FreeRTOS examples of CM4 provided with the SDK does not work on i.MX RT1160 Evaluation Kit
已解决
跳至解决方案
1,456 次查看
Mc2023
Hello All,
The FreeRTOS examples of CM4 (evkmimxrt1160_freertos_hello_cm4) provided with the SDK does not work on  i.MX RT1160 Evaluation Kit.
Could you solve this issue?
Mc2023
1 解答
1,416 次查看
Mc2023
Hi Miguel,
Thanks for your message!
Did you use the GUI Flash tool or the debug mode?
In my case, it works in debug mode but I cannot use the GUI Flash tool.
在原帖中查看解决方案
3 回复数
1,417 次查看
Mc2023
Hi Miguel,
1,398 次查看
Miguel04
Hi @Mc2023
I used the debug mode, this link will take you to the mcuxpresso user guide, look into chapter 15 for more information about the GUI Flash Tool.
Best Regards, Miguel.
1,434 次查看
Miguel04
Hi @Mc2023
The example works for me, please make sure all the jumpers are connected correctly. Check this Getting Started to see jumpers J5, J6, J7 and J8. In case this doesn't work, read this post to regain access to the debugger.
