IMX8MM - aspect ration
1,909 次查看
santhosh2
Hello, I am trying to change the aspect ration and seems thats its working but i am seeing lot of dataloss and there is delay. How to do this properly gst-variable-rtsp-server -p 554 -m /video_1 -u "v4l2src device=/dev/video0 ! video/x-raw,width=1920,height=1080 ! videoscale ! video/x-raw,width=1280,height=800, pixel-aspect-ratio=11/10 ! videoconvert ! vpuenc_h264 ! rtph264pay pt=96 name=pay0" Regards Santhosh
1,897 次查看
joanxie
why did you set pixel-aspect-ratio as 11/10? any reason or you just want to test this? normally we use the command pixel-aspect-ratio=(fraction)1/1 in the command, if you want to change this, you also can add this parameter in the dts file.
1,887 次查看
santhosh2
joanxie
Can you please help me to locate in dts file where to add
Santhosh
标记 (1)
1,876 次查看
joanxie
I don't know what panel you use which need such aspect ration, but you can refer to the patch as below, how to add the ration you need to the API
"https://lists.freedesktop.org/archives/dri-devel/2017-November/157835.html"
