
compatible = "jedec,spi-nor";
spi-max-frequency = <80000000>;
spi-tx-bus-width = <4>;
spi-rx-bus-width = <4>;
&flexcan1 {
pinctrl-0 = <&pinctrl_flexcan1>;
xceiver-supply = <&reg_can1_stby>;
status = "okay";
&flexcan2 {
pinctrl-0 = <&pinctrl_flexcan2>;
xceiver-supply = <&reg_can2_stby>;
pinctrl-assert-gpios = <&pca6416 3 GPIO_ACTIVE_HIGH>;
status = "disabled";/* can2 pin conflict with pdm: gpio low select pdm, gpio high select can2 */
&i2c1 {
clock-frequency = <400000>;
pinctrl-0 = <&pinctrl_i2c1>;
status = "okay";
pmic: pca9450@25 {
reg = <0x25>;
compatible = "nxp,pca9450c";
/* PMIC PCA9450 PMIC_nINT GPIO1_IO3 */
pinctrl-0 = <&pinctrl_pmic>;
interrupt-parent = <&gpio1>;
interrupts = GPIO_ACTIVE_LOW>;
regulators {
buck1: BUCK1 {
regulator-name = "BUCK1";
regulator-min-microvolt = <600000>;
regulator-max-microvolt = <2187500>;
regulator-boot-on;
regulator-ramp-delay = <3125>;
buck2: BUCK2 {
regulator-name = "BUCK2";
regulator-boot-on;
nxp,dvs-run-voltage = <950000>;
nxp,dvs-standby-voltage = <850000>;
buck4: BUCK4{
regulator-name = "BUCK4";
regulator-max-microvolt = <3400000>;
regulator-boot-on;
buck5: BUCK5{
regulator-name = "BUCK5";
regulator-boot-on;
buck6: BUCK6 {
regulator-name = "BUCK6";
regulator-boot-on;
ldo1: LDO1 {
regulator-name = "LDO1";
regulator-min-microvolt = <1600000>;
regulator-boot-on;
ldo2: LDO2 {
regulator-name = "LDO2";
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
ldo3: LDO3 {
regulator-name = "LDO3";
regulator-boot-on;
ldo4: LDO4 {
regulator-name = "LDO4";
regulator-boot-on;
ldo5: LDO5 {
regulator-name = "LDO5";
regulator-min-microvolt = <1800000>;
regulator-boot-on;
&i2c2 {
clock-frequency = <100000>;
pinctrl-0 = <&pinctrl_i2c2>;
status = "okay";
adv_bridge: adv7535@3d {
compatible = "adi,adv7533";
reg = <0x3d>;
adi,addr-cec = <0x3b>;
adi,dsi-lanes = <4>;
status = "okay";
port {
adv7535_from_dsim: endpoint {
remote-endpoint = <&dsim_to_adv7535>;
lvds_bridge: lvds-to-hdmi-bridge@4c {
compatible = "ite,it6263";
reg = <0x4c>;
reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
port {
it6263_in: endpoint {
remote-endpoint = <&lvds_out>;
ov5640_0: ov5640_mipi@3c {
compatible = "ovti,ov5640";
reg = <0x3c>;
pinctrl-0 = <&pinctrl_csi0_pwn>, <&pinctrl_csi0_rst>, <&pinctrl_csi_mclk>;
clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
clock-names = "xclk";
assigned-clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
assigned-clock-parents = <&clk IMX8MP_CLK_24M>;
assigned-clock-rates = <24000000>;
csi_id = <0>;
powerdown-gpios = <&gpio2 11 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
mclk = <24000000>;
mclk_source = <0>;
mipi_csi;
status = "okay";
port {
ov5640_mipi_0_ep: endpoint {
remote-endpoint = <&mipi_csi0_ep>;
data-lanes = <1 2>;
clock-lanes = <0>;
ptn5110: tcpc@50 {
compatible = "nxp,ptn5110";
pinctrl-0 = <&pinctrl_typec>;
reg = <0x50>;
interrupt-parent = <&gpio4>;
interrupts = <19 8>;
port {
typec_dr_sw: endpoint {
remote-endpoint = <&usb3_drd_sw>;
usb_con: connector {
compatible = "usb-c-connector";
label = "USB-C";
power-role = "dual";
data-role = "dual";
try-power-role = "sink";
source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>;
sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)
PDO_VAR(5000, 20000, 3000)>;
op-sink-microwatt = <15000000>;
self-powered;
ports {
#size-cells = <0>;
port@1 {
reg = <1>;
typec_con_ss: endpoint {
remote-endpoint = <&usb3_data_ss>;
&i2c3 {
pinctrl-0 = <&pinctrl_i2c3>;
status = "okay";
pca6416: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
codec: wm8960@1a {
compatible = "wlf,wm8960";
reg = <0x1a>;
clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI3_MCLK1>;
clock-names = "mclk";
wlf,shared-lrclk;
wlf,hp-cfg = 2 3>;
wlf,gpio-cfg = <1 3>;
SPKVDD1-supply = <&reg_audio_pwr>;
ov5640_1: ov5640_mipi@3c {
reg = <0x3c>;
csi_id = <0>;
powerdown-gpios = <&gpio4 1 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio4 0 GPIO_ACTIVE_LOW>;
mclk = <24000000>;
mclk_source = <0>;
mipi_csi;
port {
ov5640_mipi_1_ep: endpoint {
remote-endpoint = <&mipi_csi1_ep>;
data-lanes = <1 2>;
clock-lanes = <0>;
&irqsteer_hdmi {
status = "okay";
&hdmi_blk_ctrl {
status = "okay";
&hdmi_pavi {
status = "okay";
&hdmi {
status = "okay";
&hdmiphy {
status = "okay";
&lcdif1 {
status = "okay";
&lcdif2 {
status = "okay";
&lcdif3 {
status = "okay";
thres-low = <1 2>; /* (FIFO * 1 / 2) */
thres-high = 4>; /* (FIFO * 3 / 4) */
&ldb {
status = "okay";
lvds-channel@0 {
fsl,data-mapping = "jeida";
fsl,data-width = <24>;
status = "okay";
port@1 {
reg = <1>;
lvds_out: endpoint {
remote-endpoint = <&it6263_in>;
&ldb_phy {
status = "okay";
&mipi_dsi {
status = "okay";
port@1 {
dsim_to_adv7535: endpoint {
remote-endpoint = <&adv7535_from_dsim>;
attach-bridge;
&snvs_pwrkey {
status = "okay";
&easrc {
fsl,asrc-rate = <48000>;
status = "okay";
&micfil {
pinctrl-0 = <&pinctrl_pdm>;
assigned-clocks = <&clk IMX8MP_CLK_PDM>;
assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
assigned-clock-rates = <196608000>;
status = "okay";
&pcie{
pinctrl-0 = <&pinctrl_pcie>;
disable-gpio = <&gpio2 6 GPIO_ACTIVE_LOW>;
reset-gpio = <&gpio2 7 GPIO_ACTIVE_LOW>;
ext_osc = <1>;
clocks = <&clk IMX8MP_CLK_HSIO_ROOT>,
<&clk IMX8MP_CLK_PCIE_AUX>,
<&clk IMX8MP_CLK_HSIO_AXI>,
<&clk IMX8MP_CLK_PCIE_ROOT>;
clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus";
assigned-clocks = <&clk IMX8MP_CLK_HSIO_AXI>,
<&clk IMX8MP_CLK_PCIE_AUX>;
assigned-clock-rates = <500000000>, <10000000>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL2_500M>,
<&clk IMX8MP_SYS_PLL2_50M>;
l1ss-disabled;
status = "okay";
wifi_wake_host {
compatible = "nxp,wifi-wake-host";
interrupt-parent = <&gpio5>;
interrupts = <21 IRQ_TYPE_LEVEL_LOW>;
interrupt-names = "host-wake";
&pcie_ep{
ext_osc = <1>;
&pcie_phy{
ext_osc = <1>;
status = "okay";
&sai2 {
#sound-dai-cells = <0>;
pinctrl-0 = <&pinctrl_sai2>;
assigned-clocks = <&clk IMX8MP_CLK_SAI2>;
assigned-clock-rates = <12288000>;
status = "okay";
&sai3 {
pinctrl-0 = <&pinctrl_sai3>;
assigned-clocks = <&clk IMX8MP_CLK_SAI3>;
clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI3_IPG>, <&clk IMX8MP_CLK_DUMMY>,
<&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI3_MCLK1>, <&clk IMX8MP_CLK_DUMMY>,
<&clk IMX8MP_CLK_DUMMY>;
clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3";
fsl,sai-mclk-direction-output;
status = "okay";
&xcvr {
status = "okay";
&sdma2 {
status = "okay";
&uart1 { /* BT */
pinctrl-0 = <&pinctrl_uart1>;
assigned-clocks = <&clk IMX8MP_CLK_UART1>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
fsl,uart-has-rtscts;
status = "okay";
&uart2 {
/* console */
pinctrl-0 = <&pinctrl_uart2>;
status = "okay";
&uart3 {
pinctrl-0 = <&pinctrl_uart3>;
assigned-clocks = <&clk IMX8MP_CLK_UART3>;
status = "okay";
&usb3_phy0 {
vbus-power-supply = <&ptn5110>;
fsl,phy-tx-vref-tune = <0xe>;
fsl,phy-tx-preemp-amp-tune = <3>;
fsl,phy-tx-vboost-level = <5>;
fsl,phy-comp-dis-tune = <7>;
fsl,pcs-tx-deemph-3p5db = <0x21>;
fsl,phy-pcs-tx-swing-full = <0x7f>;
status = "okay";
&usb3_0 {
status = "okay";
&usb_dwc3_0 {
dr_mode = "otg";
hnp-disable;
srp-disable;
adp-disable;
usb-role-switch;
role-switch-default-mode = "none";
status = "okay";
port {
usb3_drd_sw: endpoint {
remote-endpoint = <&typec_dr_sw>;
&usb3_phy1 {
fsl,phy-tx-vref-tune = <0xb>;
status = "okay";
&usb3_1 {
status = "okay";
&usb_dwc3_1 {
pinctrl-0 = <&pinctrl_usb1_vbus>;
dr_mode = "host";
status = "okay";
&usdhc2 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC2>;
assigned-clock-rates = <400000000>;
pinctrl-names = "default", "state_100mhz", "state_200mhz";
pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
vmmc-supply = <&reg_usdhc2_vmmc>;
bus-width = <4>;
status = "okay";
&usdhc3 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC3>;
pinctrl-0 = <&pinctrl_usdhc3>;
pinctrl-1 = <&pinctrl_usdhc3_100mhz>;
pinctrl-2 = <&pinctrl_usdhc3_200mhz>;
bus-width = <8>;
non-removable;
status = "okay";
&wdog1 {
pinctrl-0 = <&pinctrl_wdog>;
fsl,ext-reset-output;
status = "okay";
&iomuxc {
pinctrl-0 = <&pinctrl_hog>;
pinctrl_hog: hoggrp {
fsl,pins = <
MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_HDMI_SCL 0x400001c3
MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_HDMI_SDA 0x400001c3
MX8MP_IOMUXC_HDMI_HPD__HDMIMIX_HDMI_HPD 0x40000019
MX8MP_IOMUXC_HDMI_CEC__HDMIMIX_HDMI_CEC 0x40000019
pinctrl_pwm1: pwm1grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO01__PWM1_OUT 0x116
pinctrl_pwm2: pwm2grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO11__PWM2_OUT 0x116
pinctrl_pwm4: pwm4grp {
fsl,pins = <
MX8MP_IOMUXC_SAI5_RXFS__PWM4_OUT 0x116
pinctrl_ecspi2: ecspi2grp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x82
MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x82
MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x82
pinctrl_ecspi2_cs: ecspi2cs {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SS0__GPIO5_IO13 0x40000
pinctrl_eqos: eqosgrp {
fsl,pins = <
MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3
MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3
MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91
MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91
MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91
MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91
MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91
MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91
MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f
MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f
MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f
MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f
MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f
MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f
MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x19
pinctrl_fec: fecgrp {
fsl,pins = <
MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3
MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3
MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91
MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91
MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91
MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91
MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91
MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91
MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f
MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f
MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f
MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f
MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f
MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f
MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x19
pinctrl_flexcan1: flexcan1grp {
fsl,pins = <
MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x154
MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x154
pinctrl_flexcan2: flexcan2grp {
fsl,pins = <
MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x154
MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x154
pinctrl_flexcan1_reg: flexcan1reggrp {
fsl,pins = <
MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x154 /* CAN1_STBY */
pinctrl_flexcan2_reg: flexcan2reggrp {
fsl,pins = <
MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x154 /* CAN2_STBY */
pinctrl_flexspi0: flexspi0grp {
fsl,pins = <
MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x1c2
MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x82
MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x82
MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x82
MX8MP_IOMUXC_NAND_DATA02__FLEXSPI_A_DATA02 0x82
MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x82
pinctrl_gpio_led: gpioledgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x19
pinctrl_i2c1: i2c1grp {
fsl,pins = <
MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c3
MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c3
pinctrl_i2c2: i2c2grp {
fsl,pins = <
MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3
MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3
pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3
MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3
pinctrl_mipi_dsi_en: mipi_dsi_en {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO08__GPIO1_IO08 0x16
pinctrl_pcie: pciegrp {
fsl,pins = <
MX8MP_IOMUXC_I2C4_SCL__PCIE_CLKREQ_B 0x61 /* open drain, pull up */
MX8MP_IOMUXC_SD1_DATA4__GPIO2_IO06 0x41
MX8MP_IOMUXC_SD1_DATA5__GPIO2_IO07 0x41
MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x1c4
pinctrl_pmic: pmicirq {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x41
pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41
pinctrl_pdm: pdmgrp {
fsl,pins = <
MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_PDM_CLK 0xd6
MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_PDM_BIT_STREAM00 0xd6
MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_PDM_BIT_STREAM01 0xd6
MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_PDM_BIT_STREAM02 0xd6
MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_PDM_BIT_STREAM03 0xd6
pinctrl_sai2: sai2grp {
fsl,pins = <
MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK 0xd6
MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC 0xd6
MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00 0xd6
MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00 0xd6
pinctrl_sai3: sai3grp {
fsl,pins = <
MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0xd6
MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0xd6
MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0xd6
MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0xd6
MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0xd6
MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0xd6
MX8MP_IOMUXC_SAI3_RXC__GPIO4_IO29 0xd6
pinctrl_i2c2_synaptics_dsx_io: synaptics_dsx_iogrp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x16
pinctrl_uart1: uart1grp {
fsl,pins = <
MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x140
MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x140
MX8MP_IOMUXC_UART3_RXD__UART1_DCE_CTS 0x140
MX8MP_IOMUXC_UART3_TXD__UART1_DCE_RTS 0x140
pinctrl_typec: typec1grp {
fsl,pins = <
MX8MP_IOMUXC_SAI1_TXD7__GPIO4_IO19 0x1c4
pinctrl_typec_mux: typec1muxgrp {
fsl,pins = <
MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x16
pinctrl_uart2: uart2grp {
fsl,pins = <
MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x49
MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x49
pinctrl_uart3: uart3grp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x140
MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x140
MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x140
MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x140
pinctrl_usb1_vbus: usb1grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO14__USB2_PWR 0x19
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0
MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1
pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4
pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6
pinctrl_usdhc2_gpio: usdhc2gpiogrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4
pinctrl_usdhc3: usdhc3grp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190
pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194
pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196
pinctrl_wdog: wdoggrp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6
pinctrl_csi0_pwn: csi0_pwn_grp {
fsl,pins = <
MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x19
pinctrl_csi0_rst: csi0_rst_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x19
pinctrl_csi_mclk: csi_mclk_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO15__CCM_CLKO2 0x59
&vpu_g1 {
status = "okay";
&vpu_g2 {
status = "okay";
&vpu_vc8000e {
status = "okay";
&vpu_v4l2 {
status = "okay";
&gpu_3d {
status = "okay";
&gpu_2d {
status = "okay";
&ml_vipsi {
status = "okay";
&mix_gpu_ml {
status = "okay";
&mipi_csi_0 {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
mipi_csi0_ep: endpoint {
remote-endpoint = <&ov5640_mipi_0_ep>;
data-lanes = <2>;
csis-hs-settle = <13>;
csis-clk-settle = <2>;
csis-wclk;
&mipi_csi_1 {
#size-cells = <0>;
port@1 {
reg = <1>;
mipi_csi1_ep: endpoint {
remote-endpoint = <&ov5640_mipi_1_ep>;
data-lanes = <2>;
csis-wclk;
&cameradev {
status = "okay";
&isi_0 {
status = "okay";
cap_device {
status = "okay";
m2m_device {
status = "okay";
&isi_1 {
cap_device {
status = "okay";
4,906 次查看
Zhiming_Liu
Hi @ammar
We have release ubuntu version which support audio codec:
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
4,050 次查看
kevinkimkr
What's version you means? Can you tell me a download link again?
4,874 次查看
ammar
We are porting ubuntu core on imx8mp-evk.
Kernel: https://source.codeaurora.org/external/imx/linux-imx
branch: rel_imx_5.4.47_2.2.0
We are getting the following dmesg logs for wm8960.
[ 8.271306] imx-wm8960 sound-wm8960: ASoC: failed to init link HiFi-ASRC-FE: -517
[ 8.278907] imx-wm8960 sound-wm8960: snd_soc_register_card failed (-517)
Is there any patch or CONFIG that we are missing?
