IMX8MM + sn65dsi83 + yocto scarthgap = devicetree problem
pavelko
back to 4.19 warrior I have used this configuration of sn65dsi84 DSI to LVDS bridge in device tree:
&i2c1 {
clock-frequency = <400000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c1>;
status = "okay";
dsi_lvds_bridge: sn65dsi84@2c {
compatible = "ti,sn65dsi83";
reg = <0x2c>;
ti,dsi-lanes = <4>;
ti,lvds-format = <2>;
ti,lvds-channels = <1>;
ti,lvds-bpp = <24>;
ti,width-mm = <210>;
ti,height-mm = <157>;
ti,burst-mode;
pinctrl-0 = <&pinctrl_lvds>;
enable-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
status = "okay";
display-timings {
lvds {
clock-frequency = <65000000>;
hactive = <1024>;
vactive = <768>;
hfront-porch = <24>;
hsync-len = <136>;
hback-porch = <160>;
vfront-porch = <3>;
vsync-len = <6>;
vback-porch = <29>;
vsync-active = <0>;
hsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
port {
lvds_from_dsi: endpoint {
remote-endpoint = <&dsi_to_lvds>;
&mipi_dsi {
status = "okay";
port@1 {
dsi_to_lvds: endpoint {
remote-endpoint = <&lvds_from_dsi>;
&iomuxc {
pinctrl_i2c1: i2c1grp {
fsl,pins = <
MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3
MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3
pinctrl_lvds: lvdsgrp {
fsl,pins = <
MX8MM_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x16
However, when I ported the device tree to yocto scarthgap (Linux 6.6) this definition is not working anymore:
[ 1.290572] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.298317] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.305343] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e10000 to encoder DSI-34: -19
[ 1.316955] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.325231] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -19
[ 1.332903] imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 1.341048] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.348908] imx-drm display-subsystem: [drm] Cannot find any crtc or sizes
Could anyone point me an example device tree setup for sn65dsi8(3/4/5) + imx8mm + Linux 6.6
Thanks in advance.
Manuel_Salas
Hello @pavelko
I hope you are doing very well.
You can take a look into the sn65dsi83 binding in the linux kernel.
Also, you can try with this modified device tree:
&i2c1 {
    status = "okay";
        reg = <0x2c>;
        status = "okay";
        ports {
            #address-cells = <1>;
            #size-cells = <0>;
            port@0 {
                reg = <0>;
                bridge_in: endpoint {
                    remote-endpoint = <&mipi_dsi_out>;
                    data-lanes = <1 2 3 4>;
            port@2 {
                reg = <2>;
                bridge_out: endpoint {
                    remote-endpoint = <&panel_in>;
&mipi_dsi {
    status = "okay";
    port@1 {
        reg = <1>;
        mipi_dsi_out: endpoint {
            remote-endpoint = <&bridge_in>;
panel_lvds: panel {
    compatible = "panel-lvds";
    data-mapping = "jeida-24";
    width-mm = <210>;
    height-mm = <157>;
    panel-timing {
        hactive = <1024>;
        vactive = <768>;
        hsync-len = <136>;
        vfront-porch = <3>;
        vsync-len = <6>;
        vback-porch = <29>;
        hsync-active = <0>;
        vsync-active = <0>;
        de-active = <1>;
    port {
        panel_in: endpoint {
            remote-endpoint = <&bridge_out>;
It should align with the 6.6 kernel version.
Salas.
pavelko
Thank you for your solution!
Pavel
pavelko
Thank you for the answer.
To accept it as an answer "port 1" in sn65dsi declaration shall be renamed to "port 2", as port 1 is used foe 2nd DSI output channel. and correct reg =<1> to reg=<2> accordingly.
Thank you!
Manuel_Salas
Hello @pavelko
I updated the post, please check it, also, thank you for the feedback!
Salas.
Manuel_Salas
Hello @pavelko
&i2c1 {
    status = "okay";
        reg = <0x2c>;
        status = "okay";
        ports {
            #size-cells = <0>;
            port@0 {
                reg = <0>;
            port@2 {
                reg = <2>;
&mipi_dsi {
    status = "okay";
    port@1 {
        reg = <1>;
panel_lvds: panel {
    width-mm = <210>;
    height-mm = <157>;
    panel-timing {
        hactive = <1024>;
        vactive = <768>;
        hsync-len = <136>;
        vfront-porch = <3>;
        vsync-len = <6>;
        vback-porch = <29>;
        hsync-active = <0>;
        vsync-active = <0>;
        de-active = <1>;
    port {
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2028353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MM%20%2B%20sn65dsi83%20%2B%20yocto%20scarthgap%20%3D%20devicetree%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2028353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Eback%20to%204.19%20warrior%20I%20have%20used%20this%20configuration%20of%20sn65dsi84%20DSI%20to%20LVDS%20bridge%20in%20device%20tree%3A%3C%2FP%3E%3CPRE%3E%26amp%3Bi2c1%20%7B%3CBR%20%2F%3E%20%20clock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%3CBR%20%2F%3E%20%20pinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c1%26gt%3B%3B%3CBR%20%2F%3E%20%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20dsi_lvds_bridge%3A%20sn65dsi84%402c%20%7B%3CBR%20%2F%3E%20%20%20%20compatible%20%3D%20%22ti%2Csn65dsi83%22%3B%3CBR%20%2F%3E%20%20%20%20reg%20%3D%20%26lt%3B0x2c%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Cdsi-lanes%20%3D%20%26lt%3B4%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Clvds-format%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Clvds-channels%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Clvds-bpp%20%3D%20%26lt%3B24%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Cwidth-mm%20%3D%20%26lt%3B210%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Cheight-mm%20%3D%20%26lt%3B157%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20ti%2Cburst-mode%3B%3CBR%20%2F%3E%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_lvds%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2012%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20%20%20display-timings%20%7B%3CBR%20%2F%3E%20%20%20%20%20%20lvds%20%7B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B65000000%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B1024%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B768%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%2F*%20*%2F%3CBR%20%2F%3E%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B24%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B136%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B160%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%2F*%20*%2F%3CBR%20%2F%3E%20%20%20%20%20%20%20%20vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B29%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20%2F*%20*%2F%3CBR%20%2F%3E%20%20%20%20%20%20%20%20vsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20hsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20de-active%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%20%20%20pixelclk-active%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%20%7D%3B%3CBR%20%2F%3E%20%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20port%20%7B%3CBR%20%2F%3E%20%20%20%20lvds_from_dsi%3A%20endpoint%20%7B%3CBR%20%2F%3E%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bdsi_to_lvds%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%7D%3B%3CBR%20%2F%3E%20%20%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26amp%3Bmipi_dsi%20%7B%3CBR%20%2F%3E%20%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20port%401%20%7B%3CBR%20%2F%3E%20%20%20%20dsi_to_lvds%3A%20endpoint%20%7B%3CBR%20%2F%3E%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds_from_dsi%26gt%3B%3B%3CBR%20%2F%3E%20%20%20%20%7D%3B%3CBR%20%2F%3E%20%20%7D%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26amp%3Biomuxc%20%7B%3CBR%20%2F%3E%20%20pinctrl_i2c1%3A%20i2c1grp%20%7B%3CBR%20%2F%3E%20%20%20%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20%20%20%20%20%20MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL%200x400001c3%3CBR%20%2F%3E%20%20%20%20%20%20MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA%200x400001c3%3CBR%20%2F%3E%20%20%20%20%26gt%3B%3B%3CBR%20%2F%3E%20%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%20pinctrl_lvds%3A%20lvdsgrp%20%7B%3CBR%20%2F%3E%20%20%20%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20%20%20%20%20%20MX8MM_IOMUXC_GPIO1_IO12_GPIO1_IO12%200x16%3CBR%20%2F%3E%20%20%20%20%26gt%3B%3B%3CBR%20%2F%3E%20%20%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FPRE%3E%3CP%3EHowever%2C%20when%20I%20ported%20the%20device%20tree%20to%20yocto%20scarthgap%20(Linux%206.6)%20this%20definition%20is%20not%20working%20anymore%3A%3C%2FP%3E%3CP%3E%5B%201.290572%5D%20imx-drm%20display-subsystem%3A%20bound%20imx-lcdif-crtc.0%20(ops%20lcdif_crtc_ops)%3CBR%20%2F%3E%5B%201.298317%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20version%20number%20is%200x1060200%3CBR%20%2F%3E%5B%201.305343%5D%20%5Bdrm%3Adrm_bridge_attach%5D%20*ERROR*%20failed%20to%20attach%20bridge%20%2Fsoc%400%2Fbus%4032c00000%2Fmipi_dsi%4032e10000%20to%20encoder%20DSI-34%3A%20-19%3CBR%20%2F%3E%5B%201.316955%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Failed%20to%20attach%20bridge%3A%2032e10000.mipi_dsi%3CBR%20%2F%3E%5B%201.325231%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20failed%20to%20bind%20sec%20dsim%20bridge%3A%20-19%3CBR%20%2F%3E%5B%201.332903%5D%20imx-drm%20display-subsystem%3A%20bound%2032e10000.mipi_dsi%20(ops%20imx_sec_dsim_ops)%3CBR%20%2F%3E%5B%201.341048%5D%20%5Bdrm%5D%20Initialized%20imx-drm%201.0.0%2020120507%20for%20display-subsystem%20on%20minor%200%3CBR%20%2F%3E%5B%201.348908%5D%20imx-drm%20display-subsystem%3A%20%5Bdrm%5D%20Cannot%20find%20any%20crtc%20or%20sizes%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ECould%20anyone%20point%20me%20an%20example%20device%20tree%20setup%20for%20sn65dsi8(3%2F4%2F5)%20%2B%20imx8mm%20%2B%20Linux%206.6%3C%2FP%3E%3CP%3EThanks%20in%20advance.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2029055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8MM%20%2B%20sn65dsi83%20%2B%20yocto%20scarthgap%20%3D%20devicetree%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2029055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20solution!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2029051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8MM%20%2B%20sn65dsi83%20%2B%20yocto%20scarthgap%20%3D%20devicetree%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2029051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205827%22%20target%3D%22_blank%22%3E%40pavelko%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20updated%20the%20post%2C%20please%20check%20it%2C%20also%2C%20thank%20you%20for%20the%20feedback!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2029044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8MM%20%2B%20sn65dsi83%20%2B%20yocto%20scarthgap%20%3D%20devicetree%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2029044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20the%20answer.%3C%2FP%3E%3CP%3ETo%20accept%20it%20as%20an%20answer%20%22port%201%22%20in%20sn65dsi%20declaration%20shall%20be%20renamed%20to%20%22port%202%22%2C%20as%20port%201%20is%20used%20foe%202nd%20DSI%20output%20channel.%20and%20correct%20reg%20%3D%26lt%3B1%26gt%3B%20to%20reg%3D%26lt%3B2%26gt%3B%20accordingly.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you!%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2028399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8MM%20%2B%20sn65dsi83%20%2B%20yocto%20scarthgap%20%3D%20devicetree%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2028399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205827%22%20target%3D%22_blank%22%3E%40pavelko%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20very%20well.%3C%2FP%3E%0A%3CP%3EYou%20can%20take%20a%20look%20into%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.6.y%2FDocumentation%2Fdevicetree%2Fbindings%2Fdisplay%2Fbridge%2Fti%252Csn65dsi83.yaml%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esn65dsi83%20binding%3C%2FA%3E%20in%20the%20linux%20kernel.%3C%2FP%3E%0A%3CP%3EAlso%2C%20you%20can%20try%20with%20this%20modified%20device%20tree%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%3E%26amp%3Bi2c1%20%7B%0A%20%20%20%20clock-frequency%20%3D%20%26lt%3B400000%26gt%3B%3B%0A%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c1%26gt%3B%3B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20dsi_lvds_bridge%3A%20sn65dsi84%402c%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22ti%2Csn65dsi83%22%3B%0A%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x2c%26gt%3B%3B%0A%20%20%20%20%20%20%20%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2012%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20%20%20%20%20ports%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20port%400%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20bridge_in%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_dsi_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%203%204%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20port%402%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20bridge_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%0A%26amp%3Bmipi_dsi%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20mipi_dsi_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bbridge_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%203%204%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%0Apanel_lvds%3A%20panel%20%7B%0A%20%20%20%20compatible%20%3D%20%22panel-lvds%22%3B%0A%20%20%20%20data-mapping%20%3D%20%22jeida-24%22%3B%0A%20%20%20%20width-mm%20%3D%20%26lt%3B210%26gt%3B%3B%0A%20%20%20%20height-mm%20%3D%20%26lt%3B157%26gt%3B%3B%0A%0A%20%20%20%20panel-timing%20%7B%0A%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B65000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B1024%26gt%3B%3B%0A%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B768%26gt%3B%3B%0A%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B24%26gt%3B%3B%0A%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B136%26gt%3B%3B%0A%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B160%26gt%3B%3B%0A%20%20%20%20%20%20%20%20vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%0A%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B29%26gt%3B%3B%0A%20%20%20%20%20%20%20%20hsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20vsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20de-active%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20pixelclk-active%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%7D%3B%0A%0A%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20panel_in%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bbridge_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIt%20should%20align%20with%20the%206.6%20kernel%20version.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
