IMX6ULL GPIO function
Saenghee
dear nxp
GPIO01_IO01 will connect BT_HOST_WAKE_INT
BT_HOST_WAKE pin will  wake up the AP(IMX6ULL) even if the AP sleep state.
Q1>  GPIO01_IO01 have interrupt function?
        GPIO01_IO01 support AP wakeup?
Q2> ENET2_RX_ER support UART RTS function ? (it will connect BT UART CTS)
        ENET2_TX_CLK support UART CTS function?(it will connect BT UART RTS)
        ENET2_TX_DATA1 support UART TXD function?(it will connect BT UART RXD)
        ENET2_TX_EN support UART RXD function? (it will connect BT UART TXD)
AldoG
A1 > Yes, it does
A2 >
Yes, ALT1 mux port: UART8_RTS_B
Yes, ALT1 mux port: UART8_CTS_B
Yes, ALT1 mux port: UART8_TX
Yes, ALT1 mux port: UART8_RX
Aldo.
Saenghee
thank you for your confirmation.
close.
AldoG
A1 > Yes, it does
A2 >
Aldo.
