IMX287 with WiFi/BT Combo module interface error
1,900 次查看
sung-ukjang
Dear Freescale support.
My customer is using IMX28 device for phone module application.
we have some problem, customer IMX28system is usging WiFi/BT Combo module for phone uesr.
when the customer doing aging test Combo module driver mount and unmount.( about 30~35 times)
sometime, driver is don't  unmout or kernel panic.( please attached error log files )
Conbo module information.
Interface : SDIO ( voltage is 1.8v )
Partnumber : WM-BN-BM-04 ( USI company )
Module chipset :  BCM4330.
Driver name : dhd.ko ( attached file )
Can you help debugging point for my customer ??
Original Attachment has been moved to: dhd.ko.zip
Original Attachment has been moved to: apsi_kernel_log_5.log.zip
Original Attachment has been moved to: apsi_kernel_log_4.log.zip
Original Attachment has been moved to: apsi_kernel_log_3.log.zip
Original Attachment has been moved to: apsi_kernel_log_2.log.zip
Original Attachment has been moved to: apsi_kernel_log_1.log.zip
Original Attachment has been moved to: apsi_kernel_log_6.log.zip
标签 (2)
1,598 次查看
sung-ukjang
Please update my request..
