I need to communicate quectel module using usb protocol rt1170 for sending receiving AT commands
745 次查看
Bharath_S
I need to communicate quectel module using usb protocol using rt1170 arm processor for sending receiving AT commands response, so for this i gone through the usb example but i couldn't able to understand what are parameters i need to change for this if any one knows what are thigs i need to know before starting modifications
725 次查看
Pavel_Hernandez
Hello, could you share the datasheet of the Quectel or the pinout, maybe you need to use Uart to send the AT command through RX & TX, if that is the right protocol, you can use the example from the SDK.
Best regards,
Pavel
