Booting IMX8M MINI EVK from SD card for Android OS .
The process is carried out by minicom.
The booting gets completed .While running Kernel the process gets rebooting many times.
The major error begin from
[ 4.010004] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 4.018347] ALSA device list: [ 4.018672] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db [ 4.216912] init: bool android::init::BlockDevInitializer::InitDevices(std::set:string>): partition(s) not found in /sys, waiting for tb [ 14.245666] init: bool android::init::BlockDevInitializer::InitDevices(std::set:string>): partition(s) not found after polling timeout:b
Full log
[ 14.352680] imx-sdma 302b0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin [ 14.369747] ci_hdrc ci_hdrc.0: remove, state 1 [ 14.374210] usb usb1: USB disconnect, device number 1 [ 14.379268] usb 1-1: USB disconnect, device number 2 [ 14.545952] ci_hdrc ci_hdrc.0: USB bus 1 deregistered [ 14.572483] reboot: Restarting system with command 'bootloader' U-Boot SPL 2020.04-dirty (Mar 22 2021 - 09:56:56 +0530) power_bd71837_init DDRINFO: start DRAM init DDRINFO: DRAM rate 3000MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done Normal Boot Trying to boot from MMC1 NOTICE: BL31: v2.2(release):android-11.0.0_1.0.0-rc3-0-g1555e5d00 NOTICE: BL31: Built : 09:57:44, Mar 22 2021 U-Boot 2020.04-dirty (Mar 22 2021 - 09:56:56 +0530) CPU: i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz) CPU: Commercial temperature grade (0C to 95C) at 45C Reset cause: POR Model: NXP i.MX8MM EVK board DRAM: 2 GiB TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x52] Power supply on USB2 TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50] MMC: FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... *** Warning - bad CRC, using default environment [*]-Video Link 0 (1920 x 1080) [0] lcdif@32e00000, video [1] mipi_dsi@32e10000, video_bridge [2] adv7535@3d, panel In: serial Out: serial Err: serial BuildInfo: - ATF 1555e5d - U-Boot 2020.04-dirty flash target is MMC:1 Net: Warning: ethernet@30be0000 using MAC address from ROM eth0: ethernet@30be0000 Fastboot: Normal Normal Boot Hit any key to stop autoboot: 0 Writing A/B metadata to disk. verify OK, boot 'boot_b' Kernel load addr 0x40480000 size 43143 KiB kernel @ 40480000 (44177920) ramdisk @ 44680000 (8503659) fdt @ 44480000 (47651) ## Flattened Device Tree blob at 44480000 Booting using the fdt blob at 0x44480000 Using Device Tree in place at 0000000044480000, end 000000004448ea22 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.4.47 (ruban@ruban-OptiPlex-5070) (Android (6573524 based on r383902b) clang version 11.0.2 (https://android.goog1 [ 0.000000] Machine model: FSL i.MX8MM EVK board [ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200') [ 0.000000] printk: bootconsole [ec_imx6q0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 800 MiB at 0x0000000084000000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xbfbcd500-0xbfbcefff] [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000bfffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8400000-0x00000000b84fffff] [ 0.000000] node 0: [mem 0x00000000b8510000-0x00000000bfffffff] [ 0.000000] Zeroed struct page in unavailable ranges: 16 pages [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 33 pages/cpu s96280 r8192 d30696 u135168 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515056 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboo [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1179992K/2092992K available (21564K kernel code, 2310K rwdata, 13652K rodata, 5312K init, 576K bss, 93800K reserved, 819) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 128 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] random: get_random_bytes called from start_kernel+0x208/0x41c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns [ 0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns [ 0.008487] Console: colour dummy device 80x25 [ 0.012617] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000) [ 0.022845] pid_max: default: 32768 minimum: 301 [ 0.027550] LSM: Security Framework initializing [ 0.032144] SELinux: Initializing. [ 0.035674] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.043063] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.075028] ASID allocator initialised with 32768 entries [ 0.083027] rcu: Hierarchical SRCU implementation. [ 0.091949] EFI services will not be available. [ 0.099067] smp: Bringing up secondary CPUs ... [ 0.131235] Detected VIPT I-cache on CPU1 [ 0.131263] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000 [ 0.131297] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.163283] Detected VIPT I-cache on CPU2 [ 0.163300] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000 [ 0.163322] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.195340] Detected VIPT I-cache on CPU3 [ 0.195357] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000 [ 0.195376] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.195443] smp: Brought up 1 node, 4 CPUs [ 0.249202] SMP: Total of 4 processors activated. [ 0.253920] CPU features: detected: 32-bit EL0 Support [ 0.259098] CPU features: detected: CRC32 instructions [ 0.280588] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching [ 0.286126] CPU: All CPU(s) started at EL2 [ 0.290254] alternatives: patching kernel code [ 0.295715] CPU3: update max cpu_capacity 1024 [ 0.296784] devtmpfs: initialized [ 0.307593] CPU1: update max cpu_capacity 1024 [ 0.310381] Initilizing CustomIPI irq domain [ 0.316296] Registered cp15_barrier emulation handler [ 0.321352] Registered setend emulation handler [ 0.326221] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.335709] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.365231] pinctrl core: initialized pinctrl subsystem [ 0.368344] DMI not present or invalid. [ 0.371893] NET: Registered protocol family 16 [ 0.376680] schedtune: configured to support 5 boost groups [ 0.391922] DMA: preallocated 256 KiB pool for atomic allocations [ 0.395224] audit: initializing netlink subsys (disabled) [ 0.400914] audit: type=2000 audit(0.344:1): state=initialized audit_enabled=0 res=1 [ 0.408440] cpuidle: using governor menu [ 0.413099] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.420089] Serial: AMBA PL011 UART driver [ 0.423346] imx mu driver is registered. [ 0.427226] imx rpmsg driver is registered. [ 0.432485] printk: console [pstore-1] enabled [ 0.436048] pstore: Registered ramoops as persistent store backend [ 0.442096] ramoops: using 0x100000@0xb7f00000, ecc: 0 [ 0.473508] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver [ 0.493857] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.497762] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.504474] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.511214] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.519089] cryptd: max_cpu_qlen set to 1000 [ 0.525672] ACPI: Interpreter disabled. [ 0.527715] iommu: Default domain type: Translated [ 0.531909] vgaarb: loaded [ 0.534846] SCSI subsystem initialized [ 0.538387] usbcore: registered new interface driver usbfs [ 0.543598] usbcore: registered new interface driver hub [ 0.548954] usbcore: registered new device driver usb [ 0.554890] mc: Linux media interface: v0.10 [ 0.558279] videodev: Linux video capture interface: v2.00 [ 0.563825] pps_core: LinuxPPS API ver. 1 registered [ 0.568751] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 0.577949] PTP clock support registered [ 0.582147] trusty trusty: failed to get version: -1 [ 0.586868] trusty trusty: selected api version: 0 (requested 3) [ 0.593868] EDAC MC: Ver: 3.0.0 [ 0.597043] FPGA manager framework [ 0.599561] Advanced Linux Sound Architecture Driver Initialized. [ 0.606018] Bluetooth: Core ver 2.22 [ 0.609185] NET: Registered protocol family 31 [ 0.613641] Bluetooth: HCI device and connection manager initialized [ 0.620033] Bluetooth: HCI socket layer initialized [ 0.624930] Bluetooth: L2CAP socket layer initialized [ 0.630006] Bluetooth: SCO socket layer initialized [ 0.636262] clocksource: Switched to clocksource arch_sys_counter [ 0.720222] VFS: Disk quotas dquot_6.6.0 [ 0.721361] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.728412] pnp: PnP ACPI: disabled [ 0.738257] thermal_sys: Registered thermal governor 'step_wise' [ 0.738262] thermal_sys: Registered thermal governor 'power_allocator' [ 0.741802] NET: Registered protocol family 2 [ 0.752832] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.760998] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.769026] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 0.776490] TCP: Hash tables configured (established 16384 bind 16384) [ 0.782925] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.789613] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.796884] NET: Registered protocol family 1 [ 0.801553] PCI: CLS 0 bytes, default 64 [ 0.805266] Trying to unpack rootfs image as initramfs... [ 1.149071] Freeing initrd memory: 8304K [ 1.151228] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.158381] kvm [1]: IPA Size Limit: 40bits [ 1.163585] kvm [1]: GICv3: no GICV resource entry [ 1.166954] kvm [1]: disabling GICv2 emulation [ 1.171431] kvm [1]: GIC system register CPU interface enabled [ 1.177363] kvm [1]: vgic interrupt IRQ1 [ 1.181350] kvm [1]: Hyp mode initialized successfully [ 1.189846] Initialise system trusted keyrings [ 1.191545] workingset: timestamp_bits=44 max_order=19 bucket_order=0 [ 1.204668] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.207802] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. [ 1.214225] fuse: init (API version 7.31) [ 1.218160] 9p: Installing v9fs 9p2000 file system support [ 1.238063] Key type asymmetric registered [ 1.239313] Asymmetric key parser 'x509' registered [ 1.244260] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239) [ 1.251655] io scheduler mq-deadline registered [ 1.256205] io scheduler kyber registered [ 1.276602] imx-sdma 302c0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2 [ 1.284271] imx-sdma 302c0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin [ 1.302250] mxs-dma 33000000.dma-controller: initialized [ 1.306036] Bus freq driver module loaded [ 1.312546] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.318291] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 39, base_baud = 5000000) is a IMX [ 1.325389] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 40, base_baud = 5000000) is a IMX [ 1.334093] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 41, base_baud = 1500000) is a IMX [ 1.342548] printk: console [ttymxc1] enabled [ 1.342548] printk: console [ttymxc1] enabled [ 1.351204] printk: bootconsole [ec_imx6q0] disabled [ 1.351204] printk: bootconsole [ec_imx6q0] disabled [ 1.367060] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.373706] [drm] No driver support for vblank timestamp query. [ 1.379720] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops) [ 1.389676] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200 [ 1.397234] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi [ 1.405513] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517 [ 1.423315] brd: module loaded [ 1.433685] loop: module loaded [ 1.437319] zram: Added device: zram0 [ 1.442437] nd_pmem namespace0.0: unable to guarantee persistence of writes [ 1.443862] imx ahci driver is registered. [ 1.450155] pmem0: detected capacity change from 0 to 65536 [ 1.457084] spi-nor spi3.0: n25q256ax1 (32768 Kbytes) [ 1.470368] libphy: Fixed MDIO Bus: probed [ 1.475393] tun: Universal TUN/TAP device driver, 1.6 [ 1.481368] thunder_xcv, ver 1.0 [ 1.484658] thunder_bgx, ver 1.0 [ 1.487921] nicpf, ver 1.0 [ 1.491564] pps pps0: new PPS source ptp0 [ 1.501847] libphy: fec_enet_mii_bus: probed [ 1.508981] fec 30be0000.ethernet eth0: registered PHC device 0 [ 1.516354] hclge is initializing [ 1.519677] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 1.526912] hns3: Copyright (c) 2017 Huawei Corporation. [ 1.532322] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 1.539381] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 1.545176] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k [ 1.551020] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.556983] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k [ 1.563953] igb: Copyright (c) 2007-2014 Intel Corporation. [ 1.569568] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 1.577408] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 1.583522] sky2: driver version 1.30 [ 1.587941] PPP generic driver version 2.4.2 [ 1.592396] PPP BSD Compression module registered [ 1.597118] PPP Deflate Compression module registered [ 1.602197] PPP MPPE Compression module registered [ 1.607000] NET: Registered protocol family 24 [ 1.611453] PPTP driver version 0.8.5 [ 1.615357] usbcore: registered new interface driver r8152 [ 1.620889] usbcore: registered new interface driver asix [ 1.626352] usbcore: registered new interface driver ax88179_178a [ 1.632487] usbcore: registered new interface driver cdc_ether [ 1.638397] usbcore: registered new interface driver net1080 [ 1.644105] usbcore: registered new interface driver cdc_subset [ 1.650071] usbcore: registered new interface driver zaurus [ 1.655698] usbcore: registered new interface driver cdc_ncm [ 1.661571] VFIO - User Level meta-driver version: 0.3 [ 1.668810] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.675359] ehci-pci: EHCI PCI platform driver [ 1.679850] ehci-platform: EHCI generic platform driver [ 1.685292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.691484] ohci-pci: OHCI PCI platform driver [ 1.695974] ohci-platform: OHCI generic platform driver [ 1.701994] usbcore: registered new interface driver uas [ 1.707368] usbcore: registered new interface driver usb-storage [ 1.713466] usbcore: registered new interface driver usbserial_generic [ 1.720023] usbserial: USB Serial support registered for generic [ 1.726065] usbcore: registered new interface driver ftdi_sio [ 1.731842] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.739194] usbcore: registered new interface driver usb_serial_simple [ 1.745754] usbserial: USB Serial support registered for carelink [ 1.751874] usbserial: USB Serial support registered for zio [ 1.757563] usbserial: USB Serial support registered for funsoft [ 1.763599] usbserial: USB Serial support registered for flashloader [ 1.769982] usbserial: USB Serial support registered for google [ 1.775931] usbserial: USB Serial support registered for libtransistor [ 1.782486] usbserial: USB Serial support registered for vivopay [ 1.788520] usbserial: USB Serial support registered for moto_modem [ 1.794818] usbserial: USB Serial support registered for motorola_tetra [ 1.801459] usbserial: USB Serial support registered for novatel_gps [ 1.807840] usbserial: USB Serial support registered for hp4x [ 1.813614] usbserial: USB Serial support registered for suunto [ 1.819561] usbserial: USB Serial support registered for siemens_mpi [ 1.825956] usbcore: registered new interface driver usb_ehset_test [ 1.833937] imx_usb 32e40000.usb: No over current polarity defined [ 1.841676] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/soc@0:bus@30000000/30370000.snvs/30370000.snvs:snvs-powerkey/input0 [ 1.855502] usbcore: registered new interface driver xpad [ 1.860967] usbcore: registered new interface driver usb_acecad [ 1.866928] usbcore: registered new interface driver aiptek [ 1.872542] usbcore: registered new interface driver gtco [ 1.877983] usbcore: registered new interface driver hanwang [ 1.883683] usbcore: registered new interface driver kbtab [ 1.890944] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0 [ 1.897206] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:09:00 UTC (540) [ 1.906559] i2c /dev entries driver [ 1.910987] mx6s-csi 32e20000.csi1_bridge: initialising [ 1.916840] mxc_mipi-csi 32e30000.mipi_csi: 32e30000.mipi_csi supply mipi-phy not found, using dummy regulator [ 1.927081] mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered [ 1.934065] CSI: Registered sensor subdevice: mxc_mipi-csi.0 [ 1.939751] mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 333000000 [ 1.949735] uvcvideo: Unable to create debugfs directory [ 1.955112] usbcore: registered new interface driver uvcvideo [ 1.960868] USB Video Class driver (1.1.1) [ 1.965709] __power_supply_register: Expected proper parent device for 'battery' [ 1.973475] __power_supply_register: Expected proper parent device for 'usb' [ 1.983993] trusty-log not supported on secure side. [ 1.989151] trusty-virtio trusty:trusty-virtio: initializing [ 1.994864] trusty-virtio trusty:trusty-virtio: trusty_load_device_descr: virtio get descr returned (-1) [ 2.004363] trusty-virtio trusty:trusty-virtio: failed (-19) to load device descr [ 2.011859] trusty-virtio trusty:trusty-virtio: Failed to add virtio devices [ 2.019724] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0) [ 2.026428] device-mapper: uevent: version 1.0.3 [ 2.031304] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com [ 2.040036] Bluetooth: HCI UART driver ver 2.3 [ 2.044507] Bluetooth: HCI UART protocol H4 registered [ 2.049660] Bluetooth: HCI UART protocol BCSP registered [ 2.055010] Bluetooth: HCI UART protocol LL registered [ 2.060162] Bluetooth: HCI UART protocol ATH3K registered [ 2.065592] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.072046] Bluetooth: HCI UART protocol Broadcom registered [ 2.077736] Bluetooth: HCI UART protocol QCA registered [ 2.085274] sdhci: Secure Digital Host Controller Interface driver [ 2.091474] sdhci: Copyright(c) Pierre Ossman [ 2.096086] Synopsys Designware Multimedia Card Interface Driver [ 2.102753] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.141848] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA [ 2.152030] ledtrig-cpu: registered to indicate activity on CPUs [ 2.158653] hidraw: raw HID events driver (C) Jiri Kosina [ 2.166867] usbcore: registered new interface driver usbhid [ 2.172465] usbhid: USB HID core driver [ 2.178858] ashmem: initialized [ 2.186537] galcore: clk_get vg clock failed, disable vg! [ 2.192307] Galcore version 6.4.3.p0.286725 [ 2.254715] mmc2: new HS400 Enhanced strobe MMC card at address 0001 [ 2.266010] mmcblk2: mmc2:0001 DG4016 14.7 GiB [ 2.269456] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 0 [ 2.270770] mmcblk2boot0: mmc2:0001 DG4016 partition 1 4.00 MiB [ 2.279545] hantrodec 0 : module inserted. Major = 506 [ 2.284120] mmcblk2boot1: mmc2:0001 DG4016 partition 2 4.00 MiB [ 2.289644] hantrodec 1 : module inserted. Major = 506 [ 2.295740] mmcblk2rpmb: mmc2:0001 DG4016 partition 3 4.00 MiB, chardev (510:0) [ 2.301060] hx280enc: module inserted. Major <505> [ 2.314611] usbcore: registered new interface driver snd-usb-audio [ 2.325997] Alternate GPT is invalid, using primary GPT. [ 2.331400] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 [ 2.366912] fsl-micfil-dai 30080000.micfil: GET IRQ: 16 [ 2.372188] fsl-micfil-dai 30080000.micfil: GET IRQ: 17 [ 2.377435] fsl-micfil-dai 30080000.micfil: GET IRQ: 18 [ 2.382684] fsl-micfil-dai 30080000.micfil: GET IRQ: 19 [ 2.394361] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 30090000.spdif mapping ok [ 2.402022] imx-spdif sound-spdif: ASoC: no DMI vendor name! [ 2.411659] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30080000.micfil mapping ok [ 2.419541] imx-micfil sound-micfil: ASoC: no DMI vendor name! [ 2.427634] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 2.439345] drop_monitor: Initializing network drop monitor service [ 2.445717] NET: Registered protocol family 26 [ 2.450181] netem: version 1.3 [ 2.453253] u32 classifier [ 2.455963] input device check on [ 2.459635] Actions configured [ 2.463747] xt_time: kernel timezone is -0000 [ 2.468246] gre: GRE over IPv4 demultiplexor driver [ 2.473144] IPv4 over IPsec tunneling driver [ 2.478041] Initializing XFRM netlink socket [ 2.482353] IPsec XFRM device driver [ 2.486421] NET: Registered protocol family 10 [ 2.492174] Segment Routing with IPv6 [ 2.495962] mip6: Mobile IPv6 [ 2.499926] NET: Registered protocol family 17 [ 2.504412] NET: Registered protocol family 15 [ 2.509633] Bluetooth: RFCOMM TTY layer initialized [ 2.514539] Bluetooth: RFCOMM socket layer initialized [ 2.519701] Bluetooth: RFCOMM ver 1.11 [ 2.523464] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.528787] Bluetooth: BNEP filters: protocol multicast [ 2.534026] Bluetooth: BNEP socket layer initialized [ 2.539002] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.544955] Bluetooth: HIDP socket layer initialized [ 2.549962] l2tp_core: L2TP core driver, V2.0 [ 2.554338] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.559138] 8021q: 802.1Q VLAN Support v1.8 [ 2.563351] lib80211: common routines for IEEE802.11 drivers [ 2.569439] 9pnet: Installing 9P2000 support [ 2.573748] tsn generic netlink module v1 init... [ 2.579618] registered taskstats version 1 [ 2.583740] Loading compiled-in X.509 certificates [ 2.588679] Key type ._fscrypt registered [ 2.592701] Key type .fscrypt registered [ 2.596634] Key type fscrypt-provisioning registered [ 2.602547] pstore: Using crash dump compression: deflate [ 2.616152] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator [ 2.624994] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator [ 2.648013] ldo6: supplied by regulator-dummy [ 2.653204] i2c i2c-0: IMX I2C adapter registered [ 2.659308] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator [ 2.666731] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator [ 2.674071] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator [ 2.681409] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator [ 2.688832] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator [ 2.696168] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator [ 2.712098] random: fast init done [ 2.719232] i2c i2c-1: IMX I2C adapter registered [ 2.728782] ov5640_mipi 2-003c: No sensor reset pin available [ 2.734592] ov5640_mipi 2-003c: 2-003c supply DOVDD not found, using dummy regulator [ 2.742422] ov5640_mipi 2-003c: 2-003c supply DVDD not found, using dummy regulator [ 2.750108] ov5640_mipi 2-003c: 2-003c supply AVDD not found, using dummy regulator [ 2.768589] ov5640_mipi 2-003c: Read reg error: reg=300a [ 2.773921] ov5640_mipi 2-003c: Camera is not found [ 2.778955] i2c i2c-2: IMX I2C adapter registered [ 2.785520] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator [ 2.794962] imx6q-pcie 33800000.pcie: EXT REF_CLK is used!. [ 2.816643] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA [ 2.828364] imx6q-pcie 33800000.pcie: PCIe PLL locked after 20 us. [ 2.834615] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges: [ 2.841877] imx6q-pcie 33800000.pcie: IO 0x1ff80000..0x1ff8ffff -> 0x00000000 [ 2.849297] imx6q-pcie 33800000.pcie: MEM 0x18000000..0x1fefffff -> 0x18000000 [ 2.857356] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA [ 2.865658] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.872314] [drm] No driver support for vblank timestamp query. [ 2.878326] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops) [ 2.888290] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200 [ 2.897371] imx-drm soc@0:bus@32c00000:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops) [ 2.907279] mmc0: queuing unknown CIS tuple 0x01 (3 bytes) [ 2.912910] [drm] Initialized imx-drm 1.0.0 20120507 for soc@0:bus@32c00000:display-subsystem on minor 1 [ 2.933281] mmc0: queuing unknown CIS tuple 0x1a (5 bytes) [ 2.942554] mmc0: queuing unknown CIS tuple 0x1b (8 bytes) [ 2.948753] mmc0: queuing unknown CIS tuple 0x14 (0 bytes) [ 2.970499] mmc0: queuing unknown CIS tuple 0x80 (1 bytes) [ 2.976146] mmc0: queuing unknown CIS tuple 0x81 (1 bytes) [ 2.981704] mmc0: queuing unknown CIS tuple 0x82 (1 bytes) [ 2.987235] mmc0: new ultra high speed SDR104 SDIO card at address 0001 [ 3.435795] Console: switching to colour frame buffer device 240x67 [ 3.474131] imx-drm soc@0:bus@32c00000:display-subsystem: fb0: imx-drmdrmfb frame buffer device [ 3.483670] imx_usb 32e40000.usb: No over current polarity defined [ 3.489959] imx_usb 32e40000.usb: 32e40000.usb supply vbus not found, using dummy regulator [ 3.504001] bt power gpio is:38 [ 3.507291] mxc_bt_rfkill driver success loaded [ 3.512102] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 3 mkt segment 0 supported-hw 0x8 0x1 [ 3.521563] rfkill: BT RF going to : on [ 3.525439] mxc_bt_rfkill_reset [ 3.530810] Hot alarm is canceled. GPU3D clock will return to 64/64 [ 3.539029] asoc-simple-card sound-bt-sco: bt-sco-pcm <-> 30020000.sai mapping ok [ 3.546550] asoc-simple-card sound-bt-sco: ASoC: no DMI vendor name! [ 3.554928] asoc-simple-card sound-wm8524: wm8524-hifi <-> 30030000.sai mapping ok [ 3.562548] asoc-simple-card sound-wm8524: ASoC: no DMI vendor name! [ 3.577318] imx-ak4458 sound-ak4458: ASoC: failed to init link ak4458: -517 [ 3.584318] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-517) [ 3.593987] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@50/connector [ 3.602730] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@50/connector [ 3.860419] imx6q-pcie 33800000.pcie: Phy link never came up [ 3.945278] imx6q-pcie 33800000.pcie: failed to initialize host [ 3.951228] imx6q-pcie 33800000.pcie: unable to add pcie port. [ 3.956318] ak4458 2-0010: ASoC: failed to probe component -6 [ 3.962831] imx-ak4458 sound-ak4458: ASoC: failed to instantiate card -6 [ 3.969586] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-6) //Ruban [ 3.978566] input: bd718xx-pwrkey as /devices/platform/soc@0/soc@0:bus@30800000/30a20000.i2c/i2c-0/0-004b/gpio-keys.1.auto/input/input1 [ 3.991552] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.003322] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.010004] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 4.018347] ALSA device list: [ 4.018672] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db //Ruban [ 4.021627] #0: imx-spdif [ 4.032156] #1: imx-audio-micfil [ 4.035812] #2: bt-sco-audio [ 4.038875] #3: wm8524-audio [ 4.043808] Freeing unused kernel memory: 5312K [ 4.068602] Run /init as init process [ 4.101418] init: init first stage started! [ 4.105766] init: Unable to open /lib/modules, skipping module loading. [ 4.112703] init: Switching root to '/first_stage_ramdisk' [ 4.120558] init: Using Android DT directory /proc/device-tree/firmware/android/ [ 4.216912] init: bool android::init::BlockDevInitializer::InitDevices(std::set:string>): partition(s) not found in /sys, waiting for tb [ 4.317618] ci_hdrc ci_hdrc.0: EHCI Host Controller [ 4.322545] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1 [ 4.344288] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00 [ 4.349868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 4.358144] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.365371] usb usb1: Product: EHCI Host Controller [ 4.370271] usb usb1: Manufacturer: Linux 5.4.47 ehci_hcd [ 4.375674] usb usb1: SerialNumber: ci_hdrc.0 [ 4.381043] hub 1-0:1.0: USB hub found [ 4.384825] hub 1-0:1.0: 1 port detected [ 4.724934] usb 1-1: new full-speed USB device number 2 using ci_hdrc [ 4.899356] usb 1-1: New USB device found, idVendor=413c, idProduct=301b, bcdDevice=11.23 [ 4.907556] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.914703] usb 1-1: Product: Dell Universal Receiver [ 4.919764] usb 1-1: Manufacturer: Dell [ 4.928863] input: Dell Dell Universal Receiver as /devices/platform/soc@0/soc@0:bus@32c00000/32e40000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:42 [ 5.002473] hid-generic 0003:413C:301B.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell Dell Universal Receiver] on usb-ci_hdrc.0-1/input0 [ 5.020145] input: Dell Dell Universal Receiver Mouse as /devices/platform/soc@0/soc@0:bus@32c00000/32e40000.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/3 [ 5.036132] input: Dell Dell Universal Receiver Consumer Control as /devices/platform/soc@0/soc@0:bus@32c00000/32e40000.usb/ci_hdrc.0/usb1/14 [ 5.113407] input: Dell Dell Universal Receiver System Control as /devices/platform/soc@0/soc@0:bus@32c00000/32e40000.usb/ci_hdrc.0/usb1/1-15 [ 5.130670] hid-generic 0003:413C:301B.0002: input,hidraw1: USB HID v1.11 Mouse [Dell Dell Universal Receiver] on usb-ci_hdrc.0-1/input1 [ 5.148174] hid-generic 0003:413C:301B.0003: hiddev96,hidraw2: USB HID v1.11 Device [Dell Dell Universal Receiver] on usb-ci_hdrc.0-1/input2 [ 14.239841] init: Wait for partitions returned after 10005ms [ 14.245666] init: bool android::init::BlockDevInitializer::InitDevices(std::set:string>): partition(s) not found after polling timeout:b [ 14.262191] init: Failed to mount required partitions early ... [ 14.269358] init: InitFatalReboot: signal 6 [ 14.277395] init: #00 pc 00000000000afe30 /system/bin/init [ 14.283068] init: #01 pc 000000000004cd90 /system/bin/init [ 14.288671] init: #02 pc 0000000000013ab0 /system/lib64/libbase.so [ 14.295011] init: #03 pc 0000000000013090 /system/lib64/libbase.so [ 14.301297] init: #04 pc 0000000000075b1c /system/bin/init [ 14.306902] init: #05 pc 000000000002e0ec /system/bin/init [ 14.312542] kvm: exiting hardware virtualization [ 14.312875] imx-sdma 302b0000.dma-controller: external firmware not found, using ROM firmware [ 14.312929] cfg80211: failed to load regulatory.db [ 14.313004] imx-sdma 302c0000.dma-controller: external firmware not found, using ROM firmware [ 14.313071] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2 [ 14.313076] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin [ 19.269982] init: Reboot ending, jumping to kernel [ 35.880671] VSD_3V3: disabling [ 47.488649] random: crng init done :string>:string>:string>:string>
