I'm not able to use Second SD port, when flashing MMC using imx28_ivt_linux.sb
1,837 次查看
swaraj
When kernel is loaded with imx28_ivt_linux.sb and mk_mx28_sd, i am able to login directly without U-Boot prompt but i'm not able to use SD1 (2nd SD slot).
Can anyone help me..
1,589 次查看
Matt_ng9
Try this command line...
noinitrd console=ttyAM0,115200 root=/dev/mmcblk0p3 rw rootwait ip=none ssp1
Got this from page 5-24 of i.MX28_Linux_BSP_UG.pdf
1,589 次查看
swaraj
My command line is:
Kernel command line: noinitrd console=ttyAM0,115200 root=/dev/mmcblk0p3 rw rootwait ip=none gpmi
this is by default set in (2.6.35.3 kernel )
Other thing what i noticed is that NAND and SD1 will be sharing pins, So how should i configure them by disabling NAND pins...
Sinan Emre Kutlu said:
I think it depends on your kernel command line
1,589 次查看
snan1z
