IMX8M plus ddr stress test without UI
672件の閲覧回数
JeromeL
I have to make some DDR stress tests automaticaly so without UI on a board with a IMX8MPLUS
I found the following link with an explanation and binary files for others references :
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/mx8-ddr-stress-test-without-UI/ta-p/1414...
Does the same document exist for the iMX8M Plus ?
Jerome
648件の閲覧回数
JorgeCas
I checked internally and there are no available documents to run DDR stress test without UI on i.MX8M families.
According to the document you need the binaries and the init/start UART commands to achieve it but, there is no documentation about the exact commands.
Best regards.
