IMX6UL NTFS-3G related
1,192 次查看
Nu-GG
hello.
I have completed a build with "ntfs-3g-ntfsprogs 2017.3.23" in a yocto 3.2 environment.
I can also check the installed packages.
However, there is no executable file, and I get an error when I run it with ntfs-3g in the mount option.
If anyone has experience with this, please help.
1,166 次查看
Harvey021
It seems telling from the log that the fs not available yet. You might try compile it manually as GitHub - tuxera/ntfs-3g: NTFS-3G Safe Read/Write NTFS Driver.
Harvey
1,120 次查看
Nu-GG
Thank you for your response.
I will try to find a way to build it.
