IMX6ULLevk basic image does not get response from keyboard when connected
omerg
I am trying to work on a basic image using CLI but for unknown reason, i stopped receiving keyboard inputs and cannot work with the board, I am using Putty and I'm connected on the uart debug mode and before and after the boot sequence any key press doesn't do anything, What can i do?
Hi Omer
one can try to test ddr memory :
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-6-7-DDR-Stress-Test-Tool/ta-p/11082...
and update uboot dcd header with new ddr calibration coefficients found from test
https://source.codeaurora.org/external/imx/uboot-imx/tree/board/freescale/mx6ullevk/imximage.cfg?h=i...
omerg
thanks ill try it
