I.MX8QXP Android P auto camera HAL3
27,049件の閲覧回数
xu_ji1
Dears,
If I want to used enable /imx/libcamera3 camera HAL3 code in OS,and used Max9286 to connect camera,
how to I change the source code?
I think now get video devices flow not proper for MAX9286 chip,log as below:
03-23 07:59:28.499 1047 1726 1726 W FslCameraHAL: getNodeName dev path:/dev/video12 is not capture
03-23 07:59:28.501 1047 1726 1726 I FslCameraHAL: matchPropertyName: index:0, max9286_mipi
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: index:0, propName:max9286_mipi
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: matchNodeName
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:0
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: matchPropertyName: index:1, uvc,adv7180_decoder
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: index:1, propName:uvc
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:uvc, index:1
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: index:1, propName:adv7180_decoder
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:adv7180_decoder, index:1
03-23 07:59:28.502 1047 1726 1726 I FslCameraHAL: camera number is 0
Please support,thanks
25,290件の閲覧回数
xu_ji1
Dears,
I resolved in my side,close this QA.
21 返答(返信)
25,132件の閲覧回数
Rita_Wang
Which version BSP are you using?
25,132件の閲覧回数
xu_ji1
Hello, Rita,
I used mek_8q_car-eng 9 1.0.2-auto-beta-rc3 20190114 this version.
25,132件の閲覧回数
Rita_Wang
OK. I will confirm it for you and then give you reply.
25,291件の閲覧回数
xu_ji1
Dears,
25,132件の閲覧回数
jack-cap
HI Xu Ji
How did you fix it,I porting max9286 to IMX8MQ,it also can not open camera,the detect sensor number  is 0.
Should I modify the hal code ?
25,132件の閲覧回数
xu_ji1
hi,yan
Pls share your dmesg and logcat full log for tracing same issue with me or not.
25,132件の閲覧回数
jack-cap
Hi Xu Ji
My kernel log as below :
U-Boot SPL 2018.03 (Oct 25 2019 - 17:36:54 +0800)
PMIC: PFUZE100 ID=0x10
DDRINFO: start lpddr4 ddr init
DRAM PHY training for 3200MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC1
U-Boot 2018.03 (Oct 25 2019 - 17:36:54 +0800)
CPU: Freescale i.MX8MQ rev2.1 1300 MHz (running at 800 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 54C
Reset cause: POR
Model: Freescale i.MX8MQ EVK
DRAM: 3 GiB
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C0 0x50]
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
No panel detected: default to HDMI
Display: HDMI (1280x720)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
flash target is MMC:0
Net:
Error: ethernet@30be0000 address not set.
No ethernet found.
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
verify OK, boot 'boot_a'
Kernel load addr 0x40480000 size 30901 KiB
kernel @ 40480000 (31642112)
ramdisk @ 43600000 (7425791)
fdt @ 43400000 (45831)
## Flattened Device Tree blob at 43400000
Booting using the fdt blob at 0x43400000
Using Device Tree in place at 0000000043400000, end 000000004340e306
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.98-00001-gde6b135-dirty (neo@neo-PowerEdge-R420) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #13 SMP PREEMPT Fri Oct 25 17:38:31 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Freescale i.MX8MQ EVK
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: ION carveout pool at 0x00000000f8000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node imx_ion@0, compatible id imx-ion-pool
[ 0.000000] cma: Reserved 1280 MiB at 0x00000000a8000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xa7fba500-0xa7fbc2ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000097ffffff]
[ 0.000000] node 0: [mem 0x0000000098100000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu @ffff800067f50000 s64536 r8192 d29672 u102400
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 773888
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200 init=/init androidboot.gui_resolution=1080p androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.fbTileSupport=enable cma=1280M androidboot.primary_display=imx-drm firmware_class.path=/vendor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.wifivendor=bcm buildvariant=userdebug androidboot.serialno=152059d6f32ef628 androidboot.btmacaddr=15:20:59:d6:f3:2e androidboot.soc_type=imx8mq androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:4930,KL:0,KD:0,AVB:2259,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 97e19bdf0e87b7ad0008569a7e51b4429e65a53b 882f354b1ef5d8d2a81882f121787388fa565132 10 restart_on_corruption ignore_ze
[ 0.000000] device-mapper: init: will configure 1 devices
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1621520K/3144704K available (15868K kernel code, 2420K rwdata, 7044K rodata, 5504K init, 523K bss, 212464K reserved, 1310720K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000009000000 ( 15872 KB)
[ 0.000000] .rodata : 0xffff000009000000 - 0xffff0000096f0000 ( 7104 KB)
[ 0.000000] .init : 0xffff0000096f0000 - 0xffff000009c50000 ( 5504 KB)
[ 0.000000] .data : 0xffff000009c50000 - 0xffff000009ead200 ( 2421 KB)
[ 0.000000] .bss : 0xffff000009ead200 - 0xffff000009f30080 ( 524 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0003000000 ( 48 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff8000c0000000 ( 3072 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MQ clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.008872] system counter timer init
[ 0.011731] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.019710] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.031074] Console: colour dummy device 80x25
[ 0.034493] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044749] pid_max: default: 32768 minimum: 301
[ 0.049445] Security Framework initialized
[ 0.053469] SELinux: Initializing.
[ 0.058524] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.064944] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.071300] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.077995] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.101209] ASID allocator initialised with 32768 entries
[ 0.109209] Hierarchical SRCU implementation.
[ 0.117788] Cannot find MU entry in device tree
[ 0.119617] CPU identified as i.MX8MQ, silicon rev 2.1
[ 0.125577] EFI services will not be available.
[ 0.137190] smp: Bringing up secondary CPUs ...
[ 0.165378] Detected VIPT I-cache on CPU1
[ 0.165408] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.165437] CPU1: Booted secondary processor [410fd034]
[ 0.193441] Detected VIPT I-cache on CPU2
[ 0.193462] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.193483] CPU2: Booted secondary processor [410fd034]
[ 0.221532] Detected VIPT I-cache on CPU3
[ 0.221553] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.221573] CPU3: Booted secondary processor [410fd034]
[ 0.221802] smp: Brought up 1 node, 4 CPUs
[ 0.271461] SMP: Total of 4 processors activated.
[ 0.276162] CPU features: detected feature: GIC system register CPU interface
[ 0.283323] CPU features: detected feature: 32-bit EL0 Support
[ 0.289154] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.328434] CPU: All CPU(s) started at EL2
[ 0.329851] alternatives: patching kernel code
[ 0.334510] CPU3: update max cpu_capacity 1024
[ 0.339702] devtmpfs: initialized
[ 0.341634] CPU1: update max cpu_capacity 1024
[ 0.352933] Registered cp15_barrier emulation handler
[ 0.355206] Registered setend emulation handler
[ 0.360285] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369492] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.415844] pinctrl core: initialized pinctrl subsystem
[ 0.419791] DMI not present or invalid.
[ 0.422610] NET: Registered protocol family 16
[ 0.428769] schedtune: configured to support 5 boost groups
[ 0.435193] cpuidle: using governor menu
[ 0.438819] vdso: 2 pages (1 code @ ffff000009007000, 1 data @ ffff000009c54000)
[ 0.443698] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.457983] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.463163] Serial: AMBA PL011 UART driver
[ 0.466036] imx rpmsg driver is registered.
[ 0.480313] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.498063] MU is ready for cross core communication!
[ 0.502232] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.546879] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.565081] ACPI: Interpreter disabled.
[ 0.570355] vgaarb: loaded
[ 0.571373] SCSI subsystem initialized
[ 0.575424] usbcore: registered new interface driver usbfs
[ 0.579646] usbcore: registered new interface driver hub
[ 0.585176] usbcore: registered new device driver usb
[ 0.591170] i2c i2c-0: IMX I2C adapter registered
[ 0.594557] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.600547] i2c i2c-1: IMX I2C adapter registered
[ 0.604581] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.610761] i2c i2c-2: IMX I2C adapter registered
[ 0.614669] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.621603] media: Linux media interface: v0.10
[ 0.624611] Linux video capture interface: v2.00
[ 0.629271] pps_core: LinuxPPS API ver. 1 registered
[ 0.634107] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.643282] PTP clock support registered
[ 0.647715] EDAC MC: Ver: 3.0.0
[ 0.650823] dmi: Firmware registration failed.
[ 0.655577] Advanced Linux Sound Architecture Driver Initialized.
[ 0.661589] Bluetooth: Core ver 2.22
[ 0.664478] NET: Registered protocol family 31
[ 0.668842] Bluetooth: HCI device and connection manager initialized
[ 0.675269] Bluetooth: HCI socket layer initialized
[ 0.680095] Bluetooth: L2CAP socket layer initialized
[ 0.685169] Bluetooth: SCO socket layer initialized
[ 0.693581] clocksource: Switched to clocksource arch_sys_counter
[ 0.760456] VFS: Disk quotas dquot_6.6.0
[ 0.761606] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.768685] pnp: PnP ACPI: disabled
[ 0.780651] NET: Registered protocol family 2
[ 0.782849] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.789908] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.796752] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.802756] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.808717] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.815337] NET: Registered protocol family 1
[ 0.822592] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.828170] kvm [1]: 8-bit VMID
[ 0.831995] kvm [1]: GICv3: no GICV resource entry
[ 0.835447] kvm [1]: disabling GICv2 emulation
[ 0.840065] kvm [1]: GIC system register CPU interface enabled
[ 0.846123] kvm [1]: vgic interrupt IRQ1
[ 0.850179] kvm [1]: Hyp mode initialized successfully
[ 0.862825] audit: initializing netlink subsys (disabled)
[ 0.865661] audit: type=2000 audit(0.723:1): state=initialized audit_enabled=0 res=1
[ 0.866604] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.891819] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.895120] Registering sdcardfs 0.1
[ 0.898825] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.905229] fuse init (API version 7.26)
[ 0.908967] 9p: Installing v9fs 9p2000 file system support
[ 0.926502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.931079] io scheduler noop registered
[ 0.935177] io scheduler cfq registered (default)
[ 0.939707] io scheduler mq-deadline registered
[ 0.944238] io scheduler kyber registered
[ 0.972642] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 0.979102] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 0.988269] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.004889] mxs-dma 33000000.dma-apbh: initialized
[ 1.010629] Bus freq driver module loaded
[ 1.014253] Config NOC for GPU to 0x80000600
[ 1.016057] Config NOC for VPU and CPU
[ 1.024947] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.028886] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.033532] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.052857] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.060909] SuperH (H)SCI(F) driver initialized
[ 1.063626] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 44, base_baud = 1562500) is a IMX
[ 1.074309] console [ttymxc0] enabled
[ 1.078839] bootconsole [ec_imx6q0] disabled
[ 1.088802] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 45, base_baud = 5000000) is a IMX
[ 1.100795] msm_serial: driver initialized
[ 1.125562] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.132266] [drm] No driver support for vblank timestamp query.
[ 1.138365] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 1.146101] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 1.154647] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
[ 1.161467] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
[ 1.171402] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
[ 1.182262] [drm] VCO frequency is 5940000
[ 1.186377] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
[ 1.218076] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.225340] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 1.231578] [drm] Failed to initialize HDCP
[ 1.237408] [drm] hdmi-audio-codec driver bound to HDMI
[ 1.242671] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[ 1.250197] [drm] Cannot find any crtc or sizes
[ 1.255377] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.277547] brd: module loaded
[ 1.288760] loop: module loaded
[ 1.292962] zram: Added device: zram0
[ 1.305239] fsl-quadspi 30bb0000.qspi: unrecognized JEDEC id bytes: 00, 00, 00
[ 1.312502] fsl-quadspi 30bb0000.qspi: Freescale QuadSPI probe failed
[ 1.319067] fsl-quadspi: probe of 30bb0000.qspi failed with error -2
[ 1.325906] slram: not enough parameters.
[ 1.336212] libphy: Fixed MDIO Bus: probed
[ 1.342284] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.348881] tun: Universal TUN/TAP device driver, 1.6
[ 1.354429] CAN device driver interface
[ 1.361312] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 1.370981] pps pps0: new PPS source ptp0
[ 1.379867] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 1.389906] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: c2:f1:db:da:05:9c
[ 1.402156] libphy: fec_enet_mii_bus: probed
[ 1.408039] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.415101] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.420954] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.427004] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.434041] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.439728] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.447633] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.454342] sky2: driver version 1.30
[ 1.458794] PPP generic driver version 2.4.2
[ 1.463369] PPP BSD Compression module registered
[ 1.468093] PPP Deflate Compression module registered
[ 1.473186] PPP MPPE Compression module registered
[ 1.478105] usbcore: registered new interface driver asix
[ 1.483716] usbcore: registered new interface driver ax88179_178a
[ 1.489925] usbcore: registered new interface driver cdc_ether
[ 1.495933] usbcore: registered new interface driver net1080
[ 1.501706] usbcore: registered new interface driver cdc_subset
[ 1.507796] usbcore: registered new interface driver zaurus
[ 1.513491] usbcore: registered new interface driver cdc_ncm
[ 1.530798] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.537355] ehci-pci: EHCI PCI platform driver
[ 1.542037] ehci-platform: EHCI generic platform driver
[ 1.547602] ehci-orion: EHCI orion driver
[ 1.551959] ehci-exynos: EHCI EXYNOS driver
[ 1.556434] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 1.562334] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.568548] ohci-pci: OHCI PCI platform driver
[ 1.573230] ohci-platform: OHCI generic platform driver
[ 1.578767] ohci-exynos: OHCI EXYNOS driver
[ 1.583849] Can't support > 32 bit dma.
[ 1.587750] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.593332] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.608214] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000001010810
[ 1.617744] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x38200000
[ 1.623960] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.630829] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.638071] usb usb1: Product: xHCI Host Controller
[ 1.643027] usb usb1: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 1.650356] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.656315] hub 1-0:1.0: USB hub found
[ 1.660125] hub 1-0:1.0: 1 port detected
[ 1.664603] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.670124] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.677870] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.684688] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.691559] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.698800] usb usb2: Product: xHCI Host Controller
[ 1.703757] usb usb2: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 1.711085] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.716707] hub 2-0:1.0: USB hub found
[ 1.720507] hub 2-0:1.0: 1 port detected
[ 1.725848] usbcore: registered new interface driver usb-storage
[ 1.732056] usbcore: registered new interface driver usb_ehset_test
[ 1.743634] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.755886] usbcore: registered new interface driver xpad
[ 1.761466] usbcore: registered new interface driver usb_acecad
[ 1.767748] usbcore: registered new interface driver aiptek
[ 1.773503] usbcore: registered new interface driver gtco
[ 1.779136] usbcore: registered new interface driver hanwang
[ 1.784975] usbcore: registered new interface driver kbtab
[ 1.794759] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 1.805349] i2c /dev entries driver
[ 1.817235] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 1.823520] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 1.829484] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at /mipi_csi1@30a70000/port/endpoint1 XXX found
[ 1.839577] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 1.847682] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 1.853945] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 1.859726] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at /mipi_csi2@30b60000/port/endpoint1 XXX found
[ 1.869755] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 1, name: mxc-mipi-csi2.1
[ 1.878133] max9286_probe: YYJ ADD 1 @@              --------9286 probe
[ 1.882195] max9286_read_reg: YYJ ADD 41 @@ reg value=1e
[ 1.888679] max9286_hardware_preinit: YYJ ADD 2 @@
[ 1.893665] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 1.900092] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 1.925605] max9286_write_reg: YYJ ADD 42 @@ reg value=3f
[ 1.941602] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 1.957601] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 1.973600] max9271_write_reg: YYJ ADD 40 @@ reg value=40
[ 1.989600] max9271_write_reg: YYJ ADD 40 @@ reg value=8
[ 1.995820] max9271_write_reg: YYJ ADD 40 @@ reg value=97
[ 2.013600] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.033601] max9286_write_reg: YYJ ADD 42 @@ reg value=12
[ 2.039908] max9286_write_reg: YYJ ADD 42 @@ reg value=1
[ 2.046132] max9286_write_reg: YYJ ADD 42 @@ reg value=63
[ 2.052439] max9286_write_reg: YYJ ADD 42 @@ reg value=64
[ 2.058749] max9286_write_reg: YYJ ADD 42 @@ reg value=8
[ 2.064971] max9286_write_reg: YYJ ADD 42 @@ reg value=c
[ 2.071193] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 2.281678] [drm] Cannot find any crtc or sizes
[ 2.286389] max9286_read_reg: YYJ ADD 41 @@ reg value=49
[ 2.292748] max9286_data->sensor_num=80
[ 2.292753] max9286_mipi: reg = 0x80.
[ 2.300341] max9286_mipi: sensor number = 1.    ---sensor detect
[ 2.304688] YYJ v4l2_i2c_subdev_init sd->name =max9286_mipi 1-006a
[ 2.311058] YYJ add --->media_entity_pads_init entity->num_pads=4
[ 2.317312] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: max9286_mipi 1-006a
[ 2.326202] YYJ ADD max9286_probe retval=0
[ 2.330464] max9286_mipi 1-006a: YYJ ADD 4 In max9286_hardware_init()
[ 2.337098] max9286_mipi 1-006a: In max9286_hardware_init()
[ 2.342687] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 2.348906] max9286_camera_reorder: YYJ ADD 3 @@
[ 2.353718] max9286_write_reg: YYJ ADD 42 @@ reg value=b
[ 2.359936] max9286_write_reg: YYJ ADD 42 @@ reg value=69
[ 2.366245] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 2.397602] max9271_write_reg: YYJ ADD 40 @@ reg value=7
[ 2.429602] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 2.435822] max9271_write_reg: YYJ ADD 40 @@ reg value=0
[ 2.457601] max9271_write_reg: YYJ ADD 40 @@ reg value=20
[ 2.463908] max9271_write_reg: YYJ ADD 40 @@ reg value=21
[ 2.470219] max9271_write_reg: YYJ ADD 40 @@ reg value=22
[ 2.476528] max9271_write_reg: YYJ ADD 40 @@ reg value=23
[ 2.482837] max9271_write_reg: YYJ ADD 40 @@ reg value=24
[ 2.489146] max9271_write_reg: YYJ ADD 40 @@ reg value=25
[ 2.495455] max9271_write_reg: YYJ ADD 40 @@ reg value=26
[ 2.501767] max9271_write_reg: YYJ ADD 40 @@ reg value=27
[ 2.508076] max9271_write_reg: YYJ ADD 40 @@ reg value=30
[ 2.514385] max9271_write_reg: YYJ ADD 40 @@ reg value=31
[ 2.520696] max9271_write_reg: YYJ ADD 40 @@ reg value=32
[ 2.527005] max9271_write_reg: YYJ ADD 40 @@ reg value=33
[ 2.533314] max9271_write_reg: YYJ ADD 40 @@ reg value=34
[ 2.539622] max9271_write_reg: YYJ ADD 40 @@ reg value=35
[ 2.545932] max9271_write_reg: YYJ ADD 40 @@ reg value=36
[ 2.552239] max9271_write_reg: YYJ ADD 40 @@ reg value=37
[ 2.558547] max9271_write_reg: YYJ ADD 40 @@ reg value=3f
[ 2.564855] max9271_write_reg: YYJ ADD 40 @@ reg value=47
[ 2.571164] max9271_write_reg: YYJ ADD 40 @@ reg value=48
[ 2.577472] max9271_write_reg: YYJ ADD 40 @@ reg value=49
[ 2.583779] max9271_write_reg: YYJ ADD 40 @@ reg value=4c
[ 2.590090] max9271_write_reg: YYJ ADD 40 @@ reg value=43
[ 2.596399] max9271_write_reg: YYJ ADD 40 @@ reg value=1
[ 2.602620] max9271_write_reg: YYJ ADD 40 @@ reg value=9
[ 2.608841] max9271_write_reg: YYJ ADD 40 @@ reg value=a
[ 2.615082] max9271_write_reg: YYJ ADD 40 @@ reg value=b
[ 2.621325] max9271_write_reg: YYJ ADD 40 @@ reg value=c
[ 2.637600] max9286_mipi: initialized sensor = 0x04.
[ 2.642670] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 2.648912] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 2.655156] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 2.661485] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 2.667677] random: fast init done
[ 2.672263] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 3.689752] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 3.713669] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 3.720504] max9286_mipi 1-006a: max9286_mipi is found, name max9286_mipi 1-006a
[ 3.735508] usbcore: registered new interface driver uvcvideo
[ 3.741347] USB Video Class driver (1.1.1)
[ 3.748846] __power_supply_register: Expected proper parent device for 'battery'
[ 3.757399] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 3.770276] __power_supply_register: Expected proper parent device for 'usb'
[ 3.793161] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 3.803264] device-mapper: uevent: version 1.0.3
[ 3.809239] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[ 3.819061] Bluetooth: HCI UART driver ver 2.3
[ 3.823699] Bluetooth: HCI UART protocol H4 registered
[ 3.828921] Bluetooth: HCI UART protocol BCSP registered
[ 3.834374] Bluetooth: HCI UART protocol ATH3K registered
[ 3.839858] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.846940] Bluetooth: HCI UART protocol Broadcom registered
[ 3.852714] Bluetooth: HCI UART protocol QCA registered
[ 3.859245] bt power gpio is:69
[ 3.863083] rfkill: BT RF going to : on
[ 3.865675] mxc_bt_rfkill driver success loaded
my device directory modify as below:
diff --git a/imx8m/evk_8mq/init.rc b/imx8m/evk_8mq/init.rc
index 6335f09..618fc0a 100644
--- a/imx8m/evk_8mq/init.rc
+++ b/imx8m/evk_8mq/init.rc
@@ -65,9 +65,11 @@ on early-boot
#For portrait mode, orient is 90
#the android before honycomb are all in portrait mode
setprop camera.disable_zsl_mode 1
- setprop back_camera_name mx6s-csi
+ #setprop back_camera_name mx6s-csi
+ setprop back_camera_name max9286_mipi
setprop back_camera_orient 0
- setprop front_camera_name uvc
+ #setprop front_camera_name uvc
+ setprop front_camera_name max9286_mipi
setprop front_camera_orient 0
Is there need any modify?  I used system camera APP open camera,it shows camera number is 0 .
BRs
thanks
25,132件の閲覧回数
xu_ji1
hi,yingjin
pls share kernel and user log when your camera open,power on log seems ok
25,132件の閲覧回数
jack-cap
MY device directory change as below:
I have a question that  why I connect one sensor with max9286,  the dev directory did not register new video node
the user log as below:
[ 8.660723] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 8.660723]
[ 8.666779] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 8.666779]
[ 8.674162] e2fsck: Pass 2: Checking directory structure
[ 8.674162]
[ 8.681024] e2fsck: Pass 3: Checking directory connectivity
[ 8.681024]
[ 8.688143] e2fsck: Pass 4: Checking reference counts
[ 8.688143]
[ 8.694804] e2fsck: Pass 5: Checking group summary information
[ 8.694804]
[ 8.702129] e2fsck:
[ 8.702129]
[ 8.705806] e2fsck: /dev/block/by-name/userdata: ***** FILE SYSTEM WAS MODIFIED *****
[ 8.705806]
[ 8.715126] e2fsck: /dev/block/by-name/userdata: 1529/581632 files (2.4% non-contiguous), 73849/2326528 blocks
[ 8.715126]
[ 8.732578] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 8.746692] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 8.787073] zram0: detected capacity change from 0 to 314572800
[ 8.815626] logd.auditd: start
[ 8.818722] logd.klogd: 8683884206
[ 8.819125] mkswap: Swapspace size: 307196k, UUID=352e7850-43aa-4635-bdc6-c79d0b69741f
[ 8.830656] Adding 307196k swap on /dev/block/zram0. Priority:-2 extents:1 across:307196k SS
[ 8.856789] type=1400 audit(1572328418.715:38): avc: denied { getattr } for pid=2346 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.877727] type=1400 audit(1572328418.715:38): avc: denied { getattr } for pid=2346 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.898301] type=1400 audit(1572328418.715:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 9.234482] update_verifier: Started with arg 1: nonencrypted
[ 9.245534] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 9.252067] update_verifier: Leaving update_verifier.
[ 9.310216] logd.daemon: reinit
[ 9.327731] rfkill: BT RF going to : off
[ 9.342514] Mass Storage Function, version: 2009/09/11
[ 9.347943] LUN: removable file: (no medium)
[ 9.358715] using random self ethernet address
[ 9.363193] using random host ethernet address
[ 9.369457] file system registered
[ 9.515647] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 9.616302] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
evk_8mq:/ $ [ 10.252047] read descriptors
[ 10.281124] read strings
[ 10.992718] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 11.022996] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 11.053301] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 11.432316] android_work: sent uevent USB_STATE=CONNECTED
[ 11.459184] configfs-gadget gadget: high-speed config #1: b
[ 11.468457] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.475701] init: Received control message 'start' for 'bootanim' from pid: 2985 (/system/bin/surfaceflinger)
[ 11.486797] init: starting service 'bootanim'...
[ 11.854639] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[ 11.965607] random: crng init done
[ 12.197052] init: Service 'early_init_sh' (pid 2349) exited with status 0
[ 13.756628] type=1400 audit(1572328421.367:576): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 13.773467] audit_log_lost: 30 callbacks suppressed
[ 13.773472] audit: audit_lost=522 audit_rate_limit=5 audit_backlog_limit=64
[ 13.776326] type=1400 audit(1572328423.631:577): avc: denied { dac_read_search } for pid=2995 comm="Binder:2995_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
[ 13.781045] audit: rate limit exceeded
[ 14.108449] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 14.118186] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 14.152572] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 14.292961] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
[ 14.842898] read descriptors
[ 14.845988] read strings
[ 14.849769] read descriptors
[ 14.854341] read strings
[ 14.873611] acc_open
[ 14.875848] acc_release
[ 15.029314] fec 30be0000.ethernet eth0: Unable to connect to phy
[ 15.133031] type=1400 audit(1572328423.639:582): avc: denied { dac_read_search } for pid=2995 comm="Binder:2995_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 15.155114] type=1400 audit(1572328425.007:2353): avc: denied { dac_read_search } for pid=3240 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.229172] type=1400 audit(1572328425.007:2356): avc: denied { dac_read_search } for pid=3240 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 15.234996] audit: audit_lost=2292 audit_rate_limit=5 audit_backlog_limit=64
[ 15.253317] type=1400 audit(1572328425.099:2357): avc: denied { dac_read_search } for pid=3260 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.259705] sdcardfs version 2.0
[ 15.277861] audit: rate limit exceeded
[ 15.286881] sdcardfs: dev_name -> /data/media
[ 15.291550] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[ 15.302324] sdcardfs: mnt -> ffff80005fb39a60
[ 15.307769] sdcardfs: mounted on top of /data/media type ext4
[ 15.314117] Remount options were mask=23,gid=9997 for vfsmnt ffff80005ff10c60.
[ 15.321941] sdcardfs : options - debug:1
[ 15.326091] sdcardfs : options - gid:9997
[ 15.330175] sdcardfs : options - mask:23
[ 15.334354] Remount options were mask=7,gid=9997 for vfsmnt ffff80005ff118a0.
[ 15.341883] sdcardfs : options - debug:1
[ 15.346058] sdcardfs : options - gid:9997
[ 15.350133] sdcardfs : options - mask:7
[ 16.165251] type=1400 audit(1572328425.099:2357): avc: denied { dac_read_search } for pid=3260 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 16.183261] type=1400 audit(1572328426.039:2381): avc: denied { dac_read_search } for pid=3494 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 16.578967] type=1400 audit(1572328426.039:2384): avc: denied { dac_read_search } for pid=3494 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 16.600399] type=1400 audit(1572328426.451:2385): avc: denied { read } for pid=3123 comm="system_server" name="state" dev="sysfs" ino=21297 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 16.613972] audit: audit_lost=2315 audit_rate_limit=5 audit_backlog_limit=64
[ 16.631260] audit: rate limit exceeded
[ 18.458941] init: Service 'bootanim' (pid 3098) exited with status 0
[ 18.504655] init: processing action (sys.boot_completed=1) from (/init.rc:719)
[ 18.512331] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:20)
[ 18.525055] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:27)
[ 18.529193] type=1400 audit(1572328426.451:2385): avc: denied { read } for pid=3123 comm="system_server" name="state" dev="sysfs" ino=21297 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 18.542400] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
[ 18.556648] type=1400 audit(1572328428.403:2390): avc: denied { dac_read_search } for pid=2884 comm="Binder:2884_3" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 18.571171] init: starting service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[ 18.599068] audit: audit_lost=2319 audit_rate_limit=5 audit_backlog_limit=64
[ 18.605710] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 18.607154] audit: rate limit exceeded
[ 18.697223] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 72ms and succeeded
[ 18.740522] init: Service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)' (pid 3630) exited with status 0
[ 18.743452] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[ 18.743452]
[ 19.790452] audit: audit_lost=3554 audit_rate_limit=5 audit_backlog_limit=64
[ 19.798398] audit: rate limit exceeded
[ 25.516159] type=1400 audit(1572328429.663:3634): avc: denied { dac_read_search } for pid=3749 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.535662] type=1400 audit(1572328435.391:3646): avc: denied { dac_read_search } for pid=3818 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.535978] audit: audit_lost=3565 audit_rate_limit=5 audit_backlog_limit=64
[ 25.555147] type=1400 audit(1572328435.411:3649): avc: denied { dac_read_search } for pid=3818 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 25.560412] audit: rate limit exceeded
[ 25.580556] type=1400 audit(1572328435.411:3650): avc: denied { dac_read_search } for pid=3825 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 26.600108] type=1400 audit(1572328435.411:3650): avc: denied { dac_read_search } for pid=3825 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 26.618576] type=1400 audit(1572328436.475:3682): avc: denied { dac_read_search } for pid=3997 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 69.516105] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 69.617433] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 69.625618] type=1400 audit(1572328436.475:3685): avc: denied { dac_read_search } for pid=3997 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 69.646300] type=1400 audit(1572328479.503:3686): avc: denied { read } for pid=2979 comm="[email protected]" name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 129.516024] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 129.616825] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 189.516015] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 189.616823] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 249.515962] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 249.616813] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 309.515963] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 309.616815] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
U-Boot SPL 2018.03 (Oct 29 2019 - 11:48:53 +0800)
Training PASS
Training PASS
Training PASS
Training PASS
Normal Boot
U-Boot 2018.03 (Oct 29 2019 - 11:48:53 +0800)
CPU: Industrial temperature grade (-40C to 105C) at 70C
Reset cause: POR
DRAM: 3 GiB
Failed (-5)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
Net: No ethernet found.
Fastboot: Normal
Normal Boot
Starting kernel ...
[ 0.000000] Linux version 4.14.98-00001-gde6b135-dirty (neolix@neolix-PowerEdge-R420) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #15 SMP PREEMPT Tue Oct 29 11:50:29 CST 2019
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200 init=/init androidboot.gui_resolution=1080p androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.fbTileSupport=enable cma=1280M androidboot.primary_display=imx-drm firmware_class.path=/vendor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.wifivendor=bcm buildvariant=userdebug androidboot.serialno=152059d6f32ef628 androidboot.btmacaddr=15:20:59:d6:f3:2e androidboot.soc_type=imx8mq androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:4829,KL:0,KD:0,AVB:2258,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_ze
[ 0.000005] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.031073] Console: colour dummy device 80x25
[ 0.034492] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044750] pid_max: default: 32768 minimum: 301
[ 0.049447] Security Framework initialized
[ 0.058523] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.077994] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.101210] ASID allocator initialised with 32768 entries
[ 0.109210] Hierarchical SRCU implementation.
[ 0.117789] Cannot find MU entry in device tree
[ 0.137191] smp: Bringing up secondary CPUs ...
[ 0.165379] Detected VIPT I-cache on CPU1
[ 0.165409] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.165438] CPU1: Booted secondary processor [410fd034]
[ 0.193444] Detected VIPT I-cache on CPU2
[ 0.193465] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.193485] CPU2: Booted secondary processor [410fd034]
[ 0.221534] Detected VIPT I-cache on CPU3
[ 0.221555] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.221576] CPU3: Booted secondary processor [410fd034]
[ 0.221804] smp: Brought up 1 node, 4 CPUs
[ 0.271462] SMP: Total of 4 processors activated.
[ 0.276164] CPU features: detected feature: GIC system register CPU interface
[ 0.283325] CPU features: detected feature: 32-bit EL0 Support
[ 0.289157] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.328443] CPU: All CPU(s) started at EL2
[ 0.329861] alternatives: patching kernel code
[ 0.334521] CPU3: update max cpu_capacity 1024
[ 0.339705] devtmpfs: initialized
[ 0.341638] CPU1: update max cpu_capacity 1024
[ 0.353054] Registered cp15_barrier emulation handler
[ 0.355328] Registered setend emulation handler
[ 0.360407] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369614] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.416042] pinctrl core: initialized pinctrl subsystem
[ 0.420182] DMI not present or invalid.
[ 0.422683] NET: Registered protocol family 16
[ 0.428962] schedtune: configured to support 5 boost groups
[ 0.435320] cpuidle: using governor menu
[ 0.439003] vdso: 2 pages (1 code @ ffff000009007000, 1 data @ ffff000009c54000)
[ 0.443886] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.458062] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.463965] Serial: AMBA PL011 UART driver
[ 0.466111] imx rpmsg driver is registered.
[ 0.480309] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.498003] MU is ready for cross core communication!
[ 0.502169] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.548354] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.572686] ACPI: Interpreter disabled.
[ 0.577772] vgaarb: loaded
[ 0.578731] SCSI subsystem initialized
[ 0.583207] usbcore: registered new interface driver usbfs
[ 0.587095] usbcore: registered new interface driver hub
[ 0.592676] usbcore: registered new device driver usb
[ 0.599449] i2c i2c-0: IMX I2C adapter registered
[ 0.601974] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.608235] i2c i2c-1: IMX I2C adapter registered
[ 0.611998] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.618763] i2c i2c-2: IMX I2C adapter registered
[ 0.622026] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.629581] media: Linux media interface: v0.10
[ 0.632029] Linux video capture interface: v2.00
[ 0.637054] pps_core: LinuxPPS API ver. 1 registered
[ 0.641466] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.650816] PTP clock support registered
[ 0.655748] EDAC MC: Ver: 3.0.0
[ 0.658733] dmi: Firmware registration failed.
[ 0.663489] Advanced Linux Sound Architecture Driver Initialized.
[ 0.669386] Bluetooth: Core ver 2.22
[ 0.671948] NET: Registered protocol family 31
[ 0.676259] Bluetooth: HCI device and connection manager initialized
[ 0.682626] Bluetooth: HCI socket layer initialized
[ 0.687511] Bluetooth: L2CAP socket layer initialized
[ 0.692585] Bluetooth: SCO socket layer initialized
[ 0.701241] clocksource: Switched to clocksource arch_sys_counter
[ 0.768695] VFS: Disk quotas dquot_6.6.0
[ 0.769846] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.777036] pnp: PnP ACPI: disabled
[ 0.796797] NET: Registered protocol family 2
[ 0.799034] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.806039] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.812958] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.818839] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.824920] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.831423] NET: Registered protocol family 1
[ 0.838717] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.844589] kvm [1]: 8-bit VMID
[ 0.848166] kvm [1]: GICv3: no GICV resource entry
[ 0.851570] kvm [1]: disabling GICv2 emulation
[ 0.856189] kvm [1]: GIC system register CPU interface enabled
[ 0.862251] kvm [1]: vgic interrupt IRQ1
[ 0.866304] kvm [1]: Hyp mode initialized successfully
[ 0.879914] audit: initializing netlink subsys (disabled)
[ 0.882750] audit: type=2000 audit(0.739:1): state=initialized audit_enabled=0 res=1
[ 0.883910] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.913723] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.917124] Registering sdcardfs 0.1
[ 0.920842] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.927210] fuse init (API version 7.26)
[ 0.931021] 9p: Installing v9fs 9p2000 file system support
[ 0.948693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.953270] io scheduler noop registered
[ 0.957490] io scheduler cfq registered (default)
[ 0.961899] io scheduler mq-deadline registered
[ 0.966489] io scheduler kyber registered
[ 1.001569] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 1.008020] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 1.013901] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.027583] mxs-dma 33000000.dma-apbh: initialized
[ 1.032482] Bus freq driver module loaded
[ 1.035602] Config NOC for GPU to 0x80000600
[ 1.037931] Config NOC for VPU and CPU
[ 1.046258] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.050137] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.054902] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.073261] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.081318] SuperH (H)SCI(F) driver initialized
[ 1.084019] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 44, base_baud = 1562500) is a IMX
[ 1.094719] console [ttymxc0] enabled
[ 1.099249] bootconsole [ec_imx6q0] disabled
[ 1.109314] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 45, base_baud = 5000000) is a IMX
[ 1.121179] msm_serial: driver initialized
[ 1.146101] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.152742] [drm] No driver support for vblank timestamp query.
[ 1.158840] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 1.166578] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 1.175124] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
[ 1.181949] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
[ 1.191884] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
[ 1.202742] [drm] VCO frequency is 5940000
[ 1.206858] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
[ 1.238624] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.245887] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 1.252127] [drm] Failed to initialize HDCP
[ 1.258227] [drm] hdmi-audio-codec driver bound to HDMI
[ 1.263490] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[ 1.294953] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 1.307435] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 222750, color depth is 12-bit.
[ 1.307444] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (12-bit). Settings found in row 18
[ 1.307449] [drm] VCO frequency is 4455000
[ 1.307455] [drm] VCO frequency (4455000 KHz) is supported. Settings found in row 11
[ 1.322262] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 2.027733] Console: switching to colour frame buffer device 240x67
[ 2.121874] imx-drm display-subsystem: fb0: frame buffer device
[ 2.128618] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.150969] brd: module loaded
[ 2.162268] loop: module loaded
[ 2.166580] zram: Added device: zram0
[ 2.178824] fsl-quadspi 30bb0000.qspi: unrecognized JEDEC id bytes: 00, 00, 00
[ 2.186150] fsl-quadspi 30bb0000.qspi: Freescale QuadSPI probe failed
[ 2.192674] fsl-quadspi: probe of 30bb0000.qspi failed with error -2
[ 2.199576] slram: not enough parameters.
[ 2.210015] libphy: Fixed MDIO Bus: probed
[ 2.216084] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 2.222757] tun: Universal TUN/TAP device driver, 1.6
[ 2.228325] CAN device driver interface
[ 2.235227] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 2.244877] pps pps0: new PPS source ptp0
[ 2.253993] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 2.264064] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: b6:40:e3:cc:bb:3c
[ 2.276346] libphy: fec_enet_mii_bus: probed
[ 2.280751] mdio_bus 30be0000.ethernet-1: MDIO device at address 0 is missing.
[ 2.289316] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.296764] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.302617] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.308798] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.315779] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.321588] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.329488] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.336461] sky2: driver version 1.30
[ 2.341163] PPP generic driver version 2.4.2
[ 2.345918] PPP BSD Compression module registered
[ 2.350643] PPP Deflate Compression module registered
[ 2.355793] PPP MPPE Compression module registered
[ 2.360784] usbcore: registered new interface driver asix
[ 2.366452] usbcore: registered new interface driver ax88179_178a
[ 2.372717] usbcore: registered new interface driver cdc_ether
[ 2.378804] usbcore: registered new interface driver net1080
[ 2.384632] usbcore: registered new interface driver cdc_subset
[ 2.390789] usbcore: registered new interface driver zaurus
[ 2.396556] usbcore: registered new interface driver cdc_ncm
[ 2.414103] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.420658] ehci-pci: EHCI PCI platform driver
[ 2.425388] ehci-platform: EHCI generic platform driver
[ 2.431017] ehci-orion: EHCI orion driver
[ 2.435318] ehci-exynos: EHCI EXYNOS driver
[ 2.439863] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 2.445717] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.451988] ohci-pci: OHCI PCI platform driver
[ 2.456638] ohci-platform: OHCI generic platform driver
[ 2.462250] ohci-exynos: OHCI EXYNOS driver
[ 2.467285] Can't support > 32 bit dma.
[ 2.471192] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.476730] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.491806] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000001010810
[ 2.501347] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x38200000
[ 2.507563] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.514448] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.521692] usb usb1: Product: xHCI Host Controller
[ 2.526602] usb usb1: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.533971] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.539955] hub 1-0:1.0: USB hub found
[ 2.543773] hub 1-0:1.0: 1 port detected
[ 2.548267] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.553787] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.561550] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.568387] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.575273] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.582515] usb usb2: Product: xHCI Host Controller
[ 2.587472] usb usb2: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.594815] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.600417] hub 2-0:1.0: USB hub found
[ 2.604217] hub 2-0:1.0: 1 port detected
[ 2.609657] usbcore: registered new interface driver usb-storage
[ 2.615867] usbcore: registered new interface driver usb_ehset_test
[ 2.627517] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.639777] usbcore: registered new interface driver xpad
[ 2.645402] usbcore: registered new interface driver usb_acecad
[ 2.651591] usbcore: registered new interface driver aiptek
[ 2.657371] usbcore: registered new interface driver gtco
[ 2.662961] usbcore: registered new interface driver hanwang
[ 2.668854] usbcore: registered new interface driver kbtab
[ 2.678591] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 2.689118] i2c /dev entries driver
[ 2.701029] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 2.707159] random: fast init done
[ 2.710946] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 2.716731] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at /mipi_csi1@30a70000/port/endpoint1 XXX found
[ 2.726839] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 2.734970] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 2.741316] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 2.747095] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at /mipi_csi2@30b60000/port/endpoint1 XXX found
[ 2.757648] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 1, name: mxc-mipi-csi2.1
[ 2.766087] max9286_probe: YYJ ADD 1 @@
[ 2.770159] max9286_read_reg: YYJ ADD 41 @@ reg value=1e
[ 2.776580] max9286_hardware_preinit: YYJ ADD 2 @@
[ 2.781568] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 2.787982] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 2.813273] max9286_write_reg: YYJ ADD 42 @@ reg value=3f
[ 2.829336] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.845262] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 2.861261] max9271_write_reg: YYJ ADD 40 @@ reg value=40
[ 2.877261] max9271_write_reg: YYJ ADD 40 @@ reg value=8
[ 2.883482] max9271_write_reg: YYJ ADD 40 @@ reg value=97
[ 2.889268] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2.905263] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.925262] max9286_write_reg: YYJ ADD 42 @@ reg value=12
[ 2.931572] max9286_write_reg: YYJ ADD 42 @@ reg value=1
[ 2.937785] max9286_write_reg: YYJ ADD 42 @@ reg value=63
[ 2.944172] max9286_write_reg: YYJ ADD 42 @@ reg value=64
[ 2.950488] max9286_write_reg: YYJ ADD 42 @@ reg value=8
[ 2.956717] max9286_write_reg: YYJ ADD 42 @@ reg value=c
[ 2.963020] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.044790] usb 1-1: New USB device found, idVendor=17ef, idProduct=6019
[ 3.051517] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.058688] usb 1-1: Product: Lenovo Optical USB Mouse
[ 3.063845] usb 1-1: Manufacturer: PixArt
[ 3.169457] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 3.177268] max9286_read_reg: YYJ ADD 41 @@ reg value=49
[ 3.183632] max9286_data->sensor_num=80
[ 3.183637] max9286_mipi: reg = 0x80.
[ 3.191278] max9286_mipi: sensor number = 1.
[ 3.195571] YYJ v4l2_i2c_subdev_init sd->name =max9286_mipi 1-006a
[ 3.201941] YYJ add --->media_entity_pads_init entity->num_pads=4
[ 3.208155] YYJ ADD max9286_probe media_entity_pads_init retval=0
[ 3.214442] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: max9286_mipi 1-006a
[ 3.223338] YYJ ADD max9286_probe retval=0
[ 3.227553] max9286_mipi 1-006a: YYJ ADD 4 In max9286_hardware_init()
[ 3.234185] max9286_mipi 1-006a: In max9286_hardware_init()
[ 3.239780] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 3.246010] max9286_camera_reorder: YYJ ADD 3 @@
[ 3.250822] max9286_write_reg: YYJ ADD 42 @@ reg value=b
[ 3.257050] max9286_write_reg: YYJ ADD 42 @@ reg value=69
[ 3.263372] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.297262] max9271_write_reg: YYJ ADD 40 @@ reg value=7
[ 3.329261] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.335481] max9271_write_reg: YYJ ADD 40 @@ reg value=0
[ 3.357260] max9271_write_reg: YYJ ADD 40 @@ reg value=20
[ 3.363582] max9271_write_reg: YYJ ADD 40 @@ reg value=21
[ 3.369890] max9271_write_reg: YYJ ADD 40 @@ reg value=22
[ 3.376214] max9271_write_reg: YYJ ADD 40 @@ reg value=23
[ 3.382522] max9271_write_reg: YYJ ADD 40 @@ reg value=24
[ 3.388832] max9271_write_reg: YYJ ADD 40 @@ reg value=25
[ 3.395157] max9271_write_reg: YYJ ADD 40 @@ reg value=26
[ 3.401470] max9271_write_reg: YYJ ADD 40 @@ reg value=27
[ 3.407792] max9271_write_reg: YYJ ADD 40 @@ reg value=30
[ 3.414110] max9271_write_reg: YYJ ADD 40 @@ reg value=31
[ 3.420420] max9271_write_reg: YYJ ADD 40 @@ reg value=32
[ 3.426746] max9271_write_reg: YYJ ADD 40 @@ reg value=33
[ 3.433056] max9271_write_reg: YYJ ADD 40 @@ reg value=34
[ 3.439365] max9271_write_reg: YYJ ADD 40 @@ reg value=35
[ 3.445691] max9271_write_reg: YYJ ADD 40 @@ reg value=36
[ 3.452000] max9271_write_reg: YYJ ADD 40 @@ reg value=37
[ 3.458316] max9271_write_reg: YYJ ADD 40 @@ reg value=3f
[ 3.464624] max9271_write_reg: YYJ ADD 40 @@ reg value=47
[ 3.470932] max9271_write_reg: YYJ ADD 40 @@ reg value=48
[ 3.477259] max9271_write_reg: YYJ ADD 40 @@ reg value=49
[ 3.483567] max9271_write_reg: YYJ ADD 40 @@ reg value=4c
[ 3.489875] max9271_write_reg: YYJ ADD 40 @@ reg value=43
[ 3.496196] max9271_write_reg: YYJ ADD 40 @@ reg value=1
[ 3.502418] max9271_write_reg: YYJ ADD 40 @@ reg value=9
[ 3.508654] max9271_write_reg: YYJ ADD 40 @@ reg value=a
[ 3.514897] max9271_write_reg: YYJ ADD 40 @@ reg value=b
[ 3.521142] max9271_write_reg: YYJ ADD 40 @@ reg value=c
[ 3.537261] max9286_mipi: initialized sensor = 0x04.
[ 3.542346] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.548588] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.554858] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.561205] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.567536] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 4.585261] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.609262] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.615782] max9286_mipi 1-006a: max9286_mipi is found, name max9286_mipi 1-006a
[ 4.623205] YYJ ADD max9286_probe done
[ 4.628548] usbcore: registered new interface driver uvcvideo
[ 4.634317] USB Video Class driver (1.1.1)
[ 4.640251] __power_supply_register: Expected proper parent device for 'battery'
[ 4.648009] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 4.660471] __power_supply_register: Expected proper parent device for 'usb'
[ 4.673556] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 4.681482] device-mapper: uevent: version 1.0.3
[ 4.686613] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[ 4.695675] Bluetooth: HCI UART driver ver 2.3
[ 4.700143] Bluetooth: HCI UART protocol H4 registered
[ 4.705300] Bluetooth: HCI UART protocol BCSP registered
[ 4.710646] Bluetooth: HCI UART protocol ATH3K registered
[ 4.716063] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.722792] Bluetooth: HCI UART protocol Broadcom registered
[ 4.728486] Bluetooth: HCI UART protocol QCA registered
[ 4.734065] bt power gpio is:69
[ 4.737458] rfkill: BT RF going to : on
[ 4.741262] mxc_bt_rfkill driver success loaded
[ 4.741350] mxc_bt_rfkill_reset
[ 4.749948] sdhci: Secure Digital Host Controller Interface driver
[ 4.756157] sdhci: Copyright(c) Pierre Ossman
[ 4.761146] Synopsys Designware Multimedia Card Interface Driver
[ 4.769422] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.822370] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 4.831325] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 4.887548] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 4.901222] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.909751] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 4.915728] caam-snvs 30370000.caam-snvs: violation handlers armed - init state
[ 4.923985] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.948400] input: PixArt Lenovo Optical USB Mouse as /devices/platform/usb@38200000/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:17EF:6019.0001/input/input1
[ 4.963815] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo Optical USB Mouse] on usb-xhci-hcd.0.auto-1/input0
[ 4.977539] usbcore: registered new interface driver usbhid
[ 4.983249] usbhid: USB HID core driver
[ 4.987177] mmc0: new HS400 MMC card at address 0001
[ 4.992909] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 4.998019] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 5.004517] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 5.011042] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 5.019681] Alternate GPT is invalid, using primary GPT.
[ 5.025080] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 5.032535] ashmem: initialized
[ 5.041799] usbcore: registered new interface driver snd-usb-audio
[ 5.049380] ak4458 2-0010: 2-0010 supply DVDD not found, using dummy regulator
[ 5.056687] ak4458 2-0010: 2-0010 supply AVDD not found, using dummy regulator
[ 5.064374] ak4458 2-0012: 2-0012 supply DVDD not found, using dummy regulator
[ 5.071661] ak4458 2-0012: 2-0012 supply AVDD not found, using dummy regulator
[ 5.079477] ak4497 2-0011: 2-0011 supply DVDD not found, using dummy regulator
[ 5.086762] ak4497 2-0011: 2-0011 supply AVDD not found, using dummy regulator
[ 5.094713] ak5558 2-0013: 2-0013 supply DVDD not found, using dummy regulator
[ 5.102023] ak5558 2-0013: 2-0013 supply AVDD not found, using dummy regulator
[ 5.144348] imx-wm8524 sound-wm8524: wm8524-hifi <-> 308b0000.sai mapping ok
[ 5.151435] imx-wm8524 sound-wm8524: ASoC: no DMI vendor name!
[ 5.163093] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 30810000.spdif mapping ok
[ 5.170759] imx-spdif sound-spdif: ASoC: no DMI vendor name!
[ 5.179852] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 308a0000.spdif mapping ok
[ 5.187757] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 5.201083] ak4458 2-0010: ASoC: failed to probe component -6
[ 5.207014] imx-ak4458 sound-ak4458: ASoC: failed to instantiate card -6
[ 5.213976] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-6)
[ 5.236887] ak5558 2-0013: ASoC: failed to probe component -6
[ 5.242735] imx-ak5558 sound-ak5558: ASoC: failed to instantiate card -6
[ 5.249723] imx-ak5558 sound-ak5558: snd_soc_register_card failed (-6)
[ 5.256963] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30050000.sai mapping ok
[ 5.263822] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[ 5.271829] NET: Registered protocol family 26
[ 5.276379] u32 classifier
[ 5.279114] Actions configured
[ 5.282598] Netfilter messages via NETLINK v0.30.
[ 5.287666] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.294165] ctnetlink v0.93: registering with nfnetlink.
[ 5.300315] xt_time: kernel timezone is -0000
[ 5.304800] IPv4 over IPsec tunneling driver
[ 5.309949] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.316019] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 5.321912] Initializing XFRM netlink socket
[ 5.327150] NET: Registered protocol family 10
[ 5.333207] Segment Routing with IPv6
[ 5.337016] mip6: Mobile IPv6
[ 5.340026] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.346753] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.354220] NET: Registered protocol family 17
[ 5.358717] NET: Registered protocol family 15
[ 5.363238] can: controller area network core (rev 20170425 abi 9)
[ 5.369489] NET: Registered protocol family 29
[ 5.374019] can: raw protocol (rev 20170425)
[ 5.378320] can: broadcast manager protocol (rev 20170425 t)
[ 5.384059] can: netlink gateway (rev 20170425) max_hops=1
[ 5.390117] Bluetooth: RFCOMM TTY layer initialized
[ 5.395094] Bluetooth: RFCOMM socket layer initialized
[ 5.400265] Bluetooth: RFCOMM ver 1.11
[ 5.404099] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.409443] Bluetooth: BNEP filters: protocol multicast
[ 5.414747] Bluetooth: BNEP socket layer initialized
[ 5.419729] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.425742] Bluetooth: HIDP socket layer initialized
[ 5.430722] lib80211: common routines for IEEE802.11 drivers
[ 5.436893] 9pnet: Installing 9P2000 support
[ 5.443902] registered taskstats version 1
[ 5.459969] cpu cpu0: registered imx8mq-cpufreq
[ 5.479319] galcore: clk_get 2d core clock failed, disable 2d/vg!
[ 5.485742] Galcore version 6.2.4.190076
[ 5.579835] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 1
[ 5.590915] update hantro voltage from 900 mV to 1000 mV
[ 5.596869] hantrodec: module inserted. Major = 509
[ 5.604616] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2019-10-29 06:00:08 UTC (1572328808)
[ 5.615398] VSD_3V3: disabling
[ 5.618471] gpio_dvfs: disabling
[ 5.621736] VGEN1: disabling
[ 5.626567] VGEN6: disabling
[ 5.631233] ALSA device list:
[ 5.634266] #0: wm8524-audio
[ 5.637398] #1: imx-spdif
[ 5.640194] #2: imx-hdmi-arc
[ 5.643327] #3: imx-audio-hdmi
[ 5.646809] device-mapper: init: attempting early device configuration.
[ 5.654658] device-mapper: init: adding target '0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 fec_roots 2 fec_blocks 455050 fec_start 455050'
[ 5.703244] device-mapper: init: dm-0 is ready
[ 5.724135] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 5.731231] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
[ 5.738694] devtmpfs: mounted
[ 5.743314] Freeing unused kernel memory: 5504K
[ 5.778422] init: init first stage started!
[ 5.783520] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 5.793404] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[ 5.839935] init: [libfs_mgr]Returning avb_handle with status: 0
[ 5.851474] init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/30b40000.usdhc/by-name/vendor_a /dev/block/platform/30b40000.usdhc/by-name/vendor_a 4096 4096 64481 64481 sha1 51806766da39076dff37f6ba052ba9c97bb90718 9dcbde58e29f0cf7ca3f2b33cfdfb75a9d9fb268 10 use_fec_from_device /dev/block/platform/30b40000.usdhc/by-name/vendor_a fec_roots 2 fec_blocks 64990 fec_start 64990 restart_on_corruption ignore_zero_blocks'
[ 5.905196] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 5.914601] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
[ 5.923573] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 5.930564] init: Loading SELinux policy
[ 5.962457] SELinux: Class process2 not defined in policy.
[ 5.968556] SELinux: Class infiniband_pkey not defined in policy.
[ 5.974772] SELinux: Class infiniband_endport not defined in policy.
[ 5.981225] SELinux: the above unknown classes and permissions will be denied
[ 5.988390] SELinux: policy capability network_peer_controls=1
[ 5.994331] SELinux: policy capability open_perms=1
[ 5.999304] SELinux: policy capability extended_socket_class=1
[ 6.005333] SELinux: policy capability always_check_network=0
[ 6.011187] SELinux: policy capability cgroup_seclabel=0
[ 6.016595] SELinux: policy capability nnp_nosuid_transition=0
[ 6.110925] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 6.110925]
[ 6.111232] audit: type=1403 audit(1572328809.003:2): policy loaded auid=4294967295 ses=4294967295
[ 6.129780] audit: type=1404 audit(1572328809.015:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 6.159783] selinux: SELinux: Loaded file_contexts
[ 6.159783]
[ 6.170480] init: init second stage started!
[ 6.195525] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 6.207476] selinux: SELinux: Loaded file_contexts
[ 6.207476]
[ 6.213783] init: Running restorecon...
[ 6.225450] init: waitid failed: No child processes
[ 6.235057] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
[ 6.253503] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[ 6.262564] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2347
[ 6.270112] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2348
[ 6.277302] init: Parsing file /init.rc...
[ 6.372420] audit: type=1400 audit(1572328809.263:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.378239] ueventd: ueventd started!
[ 6.390037] audit: type=1400 audit(1572328809.263:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.396711] selinux: SELinux: Loaded file_contexts
[ 6.396711]
[ 6.411280] audit: type=1400 audit(1572328809.263:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.417729] ueventd: Parsing file /ueventd.rc...
[ 6.435134] audit: type=1400 audit(1572328809.263:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.435198] audit: type=1400 audit(1572328809.267:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.441808] ueventd: Parsing file /vendor/ueventd.rc...
[ 6.457478] audit: type=1400 audit(1572328809.271:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.475886] ueventd: Parsing file /odm/ueventd.rc...
[ 6.480363] audit: type=1400 audit(1572328809.271:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.480371] audit: type=1400 audit(1572328809.271:11): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.498044] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[ 6.548488] ueventd: Parsing file /ueventd.freescale.rc...
[ 6.554120] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[ 6.583104] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin'
[ 6.602951] ueventd: loading /devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin took 19ms
[ 6.618797] imx-sdma 302c0000.sdma: loaded firmware 4.4
[ 6.619479] imx-sdma 30bd0000.sdma: loaded firmware 4.4
[ 6.752131] Registered swp emulation handler
[ 6.762894] watchdogd: watchdogd started (interval 10, margin 20)!
[ 6.769847] Console: switching to colour dummy device 80x25
[ 6.775507] wlan: loading driver v4.5.23.1
[ 6.798477] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 6.948643] EXT4-fs (mmcblk0p12): recovery complete
[ 6.954613] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 8.419215] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 8.419215]
[ 8.425301] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 8.425301]
[ 8.432683] e2fsck: Pass 2: Checking directory structure
[ 8.432683]
[ 8.439503] e2fsck: Pass 3: Checking directory connectivity
[ 8.439503]
[ 8.446701] e2fsck: Pass 4: Checking reference counts
[ 8.446701]
[ 8.453245] e2fsck: Pass 5: Checking group summary information
[ 8.453245]
[ 8.460584] e2fsck: /dev/block/by-name/userdata: 1563/581632 files (2.4% non-contiguous), 73918/2326528 blocks
[ 8.460584]
[ 8.477393] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 8.491907] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 8.533378] zram0: detected capacity change from 0 to 314572800
[ 8.550236] logd.auditd: start
[ 8.553367] logd.klogd: 8412114995
[ 8.565411] mkswap: Swapspace size: 307196k, UUID=1320804e-3060-4717-9173-3d945548292b
[ 8.575189] Adding 307196k swap on /dev/block/zram0. Priority:-2 extents:1 across:307196k SS
[ 8.599312] type=1400 audit(1572328811.475:38): avc: denied { getattr } for pid=2347 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.620376] type=1400 audit(1572328811.475:38): avc: denied { getattr } for pid=2347 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.640945] type=1400 audit(1572328811.479:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 8.930955] update_verifier: Started with arg 1: nonencrypted
[ 8.942460] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 8.949001] update_verifier: Leaving update_verifier.
[ 8.983659] logd.daemon: reinit
[ 8.999935] rfkill: BT RF going to : off
[ 9.011742] Mass Storage Function, version: 2009/09/11
[ 9.016970] LUN: removable file: (no medium)
[ 9.025903] using random self ethernet address
[ 9.030423] using random host ethernet address
[ 9.036848] file system registered
[ 9.143303] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
evk_8mq:/ $ [ 9.302911] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 9.677439] type=1400 audit(1572328811.483:46): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 9.768970] read descriptors
[ 9.785323] read strings
[ 10.373431] type=1400 audit(1572328812.559:546): avc: denied { read } for pid=2983 comm="[email protected]" name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=9354 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
[ 10.398854] type=1400 audit(1572328812.559:546): avc: denied { read } for pid=2983 comm="[email protected]" name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=9354 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
[ 10.420613] type=1400 audit(1572328812.563:547): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 10.675771] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.706746] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.737154] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.870809] android_work: sent uevent USB_STATE=CONNECTED
[ 10.933465] configfs-gadget gadget: high-speed config #1: b
[ 10.939426] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.554202] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[ 11.877854] random: crng init done
[ 11.963636] init: Service 'early_init_sh' (pid 2350) exited with status 0
[ 13.386122] audit_log_lost: 30 callbacks suppressed
[ 13.386127] audit: audit_lost=520 audit_rate_limit=5 audit_backlog_limit=64
[ 13.398159] audit: rate limit exceeded
[ 13.604015] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.620183] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.630983] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.797612] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
[ 14.349486] read descriptors
[ 14.352400] read strings
[ 14.355065] read descriptors
[ 14.358001] read strings
[ 14.379283] acc_open
[ 14.381518] acc_release
[ 14.534592] fec 30be0000.ethernet eth0: Unable to connect to phy
[ 14.653046] type=1400 audit(1572328816.279:580): avc: denied { dac_read_search } for pid=2995 comm="Binder:2995_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.674808] type=1400 audit(1572328817.543:2351): avc: denied { dac_read_search } for pid=3240 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.791236] audit: audit_lost=2290 audit_rate_limit=5 audit_backlog_limit=64
[ 14.796374] type=1400 audit(1572328817.543:2354): avc: denied { dac_read_search } for pid=3240 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.803439] sdcardfs version 2.0
[ 14.804319] audit: rate limit exceeded
[ 14.830793] sdcardfs: dev_name -> /data/media
[ 14.831367] type=1400 audit(1572328817.683:2355): avc: denied { dac_read_search } for pid=3258 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.835286] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[ 14.863471] sdcardfs: mnt -> ffff80005ea783a0
[ 14.868003] sdcardfs: mounted on top of /data/media type ext4
[ 14.875356] Remount options were mask=23,gid=9997 for vfsmnt ffff80005ea79360.
[ 14.883042] sdcardfs : options - debug:1
[ 14.887027] sdcardfs : options - gid:9997
[ 14.891296] sdcardfs : options - mask:23
[ 14.896568] Remount options were mask=7,gid=9997 for vfsmnt ffff80005ea79de0.
[ 14.903951] sdcardfs : options - debug:1
[ 14.907930] sdcardfs : options - gid:9997
[ 14.912166] sdcardfs : options - mask:7
[ 16.054292] type=1400 audit(1572328817.683:2355): avc: denied { dac_read_search } for pid=3258 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 16.076984] type=1400 audit(1572328818.947:2383): avc: denied { read } for pid=3122 comm="system_server" name="state" dev="sysfs" ino=21219 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 16.124925] type=1400 audit(1572328818.947:2383): avc: denied { read } for pid=3122 comm="system_server" name="state" dev="sysfs" ino=21219 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 16.154964] type=1400 audit(1572328818.999:2384): avc: denied { dac_read_search } for pid=3559 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 17.898193] init: Service 'bootanim' (pid 3097) exited with status 0
[ 18.013611] init: processing action (sys.boot_completed=1) from (/init.rc:719)
[ 18.021309] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:20)
[ 18.038195] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:27)
[ 18.043800] type=1400 audit(1572328818.999:2387): avc: denied { dac_read_search } for pid=3559 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 18.071785] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
[ 18.074219] type=1400 audit(1572328820.931:2388): avc: denied { dac_read_search } for pid=2884 comm="Binder:2884_3" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 18.084403] audit: audit_lost=2317 audit_rate_limit=5 audit_backlog_limit=64
[ 18.084703] init: starting service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[ 18.086002] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 18.145337] audit: rate limit exceeded
[ 18.151277] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 65ms and succeeded
[ 18.183984] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[ 18.183984]
[ 18.215001] init: Async property child exited with status 0
[ 19.361027] audit: audit_lost=3552 audit_rate_limit=5 audit_backlog_limit=64
[ 19.368170] audit: rate limit exceeded
[ 25.039187] type=1400 audit(1572328822.251:3632): avc: denied { dac_read_search } for pid=3748 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.059307] type=1400 audit(1572328827.931:3644): avc: denied { dac_read_search } for pid=3827 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.068518] audit: audit_lost=3563 audit_rate_limit=5 audit_backlog_limit=64
[ 25.079335] type=1400 audit(1572328827.931:3647): avc: denied { dac_read_search } for pid=3827 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 25.084602] audit: rate limit exceeded
[ 25.104424] type=1400 audit(1572328827.959:3648): avc: denied { dac_read_search } for pid=3842 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
PMIC: PFUZE100 ID=0x10
DDRINFO: start lpddr4 ddr init
DRAM PHY training for 3200MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC1
CPU: Freescale i.MX8MQ rev2.1 1300 MHz (running at 800 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 73C
Reset cause: POR
Model: Freescale i.MX8MQ EVK
DRAM: 3 GiB
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C0 0x50]
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
No panel detected: default to HDMI
Display: HDMI (1280x720)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
flash target is MMC:0
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
verify OK, boot 'boot_a'
Kernel load addr 0x40480000 size 30901 KiB
kernel @ 40480000 (31642112)
ramdisk @ 43600000 (7425791)
fdt @ 43400000 (45831)
## Flattened Device Tree blob at 43400000
Booting using the fdt blob at 0x43400000
Using Device Tree in place at 0000000043400000, end 000000004340e306
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Freescale i.MX8MQ EVK
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: ION carveout pool at 0x00000000f8000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node imx_ion@0, compatible id imx-ion-pool
[ 0.000000] cma: Reserved 1280 MiB at 0x00000000a8000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xa7fba500-0xa7fbc2ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000097ffffff]
[ 0.000000] node 0: [mem 0x0000000098100000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu @ffff800067f50000 s64536 r8192 d29672 u102400
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 773888
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200 init=/init androidboot.gui_resolution=1080p androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.fbTileSupport=enable cma=1280M androidboot.primary_display=imx-drm firmware_class.path=/vendor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.wifivendor=bcm buildvariant=userdebug androidboot.serialno=152059d6f32ef628 androidboot.btmacaddr=15:20:59:d6:f3:2e androidboot.soc_type=imx8mq androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:4835,KL:0,KD:0,AVB:2259,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_ze
[ 0.000000] device-mapper: init: will configure 1 devices
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1621520K/3144704K available (15868K kernel code, 2420K rwdata, 7044K rodata, 5504K init, 523K bss, 212464K reserved, 1310720K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000009000000 ( 15872 KB)
[ 0.000000] .rodata : 0xffff000009000000 - 0xffff0000096f0000 ( 7104 KB)
[ 0.000000] .init : 0xffff0000096f0000 - 0xffff000009c50000 ( 5504 KB)
[ 0.000000] .data : 0xffff000009c50000 - 0xffff000009ead200 ( 2421 KB)
[ 0.000000] .bss : 0xffff000009ead200 - 0xffff000009f30080 ( 524 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0003000000 ( 48 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff8000c0000000 ( 3072 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MQ clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.008873] system counter timer init
[ 0.011731] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.019710] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.031075] Console: colour dummy device 80x25
[ 0.034493] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.053470] SELinux: Initializing.
[ 0.058524] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.064943] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.071301] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.077995] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.117786] Cannot find MU entry in device tree
[ 0.119614] CPU identified as i.MX8MQ, silicon rev 2.1
[ 0.125574] EFI services will not be available.
[ 0.137189] smp: Bringing up secondary CPUs ...
[ 0.165374] Detected VIPT I-cache on CPU1
[ 0.165406] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.165433] CPU1: Booted secondary processor [410fd034]
[ 0.193441] Detected VIPT I-cache on CPU2
[ 0.193462] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.193483] CPU2: Booted secondary processor [410fd034]
[ 0.221531] Detected VIPT I-cache on CPU3
[ 0.221552] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.221573] CPU3: Booted secondary processor [410fd034]
[ 0.221801] smp: Brought up 1 node, 4 CPUs
[ 0.271460] SMP: Total of 4 processors activated.
[ 0.276162] CPU features: detected feature: GIC system register CPU interface
[ 0.283322] CPU features: detected feature: 32-bit EL0 Support
[ 0.289154] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.328439] CPU: All CPU(s) started at EL2
[ 0.329857] alternatives: patching kernel code
[ 0.334517] CPU3: update max cpu_capacity 1024
[ 0.339706] devtmpfs: initialized
[ 0.341635] CPU1: update max cpu_capacity 1024
[ 0.353049] Registered cp15_barrier emulation handler
[ 0.355322] Registered setend emulation handler
[ 0.360401] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369608] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.415994] pinctrl core: initialized pinctrl subsystem
[ 0.419950] DMI not present or invalid.
[ 0.422807] NET: Registered protocol family 16
[ 0.428914] schedtune: configured to support 5 boost groups
[ 0.440356] cpuidle: using governor menu
[ 0.443792] vdso: 2 pages (1 code @ ffff000009007000, 1 data @ ffff000009c54000)
[ 0.448862] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.463368] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.469282] Serial: AMBA PL011 UART driver
[ 0.471410] imx rpmsg driver is registered.
[ 0.485777] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.503522] MU is ready for cross core communication!
[ 0.507674] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.573024] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.589322] ACPI: Interpreter disabled.
[ 0.594407] vgaarb: loaded
[ 0.595335] SCSI subsystem initialized
[ 0.599952] usbcore: registered new interface driver usbfs
[ 0.603740] usbcore: registered new interface driver hub
[ 0.609321] usbcore: registered new device driver usb
[ 0.616182] i2c i2c-0: IMX I2C adapter registered
[ 0.618610] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.624819] i2c i2c-1: IMX I2C adapter registered
[ 0.628633] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.635401] i2c i2c-2: IMX I2C adapter registered
[ 0.638661] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.646212] media: Linux media interface: v0.10
[ 0.648664] Linux video capture interface: v2.00
[ 0.653694] pps_core: LinuxPPS API ver. 1 registered
[ 0.658101] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.667444] PTP clock support registered
[ 0.672433] EDAC MC: Ver: 3.0.0
[ 0.675392] dmi: Firmware registration failed.
[ 0.680073] Advanced Linux Sound Architecture Driver Initialized.
[ 0.686071] Bluetooth: Core ver 2.22
[ 0.688574] NET: Registered protocol family 31
[ 0.692894] Bluetooth: HCI device and connection manager initialized
[ 0.699262] Bluetooth: HCI socket layer initialized
[ 0.704143] Bluetooth: L2CAP socket layer initialized
[ 0.709220] Bluetooth: SCO socket layer initialized
[ 0.717892] clocksource: Switched to clocksource arch_sys_counter
[ 0.785393] VFS: Disk quotas dquot_6.6.0
[ 0.786545] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.793745] pnp: PnP ACPI: disabled
[ 0.808816] NET: Registered protocol family 2
[ 0.811024] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.818138] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.824914] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.830857] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.836939] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.843441] NET: Registered protocol family 1
[ 0.850786] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.856418] kvm [1]: 8-bit VMID
[ 0.860186] kvm [1]: GICv3: no GICV resource entry
[ 0.863642] kvm [1]: disabling GICv2 emulation
[ 0.868203] kvm [1]: GIC system register CPU interface enabled
[ 0.874321] kvm [1]: vgic interrupt IRQ1
[ 0.878305] kvm [1]: Hyp mode initialized successfully
[ 0.892703] audit: initializing netlink subsys (disabled)
[ 0.895589] audit: type=2000 audit(0.759:1): state=initialized audit_enabled=0 res=1
[ 0.896602] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.926514] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.929919] Registering sdcardfs 0.1
[ 0.933562] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.940081] fuse init (API version 7.26)
[ 0.943752] 9p: Installing v9fs 9p2000 file system support
[ 0.961519] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.966174] io scheduler noop registered
[ 0.970251] io scheduler cfq registered (default)
[ 0.974725] io scheduler mq-deadline registered
[ 0.979256] io scheduler kyber registered
[ 1.014183] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 1.020667] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 1.030431] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.047235] mxs-dma 33000000.dma-apbh: initialized
[ 1.052971] Bus freq driver module loaded
[ 1.056598] Config NOC for GPU to 0x80000600
[ 1.058417] Config NOC for VPU and CPU
[ 1.067615] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.071679] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.076201] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.098714] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.106817] SuperH (H)SCI(F) driver initialized
[ 1.109508] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 44, base_baud = 1562500) is a IMX
[ 1.120218] console [ttymxc0] enabled
[ 1.124749] bootconsole [ec_imx6q0] disabled
[ 1.134822] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 45, base_baud = 5000000) is a IMX
[ 1.146777] msm_serial: driver initialized
[ 1.171524] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.178226] [drm] No driver support for vblank timestamp query.
[ 1.184320] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 1.192055] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 1.200602] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
[ 1.207426] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
[ 1.217361] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
[ 1.228220] [drm] VCO frequency is 5940000
[ 1.232335] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
[ 1.264293] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.271556] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 1.277800] [drm] Failed to initialize HDCP
[ 1.283821] [drm] hdmi-audio-codec driver bound to HDMI
[ 1.289086] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[ 1.320613] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 1.333060] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 222750, color depth is 12-bit.
[ 1.333070] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (12-bit). Settings found in row 18
[ 1.333075] [drm] VCO frequency is 4455000
[ 1.333080] [drm] VCO frequency (4455000 KHz) is supported. Settings found in row 11
[ 1.346958] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 2.052631] Console: switching to colour frame buffer device 240x67
[ 2.146941] imx-drm display-subsystem: fb0: frame buffer device
[ 2.153670] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.175980] brd: module loaded
[ 2.187199] loop: module loaded
[ 2.191402] zram: Added device: zram0
[ 2.203635] fsl-quadspi 30bb0000.qspi: unrecognized JEDEC id bytes: 00, 00, 00
[ 2.210899] fsl-quadspi 30bb0000.qspi: Freescale QuadSPI probe failed
[ 2.217462] fsl-quadspi: probe of 30bb0000.qspi failed with error -2
[ 2.224308] slram: not enough parameters.
[ 2.234757] libphy: Fixed MDIO Bus: probed
[ 2.240906] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 2.247649] tun: Universal TUN/TAP device driver, 1.6
[ 2.253137] CAN device driver interface
[ 2.260108] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 2.269811] pps pps0: new PPS source ptp0
[ 2.278878] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 2.288980] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: f2:f0:27:51:0c:2c
[ 2.301211] libphy: fec_enet_mii_bus: probed
[ 2.305762] mdio_bus 30be0000.ethernet-1: MDIO device at address 0 is missing.
[ 2.314312] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.321716] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.327678] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.333843] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.340932] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.346726] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.354717] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.361681] sky2: driver version 1.30
[ 2.366477] PPP generic driver version 2.4.2
[ 2.371262] PPP BSD Compression module registered
[ 2.375986] PPP Deflate Compression module registered
[ 2.381134] PPP MPPE Compression module registered
[ 2.386163] usbcore: registered new interface driver asix
[ 2.391828] usbcore: registered new interface driver ax88179_178a
[ 2.398156] usbcore: registered new interface driver cdc_ether
[ 2.404210] usbcore: registered new interface driver net1080
[ 2.410145] usbcore: registered new interface driver cdc_subset
[ 2.416287] usbcore: registered new interface driver zaurus
[ 2.422174] usbcore: registered new interface driver cdc_ncm
[ 2.439685] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.446303] ehci-pci: EHCI PCI platform driver
[ 2.450923] ehci-platform: EHCI generic platform driver
[ 2.456548] ehci-orion: EHCI orion driver
[ 2.460847] ehci-exynos: EHCI EXYNOS driver
[ 2.465378] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 2.471212] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.477483] ohci-pci: OHCI PCI platform driver
[ 2.482111] ohci-platform: OHCI generic platform driver
[ 2.487710] ohci-exynos: OHCI EXYNOS driver
[ 2.492733] Can't support > 32 bit dma.
[ 2.496700] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.502235] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.517194] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000001010810
[ 2.526729] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x38200000
[ 2.532927] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.539796] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.547037] usb usb1: Product: xHCI Host Controller
[ 2.551994] usb usb1: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.559364] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.565360] hub 1-0:1.0: USB hub found
[ 2.569168] hub 1-0:1.0: 1 port detected
[ 2.573663] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.579184] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.586929] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.593749] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.600620] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.607862] usb usb2: Product: xHCI Host Controller
[ 2.612818] usb usb2: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.620145] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.625755] hub 2-0:1.0: USB hub found
[ 2.629553] hub 2-0:1.0: 1 port detected
[ 2.634950] usbcore: registered new interface driver usb-storage
[ 2.641165] usbcore: registered new interface driver usb_ehset_test
[ 2.652800] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.665066] usbcore: registered new interface driver xpad
[ 2.670655] usbcore: registered new interface driver usb_acecad
[ 2.676909] usbcore: registered new interface driver aiptek
[ 2.682658] usbcore: registered new interface driver gtco
[ 2.688293] usbcore: registered new interface driver hanwang
[ 2.694137] usbcore: registered new interface driver kbtab
[ 2.703973] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 2.714542] i2c /dev entries driver
[ 2.725480] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 2.731762] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 2.737519] random: fast init done
[ 2.741105] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at /mipi_csi1@30a70000/port/endpoint1 XXX found
[ 2.751212] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 2.759093] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 2.765351] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 2.771150] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at /mipi_csi2@30b60000/port/endpoint1 XXX found
[ 2.781407] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 1, name: mxc-mipi-csi2.1
[ 2.789486] max9286_probe: YYJ ADD 1 @@
[ 2.793760] max9286_read_reg: YYJ ADD 41 @@ reg value=1e
[ 2.800211] max9286_hardware_preinit: YYJ ADD 2 @@
[ 2.805256] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 2.811624] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 2.837915] max9286_write_reg: YYJ ADD 42 @@ reg value=3f
[ 2.853912] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.869912] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 2.885910] max9271_write_reg: YYJ ADD 40 @@ reg value=40
[ 2.901910] max9271_write_reg: YYJ ADD 40 @@ reg value=8
[ 2.908131] max9271_write_reg: YYJ ADD 40 @@ reg value=97
[ 2.921921] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2.925911] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.949911] max9286_write_reg: YYJ ADD 42 @@ reg value=12
[ 2.956220] max9286_write_reg: YYJ ADD 42 @@ reg value=1
[ 2.962442] max9286_write_reg: YYJ ADD 42 @@ reg value=63
[ 2.968764] max9286_write_reg: YYJ ADD 42 @@ reg value=64
[ 2.975073] max9286_write_reg: YYJ ADD 42 @@ reg value=8
[ 2.981318] max9286_write_reg: YYJ ADD 42 @@ reg value=c
[ 2.987561] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.085942] usb 1-1: New USB device found, idVendor=17ef, idProduct=6019
[ 3.092668] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.099821] usb 1-1: Product: Lenovo Optical USB Mouse
[ 3.104978] usb 1-1: Manufacturer: PixArt
[ 3.194135] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 3.197919] max9286_read_reg: YYJ ADD 41 @@ reg value=49
[ 3.206056] max9286_data->sensor_num=80
[ 3.206061] max9286_mipi: reg = 0x80.
[ 3.213577] max9286_mipi: sensor number = 1.
[ 3.218034] YYJ v4l2_i2c_subdev_init sd->name =max9286_mipi 1-006a
[ 3.224407] YYJ add --->media_entity_pads_init entity->num_pads=4
[ 3.230604] YYJ ADD max9286_probe media_entity_pads_init retval=0
[ 3.236909] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: max9286_mipi 1-006a
[ 3.245798] YYJ ADD max9286_probe retval=0
[ 3.250015] max9286_mipi 1-006a: YYJ ADD 4 In max9286_hardware_init()
[ 3.256648] max9286_mipi 1-006a: In max9286_hardware_init()
[ 3.262237] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 3.268469] max9286_camera_reorder: YYJ ADD 3 @@
[ 3.273280] max9286_write_reg: YYJ ADD 42 @@ reg value=b
[ 3.279500] max9286_write_reg: YYJ ADD 42 @@ reg value=69
[ 3.285825] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.317912] max9271_write_reg: YYJ ADD 40 @@ reg value=7
[ 3.349911] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.356132] max9271_write_reg: YYJ ADD 40 @@ reg value=0
[ 3.377912] max9271_write_reg: YYJ ADD 40 @@ reg value=20
[ 3.384235] max9271_write_reg: YYJ ADD 40 @@ reg value=21
[ 3.390545] max9271_write_reg: YYJ ADD 40 @@ reg value=22
[ 3.396853] max9271_write_reg: YYJ ADD 40 @@ reg value=23
[ 3.403178] max9271_write_reg: YYJ ADD 40 @@ reg value=24
[ 3.409488] max9271_write_reg: YYJ ADD 40 @@ reg value=25
[ 3.415816] max9271_write_reg: YYJ ADD 40 @@ reg value=26
[ 3.422127] max9271_write_reg: YYJ ADD 40 @@ reg value=27
[ 3.428433] max9271_write_reg: YYJ ADD 40 @@ reg value=30
[ 3.434758] max9271_write_reg: YYJ ADD 40 @@ reg value=31
[ 3.441066] max9271_write_reg: YYJ ADD 40 @@ reg value=32
[ 3.447376] max9271_write_reg: YYJ ADD 40 @@ reg value=33
[ 3.453698] max9271_write_reg: YYJ ADD 40 @@ reg value=34
[ 3.460006] max9271_write_reg: YYJ ADD 40 @@ reg value=35
[ 3.466337] max9271_write_reg: YYJ ADD 40 @@ reg value=36
[ 3.472644] max9271_write_reg: YYJ ADD 40 @@ reg value=37
[ 3.478952] max9271_write_reg: YYJ ADD 40 @@ reg value=3f
[ 3.485273] max9271_write_reg: YYJ ADD 40 @@ reg value=47
[ 3.491583] max9271_write_reg: YYJ ADD 40 @@ reg value=48
[ 3.497898] max9271_write_reg: YYJ ADD 40 @@ reg value=49
[ 3.504216] max9271_write_reg: YYJ ADD 40 @@ reg value=4c
[ 3.510524] max9271_write_reg: YYJ ADD 40 @@ reg value=43
[ 3.516847] max9271_write_reg: YYJ ADD 40 @@ reg value=1
[ 3.523070] max9271_write_reg: YYJ ADD 40 @@ reg value=9
[ 3.529291] max9271_write_reg: YYJ ADD 40 @@ reg value=a
[ 3.535549] max9271_write_reg: YYJ ADD 40 @@ reg value=b
[ 3.541792] max9271_write_reg: YYJ ADD 40 @@ reg value=c
[ 3.557910] max9286_mipi: initialized sensor = 0x04.
[ 3.562980] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.569237] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.575480] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.581814] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.588155] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 4.609934] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.633911] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.640241] max9286_mipi 1-006a: max9286_mipi is found, name max9286_mipi 1-006a
[ 4.647663] YYJ ADD max9286_probe done
[ 4.652583] usbcore: registered new interface driver uvcvideo
[ 4.658352] USB Video Class driver (1.1.1)
[ 4.663891] __power_supply_register: Expected proper parent device for 'battery'
[ 4.671595] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 4.684009] __power_supply_register: Expected proper parent device for 'usb'
[ 4.695092] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 4.702038] device-mapper: uevent: version 1.0.3
[ 4.707219] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[ 4.716444] Bluetooth: HCI UART driver ver 2.3
[ 4.720915] Bluetooth: HCI UART protocol H4 registered
[ 4.726131] Bluetooth: HCI UART protocol BCSP registered
[ 4.731470] Bluetooth: HCI UART protocol ATH3K registered
[ 4.736957] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.743625] Bluetooth: HCI UART protocol Broadcom registered
[ 4.749381] Bluetooth: HCI UART protocol QCA registered
[ 4.754900] bt power gpio is:69
[ 4.758352] rfkill: BT RF going to : on
[ 4.761912] mxc_bt_rfkill driver success loaded
[ 4.762211] mxc_bt_rfkill_reset
[ 4.770775] sdhci: Secure Digital Host Controller Interface driver
[ 4.776984] sdhci: Copyright(c) Pierre Ossman
[ 4.781702] Synopsys Designware Multimedia Card Interface Driver
[ 4.789385] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.843024] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 4.853412] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 4.911697] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 4.927556] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.935683] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 4.941642] caam-snvs 30370000.caam-snvs: violation handlers armed - init state
[ 4.949504] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.965529] mmc0: new HS400 MMC card at address 0001
[ 4.971264] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 4.976336] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 4.982726] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 4.989174] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 4.997832] input: PixArt Lenovo Optical USB Mouse as /devices/platform/usb@38200000/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:17EF:6019.0001/input/input1
[ 5.013217] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo Optical USB Mouse] on usb-xhci-hcd.0.auto-1/input0
[ 5.026381] Alternate GPT is invalid, using primary GPT.
[ 5.026678] usbcore: registered new interface driver usbhid
[ 5.031784] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 5.037385] usbhid: USB HID core driver
[ 5.053756] tcpci 0-0050: Log buffer index 6 is NULL
[ 5.085225] ashmem: initialized
[ 5.096331] usbcore: registered new interface driver snd-usb-audio
[ 5.104021] ak4458 2-0010: 2-0010 supply DVDD not found, using dummy regulator
[ 5.111397] ak4458 2-0010: 2-0010 supply AVDD not found, using dummy regulator
[ 5.119011] ak4458 2-0012: 2-0012 supply DVDD not found, using dummy regulator
[ 5.126358] ak4458 2-0012: 2-0012 supply AVDD not found, using dummy regulator
[ 5.134144] ak4497 2-0011: 2-0011 supply DVDD not found, using dummy regulator
[ 5.141434] ak4497 2-0011: 2-0011 supply AVDD not found, using dummy regulator
[ 5.149404] ak5558 2-0013: 2-0013 supply DVDD not found, using dummy regulator
[ 5.156698] ak5558 2-0013: 2-0013 supply AVDD not found, using dummy regulator
[ 5.198895] imx-wm8524 sound-wm8524: wm8524-hifi <-> 308b0000.sai mapping ok
[ 5.206055] imx-wm8524 sound-wm8524: ASoC: no DMI vendor name!
[ 5.217476] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 30810000.spdif mapping ok
[ 5.225090] imx-spdif sound-spdif: ASoC: no DMI vendor name!
[ 5.234033] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 308a0000.spdif mapping ok
[ 5.241901] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 5.254419] ak4458 2-0010: ASoC: failed to probe component -6
[ 5.260372] imx-ak4458 sound-ak4458: ASoC: failed to instantiate card -6
[ 5.267766] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-6)
[ 5.290239] ak5558 2-0013: ASoC: failed to probe component -6
[ 5.296171] imx-ak5558 sound-ak5558: ASoC: failed to instantiate card -6
[ 5.303494] imx-ak5558 sound-ak5558: snd_soc_register_card failed (-6)
[ 5.310693] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30050000.sai mapping ok
[ 5.317517] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[ 5.325100] NET: Registered protocol family 26
[ 5.329636] u32 classifier
[ 5.332388] Actions configured
[ 5.335874] Netfilter messages via NETLINK v0.30.
[ 5.340884] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.347304] ctnetlink v0.93: registering with nfnetlink.
[ 5.353208] xt_time: kernel timezone is -0000
[ 5.357753] IPv4 over IPsec tunneling driver
[ 5.362597] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.368739] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 5.374623] Initializing XFRM netlink socket
[ 5.379539] NET: Registered protocol family 10
[ 5.385396] Segment Routing with IPv6
[ 5.389152] mip6: Mobile IPv6
[ 5.392155] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.398657] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.405779] NET: Registered protocol family 17
[ 5.410319] NET: Registered protocol family 15
[ 5.414791] can: controller area network core (rev 20170425 abi 9)
[ 5.421110] NET: Registered protocol family 29
[ 5.425580] can: raw protocol (rev 20170425)
[ 5.429957] can: broadcast manager protocol (rev 20170425 t)
[ 5.435660] can: netlink gateway (rev 20170425) max_hops=1
[ 5.441552] Bluetooth: RFCOMM TTY layer initialized
[ 5.446459] Bluetooth: RFCOMM socket layer initialized
[ 5.451706] Bluetooth: RFCOMM ver 1.11
[ 5.455481] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.460870] Bluetooth: BNEP filters: protocol multicast
[ 5.466133] Bluetooth: BNEP socket layer initialized
[ 5.471175] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.477116] Bluetooth: HIDP socket layer initialized
[ 5.482170] lib80211: common routines for IEEE802.11 drivers
[ 5.488231] 9pnet: Installing 9P2000 support
[ 5.495591] registered taskstats version 1
[ 5.511738] cpu cpu0: registered imx8mq-cpufreq
[ 5.531088] galcore: clk_get 2d core clock failed, disable 2d/vg!
[ 5.537475] Galcore version 6.2.4.190076
[ 5.634245] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 1
[ 5.643689] update hantro voltage from 900 mV to 1000 mV
[ 5.649361] hantrodec: module inserted. Major = 509
[ 5.656888] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2019-10-29 06:01:01 UTC (1572328861)
[ 5.667635] VSD_3V3: disabling
[ 5.670764] gpio_dvfs: disabling
[ 5.674015] VGEN1: disabling
[ 5.678217] VGEN6: disabling
[ 5.681918] ALSA device list:
[ 5.684900] #0: wm8524-audio
[ 5.688023] #1: imx-spdif
[ 5.690831] #2: imx-hdmi-arc
[ 5.693897] #3: imx-audio-hdmi
[ 5.697314] device-mapper: init: attempting early device configuration.
[ 5.704800] device-mapper: init: adding target '0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 fec_roots 2 fec_blocks 455050 fec_start 455050'
[ 5.745402] device-mapper: init: dm-0 is ready
[ 5.768269] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 5.775356] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
[ 5.782789] devtmpfs: mounted
[ 5.787421] Freeing unused kernel memory: 5504K
[ 5.823074] init: init first stage started!
[ 5.828184] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 5.838386] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[ 5.884536] init: [libfs_mgr]Returning avb_handle with status: 0
[ 5.895894] init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/30b40000.usdhc/by-name/vendor_a /dev/block/platform/30b40000.usdhc/by-name/vendor_a 4096 4096 64481 64481 sha1 51806766da39076dff37f6ba052ba9c97bb90718 9dcbde58e29f0cf7ca3f2b33cfdfb75a9d9fb268 10 use_fec_from_device /dev/block/platform/30b40000.usdhc/by-name/vendor_a fec_roots 2 fec_blocks 64990 fec_start 64990 restart_on_corruption ignore_zero_blocks'
[ 5.954632] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 5.964030] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
[ 5.973000] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 5.979998] init: Loading SELinux policy
[ 6.010537] SELinux: Class process2 not defined in policy.
[ 6.016613] SELinux: Class infiniband_pkey not defined in policy.
[ 6.022832] SELinux: Class infiniband_endport not defined in policy.
[ 6.029287] SELinux: the above unknown classes and permissions will be denied
[ 6.036457] SELinux: policy capability network_peer_controls=1
[ 6.042386] SELinux: policy capability open_perms=1
[ 6.047358] SELinux: policy capability extended_socket_class=1
[ 6.053285] SELinux: policy capability always_check_network=0
[ 6.059126] SELinux: policy capability cgroup_seclabel=0
[ 6.064532] SELinux: policy capability nnp_nosuid_transition=0
[ 6.164115] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 6.164115]
[ 6.164443] audit: type=1403 audit(1572328862.003:2): policy loaded auid=4294967295 ses=4294967295
[ 6.182910] audit: type=1404 audit(1572328862.015:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 6.207400] selinux: SELinux: Loaded file_contexts
[ 6.207400]
[ 6.217528] init: init second stage started!
[ 6.242086] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 6.254017] selinux: SELinux: Loaded file_contexts
[ 6.254017]
[ 6.260321] init: Running restorecon...
[ 6.272000] init: waitid failed: No child processes
[ 6.281716] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
[ 6.299788] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[ 6.308853] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2348
[ 6.316420] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2349
[ 6.323532] init: Parsing file /init.rc...
[ 6.425882] audit: type=1400 audit(1572328862.263:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.429565] ueventd: ueventd started!
[ 6.443580] audit: type=1400 audit(1572328862.263:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.450044] selinux: SELinux: Loaded file_contexts
[ 6.450044]
[ 6.464929] audit: type=1400 audit(1572328862.263:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.471186] ueventd: Parsing file /ueventd.rc...
[ 6.488775] audit: type=1400 audit(1572328862.263:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.511068] audit: type=1400 audit(1572328862.331:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.528725] audit: type=1400 audit(1572328862.331:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.546432] audit: type=1400 audit(1572328862.331:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.564155] audit: type=1400 audit(1572328862.331:11): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.564740] ueventd: Parsing file /vendor/ueventd.rc...
[ 6.588615] ueventd: Parsing file /odm/ueventd.rc...
[ 6.593688] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[ 6.603620] ueventd: Parsing file /ueventd.freescale.rc...
[ 6.609223] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[ 6.634209] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin'
[ 6.651491] ueventd: loading /devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin took 17ms
[ 6.666305] imx-sdma 30bd0000.sdma: loaded firmware 4.4
[ 6.677393] imx-sdma 302c0000.sdma: loaded firmware 4.4
[ 6.816424] Registered swp emulation handler
[ 6.827665] watchdogd: watchdogd started (interval 10, margin 20)!
[ 6.834419] Console: switching to colour dummy device 80x25
[ 6.859424] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 6.994078] wlan: loading driver v4.5.23.1
[ 7.023768] EXT4-fs (mmcblk0p12): recovery complete
[ 7.029320] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 8.158965] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 8.158965]
[ 8.165203] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 8.165203]
[ 8.172546] e2fsck: Pass 2: Checking directory structure
[ 8.172546]
[ 8.179516] e2fsck: Pass 3: Checking directory connectivity
[ 8.179516]
[ 8.186603] e2fsck: Pass 4: Checking reference counts
[ 8.186603]
[ 8.193204] e2fsck: Pass 5: Checking group summary information
[ 8.193204]
[ 8.200545] e2fsck: /dev/block/by-name/userdata: 1609/581632 files (2.5% non-contiguous), 74026/2326528 blocks
[ 8.200545]
[ 8.218226] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 8.233280] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 8.278611] zram0: detected capacity change from 0 to 314572800
[ 8.300265] logd.auditd: start
[ 8.303392] logd.klogd: 8169494544
[ 8.308548] mkswap: Swapspace size: 307196k, UUID=13c4500a-679c-4cbf-ad3c-73a762312205
[ 8.317325] Adding 307196k swap on /dev/block/zram0. Priority:-2 extents:1 across:307196k SS
[ 8.349376] type=1400 audit(1572328864.167:38): avc: denied { getattr } for pid=2348 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.370540] type=1400 audit(1572328864.167:38): avc: denied { getattr } for pid=2348 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.391047] type=1400 audit(1572328864.167:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 8.668205] update_verifier: Started with arg 1: nonencrypted
[ 8.678994] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 8.685476] update_verifier: Leaving update_verifier.
[ 8.737995] logd.daemon: reinit
[ 8.745052] rfkill: BT RF going to : off
[ 8.758737] Mass Storage Function, version: 2009/09/11
[ 8.763988] LUN: removable file: (no medium)
[ 8.772149] using random self ethernet address
[ 8.776659] using random host ethernet address
[ 8.782963] file system registered
[ 8.954124] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 9.069475] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
evk_8mq:/ $ [ 9.635630] read descriptors
[ 9.663952] read strings
[ 10.522422] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.552845] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.583355] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.746834] android_work: sent uevent USB_STATE=CONNECTED
[ 10.774506] configfs-gadget gadget: high-speed config #1: b
[ 10.796263] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.283640] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[ 11.821088] random: crng init done
[ 12.192146] init: Service 'early_init_sh' (pid 2351) exited with status 0
[ 13.127211] type=1400 audit(1572328866.775:572): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 13.136767] audit_log_lost: 30 callbacks suppressed
[ 13.136772] audit: audit_lost=518 audit_rate_limit=5 audit_backlog_limit=64
[ 13.146682] type=1400 audit(1572328868.967:573): avc: denied { dac_read_search } for pid=2998 comm="Binder:2998_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
[ 13.151588] audit: rate limit exceeded
[ 13.363988] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.376169] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.398436] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.562642] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
[ 14.113571] read descriptors
[ 14.116690] read strings
[ 14.119457] read descriptors
[ 14.122391] read strings
[ 14.142210] acc_open
[ 14.144416] acc_release
[ 14.290501] fec 30be0000.ethernet eth0: Unable to connect to phy
[ 14.383721] type=1400 audit(1572328868.975:578): avc: denied { dac_read_search } for pid=2998 comm="Binder:2998_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.404980] type=1400 audit(1572328870.223:2349): avc: denied { dac_read_search } for pid=3242 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.471906] type=1400 audit(1572328870.223:2352): avc: denied { dac_read_search } for pid=3242 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.473838] audit: audit_lost=2288 audit_rate_limit=5 audit_backlog_limit=64
[ 14.497378] type=1400 audit(1572328870.311:2353): avc: denied { dac_read_search } for pid=3259 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.503368] audit: rate limit exceeded
[ 14.527944] sdcardfs version 2.0
[ 14.531435] sdcardfs: dev_name -> /data/media
[ 14.535971] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[ 14.547591] sdcardfs: mnt -> ffff80005e2b7520
[ 14.553851] sdcardfs: mounted on top of /data/media type ext4
[ 14.560761] Remount options were mask=23,gid=9997 for vfsmnt ffff80005fc5c720.
[ 14.568419] sdcardfs : options - debug:1
[ 14.572488] sdcardfs : options - gid:9997
[ 14.576630] sdcardfs : options - mask:23
[ 14.580875] Remount options were mask=7,gid=9997 for vfsmnt ffff80005fc5d360.
[ 14.588258] sdcardfs : options - debug:1
[ 14.592234] sdcardfs : options - gid:9997
[ 14.596305] sdcardfs : options - mask:7
[ 15.673194] type=1400 audit(1572328870.311:2353): avc: denied { dac_read_search } for pid=3259 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.696429] type=1400 audit(1572328871.511:2381): avc: denied { read } for pid=3121 comm="system_server" name="state" dev="sysfs" ino=21950 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 15.755847] type=1400 audit(1572328871.511:2381): avc: denied { read } for pid=3121 comm="system_server" name="state" dev="sysfs" ino=21950 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 15.793552] type=1400 audit(1572328871.595:2382): avc: denied { dac_read_search } for pid=3558 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 17.615536] init: Service 'bootanim' (pid 3101) exited with status 0
[ 17.641290] init: processing action (sys.boot_completed=1) from (/init.rc:719)
[ 17.648845] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:20)
[ 17.662966] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:27)
[ 17.673570] type=1400 audit(1572328871.619:2385): avc: denied { dac_read_search } for pid=3558 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 17.678270] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
[ 17.698034] audit: audit_lost=2315 audit_rate_limit=5 audit_backlog_limit=64
[ 17.702204] type=1400 audit(1572328873.511:2386): avc: denied { dac_read_search } for pid=2883 comm="Binder:2883_2" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 17.706866] init: starting service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[ 17.711922] audit: rate limit exceeded
[ 17.731894] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 17.831925] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 70ms and succeeded
[ 17.883502] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[ 17.883502]
[ 17.884173] init: Service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)' (pid 3632) exited with status 0
[ 18.995199] audit: audit_lost=3550 audit_rate_limit=5 audit_backlog_limit=64
[ 19.005943] audit: rate limit exceeded
[ 24.743806] type=1400 audit(1572328874.835:3630): avc: denied { dac_read_search } for pid=3752 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 24.761534] type=1400 audit(1572328880.583:3646): avc: denied { dac_read_search } for pid=3846 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 24.851049] audit: audit_lost=3565 audit_rate_limit=5 audit_backlog_limit=64
[ 24.851444] type=1400 audit(1572328880.587:3649): avc: denied { dac_read_search } for pid=3846 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 24.858161] audit: rate limit exceeded
[ 24.879172] type=1400 audit(1572328880.691:3650): avc: denied { dac_read_search } for pid=3869 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.812131] type=1400 audit(1572328880.691:3650): avc: denied { dac_read_search } for pid=3869 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.829876] type=1400 audit(1572328881.651:3678): avc: denied { dac_read_search } for pid=4004 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
U-Boot SPL 2018.03 (Oct 29 2019 - 11:48:53 +0800)
Training PASS
Training PASS
Training PASS
Training PASS
Normal Boot
U-Boot 2018.03 (Oct 29 2019 - 11:48:53 +0800)
CPU: Industrial temperature grade (-40C to 105C) at 74C
Reset cause: POR
DRAM: 3 GiB
Failed (-5)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
Net: No ethernet found.
Fastboot: Normal
Normal Boot
Starting kernel ...
[ 0.000000] Linux version 4.14.98-00001-gde6b135-dirty (neolix@neolix-PowerEdge-R420) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #15 SMP PREEMPT Tue Oct 29 11:50:29 CST 2019
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200 init=/init androidboot.gui_resolution=1080p androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.fbTileSupport=enable cma=1280M androidboot.primary_display=imx-drm firmware_class.path=/vendor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.wifivendor=bcm buildvariant=userdebug androidboot.serialno=152059d6f32ef628 androidboot.btmacaddr=15:20:59:d6:f3:2e androidboot.soc_type=imx8mq androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:4839,KL:0,KD:0,AVB:2258,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_ze
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.008872] system counter timer init
[ 0.031071] Console: colour dummy device 80x25
[ 0.034491] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044749] pid_max: default: 32768 minimum: 301
[ 0.049446] Security Framework initialized
[ 0.053469] SELinux: Initializing.
[ 0.058526] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.064942] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.071300] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.077994] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.101209] ASID allocator initialised with 32768 entries
[ 0.109209] Hierarchical SRCU implementation.
[ 0.117785] Cannot find MU entry in device tree
[ 0.119612] CPU identified as i.MX8MQ, silicon rev 2.1
[ 0.125573] EFI services will not be available.
[ 0.137188] smp: Bringing up secondary CPUs ...
[ 0.165375] Detected VIPT I-cache on CPU1
[ 0.165435] CPU1: Booted secondary processor [410fd034]
[ 0.193440] Detected VIPT I-cache on CPU2
[ 0.193482] CPU2: Booted secondary processor [410fd034]
[ 0.221572] CPU3: Booted secondary processor [410fd034]
[ 0.221800] smp: Brought up 1 node, 4 CPUs
[ 0.271459] SMP: Total of 4 processors activated.
[ 0.276161] CPU features: detected feature: GIC system register CPU interface
[ 0.283321] CPU features: detected feature: 32-bit EL0 Support
[ 0.289153] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.328431] CPU: All CPU(s) started at EL2
[ 0.329848] alternatives: patching kernel code
[ 0.334507] CPU3: update max cpu_capacity 1024
[ 0.339693] devtmpfs: initialized
[ 0.341636] CPU1: update max cpu_capacity 1024
[ 0.353041] Registered cp15_barrier emulation handler
[ 0.355314] Registered setend emulation handler
[ 0.360393] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369599] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.416031] pinctrl core: initialized pinctrl subsystem
[ 0.420163] DMI not present or invalid.
[ 0.422794] NET: Registered protocol family 16
[ 0.428955] schedtune: configured to support 5 boost groups
[ 0.436347] cpuidle: using governor menu
[ 0.439893] vdso: 2 pages (1 code @ ffff000009007000, 1 data @ ffff000009c54000)
[ 0.444912] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.459138] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.465003] Serial: AMBA PL011 UART driver
[ 0.467192] imx rpmsg driver is registered.
[ 0.481501] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.499249] MU is ready for cross core communication!
[ 0.503431] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.562384] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.580253] ACPI: Interpreter disabled.
[ 0.584236] vgaarb: loaded
[ 0.584787] SCSI subsystem initialized
[ 0.589041] usbcore: registered new interface driver usbfs
[ 0.593456] usbcore: registered new interface driver hub
[ 0.599052] usbcore: registered new device driver usb
[ 0.605076] i2c i2c-0: IMX I2C adapter registered
[ 0.608443] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.614436] i2c i2c-1: IMX I2C adapter registered
[ 0.618462] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.624806] i2c i2c-2: IMX I2C adapter registered
[ 0.628550] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.635435] media: Linux media interface: v0.10
[ 0.638487] Linux video capture interface: v2.00
[ 0.643147] pps_core: LinuxPPS API ver. 1 registered
[ 0.647989] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.657157] PTP clock support registered
[ 0.661543] EDAC MC: Ver: 3.0.0
[ 0.664648] dmi: Firmware registration failed.
[ 0.669302] Advanced Linux Sound Architecture Driver Initialized.
[ 0.675471] Bluetooth: Core ver 2.22
[ 0.678345] NET: Registered protocol family 31
[ 0.682724] Bluetooth: HCI device and connection manager initialized
[ 0.689150] Bluetooth: HCI socket layer initialized
[ 0.693973] Bluetooth: L2CAP socket layer initialized
[ 0.699048] Bluetooth: SCO socket layer initialized
[ 0.707381] clocksource: Switched to clocksource arch_sys_counter
[ 0.774902] VFS: Disk quotas dquot_6.6.0
[ 0.776054] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.783136] pnp: PnP ACPI: disabled
[ 0.797849] NET: Registered protocol family 2
[ 0.800037] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.807094] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.814010] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.819887] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.825975] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.832468] NET: Registered protocol family 1
[ 0.839693] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.845268] kvm [1]: 8-bit VMID
[ 0.849092] kvm [1]: GICv3: no GICV resource entry
[ 0.852548] kvm [1]: disabling GICv2 emulation
[ 0.857166] kvm [1]: GIC system register CPU interface enabled
[ 0.863229] kvm [1]: vgic interrupt IRQ1
[ 0.867277] kvm [1]: Hyp mode initialized successfully
[ 0.880343] audit: initializing netlink subsys (disabled)
[ 0.883157] audit: type=2000 audit(0.739:1): state=initialized audit_enabled=0 res=1
[ 0.884034] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.910060] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.913365] Registering sdcardfs 0.1
[ 0.917072] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.923502] fuse init (API version 7.26)
[ 0.927124] 9p: Installing v9fs 9p2000 file system support
[ 0.944835] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.949471] io scheduler noop registered
[ 0.953507] io scheduler cfq registered (default)
[ 0.958099] io scheduler mq-deadline registered
[ 0.962572] io scheduler kyber registered
[ 0.991110] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 0.997704] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 1.005215] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.015957] mxs-dma 33000000.dma-apbh: initialized
[ 1.021024] Bus freq driver module loaded
[ 1.024146] Config NOC for GPU to 0x80000600
[ 1.026452] Config NOC for VPU and CPU
[ 1.033885] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.037766] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.042470] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.059927] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.066650] SuperH (H)SCI(F) driver initialized
[ 1.069397] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 44, base_baud = 1562500) is a IMX
[ 1.080109] console [ttymxc0] enabled
[ 1.084582] bootconsole [ec_imx6q0] disabled
[ 1.094062] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 45, base_baud = 5000000) is a IMX
[ 1.105804] msm_serial: driver initialized
[ 1.126352] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.132997] [drm] No driver support for vblank timestamp query.
[ 1.139152] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 1.146812] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 1.155430] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
[ 1.162187] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
[ 1.172182] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
[ 1.182981] [drm] VCO frequency is 5940000
[ 1.187156] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
[ 1.218903] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.226167] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 1.232400] [drm] Failed to initialize HDCP
[ 1.238281] [drm] hdmi-audio-codec driver bound to HDMI
[ 1.243544] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[ 1.275067] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 1.287183] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 222750, color depth is 12-bit.
[ 1.287193] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (12-bit). Settings found in row 18
[ 1.287198] [drm] VCO frequency is 4455000
[ 1.287204] [drm] VCO frequency (4455000 KHz) is supported. Settings found in row 11
[ 1.301089] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.989248] Console: switching to colour frame buffer device 240x67
[ 2.083335] imx-drm display-subsystem: fb0: frame buffer device
[ 2.090089] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.112167] brd: module loaded
[ 2.123523] loop: module loaded
[ 2.127733] zram: Added device: zram0
[ 2.139978] fsl-quadspi 30bb0000.qspi: unrecognized JEDEC id bytes: 00, 00, 00
[ 2.147244] fsl-quadspi 30bb0000.qspi: Freescale QuadSPI probe failed
[ 2.153830] fsl-quadspi: probe of 30bb0000.qspi failed with error -2
[ 2.160658] slram: not enough parameters.
[ 2.171121] libphy: Fixed MDIO Bus: probed
[ 2.177226] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 2.184016] tun: Universal TUN/TAP device driver, 1.6
[ 2.189662] CAN device driver interface
[ 2.196591] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 2.206405] pps pps0: new PPS source ptp0
[ 2.215468] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 2.225498] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 72:3f:96:ab:32:d3
[ 2.237704] libphy: fec_enet_mii_bus: probed
[ 2.242102] mdio_bus 30be0000.ethernet-1: MDIO device at address 0 is missing.
[ 2.250576] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.257961] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.263873] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.269999] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.277038] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.282785] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.290707] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.297617] sky2: driver version 1.30
[ 2.302377] PPP generic driver version 2.4.2
[ 2.307097] PPP BSD Compression module registered
[ 2.311880] PPP Deflate Compression module registered
[ 2.316972] PPP MPPE Compression module registered
[ 2.322026] usbcore: registered new interface driver asix
[ 2.327641] usbcore: registered new interface driver ax88179_178a
[ 2.333963] usbcore: registered new interface driver cdc_ether
[ 2.339981] usbcore: registered new interface driver net1080
[ 2.345873] usbcore: registered new interface driver cdc_subset
[ 2.351972] usbcore: registered new interface driver zaurus
[ 2.357797] usbcore: registered new interface driver cdc_ncm
[ 2.375101] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.381721] ehci-pci: EHCI PCI platform driver
[ 2.386377] ehci-platform: EHCI generic platform driver
[ 2.392012] ehci-orion: EHCI orion driver
[ 2.396312] ehci-exynos: EHCI EXYNOS driver
[ 2.400842] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 2.406697] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.412970] ohci-pci: OHCI PCI platform driver
[ 2.417597] ohci-platform: OHCI generic platform driver
[ 2.423210] ohci-exynos: OHCI EXYNOS driver
[ 2.428240] Can't support > 32 bit dma.
[ 2.432200] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.437737] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.452843] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000001010810
[ 2.462309] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x38200000
[ 2.468585] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.475408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.482708] usb usb1: Product: xHCI Host Controller
[ 2.487620] usb usb1: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.495015] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.500953] hub 1-0:1.0: USB hub found
[ 2.504775] hub 1-0:1.0: 1 port detected
[ 2.509286] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.514807] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.522509] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.529345] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.536231] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.543473] usb usb2: Product: xHCI Host Controller
[ 2.548430] usb usb2: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.555772] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.561394] hub 2-0:1.0: USB hub found
[ 2.565194] hub 2-0:1.0: 1 port detected
[ 2.570624] usbcore: registered new interface driver usb-storage
[ 2.576836] usbcore: registered new interface driver usb_ehset_test
[ 2.588502] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.600706] usbcore: registered new interface driver xpad
[ 2.606373] usbcore: registered new interface driver usb_acecad
[ 2.612564] usbcore: registered new interface driver aiptek
[ 2.618382] usbcore: registered new interface driver gtco
[ 2.623977] usbcore: registered new interface driver hanwang
[ 2.629875] usbcore: registered new interface driver kbtab
[ 2.639738] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 2.650269] i2c /dev entries driver
[ 2.662189] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 2.668424] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 2.674180] random: fast init done
[ 2.677722] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at /mipi_csi1@30a70000/port/endpoint1 XXX found
[ 2.687827] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 2.695671] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 2.701870] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 2.707663] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at /mipi_csi2@30b60000/port/endpoint1 XXX found
[ 2.717821] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 1, name: mxc-mipi-csi2.1
[ 2.725761] max9286_probe: YYJ ADD 1 @@
[ 2.729965] max9286_read_reg: YYJ ADD 41 @@ reg value=1e
[ 2.736470] max9286_hardware_preinit: YYJ ADD 2 @@
[ 2.741457] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 2.747886] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 2.771405] max9286_write_reg: YYJ ADD 42 @@ reg value=3f
[ 2.787402] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.803400] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 2.819400] max9271_write_reg: YYJ ADD 40 @@ reg value=40
[ 2.835400] max9271_write_reg: YYJ ADD 40 @@ reg value=8
[ 2.841632] max9271_write_reg: YYJ ADD 40 @@ reg value=97
[ 2.855411] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2.859401] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.883402] max9286_write_reg: YYJ ADD 42 @@ reg value=12
[ 2.889725] max9286_write_reg: YYJ ADD 42 @@ reg value=1
[ 2.895948] max9286_write_reg: YYJ ADD 42 @@ reg value=63
[ 2.902264] max9286_write_reg: YYJ ADD 42 @@ reg value=64
[ 2.908585] max9286_write_reg: YYJ ADD 42 @@ reg value=8
[ 2.914806] max9286_write_reg: YYJ ADD 42 @@ reg value=c
[ 2.921112] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.019411] usb 1-1: New USB device found, idVendor=17ef, idProduct=6019
[ 3.026136] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.033291] usb 1-1: Product: Lenovo Optical USB Mouse
[ 3.038446] usb 1-1: Manufacturer: PixArt
[ 3.131400] max9286_read_reg: YYJ ADD 41 @@ reg value=49
[ 3.139606] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 3.145513] max9286_data->sensor_num=80
[ 3.145518] max9286_mipi: reg = 0x80.
[ 3.153060] max9286_mipi: sensor number = 1.
[ 3.157351] YYJ v4l2_i2c_subdev_init sd->name =max9286_mipi 1-006a
[ 3.163725] YYJ add --->media_entity_pads_init entity->num_pads=4
[ 3.169980] YYJ ADD max9286_probe media_entity_pads_init retval=0
[ 3.176287] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: max9286_mipi 1-006a
[ 3.185177] YYJ ADD max9286_probe retval=0
[ 3.189380] max9286_mipi 1-006a: YYJ ADD 4 In max9286_hardware_init()
[ 3.196013] max9286_mipi 1-006a: In max9286_hardware_init()
[ 3.201600] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 3.207827] max9286_camera_reorder: YYJ ADD 3 @@
[ 3.212641] max9286_write_reg: YYJ ADD 42 @@ reg value=b
[ 3.218870] max9286_write_reg: YYJ ADD 42 @@ reg value=69
[ 3.225192] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.259402] max9271_write_reg: YYJ ADD 40 @@ reg value=7
[ 3.291400] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.297621] max9271_write_reg: YYJ ADD 40 @@ reg value=0
[ 3.319401] max9271_write_reg: YYJ ADD 40 @@ reg value=20
[ 3.325698] max9271_write_reg: YYJ ADD 40 @@ reg value=21
[ 3.332070] max9271_write_reg: YYJ ADD 40 @@ reg value=22
[ 3.338395] max9271_write_reg: YYJ ADD 40 @@ reg value=23
[ 3.344703] max9271_write_reg: YYJ ADD 40 @@ reg value=24
[ 3.351010] max9271_write_reg: YYJ ADD 40 @@ reg value=25
[ 3.357333] max9271_write_reg: YYJ ADD 40 @@ reg value=26
[ 3.363645] max9271_write_reg: YYJ ADD 40 @@ reg value=27
[ 3.369970] max9271_write_reg: YYJ ADD 40 @@ reg value=30
[ 3.376279] max9271_write_reg: YYJ ADD 40 @@ reg value=31
[ 3.382587] max9271_write_reg: YYJ ADD 40 @@ reg value=32
[ 3.388912] max9271_write_reg: YYJ ADD 40 @@ reg value=33
[ 3.395221] max9271_write_reg: YYJ ADD 40 @@ reg value=34
[ 3.401538] max9271_write_reg: YYJ ADD 40 @@ reg value=35
[ 3.407862] max9271_write_reg: YYJ ADD 40 @@ reg value=36
[ 3.414170] max9271_write_reg: YYJ ADD 40 @@ reg value=37
[ 3.420494] max9271_write_reg: YYJ ADD 40 @@ reg value=3f
[ 3.426801] max9271_write_reg: YYJ ADD 40 @@ reg value=47
[ 3.433109] max9271_write_reg: YYJ ADD 40 @@ reg value=48
[ 3.439435] max9271_write_reg: YYJ ADD 40 @@ reg value=49
[ 3.445743] max9271_write_reg: YYJ ADD 40 @@ reg value=4c
[ 3.452060] max9271_write_reg: YYJ ADD 40 @@ reg value=43
[ 3.458380] max9271_write_reg: YYJ ADD 40 @@ reg value=1
[ 3.464602] max9271_write_reg: YYJ ADD 40 @@ reg value=9
[ 3.470838] max9271_write_reg: YYJ ADD 40 @@ reg value=a
[ 3.477081] max9271_write_reg: YYJ ADD 40 @@ reg value=b
[ 3.483324] max9271_write_reg: YYJ ADD 40 @@ reg value=c
[ 3.499400] max9286_mipi: initialized sensor = 0x04.
[ 3.504483] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.510725] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.516969] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.523314] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.529645] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 4.555420] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.579401] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.585742] max9286_mipi 1-006a: max9286_mipi is found, name max9286_mipi 1-006a
[ 4.593167] YYJ ADD max9286_probe done
[ 4.598495] usbcore: registered new interface driver uvcvideo
[ 4.604281] USB Video Class driver (1.1.1)
[ 4.610215] __power_supply_register: Expected proper parent device for 'battery'
[ 4.617972] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 4.630434] __power_supply_register: Expected proper parent device for 'usb'
[ 4.643261] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 4.651221] device-mapper: uevent: version 1.0.3
[ 4.656600] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[ 4.665698] Bluetooth: HCI UART driver ver 2.3
[ 4.670246] Bluetooth: HCI UART protocol H4 registered
[ 4.675405] Bluetooth: HCI UART protocol BCSP registered
[ 4.680792] Bluetooth: HCI UART protocol ATH3K registered
[ 4.686225] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.692955] Bluetooth: HCI UART protocol Broadcom registered
[ 4.698637] Bluetooth: HCI UART protocol QCA registered
[ 4.704237] bt power gpio is:69
[ 4.707616] rfkill: BT RF going to : on
[ 4.711408] mxc_bt_rfkill driver success loaded
[ 4.711475] mxc_bt_rfkill_reset
[ 4.720133] sdhci: Secure Digital Host Controller Interface driver
[ 4.726392] sdhci: Copyright(c) Pierre Ossman
[ 4.731120] Synopsys Designware Multimedia Card Interface Driver
[ 4.739024] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.796019] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 4.804939] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 4.861257] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 4.876046] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.884334] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 4.890247] caam-snvs 30370000.caam-snvs: violation handlers armed - init state
[ 4.898365] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.909670] mmc0: new HS400 MMC card at address 0001
[ 4.915447] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 4.920481] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 4.926924] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 4.933321] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 4.941998] input: PixArt Lenovo Optical USB Mouse as /devices/platform/usb@38200000/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:17EF:6019.0001/input/input1
[ 4.946167] Alternate GPT is invalid, using primary GPT.
[ 4.957520] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo Optical USB Mouse] on usb-xhci-hcd.0.auto-1/input0
[ 4.962097] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.975311] usbcore: registered new interface driver usbhid
[ 4.987491] usbhid: USB HID core driver
[ 4.999587] tcpci 0-0050: Log buffer index 6 is NULL
[ 5.030590] ashmem: initialized
[ 5.041482] usbcore: registered new interface driver snd-usb-audio
[ 5.049092] ak4458 2-0010: 2-0010 supply DVDD not found, using dummy regulator
[ 5.056445] ak4458 2-0010: 2-0010 supply AVDD not found, using dummy regulator
[ 5.064036] ak4458 2-0012: 2-0012 supply DVDD not found, using dummy regulator
[ 5.071403] ak4458 2-0012: 2-0012 supply AVDD not found, using dummy regulator
[ 5.079189] ak4497 2-0011: 2-0011 supply DVDD not found, using dummy regulator
[ 5.086485] ak4497 2-0011: 2-0011 supply AVDD not found, using dummy regulator
[ 5.094430] ak5558 2-0013: 2-0013 supply DVDD not found, using dummy regulator
[ 5.101716] ak5558 2-0013: 2-0013 supply AVDD not found, using dummy regulator
[ 5.142946] imx-wm8524 sound-wm8524: wm8524-hifi <-> 308b0000.sai mapping ok
[ 5.150035] imx-wm8524 sound-wm8524: ASoC: no DMI vendor name!
[ 5.161376] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 30810000.spdif mapping ok
[ 5.169040] imx-spdif sound-spdif: ASoC: no DMI vendor name!
[ 5.178142] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 308a0000.spdif mapping ok
[ 5.186006] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 5.199063] ak4458 2-0010: ASoC: failed to probe component -6
[ 5.205073] imx-ak4458 sound-ak4458: ASoC: failed to instantiate card -6
[ 5.212434] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-6)
[ 5.235266] ak5558 2-0013: ASoC: failed to probe component -6
[ 5.241195] imx-ak5558 sound-ak5558: ASoC: failed to instantiate card -6
[ 5.248520] imx-ak5558 sound-ak5558: snd_soc_register_card failed (-6)
[ 5.255706] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30050000.sai mapping ok
[ 5.262470] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[ 5.270219] NET: Registered protocol family 26
[ 5.274699] u32 classifier
[ 5.277423] Actions configured
[ 5.280849] Netfilter messages via NETLINK v0.30.
[ 5.285856] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.292265] ctnetlink v0.93: registering with nfnetlink.
[ 5.298217] xt_time: kernel timezone is -0000
[ 5.302765] IPv4 over IPsec tunneling driver
[ 5.307605] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.313667] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 5.319635] Initializing XFRM netlink socket
[ 5.324416] NET: Registered protocol family 10
[ 5.330374] Segment Routing with IPv6
[ 5.334126] mip6: Mobile IPv6
[ 5.337186] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.343632] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.350747] NET: Registered protocol family 17
[ 5.355283] NET: Registered protocol family 15
[ 5.359747] can: controller area network core (rev 20170425 abi 9)
[ 5.366050] NET: Registered protocol family 29
[ 5.370517] can: raw protocol (rev 20170425)
[ 5.374862] can: broadcast manager protocol (rev 20170425 t)
[ 5.380570] can: netlink gateway (rev 20170425) max_hops=1
[ 5.386575] Bluetooth: RFCOMM TTY layer initialized
[ 5.391480] Bluetooth: RFCOMM socket layer initialized
[ 5.396709] Bluetooth: RFCOMM ver 1.11
[ 5.400484] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.405869] Bluetooth: BNEP filters: protocol multicast
[ 5.411115] Bluetooth: BNEP socket layer initialized
[ 5.416154] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.422093] Bluetooth: HIDP socket layer initialized
[ 5.427130] lib80211: common routines for IEEE802.11 drivers
[ 5.433180] 9pnet: Installing 9P2000 support
[ 5.440590] registered taskstats version 1
[ 5.456596] cpu cpu0: registered imx8mq-cpufreq
[ 5.465895] galcore: clk_get 2d core clock failed, disable 2d/vg!
[ 5.472219] Galcore version 6.2.4.190076
[ 5.578947] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 1
[ 5.588689] update hantro voltage from 900 mV to 1000 mV
[ 5.594599] hantrodec: module inserted. Major = 509
[ 5.603338] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2019-10-29 06:02:14 UTC (1572328934)
[ 5.614141] VSD_3V3: disabling
[ 5.617211] gpio_dvfs: disabling
[ 5.620462] VGEN1: disabling
[ 5.625182] VGEN6: disabling
[ 5.629910] ALSA device list:
[ 5.632895] #0: wm8524-audio
[ 5.635962] #1: imx-spdif
[ 5.638758] #2: imx-hdmi-arc
[ 5.641844] #3: imx-audio-hdmi
[ 5.645264] device-mapper: init: attempting early device configuration.
[ 5.656652] device-mapper: init: adding target '0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 fec_roots 2 fec_blocks 455050 fec_start 455050'
[ 5.696361] device-mapper: init: dm-0 is ready
[ 5.720339] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 5.727432] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
[ 5.734804] devtmpfs: mounted
[ 5.739453] Freeing unused kernel memory: 5504K
[ 5.770759] init: init first stage started!
[ 5.775857] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 5.786644] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[ 5.833066] init: [libfs_mgr]Returning avb_handle with status: 0
[ 5.844461] init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/30b40000.usdhc/by-name/vendor_a /dev/block/platform/30b40000.usdhc/by-name/vendor_a 4096 4096 64481 64481 sha1 51806766da39076dff37f6ba052ba9c97bb90718 9dcbde58e29f0cf7ca3f2b33cfdfb75a9d9fb268 10 use_fec_from_device /dev/block/platform/30b40000.usdhc/by-name/vendor_a fec_roots 2 fec_blocks 64990 fec_start 64990 restart_on_corruption ignore_zero_blocks'
[ 5.905045] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 5.914430] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
[ 5.923422] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 5.930464] init: Loading SELinux policy
[ 5.961564] SELinux: Class process2 not defined in policy.
[ 5.967671] SELinux: Class infiniband_pkey not defined in policy.
[ 5.973862] SELinux: Class infiniband_endport not defined in policy.
[ 5.980314] SELinux: the above unknown classes and permissions will be denied
[ 5.987482] SELinux: policy capability network_peer_controls=1
[ 5.993411] SELinux: policy capability open_perms=1
[ 5.998383] SELinux: policy capability extended_socket_class=1
[ 6.004310] SELinux: policy capability always_check_network=0
[ 6.010151] SELinux: policy capability cgroup_seclabel=0
[ 6.015558] SELinux: policy capability nnp_nosuid_transition=0
[ 6.113155] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 6.113155]
[ 6.113481] audit: type=1403 audit(1572328935.007:2): policy loaded auid=4294967295 ses=4294967295
[ 6.131928] audit: type=1404 audit(1572328935.015:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 6.159795] selinux: SELinux: Loaded file_contexts
[ 6.159795]
[ 6.170324] init: init second stage started!
[ 6.195545] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 6.207447] selinux: SELinux: Loaded file_contexts
[ 6.207447]
[ 6.213749] init: Running restorecon...
[ 6.225425] init: waitid failed: No child processes
[ 6.234330] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
[ 6.251853] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[ 6.260934] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2349
[ 6.268551] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2350
[ 6.275664] init: Parsing file /init.rc...
[ 6.372808] audit: type=1400 audit(1572328935.267:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.378109] ueventd: ueventd started!
[ 6.390556] audit: type=1400 audit(1572328935.267:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.397049] selinux: SELinux: Loaded file_contexts
[ 6.397049]
[ 6.411670] audit: type=1400 audit(1572328935.267:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.418076] ueventd: Parsing file /ueventd.rc...
[ 6.435530] audit: type=1400 audit(1572328935.267:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.441666] ueventd: Parsing file /vendor/ueventd.rc...
[ 6.457728] audit: type=1400 audit(1572328935.271:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.457735] audit: type=1400 audit(1572328935.271:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.457740] audit: type=1400 audit(1572328935.271:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.457745] audit: type=1400 audit(1572328935.271:11): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.534816] ueventd: Parsing file /odm/ueventd.rc...
[ 6.539878] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[ 6.549844] ueventd: Parsing file /ueventd.freescale.rc...
[ 6.555416] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[ 6.580944] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin'
[ 6.598801] ueventd: loading /devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin took 17ms
[ 6.612455] imx-sdma 30bd0000.sdma: loaded firmware 4.4
[ 6.621935] imx-sdma 302c0000.sdma: loaded firmware 4.4
[ 6.733387] Registered swp emulation handler
[ 6.742845] watchdogd: watchdogd started (interval 10, margin 20)!
[ 6.749543] Console: switching to colour dummy device 80x25
[ 6.777107] wlan: loading driver v4.5.23.1
[ 6.777641] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 6.915613] EXT4-fs (mmcblk0p12): recovery complete
[ 6.921052] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 8.343853] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 8.343853]
[ 8.349910] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 8.349910]
[ 8.357294] e2fsck: Pass 2: Checking directory structure
[ 8.357294]
[ 8.364156] e2fsck: Pass 3: Checking directory connectivity
[ 8.364156]
[ 8.371276] e2fsck: Pass 4: Checking reference counts
[ 8.371276]
[ 8.377845] e2fsck: Pass 5: Checking group summary information
[ 8.377845]
[ 8.385227] e2fsck: /dev/block/by-name/userdata: 1643/581632 files (2.5% non-contiguous), 74076/2326528 blocks
[ 8.385227]
[ 8.402638] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 8.417037] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 8.456579] zram0: detected capacity change from 0 to 314572800
[ 8.489305] logd.auditd: start
[ 8.492603] logd.klogd: 8353219192
[ 8.492845] mkswap: Swapspace size: 307196k, UUID=f2288675-c091-42f5-810e-e8ea61bdaea8
[ 8.504783] Adding 307196k swap on /dev/block/zram0. Priority:-2 extents:1 across:307196k SS
[ 8.553398] type=1400 audit(1572328937.411:38): avc: denied { getattr } for pid=2349 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.574455] type=1400 audit(1572328937.411:38): avc: denied { getattr } for pid=2349 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.594918] type=1400 audit(1572328937.411:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 8.841151] update_verifier: Started with arg 1: nonencrypted
[ 8.851228] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 8.857709] update_verifier: Leaving update_verifier.
[ 8.914600] logd.daemon: reinit
[ 8.921716] rfkill: BT RF going to : off
[ 8.931679] Mass Storage Function, version: 2009/09/11
[ 8.936865] LUN: removable file: (no medium)
[ 8.944950] using random self ethernet address
[ 8.949459] using random host ethernet address
[ 8.956379] file system registered
[ 9.105679] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 9.201537] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
evk_8mq:/ $ [ 9.892638] read descriptors
[ 9.915440] read strings
[ 10.638341] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.668623] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.699005] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.882260] android_work: sent uevent USB_STATE=CONNECTED
[ 10.948264] configfs-gadget gadget: high-speed config #1: b
[ 10.954259] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.428385] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[ 11.836556] random: crng init done
[ 11.964736] init: Service 'early_init_sh' (pid 2352) exited with status 0
[ 13.320572] type=1400 audit(1572328939.943:576): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 13.341105] type=1400 audit(1572328942.215:577): avc: denied { dac_read_search } for pid=2999 comm="Binder:2999_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
[ 13.348187] audit_log_lost: 30 callbacks suppressed
[ 13.348192] audit: audit_lost=522 audit_rate_limit=5 audit_backlog_limit=64
[ 13.371739] audit: rate limit exceeded
[ 13.585431] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.596869] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.656318] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.756122] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
[ 14.285802] read descriptors
[ 14.288926] read strings
[ 14.291776] read descriptors
[ 14.294672] read strings
[ 14.316293] acc_open
[ 14.318627] acc_release
[ 14.482909] fec 30be0000.ethernet eth0: Unable to connect to phy
[ 14.672877] type=1400 audit(1572328942.243:582): avc: denied { dac_read_search } for pid=2999 comm="Binder:2999_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.698875] type=1400 audit(1572328943.567:2353): avc: denied { dac_read_search } for pid=3250 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.703272] sdcardfs version 2.0
[ 14.705859] audit: audit_lost=2292 audit_rate_limit=5 audit_backlog_limit=64
[ 14.705862] audit: rate limit exceeded
[ 14.718015] type=1400 audit(1572328943.575:2356): avc: denied { dac_read_search } for pid=3250 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.720949] sdcardfs: dev_name -> /data/media
[ 14.730682] type=1400 audit(1572328943.599:2357): avc: denied { dac_read_search } for pid=3259 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 14.753374] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[ 14.783343] sdcardfs: mnt -> ffff80005e590c60
[ 14.788113] sdcardfs: mounted on top of /data/media type ext4
[ 14.794648] Remount options were mask=23,gid=9997 for vfsmnt ffff80005e591c20.
[ 14.801942] sdcardfs : options - debug:1
[ 14.806032] sdcardfs : options - gid:9997
[ 14.810145] sdcardfs : options - mask:23
[ 14.814303] Remount options were mask=7,gid=9997 for vfsmnt ffff80005fc5c720.
[ 14.821684] sdcardfs : options - debug:1
[ 14.825704] sdcardfs : options - gid:9997
[ 14.829758] sdcardfs : options - mask:7
[ 15.956155] type=1400 audit(1572328943.599:2357): avc: denied { dac_read_search } for pid=3259 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.976876] type=1400 audit(1572328944.851:2385): avc: denied { read } for pid=3126 comm="system_server" name="state" dev="sysfs" ino=21965 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 16.050888] type=1400 audit(1572328944.851:2385): avc: denied { read } for pid=3126 comm="system_server" name="state" dev="sysfs" ino=21965 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
[ 16.077504] type=1400 audit(1572328944.943:2386): avc: denied { dac_read_search } for pid=3556 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 16.224059] binder: undelivered transaction 9969, process died.
[ 16.231962] binder: undelivered transaction 9937, process died.
[ 17.811911] init: Service 'bootanim' (pid 3103) exited with status 0
[ 17.853800] init: processing action (sys.boot_completed=1) from (/init.rc:719)
[ 17.861225] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:20)
[ 17.877206] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:27)
[ 17.892345] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
[ 17.899913] audit: audit_lost=2319 audit_rate_limit=5 audit_backlog_limit=64
[ 17.905484] init: starting service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[ 17.906116] type=1400 audit(1572328944.951:2389): avc: denied { dac_read_search } for pid=3556 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 17.906143] type=1400 audit(1572328946.787:2390): avc: denied { dac_read_search } for pid=2885 comm="Binder:2885_2" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 17.930488] audit: rate limit exceeded
[ 17.948981] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 18.051788] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 71ms and succeeded
[ 18.074580] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[ 18.074580]
[ 18.099754] init: Async property child exited with status 0
[ 19.195022] audit: audit_lost=3554 audit_rate_limit=5 audit_backlog_limit=64
[ 19.202130] audit: rate limit exceeded
[ 24.951465] type=1400 audit(1572328948.087:3634): avc: denied { dac_read_search } for pid=3750 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 24.970025] type=1400 audit(1572328953.843:3650): avc: denied { dac_read_search } for pid=3840 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.059682] type=1400 audit(1572328953.847:3653): avc: denied { dac_read_search } for pid=3840 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 25.065877] audit: audit_lost=3569 audit_rate_limit=5 audit_backlog_limit=64
[ 25.079886] type=1400 audit(1572328953.955:3654): avc: denied { dac_read_search } for pid=3863 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.087097] audit: rate limit exceeded
[ 25.992673] type=1400 audit(1572328953.955:3654): avc: denied { dac_read_search } for pid=3863 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 26.010451] type=1400 audit(1572328954.887:3682): avc: denied { dac_read_search } for pid=4000 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $
evk_8mq:/ $ su
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ #
evk_8mq:/ # logcat
--------- beginning of main
10-29 06:02:17.374 2873 2873 I SELinux : SELinux: Loaded service_contexts from:
10-29 06:02:17.377 2873 2873 I SELinux : /system/etc/selinux/plat_service_contexts
10-29 06:02:17.377 2875 2875 I SELinux : SELinux: Loaded service_contexts from:
10-29 06:02:17.377 2875 2875 I SELinux : /vendor/etc/selinux/vndservice_contexts
10-29 06:02:09.775 2872 2872 W auditd : type=2000 audit(0.0:1): state=initialized audit_enabled=0 res=1
10-29 06:02:15.007 2872 2872 I auditd : type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
10-29 06:02:15.015 2872 2872 W auditd : type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
10-29 06:02:15.267 1 1 W init : type=1400 audit(0.0:4): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:15.271 1 1 I chatty : uid=0(root) /init identical 4 lines
10-29 06:02:15.271 1 1 W init : type=1400 audit(0.0:9): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:15.271 1 1 W init : type=1400 audit(0.0:10): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:15.271 1 1 W init : type=1400 audit(0.0:11): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:17.411 2349 2349 W init : type=1400 audit(0.0:38): avc: denied { getattr } for path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
10-29 06:02:17.411 1 1 W init : type=1400 audit(0.0:39): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:17.415 1 1 I chatty : uid=0(root) /init identical 6 lines
10-29 06:02:17.415 1 1 W init : type=1400 audit(0.0:46): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:17.429 2874 2874 I hwservicemanager: hwservicemanager is ready now.
10-29 06:02:17.509 2883 2883 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:17.511 2883 2883 I [email protected]: Registration complete for [email protected]::IBootControl/default.
--------- beginning of system
10-29 06:02:17.519 2885 2885 I vold : Vold 3.0 (the awakening) firing up
10-29 06:02:17.520 2885 2885 V vold : Detected support for: ext4 vfat
10-29 06:02:17.522 2884 2884 I [email protected]: Fetching keymaster device name default
10-29 06:02:17.522 2884 2884 I [email protected]: Could not find any keystore module, using software-only implementation.
10-29 06:02:17.523 2885 2885 V vold : Found unmanaged dm device named vroot
10-29 06:02:17.523 2885 2885 V vold : Found unmanaged dm device named vendor
10-29 06:02:17.523 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop2: No such device or address
10-29 06:02:17.523 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop0: No such device or address
10-29 06:02:17.523 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop5: No such device or address
10-29 06:02:17.523 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop3: No such device or address
10-29 06:02:17.523 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop7: No such device or address
10-29 06:02:17.524 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop6: No such device or address
10-29 06:02:17.524 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop4: No such device or address
10-29 06:02:17.524 2885 2885 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop1: No such device or address
10-29 06:02:17.524 2884 2884 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:17.525 2884 2884 I [email protected]: Registration complete for [email protected]::IKeymasterDevice/default.
10-29 06:02:17.526 2885 2885 D vold : VoldNativeService::start() completed OK
10-29 06:02:17.527 2885 2889 I vold : e4crypt_initialize_global_de
10-29 06:02:17.528 2885 2889 D vold : Key exists, using: /data/unencrypted/key
10-29 06:02:17.534 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:02:17.535 2885 2889 I vold : List of Keymaster HALs found:
10-29 06:02:17.535 2885 2889 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:17.536 2885 2889 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:17.542 2885 2889 D vold : Added key 770663794 (ext4:4ef46da64e7b8474) to keyring 782663036 in process 2885
10-29 06:02:17.542 2885 2889 D vold : Added key 985905548 (f2fs:4ef46da64e7b8474) to keyring 782663036 in process 2885
10-29 06:02:17.542 2885 2889 D vold : Added key 866872149 (fscrypt:4ef46da64e7b8474) to keyring 782663036 in process 2885
10-29 06:02:17.543 2885 2889 I vold : Wrote system DE key reference to:/data/unencrypted/ref
10-29 06:02:17.632 2885 2885 D vold : e4crypt_init_user0
10-29 06:02:17.632 2885 2885 D vold : Preparing: /data/misc/vold/user_keys
10-29 06:02:17.634 2885 2885 D vold : Preparing: /data/misc/vold/user_keys/ce
10-29 06:02:17.634 2885 2885 D vold : Preparing: /data/misc/vold/user_keys/de
10-29 06:02:17.640 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:02:17.641 2885 2885 I vold : List of Keymaster HALs found:
10-29 06:02:17.642 2885 2885 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:17.642 2885 2885 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:17.643 2885 2885 D vold : Added key 538869658 (ext4:5b8c9e017e946cff) to keyring 782663036 in process 2885
10-29 06:02:17.643 2885 2885 D vold : Added key 1056248520 (f2fs:5b8c9e017e946cff) to keyring 782663036 in process 2885
10-29 06:02:17.643 2885 2885 D vold : Added key 226375555 (fscrypt:5b8c9e017e946cff) to keyring 782663036 in process 2885
10-29 06:02:17.643 2885 2885 D vold : Installed de key for user 0
10-29 06:02:17.643 2885 2885 D vold : Skipping non-de-key .
10-29 06:02:17.643 2885 2885 D vold : Skipping non-de-key ..
10-29 06:02:17.643 2885 2885 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
10-29 06:02:17.643 2885 2885 D vold : Preparing: /data/system/users/0
10-29 06:02:17.644 2885 2885 D vold : Preparing: /data/misc/profiles/cur/0
10-29 06:02:17.644 2885 2885 D vold : Preparing: /data/system_de/0
10-29 06:02:17.645 2885 2885 D vold : Preparing: /data/misc_de/0
10-29 06:02:17.645 2885 2885 D vold : Preparing: /data/vendor_de/0
10-29 06:02:17.645 2885 2885 D vold : Preparing: /data/user_de/0
10-29 06:02:17.646 2885 2885 I vold : Found policy 5b8c9e017e946cff at /data/system_de/0 which matches expected value
10-29 06:02:17.647 2885 2885 I vold : Found policy 5b8c9e017e946cff at /data/misc_de/0 which matches expected value
10-29 06:02:17.647 2885 2885 I vold : Found policy 5b8c9e017e946cff at /data/vendor_de/0 which matches expected value
10-29 06:02:17.648 2885 2885 I vold : Found policy 5b8c9e017e946cff at /data/user_de/0 which matches expected value
10-29 06:02:17.648 2885 2885 V vold : /system/bin/vold_prepare_subdirs
10-29 06:02:17.648 2885 2885 V vold : prepare
10-29 06:02:17.648 2885 2885 V vold : 0
10-29 06:02:17.648 2885 2885 V vold : 1
10-29 06:02:17.672 2885 2885 I vold_prepare_subdirs: SELinux: Loaded file_contexts
10-29 06:02:17.674 2952 2952 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
10-29 06:02:17.675 2952 2952 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
10-29 06:02:17.676 2952 2952 D vold_prepare_subdirs: Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
10-29 06:02:17.695 2953 2953 I /system/bin/tzdatacheck: timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
10-29 06:02:17.886 2956 2956 I Netd : Netd 1.0 starting
10-29 06:02:17.892 2956 2956 D TetherController: Setting IP forward enable = 0
10-29 06:02:17.968 2956 2956 I Netd : Creating child chains: 69.4ms
10-29 06:02:17.968 2956 2956 I Netd : Setting up OEM hooks: 0.2ms
10-29 06:02:17.968 2956 2956 I Netd : Setting up FirewallController hooks: 0.0ms
10-29 06:02:17.969 2966 2966 I [email protected]/: [email protected]/backup: Hal starting main loop...
10-29 06:02:17.969 2966 2966 I [email protected]/: [email protected]/backup Hal is starting up...
10-29 06:02:17.973 2965 2965 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:17.976 2956 2956 I Netd : Setting up TetherController hooks: 7.5ms
10-29 06:02:17.981 2956 2956 I Netd : Setting up BandwidthController hooks: 4.6ms
10-29 06:02:17.981 2956 2956 I Netd : Setting up IdletimerController hooks: 0.1ms
10-29 06:02:17.982 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IHealth/default in either framework or device manifest.
10-29 06:02:17.993 2966 2966 I [email protected]/: [email protected]/backup: Hal init done
10-29 06:02:18.015 2969 2969 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.016 2969 2969 I [email protected]: Registration complete for [email protected]::IBluetoothHci/default.
10-29 06:02:18.085 2981 2981 I [email protected]/: [email protected]/default: Hal starting main loop...
10-29 06:02:18.085 2981 2981 I [email protected]/: [email protected]/default Hal is starting up...
10-29 06:02:18.094 2981 2981 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.097 2981 2981 I [email protected]/: [email protected]/default: Hal init done
10-29 06:02:18.116 2985 2985 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.118 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:02:18.119 2985 2985 I [email protected]: USB HAL Ready.
10-29 06:02:18.132 2956 2956 I Netd : initializing traffic control: 151.1ms
10-29 06:02:18.140 2956 2956 I Netd : Disabling bandwidth control: 8.0ms
10-29 06:02:18.141 2956 2956 E Netd : cannot find interface dummy0
10-29 06:02:18.142 2956 2956 I Netd : Initializing RouteController: 1.8ms
10-29 06:02:18.142 2956 2956 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHSA
10-29 06:02:18.142 2956 2956 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHPOLICY
10-29 06:02:18.142 2956 2956 I Netd : Initializing XfrmController: 0.4ms
10-29 06:02:18.143 2956 2956 E Netd : Unable to create netlink socket: Protocol not supported
10-29 06:02:18.143 2956 2956 W Netd : Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
10-29 06:02:18.143 2956 2956 D MDnsDS : MDnsSdListener::Hander starting up
10-29 06:02:18.146 2956 2956 I Netd : Registering NetdNativeService: 2.4ms
10-29 06:02:18.146 2956 2956 I Netd : Starting CommandListener: 0.2ms
10-29 06:02:18.149 2956 2956 I Netd : Registering NetdHwService: 3.2ms
10-29 06:02:18.149 2956 2956 I Netd : Netd started in 263ms
10-29 06:02:18.153 2956 3007 D MDnsDS : MDnsSdListener starting to monitor
10-29 06:02:18.153 2956 3007 D MDnsDS : Going to poll with pollCount 1
10-29 06:02:18.155 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: allowing syscall: connect
10-29 06:02:18.155 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: allowing syscall: fcntl
10-29 06:02:18.155 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: allowing syscall: sendto
10-29 06:02:18.155 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: allowing syscall: socket
10-29 06:02:18.155 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: allowing syscall: writev
10-29 06:02:18.155 2976 2976 D [email protected]: [email protected] starting...
10-29 06:02:18.173 2975 2975 W /vendor/bin/hw/[email protected]: libminijail[2975]: logging seccomp filter failures
10-29 06:02:18.174 2975 2975 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.178 2982 2982 E lights : cannot open backlight file /sys/class/backlight/30a00000.mipi_dsi_bridge.0/max_brightness
10-29 06:02:18.178 2982 2982 E light : light_open lights backlight failed: -22
10-29 06:02:18.178 2982 2982 E light : Light passthrough failed to load legacy HAL.
10-29 06:02:18.178 2982 2982 E light : light_open lights keyboard failed: -22
10-29 06:02:18.180 2982 2982 E light : light_open lights buttons failed: -22
10-29 06:02:18.180 2982 2982 E light : Light passthrough failed to load legacy HAL.
10-29 06:02:18.181 2982 2982 E light : light_open lights battery failed: -22
10-29 06:02:18.181 2982 2982 E light : Light passthrough failed to load legacy HAL.
10-29 06:02:18.181 2982 2982 E light : light_open lights notifications failed: -22
10-29 06:02:18.181 2982 2982 E light : light_open lights attention failed: -22
10-29 06:02:18.181 2982 2982 E light : light_open lights bluetooth failed: -22
10-29 06:02:18.182 2982 2982 E light : light_open lights wifi failed: -22
10-29 06:02:18.182 2982 2982 E light : Light passthrough failed to load legacy HAL.
10-29 06:02:18.182 2982 2982 I light : Could not open any lights.
10-29 06:02:18.184 2979 2979 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.185 2983 2983 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.188 2979 2979 I [email protected]: Registration complete for [email protected]::IAllocator/default.
10-29 06:02:18.189 2982 2982 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.190 2983 2983 I [email protected]: Registration complete for [email protected]::IMemtrack/default.
10-29 06:02:18.194 2982 2982 I [email protected]: Registration complete for [email protected]::ILight/default.
10-29 06:02:18.195 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IThermal/default in either framework or device manifest.
10-29 06:02:18.201 2990 2990 W thermalserviced: Unable to get Thermal HAL V1.1, vendor thermal event notification not available
10-29 06:02:18.234 2999 2999 I installd: installd firing up
10-29 06:02:18.243 2984 2984 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.246 2984 2984 I [email protected]: Registration complete for [email protected]::IPower/default.
10-29 06:02:18.247 2978 2978 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.249 2978 2978 I [email protected]: Registration complete for [email protected]::IGatekeeper/default.
10-29 06:02:18.309 2973 2973 I [email protected]: Camera provider Service is starting.
10-29 06:02:18.313 2974 2974 D [email protected]: [email protected] starting...
10-29 06:02:18.313 2974 2974 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.324 2976 2976 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.335 2976 2976 I [email protected]: Registration complete for [email protected]::IDrmFactory/default.
10-29 06:02:18.339 3025 3025 I /system/bin/tombstoned: tombstoned successfully initialized
10-29 06:02:18.341 2976 2976 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.342 2976 2976 I [email protected]: Registration complete for [email protected]::ICryptoFactory/default.
10-29 06:02:18.376 2980 2980 I hwcomposer: hwc_device_open,1239
10-29 06:02:18.377 2980 2980 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.385 2980 2980 I [email protected]: Registration complete for [email protected]::IComposer/default.
10-29 06:02:18.478 3027 3027 I usbd : Usb HAL found.
10-29 06:02:18.479 1 1 W init : type=1400 audit(0.0:535): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:18.479 1 1 I chatty : uid=0(root) /init identical 3 lines
10-29 06:02:18.479 3027 3027 I usbd : peristent prop is adb
10-29 06:02:18.482 2985 2985 I [email protected]: setCurrentUsbFunctions None
10-29 06:02:18.482 2985 2985 I [email protected]: Gadget cannot be pulled down
10-29 06:02:18.483 1 1 W init : type=1400 audit(0.0:539): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tconte[ 69.098250] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
10-29 06:02:18.483 3019 3019 I wificond: wificond is starting up...
10-29 06:02:18.502 2985 2985 W libc : Unable to set property "sys.usb.ffs.ready" to "0": error code: 0x18
10-29 06:02:18.502 2985 2985 I [email protected]: mMonitor not running
10-29 06:02:18.601 2968 2968 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.602 2968 2968 I audiohalservice: Registration complete for [email protected]::IDevicesFactory/default.
10-29 06:02:18.603 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.625 2985 2985 I chatty : uid=0(root) [email protected] identical 2 lines
10-29 06:02:18.645 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.663 2973 2973 I FslCameraHAL: enumSensorSet
10-29 0[ 69.202280] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
6:02:18.663 2973 2973 I FslCame[ 69.211285] type=1400 audit(1572328954.887:3685): avc: denied { dac_read_search } for pid=4000 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
raHAL: matchDevNodes
10-29 06:02[ 69.233519] type=1400 audit(1572328998.103:3686): avc: denied { read } for pid=2981 comm="[email protected]" name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
:18.663 2973 2973 I FslCameraHAL: getNodeName: dev path:/dev/video1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName: node name:mx6s-csi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video1 failed
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeNames: node name:mx6s-csi,i.MX6S_CSI
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName: dev path:/dev/video0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video0 failed
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchPropertyName: index:0, max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: index:0, propName:max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchPropertyName: index:1, max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: index:1, propName:max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: camera number is 0
10-29 06:02:18.664 2973 2973 I [email protected]: Loaded "Default Camera HAL" camera module
10-29 06:02:18.666 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.684 2973 2973 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.685 2973 2973 I [email protected]: Registration complete for [email protected]::ICameraProvider/legacy/0.
10-29 06:02:18.686 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.693 2968 2968 I audiohalservice: Registration complete for [email protected]::IEffectsFactory/default.
10-29 06:02:18.694 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:02:18.706 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.712 2968 2968 E audiohalservice: Could not get passthrough implementation for [email protected]::ISoundTriggerHw/default.
10-29 06:02:18.713 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:02:18.713 2968 2968 E audiohalservice: Could not get passthrough implementation for [email protected]::ISoundTriggerHw/default.
10-29 06:02:18.713 2968 2968 W audiohalservice: Could not register soundtrigger API 2.0 nor 2.1
10-29 06:02:18.714 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IBluetoothAudioOffload/default in either framework or device manifest.
10-29 06:02:18.714 2968 2968 E audiohalservice: Could not get passthrough implementation for [email protected]::IBluetoothAudioOffload/default.
10-29 06:02:18.714 2968 2968 W audiohalservice: Could not register Bluetooth audio offload 1.0
10-29 06:02:18.726 3023 3023 I gatekeeperd: Starting gatekeeperd...
10-29 06:02:18.727 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.767 2985 2985 I chatty : uid=0(root) [email protected] identical 2 lines
10-29 06:02:18.788 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.789 3037 3039 I adbd : initializing functionfs
10-29 06:02:18.789 3037 3039 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
10-29 06:02:18.790 2992 2992 I mediaserver: ServiceManager: 0xf4651883d480
10-29 06:02:18.808 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.808 2996 2996 I [email protected]: Wifi Hal is booting up...
10-29 06:02:18.809 2996 2996 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:18.828 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.829 3037 3039 I adbd : functionfs successfully initialized
10-29 06:02:18.829 3037 3039 I adbd : registering usb transport
10-29 06:02:18.841 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:02:18.843 3000 3000 I keystore: found [email protected]::IKeymasterDevice with interface name default and seclevel SOFTWARE
10-29 06:02:18.843 3000 3000 W keystore: No secure Keymaster implementation found, but device offers insecure Keymaster HAL. Using as default.
10-29 06:02:18.849 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.853 3017 3017 W statsd : statscompanion service unavailable!
10-29 06:02:18.864 3017 3017 I statsd : using statsd socket
10-29 06:02:18.869 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.869 3026 3026 I update_engine: [1029/060218.869500:INFO:main.cc(182)] Chrome OS Update Engine starting
10-29 06:02:18.873 3026 3026 I update_engine: [1029/060218.873137:INFO:boot_control_android.cc(64)] Loaded boot control hidl hal.
10-29 06:02:18.873 3026 3026 I update_engine: [1029/060218.873307:INFO:daemon_state_android.cc(43)] Booted in dev mode.
10-29 06:02:18.889 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.893 2957 2957 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
10-29 06:02:18.909 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.930 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.938 2957 2957 I zygote64: option[0]=-Xzygote
10-29 06:02:18.938 2957 2957 I zygote64: option[1]=-Xusetombstonedtraces
10-29 06:02:18.938 2957 2957 I zygote64: option[2]=exit
10-29 06:02:18.938 2957 2957 I zygote64: option[3]=vfprintf
10-29 06:02:18.938 2957 2957 I zygote64: option[4]=sensitiveThread
10-29 06:02:18.938 2957 2957 I zygote64: option[5]=-verbose:gc
10-29 06:02:18.938 2957 2957 I zygote64: option[6]=-Xms16m
10-29 06:02:18.938 2957 2957 I zygote64: option[7]=-Xmx512m
10-29 06:02:18.938 2957 2957 I zygote64: option[8]=-XX:HeapGrowthLimit=192m
10-29 06:02:18.938 2957 2957 I zygote64: option[9]=-XX:HeapMinFree=512k
10-29 06:02:18.938 2957 2957 I zygote64: option[10]=-XX:HeapMaxFree=8m
10-29 06:02:18.938 2957 2957 I zygote64: option[11]=-XX:HeapTargetUtilization=0.75
10-29 06:02:18.938 2957 2957 I zygote64: option[12]=-Xusejit:true
10-29 06:02:18.938 2957 2957 I zygote64: option[13]=-Xjitsaveprofilinginfo
10-29 06:02:18.938 2957 2957 I zygote64: option[14]=-XjdwpOptions:suspend=n,server=y
10-29 06:02:18.938 2957 2957 I zygote64: option[15]=-XjdwpProvider:default
10-29 06:02:18.938 2957 2957 I zygote64: option[16]=-Xlockprofthreshold:500
10-29 06:02:18.938 2957 2957 I zygote64: option[17]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[18]=--runtime-arg
10-29 06:02:18.939 2957 2957 I zygote64: option[19]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[20]=-Xms64m
10-29 06:02:18.939 2957 2957 I zygote64: option[21]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[22]=--runtime-arg
10-29 06:02:18.939 2957 2957 I zygote64: option[23]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[24]=-Xmx64m
10-29 06:02:18.939 2957 2957 I zygote64: option[25]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[26]=--profile-file=/system/etc/boot-image.prof
10-29 06:02:18.939 2957 2957 I zygote64: option[27]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[28]=--compiler-filter=speed-profile
10-29 06:02:18.939 2957 2957 I zygote64: option[29]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[30]=--runtime-arg
10-29 06:02:18.939 2957 2957 I zygote64: option[31]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[32]=-Xms64m
10-29 06:02:18.939 2957 2957 I zygote64: option[33]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[34]=--runtime-arg
10-29 06:02:18.939 2957 2957 I zygote64: option[35]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[36]=-Xmx512m
10-29 06:02:18.939 2957 2957 I zygote64: option[37]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[38]=--instruction-set-variant=cortex-a53
10-29 06:02:18.939 2957 2957 I zygote64: option[39]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[40]=--instruction-set-variant=cortex-a53
10-29 06:02:18.939 2957 2957 I zygote64: option[41]=-Ximage-compiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[42]=--instruction-set-features=default
10-29 06:02:18.939 2957 2957 I zygote64: option[43]=-Xcompiler-option
10-29 06:02:18.939 2957 2957 I zygote64: option[44]=--instruction-set-features=default
10-29 06:02:18.939 2957 2957 I zygote64: option[45]=-Duser.locale=en-US
10-29 06:02:18.939 2957 2957 I zygote64: option[46]=--cpu-abilist=arm64-v8a
10-29 06:02:18.939 2957 2957 I zygote64: option[47]=-Xfingerprint:Android/evk_8mq/evk_8mq:9/2.0.1-ga-rc1/neolix09171654:userdebug/dev-keys
10-29 06:02:18.951 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.954 2957 2957 I zygote64: VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm64 --instruction-set=arm64 --verify
10-29 06:02:18.971 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:18.992 2985 2985 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:02:19.003 2958 2958 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
10-29 06:02:19.012 2958 2958 I zygote : option[0]=-Xzygote
10-29 06:02:19.012 2958 2958 I zygote : option[1]=-Xusetombstonedtraces
10-29 06:02:19.012 2958 2958 I zygote : option[2]=exit
10-29 06:02:19.012 2958 2958 I zygote : option[3]=vfprintf
10-29 06:02:19.012 2958 2958 I zygote : option[4]=sensitiveThread
10-29 06:02:19.012 2958 2958 I zygote : option[5]=-verbose:gc
10-29 06:02:19.012 2958 2958 I zygote : option[6]=-Xms16m
10-29 06:02:19.012 2958 2958 I zygote : option[7]=-Xmx512m
10-29 06:02:19.012 2958 2958 I zygote : option[8]=-XX:HeapGrowthLimit=192m
10-29 06:02:19.012 2958 2958 I zygote : option[9]=-XX:HeapMinFree=512k
10-29 06:02:19.012 2958 2958 I zygote : option[10]=-XX:HeapMaxFree=8m
10-29 06:02:19.012 2958 2958 I zygote : option[11]=-XX:HeapTargetUtilization=0.75
10-29 06:02:19.012 2958 2958 I zygote : option[12]=-Xusejit:true
10-29 06:02:19.012 2958 2958 I zygote : option[13]=-Xjitsaveprofilinginfo
10-29 06:02:19.012 2958 2958 I zygote : option[14]=-XjdwpOptions:suspend=n,server=y
10-29 06:02:19.012 2958 2958 I zygote : option[15]=-XjdwpProvider:default
10-29 06:02:19.012 2958 2958 I zygote : option[16]=-Xlockprofthreshold:500
10-29 06:02:19.012 2958 2958 I zygote : option[17]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[18]=--runtime-arg
10-29 06:02:19.012 2958 2958 I zygote : option[19]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[20]=-Xms64m
10-29 06:02:19.012 2958 2958 I zygote : option[21]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[22]=--runtime-arg
10-29 06:02:19.012 2958 2958 I zygote : option[23]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[24]=-Xmx64m
10-29 06:02:19.012 2958 2958 I zygote : option[25]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[26]=--profile-file=/system/etc/boot-image.prof
10-29 06:02:19.012 2958 2958 I zygote : option[27]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[28]=--compiler-filter=speed-profile
10-29 06:02:19.012 2958 2958 I zygote : option[29]=-Xcompiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[30]=--runtime-arg
10-29 06:02:19.012 2958 2958 I zygote : option[31]=-Xcompiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[32]=-Xms64m
10-29 06:02:19.012 2958 2958 I zygote : option[33]=-Xcompiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[34]=--runtime-arg
10-29 06:02:19.012 2958 2958 I zygote : option[35]=-Xcompiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[36]=-Xmx512m
10-29 06:02:19.012 2958 2958 I zygote : option[37]=-Ximage-compiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[38]=--instruction-set-variant=cortex-a9
10-29 06:02:19.012 2958 2958 I zygote : option[39]=-Xcompiler-option
10-29 06:02:19.012 2958 2958 I zygote : option[40]=--instruction-set-variant=cortex-a9
10-29 06:02:19.012 2958 2958 I zygote : option[41]=-Ximage-compiler-option
10-29 06:02:19.013 2958 2958 I zygote : option[42]=--instruction-set-features=default
10-29 06:02:19.013 2958 2958 I zygote : option[43]=-Xcompiler-option
10-29 06:02:19.013 2958 2958 I zygote : option[44]=--instruction-set-features=default
10-29 06:02:19.013 2958 2958 I zygote : option[45]=-Duser.locale=en-US
10-29 06:02:19.013 2958 2958 I zygote : option[46]=--cpu-abilist=armeabi-v7a,armeabi
10-29 06:02:19.013 2958 2958 I zygote : option[47]=-Xfingerprint:Android/evk_8mq/evk_8mq:9/2.0.1-ga-rc1/neolix09171654:userdebug/dev-keys
10-29 06:02:19.016 2985 2985 I [email protected]: setCurrentUsbFunctions Adb
10-29 06:02:19.016 2985 2985 I [email protected]: Service started
10-29 06:02:19.016 2985 2985 I [email protected]: Usb Gadget setcurrent functions called successfully
10-29 06:02:19.018 2958 2958 W zygote : Could not reserve sentinel fault page
10-29 06:02:19.034 2958 2958 I zygote : VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm --instruction-set=arm --verify
10-29 06:02:19.048 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
10-29 06:02:19.049 2987 2987 I SurfaceFlinger: Using HWComposer service: 'default'
10-29 06:02:19.049 2987 2987 I SurfaceFlinger: SurfaceFlinger is starting
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
10-29 06:02:19.051 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:19.053 2987 2987 I ConfigStore: android::hardware::configstore::V1_1::ISurfaceFlingerConfigs::primaryDisplayOrientation retrieved: ORIENTATION_0 (default)
10-29 06:02:19.053 2987 2987 I SurfaceFlinger: Disabling backpressure propagation
10-29 06:02:19.053 2987 2987 I SurfaceFlinger: Enabling HWC virtual displays
10-29 06:02:19.053 2987 2987 I SurfaceFlinger: Disabling Triple Buffering
10-29 06:02:19.053 2987 2987 I SurfaceFlinger: Treble testing override: 'false'
10-29 06:02:19.068 2987 2987 I SurfaceFlinger: SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
10-29 06:02:19.068 2987 2987 I SurfaceFlinger: Phase offest NS: 1000000
10-29 06:02:19.080 3020 3020 I media.codec: mediacodecservice starting
10-29 06:02:19.113 3020 3020 W media.codec: libminijail[3020]: failed to get path of fd 4: No such file or directory
10-29 06:02:19.113 3020 3020 W media.codec: libminijail[3020]: allowing syscall: clock_gettime
10-29 06:02:19.114 3020 3020 W media.codec: libminijail[3020]: allowing syscall: connect
10-29 06:02:19.114 3020 3020 W media.codec: libminijail[3020]: allowing syscall: fcntl64
10-29 06:02:19.114 3020 3020 W media.codec: libminijail[3020]: allowing syscall: socket
10-29 06:02:19.114 3020 3020 W media.codec: libminijail[3020]: allowing syscall: writev
10-29 06:02:19.121 3020 3020 W media.codec: libminijail[3020]: compile_file: <fd>(60): nonexistent syscall 'select'
10-29 06:02:19.121 3020 3020 W media.codec: libminijail[3020]: logging seccomp filter failures
10-29 06:02:19.160 2987 2987 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:02:19.174 3020 3020 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
10-29 06:02:19.174 3020 3020 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
10-29 06:02:19.175 3020 3020 E MediaCodecsXmlParser: Cannot find the role for a decoder of type video/x-vnd.on2.vp6
10-29 06:02:19.176 3020 3020 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:19.177 3016 3016 I mediametrics: ServiceManager: 0xe4a98da3d740
10-29 06:02:19.178 3016 3016 D MediaAnalyticsService: MediaAnalyticsService created
10-29 06:02:19.210 2987 2987 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:02:19.267 2997 2997 I cameraserver: ServiceManager: 0xed79c100
10-29 06:02:19.267 2997 2997 I CameraService: CameraService started (pid=2997)
10-29 06:02:19.267 2997 2997 I CameraService: CameraService process starting
10-29 06:02:19.268 2997 2997 W BatteryNotifier: batterystats service unavailable!
10-29 06:02:19.271 2997 2997 I CameraProviderManager: Connecting to new camera provider: legacy/0, isRemote? 1
10-29 06:02:19.272 2997 2997 I CameraProviderManager: Camera provider legacy/0 ready with 0 camera devices
10-29 06:02:19.272 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ICameraProvider/external/0 in either framework or device manifest.
10-29 06:02:19.273 2997 2997 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds
10-29 06:02:19.273 2997 2997 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds CameraDevice str is legacy/0
10-29 06:02:19.273 2997 2997 I : Waiting for activity service
10-29 06:02:19.274 2997 3066 W CameraProviderManager: addProviderLocked: Camera provider HAL with name 'legacy/0' already registered
10-29 06:02:19.275 2997 3066 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds
10-29 06:02:19.275 2997 3066 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds CameraDevice str is legacy/0
10-29 06:02:19.283 2987 2987 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:02:19.302 3020 3020 I OMXPlayer: LEVEL: 1 FUNCTION: Open LINE: 39
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_ac3
10-29 06:02:19.302 3020 3020 I OMXPlayer: LEVEL: 1 FUNCTION: ComponentRegister LINE: 75
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_ac3 fail.
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_ddp
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_ddp fail.
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_ms
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_ms fail.
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_wmv9
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_wmv9 fail.
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_ra
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_ra fail.
10-29 06:02:19.302 3020 3020 I OMXPlayer: Can't open file: /vendor/etc/component_register_rv
10-29 06:02:19.302 3020 3020 I OMXPlayer: Open component register file /vendor/etc/component_register_rv fail.
10-29 06:02:19.316 3020 3020 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
10-29 06:02:19.316 3020 3020 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
10-29 06:02:19.317 3020 3020 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:02:19.324 3020 3020 I media.codec: IOmx HAL service created.
10-29 06:02:19.353 3001 3001 V MediaUtils: physMem: 3008249856
10-29 06:02:19.353 3001 3001 V MediaUtils: requested limit: 601649960
10-29 06:02:19.353 3001 3001 V MediaUtils: actual limit: 3221225471
10-29 06:02:19.353 3001 3001 V MediaUtils: original limits: -1/-1
10-29 06:02:19.353 3001 3001 V MediaUtils: new limits: 3221225471/-1
10-29 06:02:19.360 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:19.361 2987 2987 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:02:19.361 2987 2987 W SurfaceFlinger: no suitable EGLConfig found, trying a simpler query
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: EGL information:
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: vendor : Android
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: version : 1.4 Android META-EGL
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_EXT_surface_SMPTE2086_metadata EGL_EXT_surface_CTA861_3_metadata EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_EXT_buffer_age EGL_EXT_protected_content
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: Client API: OpenGL_ES
10-29 06:02:19.361 2987 2987 I SurfaceFlinger: EGLSurface: 8-8-8-8, config=0x15
10-29 06:02:19.368 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: failed to get path of fd 4: No such file or directory
10-29 06:02:19.369 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: allowing syscall: connect
10-29 06:02:19.369 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: allowing syscall: fcntl
10-29 06:02:19.369 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: allowing syscall: sendto
10-29 06:02:19.369 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: allowing syscall: socket
10-29 06:02:19.369 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: allowing syscall: writev
10-29 06:02:19.371 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: compile_file: <fd>(47): nonexistent syscall 'ftruncate64'
10-29 06:02:19.371 3001 3001 W /system/bin/mediaextractor: libminijail[3001]: logging seccomp filter failures
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: OpenGL ES informations:
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: vendor : Vivante Corporation
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: renderer : Vivante GC7000L
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: version : OpenGL ES 3.1 V6.2.4.p4.190076
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_texture_storage_multisample_2d_array GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex GL_OES_texture_half_float GL_OES_texture_float GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness GL_KHR_robust_buffer_acces
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: GL_MAX_TEXTURE_SIZE = 8192
10-29 06:02:19.421 2987 2987 I SurfaceFlinger: GL_MAX_VIEWPORT_DIMS = 8192
10-29 06:02:19.442 2980 3072 I display : HWC disabled!
10-29 06:02:19.442 2980 3072 I display : Opengl ES 3D composition enabled!
10-29 06:02:19.457 2993 2993 I mediaserver: ServiceManager: 0xf079c1c0
10-29 06:02:19.458 2993 2993 W BatteryNotifier: batterystats service unavailable!
10-29 06:02:19.486 2991 2991 I FastMixerState: sMaxFastTracks = 8
10-29 06:02:19.488 2991 2991 V MediaUtils: physMem: 3008249856
10-29 06:02:19.488 2991 2991 V MediaUtils: requested limit: 536870912
10-29 06:02:19.488 2991 2991 V MediaUtils: actual limit: 536870912
10-29 06:02:19.488 2991 2991 V MediaUtils: original limits: 4294967295/4294967295
10-29 06:02:19.488 2991 2991 V MediaUtils: new limits: 536870912/4294967295
10-29 06:02:19.489 2991 2991 I audioserver: ServiceManager: 0xf139c100
10-29 06:02:19.489 2991 2991 W BatteryNotifier: batterystats service unavailable!
10-29 06:02:19.493 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IDevicesFactory/msd in either framework or device manifest.
10-29 06:02:19.495 2991 2991 I AudioFlinger: Using default 3000 mSec as standby time.
10-29 06:02:19.497 2991 2991 E APM::Serializer: deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
10-29 06:02:19.498 2980 3072 I display : can't find /vendor/lib64/libg2d.so, 2D is invalid
10-29 06:02:19.499 2980 3072 I display : open gpu gralloc module!
10-29 06:02:19.510 2980 3072 I display : try dev:/dev/dri/card0
10-29 06:02:19.510 2980 3072 I libedid : Try to check fd 19 connector:47 edid info
10-29 06:02:19.524 2985 3050 I [email protected]: GADGET pulled up
10-29 06:02:19.557 2968 3076 W audio_hw_primary: card 0, id wm8524audio, driver wm8524-audio, name wm8524-audio
10-29 06:02:19.571 2980 3072 I display : readConnection: id:1, connection:1, count_modes:8, count_encoders:1
10-29 06:02:19.571 2980 3072 I display : Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
10-29 06:02:19.571 2980 3072 I display : Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
10-29 06:02:19.578 2968 3076 W audio_hw_primary: out rate 48000
10-29 06:02:19.599 2968 3076 W audio_hw_primary: in rate 0, channels 0 format 0
10-29 06:02:19.599 2968 3076 W audio_hw_primary: card 1, id imxspdif, driver imx-spdif, name imx-spdif
10-29 06:02:19.600 2968 3076 W audio_hw_primary: out rate 44100
10-29 06:02:19.601 2968 3076 W audio_hw_primary: in rate 44100, channels 2 format 3
10-29 06:02:19.601 2968 3076 W audio_hw_primary: card 2, id imxhdmiarc, driver imx-hdmi-arc, name imx-hdmi-arc
10-29 06:02:19.601 2968 3076 W audio_hw_primary: unrecognized card found.
10-29 06:02:19.601 2968 3076 W audio_hw_primary: card 3, id imxaudiohdmi, driver imx-audio-hdmi, name imx-audio-hdmi
10-29 06:02:19.602 2980 3072 I display : Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
10-29 06:02:19.602 2980 3072 I display : Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
10-29 06:02:19.602 2980 3072 E display : can't find property ID for 'dtrc_table_ofs'.
10-29 06:02:19.603 2980 3072 E display : can't find property ID for 'alpha'.
10-29 06:02:19.603 2980 3072 W display : xres = 1920 px
10-29 06:02:19.603 2980 3072 W display : yres = 1080 px
10-29 06:02:19.603 2980 3072 W display : format = 1
10-29 06:02:19.603 2980 3072 W display : xdpi = 61.73 ppi
10-29 06:02:19.603 2980 3072 W display : ydpi = 160.00 ppi
10-29 06:02:19.603 2980 3072 W display : fps = 60.00 Hz
10-29 06:02:19.603 2980 3072 W display : mode.width = 1920 px
10-29 06:02:19.603 2980 3072 W display : mode.height = 1080 px
10-29 06:02:19.603 2980 3072 I display : no need to alloc memory
10-29 06:02:19.603 2980 3072 I display : enumKmsDisplay set 1 as primary display
10-29 06:02:19.603 2980 3072 E display : failed to set DPMS mode:3
10-29 06:02:19.603 2980 3072 I display : try dev:/dev/dri/card1
10-29 06:02:19.604 2980 3072 E display : Failed to set atomic cap -1
10-29 06:02:19.607 2987 2987 E HWComposer: getSupportedPerFrameMetadata: getSupportedPerFrameMetadata failed for display 0: Unsupported (8)
10-29 06:02:19.614 2979 2979 I display : open gpu gralloc module!
10-29 06:02:19.616 2979 2979 E ion : ioctl c0044901 failed with code -1: Not a typewriter
10-29 06:02:19.618 2987 2987 I display : open gpu gralloc module!
10-29 06:02:19.619 2987 2987 E gralloc : gralloc1_device_open invalid name:fb0
10-29 06:02:19.619 2987 2987 I v_egl : FramebufferSurface: bufferCount=3
10-29 06:02:19.672 2968 3076 W audio_hw_primary: out rate 44100
10-29 06:02:19.757 2968 3076 W audio_hw_primary: in rate 0, channels 0 format 0
10-29 06:02:19.757 2968 3076 I audio_hw_primary: Total 3 cards match
10-29 06:02:19.757 2968 3076 I audio_hw_primary: card idx 0, name wm8524-audio
10-29 06:02:19.757 2968 3076 I audio_hw_primary: card idx 1, name imx-spdif
10-29 06:02:19.757 2968 3076 I audio_hw_primary: card idx 2, name imx-audio-hdmi
10-29 06:02:19.757 2968 3076 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
10-29 06:02:19.758 2968 2968 W DeviceHAL: Error from HAL Device in function set_master_volume: Function not implemented
10-29 06:02:19.758 2991 2991 I AudioFlinger: loadHwModule() Loaded primary audio interface, handle 10
10-29 06:02:19.758 2991 2991 I AudioFlinger: openOutput() this 0xf13be000, module 10 Device 0x2, SamplingRate 48000, Format 0x000001, Channels 0x3, flags 0x2
10-29 06:02:19.758 2968 2968 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(48000) channel_mask(0x3) format(0x1) devices(0x2) flags(0x2), address()
10-29 06:02:19.758 2968 2968 I audio_hw_primary: adev_open_output_stream: exit: output_type 1, output 0xf3d50000
10-29 06:02:19.759 2991 2991 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 960 frames
10-29 06:02:19.777 2991 2991 I BufferProvider: found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
10-29 06:02:19.778 2980 3089 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:02:19.781 2991 2991 I AudioFlinger: Using module 10 as the primary audio interface
10-29 06:02:19.781 2968 3076 I audio_hw_primary: adev_set_mode mode 0
10-29 06:02:19.782 2991 2991 W AudioFlinger: moveEffects() bad srcOutput 0
10-29 06:02:19.785 2991 3095 I AudioFlinger: AudioFlinger's thread 0xf09038c0 tid=3095 ready to run
10-29 06:02:19.785 2991 3095 W AudioFlinger: no wake lock to update, system not ready yet
10-29 06:02:19.786 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=2
10-29 06:02:19.786 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:19.787 2968 2968 W audio_hw_primary: In channels 2, rate 48000, devices 0x80000004
10-29 06:02:19.787 2968 3092 W audio_hw_primary: get_input_buffer_size size = 512, channel_count = 2
10-29 06:02:19.788 2968 3092 W audio_hw_primary: get_input_buffer_size size = 512, channel_count = 2
10-29 06:02:19.789 2991 3099 I AudioFlinger: AudioFlinger's thread 0xf0603700 tid=3099 ready to run
10-29 06:02:19.790 2991 3098 E FastThread: did not receive expected priority boost on time
10-29 06:02:19.812 2991 2991 I bt_a2dp_hw: adev_open: adev_open in A2dp_hw module
10-29 06:02:19.812 2991 2991 I AudioFlinger: loadHwModule() Loaded a2dp audio interface, handle 18
10-29 06:02:19.816 2991 2991 I AudioFlinger: loadHwModule() Loaded usb audio interface, handle 26
10-29 06:02:19.819 2968 3092 I r_submix: adev_open(name=audio_hw_if)
10-29 06:02:19.820 2968 3092 I r_submix: adev_init_check()
10-29 06:02:19.820 2968 3092 W DeviceHAL: Error from HAL Device in function set_master_mute: Function not implemented
10-29 06:02:19.820 2991 2991 I AudioFlinger: loadHwModule() Loaded r_submix audio interface, handle 34
10-29 06:02:19.820 2968 3092 D r_submix: adev_open_input_stream(addr=0)
10-29 06:02:19.821 2968 3092 D r_submix: submix_audio_device_create_pipe_l(addr=0, idx=9)
10-29 06:02:19.821 2968 3092 D r_submix: now using address 0 for route 9
10-29 06:02:19.822 2991 3100 I AudioFlinger: AudioFlinger's thread 0xf0603d40 tid=3100 ready to run
10-29 06:02:19.823 2991 2991 I : Waiting for activity service
10-29 06:02:19.823 2968 3092 D r_submix: adev_close_input_stream()
10-29 06:02:19.823 2968 3092 D r_submix: submix_audio_device_release_pipe_l(idx=9) addr=0
10-29 06:02:19.823 2968 3092 D r_submix: submix_audio_device_destroy_pipe_l(): pipe destroyed
10-29 06:02:19.825 3018 3047 I ServiceManager: Waiting for service package_native...
10-29 06:02:19.850 2980 3089 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:02:19.940 2987 2987 D SurfaceFlinger: shader cache generated - 24 shaders in 297.090027 ms
10-29 06:02:19.943 1 1 W init : type=1400 audit(0.0:573): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:19.943 1 1 I chatty : uid=0(root) /init identical 2 lines
10-29 06:02:19.943 1 1 W init : type=1400 audit(0.0:576): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:02:19.943 2987 2987 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xf78be2258000
10-29 06:02:19.943 2987 2987 D SurfaceFlinger: Finished set power mode=2, type=0
10-29 06:02:20.084 2958 2958 I zygote : Explicit concurrent copying GC freed 178(9KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 82us total 8.282ms
10-29 06:02:20.093 2958 2958 I zygote : Explicit concurrent copying GC freed 5(32KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 58us total 7.736ms
10-29 06:02:20.093 2958 2958 D Zygote32Timing: PostZygoteInitGC took to complete: 17ms
10-29 06:02:20.093 2958 2958 D Zygote32Timing: ZygoteInit took to complete: 17ms
10-29 06:02:20.116 2958 2958 I Zygote : Accepting command socket connections
10-29 06:02:20.125 2957 2957 D Zygote : begin preload
10-29 06:02:20.125 2957 2957 I Zygote : Installing ICU cache reference pinning...
10-29 06:02:20.125 2957 2957 I Zygote : Preloading ICU data...
10-29 06:02:20.196 2957 2957 D Zygote64Timing: BeginIcuCachePinning took to complete: 71ms
10-29 06:02:20.197 2957 2957 I Zygote : Preloading classes...
10-29 06:02:20.222 2957 2957 I Zygote : ...preloaded 0 classes in 25ms.
10-29 06:02:20.222 2957 2957 I zygote64: VMRuntime.preloadDexCaches starting
10-29 06:02:20.314 2957 2957 I zygote64: VMRuntime.preloadDexCaches strings total=339244 before=12303 after=12303
10-29 06:02:20.314 2957 2957 I zygote64: VMRuntime.preloadDexCaches types total=31355 before=7818 after=7819
10-29 06:02:20.314 2957 2957 I zygote64: VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
10-29 06:02:20.314 2957 2957 I zygote64: VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
10-29 06:02:20.314 2957 2957 I zygote64: VMRuntime.preloadDexCaches finished
10-29 06:02:20.314 2957 2957 D Zygote64Timing: PreloadClasses took to complete: 118ms
10-29 06:02:20.364 2957 3112 I zygote64: Thread[6,tid=3112,Native,Thread*=0xea7bf2486800,peer=0x12cf3a58,"Thread-1"] recursive attempt to load library "/system/lib64/libmedia_jni.so"
10-29 06:02:20.364 2957 3112 D MtpDeviceJNI: register_android_mtp_MtpDevice
10-29 06:02:20.365 2957 3112 I zygote64: Thread[6,tid=3112,Native,Thread*=0xea7bf2486800,peer=0x12cf3a58,"Thread-1"] recursive attempt to load library "/system/lib64/libmedia_jni.so"
10-29 06:02:20.499 3103 3121 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:02:20.509 3103 3121 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:02:20.584 2957 2957 I Zygote : Preloading resources...
10-29 06:02:20.587 3103 3121 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:02:20.613 2957 2957 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
10-29 06:02:20.639 2957 2957 I Zygote : ...preloaded 64 resources in 55ms.
10-29 06:02:20.646 2957 2957 I Zygote : ...preloaded 41 resources in 7ms.
10-29 06:02:20.646 2957 2957 D Zygote64Timing: PreloadResources took to complete: 329ms
10-29 06:02:20.667 3103 3121 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:20.668 3103 3121 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:02:20.671 2957 2957 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:02:20.674 3103 3121 I display : open gpu gralloc module!
10-29 06:02:20.684 3103 3121 D BootAnimation: BootAnimationShownTiming start time: 11648ms
10-29 06:02:20.686 2957 2957 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:02:20.720 2987 2987 I SurfaceFlinger: Enter boot animation
10-29 06:02:20.730 2987 2987 W SurfaceFlinger: Unable to determine the display type for display 1
10-29 06:02:20.763 2957 2957 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:02:20.780 2980 3089 E display : threadLoop invalid uevent remove@/bus/pci/drivers/hif_pci
10-29 06:02:20.796 2980 3089 E display : threadLoop invalid uevent remove@/module/wlan
10-29 06:02:20.821 2957 2957 I Zygote : Preloading shared libraries...
10-29 06:02:20.835 3018 3047 I ServiceManager: Waiting for service package_native...
10-29 06:02:20.858 2957 2957 I Zygote : Uninstalled ICU cache reference pinning...
10-29 06:02:20.859 2957 2957 I Zygote : Installed AndroidKeyStoreProvider in 1ms.
10-29 06:02:20.872 2957 2957 I Zygote : Warmed up JCA providers in 13ms.
10-29 06:02:20.872 2957 2957 D Zygote : end preload
10-29 06:02:20.872 2957 2957 D Zygote64Timing: ZygotePreload took to complete: 747ms
10-29 06:02:20.916 2957 2957 I zygote64: Explicit concurrent copying GC freed 51207(5MB) AllocSpace objects, 165(3MB) LOS objects, 49% free, 2MB/4MB, paused 57us total 43.867ms
10-29 06:02:20.956 2957 2957 I zygote64: Explicit concurrent copying GC freed 2797(136KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 2MB/4MB, paused 32us total 32.094ms
10-29 06:02:20.956 2957 2957 D Zygote64Timing: PostZygoteInitGC took to complete: 84ms
10-29 06:02:20.956 2957 2957 D Zygote64Timing: ZygoteInit took to complete: 831ms
10-29 06:02:21.188 2957 2957 I Zygote : System server process 3126 has been created
10-29 06:02:21.191 2957 2957 I Zygote : Accepting command socket connections
10-29 06:02:21.206 3126 3126 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
10-29 06:02:21.305 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:21.339 3126 3126 I chatty : uid=1000 system_server identical 2 lines
10-29 06:02:21.340 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:21.358 3126 3126 I SystemServer: InitBeforeStartServices
10-29 06:02:21.359 3126 3126 I SystemServer: Entered the Android system server!
10-29 06:02:21.619 3126 3126 E UsbAlsaJackDetectorJNI: Can't register UsbAlsaJackDetector native methods
10-29 06:02:21.637 3126 3126 D SystemServerTiming: InitBeforeStartServices took to complete: 279ms
10-29 06:02:21.638 3126 3126 I SystemServer: StartServices
10-29 06:02:21.638 3126 3126 I SystemServer: Reading configuration...
10-29 06:02:21.638 3126 3126 I SystemServer: ReadingSystemConfig
10-29 06:02:21.638 3126 3126 D SystemServerTiming: ReadingSystemConfig took to complete: 0ms
10-29 06:02:21.638 3126 3126 I SystemServer: StartInstaller
10-29 06:02:21.638 3126 3126 I SystemServiceManager: Starting com.android.server.pm.Installer
10-29 06:02:21.639 3126 3139 D SystemServerInitThreadPool: Started executing ReadingSystemConfig
10-29 06:02:21.640 2999 3028 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:02:21.640 3126 3126 D SystemServerTiming: StartInstaller took to complete: 2ms
10-29 06:02:21.640 3126 3126 I SystemServer: DeviceIdentifiersPolicyService
10-29 06:02:21.641 3126 3126 I SystemServiceManager: Starting com.android.server.os.DeviceIdentifiersPolicyService
10-29 06:02:21.641 3126 3126 D SystemServerTiming: DeviceIdentifiersPolicyService took to complete: 1ms
10-29 06:02:21.641 3126 3126 I SystemServer: StartActivityManager
10-29 06:02:21.641 3126 3126 I SystemServiceManager: Starting com.android.server.am.ActivityManagerService$Lifecycle
10-29 06:02:21.656 3126 3126 I ActivityManager: Memory class: 192
10-29 06:02:21.664 3126 3126 D BatteryStatsImpl: Reading daily items from /data/system/batterystats-daily.xml
10-29 06:02:21.673 3126 3145 E BluetoothAdapter: Bluetooth binder is null
10-29 06:02:21.676 3126 3145 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
10-29 06:02:21.677 3126 3145 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:02:21.688 3126 3139 D SystemServerInitThreadPool: Finished executing ReadingSystemConfig
10-29 06:02:21.689 3126 3145 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_active_time
10-29 06:02:21.689 3126 3145 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_policy_time
10-29 06:02:21.693 3126 3145 I PowerManagerService-JNI: Loaded power HAL 1.0 service
10-29 06:02:21.693 3126 3145 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:02:21.783 3126 3126 W AppOps : Unknown attribute in 'op' tag: n
10-29 06:02:21.790 3126 3126 I chatty : uid=1000 system_server identical 88 lines
10-29 06:02:21.790 3126 3126 W AppOps : Unknown attribute in 'op' tag: n
10-29 06:02:21.794 3126 3126 I IntentFirewall: Read new rules (A:0 B:0 S:0)
10-29 06:02:21.800 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1003/pid_3103: Device or resource busy
10-29 06:02:21.800 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1003: Permission denied
10-29 06:02:21.800 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1001/pid_3021: Device or resource busy
10-29 06:02:21.800 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1001: Permission denied
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1058/pid_3025: Device or resource busy
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1058: Permission denied
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1066/pid_3017: Device or resource busy
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1066: Permission denied
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1046/pid_3020: Device or resource busy
10-29 06:02:21.801 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1046: Permission denied
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1036/pid_2872: Device or resource busy
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1036: Permission denied
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_2000/pid_2995: Device or resource busy
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_2000: Permission denied
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1040/pid_3001: Device or resource busy
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1040: Permission denied
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1002/pid_2969: Device or resource busy
10-29 06:02:21.802 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1002: Permission denied
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1010/pid_3019: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1010/pid_2996: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1010: Permission denied
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1067/pid_2998: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1067: Permission denied
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2982: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_3023: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2990: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2980: Device or resource busy
10-29 06:02:21.803 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2979: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2884: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2874: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2987: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2975: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2965: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2983: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2981: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2875: Device or resource busy
10-29 06:02:21.804 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2978: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2873: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2984: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1000: Permission denied
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1019/pid_2994: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1019: Permission denied
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1047/pid_2997: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1047/pid_2973: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1047: Permission denied
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1017/pid_3000: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1017: Permission denied
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2999: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_3018: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2957: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2985: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_3026: Device or resource busy
10-29 06:02:21.805 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2351: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_3024: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2885: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2883: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_3037: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2958: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2986: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2863: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2966: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0/pid_2956: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_0: Permission denied
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013/pid_3016: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2993: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2976: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2974: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2992: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1013: Permission denied
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1041/pid_2991: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1041/pid_2968: Device or resource busy
10-29 06:02:21.806 3126 3126 W libprocessgroup: Failed to remove /acct/uid_1041: Permission denied
10-29 06:02:21.808 3126 3126 D AppOps : AppOpsService published
10-29 06:02:21.808 3126 3126 D SystemServerTiming: StartActivityManager took to complete: 167ms
10-29 06:02:21.808 3126 3126 I SystemServer: StartPowerManager
10-29 06:02:21.808 3126 3126 I SystemServiceManager: Starting com.android.server.power.PowerManagerService
10-29 06:02:21.812 3126 3126 D SystemServerTiming: StartPowerManager took to complete: 4ms
10-29 06:02:21.812 3126 3126 I SystemServer: InitPowerManagement
10-29 06:02:21.813 3126 3126 D SystemServerTiming: InitPowerManagement took to complete: 1ms
10-29 06:02:21.813 3126 3126 I SystemServer: StartRecoverySystemService
10-29 06:02:21.813 3126 3126 I SystemServiceManager: Starting com.android.server.RecoverySystemService
10-29 06:02:21.814 3126 3126 D SystemServerTiming: StartRecoverySystemService took to complete: 1ms
10-29 06:02:21.815 3126 3126 V RescueParty: Disabled because of active USB connection
10-29 06:02:21.815 3126 3126 I SystemServer: StartLightsService
10-29 06:02:21.815 3126 3126 I SystemServiceManager: Starting com.android.server.lights.LightsService
10-29 06:02:21.815 3126 3126 D SystemServerTiming: StartLightsService took to complete: 0ms
10-29 06:02:21.815 3126 3126 I SystemServer: StartSidekickService
10-29 06:02:21.815 3126 3126 D SystemServerTiming: StartSidekickService took to complete: 0ms
10-29 06:02:21.815 3126 3126 I SystemServer: StartDisplayManager
10-29 06:02:21.816 3126 3126 I SystemServiceManager: Starting com.android.server.display.DisplayManagerService
10-29 06:02:21.820 3126 3126 D SystemServerTiming: StartDisplayManager took to complete: 5ms
10-29 06:02:21.820 3126 3126 I SystemServer: WaitForDisplay
10-29 06:02:21.820 3126 3126 I SystemServiceManager: Starting phase 100
10-29 06:02:21.831 3126 3149 I DisplayManagerService: Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 1920 x 1080, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1920, height=1080, fps=60.000004}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@21c1c928, density 213, 320.0 x 320.0 dpi, appVsyncOff 1000000, presDeadline 16666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
10-29 06:02:21.831 2987 2987 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xf78be2258000
10-29 06:02:21.836 3126 3149 E LightsService: Light requested not available on this device. 0
10-29 06:02:21.837 3126 3126 D SystemServerTiming: WaitForDisplay took to complete: 16ms
10-29 06:02:21.837 3126 3149 I DisplayManagerService: Display device changed state: "Built-in Screen", ON
10-29 06:02:21.837 3126 3126 I SystemServer: StartPackageManagerService
10-29 06:02:21.846 3018 3047 I ServiceManager: Waiting for service package_native...
10-29 06:02:21.853 3126 3126 D SELinuxMMAC: Using policy file /system/etc/selinux/plat_mac_permissions.xml
10-29 06:02:21.855 3126 3126 D SELinuxMMAC: Using policy file /vendor/etc/selinux/vendor_mac_permissions.xml
10-29 06:02:21.858 3126 3126 D FallbackCategoryProvider: Found 1 fallback categories
10-29 06:02:22.031 3126 3126 D PackageManager: No files in app dir /product/overlay
10-29 06:02:22.035 3126 3126 W PackageManager: Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
10-29 06:02:22.035 3126 3126 W PackageManager: Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
10-29 06:02:22.035 3126 3126 W PackageManager: Failed to parse /system/framework/arm64: Missing base APK in /system/framework/arm64
10-29 06:02:22.192 3126 3126 D PackageManager: No files in app dir /vendor/priv-app
10-29 06:02:22.199 3126 3126 D PackageManager: No files in app dir /odm/priv-app
10-29 06:02:22.199 3126 3126 D PackageManager: No files in app dir /odm/app
10-29 06:02:22.199 3126 3126 D PackageManager: No files in app dir /oem/app
10-29 06:02:22.200 3126 3126 D PackageManager: No files in app dir /system/product/priv-app
10-29 06:02:22.200 3126 3126 D PackageManager: No files in app dir /system/product/app
10-29 06:02:22.200 3126 3126 I PackageManager: Finished scanning system apps. Time: 180 ms, packageCount: 88 , timePerPackage: 2 , cached: 88
10-29 06:02:22.204 3126 3126 D PackageManager: No files in app dir /data/app-private
10-29 06:02:22.204 3126 3126 I PackageManager: Finished scanning non-system apps. Time: 4 ms, packageCount: 1 , timePerPackage: 4 , cached: 1
10-29 06:02:22.207 3126 3126 I PackageManager: Time to scan packages: 0.187 seconds
10-29 06:02:22.214 3126 3126 V PackageManager: reconcileAppsData for null u0 0x1 migrateAppData=true
10-29 06:02:22.215 2999 2999 W Binder:2999_1: type=1400 audit(0.0:577): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
10-29 06:02:22.241 2999 3028 I SELinux : SELinux: Loaded file_contexts
10-29 06:02:22.243 2999 2999 I chatty : uid=0(root) Binder:2999_2 expire 4 lines
10-29 06:02:22.243 2999 2999 W Binder:2999_1: type=1400 audit(0.0:582): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
10-29 06:02:22.323 3126 3126 V PackageManager: reconcileAppsData finished 21 packages
10-29 06:02:22.323 3126 3175 D SystemServerInitThreadPool: Started executing prepareAppData
10-29 06:02:22.383 3126 3126 E PackageManager: There should probably be a verifier, but, none were found
10-29 06:02:22.386 3126 3126 D PackageManager: Ephemeral resolver NOT found; no matching intent filters
10-29 06:02:22.386 3126 3126 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
10-29 06:02:22.386 3126 3126 D PackageManager: Clear ephemeral installer activity
10-29 06:02:22.402 2999 3028 W installd: Ignoring /data/data/yOM1hV7cMp2jtOxL2xF6T4BsCUbKTugl/ky9km8KxYKq0phCi8Tz8ZC with unexpected GID 0 instead of 10066
10-29 06:02:22.415 2999 3028 W installd: Ignoring /data/data/lbnHpjS8ssVFvvDdN+4RY9VJL9D/q2zUWd4gU3zNozE1sYLfyC with unexpected GID 0 instead of 10042
10-29 06:02:22.464 3126 3126 I system_server: Explicit concurrent copying GC freed 48650(2MB) AllocSpace objects, 21(836KB) LOS objects, 42% free, 3MB/5MB, paused 60us total 72.314ms
10-29 06:02:22.466 3126 3126 D SystemServerTiming: StartPackageManagerService took to complete: 629ms
10-29 06:02:22.466 3126 3126 I SystemServer: StartOtaDexOptService
10-29 06:02:22.467 3126 3126 D OTADexopt: No upgrade, skipping A/B artifacts check.
10-29 06:02:22.467 3126 3126 D SystemServerTiming: StartOtaDexOptService took to complete: 1ms
10-29 06:02:22.467 3126 3126 I SystemServer: StartUserManagerService
10-29 06:02:22.467 3126 3126 I SystemServiceManager: Starting com.android.server.pm.UserManagerService$LifeCycle
10-29 06:02:22.468 3126 3126 D SystemServerTiming: StartUserManagerService took to complete: 1ms
10-29 06:02:22.468 3126 3126 I SystemServer: InitAttributerCache
10-29 06:02:22.468 3126 3126 D SystemServerTiming: InitAttributerCache took to complete: 0ms
10-29 06:02:22.468 3126 3126 I SystemServer: SetSystemProcess
10-29 06:02:22.472 2986 2986 I lowmemorykiller: lmkd data connection established
10-29 06:02:22.473 3126 3126 D SystemServerTiming: SetSystemProcess took to complete: 5ms
10-29 06:02:22.475 3126 3126 I SystemServer: StartOverlayManagerService
10-29 06:02:22.476 3126 3126 D SystemServerTiming: StartOverlayManagerService took to complete: 1ms
10-29 06:02:22.476 3126 3179 D SystemServerInitThreadPool: Started executing Init OverlayManagerService
10-29 06:02:22.476 3126 3126 I SystemServer: StartBatteryService
10-29 06:02:22.476 3126 3126 I SystemServiceManager: Starting com.android.server.BatteryService
10-29 06:02:22.476 3126 3180 D SystemServerInitThreadPool: Started executing StartSensorService
10-29 06:02:22.477 3126 3180 D SensorService: nuSensorService starting...
10-29 06:02:22.479 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISensors/default in either framework or device manifest.
10-29 06:02:22.479 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IHealth
10-29 06:02:22.481 3126 3180 D SystemServerTimingAsync: StartSensorService took to complete: 4ms
10-29 06:02:22.481 3126 3180 D SystemServerInitThreadPool: Finished executing StartSensorService
10-29 06:02:22.483 3126 3175 D SystemServerTimingAsync: AppDataFixup took to complete: 160ms
10-29 06:02:22.490 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:02:22.493 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:02:22.493 2991 2991 E SoundTriggerHwService: could not read implementation properties
10-29 06:02:22.496 3126 3145 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:02:22.497 3126 3145 I chatty : uid=1000(system) batterystats-wo identical 1 line
10-29 06:02:22.500 3126 3145 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:02:22.503 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:02:22.506 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:02:22.507 3126 3126 I HealthServiceWrapper: health: HealthServiceWrapper listening to instance default
10-29 06:02:22.508 3126 3181 E LightsService: Light requested not available on this device. 3
10-29 06:02:22.508 3126 3126 I BatteryService: health: Waited 1ms and received the update.
10-29 06:02:22.509 3126 3126 D SystemServerTiming: StartBatteryService took to complete: 33ms
10-29 06:02:22.509 3126 3188 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IHealth
10-29 06:02:22.509 3126 3126 I SystemServer: StartUsageService
10-29 06:02:22.509 3126 3126 I SystemServiceManager: Starting com.android.server.usage.UsageStatsService
10-29 06:02:22.526 3126 3126 I UsageStatsService: User[0] Rollover scheduled @ 2019-10-30 03:53:29(1572407609595)
10-29 06:02:22.526 3126 3126 D SystemServerTiming: StartUsageService took to complete: 17ms
10-29 06:02:22.526 3126 3126 I SystemServer: StartWebViewUpdateService
10-29 06:02:22.526 3126 3126 I SystemServiceManager: Starting com.android.server.webkit.WebViewUpdateService
10-29 06:02:22.528 3126 3126 D SystemServerTiming: StartWebViewUpdateService took to complete: 2ms
10-29 06:02:22.528 3126 3126 I SystemServer: StartBinderCallsStatsService
10-29 06:02:22.529 3126 3126 D SystemServerTiming: StartBinderCallsStatsService took to complete: 1ms
10-29 06:02:22.529 3126 3126 I SystemServer: StartKeyAttestationApplicationIdProviderService
10-29 06:02:22.529 3126 3139 D SystemServerInitThreadPool: Started executing SecondaryZygotePreload
10-29 06:02:22.530 3126 3139 I SystemServer: SecondaryZygotePreload
10-29 06:02:22.530 3126 3126 D SystemServerTiming: StartKeyAttestationApplicationIdProviderService took to complete: 1ms
10-29 06:02:22.530 3126 3126 I SystemServer: StartKeyChainSystemService
10-29 06:02:22.530 3126 3126 I SystemServiceManager: Starting com.android.server.security.KeyChainSystemService
10-29 06:02:22.531 3126 3126 D SystemServerTiming: StartKeyChainSystemService took to complete: 1ms
10-29 06:02:22.531 3126 3126 I SystemServer: StartSchedulingPolicyService
10-29 06:02:22.531 3126 3180 D SystemServerInitThreadPool: Started executing SchedulingPolicyService.<init>
10-29 06:02:22.536 3126 3180 I SchedulingPolicyService: Moving 3020 back to group default
10-29 06:02:22.536 3126 3180 D SystemServerInitThreadPool: Finished executing SchedulingPolicyService.<init>
10-29 06:02:22.537 3126 3126 D SystemServerTiming: StartSchedulingPolicyService took to complete: 6ms
10-29 06:02:22.537 3126 3126 I SystemServer: StartTelecomLoaderService
10-29 06:02:22.537 3126 3126 I SystemServiceManager: Starting com.android.server.telecom.TelecomLoaderService
10-29 06:02:22.537 3126 3126 D SystemServerTiming: StartTelecomLoaderService took to complete: 0ms
10-29 06:02:22.537 3126 3126 I SystemServer: StartTelephonyRegistry
10-29 06:02:22.539 3126 3126 D SystemServerTiming: StartTelephonyRegistry took to complete: 2ms
10-29 06:02:22.539 3126 3126 I SystemServer: StartEntropyMixer
10-29 06:02:22.540 3126 3139 I Zygote : Process: zygote socket RESERVED/zygote opened, supported ABIS: arm64-v8a
10-29 06:02:22.542 3126 3126 W EntropyMixer: Failed to add HW RNG output to entropy pool
10-29 06:02:22.542 3126 3126 W EntropyMixer: java.io.IOException: read failed: ENODEV (No such device)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at libcore.io.IoBridge.read(IoBridge.java:511)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at java.io.FileInputStream.read(FileInputStream.java:307)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.RandomBlock.fromStream(RandomBlock.java:56)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.RandomBlock.fromFile(RandomBlock.java:46)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.EntropyMixer.addHwRandomEntropy(EntropyMixer.java:205)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.EntropyMixer.<init>(EntropyMixer.java:115)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.EntropyMixer.<init>(EntropyMixer.java:97)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.SystemServer.startOtherServices(SystemServer.java:829)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.SystemServer.run(SystemServer.java:447)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.server.SystemServer.main(SystemServer.java:300)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at java.lang.reflect.Method.invoke(Native Method)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:893)
10-29 06:02:22.542 3126 3126 W EntropyMixer: Caused by: android.system.ErrnoException: read failed: ENODEV (No such device)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at libcore.io.Linux.readBytes(Native Method)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at libcore.io.Linux.read(Linux.java:184)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at libcore.io.BlockGuardOs.read(BlockGuardOs.java:254)
10-29 06:02:22.542 3126 3126 W EntropyMixer: at libcore.io.IoBridge.read(IoBridge.java:501)
10-29 06:02:22.542 3126 3126 W EntropyMixer: ... 12 more
10-29 06:02:22.542 3126 3126 I EntropyMixer: Writing entropy...
10-29 06:02:22.553 3126 3126 D SystemServerTiming: StartEntropyMixer took to complete: 14ms
10-29 06:02:22.553 3126 3126 I SystemServer: StartAccountManagerService
10-29 06:02:22.554 3126 3126 I SystemServiceManager: Starting com.android.server.accounts.AccountManagerService$Lifecycle
10-29 06:02:22.557 3126 3126 D SystemServerTiming: StartAccountManagerService took to complete: 4ms
10-29 06:02:22.557 3126 3126 I SystemServer: StartContentService
10-29 06:02:22.557 3126 3126 I SystemServiceManager: Starting com.android.server.content.ContentService$Lifecycle
10-29 06:02:22.558 3126 3126 D SystemServerTiming: StartContentService took to complete: 1ms
10-29 06:02:22.558 3126 3126 I SystemServer: InstallSystemProviders
10-29 06:02:22.561 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:02:22.561 3018 3047 I storaged: storaged: Start
10-29 06:02:22.562 3018 3047 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:02:22.562 3126 3139 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
10-29 06:02:22.573 2958 2958 I Zygote : Lazily preloading resources.
10-29 06:02:22.573 2958 2958 D Zygote : begin preload
10-29 06:02:22.573 2958 2958 I Zygote : Installing ICU cache reference pinning...
10-29 06:02:22.573 2958 2958 I Zygote : Preloading ICU data...
10-29 06:02:22.573 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:22.590 2958 2958 D ZygoteInitTiming_lazy: BeginIcuCachePinning took to complete: 17ms
10-29 06:02:22.590 2958 2958 I Zygote : Preloading classes...
10-29 06:02:22.593 3126 3126 I SettingsState: No settings state /data/system/users/0/settings_ssaid.xml
10-29 06:02:22.600 3126 3126 D SystemServerTiming: InstallSystemProviders took to complete: 42ms
10-29 06:02:22.600 3126 3126 I SystemServer: StartDropBoxManager
10-29 06:02:22.600 3126 3126 I SystemServiceManager: Starting com.android.server.DropBoxManagerService
10-29 06:02:22.601 3126 3126 D SystemServerTiming: StartDropBoxManager took to complete: 1ms
10-29 06:02:22.601 3126 3126 I SystemServer: StartVibratorService
10-29 06:02:22.602 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVibrator/default in either framework or device manifest.
10-29 06:02:22.603 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVibrator/default in either framework or device manifest.
10-29 06:02:22.603 3126 3126 E VibratorService: vibratorOff command failed (1).
10-29 06:02:22.605 3126 3126 D SystemServerTiming: StartVibratorService took to complete: 4ms
10-29 06:02:22.605 3126 3126 I SystemServer: StartConsumerIrService
10-29 06:02:22.606 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IConsumerIr/default in either framework or device manifest.
10-29 06:02:22.606 3126 3126 D SystemServerTiming: StartConsumerIrService took to complete: 1ms
10-29 06:02:22.607 3126 3126 I SystemServer: StartAlarmManagerService
10-29 06:02:22.607 3126 3126 I SystemServiceManager: Starting com.android.server.AlarmManagerService
10-29 06:02:22.608 3126 3126 D AlarmManagerService: Kernel timezone updated to 0 minutes west of GMT
10-29 06:02:22.611 3126 3126 D SystemServerTiming: StartAlarmManagerService took to complete: 5ms
10-29 06:02:22.611 3126 3126 I SystemServer: InitWatchdog
10-29 06:02:22.611 3126 3126 D SystemServerTiming: InitWatchdog took to complete: 0ms
10-29 06:02:22.611 3126 3126 I SystemServer: StartInputManagerService
10-29 06:02:22.612 3126 3126 I InputManager: Initializing input manager, mUseDevInputEventForAudioJack=false
10-29 06:02:22.612 3126 3126 D SystemServerTiming: StartInputManagerService took to complete: 1ms
10-29 06:02:22.613 3126 3126 I SystemServer: StartWindowManagerService
10-29 06:02:22.615 3126 3149 I WindowManager: No existing display settings /data/system/display_settings.xml; starting empty
10-29 06:02:22.624 3126 3126 D SystemServerTiming: StartWindowManagerService took to complete: 11ms
10-29 06:02:22.625 3126 3126 I SystemServer: SetWindowManagerService
10-29 06:02:22.643 3126 3126 D SystemServerTiming: SetWindowManagerService took to complete: 19ms
10-29 06:02:22.644 3126 3126 I SystemServer: WindowManagerServiceOnInitReady
10-29 06:02:22.673 3126 3126 D SystemServerTiming: WindowManagerServiceOnInitReady took to complete: 29ms
10-29 06:02:22.673 3126 3126 I SystemServer: StartVrManagerService
10-29 06:02:22.673 3126 3126 I SystemServiceManager: Starting com.android.server.vr.VrManagerService
10-29 06:02:22.674 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVr/default in either framework or device manifest.
10-29 06:02:22.674 3126 3126 W VrManagerService: init_native: Could not open IVr interface
10-29 06:02:22.675 3126 3180 D SystemServerInitThreadPool: Started executing StartHidlServices
10-29 06:02:22.675 3126 3126 D SystemServerTiming: StartVrManagerService took to complete: 2ms
10-29 06:02:22.675 3126 3126 I SystemServer: StartInputManager
10-29 06:02:22.675 3126 3126 I InputManager: Starting input manager
10-29 06:02:22.677 3126 3126 D SystemServerTiming: StartInputManager took to complete: 2ms
10-29 06:02:22.677 3126 3126 I SystemServer: DisplayManagerWindowManagerAndInputReady
10-29 06:02:22.677 3126 3126 D SystemServerTiming: DisplayManagerWindowManagerAndInputReady took to complete: 0ms
10-29 06:02:22.677 3126 3126 I SystemServer: StartBluetoothService
10-29 06:02:22.677 3126 3126 I SystemServiceManager: Starting com.android.server.BluetoothService
10-29 06:02:22.678 3126 3126 D BluetoothManagerService: Loading stored name and address
10-29 06:02:22.678 3126 3180 D SystemServerTimingAsync: StartHidlServices took to complete: 4ms
10-29 06:02:22.678 3126 3180 D SystemServerInitThreadPool: Finished executing StartHidlServices
10-29 06:02:22.679 3126 3126 D BluetoothManagerService: Stored bluetooth Name=iMX8,Address=null
10-29 06:02:22.679 3126 3126 D BluetoothManagerService: Bluetooth persisted state: 0
10-29 06:02:22.679 3126 3126 D BluetoothManagerService: Detected SystemUiUid: 10031
10-29 06:02:22.679 3126 3126 D SystemServerTiming: StartBluetoothService took to complete: 2ms
10-29 06:02:22.679 3126 3126 I SystemServer: IpConnectivityMetrics
10-29 06:02:22.679 3126 3126 I SystemServiceManager: Starting com.android.server.connectivity.IpConnectivityMetrics
10-29 06:02:22.680 3126 3126 D SystemServerTiming: IpConnectivityMetrics took to complete: 1ms
10-29 06:02:22.680 3126 3126 I SystemServer: NetworkWatchlistService
10-29 06:02:22.680 3126 3126 I SystemServiceManager: Starting com.android.server.net.watchlist.NetworkWatchlistService$Lifecycle
10-29 06:02:22.681 3126 3196 D EventHub: No input device configuration file found for device '30370000.snvs:snvs-powerkey'.
10-29 06:02:22.683 3126 3126 I WatchlistSettings: Reload watchlist settings done
10-29 06:02:22.684 3126 3126 D SystemServerTiming: NetworkWatchlistService took to complete: 4ms
10-29 06:02:22.684 3126 3198 I WatchlistLoggingHandler: No need to aggregate record yet.
10-29 06:02:22.684 3126 3126 I SystemServer: PinnerService
10-29 06:02:22.684 3126 3198 I WatchlistLoggingHandler: Milliseconds spent on tryAggregateRecords(): 0
10-29 06:02:22.684 3126 3126 I SystemServiceManager: Starting com.android.server.PinnerService
10-29 06:02:22.687 3126 3126 D SystemServerTiming: PinnerService took to complete: 3ms
10-29 06:02:22.687 3126 3126 I SystemServer: StartInputMethodManagerLifecycle
10-29 06:02:22.687 3126 3126 I SystemServiceManager: Starting com.android.server.InputMethodManagerService$Lifecycle
10-29 06:02:22.688 3126 3196 W EventHub: Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
10-29 06:02:22.688 3126 3196 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
10-29 06:02:22.688 3126 3196 I EventHub: New device: id=1, fd=111, path='/dev/input/event0', name='30370000.snvs:snvs-powerkey', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false,
10-29 06:02:22.693 3126 3126 D SystemServerTiming: StartInputMethodManagerLifecycle took to complete: 6ms
10-29 06:02:22.693 3126 3126 I SystemServer: StartAccessibilityManagerService
10-29 06:02:22.695 2958 2958 I Zygote : ...preloaded 0 classes in 105ms.
10-29 06:02:22.695 2958 2958 I zygote : VMRuntime.preloadDexCaches starting
10-29 06:02:22.696 3126 3126 D SystemServerTiming: StartAccessibilityManagerService took to complete: 3ms
10-29 06:02:22.696 3126 3126 I SystemServer: MakeDisplayReady
10-29 06:02:22.697 3126 3126 I ActivityManager: Config changes=20005df8 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2}
10-29 06:02:22.706 3126 3126 I ActivityManager: Override config changes=60007dfc {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2} for displayId=0
10-29 06:02:22.715 3126 3126 I ActivityManager: Config changes=20000400 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3}
10-29 06:02:22.722 3126 3126 I ActivityManager: Override config changes=20000400 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3} for displayId=0
10-29 06:02:22.730 3126 3126 D SystemServerTiming: MakeDisplayReady took to complete: 34ms
10-29 06:02:22.730 3126 3126 I SystemServer: StartStorageManagerService
10-29 06:02:22.731 3126 3126 I SystemServiceManager: Starting com.android.server.StorageManagerService$Lifecycle
10-29 06:02:22.741 3126 3126 D SystemServerTiming: StartStorageManagerService took to complete: 11ms
10-29 06:02:22.741 3126 3126 I SystemServer: StartStorageStatsService
10-29 06:02:22.741 3126 3126 I SystemServiceManager: Starting com.android.server.usage.StorageStatsService$Lifecycle
10-29 06:02:22.743 2999 3185 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:02:22.743 3126 3204 D StorageManagerService: Thinking about init, mSystemReady=false, mDaemonConnected=true
10-29 06:02:22.743 3126 3204 D StorageManagerService: Thinking about reset, mSystemReady=false, mDaemonConnected=true
10-29 06:02:22.744 3126 3126 D SystemServerTiming: StartStorageStatsService took to complete: 3ms
10-29 06:02:22.745 3126 3126 I SystemServer: StartUiModeManager
10-29 06:02:22.745 3126 3126 I SystemServiceManager: Starting com.android.server.UiModeManagerService
10-29 06:02:22.746 3126 3180 D SystemServerInitThreadPool: Started executing UiModeManager.onStart
10-29 06:02:22.746 3126 3180 I ActivityManager: Config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4}
10-29 06:02:22.752 3126 3196 D EventHub: No input device configuration file found for device 'PixArt Lenovo Optical USB Mouse'.
10-29 06:02:22.752 3126 3196 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
10-29 06:02:22.752 3126 3196 I EventHub: New device: id=2, fd=114, path='/dev/input/event1', name='PixArt Lenovo Optical USB Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false,
10-29 06:02:22.753 3126 3126 D SystemServerTiming: StartUiModeManager took to complete: 8ms
10-29 06:02:22.753 3126 3126 I SystemServer: UpdatePackagesIfNeeded
10-29 06:02:22.753 3126 3126 D SystemServerTiming: UpdatePackagesIfNeeded took to complete: 0ms
10-29 06:02:22.753 3126 3126 I SystemServer: PerformFstrimIfNeeded
10-29 06:02:22.754 3126 3126 D SystemServerTiming: PerformFstrimIfNeeded took to complete: 1ms
10-29 06:02:22.754 3126 3126 I SystemServer: StartLockSettingsService
10-29 06:02:22.754 3126 3126 I SystemServiceManager: Starting com.android.server.locksettings.LockSettingsService$Lifecycle
10-29 06:02:22.757 3126 3196 I InputReader: Device added: id=-1, name='Virtual', sources=0x00000301
10-29 06:02:22.764 3126 3196 I InputReader: Device added: id=2, name='PixArt Lenovo Optical USB Mouse', sources=0x00002002
10-29 06:02:22.764 3126 3196 I InputReader: Device added: id=1, name='30370000.snvs:snvs-powerkey', sources=0x00000101
10-29 06:02:22.771 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:02:22.772 3126 3180 I ActivityManager: Override config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4} for displayId=0
10-29 06:02:22.781 3126 3180 D SystemServerInitThreadPool: Finished executing UiModeManager.onStart
10-29 06:02:22.784 3126 3126 D SystemServerTiming: StartLockSettingsService took to complete: 30ms
10-29 06:02:22.784 3126 3126 I SystemServer: StartPersistentDataBlock
10-29 06:02:22.784 3126 3126 I SystemServiceManager: Starting com.android.server.PersistentDataBlockService
10-29 06:02:22.785 3126 3126 D SystemServerTiming: StartPersistentDataBlock took to complete: 0ms
10-29 06:02:22.785 3126 3180 D SystemServerInitThreadPool: Started executing PersistentDataBlockService.onStart
10-29 06:02:22.785 3126 3126 I SystemServer: StartOemLockService
10-29 06:02:22.785 3126 3126 I SystemServiceManager: Starting com.android.server.oemlock.OemLockService
10-29 06:02:22.786 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IOemLock/default in either framework or device manifest.
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: not able to find package
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: android.content.pm.PackageManager$NameNotFoundException:
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:299)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:113)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.server.PersistentDataBlockService.lambda$onStart$0(PersistentDataBlockService.java:126)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.server.-$$Lambda$PersistentDataBlockService$EZl9OYaT2eNL7kfSr2nKUBjxidk.run(Unknown Source:2)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.server.SystemServerInitThreadPool.lambda$submit$0(SystemServerInitThreadPool.java:64)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.server.-$$Lambda$SystemServerInitThreadPool$7wfLGkZF7FvYZv7xj3ghvuiJJGk.run(Unknown Source:4)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:458)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at java.util.concurrent.FutureTask.run(FutureTask.java:266)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
10-29 06:02:22.786 3126 3180 E PersistentDataBlockService: at com.android.internal.util.ConcurrentUtils$1$1.run(ConcurrentUtils.java:62)
10-29 06:02:22.786 3126 3126 I OemLock : OemLock HAL not present on device
10-29 06:02:22.786 3126 3126 I OemLock : Using persistent data block based lock
10-29 06:02:22.787 3126 3126 D SystemServerTiming: StartOemLockService took to complete: 2ms
10-29 06:02:22.787 3126 3126 I SystemServer: StartDeviceIdleController
10-29 06:02:22.788 3126 3126 I SystemServiceManager: Starting com.android.server.DeviceIdleController
10-29 06:02:22.792 3126 3126 D SystemServerTiming: StartDeviceIdleController took to complete: 5ms
10-29 06:02:22.792 3126 3126 I SystemServer: StartDevicePolicyManager
10-29 06:02:22.792 3126 3126 I SystemServiceManager: Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
10-29 06:02:22.804 3126 3126 D SystemServerTiming: StartDevicePolicyManager took to complete: 12ms
10-29 06:02:22.804 3126 3126 I SystemServer: StartStatusBarManagerService
10-29 06:02:22.805 3126 3126 D SystemServerTiming: StartStatusBarManagerService took to complete: 1ms
10-29 06:02:22.805 3126 3126 I SystemServer: StartClipboardService
10-29 06:02:22.805 3126 3126 I SystemServiceManager: Starting com.android.server.clipboard.ClipboardService
10-29 06:02:22.807 3126 3126 D SystemServerTiming: StartClipboardService took to complete: 1ms
10-29 06:02:22.807 3126 3126 I SystemServer: StartNetworkManagementService
10-29 06:02:22.812 3126 3206 I NetworkManagement: onDaemonConnected()
10-29 06:02:22.814 3126 3126 D SystemServerTiming: StartNetworkManagementService took to complete: 7ms
10-29 06:02:22.814 3126 3126 I SystemServer: StartIpSecService
10-29 06:02:22.815 3126 3126 D SystemServerTiming: StartIpSecService took to complete: 1ms
10-29 06:02:22.815 3126 3126 I SystemServer: StartTextServicesManager
10-29 06:02:22.815 3126 3126 I SystemServiceManager: Starting com.android.server.TextServicesManagerService$Lifecycle
10-29 06:02:22.817 3126 3126 D SystemServerTiming: StartTextServicesManager took to complete: 2ms
10-29 06:02:22.817 3126 3126 I SystemServer: StartTextClassificationManagerService
10-29 06:02:22.817 3126 3126 I SystemServiceManager: Starting com.android.server.textclassifier.TextClassificationManagerService$Lifecycle
10-29 06:02:22.818 3126 3126 D SystemServerTiming: StartTextClassificationManagerService took to complete: 1ms
10-29 06:02:22.818 3126 3126 I SystemServer: StartNetworkScoreService
10-29 06:02:22.818 3126 3126 I SystemServiceManager: Starting com.android.server.NetworkScoreService$Lifecycle
10-29 06:02:22.819 3126 3126 I NetworkScoreService: Registering network_score
10-29 06:02:22.820 3126 3126 D SystemServerTiming: StartNetworkScoreService took to complete: 2ms
10-29 06:02:22.820 3126 3126 I SystemServer: StartNetworkStatsService
10-29 06:02:22.821 3126 3180 D SystemServerInitThreadPool: Finished executing PersistentDataBlockService.onStart
10-29 06:02:22.825 3126 3126 D SystemServerTiming: StartNetworkStatsService took to complete: 5ms
10-29 06:02:22.825 3126 3126 I SystemServer: StartNetworkPolicyManagerService
10-29 06:02:22.835 3126 3126 D SystemServerTiming: StartNetworkPolicyManagerService took to complete: 9ms
10-29 06:02:22.835 3126 3126 I SystemServer: StartWifi
10-29 06:02:22.838 3126 3126 I SystemServiceManager: Starting com.android.server.wifi.WifiService
10-29 06:02:22.864 2958 2958 I zygote : VMRuntime.preloadDexCaches strings total=339244 before=12303 after=12303
10-29 06:02:22.864 2958 2958 I zygote : VMRuntime.preloadDexCaches types total=31355 before=7818 after=7820
10-29 06:02:22.864 2958 2958 I zygote : VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
10-29 06:02:22.864 2958 2958 I zygote : VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
10-29 06:02:22.864 2958 2958 I zygote : VMRuntime.preloadDexCaches finished
10-29 06:02:22.870 2958 2958 D ZygoteInitTiming_lazy: PreloadClasses took to complete: 280ms
10-29 06:02:22.937 3126 3134 W System : A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
10-29 06:02:22.937 3126 3134 W System : java.lang.Throwable: Explicit termination method 'close' not called
10-29 06:02:22.937 3126 3134 W System : at dalvik.system.CloseGuard.open(CloseGuard.java:221)
10-29 06:02:22.937 3126 3134 W System : at java.io.FileInputStream.<init>(FileInputStream.java:168)
10-29 06:02:22.937 3126 3134 W System : at com.android.internal.os.AtomicFile.openRead(AtomicFile.java:147)
10-29 06:02:22.937 3126 3134 W System : at com.android.server.storage.CacheQuotaStrategy.setupQuotasFromFile(CacheQuotaStrategy.java:301)
10-29 06:02:22.937 3126 3134 W System : at com.android.server.usage.StorageStatsService$H.handleMessage(StorageStatsService.java:508)
10-29 06:02:22.937 3126 3134 W System : at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:02:22.937 3126 3134 W System : at android.os.Looper.loop(Looper.java:193)
10-29 06:02:22.937 3126 3134 W System : at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:02:22.937 3126 3134 W System : at com.android.server.ServiceThread.run(ServiceThread.java:44)
10-29 06:02:22.938 3126 3136 I system_server: Background concurrent copying GC freed 16055(1415KB) AllocSpace objects, 21(452KB) LOS objects, 42% free, 3MB/6MB, paused 236us total 140.480ms
10-29 06:02:22.950 2958 3107 I zygote : Background concurrent copying GC freed 24536(3MB) AllocSpace objects, 160(2MB) LOS objects, 49% free, 2032KB/3MB, paused 3.122ms total 250.144ms
10-29 06:02:22.958 3126 3126 D WifiApConfigStore: 2G band allowed channels are:1,6,11
10-29 06:02:22.962 2958 3199 I zygote : Thread[6,tid=3199,Native,Thread*=0xebecb000,peer=0x13200220,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
10-29 06:02:22.962 2958 3199 D MtpDeviceJNI: register_android_mtp_MtpDevice
10-29 06:02:22.963 2958 3199 I zygote : Thread[6,tid=3199,Native,Thread*=0xebecb000,peer=0x13200220,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
10-29 06:02:22.969 3126 3179 D SystemServerInitThreadPool: Finished executing Init OverlayManagerService
10-29 06:02:22.982 3126 3126 I WifiScoringParams: rssi2=-85:-85:-73:-60,rssi5=-82:-82:-70:-57,pps=0:1:100,horizon=15,nud=8,expid=0
10-29 06:02:23.034 3126 3126 D WifiStateMachine: EnableConnectedMacRandomization Setting changed to false
10-29 06:02:23.034 3126 3126 E WifiStateMachine: getWifiLinkLayerStats called without an interface
10-29 06:02:23.035 3126 3126 D WifiStateMachinePrime: Starting Wifi in WifiDisabledState
10-29 06:02:23.035 3126 3214 D WifiStateMachinePrime: Entering WifiDisabledState
10-29 06:02:23.035 3126 3214 D ActiveModeManager: sending scan available broadcast: false
10-29 06:02:23.037 3126 3126 D WifiOpenNetworkNotifier: Settings toggle enabled=true
10-29 06:02:23.038 3126 3126 D WifiCarrierNetworkNotifier: Settings toggle enabled=true
10-29 06:02:23.039 3126 3126 D WakeupController: WifiWake enabled
10-29 06:02:23.041 3126 3126 D WifiController: isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false, isLocationModeActive = true
10-29 06:02:23.047 3126 3126 E SupplicantStaIfaceHal: Can't call setDebugParams, ISupplicant is null
10-29 06:02:23.048 3126 3126 W WifiDiags: no ring buffers found
10-29 06:02:23.048 3126 3126 W WifiDiags: Failed to start packet fate monitoring
10-29 06:02:23.048 3126 3126 I WifiService: Registering wifi
10-29 06:02:23.049 3126 3126 D SystemServerTiming: StartWifi took to complete: 214ms
10-29 06:02:23.049 3126 3126 I SystemServer: StartWifiScanning
10-29 06:02:23.050 3126 3126 I SystemServiceManager: Starting com.android.server.wifi.scanner.WifiScanningService
10-29 06:02:23.050 3126 3126 I WifiScanningService: Creating wifiscanner
10-29 06:02:23.051 3126 3126 I WifiScanningService: Publishing wifiscanner
10-29 06:02:23.052 3126 3126 D SystemServerTiming: StartWifiScanning took to complete: 3ms
10-29 06:02:23.052 3126 3126 I SystemServer: StartWifiP2P
10-29 06:02:23.053 3126 3126 I SystemServiceManager: Starting com.android.server.wifi.p2p.WifiP2pService
10-29 06:02:23.063 3126 3126 W HalDevMgr: isWifiStarted called but mWifi is null!?
10-29 06:02:23.063 3126 3126 I WifiP2pService: Registering wifip2p
10-29 06:02:23.064 3126 3126 D SystemServerTiming: StartWifiP2P took to complete: 12ms
10-29 06:02:23.064 3126 3126 I SystemServer: StartEthernet
10-29 06:02:23.065 3126 3126 I SystemServiceManager: Starting com.android.server.ethernet.EthernetService
10-29 06:02:23.065 3126 3126 I EthernetService: Registering service ethernet
10-29 06:02:23.066 3126 3126 D SystemServerTiming: StartEthernet took to complete: 2ms
10-29 06:02:23.066 3126 3126 I SystemServer: StartConnectivityService
10-29 06:02:23.066 2958 2958 I Zygote : Preloading resources...
10-29 06:02:23.068 3126 3126 D ConnectivityService: ConnectivityService starting up
10-29 06:02:23.070 3126 3126 D ConnectivityService: wifiOnly=true
10-29 06:02:23.070 3126 3126 E ConnectivityService: Ignoring protectedNetwork 10
10-29 06:02:23.070 3126 3126 E ConnectivityService: Ignoring protectedNetwork 11
10-29 06:02:23.070 3126 3126 E ConnectivityService: Ignoring protectedNetwork 12
10-29 06:02:23.070 3126 3126 E ConnectivityService: Ignoring protectedNetwork 14
10-29 06:02:23.070 3126 3126 E ConnectivityService: Ignoring protectedNetwork 15
10-29 06:02:23.085 3126 3126 D SystemServerTiming: StartConnectivityService took to complete: 19ms
10-29 06:02:23.085 3126 3126 I SystemServer: StartNsdService
10-29 06:02:23.087 3126 3126 D NsdService: Network service discovery is enabled
10-29 06:02:23.094 3126 3126 D SystemServerTiming: StartNsdService took to complete: 9ms
10-29 06:02:23.094 3126 3126 I SystemServer: StartSystemUpdateManagerService
10-29 06:02:23.095 3126 3126 I SystemUpdateManagerService: No existing info file /data/system/system-update-info.xml
10-29 06:02:23.096 3126 3126 D SystemServerTiming: StartSystemUpdateManagerService took to complete: 2ms
10-29 06:02:23.096 3126 3126 I SystemServer: StartUpdateLockService
10-29 06:02:23.097 3126 3126 D SystemServerTiming: StartUpdateLockService took to complete: 1ms
10-29 06:02:23.097 3126 3126 I SystemServer: StartNotificationManager
10-29 06:02:23.097 3126 3126 I SystemServiceManager: Starting com.android.server.notification.NotificationManagerService
10-29 06:02:23.104 3126 3126 D ConditionProviders.SCP: new ScheduleConditionProvider()
10-29 06:02:23.105 2958 2958 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
10-29 06:02:23.106 3126 3175 D SystemServerTimingAsync: AppDataPrepare took to complete: 623ms
10-29 06:02:23.106 3126 3175 I PackageManager: Deferred reconcileAppsData finished 68 packages
10-29 06:02:23.106 3126 3175 D SystemServerInitThreadPool: Finished executing prepareAppData
10-29 06:02:23.117 3126 3126 I NotificationListeners: Read notification listener permissions from xml
10-29 06:02:23.117 3126 3126 I NotificationAssistants: Read notification assistant permissions from xml
10-29 06:02:23.117 3126 3126 I ConditionProviders: Read condition provider permissions from xml
10-29 06:02:23.123 3126 3126 D SystemServerTiming: StartNotificationManager took to complete: 26ms
10-29 06:02:23.124 3126 3126 I SystemServer: StartDeviceMonitor
10-29 06:02:23.124 3126 3126 I SystemServiceManager: Starting com.android.server.storage.DeviceStorageMonitorService
10-29 06:02:23.126 3126 3126 D SystemServerTiming: StartDeviceMonitor took to complete: 2ms
10-29 06:02:23.126 3126 3126 I SystemServer: StartLocationManagerService
10-29 06:02:23.127 3126 3126 D SystemServerTiming: StartLocationManagerService took to complete: 1ms
10-29 06:02:23.127 3126 3126 I SystemServer: StartCountryDetectorService
10-29 06:02:23.128 3126 3126 D SystemServerTiming: StartCountryDetectorService took to complete: 1ms
10-29 06:02:23.128 3126 3126 I SystemServer: StartSearchManagerService
10-29 06:02:23.129 3126 3126 I SystemServiceManager: Starting com.android.server.search.SearchManagerService$Lifecycle
10-29 06:02:23.130 3126 3126 D SystemServerTiming: StartSearchManagerService took to complete: 2ms
10-29 06:02:23.130 3126 3126 I SystemServer: StartWallpaperManagerService
10-29 06:02:23.131 3126 3126 I SystemServiceManager: Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
10-29 06:02:23.132 3126 3126 D SystemServerTiming: StartWallpaperManagerService took to complete: 2ms
10-29 06:02:23.133 3126 3126 I SystemServer: StartAudioService
10-29 06:02:23.133 3126 3126 I SystemServiceManager: Starting com.android.server.audio.AudioService$Lifecycle
10-29 06:02:23.138 3126 3126 W TelecomManager: Telecom Service not found.
10-29 06:02:23.141 2991 2991 D PermissionCache: checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (895 us)
10-29 06:02:23.143 2991 3095 W AudioFlinger: no wake lock to update, system not ready yet
10-29 06:02:23.144 2968 3092 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:02:23.144 2991 3086 D PermissionCache: checking android.permission.MODIFY_AUDIO_ROUTING for uid=1000 => granted (743 us)
10-29 06:02:23.154 2958 2958 I Zygote : ...preloaded 64 resources in 88ms.
10-29 06:02:23.167 2958 2958 I Zygote : ...preloaded 41 resources in 13ms.
10-29 06:02:23.167 2958 2958 D ZygoteInitTiming_lazy: PreloadResources took to complete: 296ms
10-29 06:02:23.170 2991 2991 D AudioFlinger: isLowRamDevice:false totalMemory:3008249856 mClientSharedHeapSize:8388608
10-29 06:02:23.173 3126 3126 D SystemServerTiming: StartAudioService took to complete: 40ms
10-29 06:02:23.174 3126 3126 I SystemServer: StartDockObserver
10-29 06:02:23.174 3126 3126 I SystemServiceManager: Starting com.android.server.DockObserver
10-29 06:02:23.174 3126 3126 W DockObserver: This kernel does not have dock station support
10-29 06:02:23.175 3126 3126 D SystemServerTiming: StartDockObserver took to complete: 1ms
10-29 06:02:23.176 3126 3126 I SystemServer: StartWiredAccessoryManager
10-29 06:02:23.177 3126 3126 W WiredAccessoryManager: This kernel does not have wired headset support
10-29 06:02:23.178 3126 3126 W WiredAccessoryManager: This kernel does not have usb audio support
10-29 06:02:23.178 3126 3126 W WiredAccessoryManager: This kernel does not have HDMI audio support
10-29 06:02:23.178 3126 3126 D SystemServerTiming: StartWiredAccessoryManager took to complete: 2ms
10-29 06:02:23.178 3126 3126 I SystemServer: StartUsbService
10-29 06:02:23.178 3126 3126 I SystemServiceManager: Starting com.android.server.usb.UsbService$Lifecycle
10-29 06:02:23.179 3126 3126 E UsbDeviceManager: failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
10-29 06:02:23.181 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:02:23.207 3126 3126 W StorageManagerService: No primary storage defined yet; hacking together a stub
10-29 06:02:23.209 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:02:23.210 3126 3181 I UsbDeviceManager: Usb gadget hal service started [email protected]::IUsbGadget default
10-29 06:02:23.211 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:02:23.212 3126 3147 E UsbDeviceManager: prcessing MSG_GET_CURRENT_USB_FUNCTIONS
10-29 06:02:23.212 3126 3147 E UsbDeviceManager: updating mCurrentFunctions
10-29 06:02:23.213 3126 3147 E UsbDeviceManager: mCurrentFunctions:0applied:1
10-29 06:02:23.213 3126 3181 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:02:23.230 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:02:23.231 3126 3181 I UsbPortManager: Usb hal service started [email protected]::IUsb default
10-29 06:02:23.232 2958 2958 D libEGL : loaded /vendor/lib/egl/libEGL_VIVANTE.so
10-29 06:02:23.233 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsb
10-29 06:02:23.237 3126 3126 W SystemServiceManager: Service com.android.server.usb.UsbService$Lifecycle took 58 ms in onStart
10-29 06:02:23.237 3126 3126 D SystemServerTiming: StartUsbService took to complete: 58ms
10-29 06:02:23.237 2985 2985 I [email protected]: registering callback
10-29 06:02:23.237 3126 3126 I SystemServer: StartSerialService
10-29 06:02:23.237 2985 3233 E [email protected]: creating thread
10-29 06:02:23.237 2985 2985 I [email protected]: port0
10-29 06:02:23.237 3126 3126 D SystemServerTiming: StartSerialService took to complete: 0ms
10-29 06:02:23.237 3126 3126 I SystemServer: StartHardwarePropertiesManagerService
10-29 06:02:23.238 2985 2985 I [email protected]: connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
10-29 06:02:23.239 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IThermal/default in either framework or device manifest.
10-29 06:02:23.239 3126 3126 E HardwarePropertiesManagerService-JNI: Unable to get Thermal service.
10-29 06:02:23.240 3126 3126 D SystemServerTiming: StartHardwarePropertiesManagerService took to complete: 3ms
10-29 06:02:23.240 3126 3126 I SystemServer: StartTwilightService
10-29 06:02:23.240 3126 3126 I SystemServiceManager: Starting com.android.server.twilight.TwilightService
10-29 06:02:23.240 3126 3126 D SystemServerTiming: StartTwilightService took to complete: 0ms
10-29 06:02:23.241 3126 3126 I SystemServer: StartJobScheduler
10-29 06:02:23.241 3126 3126 I SystemServiceManager: Starting com.android.server.job.JobSchedulerService
10-29 06:02:23.243 3126 3126 D JobStore: Start tag: job-info
10-29 06:02:23.245 3126 3126 I JobStore: Read 2 jobs
10-29 06:02:23.252 3126 3126 D SystemServerTiming: StartJobScheduler took to complete: 11ms
10-29 06:02:23.253 3126 3126 I SystemServer: StartSoundTrigger
10-29 06:02:23.253 3126 3126 I SystemServiceManager: Starting com.android.server.soundtrigger.SoundTriggerService
10-29 06:02:23.254 3126 3126 D SystemServerTiming: StartSoundTrigger took to complete: 1ms
10-29 06:02:23.254 3126 3126 I SystemServer: StartTrustManager
10-29 06:02:23.254 3126 3126 I SystemServiceManager: Starting com.android.server.trust.TrustManagerService
10-29 06:02:23.256 3126 3126 D SystemServerTiming: StartTrustManager took to complete: 2ms
10-29 06:02:23.256 3126 3126 I SystemServer: StartBackupManager
10-29 06:02:23.256 3126 3126 I SystemServiceManager: Starting com.android.server.backup.BackupManagerService$Lifecycle
10-29 06:02:23.257 3126 3126 D SystemServerTiming: StartBackupManager took to complete: 1ms
10-29 06:02:23.257 3126 3126 I SystemServer: StartAppWidgerService
10-29 06:02:23.257 3126 3126 I SystemServiceManager: Starting com.android.server.appwidget.AppWidgetService
10-29 06:02:23.259 3126 3126 D OpenGLRenderer: Skia GL Pipeline
10-29 06:02:23.261 3126 3126 D SystemServerTiming: StartAppWidgerService took to complete: 4ms
10-29 06:02:23.261 3126 3126 I SystemServer: StartVoiceRecognitionManager
10-29 06:02:23.261 3126 3126 I SystemServiceManager: Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
10-29 06:02:23.262 3126 3126 D SystemServerTiming: StartVoiceRecognitionManager took to complete: 1ms
10-29 06:02:23.262 3126 3126 I SystemServer: StartGestureLauncher
10-29 06:02:23.262 3126 3126 I SystemServiceManager: Starting com.android.server.GestureLauncherService
10-29 06:02:23.262 3126 3126 D SystemServerTiming: StartGestureLauncher took to complete: 0ms
10-29 06:02:23.262 3126 3126 I SystemServer: StartSensorNotification
10-29 06:02:23.262 3126 3126 I SystemServiceManager: Starting com.android.server.SensorNotificationService
10-29 06:02:23.263 3126 3126 D SystemServerTiming: StartSensorNotification took to complete: 0ms
10-29 06:02:23.263 3126 3126 I SystemServer: StartContextHubSystemService
10-29 06:02:23.263 3126 3126 I SystemServiceManager: Starting com.android.server.ContextHubSystemService
10-29 06:02:23.263 3126 3126 D SystemServerTiming: StartContextHubSystemService took to complete: 0ms
10-29 06:02:23.263 3126 3126 I SystemServer: StartDiskStatsService
10-29 06:02:23.264 3126 3180 D SystemServerInitThreadPool: Started executing Init ContextHubSystemService
10-29 06:02:23.265 3126 3126 D SystemServerTiming: StartDiskStatsService took to complete: 2ms
10-29 06:02:23.265 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IContexthub/default in either framework or device manifest.
10-29 06:02:23.265 3126 3126 I SystemServer: StartNetworkTimeUpdateService
10-29 06:02:23.266 3126 3180 I ContextHubService: Context Hub HAL service not found
10-29 06:02:23.266 3126 3180 D SystemServerInitThreadPool: Finished executing Init ContextHubSystemService
10-29 06:02:23.267 3126 3126 D SystemServerTiming: StartNetworkTimeUpdateService took to complete: 2ms
10-29 06:02:23.267 3126 3126 I SystemServer: StartCommonTimeManagementService
10-29 06:02:23.268 3126 3126 D SystemServerTiming: StartCommonTimeManagementService took to complete: 1ms
10-29 06:02:23.269 3126 3126 I SystemServer: CertBlacklister
10-29 06:02:23.269 3126 3126 D SystemServerTiming: CertBlacklister took to complete: 1ms
10-29 06:02:23.269 3126 3126 I SystemServer: StartEmergencyAffordanceService
10-29 06:02:23.270 3126 3126 I SystemServiceManager: Starting com.android.server.emergency.EmergencyAffordanceService
10-29 06:02:23.270 3126 3126 D SystemServerTiming: StartEmergencyAffordanceService took to complete: 1ms
10-29 06:02:23.270 3126 3126 I SystemServer: StartDreamManager
10-29 06:02:23.270 3126 3126 I SystemServiceManager: Starting com.android.server.dreams.DreamManagerService
10-29 06:02:23.271 3126 3126 D SystemServerTiming: StartDreamManager took to complete: 1ms
10-29 06:02:23.271 3126 3126 I SystemServer: AddGraphicsStatsService
10-29 06:02:23.274 3126 3126 D SystemServerTiming: AddGraphicsStatsService took to complete: 3ms
10-29 06:02:23.275 3126 3126 I SystemServer: StartPrintManager
10-29 06:02:23.275 3126 3126 I SystemServiceManager: Starting com.android.server.print.PrintManagerService
10-29 06:02:23.277 3126 3126 D SystemServerTiming: StartPrintManager took to complete: 2ms
10-29 06:02:23.277 3126 3126 I SystemServer: StartCompanionDeviceManager
10-29 06:02:23.278 3126 3126 I SystemServiceManager: Starting com.android.server.companion.CompanionDeviceManagerService
10-29 06:02:23.279 3126 3126 D SystemServerTiming: StartCompanionDeviceManager took to complete: 2ms
10-29 06:02:23.279 3126 3126 I SystemServer: StartRestrictionManager
10-29 06:02:23.280 3126 3126 I SystemServiceManager: Starting com.android.server.restrictions.RestrictionsManagerService
10-29 06:02:23.280 3126 3126 D SystemServerTiming: StartRestrictionManager took to complete: 1ms
10-29 06:02:23.281 3126 3126 I SystemServer: StartMediaSessionService
10-29 06:02:23.281 3126 3126 I SystemServiceManager: Starting com.android.server.media.MediaSessionService
10-29 06:02:23.283 3126 3126 D SystemServerTiming: StartMediaSessionService took to complete: 3ms
10-29 06:02:23.283 3126 3126 I SystemServer: StartMediaUpdateService
10-29 06:02:23.284 3126 3126 I SystemServiceManager: Starting com.android.server.media.MediaUpdateService
10-29 06:02:23.285 3126 3126 D SystemServerTiming: StartMediaUpdateService took to complete: 2ms
10-29 06:02:23.285 3126 3126 I SystemServer: StartMediaResourceMonitor
10-29 06:02:23.285 3126 3126 I SystemServiceManager: Starting com.android.server.media.MediaResourceMonitorService
10-29 06:02:23.286 3126 3126 D SystemServerTiming: StartMediaResourceMonitor took to complete: 0ms
10-29 06:02:23.286 3126 3126 I SystemServer: StartMediaRouterService
10-29 06:02:23.287 3126 3126 D SystemServerTiming: StartMediaRouterService took to complete: 1ms
10-29 06:02:23.287 3126 3126 I SystemServer: StartBackgroundDexOptService
10-29 06:02:23.287 3126 3126 W BackgroundDexOptService: SysProp pm.dexopt.downgrade_after_inactive_days not set
10-29 06:02:23.288 3126 3126 D SystemServerTiming: StartBackgroundDexOptService took to complete: 1ms
10-29 06:02:23.288 3126 3126 I SystemServer: StartPruneInstantAppsJobService
10-29 06:02:23.288 3126 3126 D SystemServerTiming: StartPruneInstantAppsJobService took to complete: 0ms
10-29 06:02:23.288 3126 3126 I SystemServer: StartShortcutServiceLifecycle
10-29 06:02:23.288 3126 3126 I SystemServiceManager: Starting com.android.server.pm.ShortcutService$Lifecycle
10-29 06:02:23.291 3126 3126 D SystemServerTiming: StartShortcutServiceLifecycle took to complete: 3ms
10-29 06:02:23.291 3126 3126 I SystemServer: StartLauncherAppsService
10-29 06:02:23.291 3126 3126 I SystemServiceManager: Starting com.android.server.pm.LauncherAppsService
10-29 06:02:23.291 2958 2958 D libEGL : loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
10-29 06:02:23.292 3126 3126 D SystemServerTiming: StartLauncherAppsService took to complete: 1ms
10-29 06:02:23.292 3126 3126 I SystemServer: StartCrossProfileAppsService
10-29 06:02:23.292 3126 3126 I SystemServiceManager: Starting com.android.server.pm.CrossProfileAppsService
10-29 06:02:23.293 3126 3126 D SystemServerTiming: StartCrossProfileAppsService took to complete: 1ms
10-29 06:02:23.293 3126 3126 I SystemServer: StartMediaProjectionManager
10-29 06:02:23.293 3126 3126 I SystemServiceManager: Starting com.android.server.media.projection.MediaProjectionManagerService
10-29 06:02:23.294 3126 3126 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:23.295 3126 3126 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:23.296 3126 3126 D SystemServerTiming: StartMediaProjectionManager took to complete: 3ms
10-29 06:02:23.296 3126 3126 I SystemServer: StartSliceManagerService
10-29 06:02:23.296 3126 3126 I SystemServiceManager: Starting com.android.server.slice.SliceManagerService$Lifecycle
10-29 06:02:23.299 3126 3126 D SystemServerTiming: StartSliceManagerService took to complete: 3ms
10-29 06:02:23.299 3126 3126 I SystemServer: StartCameraServiceProxy
10-29 06:02:23.299 3126 3126 I SystemServiceManager: Starting com.android.server.camera.CameraServiceProxy
10-29 06:02:23.302 3126 3126 D SystemServerTiming: StartCameraServiceProxy took to complete: 3ms
10-29 06:02:23.302 3126 3126 I SystemServer: StartStatsCompanionService
10-29 06:02:23.302 3126 3126 I SystemServiceManager: Starting com.android.server.stats.StatsCompanionService$Lifecycle
10-29 06:02:23.303 3126 3126 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:02:23.304 3126 3126 D SystemServerTiming: StartStatsCompanionService took to complete: 2ms
10-29 06:02:23.304 3126 3126 I WindowManager: SAFE MODE not enabled
10-29 06:02:23.304 3126 3126 I SystemServer: StartJitCompilation
10-29 06:02:23.305 3126 3126 D SystemServerTiming: StartJitCompilation took to complete: 0ms
10-29 06:02:23.305 3126 3126 I SystemServer: StartMmsService
10-29 06:02:23.305 3126 3126 I SystemServiceManager: Starting com.android.server.MmsServiceBroker
10-29 06:02:23.306 3126 3126 D SystemServerTiming: StartMmsService took to complete: 1ms
10-29 06:02:23.306 3126 3126 I SystemServer: StartAutoFillService
10-29 06:02:23.306 3126 3126 I SystemServiceManager: Starting com.android.server.autofill.AutofillManagerService
10-29 06:02:23.307 3126 3126 I AutofillManagerService: Setting debug to true
10-29 06:02:23.309 3126 3126 D SystemServerTiming: StartAutoFillService took to complete: 3ms
10-29 06:02:23.309 3126 3126 I SystemServer: MakeVibratorServiceReady
10-29 06:02:23.311 3126 3126 D SystemServerTiming: MakeVibratorServiceReady took to complete: 1ms
10-29 06:02:23.311 3126 3126 I SystemServer: MakeLockSettingsServiceReady
10-29 06:02:23.325 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IWeaver/default in either framework or device manifest.
10-29 06:02:23.326 3126 3126 I SyntheticPasswordManager: Device does not support weaver
10-29 06:02:23.326 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IAuthSecret/default in either framework or device manifest.
10-29 06:02:23.327 3126 3126 I LockSettingsService: Device doesn't implement AuthSecret HAL
10-29 06:02:23.328 3126 3126 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory)
10-29 06:02:23.329 3126 3126 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
10-29 06:02:23.329 3126 3126 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory)
10-29 06:02:23.329 3126 3126 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
10-29 06:02:23.330 3126 3126 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
10-29 06:02:23.330 3126 3126 D SystemServerTiming: MakeLockSettingsServiceReady took to complete: 19ms
10-29 06:02:23.330 3126 3126 I SystemServer: StartBootPhaseLockSettingsReady
10-29 06:02:23.330 3126 3126 I SystemServiceManager: Starting phase 480
10-29 06:02:23.333 3126 3126 I DevicePolicyManager: Set ro.device_owner property to false
10-29 06:02:23.335 3126 3179 D SystemServerInitThreadPool: Started executing DevicePolicyManager
10-29 06:02:23.336 3126 3179 D SystemServerInitThreadPool: Finished executing DevicePolicyManager
10-29 06:02:23.338 3126 3126 D SystemServerTiming: StartBootPhaseLockSettingsReady took to complete: 7ms
10-29 06:02:23.338 3126 3126 I SystemServer: StartBootPhaseSystemServicesReady
10-29 06:02:23.338 3126 3126 I SystemServiceManager: Starting phase 500
10-29 06:02:23.339 3126 3126 D AppStandbyController: Setting app idle enabled state
10-29 06:02:23.343 3126 3126 I VrManagerService: No default vr listener service found.
10-29 06:02:23.348 3126 3126 I WifiService: WifiService starting up with Wi-Fi disabled
10-29 06:02:23.353 3126 3214 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:02:23.354 3126 3181 D HalDevMgr: IWifi registration notification: [email protected]::IWifi, name=default, preexisting=true
10-29 06:02:23.357 3126 3181 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IWifi
10-29 06:02:23.358 3126 3214 D WificondControl: tearing down interfaces in wificond
10-29 06:02:23.362 3126 3126 I WifiScanningService: Starting wifiscanner
10-29 06:02:23.366 3126 3126 I EthernetServiceImpl: Starting Ethernet service
10-29 06:02:23.370 3126 3126 D Ethernet: Registering NetworkFactory
10-29 06:02:23.371 3126 3219 D ConnectivityService: Got NetworkFactory Messenger for Ethernet
10-29 06:02:23.371 3126 3239 D Ethernet: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:23.372 3126 3126 E IpConfigStore: Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
10-29 06:02:23.375 3126 3239 I EthernetTracker: maybeTrackInterface eth0
10-29 06:02:23.376 2956 3011 D CommandListener: Setting iface cfg
10-29 06:02:23.377 2956 3011 D CommandListener: Trying to bring up eth0
10-29 06:02:23.387 2991 2991 D PermissionCache: checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (183 us)
10-29 06:02:23.387 3126 3126 W SoundTriggerHelper: listModules status=0, # of modules=0
10-29 06:02:23.389 3126 3126 D ContextHubSystemService: onBootPhase: PHASE_SYSTEM_SERVICES_READY
10-29 06:02:23.389 3126 3126 D SystemServerTiming: StartBootPhaseSystemServicesReady took to complete: 51ms
10-29 06:02:23.390 3126 3126 I SystemServer: MakeWindowManagerServiceReady
10-29 06:02:23.394 2956 3011 E CommandListener: Error upping interface
10-29 06:02:23.395 3126 3126 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::ISurfaceFlingerConfigs
10-29 06:02:23.395 3126 3239 E EthernetTracker: Error upping interface eth0
10-29 06:02:23.395 3126 3239 E EthernetTracker: java.lang.IllegalStateException: command '3 interface setcfg eth0 0.0.0.0 0 broadcast up multicast' failed with '400 3 Failed to up interface (No such device)'
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:1066)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceUp(NetworkManagementService.java:1083)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.addInterface(EthernetTracker.java:178)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.maybeTrackInterface(EthernetTracker.java:252)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.trackAvailableInterfaces(EthernetTracker.java:259)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.lambda$7ZSuSvoSqcExye5DLwv_gyq6gyM(Unknown Source:0)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.ethernet.-$$Lambda$EthernetTracker$7ZSuSvoSqcExye5DLwv_gyq6gyM.run(Unknown Source:2)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at android.os.Handler.handleCallback(Handler.java:873)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at android.os.Handler.dispatchMessage(Handler.java:99)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at android.os.Looper.loop(Looper.java:193)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:02:23.395 3126 3239 E EthernetTracker: Caused by: com.android.server.NativeDaemonConnector$NativeDaemonFailureException: command '3 interface setcfg eth0 0.0.0.0 0 broadcast up multicast' failed with '400 3 Failed to up interface (No such device)'
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NativeDaemonConnector.executeForList(NativeDaemonConnector.java:515)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:411)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:406)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:391)
10-29 06:02:23.395 3126 3239 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:1064)
10-29 06:02:23.395 3126 3239 E EthernetTracker: ... 10 more
10-29 06:02:23.395 3126 3239 E EthernetTracker: Null interface config for eth0. Bailing out.
10-29 06:02:23.395 3126 3239 I EthernetTracker: maybeTrackInterface ip6_vti0
10-29 06:02:23.395 3126 3239 I EthernetTracker: maybeTrackInterface ip6tnl0
10-29 06:02:23.395 3126 3239 I EthernetTracker: maybeTrackInterface ip_vti0
10-29 06:02:23.395 3126 3239 I EthernetTracker: maybeTrackInterface lo
10-29 06:02:23.396 3126 3239 I EthernetTracker: maybeTrackInterface sit0
10-29 06:02:23.396 3126 3126 D SystemServerTiming: MakeWindowManagerServiceReady took to complete: 5ms
10-29 06:02:23.396 3126 3126 I SystemServer: MakePowerManagerServiceReady
10-29 06:02:23.404 3126 3151 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
10-29 06:02:23.407 3126 3126 D SystemServerTiming: MakePowerManagerServiceReady took to complete: 11ms
10-29 06:02:23.407 3126 3126 I SystemServer: MakePackageManagerServiceReady
10-29 06:02:23.410 2958 2958 D libEGL : loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
10-29 06:02:23.421 3126 3126 V UserDataPreparer: Found /data/user_de/0 with serial number 0
10-29 06:02:23.421 3126 3126 V UserDataPreparer: Found /data/user/0 with serial number 0
10-29 06:02:23.421 3126 3126 V UserDataPreparer: Found /data/system_de/0 with serial number 0
10-29 06:02:23.421 3126 3126 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
10-29 06:02:23.421 3126 3126 V UserDataPreparer: Found /data/misc_ce/0 with serial number 0
10-29 06:02:23.422 3126 3126 D SystemServerTiming: MakePackageManagerServiceReady took to complete: 14ms
10-29 06:02:23.422 3126 3126 I SystemServer: MakeDisplayManagerServiceReady
10-29 06:02:23.422 3126 3126 D SystemServerTiming: MakeDisplayManagerServiceReady took to complete: 0ms
10-29 06:02:23.422 3126 3126 I SystemServer: StartDeviceSpecificServices
10-29 06:02:23.422 3126 3126 D SystemServerTiming: StartDeviceSpecificServices took to complete: 0ms
10-29 06:02:23.422 3126 3126 I SystemServer: StartBootPhaseDeviceSpecificServicesReady
10-29 06:02:23.422 3126 3126 I SystemServiceManager: Starting phase 520
10-29 06:02:23.422 3126 3126 D SystemServerTiming: StartBootPhaseDeviceSpecificServicesReady took to complete: 0ms
10-29 06:02:23.423 3126 3126 W UsageStatsService: Event reported without a package name
10-29 06:02:23.425 3126 3126 I AppOps : Pruning old package system/com.android.server.AppOpsService$UidState@2fe08d6: new uid=-1
10-29 06:02:23.426 3126 3126 I ActivityManager: System now ready
10-29 06:02:23.429 3126 3126 I SystemServer: Making services ready
10-29 06:02:23.429 3126 3126 I SystemServer: StartActivityManagerReadyPhase
10-29 06:02:23.429 3126 3126 I SystemServiceManager: Starting phase 550
10-29 06:02:23.432 3126 3126 W ActivityManager: Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
10-29 06:02:23.436 3126 3214 D WifiStateMachinePrime: received a message in WifiDisabledState: { when=-1ms what=3 target=com.android.internal.util.StateMachine$SmHandler }
10-29 06:02:23.436 3126 3214 D WifiStateMachinePrime: Switching from WifiDisabledState to WifiDisabled
10-29 06:02:23.436 3126 3214 D WifiStateMachinePrime: Entering WifiDisabledState
10-29 06:02:23.436 3126 3214 D ActiveModeManager: sending scan available broadcast: false
10-29 06:02:23.464 3126 3126 D BluetoothManagerService: Bluetooth boot completed
10-29 06:02:23.464 3126 3126 D BluetoothManagerService: Getting adapter name and address
10-29 06:02:23.464 3126 3148 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
10-29 06:02:23.464 3126 3148 D BluetoothManagerService: Binding to service to get name and address
10-29 06:02:23.525 2958 2958 I Zygote : Preloading shared libraries...
10-29 06:02:23.533 3126 3133 W JHwRemoteBinder: BinderProxy is being destroyed but the application did not call unlinkToDeath to unlink all of its death recipients beforehand. Releasing leaked death recipient: com.android.server.usb.UsbDeviceManager$UsbHandlerHal$UsbGadgetDeathRecipient
10-29 06:02:23.533 2958 2958 I Zygote : Uninstalled ICU cache reference pinning...
10-29 06:02:23.536 2958 2958 I Zygote : Installed AndroidKeyStoreProvider in 3ms.
10-29 06:02:23.549 3126 3126 W SystemServiceManager: Service com.android.server.InputMethodManagerService$Lifecycle took 84 ms in onBootPhase
10-29 06:02:23.550 3126 3204 D StorageManagerService: Thinking about init, mSystemReady=true, mDaemonConnected=true
10-29 06:02:23.550 3126 3204 D StorageManagerService: Thinking about reset, mSystemReady=true, mDaemonConnected=true
10-29 06:02:23.550 3126 3141 I ActivityManager: Force stopping com.android.providers.media appid=10006 user=-1: vold reset
10-29 06:02:23.551 3126 3126 I WallpaperManagerService: No static wallpaper imagery; defaults will be shown
10-29 06:02:23.552 2958 2958 I Zygote : Warmed up JCA providers in 16ms.
10-29 06:02:23.552 2958 2958 D Zygote : end preload
10-29 06:02:23.552 3126 3139 D SystemServerTimingAsync: SecondaryZygotePreload took to complete: 1023ms
10-29 06:02:23.552 3126 3139 D SystemServerInitThreadPool: Finished executing SecondaryZygotePreload
10-29 06:02:23.553 3126 3186 V StorageManagerService: Found primary storage at VolumeInfo{emulated}:
10-29 06:02:23.553 3126 3186 V StorageManagerService: type=EMULATED diskId=null partGuid= mountFlags=0 mountUserId=-1
10-29 06:02:23.553 3126 3186 V StorageManagerService: state=UNMOUNTED
10-29 06:02:23.553 3126 3186 V StorageManagerService: fsType=null fsUuid=null fsLabel=null
10-29 06:02:23.553 3126 3186 V StorageManagerService: path=null internalPath=null
10-29 06:02:23.553 3126 3126 E BitmapFactory: Unable to decode stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or directory)
10-29 06:02:23.554 3126 3126 W WallpaperManagerService: Invalid wallpaper data
10-29 06:02:23.554 3126 3126 E WallpaperManagerService: Unable to apply new wallpaper
10-29 06:02:23.556 3126 3126 D SystemServerTiming: StartActivityManagerReadyPhase took to complete: 127ms
10-29 06:02:23.556 2985 2985 I [email protected]: port0
10-29 06:02:23.556 2885 2885 V vold : Waiting for FUSE to spin up...
10-29 06:02:23.557 2985 2985 I [email protected]: connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
10-29 06:02:23.557 3126 3126 I SystemServer: StartObservingNativeCrashes
10-29 06:02:23.557 3126 3181 I UsbPortManager: ClientCallback: port0
10-29 06:02:23.557 2968 3092 D audio_hw_primary: adev_set_parameters: enter: A2dpSuspended=false
10-29 06:02:23.557 2968 3092 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:02:23.558 3126 3227 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
10-29 06:02:23.558 3126 3147 I UsbPortManager: USB port added: port=UsbPort{id=port0, supportedModes=dual}, status=UsbPortStatus{connected=true, currentMode=ufp, currentPowerRole=sink, currentDataRole=device, supportedRoleCombinations=[source:host, sink:device]}, canChangeMode=true, canChangePowerRole=false, canChangeDataRole=false
10-29 06:02:23.558 2968 3092 D audio_hw_primary: adev_set_parameters: enter: BT_SCO=off
10-29 06:02:23.558 2968 3092 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:02:23.560 3126 3227 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:02:23.560 3126 3126 D SystemServerTiming: StartObservingNativeCrashes took to complete: 2ms
10-29 06:02:23.560 3126 3126 I SystemServer: StartSystemUI
10-29 06:02:23.561 3126 3175 D SystemServerInitThreadPool: Started executing WebViewFactoryPreparation
10-29 06:02:23.561 3126 3175 I SystemServer: WebViewFactoryPreparation
10-29 06:02:23.562 3126 3227 E BluetoothHearingAid: Could not bind to Bluetooth Hearing Aid Service with Intent { act=android.bluetooth.IBluetoothHearingAid }
10-29 06:02:23.563 3126 3126 D SystemServerTiming: StartSystemUI took to complete: 3ms
10-29 06:02:23.564 3126 3126 I SystemServer: MakeNetworkManagementServiceReady
10-29 06:02:23.564 3126 3143 W ActivityManager: Slow operation: 98ms so far, now at startProcess: returned from zygote!
10-29 06:02:23.564 2991 3086 I AudioFlinger: systemReady
10-29 06:02:23.565 3126 3247 I UsbDescriptorParser: Unknown Descriptor len: 6 type:0x30
10-29 06:02:23.565 3126 3143 W ActivityManager: Slow operation: 99ms so far, now at startProcess: done updating battery stats
10-29 06:02:23.566 3126 3143 W ActivityManager: Slow operation: 100ms so far, now at startProcess: building log message
10-29 06:02:23.566 3126 3143 I ActivityManager: Start proc 3250:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
10-29 06:02:23.566 3126 3143 W ActivityManager: Slow operation: 100ms so far, now at startProcess: starting to update pids map
10-29 06:02:23.566 3126 3143 W ActivityManager: Slow operation: 100ms so far, now at startProcess: done updating pids map
10-29 06:02:23.567 3250 3250 W main : type=1400 audit(0.0:2353): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:23.570 3126 3126 D NetworkManagement: enabling bandwidth control
10-29 06:02:23.575 3250 3250 I chatty : uid=1002(bluetooth) com.android.bluetooth identical 2 lines
10-29 06:02:23.575 3250 3250 W main : type=1400 audit(0.0:2356): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:23.576 3126 3247 D UsbHostManager: USB device attached: vidpid 17ef:6019 mfg/product/ver/serial PixArt/Lenovo Optical USB Mouse/1.00/null hasAudio/HID/Storage: false/true/false
10-29 06:02:23.579 3126 3175 D WebViewLibraryLoader: Setting new address space to 147551200
10-29 06:02:23.586 3126 3247 D UsbDeviceDescriptor: 1 configs
10-29 06:02:23.587 3126 3247 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/001/002,mVendorId=6127,mProductId=24601,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=PixArt,mProductName=Lenovo Optical USB Mouse,mVersion=1.00,mSerialNumber=null,mConfigurations=[
10-29 06:02:23.587 3126 3247 D UsbHostManager: UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
10-29 06:02:23.587 3126 3247 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
10-29 06:02:23.587 3126 3247 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=4,mInterval=10]]]]
10-29 06:02:23.598 3126 3175 D SystemServerTimingAsync: WebViewFactoryPreparation took to complete: 37ms
10-29 06:02:23.598 3126 3175 D SystemServerInitThreadPool: Finished executing WebViewFactoryPreparation
10-29 06:02:23.599 3259 3259 W main : type=1400 audit(0.0:2357): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:23.599 3248 3248 W sdcard : Device explicitly enabled sdcardfs
10-29 06:02:23.604 3001 3070 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/.) Is a directory
10-29 06:02:23.613 3126 3143 W ActivityManager: Slow operation: 66ms so far, now at startProcess: returned from zygote!
10-29 06:02:23.616 2885 2885 V vold : Waiting for FUSE to spin up...
10-29 06:02:23.619 3001 3070 E linker : library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
10-29 06:02:23.619 3001 3070 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/..) Invalid argument
10-29 06:02:23.624 3126 3143 W ActivityManager: Slow operation: 76ms so far, now at startProcess: done updating battery stats
10-29 06:02:23.624 3126 3143 W ActivityManager: Slow operation: 77ms so far, now at startProcess: building log message
10-29 06:02:23.624 3126 3143 I ActivityManager: Start proc 3259:com.android.inputmethod.latin/u0a47 for service com.android.inputmethod.latin/.LatinIME
10-29 06:02:23.624 3126 3143 W ActivityManager: Slow operation: 77ms so far, now at startProcess: starting to update pids map
10-29 06:02:23.624 3126 3143 W ActivityManager: Slow operation: 77ms so far, now at startProcess: done updating pids map
10-29 06:02:23.624 3126 3143 W ActivityManager: Slow operation: 63ms so far, now at startProcess: asking zygote to start proc
10-29 06:02:23.628 3001 3070 E MediaExtractorFactory: couldn't opendir(/vendor/lib64/extractors)
10-29 06:02:23.656 2993 3075 D StagefrightPluginLoader: Failed to load library: libstagefright_ccodec.so (dlopen failed: library "libstagefright_ccodec.so" not found)
10-29 06:02:23.656 2993 3075 D StagefrightPluginLoader: Handle or CreateInputSurface symbol is null
10-29 06:02:23.656 2993 3075 D StagefrightPluginLoader: Handle or CreateBuilder symbol is null
10-29 06:02:23.661 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.662 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.aac.decoder) in [email protected] process
10-29 06:02:23.672 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.673 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in [email protected] process
10-29 06:02:23.676 2885 2885 V vold : Waiting for FUSE to spin up...
10-29 06:02:23.678 3020 3020 I OMXPlayer: Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
10-29 06:02:23.679 3020 3020 I OMXPlayer: dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
10-29 06:02:23.686 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.687 3020 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amrnb.sw-based) in [email protected] process
10-29 06:02:23.698 3020 3062 I OMXPlayer: SetRoleFormat AMR NB mode.
10-29 06:02:23.701 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.701 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.amrnb.decoder) in [email protected] process
10-29 06:02:23.708 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.709 3020 3062 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in [email protected] process
10-29 06:02:23.712 3020 3062 I OMXPlayer: SetRoleFormat AMR WB mode.
10-29 06:02:23.714 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.714 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.amrwb.decoder) in [email protected] process
10-29 06:02:23.717 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.718 3020 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in [email protected] process
10-29 06:02:23.727 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.727 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.g711.alaw.decoder) in [email protected] process
10-29 06:02:23.733 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.734 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.g711.mlaw.decoder) in [email protected] process
10-29 06:02:23.738 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.739 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.gsm.decoder) in [email protected] process
10-29 06:02:23.745 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.745 3020 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in [email protected] process
10-29 06:02:23.756 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.757 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.mp3.decoder) in [email protected] process
10-29 06:02:23.762 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.762 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.opus.decoder) in [email protected] process
10-29 06:02:23.770 3126 3264 W ZygoteProcess: Got error connecting to zygote, retrying. msg= Connection refused
10-29 06:02:23.771 3126 3143 W system_server: Long monitor contention with owner AsyncTask #1 (3264) at android.os.Process$ProcessStartResult android.os.ZygoteProcess.startViaZygote(java.lang.String, java.lang.String, int, int, int[], int, int, int, java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String, boolean, java.lang.String[])(ZygoteProcess.java:437) waiters=0 in android.os.Process$ProcessStartResult android.os.ZygoteProcess.startViaZygote(java.lang.String, java.lang.String, int, int, int[], int, int, int, java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String, boolean, java.lang.String[]) for 146ms
10-29 06:02:23.777 3314 3314 I WebViewZygoteInit: Starting WebViewZygoteInit
10-29 06:02:23.777 3314 3314 I WebViewZygoteInit: --zygote-socket=com.android.internal.os.WebViewZygoteInit/5d1bdfe6-5b72-4f44-b92d-23c956ea7994
10-29 06:02:23.777 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.777 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.raw.decoder) in [email protected] process
10-29 06:02:23.783 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.783 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 225ms so far, now at startProcess: returned from zygote!
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 226ms so far, now at startProcess: done updating battery stats
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 226ms so far, now at startProcess: building log message
10-29 06:02:23.787 3126 3143 I ActivityManager: Start proc 3327:com.android.systemui/u0a31 for service com.android.systemui/.SystemUIService
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 226ms so far, now at startProcess: starting to update pids map
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 226ms so far, now at startProcess: done updating pids map
10-29 06:02:23.787 3126 3143 W ActivityManager: Slow operation: 190ms so far, now at startProcess: asking zygote to start proc
10-29 06:02:23.790 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.791 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.aac.encoder) in [email protected] process
10-29 06:02:23.800 3126 3143 W ActivityManager: Slow operation: 203ms so far, now at startProcess: returned from zygote!
10-29 06:02:23.801 3126 3143 W ActivityManager: Slow operation: 204ms so far, now at startProcess: done updating battery stats
10-29 06:02:23.801 3126 3143 W ActivityManager: Slow operation: 204ms so far, now at startProcess: building log message
10-29 06:02:23.801 3126 3143 I ActivityManager: Start proc 3338:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
10-29 06:02:23.801 3126 3143 W ActivityManager: Slow operation: 204ms so far, now at startProcess: starting to update pids map
10-29 06:02:23.801 3126 3143 W ActivityManager: Slow operation: 204ms so far, now at startProcess: done updating pids map
10-29 06:02:23.801 3126 3143 W ActivityManager: Slow operation: 204ms so far, now at startProcess: asking zygote to start proc
10-29 06:02:23.803 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.803 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.amrnb.encoder) in [email protected] process
10-29 06:02:23.806 3338 3338 W WebViewLoader-: Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
10-29 06:02:23.813 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.813 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.amrwb.encoder) in [email protected] process
10-29 06:02:23.815 3126 3143 W ActivityManager: Slow operation: 218ms so far, now at startProcess: returned from zygote!
10-29 06:02:23.815 3126 3143 W ActivityManager: Slow operation: 218ms so far, now at startProcess: done updating battery stats
10-29 06:02:23.815 3126 3143 W ActivityManager: Slow operation: 218ms so far, now at startProcess: building log message
10-29 06:02:23.815 3126 3143 I ActivityManager: Start proc 3355:WebViewLoader-arm64-v8a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
10-29 06:02:23.815 3126 3143 W ActivityManager: Slow operation: 218ms so far, now at startProcess: starting to update pids map
10-29 06:02:23.815 3126 3143 W ActivityManager: Slow operation: 218ms so far, now at startProcess: done updating pids map
10-29 06:02:23.826 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.826 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.flac.encoder) in [email protected] process
10-29 06:02:23.831 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.832 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in [email protected] process
10-29 06:02:23.838 3338 3338 V WebViewLibraryLoader: RelroFileCreator (64bit = false), lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so
10-29 06:02:23.840 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.842 3020 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.842 3020 3064 E OMXNodeInstance: setParameter(0xec310004:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.842 3020 3064 E OMXNodeInstance: setParameter(0xec310004:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.842 3020 3064 W OMXNodeInstance: [0xec310004:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.842 3020 3064 E OMXNodeInstance: getExtensionIndex(0xec310004:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.845 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.845 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based.secure) in [email protected] process
10-29 06:02:23.846 3355 3355 V WebViewLibraryLoader: RelroFileCreator (64bit = true), lib: /system/app/webview/webview.apk!/lib/arm64-v8a/libwebviewchromium.so
10-29 06:02:23.847 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.847 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.847 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.847 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.847 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.avc.v3.hw-based.secure] component does not support metadata mode; using fallback
10-29 06:02:23.847 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.850 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.852 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.h264.decoder) in [email protected] process
10-29 06:02:23.876 3020 3064 E OMXNodeInstance: getExtensionIndex(0xecca7c60:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.876 3020 3064 E OMXNodeInstance: getExtensionIndex(0xecca7c60:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.878 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.879 3020 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div3.hw-based) in [email protected] process
10-29 06:02:23.879 3020 3064 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.div3.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.880 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.880 3020 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.880 3020 3064 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.881 3020 3064 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.881 3020 3064 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.div3.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.881 3020 3064 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.883 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.883 3020 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div4.hw-based) in [email protected] process
10-29 06:02:23.884 3020 3305 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.div4.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.884 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.885 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.885 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.885 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.885 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.div4.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.885 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.887 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.887 3020 3305 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.divx.hw-based) in [email protected] process
10-29 06:02:23.888 3020 3305 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.divx.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.889 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.889 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.889 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.890 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.890 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.divx.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.890 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.892 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.893 3020 3305 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in [email protected] process
10-29 06:02:23.894 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.894 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.894 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.895 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.895 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.895 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.897 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.897 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.h263.decoder) in [email protected] process
10-29 06:02:23.939 3338 3338 I WebViewLoader-: System.exit called, status: 0
10-29 06:02:23.939 3338 3338 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:02:23.950 3020 3305 E OMXNodeInstance: getExtensionIndex(0xecca7d80:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.950 3020 3305 E OMXNodeInstance: getExtensionIndex(0xecca7d80:google.h263.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.954 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.955 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based) in [email protected] process
10-29 06:02:23.956 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.957 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.957 3020 3020 E OMXNodeInstance: setParameter(0xec310784:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.957 3020 3020 E OMXNodeInstance: setParameter(0xec310784:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.957 3020 3020 W OMXNodeInstance: [0xec310784:Freescale.std._decoder.hevc.hw-based] component does not support metadata mode; using fallback
10-29 06:02:23.957 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310784:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.959 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.959 3126 3379 I ActivityManager: Process WebViewLoader-armeabi-v7a (pid 3338) has died: psvc PER
10-29 06:02:23.959 3020 3305 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based.secure) in [email protected] process
10-29 06:02:23.959 2958 2958 I Zygote : Process 3338 exited cleanly (0)
10-29 06:02:23.960 3126 3144 W libprocessgroup: kill(-3338, 9) failed: No such process
10-29 06:02:23.960 3126 3144 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 3338 in 0ms
10-29 06:02:23.962 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:23.962 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:23.962 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:23.963 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:23.963 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.hevc.hw-based.secure] component does not support metadata mode; using fallback
10-29 06:02:23.963 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:23.965 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:23.966 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.hevc.decoder) in [email protected] process
10-29 06:02:24.028 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7ea0:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.028 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7ea0:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.031 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.031 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in [email protected] process
10-29 06:02:24.032 3020 3020 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.033 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.033 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.033 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.033 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.033 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.033 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.035 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.036 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in [email protected] process
10-29 06:02:24.037 3126 3126 W NetworkManagement: setDataSaverMode(): already false
10-29 06:02:24.038 3126 3137 W system_server: Long monitor contention with owner main (3126) at void java.lang.Object.wait(long, int)(Object.java:-2) waiters=0 in void com.android.server.NetworkManagementService.setUidCleartextNetworkPolicy(int, int) for 406ms
10-29 06:02:24.040 3126 3138 W system_server: Long monitor contention with owner main (3126) at void java.lang.Object.wait(long, int)(Object.java:-2) waiters=1 in void com.android.server.NetworkManagementService.setUidCleartextNetworkPolicy(int, int) for 365ms
10-29 06:02:24.042 3126 3126 D SystemServerTiming: MakeNetworkManagementServiceReady took to complete: 478ms
10-29 06:02:24.042 3126 3126 I SystemServer: MakeIpSecServiceReady
10-29 06:02:24.044 3126 3126 D IpSecService: IpSecService is ready
10-29 06:02:24.044 3126 3126 D SystemServerTiming: MakeIpSecServiceReady took to complete: 2ms
10-29 06:02:24.044 3126 3126 I SystemServer: MakeNetworkStatsServiceReady
10-29 06:02:24.045 3126 3145 E BatteryExternalStatsWorker: no controller energy info supplied for wifi
10-29 06:02:24.045 3126 3145 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
10-29 06:02:24.047 3126 3126 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:02:24.048 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.048 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.048 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.049 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.049 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.049 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.051 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.051 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in [email protected] process
10-29 06:02:24.053 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.054 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.054 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.054 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.054 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.054 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.056 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.056 3126 3126 D SystemServerTiming: MakeNetworkStatsServiceReady took to complete: 12ms
10-29 06:02:24.056 3126 3126 I SystemServer: MakeConnectivityServiceReady
10-29 06:02:24.056 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.decoder) in [email protected] process
10-29 06:02:24.058 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7d20:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.058 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7d20:google.mpeg4.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.059 3126 3239 D Ethernet: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:24.059 3126 3126 D PermissionMonitor: Monitoring
10-29 06:02:24.061 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.061 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.hw-based) in [email protected] process
10-29 06:02:24.062 3020 3305 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.sorenson.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.062 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.063 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.063 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.063 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.063 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.sorenson.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.063 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.063 3126 3126 D PermissionMonitor: Users: 1, Apps: 72
10-29 06:02:24.065 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.065 3020 3305 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.vp8.hw-based) in [email protected] process
10-29 06:02:24.067 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.067 3020 3305 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.067 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.068 3020 3305 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.068 3020 3305 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.vp8.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.068 3020 3305 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.068 3126 3126 D SystemServerTiming: MakeConnectivityServiceReady took to complete: 12ms
10-29 06:02:24.068 3126 3126 I SystemServer: MakeNetworkPolicyServiceReady
10-29 06:02:24.071 3250 3250 I droid.bluetoot: The ClassLoaderContext is a special shared library.
10-29 06:02:24.072 3126 3209 W NetworkPolicy: setRestrictBackgroundUL: already false
10-29 06:02:24.074 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.074 3355 3355 I WebViewLoader-: System.exit called, status: 0
10-29 06:02:24.074 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vp8.decoder) in [email protected] process
10-29 06:02:24.074 3355 3355 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:02:24.076 3259 3259 I putmethod.lati: The ClassLoaderContext is a special shared library.
10-29 06:02:24.081 3126 3209 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:02:24.085 3126 3126 D SystemServerTiming: MakeNetworkPolicyServiceReady took to complete: 16ms
10-29 06:02:24.085 3126 3126 I SystemServer: StartWatchdog
10-29 06:02:24.085 3126 3126 D SystemServerTiming: StartWatchdog took to complete: 0ms
10-29 06:02:24.085 3126 3126 I SystemServer: PhaseThirdPartyAppsCanStart
10-29 06:02:24.085 3126 3126 I SystemServiceManager: Starting phase 600
10-29 06:02:24.087 3126 3126 E LightsService: Light requested not available on this device. 4
10-29 06:02:24.087 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca81a0:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.087 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca81a0:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.089 3126 3126 V WallpaperManagerService: bindWallpaperComponentLocked: componentName=ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
10-29 06:02:24.091 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.091 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.vp9.hw-based) in [email protected] process
10-29 06:02:24.093 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.093 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.093 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.094 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.094 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.vp9.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.094 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.094 3126 3246 I ActivityManager: Process WebViewLoader-arm64-v8a (pid 3355) has died: psvc PER
10-29 06:02:24.095 2957 2957 I Zygote : Process 3355 exited cleanly (0)
10-29 06:02:24.095 3126 3144 W libprocessgroup: kill(-3355, 9) failed: No such process
10-29 06:02:24.095 3126 3144 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 3355 in 0ms
10-29 06:02:24.096 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.097 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.vp9.decoder) in [email protected] process
10-29 06:02:24.099 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7f60:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.099 3020 3020 E OMXNodeInstance: getExtensionIndex(0xecca7f60:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.105 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.105 3020 3020 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.xvid.hw-based) in [email protected] process
10-29 06:02:24.106 3020 3020 E OMXNodeInstance: getParameter(0xec310504:Freescale.std._decoder.xvid.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.106 2993 3075 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:02:24.107 3020 3020 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:02:24.107 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:02:24.107 3020 3020 E OMXNodeInstance: setParameter(0xec310504:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:02:24.107 3020 3020 W OMXNodeInstance: [0xec310504:Freescale.std._decoder.xvid.hw-based] component does not support metadata mode; using fallback
10-29 06:02:24.107 3020 3020 E OMXNodeInstance: getExtensionIndex(0xec310504:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:02:24.108 3250 3250 I droid.bluetoot: The ClassLoaderContext is a special shared library.
10-29 06:02:24.109 3327 3327 I ndroid.systemu: The ClassLoaderContext is a special shared library.
10-29 06:02:24.113 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.113 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.h264.encoder) in [email protected] process
10-29 06:02:24.120 3126 3126 I StatsCompanionService: Told statsd that StatsCompanionService is alive.
10-29 06:02:24.121 3126 3126 D SystemServerTiming: PhaseThirdPartyAppsCanStart took to complete: 36ms
10-29 06:02:24.121 3126 3126 I SystemServer: MakeLocationServiceReady
10-29 06:02:24.123 3259 3259 I putmethod.lati: The ClassLoaderContext is a special shared library.
10-29 06:02:24.124 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IGnss/default in either framework or device manifest.
10-29 06:02:24.124 3126 3126 D GnssLocationProvider: gnssHal 1.1 was null, trying 1.0
10-29 06:02:24.125 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IGnss/default in either framework or device manifest.
10-29 06:02:24.126 3126 3126 W LocationManagerService: no network location provider found
10-29 06:02:24.129 3126 3126 E LocationManagerService: no geocoder provider found
10-29 06:02:24.130 3126 3126 D LocationManagerService: Unable to bind FLP Geofence proxy.
10-29 06:02:24.130 3126 3126 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. class_init is effectively a no-op
10-29 06:02:24.131 3126 3126 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. is_supported is effectively a no-op
10-29 06:02:24.131 3126 3126 D LocationManagerService: Hardware Activity-Recognition not supported.
10-29 06:02:24.131 3126 3126 E ActivityRecognitionProxy: ServiceWatcher could not start.
10-29 06:02:24.131 3126 3126 D LocationManagerService: Unable to bind ActivityRecognitionProxy.
10-29 06:02:24.133 3126 3126 D SystemServerTiming: MakeLocationServiceReady took to complete: 12ms
10-29 06:02:24.133 3126 3126 I SystemServer: MakeCountryDetectionServiceReady
10-29 06:02:24.134 3126 3126 D SystemServerTiming: MakeCountryDetectionServiceReady took to complete: 0ms
10-29 06:02:24.134 3126 3126 I SystemServer: MakeNetworkTimeUpdateReady
10-29 06:02:24.135 3126 3126 D ConnectivityService: requestNetwork for uid/pid:1000/3126 NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ]
10-29 06:02:24.136 3126 3126 D SystemServerTiming: MakeNetworkTimeUpdateReady took to complete: 1ms
10-29 06:02:24.136 3126 3126 I SystemServer: MakeCommonTimeManagementServiceReady
10-29 06:02:24.136 3126 3126 I CommonTimeManagementService: No common time service detected on this platform. Common time services will be unavailable.
10-29 06:02:24.136 3126 3126 D SystemServerTiming: MakeCommonTimeManagementServiceReady took to complete: 0ms
10-29 06:02:24.136 3126 3126 I SystemServer: MakeInputManagerServiceReady
10-29 06:02:24.138 3126 3126 D SystemServerTiming: MakeInputManagerServiceReady took to complete: 2ms
10-29 06:02:24.138 3126 3239 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:02:24.138 3126 3126 I SystemServer: MakeTelephonyRegistryReady
10-29 06:02:24.138 3126 3126 D SystemServerTiming: MakeTelephonyRegistryReady took to complete: 0ms
10-29 06:02:24.139 3126 3126 I SystemServer: MakeMediaRouterServiceReady
10-29 06:02:24.139 2993 3075 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:02:24.139 3126 3126 D SystemServerTiming: MakeMediaRouterServiceReady took to complete: 1ms
10-29 06:02:24.139 3126 3126 I SystemServer: MakeMmsServiceReady
10-29 06:02:24.139 3126 3126 I MmsServiceBroker: Delay connecting to MmsService until an API is called
10-29 06:02:24.139 3126 3126 D SystemServerTiming: MakeMmsServiceReady took to complete: 0ms
10-29 06:02:24.139 3126 3126 I SystemServer: IncidentDaemonReady
10-29 06:02:24.140 3126 3126 D SystemServerTiming: IncidentDaemonReady took to complete: 1ms
10-29 06:02:24.141 3126 3126 I SystemServiceManager: Calling onStartUser u0
10-29 06:02:24.142 3126 3126 W VoiceInteractionManagerService: no available voice interaction services found for user 0
10-29 06:02:24.142 3126 3126 W VoiceInteractionManagerService: no available voice recognition services found for user 0
10-29 06:02:24.144 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000020
10-29 06:02:24.146 3126 3126 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
10-29 06:02:24.147 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000010
10-29 06:02:24.150 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.150 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.h263.encoder) in [email protected] process
10-29 06:02:24.175 3020 3020 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
10-29 06:02:24.177 2993 3075 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:02:24.177 3020 3305 E OMXNodeInstance: getConfig(0xecca8080:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:02:24.179 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.179 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.encoder) in [email protected] process
10-29 06:02:24.180 3020 3305 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
10-29 06:02:24.182 2993 3075 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:02:24.182 3020 3305 E OMXNodeInstance: getConfig(0xecca8080:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:02:24.185 2993 3075 I OMXClient: IOmx service obtained
10-29 06:02:24.186 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vp8.encoder) in [email protected] process
10-29 06:02:24.216 2993 3075 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:02:24.216 3020 3305 E OMXNodeInstance: getConfig(0xecca8200:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:02:24.217 2993 3075 D MediaCodecList: ignored a null builder
10-29 06:02:24.220 3126 3284 I OMXClient: IOmx service obtained
10-29 06:02:24.220 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.222 3020 3064 E OMXNodeInstance: getConfig(0xecca8140:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.224 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.248 3126 3126 I ActivityManager: Loaded persisted task ids for user 0
10-29 06:02:24.255 2965 2965 I chatty : uid=1000(system) [email protected] identical 10 lines
10-29 06:02:24.255 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.287 3126 3462 I OMXClient: IOmx service obtained
10-29 06:02:24.288 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.289 3020 3305 E OMXNodeInstance: getConfig(0xecca8320:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.292 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.295 2965 2965 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:02:24.296 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.331 3126 3126 W system_server: Framework Matrix: Ignore file /system/etc/vintf/manifest.xml:
10-29 06:02:24.333 3126 3465 I OMXClient: IOmx service obtained
10-29 06:02:24.333 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.335 3020 3305 E OMXNodeInstance: getConfig(0xecca8320:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.337 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.340 2965 2965 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:02:24.341 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.376 3126 3126 D SystemServerTiming: ActivityManagerStartApps took to complete: 235ms
10-29 06:02:24.376 3126 3126 D SystemServerTiming: PhaseActivityManagerReady took to complete: 953ms
10-29 06:02:24.376 3126 3142 W system_server: Long monitor contention with owner main (3126) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=0 in void com.android.server.am.ActivityManagerService.dispatchUidsChanged() for 232ms
10-29 06:02:24.376 3126 3143 W system_server: Long monitor contention with owner main (3126) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=1 in void com.android.server.am.ActivityManagerService.lambda$startProcessLocked$0(com.android.server.am.ActivityManagerService, com.android.server.am.ProcessRecord, long, java.lang.String, java.lang.String, int[], int, int, java.lang.String, java.lang.String) for 231ms
10-29 06:02:24.376 3126 3143 W ActivityManager: Slow operation: 232ms so far, now at startProcess: asking zygote to start proc
10-29 06:02:24.376 3126 3142 W Looper : Slow dispatch took 232ms android.ui h=com.android.server.am.ActivityManagerService$UiHandler c=null m=53
10-29 06:02:24.379 3126 3246 W system_server: Long monitor contention with owner main (3126) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=2 in void com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread, java.util.List) for 227ms
10-29 06:02:24.380 3126 3126 D SystemServerInitThreadPool: Shutdown successful
10-29 06:02:24.380 3126 3126 D SystemServerTiming: StartServices took to complete: 2743ms
10-29 06:02:24.381 3327 3327 W AlarmManager: Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@60f95de
10-29 06:02:24.382 3126 3469 I OMXClient: IOmx service obtained
10-29 06:02:24.383 3126 3126 W Looper : Slow delivery took 1887ms main h=android.os.Handler c=com.android.server.-$$Lambda$BatteryService$2x73lvpB0jctMSVP4qb9sHAqRPw@bf978c3 m=0
10-29 06:02:24.383 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.385 3020 3020 E OMXNodeInstance: getConfig(0xecca8140:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.388 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.393 3126 3143 W ActivityManager: Slow operation: 248ms so far, now at startProcess: returned from zygote!
10-29 06:02:24.395 2965 2965 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:02:24.395 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.439 3126 3487 I OMXClient: IOmx service obtained
10-29 06:02:24.439 3020 3020 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.441 3020 3020 E OMXNodeInstance: getConfig(0xecca8140:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.443 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.447 2965 2965 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:02:24.448 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.460 3126 3143 W ActivityManager: Slow operation: 316ms so far, now at startProcess: done updating battery stats
10-29 06:02:24.460 3126 3143 W ActivityManager: Slow operation: 316ms so far, now at startProcess: building log message
10-29 06:02:24.460 3126 3143 I ActivityManager: Start proc 3472:com.android.phone/1001 for added application com.android.phone
10-29 06:02:24.460 3126 3143 W ActivityManager: Slow operation: 316ms so far, now at startProcess: starting to update pids map
10-29 06:02:24.460 3126 3143 W ActivityManager: Slow operation: 316ms so far, now at startProcess: done updating pids map
10-29 06:02:24.460 3126 3143 W ActivityManager: Slow operation: 197ms so far, now at startProcess: asking zygote to start proc
10-29 06:02:24.462 3126 3126 D ConditionProviders.SCP: onConnected
10-29 06:02:24.463 3126 3126 D ConditionProviders: Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
10-29 06:02:24.463 3126 3126 D ConditionProviders: Subscribing to condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
10-29 06:02:24.472 3001 3460 V MediaExtractorUpdateService: loadPlugins /vendor/app/ExtractorPkg/ExtractorPkg.apk
10-29 06:02:24.474 3001 3460 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/.) Is a directory
10-29 06:02:24.475 3001 3460 E linker : library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
10-29 06:02:24.475 3001 3460 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/..) Is a directory
10-29 06:02:24.478 3001 3460 E MediaExtractorFactory: couldn't opendir(/vendor/lib64/extractors)
10-29 06:02:24.489 3472 3472 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:02:24.491 3126 3217 I WifiScanningService: wifi driver unloaded
10-29 06:02:24.493 3250 3250 V AdapterServiceConfig: Adding HeadsetService
10-29 06:02:24.494 3126 3126 V SettingsProvider: Notifying for 0: content://settings/secure/location_providers_allowed
10-29 06:02:24.494 3250 3250 V AdapterServiceConfig: Adding A2dpService
10-29 06:02:24.494 3250 3250 V AdapterServiceConfig: Adding HidHostService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding HealthService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding PanService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding GattService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding BluetoothMapService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding AvrcpTargetService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding HidDeviceService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding BluetoothOppService
10-29 06:02:24.495 3250 3250 V AdapterServiceConfig: Adding BluetoothPbapService
10-29 06:02:24.496 3126 3126 V SettingsProvider: Notifying for 0: content://settings/global/location_global_kill_switch
10-29 06:02:24.496 3126 3143 W ActivityManager: Slow operation: 233ms so far, now at startProcess: returned from zygote!
10-29 06:02:24.497 3126 3143 W ActivityManager: Slow operation: 234ms so far, now at startProcess: done updating battery stats
10-29 06:02:24.497 3126 3143 W ActivityManager: Slow operation: 234ms so far, now at startProcess: building log message
10-29 06:02:24.497 3126 3143 I ActivityManager: Start proc 3491:com.android.settings/1000 for activity com.android.settings/.FallbackHome
10-29 06:02:24.497 3126 3143 W ActivityManager: Slow operation: 234ms so far, now at startProcess: starting to update pids map
10-29 06:02:24.497 3126 3143 W ActivityManager: Slow operation: 234ms so far, now at startProcess: done updating pids map
10-29 06:02:24.503 3259 3259 I LatinIME: Hardware accelerated drawing: true
10-29 06:02:24.546 3001 3282 I FslExtractor: FslExtractor Sniff
10-29 06:02:24.550 3472 3472 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:02:24.566 3126 3506 I OMXClient: IOmx service obtained
10-29 06:02:24.567 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.568 3250 3250 I : [1029/060224.568647:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0xea7bd9be2430, handle=0x22b99719eb69e02d
10-29 06:02:24.569 3250 3250 D BluetoothAdapterService: onCreate()
10-29 06:02:24.571 3327 3327 V SystemUIService: Starting SystemUI services for user 0.
10-29 06:02:24.572 3020 3064 E OMXNodeInstance: getConfig(0xec926360:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.574 3250 3250 D AdapterState: make() - Creating AdapterState
10-29 06:02:24.574 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.575 2965 2965 I chatty : uid=1000(system) [email protected] identical 1 line
10-29 06:02:24.576 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.576 3250 3250 I bt_btif : init
10-29 06:02:24.576 3250 3250 D bt_osi_allocation_tracker: canary initialized
10-29 06:02:24.577 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.577 3250 3510 I AdapterState: OFF : entered
10-29 06:02:24.577 3250 3510 D AdapterProperties: Setting state to OFF
10-29 06:02:24.577 3250 3511 I bt_osi_thread: run_thread: thread id 3511, thread name stack_manager started
10-29 06:02:24.577 3250 3511 I bt_stack_manager: event_init_stack is initializing the stack
10-29 06:02:24.579 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.580 2965 2965 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:02:24.580 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.582 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:24.582 3491 3491 I ndroid.setting: The ClassLoaderContext is a special shared library.
10-29 06:02:24.591 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.592 2965 2965 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:02:24.594 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.594 3250 3511 E bt_btif_config: Config is missing adapter section
10-29 06:02:24.594 3250 3511 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
10-29 06:02:24.596 3250 3511 E bt_btif_config: Config is missing adapter section
10-29 06:02:24.596 3250 3511 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
10-29 06:02:24.596 3250 3511 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
10-29 06:02:24.596 3250 3511 E bt_btif_config: init unable to transcode legacy file; creating empty config.
10-29 06:02:24.597 3250 3514 I bt_osi_thread: run_thread: thread id 3514, thread name alarm_default_ca started
10-29 06:02:24.601 3250 3515 I bt_osi_thread: run_thread: thread id 3515, thread name alarm_dispatcher started
10-29 06:02:24.609 3250 3511 I bt_btif_core: btif_init_bluetooth entered
10-29 06:02:24.609 3250 3511 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
10-29 06:02:24.610 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.Dependency took to complete: 38ms
10-29 06:02:24.616 3491 3491 I ndroid.setting: The ClassLoaderContext is a special shared library.
10-29 06:02:24.631 3126 3126 W Looper : Slow dispatch took 131ms main h=android.app.ActivityThread$H c=null m=114
10-29 06:02:24.652 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.util.NotificationChannels took to complete: 43ms
10-29 06:02:24.654 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.statusbar.CommandQueue$CommandQueueStart took to complete: 2ms
10-29 06:02:24.660 3259 3259 W InputAttributes: No editor info for this field. Bug?
10-29 06:02:24.661 3250 3517 I bt_osi_thread: run_thread: thread id 3517, thread name bt_jni_workqueue started
10-29 06:02:24.661 3250 3511 I bt_btif_core: btif_init_bluetooth finished
10-29 06:02:24.661 3250 3511 I bt_stack_manager: event_init_stack finished
10-29 06:02:24.661 3250 3250 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
10-29 06:02:24.661 3250 3250 I bt_btif : get_profile_interface: id = socket
10-29 06:02:24.661 3250 3250 W bt_btif : do_in_jni_thread: Dropped message, message_loop not initialized yet!
10-29 06:02:24.661 3250 3250 I chatty : uid=1002(bluetooth) com.android.bluetooth identical 1 line
10-29 06:02:24.661 3250 3517 I bt_btif_core: run_message_loop entered
10-29 06:02:24.663 3250 3250 I bt_btif : get_profile_interface: id = sdp
10-29 06:02:24.665 3250 3250 I BluetoothAdapterService: Phone policy enabled
10-29 06:02:24.667 3126 3126 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:02:24.667 3327 3327 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:24.670 3327 3327 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:24.672 3250 3250 D BluetoothActiveDeviceManager: start()
10-29 06:02:24.679 3126 3518 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
10-29 06:02:24.686 3472 3472 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:02:24.690 3126 3126 I Telecom : SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@111f93a: TS.init@AAA
10-29 06:02:24.692 3259 3523 I LatinIME:LogUtils: Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1572328944 ; date = ?
10-29 06:02:24.695 3250 3250 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@c25bcdb
10-29 06:02:24.696 3250 3519 D BluetoothActiveDeviceManager: onAudioDevicesAdded
10-29 06:02:24.696 3250 3519 D BluetoothActiveDeviceManager: Audio device added: EVK_8MQ type: 2
10-29 06:02:24.696 3250 3519 D BluetoothActiveDeviceManager: Audio device added: EVK_8MQ type: 15
10-29 06:02:24.697 3259 3523 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 1572328944 ; date = ?
10-29 06:02:24.700 3259 3523 E ActivityThread: Failed to find provider info for user_dictionary
10-29 06:02:24.701 3250 3250 D BluetoothAdapterService: onBind()
10-29 06:02:24.710 3126 3526 I Telecom : Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentSpeakerRoute
10-29 06:02:24.711 3126 3526 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
10-29 06:02:24.721 3126 3531 I Telecom : CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
10-29 06:02:24.726 3491 3491 D OpenGLRenderer: Skia GL Pipeline
10-29 06:02:24.729 3126 3126 I Telecom : MissedCallNotifierImpl: reloadFromDatabase: Boot not yet complete -- call log db may not be available. Deferring loading until boot complete for user 0: TS.init@AAA
10-29 06:02:24.732 3126 3126 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:02:24.735 3491 3532 E libEGL : error mmaping cache file: Invalid argument (22)
10-29 06:02:24.744 3126 3126 I Telecom : Class: TelecomSystem.INSTANCE being set
10-29 06:02:24.744 3126 3126 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:197 com.android.server.telecom.components.TelecomService.onBind:67 android.app.ActivityThread.handleBindService:3597
10-29 06:02:24.748 3126 3126 W Looper : Slow dispatch took 117ms main h=android.app.ActivityThread$H c=null m=121
10-29 06:02:24.751 3126 3217 I WifiScanningService: wifi driver unloaded
10-29 06:02:24.752 3126 3126 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 com.android.server.content.SyncManager$14.run:756 android.os.Handler.handleCallback:873 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:193
10-29 06:02:24.753 3327 3327 W SoundPool: Use of stream types is deprecated for operations other than volume control
10-29 06:02:24.753 3327 3327 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
10-29 06:02:24.755 2999 3215 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:02:24.755 2999 3215 D installd: Found storage mount /data/media at /mnt/runtime/default/emulated
10-29 06:02:24.760 3126 3126 V SettingsProvider: Notifying for 0: content://settings/global/boot_count
10-29 06:02:24.761 3126 3147 D UsbDeviceManager: push notification:Charging this device via USB
10-29 06:02:24.762 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.keyguard.KeyguardViewMediator took to complete: 108ms
10-29 06:02:24.763 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:24.769 3327 3327 D OpenGLRenderer: Skia GL Pipeline
10-29 06:02:24.772 3001 3460 I FslExtractor: FslExtractor Sniff
10-29 06:02:24.781 3126 3264 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/5d1bdfe6-5b72-4f44-b92d-23c956ea7994 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
10-29 06:02:24.781 3126 3264 D WebViewZygote: Preloading package /system/app/webview/webview.apk /system/app/webview/lib/arm:/system/app/webview/webview.apk!/lib/armeabi-v7a
10-29 06:02:24.784 3126 3126 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:02:24.788 3491 3532 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:24.788 3491 3532 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:02:24.789 3491 3532 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:02:24.789 3491 3532 D OpenGLRenderer: Swap behavior 2
10-29 06:02:24.791 3472 3472 D TelephonyProvider: dbh.onOpen: ok, queried table=siminfo
10-29 06:02:24.792 3472 3472 D TelephonyProvider: dbh.onOpen: ok, queried table=carriers
10-29 06:02:24.796 3259 3523 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
10-29 06:02:24.803 3327 3539 I OMXClient: IOmx service obtained
10-29 06:02:24.804 3020 3062 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.806 3126 3264 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/5d1bdfe6-5b72-4f44-b92d-23c956ea7994 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
10-29 06:02:24.807 3020 3062 E OMXNodeInstance: getConfig(0xec9263c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.811 3491 3532 I display : open gpu gralloc module!
10-29 06:02:24.811 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.817 3314 3314 I WebViewZygoteInit: Beginning package preload
10-29 06:02:24.818 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.833 2965 2965 I chatty : uid=1000(system) [email protected] identical 9 lines
10-29 06:02:24.834 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.837 3472 3472 D CarrierIdProvider: onCreate
10-29 06:02:24.839 3314 3314 I webview_zygote: The ClassLoaderContext is a special shared library.
10-29 06:02:24.847 3126 3126 V WiredAccessoryManager: init()
10-29 06:02:24.849 3472 3472 D CarrierIdProvider: update database from pb file
10-29 06:02:24.850 3126 3126 V WiredAccessoryManager: state_cable 16
10-29 06:02:24.851 3126 3126 W system_server: type=1400 audit(0.0:2385): avc: denied { read } for name="state" dev="sysfs" ino=21965 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:02:24.851 3126 3126 V WiredAccessoryManager: newName=extcon0 newState=16 headsetState=16 prev headsetState=0
10-29 06:02:24.851 3126 3126 I WiredAccessoryManager: MSG_NEW_DEVICE_STATE
10-29 06:02:24.854 3126 3486 W ActivityManager: Unable to start service Intent { act=android.intent.action.QUICKSTEP_SERVICE pkg=com.android.launcher3 } U=0: not found
10-29 06:02:24.854 3327 3327 W OverviewProxyService: Failed to connect on attempt 1 will try again in 5000ms
10-29 06:02:24.856 3126 3149 I ActivityManager: Displayed com.android.settings/.FallbackHome: +585ms
10-29 06:02:24.856 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:02:24.859 3126 3141 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
10-29 06:02:24.871 3126 3126 W WiredAccessoryManager: /sys/class/extcon/extcon1/state not found while attempting to determine initial switch state
10-29 06:02:24.874 3126 3136 I system_server: Background concurrent copying GC freed 24728(2MB) AllocSpace objects, 30(884KB) LOS objects, 42% free, 6MB/10MB, paused 1.057ms total 277.815ms
10-29 06:02:24.884 3001 3460 I FslExtractor: FslExtractor Sniff
10-29 06:02:24.890 3472 3472 E CarrierIdProvider: read carrier list from ota pb failure: java.io.FileNotFoundException: /data/misc/carrierid/carrier_list.pb (No such file or directory)
10-29 06:02:24.890 3472 3472 D CarrierIdProvider: latest version: 4 need update: false
10-29 06:02:24.893 3472 3472 D CarrierProvider: onCreate
10-29 06:02:24.894 3314 3314 I WebViewZygoteInit: Package preload done
10-29 06:02:24.901 3327 3552 I OMXClient: IOmx service obtained
10-29 06:02:24.902 3020 3064 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:24.903 3472 3472 I ImsResolver: ImsResolver initialized with static binding.
10-29 06:02:24.903 3472 3472 I ImsResolver: Initializing cache and binding.
10-29 06:02:24.903 3020 3064 E OMXNodeInstance: getConfig(0xec9263c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:24.906 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.914 3126 3126 D AccessibilityManagerService: Ignoring non-encryption-aware service ComponentInfo{com.koushikdutta.vysor/com.koushikdutta.vysor.AudioEnablerService}
10-29 06:02:24.915 3126 3126 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
10-29 06:02:24.915 3126 3126 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:02:24.916 3126 3126 W ActivityManager: Unable to start service Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener } U=0: not found
10-29 06:02:24.916 3126 3126 W NotificationListeners: Unable to bind notification listener service: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:02:24.916 3126 3126 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:02:24.916 3126 3126 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
10-29 06:02:24.920 2965 2965 I chatty : uid=1000(system) [email protected] identical 10 lines
10-29 06:02:24.921 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:24.923 2968 3092 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:02:24.925 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.recents.Recents took to complete: 163ms
10-29 06:02:24.934 3327 3327 I vol.Events: writeEvent collection_started
10-29 06:02:24.943 3556 3556 W main : type=1400 audit(0.0:2386): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:24.944 3126 3143 I ActivityManager: Start proc 3556:android.ext.services/u0a25 for service android.ext.services/.notification.Assistant
10-29 06:02:24.949 3327 3557 I vol.Events: writeEvent external_ringer_mode_changed normal
10-29 06:02:24.949 3327 3557 I vol.Events: writeEvent internal_ringer_mode_changed normal
10-29 06:02:24.951 3556 3556 I chatty : uid=10025(android.ext.services) expire 2 lines
10-29 06:02:24.951 3556 3556 W main : type=1400 audit(0.0:2389): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:24.953 3126 3126 D ConditionProviders.SCP: onSubscribe condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true
10-29 06:02:24.954 3126 3126 D ConditionProviders.SCP: setRegistered true
10-29 06:02:24.957 3126 3126 D ConditionProviders.SCP: evaluateSubscriptionLocked cal=ScheduleCalendar[mDays={1, 2, 3, 4, 5, 6, 7}, mSchedule=ScheduleInfo{days=[1, 2, 3, 4, 5, 6, 7], startHour=22, startMinute=0, endHour=7, endMinute=0, exitAtAlarm=true, nextAlarm=Thu Jan 01 00:00:00 GMT 1970 (0)}], now=Tue Oct 29 06:02:24 GMT 2019 (1572328944954), nextUserAlarmTime=Thu Jan 01 00:00:00 GMT 1970 (0)
10-29 06:02:24.958 3126 3126 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true STATE_TRUE reason=meetsSchedule
10-29 06:02:24.959 3126 3126 D ConditionProviders.SCP: Scheduling evaluate for Tue Oct 29 07:00:00 GMT 2019 (1572332400000), in +57m35s46ms, now=Tue Oct 29 06:02:24 GMT 2019 (1572328944954)
10-29 06:02:24.972 3126 3225 E ActivityThread: Failed to find provider info for com.android.calendar
10-29 06:02:24.973 3126 3225 E ActivityThread: Failed to find provider info for com.android.calendar
10-29 06:02:24.977 3126 3126 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
10-29 06:02:24.977 3126 3126 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
10-29 06:02:24.977 3126 3148 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
10-29 06:02:24.977 3126 3148 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
10-29 06:02:24.983 3126 3148 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@96afb6c mBinding = false mUnbinding = false
10-29 06:02:24.987 3126 3126 D MediaSessionService: Global priority session is changed from null to com.android.server.telecom/HeadsetMediaButton (userId=0)
10-29 06:02:24.990 3250 3250 D BluetoothAdapterService: onUnbind() - calling cleanup
10-29 06:02:24.990 3250 3250 D BluetoothAdapterService: cleanup()
10-29 06:02:24.991 3001 3282 I FslExtractor: FslExtractor Sniff
10-29 06:02:24.992 3126 3137 W UsageStatsService: Event reported without a package name
10-29 06:02:24.996 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:02:25.003 3250 3250 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
10-29 06:02:25.003 3250 3250 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
10-29 06:02:25.003 3250 3250 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
10-29 06:02:25.003 3250 3511 I bt_stack_manager: event_clean_up_stack is cleaning up the stack
10-29 06:02:25.003 3250 3511 I bt_btif_core: btif_cleanup_bluetooth entered
10-29 06:02:25.003 3250 3511 E bt_btif : do_in_bta_thread: MessageLooper not initialized
10-29 06:02:25.004 3250 3511 E BluetoothServiceJni: Callback: 'callback_thread_event' is not called on the correct thread
10-29 06:02:25.004 3250 3511 I bt_btif_queue: btif_queue_release
10-29 06:02:25.004 3250 3517 I bt_btif_core: run_message_loop finished
10-29 06:02:25.004 3250 3517 W bt_osi_thread: run_thread: thread id 3517, thread name bt_jni_workqueue exited
10-29 06:02:25.004 3250 3511 I bt_core_module: module_clean_up Cleaning up module "stack_config_module"
10-29 06:02:25.004 3250 3511 I bt_core_module: module_clean_up Cleanup of module "stack_config_module" completed
10-29 06:02:25.005 3250 3511 I bt_core_module: module_clean_up Cleaning up module "interop_module"
10-29 06:02:25.005 3250 3511 I bt_core_module: module_clean_up Cleanup of module "interop_module" completed
10-29 06:02:25.005 3250 3511 I bt_btif_core: btif_cleanup_bluetooth finished
10-29 06:02:25.005 3250 3511 I bt_core_module: module_clean_up Cleaning up module "btif_config_module"
10-29 06:02:25.010 3126 3126 V WiredAccessoryManager: headsetName: connected
10-29 06:02:25.013 3327 3581 I OMXClient: IOmx service obtained
10-29 06:02:25.014 3020 3305 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:02:25.014 3126 3126 D AutofillManagerService: Autofill restriction did not change for user 0
10-29 06:02:25.015 2968 3092 D audio_hw_primary: adev_set_parameters: enter: connect=1024
10-29 06:02:25.015 2968 3092 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:02:25.015 3126 3244 I SyncManager: Got SyncJobService instance.
10-29 06:02:25.016 2991 3086 I AudioFlinger: openOutput() this 0xf13be000, module 10 Device 0x400, SamplingRate 0, Format 00000000, Channels 0, flags 0x1
10-29 06:02:25.016 3020 3305 E OMXNodeInstance: getConfig(0xec9263c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:02:25.016 2968 2968 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(0) channel_mask(0) format(0) devices(0x400) flags(0x1), address()
10-29 06:02:25.016 2968 2968 W audio_hw_primary: adev_open_output_stream() HDMI multichannel
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_channel_masks() card 3 got 2 sup channels
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 32000 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 44100 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 48000 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 88200 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 96000 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 176400 sup rates
10-29 06:02:25.017 2968 2968 W audio_hw_primary: out_read_hdmi_rates() card 3 got 192000 sup rates
10-29 06:02:25.017 2968 2968 I audio_hw_primary: adev_open_output_stream: exit: output_type 2, output 0xf3d50280
10-29 06:02:25.018 2991 3086 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 192 frames
10-29 06:02:25.020 2968 2968 W audio_hw_primary: out get parameters query format=1;sup_channels=, reply sup_channels=AUDIO_CHANNEL_OUT_STEREO
10-29 06:02:25.022 3250 3511 I bt_core_module: module_clean_up Cleanup of module "btif_config_module" completed
10-29 06:02:25.023 3250 3511 I bt_core_module: module_clean_up Cleaning up module "bt_utils_module"
10-29 06:02:25.023 3250 3511 I bt_core_module: module_clean_up Cleanup of module "bt_utils_module" completed
10-29 06:02:25.023 2991 3585 I AudioFlinger: AudioFlinger's thread 0xf0b91000 tid=3585 ready to run
10-29 06:02:25.023 3250 3511 I bt_core_module: module_clean_up Cleaning up module "osi_module"
10-29 06:02:25.023 3250 3515 D bt_osi_alarm: callback_dispatch Callback thread exited
10-29 06:02:25.023 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.024 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.024 3250 3515 W bt_osi_thread: run_thread: thread id 3515, thread name alarm_dispatcher exited
10-29 06:02:25.024 3250 3514 W bt_osi_thread: run_thread: thread id 3514, thread name alarm_default_ca exited
10-29 06:02:25.025 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.025 3250 3511 I bt_core_module: module_clean_up Cleanup of module "osi_module" completed
10-29 06:02:25.025 3250 3511 I bt_stack_manager: event_clean_up_stack finished
10-29 06:02:25.025 3250 3250 I BluetoothServiceJni: cleanupNative: return from cleanup
10-29 06:02:25.026 3250 3250 D BluetoothActiveDeviceManager: cleanup()
10-29 06:02:25.026 3250 3250 D BluetoothAdapterService: onDestroy()
10-29 06:02:25.026 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: closing=true
10-29 06:02:25.027 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:25.028 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.028 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: exiting=1
10-29 06:02:25.028 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:25.029 2991 3086 I AudioFlinger: openOutput() this 0xf13be000, module 10 Device 0x400, SamplingRate 32000, Format 0x000001, Channels 0x3, flags 0x1
10-29 06:02:25.029 2968 3092 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(32000) channel_mask(0x3) format(0x1) devices(0x400) flags(0x1), address()
10-29 06:02:25.029 2968 3076 W audio_hw_primary: adev_close_output_stream...0xf3d50280
10-29 06:02:25.029 2968 3092 W audio_hw_primary: adev_open_output_stream() HDMI multichannel
10-29 06:02:25.029 2968 3092 W audio_hw_primary: out_read_hdmi_channel_masks() card 3 got 2 sup channels
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 32000 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 44100 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 48000 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 88200 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 96000 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 176400 sup rates
10-29 06:02:25.030 2968 3092 W audio_hw_primary: out_read_hdmi_rates() card 3 got 192000 sup rates
10-29 06:02:25.030 2968 3092 I audio_hw_primary: adev_open_output_stream: exit: output_type 2, output 0xf3d50c80
10-29 06:02:25.031 2991 3086 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 192 frames
10-29 06:02:25.031 2991 3587 I AudioFlinger: AudioFlinger's thread 0xf0b91000 tid=3587 ready to run
10-29 06:02:25.031 3250 3250 I BluetoothAdapterService: Force exit to cleanup internal state in Bluetooth stack
10-29 06:02:25.034 3126 3126 I FusedLocation: engine started (com.android.location.fused)
10-29 06:02:25.034 3126 3126 W Looper : Drained
10-29 06:02:25.034 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.035 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.035 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: closing=true
10-29 06:02:25.035 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:25.036 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.036 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: exiting=1
10-29 06:02:25.036 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:25.038 2968 2968 W audio_hw_primary: adev_close_output_stream...0xf3d50c80
10-29 06:02:25.039 2968 2968 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=0
10-29 06:02:25.039 2968 2968 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:02:25.041 3250 3250 I droid.bluetoot: System.exit called, status: 0
10-29 06:02:25.041 3250 3250 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:02:25.045 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.046 2965 2965 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:02:25.046 2965 2965 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xfe321262c100, 32768)
10-29 06:02:25.054 3556 3556 I id.ext.service: The ClassLoaderContext is a special shared library.
10-29 06:02:25.057 3126 3126 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
10-29 06:02:25.057 3126 3126 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:25.058 3126 3126 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAI
10-29 06:02:25.072 3327 3557 I vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
10-29 06:02:25.074 3327 3557 I vol.Events: writeEvent level_changed STREAM_SYSTEM 5
10-29 06:02:25.074 3126 3223 D NotificationSQLiteLog: Pruned event entries: 0
10-29 06:02:25.081 3327 3557 I vol.Events: writeEvent level_changed STREAM_MUSIC 5
10-29 06:02:25.084 3327 3557 I vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
10-29 06:02:25.085 3556 3594 D ExtAssistant: File doesn't exist or isn't readable yet
10-29 06:02:25.092 3126 3246 I DefaultPermGrantPolicy: Revoking permissions from disabled data services for user:0
10-29 06:02:25.093 3126 3246 I DefaultPermGrantPolicy: Granting permissions to enabled data services for user:0
10-29 06:02:25.114 3327 3557 I vol.Events: writeEvent level_changed STREAM_RING 5
10-29 06:02:25.117 3327 3557 I vol.Events: writeEvent level_changed STREAM_ALARM 6
10-29 06:02:25.118 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.volume.VolumeUI took to complete: 193ms
10-29 06:02:25.120 3126 3186 I ActivityManager: Process com.android.bluetooth (pid 3250) has died: fore SVC
10-29 06:02:25.121 3126 3144 W libprocessgroup: kill(-3250, 9) failed: No such process
10-29 06:02:25.127 2957 2957 I Zygote : Process 3250 exited cleanly (0)
10-29 06:02:25.132 3327 3557 I vol.Events: writeEvent zen_mode_config_changed [disallowAlarms=false disallowMedia=false disallowSystem=true disallowRinger=false]
10-29 06:02:25.142 2998 2998 D incidentd: Start uploading backlogs in /data/misc/incidents/
10-29 06:02:25.143 2998 2998 D incidentd: Successfully uploaded 0 files to Dropbox.
10-29 06:02:25.152 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.stackdivider.Divider took to complete: 34ms
10-29 06:02:25.164 3126 3144 W libprocessgroup: kill(-3250, 9) failed: No such process
10-29 06:02:25.164 3126 3144 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 3250 in 42ms
10-29 06:02:25.171 3472 3472 D PhoneSwitcherNetworkRequstListener: Registering NetworkFactory
10-29 06:02:25.172 3126 3219 D ConnectivityService: Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
10-29 06:02:25.173 3126 3137 I WifiService: getWifiServiceMessenger uid=10031
10-29 06:02:25.176 3126 3486 D ConnectivityService: requestNetwork for uid/pid:10031/3327 NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ]
10-29 06:02:25.176 3126 3239 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:02:25.177 3126 3219 D ConnectivityService: Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
10-29 06:02:25.188 3472 3604 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:02:25.188 3472 3604 W CallerInfoCache: cursor is null
10-29 06:02:25.195 3472 3472 D CarrierConfigLoader: CarrierConfigLoader has started
10-29 06:02:25.198 3126 3137 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:02:25.209 3472 3472 I TelecomFramework: TtyManager: updateUiTtyMode -1 -> 0
10-29 06:02:25.214 3472 3472 D ImsResolver: maybeAddedImsService, packageName: null
10-29 06:02:25.214 3472 3472 I ImsResolver: Adding newly added ImsService to cache: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:02:25.216 3472 3472 I ImsResolver: Binding ImsService: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver} with features: [{s=0, f=0}, {s=0, f=1}]
10-29 06:02:25.216 3472 3472 I ImsServiceController: Granting Runtime permissions to:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:02:25.216 3126 3186 I DefaultPermGrantPolicy: Granting permissions to enabled ImsServices for user:0
10-29 06:02:25.216 3472 3472 I ImsServiceController: Binding ImsService:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:02:25.228 3126 3209 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:02:25.229 3126 3209 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:02:25.230 3472 3472 D ServiceStateProvider: subId=-2
10-29 06:02:25.236 3126 3137 I WifiService: WifiService trying to set country code to
10-29 06:02:25.236 3126 3137 I WifiService: setCountryCode uid=1001
10-29 06:02:25.242 3472 3472 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:02:25.242 3472 3472 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:25.242 3472 3472 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:25.242 3472 3472 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:02:25.243 3472 3472 D TelephonyDebugService: TelephonyDebugService()
10-29 06:02:25.245 3472 3472 D CarrierConfigLoader: mHandler: 12 phoneId: 0
10-29 06:02:25.249 3472 3472 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
10-29 06:02:25.251 3126 3137 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
10-29 06:02:25.252 3126 3137 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
10-29 06:02:25.252 3126 3137 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
10-29 06:02:25.255 3472 3472 D OpenGLRenderer: Skia GL Pipeline
10-29 06:02:25.258 3126 3137 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAY
10-29 06:02:25.258 3472 3472 I TelecomFramework: AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub Audio Routes: BESW Schemes: tel voicemail Extras: Bundle[{android.telecom.extra.SUPPORTS_VIDEO_CALLING_FALLBACK=true}] GroupId: ***] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0}
10-29 06:02:25.258 3327 3327 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:02:25.259 3472 3472 I TelecomFramework: PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {a052805}
10-29 06:02:25.259 3126 3137 I StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@ba2a223
10-29 06:02:25.268 3472 3472 I TelecomFramework: PstnPhoneCapabilitiesNotifier: handleVideoCapabilitesChanged. Video capability - false
10-29 06:02:25.270 3472 3472 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
10-29 06:02:25.276 3126 3186 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAk
10-29 06:02:25.395 3327 3327 I CameraManagerGlobal: Connecting to camera service
10-29 06:02:25.520 3327 3327 D NotificationEntryMgr: heads up is enabled
10-29 06:02:25.585 3327 3327 D BluetoothHidDevice: Bound to HID Device Service
10-29 06:02:25.586 3327 3327 D LocalBluetoothProfileManager: Adding local MAP profile
10-29 06:02:25.586 3327 3327 D BluetoothMap: Create BluetoothMap proxy object
10-29 06:02:25.588 3327 3327 D LocalBluetoothProfileManager: Adding local PBAP profile
10-29 06:02:25.590 3327 3327 D LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
10-29 06:02:25.605 3327 3327 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@5e27b1, handler=Handler (android.os.Handler) {c150496}
10-29 06:02:25.606 3327 3599 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
10-29 06:02:25.607 3327 3599 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
10-29 06:02:25.614 3327 3598 D OpenGLRenderer: profile bars disabled
10-29 06:02:25.615 3327 3598 D OpenGLRenderer: ambientRatio = 1.50
10-29 06:02:25.628 3327 3327 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:02:25.646 3327 3327 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@5e27b1, handler=Handler (android.os.Handler) {c150496}
10-29 06:02:25.647 3327 3599 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
10-29 06:02:25.647 3327 3599 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
10-29 06:02:25.656 3327 3616 I SecurityController: could not bind to KeyChainService
10-29 06:02:25.677 3327 3603 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:02:25.682 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.SystemBars took to complete: 530ms
10-29 06:02:25.687 3327 3327 D StorageNotification: Notifying about private volume: VolumeInfo{private}:
10-29 06:02:25.687 3327 3327 D StorageNotification: type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
10-29 06:02:25.687 3327 3327 D StorageNotification: state=MOUNTED
10-29 06:02:25.687 3327 3327 D StorageNotification: fsType=null fsUuid=null fsLabel=null
10-29 06:02:25.687 3327 3327 D StorageNotification: path=/data internalPath=null
10-29 06:02:25.689 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.usb.StorageNotification took to complete: 7ms
10-29 06:02:25.694 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.power.PowerUI took to complete: 5ms
10-29 06:02:25.696 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.media.RingtonePlayer took to complete: 2ms
10-29 06:02:25.697 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.keyboard.KeyboardUI took to complete: 1ms
10-29 06:02:25.709 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.pip.PipUI took to complete: 12ms
10-29 06:02:25.710 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.shortcut.ShortcutKeyDispatcher took to complete: 1ms
10-29 06:02:25.710 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.VendorServices took to complete: 0ms
10-29 06:02:25.711 3327 3327 V GarbageMonitor: Now tracking processes: 3327
10-29 06:02:25.711 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.util.leak.GarbageMonitor$Service took to complete: 1ms
10-29 06:02:25.712 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.LatencyTester took to complete: 1ms
10-29 06:02:25.715 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.globalactions.GlobalActionsComponent took to complete: 3ms
10-29 06:02:25.723 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.ScreenDecorations took to complete: 8ms
10-29 06:02:25.724 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.fingerprint.FingerprintDialogImpl took to complete: 1ms
10-29 06:02:25.726 3327 3327 D SystemUIBootTiming: StartServicescom.android.systemui.SliceBroadcastRelayHandler took to complete: 2ms
10-29 06:02:25.726 3327 3327 D SystemUIBootTiming: StartServices took to complete: 1155ms
10-29 06:02:25.738 3327 3327 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
10-29 06:02:25.738 3327 3327 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:02:25.755 3327 3327 I Choreographer: Skipped 36 frames! The application may be doing too much work on its main thread.
10-29 06:02:25.776 3327 3327 D ViewRootImpl[StatusBar]: changeCanvasOpacity: opaque=true
10-29 06:02:25.805 3327 3598 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:25.805 3327 3598 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:02:25.805 3327 3598 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:02:25.805 3327 3598 D OpenGLRenderer: Swap behavior 2
10-29 06:02:25.813 3327 3616 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:02:25.830 3327 3603 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:02:25.833 3327 3598 I display : open gpu gralloc module!
10-29 06:02:25.895 3126 3213 D WifiService: New client listening to asynchronous messages
10-29 06:02:26.311 3327 3327 D StatusBar: disable<e i a s b H!R!c s > disable2<q i n >
10-29 06:02:26.487 3327 3327 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:02:26.495 2885 2885 E Cryptfs : cryptfs_get_password not valid for file encryption
10-29 06:02:26.521 3126 3196 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:02:26.540 3327 3327 I Choreographer: Skipped 46 frames! The application may be doing too much work on its main thread.
10-29 06:02:26.543 3126 3149 W WindowManager: App freeze timeout expired.
10-29 06:02:26.562 2968 2968 D audio_hw_primary: adev_set_parameters: enter: A2dpSuspended=false
10-29 06:02:26.562 2968 2968 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:02:26.563 3126 3227 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
10-29 06:02:26.563 2968 2968 D audio_hw_primary: adev_set_parameters: enter: BT_SCO=off
10-29 06:02:26.563 2968 2968 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:02:26.566 3327 3598 I OpenGLRenderer: Davey! duration=798ms; Flags=0, IntendedVsync=16729705492, Vsync=17496372128, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=17505000120, AnimationStart=17505030600, PerformTraversalsStart=17505980040, DrawStart=17509159560, SyncQueued=17518836241, SyncStart=17520445921, IssueDrawCommandsStart=17520576361, SwapBuffers=17528424241, FrameCompleted=17529866761, DequeueBufferDuration=622000, QueueBufferDuration=286000,
10-29 06:02:26.656 3327 3598 I OpenGLRenderer: Davey! duration=888ms; Flags=0, IntendedVsync=16729705492, Vsync=17496372128, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=17505000120, AnimationStart=17505030600, PerformTraversalsStart=17505980040, DrawStart=17578894923, SyncQueued=17581287603, SyncStart=17583540003, IssueDrawCommandsStart=17583691443, SwapBuffers=17617894924, FrameCompleted=17620314125, DequeueBufferDuration=743000, QueueBufferDuration=323000,
10-29 06:02:26.739 3126 3149 I WindowManager: ******* TELLING SURFACE FLINGER WE ARE BOOTED!
10-29 06:02:26.739 2987 3056 I SurfaceFlinger: Boot is finished (7689 ms)
10-29 06:02:26.740 3327 3327 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:02:26.744 3126 3149 I SystemServiceManager: Starting phase 1000
10-29 06:02:26.757 3327 3327 I chatty : uid=10031(com.android.systemui) identical 2 lines
10-29 06:02:26.759 3327 3327 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:02:26.770 3126 3149 D ActivityManager: Finishing user boot 0
10-29 06:02:26.771 3126 3149 I ActivityManager: User 0 state changed from BOOTING to RUNNING_LOCKED
10-29 06:02:26.775 2885 2885 D vold : e4crypt_unlock_user_key 0 serial=0 token_present=0
10-29 06:02:26.780 2885 2885 D vold : Skipping non-key .
10-29 06:02:26.780 2885 2885 D vold : Skipping non-key ..
10-29 06:02:26.780 2885 2885 D vold : Trying user CE key /data/misc/vold/user_keys/ce/0/current
10-29 06:02:26.786 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:02:26.787 2885 2885 W Binder:2885_2: type=1400 audit(0.0:2390): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
10-29 06:02:26.787 2885 2885 I chatty : uid=0(root) Binder:2885_2 identical 3 lines
10-29 06:02:26.787 2885 2885 W Binder:2885_2: type=1400 audit(0.0:2394): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
10-29 06:02:26.790 2885 2885 I vold : List of Keymaster HALs found:
10-29 06:02:26.790 2885 2885 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:26.790 2885 2885 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:02:26.791 2885 2885 D vold : Successfully retrieved key
10-29 06:02:26.792 2885 2885 D vold : Added key 1043577384 (ext4:e5c0a18cb8418c01) to keyring 782663036 in process 2885
10-29 06:02:26.792 2885 2885 D vold : Added key 1060844178 (f2fs:e5c0a18cb8418c01) to keyring 782663036 in process 2885
10-29 06:02:26.792 2885 2885 D vold : Added key 610541698 (fscrypt:e5c0a18cb8418c01) to keyring 782663036 in process 2885
10-29 06:02:26.792 2885 2885 D vold : Installed ce key for user 0
10-29 06:02:26.792 3126 3149 D ActivityManager: Started unlocking user 0
10-29 06:02:26.792 3126 3149 D ActivityManager: Unlocking user 0 progress 0
10-29 06:02:26.792 3126 3149 D ActivityManager: Unlocking user 0 progress 5
10-29 06:02:26.794 2885 2885 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
10-29 06:02:26.794 2885 2885 D vold : Preparing: /data/system_ce/0
10-29 06:02:26.794 2885 2885 D vold : Preparing: /data/misc_ce/0
10-29 06:02:26.794 2885 2885 D vold : Preparing: /data/vendor_ce/0
10-29 06:02:26.795 2885 2885 D vold : Preparing: /data/media/0
10-29 06:02:26.795 2885 2885 D vold : Preparing: /data/data
10-29 06:02:26.811 3126 3214 D WifiConfigStore: Reading from stores completed in 13 ms.
10-29 06:02:26.813 3126 3214 W WifiConfigManager: No stored networks found.
10-29 06:02:26.826 3126 3143 I ActivityManager: Start proc 3627:com.android.deskclock/u0a48 for broadcast com.android.deskclock/.AlarmInitReceiver
10-29 06:02:26.827 3126 3214 D WIFI : Registering NetworkFactory
10-29 06:02:26.827 3126 3219 D ConnectivityService: Got NetworkFactory Messenger for WIFI
10-29 06:02:26.827 3126 3214 D WIFI_UT : Registering NetworkFactory
10-29 06:02:26.828 3126 3214 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:02:26.828 3126 3214 D WIFI : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:26.828 3126 3214 D WIFI : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:26.828 3126 3214 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:02:26.828 3126 3219 D ConnectivityService: Got NetworkFactory Messenger for WIFI_UT
10-29 06:02:26.828 3126 3214 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:02:26.828 3126 3214 D WIFI_UT : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:26.829 3126 3214 D WIFI_UT : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:02:26.829 3126 3214 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:02:26.867 2885 2885 I vold : Found policy e5c0a18cb8418c01 at /data/system_ce/0 which matches expected value
10-29 06:02:26.872 2885 2885 I vold : Found policy e5c0a18cb8418c01 at /data/misc_ce/0 which matches expected value
10-29 06:02:26.873 2885 2885 I vold : Policy for /data/vendor_ce/0 set to e5c0a18cb8418c01 modes 1/4
10-29 06:02:26.874 2885 2885 I vold : Found policy e5c0a18cb8418c01 at /data/media/0 which matches expected value
10-29 06:02:26.874 2885 2885 I vold : Found policy e5c0a18cb8418c01 at /data/data which matches expected value
10-29 06:02:26.874 2885 2885 V vold : Starting restorecon of /data/system_ce/0
10-29 06:02:26.879 3327 3327 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:02:26.886 3327 3327 I chatty : uid=10031(com.android.systemui) identical 1 line
10-29 06:02:26.917 3327 3327 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:02:26.926 3634 3634 I bootstat: Service started: /system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l
10-29 06:02:26.938 3627 3627 I droid.deskcloc: The ClassLoaderContext is a special shared library.
10-29 06:02:26.968 3627 3627 I droid.deskcloc: The ClassLoaderContext is a special shared library.
10-29 06:02:26.975 3327 3327 W StatusBar/NavBarView: *** Invalid layout in navigation bar (sizeChanged this=1920x64 cur=1898x64)
10-29 06:02:26.980 3327 3327 D android.widget.GridLayout: vertical constraints: y1-y0>=35, y1-y0<=32 are inconsistent; permanently removing: y1-y0<=32.
10-29 06:02:26.996 2885 2885 V vold : Finished restorecon of /data/system_ce/0
10-29 06:02:26.996 2885 2885 V vold : Starting restorecon of /data/misc_ce/0
10-29 06:02:27.002 3634 3634 I bootstat: Battery level at startup 85%
10-29 06:02:27.003 3634 3634 I bootstat: Canonical boot reason: cold
10-29 06:02:27.007 3634 3634 E bootstat: Failed to read /data/misc/bootstat/post_decrypt_time_elapsed: No such file or directory
10-29 06:02:27.007 3634 3634 E bootstat: Failed to parse boot time record: /data/misc/bootstat/post_decrypt_time_elapsed
10-29 06:02:27.019 2885 2885 V vold : Finished restorecon of /data/misc_ce/0
10-29 06:02:27.019 2885 2885 V vold : /system/bin/vold_prepare_subdirs
10-29 06:02:27.019 2885 2885 V vold : prepare
10-29 06:02:27.019 2885 2885 V vold : 0
10-29 06:02:27.019 2885 2885 V vold : 2
10-29 06:02:27.059 3327 3327 W View : requestLayout() improperly called by com.android.keyguard.CarrierText{45b073e V.ED..... ......ID 32,0-1764,80 #7f0a018a app:id/keyguard_carrier_text} during layout: running second layout pass
10-29 06:02:27.077 2885 2885 I vold_prepare_subdirs: SELinux: Loaded file_contexts
10-29 06:02:27.081 3649 3649 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_ce/0/vold
10-29 06:02:27.081 3627 3627 I AlarmClock: AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
10-29 06:02:27.082 3649 3649 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_ce/0/storaged
10-29 06:02:27.086 3126 3147 V UserDataPreparer: Found /data/user/0 with serial number 0
10-29 06:02:27.086 3126 3147 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
10-29 06:02:27.087 3126 3147 D UserDataPreparer: Setting property: sys.user.0.ce_available=true
10-29 06:02:27.088 3126 3147 V PackageManager: reconcileAppsData for null u0 0x2 migrateAppData=false
10-29 06:02:27.092 3627 3651 I AlarmClock: Fixing alarm instances
10-29 06:02:27.168 3627 3651 V AlarmClock: AlarmInitReceiver finished
10-29 06:02:27.179 3126 3140 I android.os.Debug: using rollup pss collection
10-29 06:02:27.348 3126 3147 V PackageManager: reconcileAppsData finished 89 packages
10-29 06:02:27.348 3126 3147 I ActivityManager: User 0 state changed from RUNNING_LOCKED to RUNNING_UNLOCKING
10-29 06:02:27.349 3126 3147 D ActivityManager: Unlocking user 0 progress 20
10-29 06:02:27.349 3126 3147 W Looper : Slow dispatch took 554ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@38afe66 m=0
10-29 06:02:27.349 3126 3147 W Looper : Slow delivery took 553ms android.fg h=com.android.server.AppStateTracker$MyHandler c=null m=14
10-29 06:02:27.352 3126 3141 I SystemServiceManager: Calling onUnlockUser u0
10-29 06:02:27.352 3126 3141 D BluetoothManagerService: User 0 unlocked
10-29 06:02:27.353 3126 3148 D BluetoothManagerService: MESSAGE_USER_UNLOCKED
10-29 06:02:27.353 3126 3141 D StorageManagerService: onUnlockUser 0
10-29 06:02:27.353 2885 2885 D vold : Linking /storage/emulated/0 to /mnt/user/0/primary
10-29 06:02:27.370 3126 3147 W Looper : Drained
10-29 06:02:27.370 3126 3204 D StorageManagerService: Volume emulated broadcasting mounted to UserHandle{0}
10-29 06:02:27.374 3126 3214 D WifiConfigStore: Reading from user store completed in 2 ms.
10-29 06:02:27.374 3126 3214 D WakeupConfigStoreData: WifiWake user data has been read
10-29 06:02:27.380 3126 3141 W VoiceInteractionManagerService: no available voice interaction services found for user 0
10-29 06:02:27.380 3126 3141 W VoiceInteractionManagerService: no available voice recognition services found for user 0
10-29 06:02:27.381 3126 3141 D AutofillManagerServiceImpl: Reset component for user 0 ()
10-29 06:02:27.382 3126 3141 D AutofillManagerServiceImpl: Reset component for user 0 ()
10-29 06:02:27.382 3126 3141 D FieldClassificationStrategy: reset(): service is not bound. Do nothing.
10-29 06:02:27.382 3126 3141 I ActivityManager: User 0 state changed from RUNNING_UNLOCKING to RUNNING_UNLOCKED
10-29 06:02:27.382 3126 3141 D SystemServerTiming: SystemUserUnlock took to complete: 590ms
10-29 06:02:27.383 3126 3142 D AutofillUI: destroySaveUiUiThread(): already destroyed
10-29 06:02:27.384 3126 3147 I ActivityManager: Loading recents for user 0 into memory.
10-29 06:02:27.393 3126 3656 V BackupManagerService: Starting with transport android/com.android.internal.backup.LocalTransport
10-29 06:02:27.399 3126 3214 D WifiConfigStore: Writing to stores completed in 23 ms.
10-29 06:02:27.401 3259 3259 I InputAttributes: InputType.TYPE_NULL is specified
10-29 06:02:27.404 3126 3656 I SELinux : SELinux: Loaded file_contexts
10-29 06:02:27.408 3126 3656 E BackupPasswordManager: Unable to read backup pw version
10-29 06:02:27.411 3126 3143 I ActivityManager: Start proc 3660:com.android.se/1068 for added application com.android.se
10-29 06:02:27.432 3126 3656 E BackupPasswordManager: Unable to read saved backup pw hash
10-29 06:02:27.458 3126 3656 V BackupManagerService: No ancestral data
10-29 06:02:27.468 3660 3660 I com.android.se: The ClassLoaderContext is a special shared library.
10-29 06:02:27.492 3660 3660 I SecureElementService: main onCreate
10-29 06:02:27.495 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISecureElement/eSE1 in either framework or device manifest.
10-29 06:02:27.496 3660 3660 I SecureElementService: No HAL implementation for eSE1
10-29 06:02:27.497 2874 2874 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISecureElement/SIM1 in either framework or device manifest.
10-29 06:02:27.497 3660 3660 I SecureElementService: No HAL implementation for SIM1
10-29 06:02:27.507 3126 3656 I BackupManagerService: Unlocking system user; mService=com.android.server.backup.BackupManagerService@a4168ee
10-29 06:02:27.509 3126 3656 I BackupManagerService: Backup enabled => false
10-29 06:02:27.530 3126 3656 V BackupManagerConstants: getKeyValueBackupIntervalMilliseconds(...) returns 14400000
10-29 06:02:27.530 3126 3656 V BackupManagerConstants: getKeyValueBackupFuzzMilliseconds(...) returns 600000
10-29 06:02:27.530 3126 3656 V BackupManagerConstants: getKeyValueBackupRequiredNetworkType(...) returns 1
10-29 06:02:27.530 3126 3656 V BackupManagerConstants: getKeyValueBackupRequireCharging(...) returns true
10-29 06:02:27.530 3126 3656 V KeyValueBackupJob: Scheduling k/v pass in 244 minutes
10-29 06:02:27.534 3126 3141 I AppWidgetServiceImpl: Processing of handleUserUnlocked u0 took 145 ms
10-29 06:02:27.534 3126 3141 I ActivityManager: Sending BOOT_COMPLETE user #0
10-29 06:02:27.544 3126 3126 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
10-29 06:02:27.553 3491 3491 D FallbackHome: User unlocked and real home found; let's go!
10-29 06:02:27.556 3472 3472 D CarrierSvcBindHelper: Received android.intent.action.USER_UNLOCKED
10-29 06:02:27.557 3472 3472 E PhoneInterfaceManager: [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
10-29 06:02:27.557 3472 3472 D CarrierSvcBindHelper: No carrier app for: 0
10-29 06:02:27.558 3126 3126 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:02:27.560 3126 3126 V NotificationAssistants: disabling notification assistant for user 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:02:27.560 3126 3126 D NotificationListeners: Removing active service ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:02:27.563 3126 3126 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:02:27.579 3126 3143 I ActivityManager: Start proc 3679:android.process.media/u0a6 for broadcast com.android.providers.downloads/.DownloadReceiver
10-29 06:02:27.580 3126 3126 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
10-29 06:02:27.607 3126 3246 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0
10-29 06:02:27.616 3126 3143 W ActivityManager: Slow operation: 57ms so far, now at startProcess: returned from zygote!
10-29 06:02:27.632 3126 3126 I AccountManagerService: User 0 is unlocked - opening CE database
10-29 06:02:27.675 3126 3143 W ActivityManager: Slow operation: 115ms so far, now at startProcess: done updating battery stats
10-29 06:02:27.675 3126 3143 W ActivityManager: Slow operation: 116ms so far, now at startProcess: building log message
10-29 06:02:27.675 3126 3143 I ActivityManager: Start proc 3693:com.android.launcher3/u0a11 for service com.android.launcher3/.notification.NotificationListener
10-29 06:02:27.675 3126 3143 W ActivityManager: Slow operation: 116ms so far, now at startProcess: starting to update pids map
10-29 06:02:27.675 3126 3143 W ActivityManager: Slow operation: 116ms so far, now at startProcess: done updating pids map
10-29 06:02:27.707 3679 3679 I d.process.medi: The ClassLoaderContext is a special shared library.
10-29 06:02:27.707 3126 3126 W Looper : Slow dispatch took 124ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@22cc167 m=0
10-29 06:02:27.710 3556 3711 D ExtAssistant: File doesn't exist or isn't readable yet
10-29 06:02:27.711 3126 3244 I SyncManager: Loaded persisted syncs: 0 periodic syncs, 0 oneshot syncs, 10 total system server jobs, JobStats: FirstLoad: 2/2/0 LastSave: -1/-1/-1
10-29 06:02:27.719 3693 3693 I droid.launcher: The ClassLoaderContext is a special shared library.
10-29 06:02:27.749 3679 3679 I d.process.medi: The ClassLoaderContext is a special shared library.
10-29 06:02:27.836 3126 3461 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
10-29 06:02:27.836 3126 3461 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
10-29 06:02:27.838 3693 3693 V Launcher: LauncherAppState initiated
10-29 06:02:27.852 3693 3693 D OpenGLRenderer: Skia GL Pipeline
10-29 06:02:27.886 3679 3679 D MediaScannerReceiver: action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
10-29 06:02:27.907 3722 3722 W main : type=1400 audit(0.0:3630): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:27.907 3722 3722 I chatty : uid=10033(com.android.quicksearchbox) identical 2 lines
10-29 06:02:27.907 3722 3722 W main : type=1400 audit(0.0:3633): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:27.907 3126 3143 I ActivityManager: Start proc 3722:com.android.quicksearchbox/u0a33 for broadcast com.android.quicksearchbox/.SearchWidgetProvider
10-29 06:02:27.944 3126 3136 I system_server: Background concurrent copying GC freed 53437(3MB) AllocSpace objects, 38(1140KB) LOS objects, 42% free, 5MB/9MB, paused 158us total 153.452ms
10-29 06:02:27.972 3722 3722 I .quicksearchbo: The ClassLoaderContext is a special shared library.
10-29 06:02:27.988 3722 3722 I .quicksearchbo: The ClassLoaderContext is a special shared library.
10-29 06:02:28.087 3750 3750 W main : type=1400 audit(0.0:3634): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:28.087 3126 3749 I RecoverySystem: No recovery log file
10-29 06:02:28.097 3126 3143 I ActivityManager: Start proc 3750:com.android.dialer/u0a16 for broadcast com.android.dialer/.app.calllog.CallLogReceiver
10-29 06:02:28.113 3126 3749 I BootReceiver: Copying audit failures to DropBox
10-29 06:02:28.117 3126 3749 I BootReceiver: Checking for fsck errors
10-29 06:02:28.121 3126 3749 I BootReceiver: fs_stat, partition:userdata stat:0xb
10-29 06:02:28.155 3750 3750 I .android.diale: The ClassLoaderContext is a special shared library.
10-29 06:02:28.196 3126 3141 W ActivityManager: Activity pause timeout for ActivityRecord{593d36f u0 com.android.launcher3/.Launcher t2}
10-29 06:02:28.282 3693 3720 D LoaderTask: loadWorkspace: loading default favorites
10-29 06:02:28.286 3750 3750 I .android.diale: The ClassLoaderContext is a special shared library.
10-29 06:02:28.308 3693 3766 E libEGL : error mmaping cache file: Invalid argument (22)
10-29 06:02:28.353 3693 3693 D TouchInteractionService: Touch service connected
10-29 06:02:28.361 3750 3750 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:02:28.373 3750 3750 I Dialer : CallLogFramework.registerContentObservers - enter
10-29 06:02:28.374 3750 3750 I Dialer : CallLogFramework.registerContentObservers - not registering content observers
10-29 06:02:28.379 3750 3750 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:02:28.397 3693 3766 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:02:28.398 3693 3766 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:02:28.398 3693 3766 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:02:28.398 3693 3766 D OpenGLRenderer: Swap behavior 2
10-29 06:02:28.400 3750 3750 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:02:28.408 3750 3775 I Dialer : VisualVoicemailUpdateTask.updateNotification - enter
10-29 06:02:28.422 3693 3766 I display : open gpu gralloc module!
10-29 06:02:28.424 3126 3143 I ActivityManager: Start proc 3776:android.process.acore/u0a10 for content provider com.android.providers.contacts/.CallLogProvider
10-29 06:02:28.426 3679 3721 V MediaProvider: pruneThumbnails
10-29 06:02:28.441 3679 3721 V MediaProvider: /pruneDeadThumbnailFiles...
10-29 06:02:28.501 3776 3776 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:02:28.516 3126 3143 I ActivityManager: Start proc 3792:com.android.printspooler/u0a45 for service com.android.printspooler/.model.PrintSpoolerService
10-29 06:02:28.547 3693 3693 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:02:28.561 3776 3776 I ContactsPerf: VoicemailContentProvider.onCreate start
10-29 06:02:28.573 3792 3792 I id.printspoole: The ClassLoaderContext is a special shared library.
10-29 06:02:28.575 3776 3776 I ContactsPerf: VoicemailContentProvider.onCreate finish
10-29 06:02:28.597 3776 3776 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:02:28.627 3776 3776 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:02:28.653 3776 3807 D ContactsDatabaseHelper: WAL enabled for contacts2.db: true
10-29 06:02:28.677 3126 3143 I ActivityManager: Start proc 3814:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
10-29 06:02:28.708 3776 3807 I ContactLocale: AddressBook Labels [[en_US]]: […, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, …, А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, …, א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, …, ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, …, ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, …, ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, …, あ, か, さ, た, な, は, ま, や, ら, わ, #, …]
10-29 06:02:28.727 3814 3814 I ndroid.keychai: The ClassLoaderContext is a special shared library.
10-29 06:02:28.741 3327 3327 I vol.Events: writeEvent dismiss_dialog timeout
10-29 06:02:28.744 3776 3807 D ContactsDatabaseHelper: WAL enabled for profile.db: false
10-29 06:02:28.797 3750 3775 I Dialer : VisualVoicemailUpdateTask.updateNotification - no voicemails to notify about
10-29 06:02:28.797 3750 3775 I Dialer : VisualVoicemailNotifier.cancelAllVoicemailNotifications - enter
10-29 06:02:28.798 3750 3775 I Dialer : VoicemailNotificationJobService.scheduleJob - job canceled
10-29 06:02:28.799 3750 3750 I Dialer : VisualVoicemailUpdateTask.scheduleTask - update successful
10-29 06:02:29.409 3259 3259 I LatinIME: Timeout waiting for dictionary load
10-29 06:02:33.441 3126 3149 I display : open gpu gralloc module!
10-29 06:02:33.801 3126 3126 D WifiService: boot completed do start wifi
10-29 06:02:33.801 3126 3126 W Looper : Slow dispatch took 5002ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@268be6e m=0
10-29 06:02:33.802 3126 3126 W Looper : Slow delivery took 5001ms main h=com.android.server.job.JobSchedulerService$JobHandler c=null m=4
10-29 06:02:33.818 3126 3126 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now com.android.dialer: DDC.oR@AA8
10-29 06:02:33.819 3126 3126 I TransportClient: LocalTransportService#0: Notifying [TransportManager.registerTransport()] transport = IBackupTransport
10-29 06:02:33.819 3126 3126 W Looper : Drained
10-29 06:02:33.820 3126 3126 I Telecom : MissedCallNotifierImpl: reloadAfterBootComplete: user=0: TSBCR.oR@ABA
10-29 06:02:33.822 3472 3472 D CarrierConfigLoader: mHandler: 13 phoneId: 0
10-29 06:02:33.824 3126 3656 D BackupTransportManager: Transport android/com.android.internal.backup.LocalTransportService registered
10-29 06:02:33.824 3126 3656 D BackupManagerService: Transport android/com.android.internal.backup.LocalTransport registered 6318ms after first request (delay = 3000ms)
10-29 06:02:33.830 3126 3656 I BackupManagerService: Found stale backup journal, scheduling
10-29 06:02:33.840 3472 3839 D SIP : [SipPreferences] isReceivingCallsEnabled, option not set; use default value, exception: android.provider.Settings$SettingNotFoundException: sip_receive_calls
10-29 06:02:33.843 3840 3840 W main : type=1400 audit(0.0:3650): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:33.843 3126 3656 I chatty : uid=1000(system) backup identical 52 lines
10-29 06:02:33.843 3126 3656 I BackupManagerService: Found stale backup journal, scheduling
10-29 06:02:33.847 3840 3840 I chatty : uid=10055(com.android.calendar) identical 2 lines
10-29 06:02:33.847 3840 3840 W main : type=1400 audit(0.0:3653): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:33.853 3126 3143 I ActivityManager: Start proc 3840:com.android.calendar/u0a55 for broadcast com.android.calendar/.alerts.AlertReceiver
10-29 06:02:33.897 3840 3840 I ndroid.calenda: The ClassLoaderContext is a special shared library.
10-29 06:02:33.912 3840 3840 I ndroid.calenda: The ClassLoaderContext is a special shared library.
10-29 06:02:33.934 3840 3840 D ExtensionsFactory: No custom extensions.
10-29 06:02:33.936 3840 3840 D AlertReceiver: onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
10-29 06:02:33.955 3863 3863 W main : type=1400 audit(0.0:3654): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:33.959 3126 3143 I ActivityManager: Start proc 3863:com.android.cellbroadcastreceiver/u0a19 for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver
10-29 06:02:33.984 3840 3861 D AlertService: 0 Action = android.intent.action.BOOT_COMPLETED
10-29 06:02:33.988 3840 3861 D AlertService: Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
10-29 06:02:34.007 3126 3143 I ActivityManager: Start proc 3869:com.android.providers.calendar/u0a24 for content provider com.android.providers.calendar/.CalendarProvider2
10-29 06:02:34.065 3869 3869 I viders.calenda: The ClassLoaderContext is a special shared library.
10-29 06:02:34.078 3863 3863 I oadcastreceive: The ClassLoaderContext is a special shared library.
10-29 06:02:34.116 3863 3863 D CellBroadcastReceiver: onReceive Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.cellbroadcastreceiver/.CellBroadcastReceiver (has extras) }
10-29 06:02:34.117 3863 3863 D CellBroadcastReceiver: Start Cell Broadcast configuration.
10-29 06:02:34.127 3869 3869 I CalendarProvider2: Created com.android.providers.calendar.CalendarAlarmManager@f7e25d5(com.android.providers.calendar.CalendarProvider2@ffb31ea)
10-29 06:02:34.131 3863 3863 D CellBroadcastReceiver: Default interval 0 did not change.
10-29 06:02:34.147 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.147 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4370 to 4370 from client com.android.cellbroadcastreceiver
10-29 06:02:34.148 3126 3143 I ActivityManager: Start proc 3902:com.android.contacts/u0a27 for broadcast com.android.contacts/.interactions.OnBootOrUpgradeReceiver
10-29 06:02:34.149 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:02:34.150 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4096 to 4096 from client com.android.cellbroadcastreceiver
10-29 06:02:34.152 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.153 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4383 to 4383 from client com.android.cellbroadcastreceiver
10-29 06:02:34.155 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.155 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4371 to 4372 from client com.android.cellbroadcastreceiver
10-29 06:02:34.157 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:02:34.157 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4097 to 4097 from client com.android.cellbroadcastreceiver
10-29 06:02:34.160 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.164 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4384 to 4385 from client com.android.cellbroadcastreceiver
10-29 06:02:34.170 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.170 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4373 to 4378 from client com.android.cellbroadcastreceiver
10-29 06:02:34.172 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:02:34.173 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4098 to 4098 from client com.android.cellbroadcastreceiver
10-29 06:02:34.175 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.175 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4386 to 4391 from client com.android.cellbroadcastreceiver
10-29 06:02:34.178 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.178 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4379 to 4379 from client com.android.cellbroadcastreceiver
10-29 06:02:34.181 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:02:34.181 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4099 to 4099 from client com.android.cellbroadcastreceiver
10-29 06:02:34.188 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.188 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4392 to 4392 from client com.android.cellbroadcastreceiver
10-29 06:02:34.191 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4380 to 4380 from client com.android.cellbroadcastreceiver
10-29 06:02:34.193 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove cdma broadcast subscription for MID range 4100 to 4100 from client com.android.cellbroadcastreceiver
10-29 06:02:34.195 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4393 to 4393 from client com.android.cellbroadcastreceiver
10-29 06:02:34.197 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4381 to 4381 from client com.android.cellbroadcastreceiver
10-29 06:02:34.202 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4394 to 4394 from client com.android.cellbroadcastreceiver
10-29 06:02:34.204 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4382 to 4382 from client com.android.cellbroadcastreceiver
10-29 06:02:34.206 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4395 to 4395 from client com.android.cellbroadcastreceiver
10-29 06:02:34.211 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.211 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4352 to 4354 from client com.android.cellbroadcastreceiver
10-29 06:02:34.214 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:02:34.216 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4356 to 4356 from client com.android.cellbroadcastreceiver
10-29 06:02:34.219 3902 3902 I ndroid.contact: The ClassLoaderContext is a special shared library.
10-29 06:02:34.222 3472 3602 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4355 to 4355 from client com.android.cellbroadcastreceiver
10-29 06:02:34.242 3840 3861 D AlarmScheduler: No events found starting within 1 week.
10-29 06:02:34.254 3627 3627 I AlarmClock: AlarmInitReceiver android.intent.action.BOOT_COMPLETED
10-29 06:02:34.262 3126 3461 D ActivityManager: Raise procstate to external provider: ProcessRecord{ed7b015 3776:android.process.acore/u0a10}
10-29 06:02:34.264 3126 3461 W Binder : Outgoing transactions from this process must be FLAG_ONEWAY
10-29 06:02:34.264 3126 3461 W Binder : java.lang.Throwable
10-29 06:02:34.264 3126 3461 W Binder : at android.os.BinderProxy.transact(Binder.java:1114)
10-29 06:02:34.264 3126 3461 W Binder : at android.content.ContentProviderProxy.getType(ContentProviderNative.java:451)
10-29 06:02:34.264 3126 3461 W Binder : at com.android.server.am.ActivityManagerService.getProviderMimeType(ActivityManagerService.java:13064)
10-29 06:02:34.264 3126 3461 W Binder : at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:1416)
10-29 06:02:34.264 3126 3461 W Binder : at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:3291)
10-29 06:02:34.264 3126 3461 W Binder : at android.os.Binder.execTransact(Binder.java:731)
10-29 06:02:34.267 3627 3651 I AlarmClock: Fixing alarm instances
10-29 06:02:34.274 3627 3651 V AlarmClock: AlarmInitReceiver finished
10-29 06:02:34.283 3750 3750 I Dialer : VoicemailModule.provideVoicemailClient - providing VoicemailClientImpl
10-29 06:02:34.284 3750 3750 I Dialer : VvmOmtpService - onBoot
10-29 06:02:34.308 3126 3143 I ActivityManager: Start proc 3921:com.android.email/u0a63 for broadcast com.android.email/.service.EmailBroadcastReceiver
10-29 06:02:34.343 3921 3921 I m.android.emai: The ClassLoaderContext is a special shared library.
10-29 06:02:34.359 3921 3921 I m.android.emai: The ClassLoaderContext is a special shared library.
10-29 06:02:34.399 3126 3486 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.409 3921 3938 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
10-29 06:02:34.411 3126 3486 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.436 3259 3259 I SystemBroadcastReceiver: Boot has been completed
10-29 06:02:34.436 3259 3259 I SystemBroadcastReceiver: toggleAppIcon() : FLAG_SYSTEM = true
10-29 06:02:34.471 3126 3143 I ActivityManager: Start proc 3946:com.android.managedprovisioning/u0a14 for broadcast com.android.managedprovisioning/.preprovisioning.BootReminder
10-29 06:02:34.522 3946 3946 I gedprovisionin: The ClassLoaderContext is a special shared library.
10-29 06:02:34.547 3126 3486 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
10-29 06:02:34.548 3126 3486 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.552 3126 3486 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
10-29 06:02:34.557 3921 3962 I Email : Observing account changes for notifications
10-29 06:02:34.559 3126 3486 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.561 3126 3143 I ActivityManager: Start proc 3963:com.android.onetimeinitializer/u0a20 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
10-29 06:02:34.564 3126 3246 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.566 3126 3246 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:02:34.568 3921 3921 E ActivityThread: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@41f69c1 that was originally bound here
10-29 06:02:34.568 3921 3921 E ActivityThread: android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@41f69c1 that was originally bound here
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1610)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1502)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1659)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.app.ContextImpl.bindService(ContextImpl.java:1612)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.content.ContextWrapper.bindService(ContextWrapper.java:698)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
10-29 06:02:34.568 3921 3921 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.os.Looper.loop(Looper.java:193)
10-29 06:02:34.568 3921 3921 E ActivityThread: at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:02:34.569 3126 3461 W ActivityManager: Unbind failed: could not find connection for android.os.BinderProxy@23b6893
10-29 06:02:34.595 3963 3963 I timeinitialize: The ClassLoaderContext is a special shared library.
10-29 06:02:34.604 3963 3963 V OneTimeInitializerReceiver: OneTimeInitializerReceiver.onReceive
10-29 06:02:34.626 3126 3143 I ActivityManager: Start proc 3981:com.android.packageinstaller/u0a23 for broadcast com.android.packageinstaller/.TemporaryFileManager
10-29 06:02:34.687 3981 3981 I ackageinstalle: The ClassLoaderContext is a special shared library.
10-29 06:02:34.718 3472 3472 I VvmSimStateTracker: android.intent.action.BOOT_COMPLETED
10-29 06:02:34.887 4000 4000 W main : type=1400 audit(0.0:3682): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:34.887 4000 4000 I chatty : uid=10041(com.android.traceur) identical 2 lines
10-29 06:02:34.887 4000 4000 W main : type=1400 audit(0.0:3685): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:02:34.893 3126 3143 I ActivityManager: Start proc 4000:com.android.traceur/u0a41 for broadcast com.android.traceur/.Receiver
10-29 06:02:34.930 4000 4000 I android.traceu: The ClassLoaderContext is a special shared library.
10-29 06:02:34.943 4000 4000 I android.traceu: The ClassLoaderContext is a special shared library.
10-29 06:02:34.992 3126 3461 I ActivityManager: Finished processing BOOT_COMPLETED for u0
10-29 06:02:35.300 3679 3999 W MediaScanner: Error opening directory '/oem/media/', skipping: No such file or directory.
10-29 06:02:35.300 3679 3999 W MediaScanner: Error opening directory '/product/media/', skipping: No such file or directory.
10-29 06:02:35.308 3679 3999 V MediaProvider: pruneThumbnails
10-29 06:02:35.310 3679 3999 V MediaProvider: /pruneDeadThumbnailFiles...
10-29 06:02:35.568 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:02:48.996 3126 3141 I ActivityManager: Waited long enough for: ServiceRecord{6dcc434 u0 com.android.calendar/.alerts.InitAlarmsService}
10-29 06:02:36.083 3126 3241 I chatty : uid=1000(system) PhotonicModulat identical 31 lines
10-29 06:02:36.100 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:03:04.030 3840 3868 D InitAlarmsService: Clearing and rescheduling alarms.
10-29 06:03:18.106 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:03:18.103 2981 2981 W [email protected]: type=1400 audit(0.0:3686): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:03:22.564 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:03:22.563 2981 2981 W [email protected]: type=1400 audit(0.0:3687): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:03:22.565 3018 3047 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:03:23.290 3126 3208 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:03:23.302 3126 3208 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:03:23.304 3126 3209 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:03:23.310 3126 4025 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:03:23.414 3126 4025 I chatty : uid=1000 system_server identical 17 lines
10-29 06:03:23.419 3126 4025 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:03:23.421 3126 3136 I system_server: Background concurrent copying GC freed 36747(2MB) AllocSpace objects, 29(1488KB) LOS objects, 42% free, 5MB/9MB, paused 139us total 129.443ms
10-29 06:03:23.438 3126 4025 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:03:23.783 3126 4025 I chatty : uid=1000 system_server identical 56 lines
10-29 06:03:23.792 3126 4025 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:03:23.793 3126 4025 I BackgroundDexOptService: Pinning optimized code {}
10-29 06:04:00.004 3126 3126 I ActivityManager: Killing 3722:com.android.quicksearchbox/u0a33 (adj 906): empty #17
10-29 06:04:00.005 3126 3144 W libprocessgroup: kill(-3722, 9) failed: No such process
10-29 06:04:00.044 3126 3144 W libprocessgroup: kill(-3722, 9) failed: No such process
10-29 06:04:00.046 2957 2957 I Zygote : Process 3722 exited due to signal (9)
10-29 06:04:00.088 3126 3144 W libprocessgroup: kill(-3722, 9) failed: No such process
10-29 06:04:00.088 3126 3144 I libprocessgroup: Successfully killed process cgroup uid 10033 pid 3722 in 82ms
[ 129.098150] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 129.202201] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
10-29 06:04:18.106 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:04:18.102 2981 2981 W [email protected]: type=1400 audit(0.0:3688): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:04:22.562 2981 2981 W [email protected]: type=1400 audit(0.0:3689): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:04:22.566 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:04:22.566 3018 3047 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
[ 189.098101] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 189.202190] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
10-29 06:05:18.106 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:05:18.106 2981 2981 W [email protected]: type=1400 audit(0.0:3690): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:05:22.562 2981 2981 W [email protected]: type=1400 audit(0.0:3691): avc: denied { read } for name="stat" dev="sysfs" ino=21207 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:05:22.567 2981 2981 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:05:22.567 3018 3047 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:05:42.437 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.803 3126 3241 I chatty : uid=1000(system) PhotonicModulat identical 22 lines
10-29 06:05:42.820 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.830 3126 3227 I AudioTrack: AUDIO_OUTPUT_FLAG_FAST successful; frameCount 0 -> 4512
10-29 06:05:42.831 2968 3092 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=1024
10-29 06:05:42.832 2968 3092 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:05:42.832 2968 3092 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:05:42.835 3126 3246 I ActivityManager: START u0 {act=android.settings.APPLICATION_DEVELOPMENT_SETTINGS flg=0x10008000 cmp=com.android.settings/.development.DevelopmentSettingsDisabledActivity} from uid 1000
10-29 06:05:42.836 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.850 3126 3246 E ActivityManager: applyOptionsLocked: Unknown animationType=0
10-29 06:05:42.853 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.867 3327 3327 V StatusBar: mStatusBarWindow: com.android.systemui.statusbar.phone.StatusBarWindowView{6a28f05 V.ED..... ........ 0,0-1920,1080} canPanelBeCollapsed(): true
10-29 06:05:42.870 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.904 3126 3241 I chatty : uid=1000(system) PhotonicModulat identical 2 lines
10-29 06:05:42.920 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.920 2987 3243 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{3b0ac73 token=Token{89440e2 ActivityRecord{5d6b5ad u0 com.android.settings/.development.DevelopmentSettingsDisabledActivity t3}}}#0
10-29 06:05:42.935 3491 3532 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:05:42.935 3491 3532 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:05:42.935 3491 3532 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:05:42.935 3491 3532 D OpenGLRenderer: Swap behavior 2
10-29 06:05:42.937 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.953 3126 3241 I chatty : uid=1000(system) PhotonicModulat identical 1 line
10-29 06:05:42.970 3126 3241 E LightsService: Light requested not available on this device. 0
10-29 06:05:42.982 2968 4034 I audio_hw_primary: start_output_stream_primary... 0xf3d50000, device 1024, address , mode 0
10-29 06:05:42.982 2968 4034 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:05:42.986 2968 4034 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:05:42.986 2968 4034 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:05:43.316 3327 3327 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:05:43.492 3693 3693 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:05:43.496 3327 3327 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:05:43.497 2987 3626 D SurfaceFlinger: duplicate layer name: changing Surface(name=73d9006 Toast)/@0xd9d9863 - animation-leash to Surface(name=73d9006 Toast)/@0xd9d9863 - animation-leash#1
10-29 06:05:43.512 3126 3149 I ActivityManager: Displayed com.android.launcher3/.Launcher: +3m15s796ms (total +3m15s833ms)
10-29 06:05:43.524 3327 3527 W AudioTrack: AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 -> 8329
10-29 06:05:43.545 3327 3327 D StatusBar: disable<e i a s b h!r!c s > disable2<q i n >
10-29 06:05:43.546 3126 3486 W UsageStatsService: Event reported without a package name
10-29 06:05:43.662 3693 3693 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:05:44.901 3126 3468 W NotificationService: Toast already killed. pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@c3a0245
10-29 06:05:46.414 3126 3149 W WindowManager: Unable to start animation, surface is null or no children.
10-29 06:05:46.425 3126 3242 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
10-29 06:05:46.723 2968 2968 W audio_hw_primary: do_out_standby... 0xf3d50000
U-Boot SPL 2018.03 (Oct 29 2019 - 11:48:53 +0800)
PMIC: PFUZE100 ID=0x10
DDRINFO: start lpddr4 ddr init
DRAM PHY training for 3200MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
Training PASS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC1
U-Boot 2018.03 (Oct 29 2019 - 11:48:53 +0800)
CPU: Freescale i.MX8MQ rev2.1 1300 MHz (running at 800 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 70C
Reset cause: POR
Model: Freescale i.MX8MQ EVK
DRAM: 3 GiB
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C0 0x50]
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
No panel detected: default to HDMI
Display: HDMI (1280x720)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
flash target is MMC:0
Net: No ethernet found.
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
u-boot=>
Training PASS
Training PASS
Training PASS
Training PASS
Normal Boot
CPU: Industrial temperature grade (-40C to 105C) at 66C
Reset cause: POR
DRAM: 3 GiB
Failed (-5)
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF a-20190
- U-Boot 2018.03
Fastboot: Normal
Normal Boot
verify OK, boot 'boot_a'
Kernel load addr 0x40480000 size 30901 KiB
kernel @ 40480000 (31642112)
ramdisk @ 43600000 (7425791)
fdt @ 43400000 (45831)
## Flattened Device Tree blob at 43400000
Booting using the fdt blob at 0x43400000
Using Device Tree in place at 0000000043400000, end 000000004340e306
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.98-00001-gde6b135-dirty (neolix@neolix-PowerEdge-R420) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #15 SMP PREEMPT Tue Oct 29 11:50:29 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Freescale i.MX8MQ EVK
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: ION carveout pool at 0x00000000f8000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node imx_ion@0, compatible id imx-ion-pool
[ 0.000000] cma: Reserved 1280 MiB at 0x00000000a8000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xa7fba500-0xa7fbc2ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000097ffffff]
[ 0.000000] node 0: [mem 0x0000000098100000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x414 with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu @ffff800067f50000 s64536 r8192 d29672 u102400
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 773888
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200 init=/init androidboot.gui_resolution=1080p androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.fbTileSupport=enable cma=1280M androidboot.primary_display=imx-drm firmware_class.path=/vendor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.wifivendor=bcm buildvariant=userdebug androidboot.serialno=152059d6f32ef628 androidboot.btmacaddr=15:20:59:d6:f3:2e androidboot.soc_type=imx8mq androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:4838,KL:0,KD:0,AVB:2259,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix=_a dm="1 vroot none ro 1,0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_ze
[ 0.000000] device-mapper: init: will configure 1 devices
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1621520K/3144704K available (15868K kernel code, 2420K rwdata, 7044K rodata, 5504K init, 523K bss, 212464K reserved, 1310720K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000009000000 ( 15872 KB)
[ 0.000000] .rodata : 0xffff000009000000 - 0xffff0000096f0000 ( 7104 KB)
[ 0.000000] .init : 0xffff0000096f0000 - 0xffff000009c50000 ( 5504 KB)
[ 0.000000] .data : 0xffff000009c50000 - 0xffff000009ead200 ( 2421 KB)
[ 0.000000] .bss : 0xffff000009ead200 - 0xffff000009f30080 ( 524 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0003000000 ( 48 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff8000c0000000 ( 3072 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MQ clock driver init done
[ 0.000000] arch_timer: cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.000005] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.008872] system counter timer init
[ 0.011730] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.019711] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.031073] Console: colour dummy device 80x25
[ 0.034491] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044750] pid_max: default: 32768 minimum: 301
[ 0.049446] Security Framework initialized
[ 0.053469] SELinux: Initializing.
[ 0.058526] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.064943] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.071300] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.077994] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.101208] ASID allocator initialised with 32768 entries
[ 0.109209] Hierarchical SRCU implementation.
[ 0.117787] Cannot find MU entry in device tree
[ 0.119616] CPU identified as i.MX8MQ, silicon rev 2.1
[ 0.125575] EFI services will not be available.
[ 0.137189] smp: Bringing up secondary CPUs ...
[ 0.165378] Detected VIPT I-cache on CPU1
[ 0.165408] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.165437] CPU1: Booted secondary processor [410fd034]
[ 0.193442] Detected VIPT I-cache on CPU2
[ 0.193464] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.193485] CPU2: Booted secondary processor [410fd034]
[ 0.221533] Detected VIPT I-cache on CPU3
[ 0.221554] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.221574] CPU3: Booted secondary processor [410fd034]
[ 0.221803] smp: Brought up 1 node, 4 CPUs
[ 0.271461] SMP: Total of 4 processors activated.
[ 0.276163] CPU features: detected feature: GIC system register CPU interface
[ 0.283324] CPU features: detected feature: 32-bit EL0 Support
[ 0.289156] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.328453] CPU: All CPU(s) started at EL2
[ 0.329871] alternatives: patching kernel code
[ 0.334531] CPU3: update max cpu_capacity 1024
[ 0.339719] devtmpfs: initialized
[ 0.341638] CPU1: update max cpu_capacity 1024
[ 0.353055] Registered cp15_barrier emulation handler
[ 0.355329] Registered setend emulation handler
[ 0.360407] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369613] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.416035] pinctrl core: initialized pinctrl subsystem
[ 0.420158] DMI not present or invalid.
[ 0.422730] NET: Registered protocol family 16
[ 0.428956] schedtune: configured to support 5 boost groups
[ 0.440410] cpuidle: using governor menu
[ 0.444062] vdso: 2 pages (1 code @ ffff000009007000, 1 data @ ffff000009c54000)
[ 0.448915] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.463377] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.468391] Serial: AMBA PL011 UART driver
[ 0.471148] imx rpmsg driver is registered.
[ 0.484001] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.501682] MU is ready for cross core communication!
[ 0.505798] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.566159] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.590638] ACPI: Interpreter disabled.
[ 0.595760] vgaarb: loaded
[ 0.596755] SCSI subsystem initialized
[ 0.603698] usbcore: registered new interface driver usbfs
[ 0.606374] usbcore: registered new interface driver hub
[ 0.612117] usbcore: registered new device driver usb
[ 0.618984] i2c i2c-0: IMX I2C adapter registered
[ 0.621501] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.627653] i2c i2c-1: IMX I2C adapter registered
[ 0.631526] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.638233] i2c i2c-2: IMX I2C adapter registered
[ 0.641553] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.648929] media: Linux media interface: v0.10
[ 0.651555] Linux video capture interface: v2.00
[ 0.656426] pps_core: LinuxPPS API ver. 1 registered
[ 0.660993] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.670215] PTP clock support registered
[ 0.675430] EDAC MC: Ver: 3.0.0
[ 0.678086] dmi: Firmware registration failed.
[ 0.682920] Advanced Linux Sound Architecture Driver Initialized.
[ 0.688925] Bluetooth: Core ver 2.22
[ 0.691406] NET: Registered protocol family 31
[ 0.695729] Bluetooth: HCI device and connection manager initialized
[ 0.702154] Bluetooth: HCI socket layer initialized
[ 0.706977] Bluetooth: L2CAP socket layer initialized
[ 0.712119] Bluetooth: SCO socket layer initialized
[ 0.720892] clocksource: Switched to clocksource arch_sys_counter
[ 0.788257] VFS: Disk quotas dquot_6.6.0
[ 0.789405] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.796603] pnp: PnP ACPI: disabled
[ 0.818716] NET: Registered protocol family 2
[ 0.820856] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.828018] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.834816] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.840806] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.846783] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.853401] NET: Registered protocol family 1
[ 0.860598] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.866507] kvm [1]: 8-bit VMID
[ 0.869999] kvm [1]: GICv3: no GICV resource entry
[ 0.873511] kvm [1]: disabling GICv2 emulation
[ 0.878013] kvm [1]: GIC system register CPU interface enabled
[ 0.884187] kvm [1]: vgic interrupt IRQ1
[ 0.888128] kvm [1]: Hyp mode initialized successfully
[ 0.902874] audit: initializing netlink subsys (disabled)
[ 0.905709] audit: type=2000 audit(0.803:1): state=initialized audit_enabled=0 res=1
[ 0.906898] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.936174] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.939615] Registering sdcardfs 0.1
[ 0.943123] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.949713] fuse init (API version 7.26)
[ 0.953353] 9p: Installing v9fs 9p2000 file system support
[ 0.971131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.975765] io scheduler noop registered
[ 0.979814] io scheduler cfq registered (default)
[ 0.984392] io scheduler mq-deadline registered
[ 0.988866] io scheduler kyber registered
[ 1.021517] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 1.027975] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 1.037250] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.050827] mxs-dma 33000000.dma-apbh: initialized
[ 1.055835] Bus freq driver module loaded
[ 1.059026] Config NOC for GPU to 0x80000600
[ 1.061280] Config NOC for VPU and CPU
[ 1.069597] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.073653] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.078188] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.099801] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.107892] SuperH (H)SCI(F) driver initialized
[ 1.110629] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 44, base_baud = 1562500) is a IMX
[ 1.121293] console [ttymxc0] enabled
[ 1.125823] bootconsole [ec_imx6q0] disabled
[ 1.135783] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 45, base_baud = 5000000) is a IMX
[ 1.147796] msm_serial: driver initialized
[ 1.172451] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.179092] [drm] No driver support for vblank timestamp query.
[ 1.185248] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
[ 1.192938] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 1.201482] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
[ 1.208299] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
[ 1.218234] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
[ 1.229093] [drm] VCO frequency is 5940000
[ 1.233208] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
[ 1.265235] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 1.272498] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 1.278733] [drm] Failed to initialize HDCP
[ 1.285014] [drm] hdmi-audio-codec driver bound to HDMI
[ 1.290274] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[ 1.321793] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 1.334158] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 222750, color depth is 12-bit.
[ 1.334168] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (12-bit). Settings found in row 18
[ 1.334173] [drm] VCO frequency is 4455000
[ 1.334179] [drm] VCO frequency (4455000 KHz) is supported. Settings found in row 11
[ 1.348063] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 2.055533] Console: switching to colour frame buffer device 240x67
[ 2.149739] imx-drm display-subsystem: fb0: frame buffer device
[ 2.156466] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.178564] brd: module loaded
[ 2.189818] loop: module loaded
[ 2.194093] zram: Added device: zram0
[ 2.206735] fsl-quadspi 30bb0000.qspi: unrecognized JEDEC id bytes: 00, 00, 00
[ 2.213999] fsl-quadspi 30bb0000.qspi: Freescale QuadSPI probe failed
[ 2.220501] fsl-quadspi: probe of 30bb0000.qspi failed with error -2
[ 2.227026] slram: not enough parameters.
[ 2.235979] libphy: Fixed MDIO Bus: probed
[ 2.242198] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 2.248849] tun: Universal TUN/TAP device driver, 1.6
[ 2.254426] CAN device driver interface
[ 2.261397] fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
[ 2.271009] pps pps0: new PPS source ptp0
[ 2.279991] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 2.290094] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 72:83:3b:35:7d:1f
[ 2.302329] libphy: fec_enet_mii_bus: probed
[ 2.306816] mdio_bus 30be0000.ethernet-1: MDIO device at address 0 is missing.
[ 2.315448] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.322805] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.328718] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.334829] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.341869] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.347616] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.355561] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.362472] sky2: driver version 1.30
[ 2.367211] PPP generic driver version 2.4.2
[ 2.371894] PPP BSD Compression module registered
[ 2.376677] PPP Deflate Compression module registered
[ 2.381772] PPP MPPE Compression module registered
[ 2.386803] usbcore: registered new interface driver asix
[ 2.392419] usbcore: registered new interface driver ax88179_178a
[ 2.398751] usbcore: registered new interface driver cdc_ether
[ 2.404763] usbcore: registered new interface driver net1080
[ 2.410654] usbcore: registered new interface driver cdc_subset
[ 2.416746] usbcore: registered new interface driver zaurus
[ 2.422559] usbcore: registered new interface driver cdc_ncm
[ 2.439847] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.446411] ehci-pci: EHCI PCI platform driver
[ 2.451101] ehci-platform: EHCI generic platform driver
[ 2.456671] ehci-orion: EHCI orion driver
[ 2.461048] ehci-exynos: EHCI EXYNOS driver
[ 2.465523] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 2.471358] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.477632] ohci-pci: OHCI PCI platform driver
[ 2.482258] ohci-platform: OHCI generic platform driver
[ 2.487852] ohci-exynos: OHCI EXYNOS driver
[ 2.492898] Can't support > 32 bit dma.
[ 2.496784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.502315] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.517406] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000001010810
[ 2.526886] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x38200000
[ 2.533144] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.539957] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.547200] usb usb1: Product: xHCI Host Controller
[ 2.552098] usb usb1: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.559469] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.565536] hub 1-0:1.0: USB hub found
[ 2.569340] hub 1-0:1.0: 1 port detected
[ 2.573887] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.579408] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.587153] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.593971] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.600839] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.608081] usb usb2: Product: xHCI Host Controller
[ 2.613037] usb usb2: Manufacturer: Linux 4.14.98-00001-gde6b135-dirty xhci-hcd
[ 2.620365] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.625977] hub 2-0:1.0: USB hub found
[ 2.629777] hub 2-0:1.0: 1 port detected
[ 2.635117] usbcore: registered new interface driver usb-storage
[ 2.641327] usbcore: registered new interface driver usb_ehset_test
[ 2.653009] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.665235] usbcore: registered new interface driver xpad
[ 2.670823] usbcore: registered new interface driver usb_acecad
[ 2.677062] usbcore: registered new interface driver aiptek
[ 2.682867] usbcore: registered new interface driver gtco
[ 2.688440] usbcore: registered new interface driver hanwang
[ 2.694339] usbcore: registered new interface driver kbtab
[ 2.704130] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs-rtc-lp as rtc0
[ 2.714680] i2c /dev entries driver
[ 2.726512] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
[ 2.732728] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
[ 2.733827] random: fast init done
[ 2.738740] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at /mipi_csi1@30a70000/port/endpoint1 XXX found
[ 2.751923] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
[ 2.760101] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
[ 2.766335] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
[ 2.772175] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at /mipi_csi2@30b60000/port/endpoint1 XXX found
[ 2.782204] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 1, name: mxc-mipi-csi2.1
[ 2.790350] max9286_probe: YYJ ADD 1 @@
[ 2.794550] max9286_read_reg: YYJ ADD 41 @@ reg value=1e
[ 2.801229] max9286_hardware_preinit: YYJ ADD 2 @@
[ 2.806216] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 2.812777] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 2.836917] max9286_write_reg: YYJ ADD 42 @@ reg value=3f
[ 2.852914] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.868913] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 2.884911] max9271_write_reg: YYJ ADD 40 @@ reg value=40
[ 2.900912] max9271_write_reg: YYJ ADD 40 @@ reg value=8
[ 2.907319] max9271_write_reg: YYJ ADD 40 @@ reg value=97
[ 2.920923] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[ 2.924912] max9286_write_reg: YYJ ADD 42 @@ reg value=3b
[ 2.948913] max9286_write_reg: YYJ ADD 42 @@ reg value=12
[ 2.955405] max9286_write_reg: YYJ ADD 42 @@ reg value=1
[ 2.961814] max9286_write_reg: YYJ ADD 42 @@ reg value=63
[ 2.968254] max9286_write_reg: YYJ ADD 42 @@ reg value=64
[ 2.974762] max9286_write_reg: YYJ ADD 42 @@ reg value=8
[ 2.981175] max9286_write_reg: YYJ ADD 42 @@ reg value=c
[ 2.987582] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.076696] usb 1-1: New USB device found, idVendor=17ef, idProduct=6019
[ 3.083424] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.090580] usb 1-1: Product: Lenovo Optical USB Mouse
[ 3.095737] usb 1-1: Manufacturer: PixArt
[ 3.193047] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 3.200920] max9286_read_reg: YYJ ADD 41 @@ reg value=49
[ 3.207518] max9286_data->sensor_num=80
[ 3.207523] max9286_mipi: reg = 0x80.
[ 3.215115] max9286_mipi: sensor number = 1.
[ 3.219404] YYJ v4l2_i2c_subdev_init sd->name =max9286_mipi 1-006a
[ 3.225776] YYJ add --->media_entity_pads_init entity->num_pads=4
[ 3.231976] YYJ ADD max9286_probe media_entity_pads_init retval=0
[ 3.238262] mxc-mipi-csi2_yav 30b60000.mipi_csi: Registered sensor subdevice: max9286_mipi 1-006a
[ 3.247150] YYJ ADD max9286_probe retval=0
[ 3.251351] max9286_mipi 1-006a: YYJ ADD 4 In max9286_hardware_init()
[ 3.257983] max9286_mipi 1-006a: In max9286_hardware_init()
[ 3.263571] max9286_write_reg: YYJ ADD 42 @@ reg value=e
[ 3.269794] max9286_camera_reorder: YYJ ADD 3 @@
[ 3.274609] max9286_write_reg: YYJ ADD 42 @@ reg value=b
[ 3.280831] max9286_write_reg: YYJ ADD 42 @@ reg value=69
[ 3.287157] max9286_write_reg: YYJ ADD 42 @@ reg value=0
[ 3.320912] max9271_write_reg: YYJ ADD 40 @@ reg value=7
[ 3.352912] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.359133] max9271_write_reg: YYJ ADD 40 @@ reg value=0
[ 3.380913] max9271_write_reg: YYJ ADD 40 @@ reg value=20
[ 3.381462] max9271_write_reg: YYJ ADD 40 @@ reg value=21
[ 3.393020] max9271_write_reg: YYJ ADD 40 @@ reg value=22
[ 3.399331] max9271_write_reg: YYJ ADD 40 @@ reg value=23
[ 3.405654] max9271_write_reg: YYJ ADD 40 @@ reg value=24
[ 3.411964] max9271_write_reg: YYJ ADD 40 @@ reg value=25
[ 3.418281] max9271_write_reg: YYJ ADD 40 @@ reg value=26
[ 3.424602] max9271_write_reg: YYJ ADD 40 @@ reg value=27
[ 3.430911] max9271_write_reg: YYJ ADD 40 @@ reg value=30
[ 3.437239] max9271_write_reg: YYJ ADD 40 @@ reg value=31
[ 3.443548] max9271_write_reg: YYJ ADD 40 @@ reg value=32
[ 3.449858] max9271_write_reg: YYJ ADD 40 @@ reg value=33
[ 3.456180] max9271_write_reg: YYJ ADD 40 @@ reg value=34
[ 3.462487] max9271_write_reg: YYJ ADD 40 @@ reg value=35
[ 3.468812] max9271_write_reg: YYJ ADD 40 @@ reg value=36
[ 3.475138] max9271_write_reg: YYJ ADD 40 @@ reg value=37
[ 3.481447] max9271_write_reg: YYJ ADD 40 @@ reg value=3f
[ 3.487771] max9271_write_reg: YYJ ADD 40 @@ reg value=47
[ 3.494080] max9271_write_reg: YYJ ADD 40 @@ reg value=48
[ 3.500385] max9271_write_reg: YYJ ADD 40 @@ reg value=49
[ 3.506708] max9271_write_reg: YYJ ADD 40 @@ reg value=4c
[ 3.513020] max9271_write_reg: YYJ ADD 40 @@ reg value=43
[ 3.519395] max9271_write_reg: YYJ ADD 40 @@ reg value=1
[ 3.525617] max9271_write_reg: YYJ ADD 40 @@ reg value=9
[ 3.531838] max9271_write_reg: YYJ ADD 40 @@ reg value=a
[ 3.538095] max9271_write_reg: YYJ ADD 40 @@ reg value=b
[ 3.544340] max9271_write_reg: YYJ ADD 40 @@ reg value=c
[ 3.560903] max9286_mipi: initialized sensor = 0x04.
[ 3.565975] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.572230] max9286_write_reg: YYJ ADD 42 @@ reg value=a
[ 3.578473] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.584809] max9286_write_reg: YYJ ADD 42 @@ reg value=34
[ 3.591151] max9271_write_reg: YYJ ADD 40 @@ reg value=4
[ 4.608912] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.632913] max9286_write_reg: YYJ ADD 42 @@ reg value=15
[ 4.639400] max9286_mipi 1-006a: max9286_mipi is found, name max9286_mipi 1-006a
[ 4.646817] YYJ ADD max9286_probe done
[ 4.652145] usbcore: registered new interface driver uvcvideo
[ 4.657913] USB Video Class driver (1.1.1)
[ 4.663845] __power_supply_register: Expected proper parent device for 'battery'
[ 4.671607] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 4.684057] __power_supply_register: Expected proper parent device for 'usb'
[ 4.697035] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 4.705076] device-mapper: uevent: version 1.0.3
[ 4.710333] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[ 4.719649] Bluetooth: HCI UART driver ver 2.3
[ 4.724117] Bluetooth: HCI UART protocol H4 registered
[ 4.729330] Bluetooth: HCI UART protocol BCSP registered
[ 4.734690] Bluetooth: HCI UART protocol ATH3K registered
[ 4.740178] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.746840] Bluetooth: HCI UART protocol Broadcom registered
[ 4.752593] Bluetooth: HCI UART protocol QCA registered
[ 4.758115] bt power gpio is:69
[ 4.761565] rfkill: BT RF going to : on
[ 4.765471] mxc_bt_rfkill_reset
[ 4.768720] mxc_bt_rfkill driver success loaded
[ 4.775467] sdhci: Secure Digital Host Controller Interface driver
[ 4.781673] sdhci: Copyright(c) Pierre Ossman
[ 4.786396] Synopsys Designware Multimedia Card Interface Driver
[ 4.794260] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.849539] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 4.858515] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 4.911236] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 4.926651] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.937108] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 4.943024] caam-snvs 30370000.caam-snvs: violation handlers armed - init state
[ 4.952647] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.968249] input: PixArt Lenovo Optical USB Mouse as /devices/platform/usb@38200000/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:17EF:6019.0001/input/input1
[ 4.983718] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo Optical USB Mouse] on usb-xhci-hcd.0.auto-1/input0
[ 4.987871] mmc0: new HS400 MMC card at address 0001
[ 4.997227] usbcore: registered new interface driver usbhid
[ 5.002630] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 5.007374] usbhid: USB HID core driver
[ 5.012443] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 5.022214] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 5.028719] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 5.039765] Alternate GPT is invalid, using primary GPT.
[ 5.045226] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 5.055546] ashmem: initialized
[ 5.065107] usbcore: registered new interface driver snd-usb-audio
[ 5.072464] ak4458 2-0010: 2-0010 supply DVDD not found, using dummy regulator
[ 5.079837] ak4458 2-0010: 2-0010 supply AVDD not found, using dummy regulator
[ 5.087368] ak4458 2-0012: 2-0012 supply DVDD not found, using dummy regulator
[ 5.094716] ak4458 2-0012: 2-0012 supply AVDD not found, using dummy regulator
[ 5.102406] ak4497 2-0011: 2-0011 supply DVDD not found, using dummy regulator
[ 5.109754] ak4497 2-0011: 2-0011 supply AVDD not found, using dummy regulator
[ 5.117648] ak5558 2-0013: 2-0013 supply DVDD not found, using dummy regulator
[ 5.124949] ak5558 2-0013: 2-0013 supply AVDD not found, using dummy regulator
[ 5.165832] imx-wm8524 sound-wm8524: wm8524-hifi <-> 308b0000.sai mapping ok
[ 5.172920] imx-wm8524 sound-wm8524: ASoC: no DMI vendor name!
[ 5.184434] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 30810000.spdif mapping ok
[ 5.192100] imx-spdif sound-spdif: ASoC: no DMI vendor name!
[ 5.200822] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 308a0000.spdif mapping ok
[ 5.208748] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 5.221465] ak4458 2-0010: ASoC: failed to probe component -6
[ 5.227525] imx-ak4458 sound-ak4458: ASoC: failed to instantiate card -6
[ 5.235034] imx-ak4458 sound-ak4458: snd_soc_register_card failed (-6)
[ 5.257266] ak5558 2-0013: ASoC: failed to probe component -6
[ 5.263254] imx-ak5558 sound-ak5558: ASoC: failed to instantiate card -6
[ 5.270811] imx-ak5558 sound-ak5558: snd_soc_register_card failed (-6)
[ 5.277998] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30050000.sai mapping ok
[ 5.284804] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[ 5.292550] NET: Registered protocol family 26
[ 5.297038] u32 classifier
[ 5.299747] Actions configured
[ 5.303173] Netfilter messages via NETLINK v0.30.
[ 5.308182] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.314595] ctnetlink v0.93: registering with nfnetlink.
[ 5.320426] xt_time: kernel timezone is -0000
[ 5.324981] IPv4 over IPsec tunneling driver
[ 5.329867] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.335927] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 5.341864] Initializing XFRM netlink socket
[ 5.346638] NET: Registered protocol family 10
[ 5.352520] Segment Routing with IPv6
[ 5.356273] mip6: Mobile IPv6
[ 5.359332] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.365826] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.372961] NET: Registered protocol family 17
[ 5.377438] NET: Registered protocol family 15
[ 5.381899] can: controller area network core (rev 20170425 abi 9)
[ 5.388146] NET: Registered protocol family 29
[ 5.392610] can: raw protocol (rev 20170425)
[ 5.396899] can: broadcast manager protocol (rev 20170425 t)
[ 5.402638] can: netlink gateway (rev 20170425) max_hops=1
[ 5.408524] Bluetooth: RFCOMM TTY layer initialized
[ 5.413488] Bluetooth: RFCOMM socket layer initialized
[ 5.418663] Bluetooth: RFCOMM ver 1.11
[ 5.422495] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.427823] Bluetooth: BNEP filters: protocol multicast
[ 5.433125] Bluetooth: BNEP socket layer initialized
[ 5.438107] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.444103] Bluetooth: HIDP socket layer initialized
[ 5.449083] lib80211: common routines for IEEE802.11 drivers
[ 5.455193] 9pnet: Installing 9P2000 support
[ 5.462170] registered taskstats version 1
[ 5.478195] cpu cpu0: registered imx8mq-cpufreq
[ 5.497029] galcore: clk_get 2d core clock failed, disable 2d/vg!
[ 5.504018] Galcore version 6.2.4.190076
[ 5.596725] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 1
[ 5.606538] update hantro voltage from 900 mV to 1000 mV
[ 5.612180] hantrodec: module inserted. Major = 509
[ 5.619202] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2019-10-29 06:09:56 UTC (1572329396)
[ 5.629945] VSD_3V3: disabling
[ 5.633084] gpio_dvfs: disabling
[ 5.636323] VGEN1: disabling
[ 5.641061] VGEN6: disabling
[ 5.644371] ALSA device list:
[ 5.647355] #0: wm8524-audio
[ 5.650477] #1: imx-spdif
[ 5.653333] #2: imx-hdmi-arc
[ 5.656390] #3: imx-audio-hdmi
[ 5.659933] device-mapper: init: attempting early device configuration.
[ 5.667491] device-mapper: init: adding target '0 3611944 verity 1 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 4096 4096 451493 451493 sha1 ab53a91cafa25dca457eea6d0b6be558e49cb919 6d1a422b71955fd58a5429b133b20b140b4a4a7e 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=ffbff54a-4c69-48a4-a25b-74040f5653d9 fec_roots 2 fec_blocks 455050 fec_start 455050'
[ 5.707309] device-mapper: init: dm-0 is ready
[ 5.722780] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 5.729873] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
[ 5.737182] devtmpfs: mounted
[ 5.741822] Freeing unused kernel memory: 5504K
[ 5.772533] init: init first stage started!
[ 5.777349] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 5.787237] init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
[ 5.833080] init: [libfs_mgr]Returning avb_handle with status: 0
[ 5.844591] init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/30b40000.usdhc/by-name/vendor_a /dev/block/platform/30b40000.usdhc/by-name/vendor_a 4096 4096 64481 64481 sha1 51806766da39076dff37f6ba052ba9c97bb90718 9dcbde58e29f0cf7ca3f2b33cfdfb75a9d9fb268 10 use_fec_from_device /dev/block/platform/30b40000.usdhc/by-name/vendor_a fec_roots 2 fec_blocks 64990 fec_start 64990 restart_on_corruption ignore_zero_blocks'
[ 5.894194] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 5.903581] init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
[ 5.912547] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 5.919515] init: Loading SELinux policy
[ 5.952942] SELinux: Class process2 not defined in policy.
[ 5.958978] SELinux: Class infiniband_pkey not defined in policy.
[ 5.965168] SELinux: Class infiniband_endport not defined in policy.
[ 5.971620] SELinux: the above unknown classes and permissions will be denied
[ 5.978789] SELinux: policy capability network_peer_controls=1
[ 5.984717] SELinux: policy capability open_perms=1
[ 5.989690] SELinux: policy capability extended_socket_class=1
[ 5.995617] SELinux: policy capability always_check_network=0
[ 6.001509] SELinux: policy capability cgroup_seclabel=0
[ 6.006914] SELinux: policy capability nnp_nosuid_transition=0
[ 6.106640] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 6.106640]
[ 6.106880] audit: type=1403 audit(1572329396.983:2): policy loaded auid=4294967295 ses=4294967295
[ 6.125479] audit: type=1404 audit(1572329396.995:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 6.150395] selinux: SELinux: Loaded file_contexts
[ 6.150395]
[ 6.161106] init: init second stage started!
[ 6.191226] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 6.203160] selinux: SELinux: Loaded file_contexts
[ 6.203160]
[ 6.209471] init: Running restorecon...
[ 6.221227] init: waitid failed: No child processes
[ 6.232495] init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
[ 6.250279] init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
[ 6.259335] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2348
[ 6.266903] init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2349
[ 6.274066] init: Parsing file /init.rc...
[ 6.374780] audit: type=1400 audit(1572329397.251:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.379012] ueventd: ueventd started!
[ 6.392544] audit: type=1400 audit(1572329397.251:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.398848] selinux: SELinux: Loaded file_contexts
[ 6.398848]
[ 6.413773] audit: type=1400 audit(1572329397.251:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.419991] ueventd: Parsing file /ueventd.rc...
[ 6.437575] audit: type=1400 audit(1572329397.251:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.459849] audit: type=1400 audit(1572329397.315:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.477558] audit: type=1400 audit(1572329397.315:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.495209] audit: type=1400 audit(1572329397.315:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.513008] audit: type=1400 audit(1572329397.315:11): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 6.513558] ueventd: Parsing file /vendor/ueventd.rc...
[ 6.539184] ueventd: Parsing file /odm/ueventd.rc...
[ 6.544218] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[ 6.554175] ueventd: Parsing file /ueventd.freescale.rc...
[ 6.559789] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[ 6.585584] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin'
[ 6.602957] ueventd: loading /devices/platform/30bd0000.sdma/firmware/imx!sdma!sdma-imx7d.bin took 17ms
[ 6.620266] imx-sdma 302c0000.sdma: loaded firmware 4.4
[ 6.621050] imx-sdma 30bd0000.sdma: loaded firmware 4.4
[ 6.749164] Registered swp emulation handler
[ 6.758838] watchdogd: watchdogd started (interval 10, margin 20)!
[ 6.765936] Console: switching to colour dummy device 80x25
[ 6.791116] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 6.940627] wlan: loading driver v4.5.23.1
[ 6.955028] EXT4-fs (mmcblk0p12): recovery complete
[ 6.960545] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 8.074341] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 8.074341]
[ 8.080390] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 8.080390]
[ 8.087772] e2fsck: Pass 2: Checking directory structure
[ 8.087772]
[ 8.094577] e2fsck: Pass 3: Checking directory connectivity
[ 8.094577]
[ 8.101703] e2fsck: Pass 4: Checking reference counts
[ 8.101703]
[ 8.108271] e2fsck: Pass 5: Checking group summary information
[ 8.108271]
[ 8.115652] e2fsck: /dev/block/by-name/userdata: 1656/581632 files (2.3% non-contiguous), 74008/2326528 blocks
[ 8.115652]
[ 8.133284] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[ 8.149175] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[ 8.190008] zram0: detected capacity change from 0 to 314572800
[ 8.215458] logd.auditd: start
[ 8.218795] logd.klogd: 8117904501
[ 8.224610] mkswap: Swapspace size: 307196k, UUID=4efddede-afa6-4f77-a53d-25a929e9cb44
[ 8.233462] Adding 307196k swap on /dev/block/zram0. Priority:-2 extents:1 across:307196k SS
[ 8.256753] type=1400 audit(1572329399.119:38): avc: denied { getattr } for pid=2348 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.277867] type=1400 audit(1572329399.119:38): avc: denied { getattr } for pid=2348 comm="init" path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
[ 8.298456] type=1400 audit(1572329399.123:39): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 8.640095] update_verifier: Started with arg 1: nonencrypted
[ 8.651383] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 8.657858] update_verifier: Leaving update_verifier.
[ 8.713177] logd.daemon: reinit
[ 8.725216] rfkill: BT RF going to : off
[ 8.739582] Mass Storage Function, version: 2009/09/11
[ 8.744786] LUN: removable file: (no medium)
[ 8.755325] using random self ethernet address
[ 8.759882] using random host ethernet address
[ 8.766044] file system registered
[ 8.882559] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
evk_8mq:/ $ [ 9.129627] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 9.524593] read descriptors
[ 9.537368] read strings
[ 10.395207] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.426422] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.458525] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[ 10.696740] android_work: sent uevent USB_STATE=CONNECTED
[ 10.710691] configfs-gadget gadget: high-speed config #1: b
[ 10.719905] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.297098] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
[ 11.711347] random: crng init done
[ 12.174338] init: Service 'early_init_sh' (pid 2351) exited with status 0
[ 13.190254] type=1400 audit(1572329401.719:576): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 13.212528] type=1400 audit(1572329404.067:577): avc: denied { dac_read_search } for pid=2996 comm="Binder:2996_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
[ 13.216623] audit_log_lost: 30 callbacks suppressed
[ 13.216628] audit: audit_lost=522 audit_rate_limit=5 audit_backlog_limit=64
[ 13.243562] audit: rate limit exceeded
[ 13.460319] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.472550] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.483150] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 13.650246] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
[ 14.184579] read descriptors
[ 14.187521] read strings
[ 14.190234] read descriptors
[ 14.193152] read strings
[ 14.213415] init: Received control message 'start' for 'adbd' from pid: 3121 (system_server)
[ 14.223376] android_work: sent uevent USB_STATE=DISCONNECTED
[ 14.225383] init: Received control message 'stop' for 'adbd' from pid: 2984 (/vendor/bin/hw/[email protected])
[ 14.225728] acc_open
[ 14.225738] acc_release
[ 14.246039] init: Sending signal 9 to service 'adbd' (pid 3035) process group...
[ 14.254024] type=1400 audit(1572329404.091:582): avc: denied { dac_read_search } for pid=2996 comm="Binder:2996_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 14.276477] type=1400 audit(1572329405.131:2353): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
[ 14.299168] audit: audit_lost=2292 audit_rate_limit=5 audit_backlog_limit=64
[ 14.306504] audit: rate limit exceeded
[ 14.331852] libprocessgroup: Successfully killed process cgroup uid 0 pid 3035 in 78ms
[ 14.341574] init: Service 'adbd' (pid 3035) received signal 9
[ 14.348376] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:14)
[ 14.357548] selinux: avc: denied { set } for property=sys.usb.ffs.ready pid=2984 uid=0 gid=0 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=property_service permissive=0
[ 14.357548]
[ 14.377011] init: Unable to set property 'sys.usb.ffs.ready' to '0' from uid:0 gid:0 pid:2984: SELinux permission check failed
[ 14.389674] fec 30be0000.ethernet eth0: Unable to connect to phy
[ 14.510830] read descriptors
[ 14.514337] read strings
[ 14.624777] sdcardfs version 2.0
[ 14.633160] sdcardfs: dev_name -> /data/media
[ 14.639034] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
[ 14.656958] sdcardfs: mnt -> ffff80005fa758a0
[ 14.662964] sdcardfs: mounted on top of /data/media type ext4
[ 14.672618] Remount options were mask=23,gid=9997 for vfsmnt ffff80005291caa0.
[ 14.679909] sdcardfs : options - debug:1
[ 14.684579] sdcardfs : options - gid:9997
[ 14.688793] sdcardfs : options - mask:23
[ 14.693064] Remount options were mask=7,gid=9997 for vfsmnt ffff80005291d6e0.
[ 14.700523] sdcardfs : options - debug:1
[ 14.704507] sdcardfs : options - gid:9997
[ 14.708573] sdcardfs : options - mask:7
[ 15.346983] type=1400 audit(1572329405.175:2357): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 15.369072] type=1400 audit(1572329406.223:2417): avc: denied { dac_read_search } for pid=3475 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.462700] type=1400 audit(1572329406.223:2420): avc: denied { dac_read_search } for pid=3475 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 15.462738] audit: audit_lost=2351 audit_rate_limit=5 audit_backlog_limit=64
[ 15.483387] type=1400 audit(1572329406.339:2421): avc: denied { dac_read_search } for pid=3500 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 15.491969] audit: rate limit exceeded
[ 15.614241] android_work: did not send uevent (0 0 (null))
[ 15.667587] android_work: sent uevent USB_STATE=CONNECTED
[ 15.694902] configfs-gadget gadget: high-speed config #1: b
[ 15.720292] android_work: sent uevent USB_STATE=CONFIGURED
[ 17.766249] init: Service 'bootanim' (pid 3098) exited with status 0
[ 17.803120] init: processing action (sys.boot_completed=1) from (/init.rc:719)
[ 17.812016] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:20)
[ 17.830713] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.imx8mq.rc:27)
[ 17.842925] type=1400 audit(1572329406.339:2421): avc: denied { dac_read_search } for pid=3500 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 17.847029] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
[ 17.861798] type=1400 audit(1572329408.719:2430): avc: denied { dac_read_search } for pid=2884 comm="Binder:2884_3" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 17.872452] init: starting service 'exec 6 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[ 17.892745] type=1400 audit(1572329408.719:2430): avc: denied { dac_read_search } for pid=2884 comm="Binder:2884_3" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
[ 17.894226] audit: audit_lost=2359 audit_rate_limit=5 audit_backlog_limit=64
[ 17.894229] audit: rate limit exceeded
[ 17.907704] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 17.924128] type=1400 audit(1572329408.767:2431): avc: denied { dac_read_search } for pid=3636 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 17.987120] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 56ms and succeeded
[ 18.010074] selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
[ 18.010074]
[ 18.037222] init: Async property child exited with status 0
[ 19.217365] audit: audit_lost=3594 audit_rate_limit=5 audit_backlog_limit=64
[ 19.224769] audit: rate limit exceeded
[ 24.912063] type=1400 audit(1572329410.091:3674): avc: denied { dac_read_search } for pid=3763 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 24.929890] type=1400 audit(1572329415.787:3690): avc: denied { dac_read_search } for pid=3854 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
[ 25.007573] audit: audit_lost=3609 audit_rate_limit=5 audit_backlog_limit=64
[ 25.007615] type=1400 audit(1572329415.787:3693): avc: denied { dac_read_search } for pid=3854 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 25.014687] audit: rate limit exceeded
[ 25.038688] type=1400 audit(1572329415.883:3694): avc: denied { dac_read_search } for pid=3877 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
evk_8mq:/ $
evk_8mq:/ $ su
evk_8mq:/ #
evk_8mq:/ # logcat
--------- beginning of main
10-29 06:09:59.088 2872 2872 I SELinux : SELinux: Loaded service_contexts from:
10-29 06:09:59.092 2872 2872 I SELinux : /system/etc/selinux/plat_service_contexts
10-29 06:09:59.094 2874 2874 I SELinux : SELinux: Loaded service_contexts from:
10-29 06:09:59.095 2874 2874 I SELinux : /vendor/etc/selinux/vndservice_contexts
10-29 06:09:51.784 2871 2871 W auditd : type=2000 audit(0.0:1): state=initialized audit_enabled=0 res=1
10-29 06:09:56.983 2871 2871 I auditd : type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
10-29 06:09:56.995 2871 2871 W auditd : type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
10-29 06:09:57.251 1 1 W init : type=1400 audit(0.0:4): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:57.315 1 1 I chatty : uid=0(root) /init identical 4 lines
10-29 06:09:57.315 1 1 W init : type=1400 audit(0.0:9): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:57.315 1 1 W init : type=1400 audit(0.0:10): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:57.315 1 1 W init : type=1400 audit(0.0:11): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:59.119 2348 2348 W init : type=1400 audit(0.0:38): avc: denied { getattr } for path="/data/cache" dev="mmcblk0p12" ino=131095 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
10-29 06:09:59.123 1 1 W init : type=1400 audit(0.0:39): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:59.123 1 1 I chatty : uid=0(root) /init identical 6 lines
10-29 06:09:59.123 1 1 W init : type=1400 audit(0.0:46): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:09:59.161 2873 2873 I hwservicemanager: hwservicemanager is ready now.
10-29 06:09:59.258 2882 2882 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.259 2882 2882 I [email protected]: Registration complete for [email protected]::IBootControl/default.
10-29 06:09:59.273 2883 2883 I [email protected]: Fetching keymaster device name default
10-29 06:09:59.274 2883 2883 I [email protected]: Could not find any keystore module, using software-only implementation.
10-29 06:09:59.274 2883 2883 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.275 2883 2883 I [email protected]: Registration complete for [email protected]::IKeymasterDevice/default.
--------- beginning of system
10-29 06:09:59.283 2884 2884 I vold : Vold 3.0 (the awakening) firing up
10-29 06:09:59.284 2884 2884 V vold : Detected support for: ext4 vfat
10-29 06:09:59.287 2884 2884 V vold : Found unmanaged dm device named vroot
10-29 06:09:59.288 2884 2884 V vold : Found unmanaged dm device named vendor
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop3: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop0: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop4: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop1: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop2: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop5: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop7: No such device or address
10-29 06:09:59.288 2884 2884 W vold : Failed to LOOP_GET_STATUS64 /dev/block/loop6: No such device or address
10-29 06:09:59.291 2884 2884 D vold : VoldNativeService::start() completed OK
10-29 06:09:59.300 2884 2890 I vold : e4crypt_initialize_global_de
10-29 06:09:59.301 2884 2890 D vold : Key exists, using: /data/unencrypted/key
10-29 06:09:59.305 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:09:59.307 2884 2890 I vold : List of Keymaster HALs found:
10-29 06:09:59.307 2884 2890 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:09:59.308 2884 2890 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:09:59.313 2884 2890 D vold : Added key 258883223 (ext4:4ef46da64e7b8474) to keyring 1040619598 in process 2884
10-29 06:09:59.313 2884 2890 D vold : Added key 230590574 (f2fs:4ef46da64e7b8474) to keyring 1040619598 in process 2884
10-29 06:09:59.313 2884 2890 D vold : Added key 45894818 (fscrypt:4ef46da64e7b8474) to keyring 1040619598 in process 2884
10-29 06:09:59.314 2884 2890 I vold : Wrote system DE key reference to:/data/unencrypted/ref
10-29 06:09:59.416 2884 2890 D vold : e4crypt_init_user0
10-29 06:09:59.416 2884 2890 D vold : Preparing: /data/misc/vold/user_keys
10-29 06:09:59.417 2884 2890 D vold : Preparing: /data/misc/vold/user_keys/ce
10-29 06:09:59.417 2884 2890 D vold : Preparing: /data/misc/vold/user_keys/de
10-29 06:09:59.421 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:09:59.422 2884 2890 I vold : List of Keymaster HALs found:
10-29 06:09:59.423 2884 2890 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:09:59.423 2884 2890 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:09:59.424 2884 2890 D vold : Added key 5104692 (ext4:5b8c9e017e946cff) to keyring 1040619598 in process 2884
10-29 06:09:59.424 2884 2890 D vold : Added key 847293600 (f2fs:5b8c9e017e946cff) to keyring 1040619598 in process 2884
10-29 06:09:59.424 2884 2890 D vold : Added key 610809171 (fscrypt:5b8c9e017e946cff) to keyring 1040619598 in process 2884
10-29 06:09:59.424 2884 2890 D vold : Installed de key for user 0
10-29 06:09:59.424 2884 2890 D vold : Skipping non-de-key .
10-29 06:09:59.424 2884 2890 D vold : Skipping non-de-key ..
10-29 06:09:59.424 2884 2890 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
10-29 06:09:59.424 2884 2890 D vold : Preparing: /data/system/users/0
10-29 06:09:59.424 2884 2890 D vold : Preparing: /data/misc/profiles/cur/0
10-29 06:09:59.425 2884 2890 D vold : Preparing: /data/system_de/0
10-29 06:09:59.425 2884 2890 D vold : Preparing: /data/misc_de/0
10-29 06:09:59.425 2884 2890 D vold : Preparing: /data/vendor_de/0
10-29 06:09:59.425 2884 2890 D vold : Preparing: /data/user_de/0
10-29 06:09:59.426 2884 2890 I vold : Found policy 5b8c9e017e946cff at /data/system_de/0 which matches expected value
10-29 06:09:59.427 2884 2890 I vold : Found policy 5b8c9e017e946cff at /data/misc_de/0 which matches expected value
10-29 06:09:59.427 2884 2890 I vold : Found policy 5b8c9e017e946cff at /data/vendor_de/0 which matches expected value
10-29 06:09:59.428 2884 2890 I vold : Found policy 5b8c9e017e946cff at /data/user_de/0 which matches expected value
10-29 06:09:59.428 2884 2890 V vold : /system/bin/vold_prepare_subdirs
10-29 06:09:59.428 2884 2890 V vold : prepare
10-29 06:09:59.428 2884 2890 V vold : 0
10-29 06:09:59.428 2884 2890 V vold : 1
10-29 06:09:59.453 2884 2890 I vold_prepare_subdirs: SELinux: Loaded file_contexts
10-29 06:09:59.455 2950 2950 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
10-29 06:09:59.455 2950 2950 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
10-29 06:09:59.457 2950 2950 D vold_prepare_subdirs: Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
10-29 06:09:59.476 2951 2951 I /system/bin/tzdatacheck: timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
10-29 06:09:59.682 2954 2954 I Netd : Netd 1.0 starting
10-29 06:09:59.685 2954 2954 D TetherController: Setting IP forward enable = 0
10-29 06:09:59.738 2964 2964 I [email protected]/: [email protected]/backup: Hal starting main loop...
10-29 06:09:59.738 2964 2964 I [email protected]/: [email protected]/backup Hal is starting up...
10-29 06:09:59.749 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IHealth/default in either framework or device manifest.
10-29 06:09:59.750 2954 2954 I Netd : Creating child chains: 57.3ms
10-29 06:09:59.751 2954 2954 I Netd : Setting up OEM hooks: 0.2ms
10-29 06:09:59.751 2954 2954 I Netd : Setting up FirewallController hooks: 0.0ms
10-29 06:09:59.753 2963 2963 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.753 2954 2954 I Netd : Setting up TetherController hooks: 2.5ms
10-29 06:09:59.756 2954 2954 I Netd : Setting up BandwidthController hooks: 2.6ms
10-29 06:09:59.756 2954 2954 I Netd : Setting up IdletimerController hooks: 0.1ms
10-29 06:09:59.762 2964 2964 I [email protected]/: [email protected]/backup: Hal init done
10-29 06:09:59.780 2966 2966 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.786 2966 2966 I [email protected]: Registration complete for [email protected]::IBluetoothHci/default.
10-29 06:09:59.850 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: allowing syscall: connect
10-29 06:09:59.851 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: allowing syscall: fcntl
10-29 06:09:59.851 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: allowing syscall: sendto
10-29 06:09:59.851 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: allowing syscall: socket
10-29 06:09:59.851 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: allowing syscall: writev
10-29 06:09:59.858 2972 2972 W /vendor/bin/hw/[email protected]: libminijail[2972]: logging seccomp filter failures
10-29 06:09:59.859 2972 2972 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.922 2974 2974 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.924 2974 2974 I [email protected]: Registration complete for [email protected]::IGatekeeper/default.
10-29 06:09:59.953 2954 2954 I Netd : initializing traffic control: 196.9ms
10-29 06:09:59.955 2978 2978 E lights : cannot open backlight file /sys/class/backlight/30a00000.mipi_dsi_bridge.0/max_brightness
10-29 06:09:59.956 2978 2978 E light : light_open lights backlight failed: -22
10-29 06:09:59.956 2978 2978 E light : Light passthrough failed to load legacy HAL.
10-29 06:09:59.956 2978 2978 E light : light_open lights keyboard failed: -22
10-29 06:09:59.956 2978 2978 E light : light_open lights buttons failed: -22
10-29 06:09:59.956 2978 2978 E light : light_open lights battery failed: -22
10-29 06:09:59.957 2978 2978 E light : light_open lights notifications failed: -22
10-29 06:09:59.957 2978 2978 E light : Light passthrough failed to load legacy HAL.
10-29 06:09:59.957 2978 2978 E light : light_open lights attention failed: -22
10-29 06:09:59.957 2978 2978 E light : light_open lights bluetooth failed: -22
10-29 06:09:59.957 2978 2978 E light : light_open lights wifi failed: -22
10-29 06:09:59.957 2978 2978 I light : Could not open any lights.
10-29 06:09:59.958 2978 2978 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.959 2978 2978 I [email protected]: Registration complete for [email protected]::ILight/default.
10-29 06:09:59.960 2954 2954 I Netd : Disabling bandwidth control: 6.9ms
10-29 06:09:59.960 2982 2982 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:09:59.960 2954 2954 E Netd : cannot find interface dummy0
10-29 06:09:59.961 2954 2954 I Netd : Initializing RouteController: 1.5ms
10-29 06:09:59.961 2954 2954 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHSA
10-29 06:09:59.961 2954 2954 D XfrmController: Sending Netlink XFRM Message: XFRM_MSG_FLUSHPOLICY
10-29 06:09:59.961 2954 2954 I Netd : Initializing XfrmController: 0.4ms
10-29 06:09:59.962 2954 2954 E Netd : Unable to create netlink socket: Protocol not supported
10-29 06:09:59.962 2954 2954 W Netd : Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
10-29 06:09:59.963 2982 2982 I [email protected]: Registration complete for [email protected]::IPower/default.
10-29 06:09:59.963 2954 2954 D MDnsDS : MDnsSdListener::Hander starting up
10-29 06:09:59.965 2954 2954 I Netd : Registering NetdNativeService: 1.5ms
10-29 06:09:59.965 2954 2954 I Netd : Starting CommandListener: 0.2ms
10-29 06:09:59.970 2954 2954 I Netd : Registering NetdHwService: 5.4ms
10-29 06:09:59.970 2954 2954 I Netd : Netd started in 288ms
10-29 06:10:00.001 2977 2977 I [email protected]/: [email protected]/default: Hal starting main loop...
10-29 06:10:00.001 2977 2977 I [email protected]/: [email protected]/default Hal is starting up...
10-29 06:10:00.002 2977 2977 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.008 2954 3017 D MDnsDS : MDnsSdListener starting to monitor
10-29 06:10:00.008 2954 3017 D MDnsDS : Going to poll with pollCount 1
10-29 06:10:00.009 2977 2977 I [email protected]/: [email protected]/default: Hal init done
10-29 06:10:00.011 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IThermal/default in either framework or device manifest.
10-29 06:10:00.012 2987 2987 W thermalserviced: Unable to get Thermal HAL V1.1, vendor thermal event notification not available
10-29 06:10:00.031 3009 3009 I /system/bin/tombstoned: tombstoned successfully initialized
10-29 06:10:00.032 2979 2979 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.035 2979 2979 I [email protected]: Registration complete for [email protected]::IMemtrack/default.
10-29 06:10:00.040 2973 2973 D [email protected]: [email protected] starting...
10-29 06:10:00.046 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:10:00.061 2984 2984 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.064 2996 2996 I installd: installd firing up
10-29 06:10:00.064 2984 2984 I [email protected]: USB HAL Ready.
10-29 06:10:00.100 2971 2971 D [email protected]: [email protected] starting...
10-29 06:10:00.101 2971 2971 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.148 2975 2975 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.149 2975 2975 I [email protected]: Registration complete for [email protected]::IAllocator/default.
10-29 06:10:00.155 1 1 W init : type=1400 audit(0.0:535): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:00.155 1 1 I chatty : uid=0(root) /init identical 2 lines
10-29 06:10:00.155 1 1 W init : type=1400 audit(0.0:538): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:00.157 3011 3011 I usbd : Usb HAL found.
10-29 06:10:00.157 3011 3011 I usbd : peristent prop is adb
10-29 06:10:00.159 1 1 W init : type=1400 audit(0.0:539): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:00.160 2984 2984 I [email protected]: setCurrentUsbFunctions None
10-29 06:10:00.160 2984 2984 I [email protected]: Gadget cannot be pulled down
10-29 06:10:00.161 2968 2968 I [email protected]: Camera provider Service is starting.
10-29 06:10:00.175 2976 2976 I hwcomposer: hwc_device_open,1239
10-29 06:10:00.177 2976 2976 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.178 2976 2976 I [email protected]: Registration complete for [email protected]::IComposer/default.
10-29 06:10:00.185 2984 2984 W libc : Unable to set property "sys.usb.ffs.ready" to "0": error code: 0x18
10-29 06:10:00.186 2984 2984 I [email protected]: mMonitor not running
10-29 06:10:00.188 2973 2973 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.189 2973 2973 I [email protected]: Registration complete for [email protected]::IDrmFactory/default.
10-29 06:10:00.191 2973 2973 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.191 2973 2973 I [email protected]: Registration complete for [email protected]::ICryptoFactory/default.
10-29 06:10:00.243 2993 2993 I [email protected]: Wifi Hal is booting up...
10-29 06:10:00.243 2993 2993 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.250 3006 3006 I gatekeeperd: Starting gatekeeperd...
10-29 06:10:00.260 3002 3002 I wificond: wificond is starting up...
10-29 06:10:00.356 2989 2989 I mediaserver: ServiceManager: 0xe114eca3d480
10-29 06:10:00.359 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.362 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.362 3000 3000 W statsd : statscompanion service unavailable!
10-29 06:10:00.363 3000 3000 I statsd : using statsd socket
10-29 06:10:00.385 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.388 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:10:00.390 2997 2997 I keystore: found [email protected]::IKeymasterDevice with interface name default and seclevel SOFTWARE
10-29 06:10:00.390 2997 2997 W keystore: No secure Keymaster implementation found, but device offers insecure Keymaster HAL. Using as default.
10-29 06:10:00.405 3035 3038 I adbd : initializing functionfs
10-29 06:10:00.405 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.405 3035 3038 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
10-29 06:10:00.422 3035 3038 I adbd : functionfs successfully initialized
10-29 06:10:00.422 3035 3038 I adbd : registering usb transport
10-29 06:10:00.425 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.446 2984 2984 I chatty : uid=0(root) [email protected] identical 1 line
10-29 06:10:00.466 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.475 2968 2968 I FslCameraHAL: enumSensorSet
10-29 06:10:00.475 2968 2968 I FslCameraHAL: matchDevNodes
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeName: dev path:/dev/video1
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeName: node name:mx6s-csi
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video1 failed
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeNames: node name:mx6s-csi,i.MX6S_CSI
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeName: dev path:/dev/video0
10-29 06:10:00.475 2968 2968 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video0 failed
10-29 06:10:00.475 2968 2968 I FslCameraHAL: matchPropertyName: index:0, max9286_mipi
10-29 06:10:00.475 2968 2968 I FslCameraHAL: index:0, propName:max9286_mipi
10-29 06:10:00.475 2968 2968 I FslCameraHAL: matchNodeName
10-29 06:10:00.476 2968 2968 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:0
10-29 06:10:00.476 2968 2968 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:0
10-29 06:10:00.476 2968 2968 I FslCameraHAL: matchPropertyName: index:1, max9286_mipi
10-29 06:10:00.476 2968 2968 I FslCameraHAL: index:1, propName:max9286_mipi
10-29 06:10:00.476 2968 2968 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:1
10-29 06:10:00.476 2968 2968 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:1
10-29 06:10:00.476 2968 2968 I FslCameraHAL: camera number is 0
10-29 06:10:00.476 2968 2968 I [email protected]: Loaded "Default Camera HAL" camera module
10-29 06:10:00.486 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.490 2968 2968 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.491 2968 2968 I [email protected]: Registration complete for [email protected]::ICameraProvider/legacy/0.
10-29 06:10:00.507 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.608 2984 2984 I chatty : uid=0(root) [email protected] identical 5 lines
10-29 06:10:00.629 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.638 2965 2965 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:00.639 2965 2965 I audiohalservice: Registration complete for [email protected]::IDevicesFactory/default.
10-29 06:10:00.649 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.669 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.683 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
10-29 06:10:00.684 2986 2986 I SurfaceFlinger: Using HWComposer service: 'default'
10-29 06:10:00.684 2986 2986 I SurfaceFlinger: SurfaceFlinger is starting
10-29 06:10:00.685 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
10-29 06:10:00.685 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
10-29 06:10:00.686 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:00.687 2986 2986 I ConfigStore: android::hardware::configstore::V1_1::ISurfaceFlingerConfigs::primaryDisplayOrientation retrieved: ORIENTATION_0 (default)
10-29 06:10:00.688 2986 2986 I SurfaceFlinger: Disabling backpressure propagation
10-29 06:10:00.688 2986 2986 I SurfaceFlinger: Enabling HWC virtual displays
10-29 06:10:00.688 2986 2986 I SurfaceFlinger: Disabling Triple Buffering
10-29 06:10:00.688 2986 2986 I SurfaceFlinger: Treble testing override: 'false'
10-29 06:10:00.690 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.706 2986 2986 I SurfaceFlinger: SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
10-29 06:10:00.706 2986 2986 I SurfaceFlinger: Phase offest NS: 1000000
10-29 06:10:00.707 3010 3010 I update_engine: [1029/061000.707429:INFO:main.cc(182)] Chrome OS Update Engine starting
10-29 06:10:00.710 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.710 2955 2955 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
10-29 06:10:00.717 2965 2965 I audiohalservice: Registration complete for [email protected]::IEffectsFactory/default.
10-29 06:10:00.718 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:10:00.721 3010 3010 I update_engine: [1029/061000.720961:INFO:boot_control_android.cc(64)] Loaded boot control hidl hal.
10-29 06:10:00.721 3010 3010 I update_engine: [1029/061000.721155:INFO:daemon_state_android.cc(43)] Booted in dev mode.
10-29 06:10:00.723 2965 2965 E audiohalservice: Could not get passthrough implementation for [email protected]::ISoundTriggerHw/default.
10-29 06:10:00.724 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:10:00.724 2965 2965 E audiohalservice: Could not get passthrough implementation for [email protected]::ISoundTriggerHw/default.
10-29 06:10:00.724 2965 2965 W audiohalservice: Could not register soundtrigger API 2.0 nor 2.1
10-29 06:10:00.725 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IBluetoothAudioOffload/default in either framework or device manifest.
10-29 06:10:00.725 2965 2965 E audiohalservice: Could not get passthrough implementation for [email protected]::IBluetoothAudioOffload/default.
10-29 06:10:00.725 2965 2965 W audiohalservice: Could not register Bluetooth audio offload 1.0
10-29 06:10:00.730 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.751 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:00.753 2986 2986 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:10:00.765 2955 2955 I zygote64: option[0]=-Xzygote
10-29 06:10:00.765 2955 2955 I zygote64: option[1]=-Xusetombstonedtraces
10-29 06:10:00.765 2955 2955 I zygote64: option[2]=exit
10-29 06:10:00.765 2955 2955 I zygote64: option[3]=vfprintf
10-29 06:10:00.765 2955 2955 I zygote64: option[4]=sensitiveThread
10-29 06:10:00.765 2955 2955 I zygote64: option[5]=-verbose:gc
10-29 06:10:00.765 2955 2955 I zygote64: option[6]=-Xms16m
10-29 06:10:00.765 2955 2955 I zygote64: option[7]=-Xmx512m
10-29 06:10:00.765 2955 2955 I zygote64: option[8]=-XX:HeapGrowthLimit=192m
10-29 06:10:00.765 2955 2955 I zygote64: option[9]=-XX:HeapMinFree=512k
10-29 06:10:00.765 2955 2955 I zygote64: option[10]=-XX:HeapMaxFree=8m
10-29 06:10:00.765 2955 2955 I zygote64: option[11]=-XX:HeapTargetUtilization=0.75
10-29 06:10:00.765 2955 2955 I zygote64: option[12]=-Xusejit:true
10-29 06:10:00.765 2955 2955 I zygote64: option[13]=-Xjitsaveprofilinginfo
10-29 06:10:00.765 2955 2955 I zygote64: option[14]=-XjdwpOptions:suspend=n,server=y
10-29 06:10:00.766 2955 2955 I zygote64: option[15]=-XjdwpProvider:default
10-29 06:10:00.766 2955 2955 I zygote64: option[16]=-Xlockprofthreshold:500
10-29 06:10:00.766 2955 2955 I zygote64: option[17]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[18]=--runtime-arg
10-29 06:10:00.766 2955 2955 I zygote64: option[19]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[20]=-Xms64m
10-29 06:10:00.766 2955 2955 I zygote64: option[21]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[22]=--runtime-arg
10-29 06:10:00.766 2955 2955 I zygote64: option[23]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[24]=-Xmx64m
10-29 06:10:00.766 2955 2955 I zygote64: option[25]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[26]=--profile-file=/system/etc/boot-image.prof
10-29 06:10:00.766 2955 2955 I zygote64: option[27]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[28]=--compiler-filter=speed-profile
10-29 06:10:00.766 2955 2955 I zygote64: option[29]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[30]=--runtime-arg
10-29 06:10:00.766 2955 2955 I zygote64: option[31]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[32]=-Xms64m
10-29 06:10:00.766 2955 2955 I zygote64: option[33]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[34]=--runtime-arg
10-29 06:10:00.766 2955 2955 I zygote64: option[35]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[36]=-Xmx512m
10-29 06:10:00.766 2955 2955 I zygote64: option[37]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[38]=--instruction-set-variant=cortex-a53
10-29 06:10:00.766 2955 2955 I zygote64: option[39]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[40]=--instruction-set-variant=cortex-a53
10-29 06:10:00.766 2955 2955 I zygote64: option[41]=-Ximage-compiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[42]=--instruction-set-features=default
10-29 06:10:00.766 2955 2955 I zygote64: option[43]=-Xcompiler-option
10-29 06:10:00.766 2955 2955 I zygote64: option[44]=--instruction-set-features=default
10-29 06:10:00.766 2955 2955 I zygote64: option[45]=-Duser.locale=en-US
10-29 06:10:00.766 2955 2955 I zygote64: option[46]=--cpu-abilist=arm64-v8a
10-29 06:10:00.766 2955 2955 I zygote64: option[47]=-Xfingerprint:Android/evk_8mq/evk_8mq:9/2.0.1-ga-rc1/neolix09171654:userdebug/dev-keys
10-29 06:10:00.771 2984 2984 I [email protected]: setCurrentUsbFunctions Adb
10-29 06:10:00.771 2984 2984 I [email protected]: Service started
10-29 06:10:00.771 2984 2984 I [email protected]: Usb Gadget setcurrent functions called successfully
10-29 06:10:00.786 2999 2999 I mediametrics: ServiceManager: 0xeb902b83d740
10-29 06:10:00.786 2999 2999 D MediaAnalyticsService: MediaAnalyticsService created
10-29 06:10:00.788 2955 2955 I zygote64: VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm64 --instruction-set=arm64 --verify
10-29 06:10:00.797 2986 2986 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:10:00.854 2956 2956 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
10-29 06:10:00.866 2956 2956 I zygote : option[0]=-Xzygote
10-29 06:10:00.866 2956 2956 I zygote : option[1]=-Xusetombstonedtraces
10-29 06:10:00.866 2956 2956 I zygote : option[2]=exit
10-29 06:10:00.866 2956 2956 I zygote : option[3]=vfprintf
10-29 06:10:00.866 2956 2956 I zygote : option[4]=sensitiveThread
10-29 06:10:00.866 2956 2956 I zygote : option[5]=-verbose:gc
10-29 06:10:00.866 2956 2956 I zygote : option[6]=-Xms16m
10-29 06:10:00.866 2956 2956 I zygote : option[7]=-Xmx512m
10-29 06:10:00.866 2956 2956 I zygote : option[8]=-XX:HeapGrowthLimit=192m
10-29 06:10:00.866 2956 2956 I zygote : option[9]=-XX:HeapMinFree=512k
10-29 06:10:00.866 2956 2956 I zygote : option[10]=-XX:HeapMaxFree=8m
10-29 06:10:00.866 2956 2956 I zygote : option[11]=-XX:HeapTargetUtilization=0.75
10-29 06:10:00.866 2956 2956 I zygote : option[12]=-Xusejit:true
10-29 06:10:00.866 2956 2956 I zygote : option[13]=-Xjitsaveprofilinginfo
10-29 06:10:00.866 2956 2956 I zygote : option[14]=-XjdwpOptions:suspend=n,server=y
10-29 06:10:00.866 2956 2956 I zygote : option[15]=-XjdwpProvider:default
10-29 06:10:00.866 2956 2956 I zygote : option[16]=-Xlockprofthreshold:500
10-29 06:10:00.866 2956 2956 I zygote : option[17]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[18]=--runtime-arg
10-29 06:10:00.866 2956 2956 I zygote : option[19]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[20]=-Xms64m
10-29 06:10:00.866 2956 2956 I zygote : option[21]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[22]=--runtime-arg
10-29 06:10:00.866 2956 2956 I zygote : option[23]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[24]=-Xmx64m
10-29 06:10:00.866 2956 2956 I zygote : option[25]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[26]=--profile-file=/system/etc/boot-image.prof
10-29 06:10:00.866 2956 2956 I zygote : option[27]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[28]=--compiler-filter=speed-profile
10-29 06:10:00.866 2956 2956 I zygote : option[29]=-Xcompiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[30]=--runtime-arg
10-29 06:10:00.866 2956 2956 I zygote : option[31]=-Xcompiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[32]=-Xms64m
10-29 06:10:00.866 2956 2956 I zygote : option[33]=-Xcompiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[34]=--runtime-arg
10-29 06:10:00.866 2956 2956 I zygote : option[35]=-Xcompiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[36]=-Xmx512m
10-29 06:10:00.866 2956 2956 I zygote : option[37]=-Ximage-compiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[38]=--instruction-set-variant=cortex-a9
10-29 06:10:00.866 2956 2956 I zygote : option[39]=-Xcompiler-option
10-29 06:10:00.866 2956 2956 I zygote : option[40]=--instruction-set-variant=cortex-a9
10-29 06:10:00.867 2956 2956 I zygote : option[41]=-Ximage-compiler-option
10-29 06:10:00.867 2956 2956 I zygote : option[42]=--instruction-set-features=default
10-29 06:10:00.867 2956 2956 I zygote : option[43]=-Xcompiler-option
10-29 06:10:00.867 2956 2956 I zygote : option[44]=--instruction-set-features=default
10-29 06:10:00.867 2956 2956 I zygote : option[45]=-Duser.locale=en-US
10-29 06:10:00.867 2956 2956 I zygote : option[46]=--cpu-abilist=armeabi-v7a,armeabi
10-29 06:10:00.867 2956 2956 I zygote : option[47]=-Xfingerprint:Android/evk_8mq/evk_8mq:9/2.0.1-ga-rc1/neolix09171654:userdebug/dev-keys
10-29 06:10:00.880 2986 2986 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:10:00.920 2956 2956 I zygote : VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm --instruction-set=arm --verify
10-29 06:10:00.969 2994 2994 I cameraserver: ServiceManager: 0xf351c100
10-29 06:10:00.969 2994 2994 I CameraService: CameraService started (pid=2994)
10-29 06:10:00.969 2994 2994 I CameraService: CameraService process starting
10-29 06:10:00.969 2994 2994 W BatteryNotifier: batterystats service unavailable!
10-29 06:10:00.972 2994 2994 I CameraProviderManager: Connecting to new camera provider: legacy/0, isRemote? 1
10-29 06:10:00.973 2994 2994 I CameraProviderManager: Camera provider legacy/0 ready with 0 camera devices
10-29 06:10:00.974 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ICameraProvider/external/0 in either framework or device manifest.
10-29 06:10:00.974 2994 2994 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds
10-29 06:10:00.974 2994 2994 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds CameraDevice str is legacy/0
10-29 06:10:00.974 2994 2994 I : Waiting for activity service
10-29 06:10:00.978 2994 3055 W CameraProviderManager: addProviderLocked: Camera provider HAL with name 'legacy/0' already registered
10-29 06:10:00.978 2994 3055 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds
10-29 06:10:00.978 2994 3055 E CameraProviderManager: In CameraProviderManager.cpp getAPI1CompatibleCameraDeviceIds CameraDevice str is legacy/0
10-29 06:10:00.991 3003 3003 I media.codec: mediacodecservice starting
10-29 06:10:01.009 3003 3003 W media.codec: libminijail[3003]: failed to get path of fd 4: No such file or directory
10-29 06:10:01.009 3003 3003 W media.codec: libminijail[3003]: allowing syscall: clock_gettime
10-29 06:10:01.010 3003 3003 W media.codec: libminijail[3003]: allowing syscall: connect
10-29 06:10:01.010 3003 3003 W media.codec: libminijail[3003]: allowing syscall: fcntl64
10-29 06:10:01.010 3003 3003 W media.codec: libminijail[3003]: allowing syscall: socket
10-29 06:10:01.010 3003 3003 W media.codec: libminijail[3003]: allowing syscall: writev
10-29 06:10:01.012 3003 3003 W media.codec: libminijail[3003]: compile_file: <fd>(60): nonexistent syscall 'select'
10-29 06:10:01.013 3003 3003 W media.codec: libminijail[3003]: logging seccomp filter failures
10-29 06:10:01.027 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:01.027 2986 2986 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:01.027 2986 2986 W SurfaceFlinger: no suitable EGLConfig found, trying a simpler query
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: EGL information:
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: vendor : Android
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: version : 1.4 Android META-EGL
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_EXT_surface_SMPTE2086_metadata EGL_EXT_surface_CTA861_3_metadata EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_EXT_buffer_age EGL_EXT_protected_content
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: Client API: OpenGL_ES
10-29 06:10:01.027 2986 2986 I SurfaceFlinger: EGLSurface: 8-8-8-8, config=0x15
10-29 06:10:01.040 2998 2998 V MediaUtils: physMem: 3008249856
10-29 06:10:01.040 2998 2998 V MediaUtils: requested limit: 601649960
10-29 06:10:01.040 2998 2998 V MediaUtils: actual limit: 3221225471
10-29 06:10:01.040 2998 2998 V MediaUtils: original limits: -1/-1
10-29 06:10:01.040 2998 2998 V MediaUtils: new limits: 3221225471/-1
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: failed to get path of fd 4: No such file or directory
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: allowing syscall: connect
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: allowing syscall: fcntl
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: allowing syscall: sendto
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: allowing syscall: socket
10-29 06:10:01.050 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: allowing syscall: writev
10-29 06:10:01.059 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: compile_file: <fd>(47): nonexistent syscall 'ftruncate64'
10-29 06:10:01.060 2998 2998 W /system/bin/mediaextractor: libminijail[2998]: logging seccomp filter failures
10-29 06:10:01.095 3003 3003 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
10-29 06:10:01.095 3003 3003 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
10-29 06:10:01.095 3003 3003 E MediaCodecsXmlParser: Cannot find the role for a decoder of type video/x-vnd.on2.vp6
10-29 06:10:01.097 3003 3003 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:01.147 2986 2986 I SurfaceFlinger: OpenGL ES informations:
10-29 06:10:01.147 2986 2986 I SurfaceFlinger: vendor : Vivante Corporation
10-29 06:10:01.147 2986 2986 I SurfaceFlinger: renderer : Vivante GC7000L
10-29 06:10:01.148 2986 2986 I SurfaceFlinger: version : OpenGL ES 3.1 V6.2.4.p4.190076
10-29 06:10:01.148 2986 2986 I SurfaceFlinger: extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_texture_storage_multisample_2d_array GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex GL_OES_texture_half_float GL_OES_texture_float GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness GL_KHR_robust_buffer_acces
10-29 06:10:01.148 2986 2986 I SurfaceFlinger: GL_MAX_TEXTURE_SIZE = 8192
10-29 06:10:01.148 2986 2986 I SurfaceFlinger: GL_MAX_VIEWPORT_DIMS = 8192
10-29 06:10:01.178 2990 2990 I mediaserver: ServiceManager: 0xeae1c1c0
10-29 06:10:01.179 2990 2990 W BatteryNotifier: batterystats service unavailable!
10-29 06:10:01.187 3003 3003 I OMXPlayer: LEVEL: 1 FUNCTION: Open LINE: 39
10-29 06:10:01.187 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_ac3
10-29 06:10:01.187 3003 3003 I OMXPlayer: LEVEL: 1 FUNCTION: ComponentRegister LINE: 75
10-29 06:10:01.187 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_ac3 fail.
10-29 06:10:01.187 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_ddp
10-29 06:10:01.187 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_ddp fail.
10-29 06:10:01.188 3003 3003 I OMXPlayer: LEVEL: 1 FUNCTION: Open LINE: 39
10-29 06:10:01.188 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_ms
10-29 06:10:01.188 3003 3003 I OMXPlayer: LEVEL: 1 FUNCTION: ComponentRegister LINE: 75
10-29 06:10:01.188 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_ms fail.
10-29 06:10:01.188 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_wmv9
10-29 06:10:01.188 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_wmv9 fail.
10-29 06:10:01.188 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_ra
10-29 06:10:01.188 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_ra fail.
10-29 06:10:01.188 3003 3003 I OMXPlayer: Can't open file: /vendor/etc/component_register_rv
10-29 06:10:01.188 3003 3003 I OMXPlayer: Open component register file /vendor/etc/component_register_rv fail.
10-29 06:10:01.200 3003 3003 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
10-29 06:10:01.200 3003 3003 W MediaCodecsXmlParser: parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
10-29 06:10:01.200 3003 3003 I ServiceManagement: Removing namespace from process name [email protected] to [email protected].
10-29 06:10:01.200 2976 2976 I display : HWC disabled!
10-29 06:10:01.200 2976 2976 I display : Opengl ES 3D composition enabled!
10-29 06:10:01.202 3003 3003 I media.codec: IOmx HAL service created.
10-29 06:10:01.245 2976 2976 I display : can't find /vendor/lib64/libg2d.so, 2D is invalid
10-29 06:10:01.246 2976 2976 I display : open gpu gralloc module!
10-29 06:10:01.251 2976 2976 I display : try dev:/dev/dri/card0
10-29 06:10:01.251 2976 2976 I libedid : Try to check fd 19 connector:47 edid info
10-29 06:10:01.288 2988 2988 I FastMixerState: sMaxFastTracks = 8
10-29 06:10:01.290 2988 2988 V MediaUtils: physMem: 3008249856
10-29 06:10:01.290 2988 2988 V MediaUtils: requested limit: 536870912
10-29 06:10:01.290 2988 2988 V MediaUtils: actual limit: 536870912
10-29 06:10:01.290 2988 2988 V MediaUtils: original limits: 4294967295/4294967295
10-29 06:10:01.290 2988 2988 V MediaUtils: new limits: 536870912/4294967295
10-29 06:10:01.291 2988 2988 I audioserver: ServiceManager: 0xf441c100
10-29 06:10:01.291 2988 2988 W BatteryNotifier: batterystats service unavailable!
10-29 06:10:01.292 2984 3051 I [email protected]: GADGET pulled up
10-29 06:10:01.296 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IDevicesFactory/msd in either framework or device manifest.
10-29 06:10:01.298 2988 2988 I AudioFlinger: Using default 3000 mSec as standby time.
10-29 06:10:01.302 2988 2988 E APM::Serializer: deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
10-29 06:10:01.314 2976 2976 I display : readConnection: id:1, connection:1, count_modes:8, count_encoders:1
10-29 06:10:01.314 2976 2976 I display : Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
10-29 06:10:01.314 2976 2976 I display : Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
10-29 06:10:01.345 2976 2976 I display : Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
10-29 06:10:01.345 2976 2976 I display : Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
10-29 06:10:01.346 2976 2976 E display : can't find property ID for 'dtrc_table_ofs'.
10-29 06:10:01.347 2976 2976 E display : can't find property ID for 'alpha'.
10-29 06:10:01.348 2976 2976 W display : xres = 1920 px
10-29 06:10:01.348 2976 2976 W display : yres = 1080 px
10-29 06:10:01.348 2976 2976 W display : format = 1
10-29 06:10:01.348 2976 2976 W display : xdpi = 61.73 ppi
10-29 06:10:01.348 2976 2976 W display : ydpi = 160.00 ppi
10-29 06:10:01.348 2976 2976 W display : fps = 60.00 Hz
10-29 06:10:01.348 2976 2976 W display : mode.width = 1920 px
10-29 06:10:01.348 2976 2976 W display : mode.height = 1080 px
10-29 06:10:01.348 2976 2976 I display : no need to alloc memory
10-29 06:10:01.348 2976 2976 I display : enumKmsDisplay set 1 as primary display
10-29 06:10:01.348 2976 2976 E display : failed to set DPMS mode:3
10-29 06:10:01.348 2976 2976 I display : try dev:/dev/dri/card1
10-29 06:10:01.348 2976 2976 E display : Failed to set atomic cap -1
10-29 06:10:01.350 2986 2986 E HWComposer: getSupportedPerFrameMetadata: getSupportedPerFrameMetadata failed for display 0: Unsupported (8)
10-29 06:10:01.359 2975 2975 I display : open gpu gralloc module!
10-29 06:10:01.362 2975 2975 E ion : ioctl c0044901 failed with code -1: Not a typewriter
10-29 06:10:01.364 2986 2986 I display : open gpu gralloc module!
10-29 06:10:01.365 2986 2986 E gralloc : gralloc1_device_open invalid name:fb0
10-29 06:10:01.365 2986 2986 I v_egl : FramebufferSurface: bufferCount=3
10-29 06:10:01.405 2965 3075 W audio_hw_primary: card 0, id wm8524audio, driver wm8524-audio, name wm8524-audio
10-29 06:10:01.419 2965 3075 W audio_hw_primary: out rate 48000
10-29 06:10:01.443 2965 3075 W audio_hw_primary: in rate 0, channels 0 format 0
10-29 06:10:01.443 2965 3075 W audio_hw_primary: card 1, id imxspdif, driver imx-spdif, name imx-spdif
10-29 06:10:01.443 2965 3075 W audio_hw_primary: out rate 44100
10-29 06:10:01.447 2965 3075 W audio_hw_primary: in rate 44100, channels 2 format 3
10-29 06:10:01.447 2965 3075 W audio_hw_primary: card 2, id imxhdmiarc, driver imx-hdmi-arc, name imx-hdmi-arc
10-29 06:10:01.447 2965 3075 W audio_hw_primary: unrecognized card found.
10-29 06:10:01.447 2965 3075 W audio_hw_primary: card 3, id imxaudiohdmi, driver imx-audio-hdmi, name imx-audio-hdmi
10-29 06:10:01.485 2965 3075 W audio_hw_primary: out rate 44100
10-29 06:10:01.560 2976 3083 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:10:01.600 2976 3083 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:10:01.623 2965 3075 W audio_hw_primary: in rate 0, channels 0 format 0
10-29 06:10:01.623 2965 3075 I audio_hw_primary: Total 3 cards match
10-29 06:10:01.623 2965 3075 I audio_hw_primary: card idx 0, name wm8524-audio
10-29 06:10:01.623 2965 3075 I audio_hw_primary: card idx 1, name imx-spdif
10-29 06:10:01.623 2965 3075 I audio_hw_primary: card idx 2, name imx-audio-hdmi
10-29 06:10:01.623 2965 3075 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
10-29 06:10:01.624 2965 2965 W DeviceHAL: Error from HAL Device in function set_master_volume: Function not implemented
10-29 06:10:01.624 2988 2988 I AudioFlinger: loadHwModule() Loaded primary audio interface, handle 10
10-29 06:10:01.624 2988 2988 I AudioFlinger: openOutput() this 0xf443e000, module 10 Device 0x2, SamplingRate 48000, Format 0x000001, Channels 0x3, flags 0x2
10-29 06:10:01.624 2965 2965 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(48000) channel_mask(0x3) format(0x1) devices(0x2) flags(0x2), address()
10-29 06:10:01.624 2965 2965 I audio_hw_primary: adev_open_output_stream: exit: output_type 1, output 0xe95d1000
10-29 06:10:01.625 2988 2988 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 960 frames
10-29 06:10:01.667 2988 2988 I BufferProvider: found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
10-29 06:10:01.668 2988 2988 I AudioFlinger: Using module 10 as the primary audio interface
10-29 06:10:01.668 2965 3091 I audio_hw_primary: adev_set_mode mode 0
10-29 06:10:01.669 2988 2988 W AudioFlinger: moveEffects() bad srcOutput 0
10-29 06:10:01.670 2988 3093 I AudioFlinger: AudioFlinger's thread 0xf3983f80 tid=3093 ready to run
10-29 06:10:01.670 2988 3093 W AudioFlinger: no wake lock to update, system not ready yet
10-29 06:10:01.670 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=2
10-29 06:10:01.671 2965 2965 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:01.671 2965 2965 W audio_hw_primary: In channels 2, rate 48000, devices 0x80000004
10-29 06:10:01.672 2965 2965 W audio_hw_primary: get_input_buffer_size size = 512, channel_count = 2
10-29 06:10:01.677 2988 3095 I AudioFlinger: AudioFlinger's thread 0xf3683440 tid=3095 ready to run
10-29 06:10:01.678 2988 3094 E FastThread: did not receive expected priority boost on time
10-29 06:10:01.697 2988 2988 I bt_a2dp_hw: adev_open: adev_open in A2dp_hw module
10-29 06:10:01.697 2988 2988 I AudioFlinger: loadHwModule() Loaded a2dp audio interface, handle 18
10-29 06:10:01.702 2988 2988 I AudioFlinger: loadHwModule() Loaded usb audio interface, handle 26
10-29 06:10:01.706 2965 2965 I r_submix: adev_open(name=audio_hw_if)
10-29 06:10:01.707 2965 2965 I r_submix: adev_init_check()
10-29 06:10:01.707 2965 2965 W DeviceHAL: Error from HAL Device in function set_master_mute: Function not implemented
10-29 06:10:01.707 2988 2988 I AudioFlinger: loadHwModule() Loaded r_submix audio interface, handle 34
10-29 06:10:01.707 2965 2965 D r_submix: adev_open_input_stream(addr=0)
10-29 06:10:01.708 2965 2965 D r_submix: submix_audio_device_create_pipe_l(addr=0, idx=9)
10-29 06:10:01.708 2965 2965 D r_submix: now using address 0 for route 9
10-29 06:10:01.711 2988 3096 I AudioFlinger: AudioFlinger's thread 0xf3683c00 tid=3096 ready to run
10-29 06:10:01.712 2988 2988 I : Waiting for activity service
10-29 06:10:01.713 2965 2965 D r_submix: adev_close_input_stream()
10-29 06:10:01.713 2965 2965 D r_submix: submix_audio_device_release_pipe_l(idx=9) addr=0
10-29 06:10:01.713 2965 2965 D r_submix: submix_audio_device_destroy_pipe_l(): pipe destroyed
10-29 06:10:01.719 1 1 W init : type=1400 audit(0.0:573): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:01.719 1 1 I chatty : uid=0(root) /init identical 2 lines
10-29 06:10:01.719 1 1 W init : type=1400 audit(0.0:576): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:01.719 2986 2986 D SurfaceFlinger: shader cache generated - 24 shaders in 339.243011 ms
10-29 06:10:01.721 2986 2986 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xf1b3e5658000
10-29 06:10:01.722 2986 2986 D SurfaceFlinger: Finished set power mode=2, type=0
10-29 06:10:01.952 2956 2956 I zygote : Explicit concurrent copying GC freed 178(9KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 77us total 8.033ms
10-29 06:10:01.955 2955 2955 D Zygote : begin preload
10-29 06:10:01.955 2955 2955 I Zygote : Installing ICU cache reference pinning...
10-29 06:10:01.955 2955 2955 I Zygote : Preloading ICU data...
10-29 06:10:01.961 2956 2956 I zygote : Explicit concurrent copying GC freed 5(32KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 57us total 8.021ms
10-29 06:10:01.961 2956 2956 D Zygote32Timing: PostZygoteInitGC took to complete: 17ms
10-29 06:10:01.961 2956 2956 D Zygote32Timing: ZygoteInit took to complete: 18ms
10-29 06:10:01.977 2956 2956 I Zygote : Accepting command socket connections
10-29 06:10:02.018 3001 3061 I ServiceManager: Waiting for service package_native...
10-29 06:10:02.020 2955 2955 D Zygote64Timing: BeginIcuCachePinning took to complete: 65ms
10-29 06:10:02.020 2955 2955 I Zygote : Preloading classes...
10-29 06:10:02.049 2955 2955 I Zygote : ...preloaded 0 classes in 28ms.
10-29 06:10:02.049 2955 2955 I zygote64: VMRuntime.preloadDexCaches starting
10-29 06:10:02.169 2955 2955 I zygote64: VMRuntime.preloadDexCaches strings total=339244 before=12303 after=12303
10-29 06:10:02.169 2955 2955 I zygote64: VMRuntime.preloadDexCaches types total=31355 before=7818 after=7820
10-29 06:10:02.169 2955 2955 I zygote64: VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
10-29 06:10:02.169 2955 2955 I zygote64: VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
10-29 06:10:02.169 2955 2955 I zygote64: VMRuntime.preloadDexCaches finished
10-29 06:10:02.169 2955 2955 D Zygote64Timing: PreloadClasses took to complete: 149ms
10-29 06:10:02.211 2955 3107 I zygote64: Thread[7,tid=3107,Native,Thread*=0xf26ba5a86800,peer=0x12cf3a58,"Thread-1"] recursive attempt to load library "/system/lib64/libmedia_jni.so"
10-29 06:10:02.211 2955 3107 D MtpDeviceJNI: register_android_mtp_MtpDevice
10-29 06:10:02.295 3098 3116 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:10:02.306 3098 3116 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:10:02.385 3098 3116 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:10:02.415 2955 2955 I Zygote : Preloading resources...
10-29 06:10:02.441 2955 2955 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
10-29 06:10:02.465 2955 2955 I Zygote : ...preloaded 64 resources in 51ms.
10-29 06:10:02.467 3098 3116 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:02.467 3098 3116 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:02.473 3098 3116 I display : open gpu gralloc module!
10-29 06:10:02.473 2955 2955 I Zygote : ...preloaded 41 resources in 7ms.
10-29 06:10:02.473 2955 2955 D Zygote64Timing: PreloadResources took to complete: 303ms
10-29 06:10:02.483 3098 3116 D BootAnimation: BootAnimationShownTiming start time: 11501ms
10-29 06:10:02.524 2955 2955 D libEGL : loaded /vendor/lib64/egl/libEGL_VIVANTE.so
10-29 06:10:02.533 2986 2986 I SurfaceFlinger: Enter boot animation
10-29 06:10:02.539 2955 2955 D libEGL : loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
10-29 06:10:02.542 2986 2986 W SurfaceFlinger: Unable to determine the display type for display 1
10-29 06:10:02.607 2955 2955 D libEGL : loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
10-29 06:10:02.666 2955 2955 I Zygote : Preloading shared libraries...
10-29 06:10:02.704 2955 2955 I Zygote : Uninstalled ICU cache reference pinning...
10-29 06:10:02.705 2955 2955 I Zygote : Installed AndroidKeyStoreProvider in 1ms.
10-29 06:10:02.718 2955 2955 I Zygote : Warmed up JCA providers in 13ms.
10-29 06:10:02.718 2955 2955 D Zygote : end preload
10-29 06:10:02.718 2955 2955 D Zygote64Timing: ZygotePreload took to complete: 764ms
10-29 06:10:02.761 2955 2955 I zygote64: Explicit concurrent copying GC freed 51240(5MB) AllocSpace objects, 165(3MB) LOS objects, 49% free, 2MB/4MB, paused 55us total 41.993ms
10-29 06:10:02.798 2955 2955 I zygote64: Explicit concurrent copying GC freed 2797(136KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 2MB/4MB, paused 33us total 30.784ms
10-29 06:10:02.799 2955 2955 D Zygote64Timing: PostZygoteInitGC took to complete: 80ms
10-29 06:10:02.799 2955 2955 D Zygote64Timing: ZygoteInit took to complete: 844ms
10-29 06:10:02.981 2976 3083 E display : threadLoop invalid uevent remove@/bus/pci/drivers/hif_pci
10-29 06:10:03.002 2976 3083 E display : threadLoop invalid uevent remove@/module/wlan
10-29 06:10:03.027 3001 3061 I ServiceManager: Waiting for service package_native...
10-29 06:10:03.048 2955 2955 I Zygote : System server process 3121 has been created
10-29 06:10:03.054 2955 2955 I Zygote : Accepting command socket connections
10-29 06:10:03.070 3121 3121 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
10-29 06:10:03.172 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:03.208 3121 3121 I chatty : uid=1000 system_server identical 2 lines
10-29 06:10:03.210 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:03.227 3121 3121 I SystemServer: InitBeforeStartServices
10-29 06:10:03.228 3121 3121 I SystemServer: Entered the Android system server!
10-29 06:10:03.482 3121 3121 E UsbAlsaJackDetectorJNI: Can't register UsbAlsaJackDetector native methods
10-29 06:10:03.498 3121 3121 D SystemServerTiming: InitBeforeStartServices took to complete: 270ms
10-29 06:10:03.498 3121 3121 I SystemServer: StartServices
10-29 06:10:03.498 3121 3121 I SystemServer: Reading configuration...
10-29 06:10:03.498 3121 3121 I SystemServer: ReadingSystemConfig
10-29 06:10:03.499 3121 3121 D SystemServerTiming: ReadingSystemConfig took to complete: 0ms
10-29 06:10:03.499 3121 3121 I SystemServer: StartInstaller
10-29 06:10:03.499 3121 3121 I SystemServiceManager: Starting com.android.server.pm.Installer
10-29 06:10:03.500 3121 3134 D SystemServerInitThreadPool: Started executing ReadingSystemConfig
10-29 06:10:03.501 2996 3026 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:10:03.501 3121 3121 D SystemServerTiming: StartInstaller took to complete: 2ms
10-29 06:10:03.501 3121 3121 I SystemServer: DeviceIdentifiersPolicyService
10-29 06:10:03.501 3121 3121 I SystemServiceManager: Starting com.android.server.os.DeviceIdentifiersPolicyService
10-29 06:10:03.502 3121 3121 D SystemServerTiming: DeviceIdentifiersPolicyService took to complete: 1ms
10-29 06:10:03.502 3121 3121 I SystemServer: StartActivityManager
10-29 06:10:03.503 3121 3121 I SystemServiceManager: Starting com.android.server.am.ActivityManagerService$Lifecycle
10-29 06:10:03.517 3121 3121 I ActivityManager: Memory class: 192
10-29 06:10:03.526 3121 3121 D BatteryStatsImpl: Reading daily items from /data/system/batterystats-daily.xml
10-29 06:10:03.533 3121 3140 E BluetoothAdapter: Bluetooth binder is null
10-29 06:10:03.535 3121 3140 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
10-29 06:10:03.536 3121 3140 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:10:03.541 3121 3140 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_active_time
10-29 06:10:03.541 3121 3140 W KernelCpuProcReader: File not exist: /proc/uid_cpupower/concurrent_policy_time
10-29 06:10:03.545 3121 3140 I PowerManagerService-JNI: Loaded power HAL 1.0 service
10-29 06:10:03.545 3121 3140 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:10:03.553 3121 3134 D SystemServerInitThreadPool: Finished executing ReadingSystemConfig
10-29 06:10:03.647 3121 3121 W AppOps : Unknown attribute in 'op' tag: n
10-29 06:10:03.654 3121 3121 I chatty : uid=1000 system_server identical 89 lines
10-29 06:10:03.654 3121 3121 W AppOps : Unknown attribute in 'op' tag: n
10-29 06:10:03.658 3121 3121 I IntentFirewall: Read new rules (A:0 B:0 S:0)
10-29 06:10:03.664 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1003/pid_3098: Device or resource busy
10-29 06:10:03.664 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1003: Permission denied
10-29 06:10:03.664 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1001/pid_3004: Device or resource busy
10-29 06:10:03.664 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1001: Permission denied
10-29 06:10:03.664 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1058/pid_3009: Device or resource busy
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1058: Permission denied
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1066/pid_3000: Device or resource busy
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1066: Permission denied
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1046/pid_3003: Device or resource busy
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1046: Permission denied
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1036/pid_2871: Device or resource busy
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1036: Permission denied
10-29 06:10:03.665 3121 3121 W libprocessgroup: Failed to remove /acct/uid_2000/pid_2992: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_2000: Permission denied
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1040/pid_2998: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1040: Permission denied
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1002/pid_2966: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1002: Permission denied
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1010/pid_2993: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1010/pid_3002: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1010: Permission denied
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1067/pid_2995: Device or resource busy
10-29 06:10:03.666 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1067: Permission denied
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2982: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2972: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2979: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2874: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2987: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2977: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2872: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2975: Device or resource busy
10-29 06:10:03.667 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_3006: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2963: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2978: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2883: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2873: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2986: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2976: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000/pid_2974: Device or resource busy
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1000: Permission denied
10-29 06:10:03.668 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1019/pid_2991: Device or resource busy
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1019: Permission denied
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1047/pid_2968: Device or resource busy
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1047/pid_2994: Device or resource busy
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1047: Permission denied
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1017/pid_2997: Device or resource busy
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1017: Permission denied
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2350: Device or resource busy
10-29 06:10:03.669 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_3001: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2884: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2882: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2985: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2862: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2955: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_3010: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2996: Device or resource busy
10-29 06:10:03.670 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_3007: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_3035: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2956: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2984: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2964: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0/pid_2954: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_0: Permission denied
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2990: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2999: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2989: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2973: Device or resource busy
10-29 06:10:03.671 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013/pid_2971: Device or resource busy
10-29 06:10:03.672 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1013: Permission denied
10-29 06:10:03.672 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1041/pid_2965: Device or resource busy
10-29 06:10:03.672 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1041/pid_2988: Device or resource busy
10-29 06:10:03.672 3121 3121 W libprocessgroup: Failed to remove /acct/uid_1041: Permission denied
10-29 06:10:03.673 3121 3121 D AppOps : AppOpsService published
10-29 06:10:03.674 3121 3121 D SystemServerTiming: StartActivityManager took to complete: 171ms
10-29 06:10:03.674 3121 3121 I SystemServer: StartPowerManager
10-29 06:10:03.674 3121 3121 I SystemServiceManager: Starting com.android.server.power.PowerManagerService
10-29 06:10:03.677 3121 3121 D SystemServerTiming: StartPowerManager took to complete: 3ms
10-29 06:10:03.677 3121 3121 I SystemServer: InitPowerManagement
10-29 06:10:03.678 3121 3121 D SystemServerTiming: InitPowerManagement took to complete: 1ms
10-29 06:10:03.678 3121 3121 I SystemServer: StartRecoverySystemService
10-29 06:10:03.678 3121 3121 I SystemServiceManager: Starting com.android.server.RecoverySystemService
10-29 06:10:03.679 3121 3121 D SystemServerTiming: StartRecoverySystemService took to complete: 1ms
10-29 06:10:03.680 3121 3121 V RescueParty: Disabled because of active USB connection
10-29 06:10:03.680 3121 3121 I SystemServer: StartLightsService
10-29 06:10:03.680 3121 3121 I SystemServiceManager: Starting com.android.server.lights.LightsService
10-29 06:10:03.680 3121 3121 D SystemServerTiming: StartLightsService took to complete: 1ms
10-29 06:10:03.680 3121 3121 I SystemServer: StartSidekickService
10-29 06:10:03.680 3121 3121 D SystemServerTiming: StartSidekickService took to complete: 0ms
10-29 06:10:03.681 3121 3121 I SystemServer: StartDisplayManager
10-29 06:10:03.681 3121 3121 I SystemServiceManager: Starting com.android.server.display.DisplayManagerService
10-29 06:10:03.684 3121 3121 D SystemServerTiming: StartDisplayManager took to complete: 3ms
10-29 06:10:03.684 3121 3121 I SystemServer: WaitForDisplay
10-29 06:10:03.684 3121 3121 I SystemServiceManager: Starting phase 100
10-29 06:10:03.698 3121 3144 I DisplayManagerService: Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 1920 x 1080, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1920, height=1080, fps=60.000004}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@21c1c928, density 213, 320.0 x 320.0 dpi, appVsyncOff 1000000, presDeadline 16666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
10-29 06:10:03.698 2986 2986 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xf1b3e5658000
10-29 06:10:03.703 3121 3144 E LightsService: Light requested not available on this device. 0
10-29 06:10:03.703 3121 3121 D SystemServerTiming: WaitForDisplay took to complete: 19ms
10-29 06:10:03.703 3121 3144 I DisplayManagerService: Display device changed state: "Built-in Screen", ON
10-29 06:10:03.703 3121 3121 I SystemServer: StartPackageManagerService
10-29 06:10:03.721 3121 3121 D SELinuxMMAC: Using policy file /system/etc/selinux/plat_mac_permissions.xml
10-29 06:10:03.724 3121 3121 D SELinuxMMAC: Using policy file /vendor/etc/selinux/vendor_mac_permissions.xml
10-29 06:10:03.728 3121 3121 D FallbackCategoryProvider: Found 1 fallback categories
10-29 06:10:03.902 3121 3121 D PackageManager: No files in app dir /product/overlay
10-29 06:10:03.905 3121 3121 W PackageManager: Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
10-29 06:10:03.906 3121 3121 W PackageManager: Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
10-29 06:10:03.906 3121 3121 W PackageManager: Failed to parse /system/framework/arm64: Missing base APK in /system/framework/arm64
10-29 06:10:04.036 3001 3061 I ServiceManager: Waiting for service package_native...
10-29 06:10:04.046 3121 3121 D PackageManager: No files in app dir /vendor/priv-app
10-29 06:10:04.053 3121 3121 D PackageManager: No files in app dir /odm/priv-app
10-29 06:10:04.053 3121 3121 D PackageManager: No files in app dir /odm/app
10-29 06:10:04.053 3121 3121 D PackageManager: No files in app dir /oem/app
10-29 06:10:04.053 3121 3121 D PackageManager: No files in app dir /system/product/priv-app
10-29 06:10:04.053 3121 3121 D PackageManager: No files in app dir /system/product/app
10-29 06:10:04.054 3121 3121 I PackageManager: Finished scanning system apps. Time: 164 ms, packageCount: 88 , timePerPackage: 1 , cached: 88
10-29 06:10:04.058 3121 3121 D PackageManager: No files in app dir /data/app-private
10-29 06:10:04.058 3121 3121 I PackageManager: Finished scanning non-system apps. Time: 4 ms, packageCount: 1 , timePerPackage: 4 , cached: 1
10-29 06:10:04.060 3121 3121 I PackageManager: Time to scan packages: 0.171 seconds
10-29 06:10:04.067 2996 2996 W Binder:2996_1: type=1400 audit(0.0:577): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
10-29 06:10:04.068 3121 3121 V PackageManager: reconcileAppsData for null u0 0x1 migrateAppData=true
10-29 06:10:04.091 2996 2996 I chatty : uid=0(root) Binder:2996_2 identical 4 lines
10-29 06:10:04.091 2996 2996 W Binder:2996_1: type=1400 audit(0.0:582): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
10-29 06:10:04.093 2996 3026 I SELinux : SELinux: Loaded file_contexts
10-29 06:10:04.181 3121 3121 V PackageManager: reconcileAppsData finished 21 packages
10-29 06:10:04.182 3121 3171 D SystemServerInitThreadPool: Started executing prepareAppData
10-29 06:10:04.243 3121 3121 E PackageManager: There should probably be a verifier, but, none were found
10-29 06:10:04.246 3121 3121 D PackageManager: Ephemeral resolver NOT found; no matching intent filters
10-29 06:10:04.246 3121 3121 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
10-29 06:10:04.246 3121 3121 D PackageManager: Clear ephemeral installer activity
10-29 06:10:04.262 2996 3026 W installd: Ignoring /data/data/yOM1hV7cMp2jtOxL2xF6T4BsCUbKTugl/ky9km8KxYKq0phCi8Tz8ZC with unexpected GID 0 instead of 10066
10-29 06:10:04.276 2996 3026 W installd: Ignoring /data/data/lbnHpjS8ssVFvvDdN+4RY9VJL9D/q2zUWd4gU3zNozE1sYLfyC with unexpected GID 0 instead of 10042
10-29 06:10:04.325 3121 3121 I system_server: Explicit concurrent copying GC freed 48638(2MB) AllocSpace objects, 21(836KB) LOS objects, 42% free, 3MB/5MB, paused 60us total 73.110ms
10-29 06:10:04.326 3121 3121 D SystemServerTiming: StartPackageManagerService took to complete: 623ms
10-29 06:10:04.327 3121 3121 I SystemServer: StartOtaDexOptService
10-29 06:10:04.327 3121 3121 D OTADexopt: No upgrade, skipping A/B artifacts check.
10-29 06:10:04.327 3121 3121 D SystemServerTiming: StartOtaDexOptService took to complete: 1ms
10-29 06:10:04.328 3121 3121 I SystemServer: StartUserManagerService
10-29 06:10:04.328 3121 3121 I SystemServiceManager: Starting com.android.server.pm.UserManagerService$LifeCycle
10-29 06:10:04.328 3121 3121 D SystemServerTiming: StartUserManagerService took to complete: 0ms
10-29 06:10:04.328 3121 3121 I SystemServer: InitAttributerCache
10-29 06:10:04.328 3121 3121 D SystemServerTiming: InitAttributerCache took to complete: 0ms
10-29 06:10:04.328 3121 3121 I SystemServer: SetSystemProcess
10-29 06:10:04.332 2985 2985 I lowmemorykiller: lmkd data connection established
10-29 06:10:04.334 3121 3121 D SystemServerTiming: SetSystemProcess took to complete: 6ms
10-29 06:10:04.336 3121 3121 I SystemServer: StartOverlayManagerService
10-29 06:10:04.337 3121 3121 D SystemServerTiming: StartOverlayManagerService took to complete: 1ms
10-29 06:10:04.337 3121 3175 D SystemServerInitThreadPool: Started executing Init OverlayManagerService
10-29 06:10:04.337 3121 3121 I SystemServer: StartBatteryService
10-29 06:10:04.337 3121 3121 I SystemServiceManager: Starting com.android.server.BatteryService
10-29 06:10:04.338 3121 3176 D SystemServerInitThreadPool: Started executing StartSensorService
10-29 06:10:04.338 3121 3176 D SensorService: nuSensorService starting...
10-29 06:10:04.340 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISensors/default in either framework or device manifest.
10-29 06:10:04.347 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISoundTriggerHw/default in either framework or device manifest.
10-29 06:10:04.347 2988 2988 E SoundTriggerHwService: could not read implementation properties
10-29 06:10:04.349 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:10:04.350 3001 3061 I storaged: storaged: Start
10-29 06:10:04.350 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IHealth
10-29 06:10:04.350 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:10:04.350 3121 3176 D SystemServerTimingAsync: StartSensorService took to complete: 12ms
10-29 06:10:04.350 3121 3176 D SystemServerInitThreadPool: Finished executing StartSensorService
10-29 06:10:04.350 3001 3061 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:10:04.353 3121 3171 D SystemServerTimingAsync: AppDataFixup took to complete: 170ms
10-29 06:10:04.361 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:10:04.363 3121 3177 E LightsService: Light requested not available on this device. 3
10-29 06:10:04.363 3121 3140 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:10:04.364 3121 3140 I chatty : uid=1000(system) batterystats-wo identical 1 line
10-29 06:10:04.372 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:10:04.375 3121 3140 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:10:04.375 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:10:04.376 3121 3121 I HealthServiceWrapper: health: HealthServiceWrapper listening to instance default
10-29 06:10:04.377 3121 3121 I BatteryService: health: Waited 0ms and received the update.
10-29 06:10:04.378 3121 3121 D SystemServerTiming: StartBatteryService took to complete: 40ms
10-29 06:10:04.378 3121 3121 I SystemServer: StartUsageService
10-29 06:10:04.378 3121 3121 I SystemServiceManager: Starting com.android.server.usage.UsageStatsService
10-29 06:10:04.378 3121 3184 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IHealth
10-29 06:10:04.394 3121 3121 I UsageStatsService: User[0] Rollover scheduled @ 2019-10-30 03:53:29(1572407609595)
10-29 06:10:04.394 3121 3121 D SystemServerTiming: StartUsageService took to complete: 17ms
10-29 06:10:04.394 3121 3121 I SystemServer: StartWebViewUpdateService
10-29 06:10:04.394 3121 3121 I SystemServiceManager: Starting com.android.server.webkit.WebViewUpdateService
10-29 06:10:04.397 3121 3121 D SystemServerTiming: StartWebViewUpdateService took to complete: 2ms
10-29 06:10:04.397 3121 3121 I SystemServer: StartBinderCallsStatsService
10-29 06:10:04.397 3121 3121 D SystemServerTiming: StartBinderCallsStatsService took to complete: 0ms
10-29 06:10:04.398 3121 3121 I SystemServer: StartKeyAttestationApplicationIdProviderService
10-29 06:10:04.398 3121 3134 D SystemServerInitThreadPool: Started executing SecondaryZygotePreload
10-29 06:10:04.398 3121 3134 I SystemServer: SecondaryZygotePreload
10-29 06:10:04.398 3121 3121 D SystemServerTiming: StartKeyAttestationApplicationIdProviderService took to complete: 1ms
10-29 06:10:04.398 3121 3121 I SystemServer: StartKeyChainSystemService
10-29 06:10:04.398 3121 3121 I SystemServiceManager: Starting com.android.server.security.KeyChainSystemService
10-29 06:10:04.399 3121 3121 D SystemServerTiming: StartKeyChainSystemService took to complete: 0ms
10-29 06:10:04.399 3121 3121 I SystemServer: StartSchedulingPolicyService
10-29 06:10:04.399 3121 3176 D SystemServerInitThreadPool: Started executing SchedulingPolicyService.<init>
10-29 06:10:04.400 3121 3121 D SystemServerTiming: StartSchedulingPolicyService took to complete: 1ms
10-29 06:10:04.400 3121 3121 I SystemServer: StartTelecomLoaderService
10-29 06:10:04.400 3121 3121 I SystemServiceManager: Starting com.android.server.telecom.TelecomLoaderService
10-29 06:10:04.400 3121 3121 D SystemServerTiming: StartTelecomLoaderService took to complete: 0ms
10-29 06:10:04.400 3121 3121 I SystemServer: StartTelephonyRegistry
10-29 06:10:04.401 3121 3121 D SystemServerTiming: StartTelephonyRegistry took to complete: 1ms
10-29 06:10:04.401 3121 3121 I SystemServer: StartEntropyMixer
10-29 06:10:04.404 3121 3121 W EntropyMixer: Failed to add HW RNG output to entropy pool
10-29 06:10:04.404 3121 3121 W EntropyMixer: java.io.IOException: read failed: ENODEV (No such device)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at libcore.io.IoBridge.read(IoBridge.java:511)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at java.io.FileInputStream.read(FileInputStream.java:307)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.RandomBlock.fromStream(RandomBlock.java:56)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.RandomBlock.fromFile(RandomBlock.java:46)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.EntropyMixer.addHwRandomEntropy(EntropyMixer.java:205)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.EntropyMixer.<init>(EntropyMixer.java:115)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.EntropyMixer.<init>(EntropyMixer.java:97)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.SystemServer.startOtherServices(SystemServer.java:829)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.SystemServer.run(SystemServer.java:447)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.server.SystemServer.main(SystemServer.java:300)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at java.lang.reflect.Method.invoke(Native Method)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:893)
10-29 06:10:04.404 3121 3121 W EntropyMixer: Caused by: android.system.ErrnoException: read failed: ENODEV (No such device)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at libcore.io.Linux.readBytes(Native Method)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at libcore.io.Linux.read(Linux.java:184)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at libcore.io.BlockGuardOs.read(BlockGuardOs.java:254)
10-29 06:10:04.404 3121 3121 W EntropyMixer: at libcore.io.IoBridge.read(IoBridge.java:501)
10-29 06:10:04.404 3121 3121 W EntropyMixer: ... 12 more
10-29 06:10:04.404 3121 3176 I SchedulingPolicyService: Moving 3003 back to group default
10-29 06:10:04.404 3121 3121 I EntropyMixer: Writing entropy...
10-29 06:10:04.404 3121 3176 D SystemServerInitThreadPool: Finished executing SchedulingPolicyService.<init>
10-29 06:10:04.408 3121 3134 I Zygote : Process: zygote socket RESERVED/zygote opened, supported ABIS: arm64-v8a
10-29 06:10:04.417 3121 3121 D SystemServerTiming: StartEntropyMixer took to complete: 15ms
10-29 06:10:04.417 3121 3121 I SystemServer: StartAccountManagerService
10-29 06:10:04.417 3121 3121 I SystemServiceManager: Starting com.android.server.accounts.AccountManagerService$Lifecycle
10-29 06:10:04.420 3121 3121 D SystemServerTiming: StartAccountManagerService took to complete: 4ms
10-29 06:10:04.421 3121 3121 I SystemServer: StartContentService
10-29 06:10:04.421 3121 3121 I SystemServiceManager: Starting com.android.server.content.ContentService$Lifecycle
10-29 06:10:04.422 3121 3121 D SystemServerTiming: StartContentService took to complete: 1ms
10-29 06:10:04.422 3121 3121 I SystemServer: InstallSystemProviders
10-29 06:10:04.429 3121 3134 I Zygote : Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
10-29 06:10:04.436 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:04.440 2956 2956 I Zygote : Lazily preloading resources.
10-29 06:10:04.440 2956 2956 D Zygote : begin preload
10-29 06:10:04.440 2956 2956 I Zygote : Installing ICU cache reference pinning...
10-29 06:10:04.440 2956 2956 I Zygote : Preloading ICU data...
10-29 06:10:04.454 2956 2956 D ZygoteInitTiming_lazy: BeginIcuCachePinning took to complete: 13ms
10-29 06:10:04.454 2956 2956 I Zygote : Preloading classes...
10-29 06:10:04.468 3121 3121 I SettingsState: No settings state /data/system/users/0/settings_ssaid.xml
10-29 06:10:04.475 3121 3121 D SystemServerTiming: InstallSystemProviders took to complete: 53ms
10-29 06:10:04.475 3121 3121 I SystemServer: StartDropBoxManager
10-29 06:10:04.475 3121 3121 I SystemServiceManager: Starting com.android.server.DropBoxManagerService
10-29 06:10:04.476 3121 3121 D SystemServerTiming: StartDropBoxManager took to complete: 1ms
10-29 06:10:04.476 3121 3121 I SystemServer: StartVibratorService
10-29 06:10:04.477 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVibrator/default in either framework or device manifest.
10-29 06:10:04.477 3121 3121 E VibratorService: vibratorOff command failed (1).
10-29 06:10:04.478 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVibrator/default in either framework or device manifest.
10-29 06:10:04.479 3121 3121 D SystemServerTiming: StartVibratorService took to complete: 4ms
10-29 06:10:04.479 3121 3121 I SystemServer: StartConsumerIrService
10-29 06:10:04.480 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IConsumerIr/default in either framework or device manifest.
10-29 06:10:04.481 3121 3121 D SystemServerTiming: StartConsumerIrService took to complete: 1ms
10-29 06:10:04.481 3121 3121 I SystemServer: StartAlarmManagerService
10-29 06:10:04.481 3121 3121 I SystemServiceManager: Starting com.android.server.AlarmManagerService
10-29 06:10:04.482 3121 3121 D AlarmManagerService: Kernel timezone updated to 0 minutes west of GMT
10-29 06:10:04.485 3121 3121 D SystemServerTiming: StartAlarmManagerService took to complete: 4ms
10-29 06:10:04.485 3121 3121 I SystemServer: InitWatchdog
10-29 06:10:04.485 3121 3121 D SystemServerTiming: InitWatchdog took to complete: 0ms
10-29 06:10:04.485 3121 3121 I SystemServer: StartInputManagerService
10-29 06:10:04.486 3121 3121 I InputManager: Initializing input manager, mUseDevInputEventForAudioJack=false
10-29 06:10:04.486 3121 3121 D SystemServerTiming: StartInputManagerService took to complete: 1ms
10-29 06:10:04.487 3121 3121 I SystemServer: StartWindowManagerService
10-29 06:10:04.489 3121 3144 I WindowManager: No existing display settings /data/system/display_settings.xml; starting empty
10-29 06:10:04.499 3121 3121 D SystemServerTiming: StartWindowManagerService took to complete: 12ms
10-29 06:10:04.499 3121 3121 I SystemServer: SetWindowManagerService
10-29 06:10:04.525 3121 3121 D SystemServerTiming: SetWindowManagerService took to complete: 26ms
10-29 06:10:04.525 3121 3121 I SystemServer: WindowManagerServiceOnInitReady
10-29 06:10:04.538 3121 3121 D SystemServerTiming: WindowManagerServiceOnInitReady took to complete: 13ms
10-29 06:10:04.538 3121 3121 I SystemServer: StartVrManagerService
10-29 06:10:04.538 3121 3121 I SystemServiceManager: Starting com.android.server.vr.VrManagerService
10-29 06:10:04.539 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IVr/default in either framework or device manifest.
10-29 06:10:04.539 3121 3176 D SystemServerInitThreadPool: Started executing StartHidlServices
10-29 06:10:04.539 3121 3121 W VrManagerService: init_native: Could not open IVr interface
10-29 06:10:04.540 3121 3121 D SystemServerTiming: StartVrManagerService took to complete: 2ms
10-29 06:10:04.540 3121 3121 I SystemServer: StartInputManager
10-29 06:10:04.540 3121 3121 I InputManager: Starting input manager
10-29 06:10:04.542 3121 3121 D SystemServerTiming: StartInputManager took to complete: 2ms
10-29 06:10:04.542 3121 3121 I SystemServer: DisplayManagerWindowManagerAndInputReady
10-29 06:10:04.543 3121 3121 D SystemServerTiming: DisplayManagerWindowManagerAndInputReady took to complete: 1ms
10-29 06:10:04.543 3121 3121 I SystemServer: StartBluetoothService
10-29 06:10:04.543 3121 3121 I SystemServiceManager: Starting com.android.server.BluetoothService
10-29 06:10:04.544 3121 3176 D SystemServerTimingAsync: StartHidlServices took to complete: 5ms
10-29 06:10:04.544 3121 3176 D SystemServerInitThreadPool: Finished executing StartHidlServices
10-29 06:10:04.545 3121 3121 D BluetoothManagerService: Loading stored name and address
10-29 06:10:04.545 3121 3121 D BluetoothManagerService: Stored bluetooth Name=iMX8,Address=null
10-29 06:10:04.545 3121 3121 D BluetoothManagerService: Bluetooth persisted state: 0
10-29 06:10:04.545 3121 3121 D BluetoothManagerService: Detected SystemUiUid: 10031
10-29 06:10:04.546 3121 3121 D SystemServerTiming: StartBluetoothService took to complete: 2ms
10-29 06:10:04.546 3121 3121 I SystemServer: IpConnectivityMetrics
10-29 06:10:04.546 3121 3121 I SystemServiceManager: Starting com.android.server.connectivity.IpConnectivityMetrics
10-29 06:10:04.546 3121 3121 D SystemServerTiming: IpConnectivityMetrics took to complete: 0ms
10-29 06:10:04.546 3121 3121 I SystemServer: NetworkWatchlistService
10-29 06:10:04.546 3121 3121 I SystemServiceManager: Starting com.android.server.net.watchlist.NetworkWatchlistService$Lifecycle
10-29 06:10:04.547 3121 3191 D EventHub: No input device configuration file found for device '30370000.snvs:snvs-powerkey'.
10-29 06:10:04.550 3121 3121 I WatchlistSettings: Reload watchlist settings done
10-29 06:10:04.550 3121 3192 I WatchlistLoggingHandler: No need to aggregate record yet.
10-29 06:10:04.550 3121 3192 I WatchlistLoggingHandler: Milliseconds spent on tryAggregateRecords(): 0
10-29 06:10:04.551 3121 3121 D SystemServerTiming: NetworkWatchlistService took to complete: 4ms
10-29 06:10:04.551 3121 3121 I SystemServer: PinnerService
10-29 06:10:04.551 3121 3121 I SystemServiceManager: Starting com.android.server.PinnerService
10-29 06:10:04.554 3121 3121 D SystemServerTiming: PinnerService took to complete: 3ms
10-29 06:10:04.554 3121 3121 I SystemServer: StartInputMethodManagerLifecycle
10-29 06:10:04.554 3121 3121 I SystemServiceManager: Starting com.android.server.InputMethodManagerService$Lifecycle
10-29 06:10:04.554 3121 3191 W EventHub: Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
10-29 06:10:04.554 3121 3191 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
10-29 06:10:04.554 3121 3191 I EventHub: New device: id=1, fd=111, path='/dev/input/event0', name='30370000.snvs:snvs-powerkey', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false,
10-29 06:10:04.559 3121 3121 D SystemServerTiming: StartInputMethodManagerLifecycle took to complete: 5ms
10-29 06:10:04.559 3121 3121 I SystemServer: StartAccessibilityManagerService
10-29 06:10:04.562 3121 3121 D SystemServerTiming: StartAccessibilityManagerService took to complete: 3ms
10-29 06:10:04.562 3121 3121 I SystemServer: MakeDisplayReady
10-29 06:10:04.563 3121 3121 I ActivityManager: Config changes=20005df8 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2}
10-29 06:10:04.566 2956 2956 I Zygote : ...preloaded 0 classes in 113ms.
10-29 06:10:04.567 2956 2956 I zygote : VMRuntime.preloadDexCaches starting
10-29 06:10:04.571 3121 3121 I ActivityManager: Override config changes=60007dfc {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2} for displayId=0
10-29 06:10:04.586 3121 3121 I ActivityManager: Config changes=20000400 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3}
10-29 06:10:04.590 3121 3121 I ActivityManager: Override config changes=20000400 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3} for displayId=0
10-29 06:10:04.603 3121 3121 D SystemServerTiming: MakeDisplayReady took to complete: 40ms
10-29 06:10:04.603 3121 3121 I SystemServer: StartStorageManagerService
10-29 06:10:04.603 3121 3121 I SystemServiceManager: Starting com.android.server.StorageManagerService$Lifecycle
10-29 06:10:04.612 3121 3199 D StorageManagerService: Thinking about init, mSystemReady=false, mDaemonConnected=true
10-29 06:10:04.612 3121 3199 D StorageManagerService: Thinking about reset, mSystemReady=false, mDaemonConnected=true
10-29 06:10:04.612 3121 3121 D SystemServerTiming: StartStorageManagerService took to complete: 10ms
10-29 06:10:04.612 3121 3121 I SystemServer: StartStorageStatsService
10-29 06:10:04.612 3121 3121 I SystemServiceManager: Starting com.android.server.usage.StorageStatsService$Lifecycle
10-29 06:10:04.614 3121 3191 D EventHub: No input device configuration file found for device 'PixArt Lenovo Optical USB Mouse'.
10-29 06:10:04.614 3121 3191 I EventHub: wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
10-29 06:10:04.614 3121 3191 I EventHub: New device: id=2, fd=114, path='/dev/input/event1', name='PixArt Lenovo Optical USB Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false,
10-29 06:10:04.614 2996 3181 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:10:04.615 2996 3181 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:10:04.620 3121 3191 I InputReader: Device added: id=-1, name='Virtual', sources=0x00000301
10-29 06:10:04.622 3121 3121 D SystemServerTiming: StartStorageStatsService took to complete: 9ms
10-29 06:10:04.622 3121 3121 I SystemServer: StartUiModeManager
10-29 06:10:04.622 3121 3121 I SystemServiceManager: Starting com.android.server.UiModeManagerService
10-29 06:10:04.623 3121 3176 D SystemServerInitThreadPool: Started executing UiModeManager.onStart
10-29 06:10:04.624 3121 3176 I ActivityManager: Config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4}
10-29 06:10:04.630 3121 3191 I InputReader: Device added: id=2, name='PixArt Lenovo Optical USB Mouse', sources=0x00002002
10-29 06:10:04.630 3121 3191 I InputReader: Device added: id=1, name='30370000.snvs:snvs-powerkey', sources=0x00000101
10-29 06:10:04.631 3121 3121 D SystemServerTiming: StartUiModeManager took to complete: 9ms
10-29 06:10:04.631 3121 3121 I SystemServer: UpdatePackagesIfNeeded
10-29 06:10:04.631 3121 3121 D SystemServerTiming: UpdatePackagesIfNeeded took to complete: 0ms
10-29 06:10:04.631 3121 3121 I SystemServer: PerformFstrimIfNeeded
10-29 06:10:04.632 3121 3121 D SystemServerTiming: PerformFstrimIfNeeded took to complete: 0ms
10-29 06:10:04.632 3121 3121 I SystemServer: StartLockSettingsService
10-29 06:10:04.632 3121 3121 I SystemServiceManager: Starting com.android.server.locksettings.LockSettingsService$Lifecycle
10-29 06:10:04.633 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:10:04.634 3121 3176 I ActivityManager: Override config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4} for displayId=0
10-29 06:10:04.645 3121 3176 D SystemServerInitThreadPool: Finished executing UiModeManager.onStart
10-29 06:10:04.652 3121 3121 D SystemServerTiming: StartLockSettingsService took to complete: 20ms
10-29 06:10:04.652 3121 3121 I SystemServer: StartPersistentDataBlock
10-29 06:10:04.653 3121 3121 I SystemServiceManager: Starting com.android.server.PersistentDataBlockService
10-29 06:10:04.653 3121 3121 D SystemServerTiming: StartPersistentDataBlock took to complete: 0ms
10-29 06:10:04.653 3121 3176 D SystemServerInitThreadPool: Started executing PersistentDataBlockService.onStart
10-29 06:10:04.653 3121 3121 I SystemServer: StartOemLockService
10-29 06:10:04.653 3121 3121 I SystemServiceManager: Starting com.android.server.oemlock.OemLockService
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: not able to find package
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: android.content.pm.PackageManager$NameNotFoundException:
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:299)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:113)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.server.PersistentDataBlockService.lambda$onStart$0(PersistentDataBlockService.java:126)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.server.-$$Lambda$PersistentDataBlockService$EZl9OYaT2eNL7kfSr2nKUBjxidk.run(Unknown Source:2)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.server.SystemServerInitThreadPool.lambda$submit$0(SystemServerInitThreadPool.java:64)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.server.-$$Lambda$SystemServerInitThreadPool$7wfLGkZF7FvYZv7xj3ghvuiJJGk.run(Unknown Source:4)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:458)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at java.util.concurrent.FutureTask.run(FutureTask.java:266)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
10-29 06:10:04.654 3121 3176 E PersistentDataBlockService: at com.android.internal.util.ConcurrentUtils$1$1.run(ConcurrentUtils.java:62)
10-29 06:10:04.654 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IOemLock/default in either framework or device manifest.
10-29 06:10:04.655 3121 3121 I OemLock : OemLock HAL not present on device
10-29 06:10:04.655 3121 3121 I OemLock : Using persistent data block based lock
10-29 06:10:04.659 3121 3121 D SystemServerTiming: StartOemLockService took to complete: 6ms
10-29 06:10:04.659 3121 3121 I SystemServer: StartDeviceIdleController
10-29 06:10:04.659 3121 3121 I SystemServiceManager: Starting com.android.server.DeviceIdleController
10-29 06:10:04.666 3121 3121 D SystemServerTiming: StartDeviceIdleController took to complete: 7ms
10-29 06:10:04.666 3121 3121 I SystemServer: StartDevicePolicyManager
10-29 06:10:04.666 3121 3121 I SystemServiceManager: Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
10-29 06:10:04.675 3121 3121 D SystemServerTiming: StartDevicePolicyManager took to complete: 8ms
10-29 06:10:04.675 3121 3121 I SystemServer: StartStatusBarManagerService
10-29 06:10:04.678 3121 3121 D SystemServerTiming: StartStatusBarManagerService took to complete: 2ms
10-29 06:10:04.678 3121 3121 I SystemServer: StartClipboardService
10-29 06:10:04.678 3121 3121 I SystemServiceManager: Starting com.android.server.clipboard.ClipboardService
10-29 06:10:04.680 3121 3121 D SystemServerTiming: StartClipboardService took to complete: 2ms
10-29 06:10:04.680 3121 3121 I SystemServer: StartNetworkManagementService
10-29 06:10:04.682 3121 3201 I NetworkManagement: onDaemonConnected()
10-29 06:10:04.686 3121 3176 D SystemServerInitThreadPool: Finished executing PersistentDataBlockService.onStart
10-29 06:10:04.693 3121 3121 D SystemServerTiming: StartNetworkManagementService took to complete: 14ms
10-29 06:10:04.694 3121 3121 I SystemServer: StartIpSecService
10-29 06:10:04.695 3121 3121 D SystemServerTiming: StartIpSecService took to complete: 1ms
10-29 06:10:04.695 3121 3121 I SystemServer: StartTextServicesManager
10-29 06:10:04.695 3121 3121 I SystemServiceManager: Starting com.android.server.TextServicesManagerService$Lifecycle
10-29 06:10:04.697 3121 3121 D SystemServerTiming: StartTextServicesManager took to complete: 2ms
10-29 06:10:04.697 3121 3121 I SystemServer: StartTextClassificationManagerService
10-29 06:10:04.697 3121 3121 I SystemServiceManager: Starting com.android.server.textclassifier.TextClassificationManagerService$Lifecycle
10-29 06:10:04.698 3121 3121 D SystemServerTiming: StartTextClassificationManagerService took to complete: 1ms
10-29 06:10:04.698 3121 3121 I SystemServer: StartNetworkScoreService
10-29 06:10:04.698 3121 3121 I SystemServiceManager: Starting com.android.server.NetworkScoreService$Lifecycle
10-29 06:10:04.699 3121 3121 I NetworkScoreService: Registering network_score
10-29 06:10:04.700 3121 3121 D SystemServerTiming: StartNetworkScoreService took to complete: 2ms
10-29 06:10:04.700 3121 3121 I SystemServer: StartNetworkStatsService
10-29 06:10:04.715 3121 3121 D SystemServerTiming: StartNetworkStatsService took to complete: 14ms
10-29 06:10:04.715 3121 3121 I SystemServer: StartNetworkPolicyManagerService
10-29 06:10:04.728 3121 3121 D SystemServerTiming: StartNetworkPolicyManagerService took to complete: 13ms
10-29 06:10:04.728 3121 3121 I SystemServer: StartWifi
10-29 06:10:04.731 3121 3121 I SystemServiceManager: Starting com.android.server.wifi.WifiService
10-29 06:10:04.772 2956 3193 I zygote : Thread[7,tid=3193,Native,Thread*=0xe714b000,peer=0x12d708d0,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
10-29 06:10:04.772 2956 3193 D MtpDeviceJNI: register_android_mtp_MtpDevice
10-29 06:10:04.774 2956 3193 I zygote : Thread[7,tid=3193,Native,Thread*=0xe714b000,peer=0x12d708d0,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
10-29 06:10:04.781 2956 2956 I zygote : VMRuntime.preloadDexCaches strings total=339244 before=12303 after=12303
10-29 06:10:04.781 2956 2956 I zygote : VMRuntime.preloadDexCaches types total=31355 before=7818 after=7821
10-29 06:10:04.781 2956 2956 I zygote : VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
10-29 06:10:04.781 2956 2956 I zygote : VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
10-29 06:10:04.781 2956 2956 I zygote : VMRuntime.preloadDexCaches finished
10-29 06:10:04.781 2956 2956 D ZygoteInitTiming_lazy: PreloadClasses took to complete: 327ms
10-29 06:10:04.790 3121 3175 D SystemServerInitThreadPool: Finished executing Init OverlayManagerService
10-29 06:10:04.856 3121 3129 W System : A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
10-29 06:10:04.857 3121 3129 W System : java.lang.Throwable: Explicit termination method 'close' not called
10-29 06:10:04.857 3121 3129 W System : at dalvik.system.CloseGuard.open(CloseGuard.java:221)
10-29 06:10:04.857 3121 3129 W System : at java.io.FileInputStream.<init>(FileInputStream.java:168)
10-29 06:10:04.857 3121 3129 W System : at com.android.internal.os.AtomicFile.openRead(AtomicFile.java:147)
10-29 06:10:04.857 3121 3129 W System : at com.android.server.storage.CacheQuotaStrategy.setupQuotasFromFile(CacheQuotaStrategy.java:301)
10-29 06:10:04.857 3121 3129 W System : at com.android.server.usage.StorageStatsService$H.handleMessage(StorageStatsService.java:508)
10-29 06:10:04.857 3121 3129 W System : at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:10:04.857 3121 3129 W System : at android.os.Looper.loop(Looper.java:193)
10-29 06:10:04.857 3121 3129 W System : at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:10:04.857 3121 3129 W System : at com.android.server.ServiceThread.run(ServiceThread.java:44)
10-29 06:10:04.858 3121 3131 I system_server: Background concurrent copying GC freed 16393(1409KB) AllocSpace objects, 21(452KB) LOS objects, 42% free, 3MB/6MB, paused 102us total 200.441ms
10-29 06:10:04.865 2956 3102 I zygote : Background concurrent copying GC freed 27318(4MB) AllocSpace objects, 161(2MB) LOS objects, 50% free, 2MB/4MB, paused 6.776ms total 294.622ms
10-29 06:10:04.869 3121 3121 D WifiApConfigStore: 2G band allowed channels are:1,6,11
10-29 06:10:04.881 3121 3121 I WifiScoringParams: rssi2=-85:-85:-73:-60,rssi5=-82:-82:-70:-57,pps=0:1:100,horizon=15,nud=8,expid=0
10-29 06:10:04.928 3121 3121 D WifiStateMachine: EnableConnectedMacRandomization Setting changed to false
10-29 06:10:04.928 3121 3121 E WifiStateMachine: getWifiLinkLayerStats called without an interface
10-29 06:10:04.929 3121 3121 D WifiStateMachinePrime: Starting Wifi in WifiDisabledState
10-29 06:10:04.929 3121 3207 D WifiStat[ 65.625989] type=1400 audit(1572329415.883:3694): avc: denied { dac_read_search } for pid=3877 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
eMachinePrime: Entering WifiDisab[ 65.647344] type=1400 audit(1572329456.503:3726): avc: denied { dac_read_search } for pid=4045 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
ledState
10-29 06:10:04.929 3121 3207 D ActiveModeManager: sending scan available broadcast: false
10-29 06:10:04.930 3121 3121 D WifiOpenNetworkNotifier: Settings toggle enabled=true
10-29 06:10:04.931 3121 3121 D WifiCarrierNetworkNotifier: Settings toggle enabled=true
10-29 06:10:04.932 3121 3121 D WakeupController: WifiWake enabled
10-29 06:10:04.934 3121 3121 D WifiController: isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false, isLocationModeActive = true
10-29 06:10:04.937 3121 3121 E SupplicantStaIfaceHal: Can't call setDebugParams, ISupplicant is null
10-29 06:10:04.937 3121 3121 W WifiDiags: no ring buffers found
10-29 06:10:04.937 3121 3121 W WifiDiags: Failed to start packet fate monitoring
10-29 06:10:04.938 3121 3121 I WifiService: Registering wifi
10-29 06:10:04.939 3121 3121 D SystemServerTiming: StartWifi took to complete: 210ms
10-29 06:10:04.939 3121 3121 I SystemServer: StartWifiScanning
10-29 06:10:04.940 3121 3121 I SystemServiceManager: Starting com.android.server.wifi.scanner.WifiScanningService
10-29 06:10:04.940 3121 3121 I WifiScanningService: Creating wifiscanner
10-29 06:10:04.942 3121 3121 I WifiScanningService: Publishing wifiscanner
10-29 06:10:04.943 3121 3121 D SystemServerTiming: StartWifiScanning took to complete: 4ms
10-29 06:10:04.943 3121 3121 I SystemServer: StartWifiP2P
10-29 06:10:04.944 3121 3121 I SystemServiceManager: Starting com.android.server.wifi.p2p.WifiP2pService
10-29 06:10:04.951 3121 3171 D SystemServerTimingAsync: AppDataPrepare took to complete: 598ms
10-29 06:10:04.951 3121 3171 I PackageManager: Deferred reconcileAppsData finished 68 packages
10-29 06:10:04.951 3121 3171 D SystemServerInitThreadPool: Finished executing prepareAppData
10-29 06:10:04.957 3121 3121 W HalDevMgr: isWifiStarted called but mWifi is null!?
10-29 06:10:04.957 3121 3121 I WifiP2pService: Registering wifip2p
10-29 06:10:04.958 3121 3121 D SystemServerTiming: StartWifiP2P took to complete: 14ms
10-29 06:10:04.958 3121 3121 I SystemServer: StartEthernet
10-29 06:10:04.959 3121 3121 I SystemServiceManager: Starting com.android.server.ethernet.EthernetService
10-29 06:10:04.959 3121 3121 I EthernetService: Registering service ethernet
10-29 06:10:04.960 3121 3121 D SystemServerTiming: StartEthernet took to complete: 2ms
10-29 06:10:04.960 3121 3121 I SystemServer: StartConnectivityService
10-29 06:10:04.962 3121 3121 D ConnectivityService: ConnectivityService starting up
10-29 06:10:04.967 3121 3121 D ConnectivityService: wifiOnly=true
10-29 06:10:04.967 3121 3121 E ConnectivityService: Ignoring protectedNetwork 10
10-29 06:10:04.967 3121 3121 E ConnectivityService: Ignoring protectedNetwork 11
10-29 06:10:04.967 3121 3121 E ConnectivityService: Ignoring protectedNetwork 12
10-29 06:10:04.967 3121 3121 E ConnectivityService: Ignoring protectedNetwork 14
10-29 06:10:04.967 3121 3121 E ConnectivityService: Ignoring protectedNetwork 15
10-29 06:10:04.980 3121 3121 D SystemServerTiming: StartConnectivityService took to complete: 21ms
10-29 06:10:04.981 3121 3121 I SystemServer: StartNsdService
10-29 06:10:04.982 3121 3121 D NsdService: Network service discovery is enabled
10-29 06:10:04.984 3121 3121 D SystemServerTiming: StartNsdService took to complete: 3ms
10-29 06:10:04.984 3121 3121 I SystemServer: StartSystemUpdateManagerService
10-29 06:10:04.985 3121 3121 I SystemUpdateManagerService: No existing info file /data/system/system-update-info.xml
10-29 06:10:04.986 3121 3121 D SystemServerTiming: StartSystemUpdateManagerService took to complete: 1ms
10-29 06:10:04.986 3121 3121 I SystemServer: StartUpdateLockService
10-29 06:10:04.988 3121 3121 D SystemServerTiming: StartUpdateLockService took to complete: 1ms
10-29 06:10:04.988 3121 3121 I SystemServer: StartNotificationManager
10-29 06:10:04.988 3121 3121 I SystemServiceManager: Starting com.android.server.notification.NotificationManagerService
10-29 06:10:04.994 2956 2956 I Zygote : Preloading resources...
10-29 06:10:04.994 3121 3121 D ConditionProviders.SCP: new ScheduleConditionProvider()
10-29 06:10:05.006 3121 3121 I NotificationListeners: Read notification listener permissions from xml
10-29 06:10:05.006 3121 3121 I NotificationAssistants: Read notification assistant permissions from xml
10-29 06:10:05.006 3121 3121 I ConditionProviders: Read condition provider permissions from xml
10-29 06:10:05.007 3121 3121 I ConditionProviders: Read condition provider permissions from xml
10-29 06:10:05.007 2956 2956 W Resources: Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
10-29 06:10:05.014 3121 3121 D SystemServerTiming: StartNotificationManager took to complete: 26ms
10-29 06:10:05.014 3121 3121 I SystemServer: StartDeviceMonitor
10-29 06:10:05.014 3121 3121 I SystemServiceManager: Starting com.android.server.storage.DeviceStorageMonitorService
10-29 06:10:05.016 3121 3121 D SystemServerTiming: StartDeviceMonitor took to complete: 2ms
10-29 06:10:05.016 3121 3121 I SystemServer: StartLocationManagerService
10-29 06:10:05.017 3121 3121 D SystemServerTiming: StartLocationManagerService took to complete: 1ms
10-29 06:10:05.017 3121 3121 I SystemServer: StartCountryDetectorService
10-29 06:10:05.018 3121 3121 D SystemServerTiming: StartCountryDetectorService took to complete: 1ms
10-29 06:10:05.018 3121 3121 I SystemServer: StartSearchManagerService
10-29 06:10:05.018 3121 3121 I SystemServiceManager: Starting com.android.server.search.SearchManagerService$Lifecycle
10-29 06:10:05.020 3121 3121 D SystemServerTiming: StartSearchManagerService took to complete: 1ms
10-29 06:10:05.020 3121 3121 I SystemServer: StartWallpaperManagerService
10-29 06:10:05.020 3121 3121 I SystemServiceManager: Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
10-29 06:10:05.022 3121 3121 D SystemServerTiming: StartWallpaperManagerService took to complete: 2ms
10-29 06:10:05.022 3121 3121 I SystemServer: StartAudioService
10-29 06:10:05.022 3121 3121 I SystemServiceManager: Starting com.android.server.audio.AudioService$Lifecycle
10-29 06:10:05.026 3121 3121 W TelecomManager: Telecom Service not found.
10-29 06:10:05.028 2988 2988 D PermissionCache: checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (762 us)
10-29 06:10:05.028 2988 2988 D PermissionCache: checking android.permission.MODIFY_AUDIO_ROUTING for uid=1000 => granted (137 us)
10-29 06:10:05.029 2988 3093 W AudioFlinger: no wake lock to update, system not ready yet
10-29 06:10:05.030 2965 2965 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:10:05.030 2965 3091 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:10:05.035 2956 2956 I Zygote : ...preloaded 64 resources in 41ms.
10-29 06:10:05.042 2956 2956 I Zygote : ...preloaded 41 resources in 7ms.
10-29 06:10:05.042 2956 2956 D ZygoteInitTiming_lazy: PreloadResources took to complete: 253ms
10-29 06:10:05.055 2988 3088 D AudioFlinger: isLowRamDevice:false totalMemory:3008249856 mClientSharedHeapSize:8388608
10-29 06:10:05.057 3121 3121 D SystemServerTiming: StartAudioService took to complete: 34ms
10-29 06:10:05.057 3121 3121 I SystemServer: StartDockObserver
10-29 06:10:05.057 3121 3121 I SystemServiceManager: Starting com.android.server.DockObserver
10-29 06:10:05.058 3121 3121 W DockObserver: This kernel does not have dock station support
10-29 06:10:05.059 3121 3121 D SystemServerTiming: StartDockObserver took to complete: 2ms
10-29 06:10:05.059 3121 3121 I SystemServer: StartWiredAccessoryManager
10-29 06:10:05.060 3121 3121 W WiredAccessoryManager: This kernel does not have wired headset support
10-29 06:10:05.061 3121 3121 W WiredAccessoryManager: This kernel does not have usb audio support
10-29 06:10:05.061 3121 3121 W WiredAccessoryManager: This kernel does not have HDMI audio support
10-29 06:10:05.061 3121 3121 D SystemServerTiming: StartWiredAccessoryManager took to complete: 1ms
10-29 06:10:05.061 3121 3121 I SystemServer: StartUsbService
10-29 06:10:05.061 3121 3121 I SystemServiceManager: Starting com.android.server.usb.UsbService$Lifecycle
10-29 06:10:05.063 3121 3121 E UsbDeviceManager: failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
10-29 06:10:05.064 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:10:05.082 2956 2956 D libEGL : loaded /vendor/lib/egl/libEGL_VIVANTE.so
10-29 06:10:05.088 3121 3121 W StorageManagerService: No primary storage defined yet; hacking together a stub
10-29 06:10:05.089 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:10:05.091 3121 3177 I UsbDeviceManager: Usb gadget hal service started [email protected]::IUsbGadget default
10-29 06:10:05.092 3121 3177 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:10:05.093 3121 3177 I UsbDeviceManager: Setting USB config to
10-29 06:10:05.093 3121 3177 D UsbDeviceManager: setUsbConfig(1) request:1
10-29 06:10:05.103 2984 2984 I [email protected]: setCurrentUsbFunctions None
10-29 06:10:05.103 2976 3083 E display : threadLoop invalid uevent change@/devices/platform/usb@38100000/38100000.dwc3/udc/38100000.dwc3
10-29 06:10:05.104 3035 3041 E adbd : aio: got error event on read total bufs 1: Cannot send after transport endpoint shutdown
10-29 06:10:05.104 3035 3041 E adbd : remote usb: read terminated (message): Cannot send after transport endpoint shutdown
10-29 06:10:05.105 2976 3083 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:10:05.105 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsbGadget
10-29 06:10:05.109 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:10:05.110 3121 3177 I UsbPortManager: Usb hal service started [email protected]::IUsb default
10-29 06:10:05.112 3121 3177 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IUsb
10-29 06:10:05.114 2984 3029 I [email protected]: registering callback
10-29 06:10:05.114 2984 3228 E [email protected]: creating thread
10-29 06:10:05.115 2984 3029 I [email protected]: port0
10-29 06:10:05.115 3121 3121 W SystemServiceManager: Service com.android.server.usb.UsbService$Lifecycle took 53 ms in onStart
10-29 06:10:05.115 3121 3121 D SystemServerTiming: StartUsbService took to complete: 54ms
10-29 06:10:05.115 2984 3029 I [email protected]: connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
10-29 06:10:05.115 3121 3121 I SystemServer: StartSerialService
10-29 06:10:05.116 3121 3121 D SystemServerTiming: StartSerialService took to complete: 1ms
10-29 06:10:05.116 3121 3121 I SystemServer: StartHardwarePropertiesManagerService
10-29 06:10:05.117 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IThermal/default in either framework or device manifest.
10-29 06:10:05.117 3121 3121 E HardwarePropertiesManagerService-JNI: Unable to get Thermal service.
10-29 06:10:05.117 3121 3121 D SystemServerTiming: StartHardwarePropertiesManagerService took to complete: 1ms
10-29 06:10:05.117 3121 3121 I SystemServer: StartTwilightService
10-29 06:10:05.117 3121 3121 I SystemServiceManager: Starting com.android.server.twilight.TwilightService
10-29 06:10:05.118 3121 3121 D SystemServerTiming: StartTwilightService took to complete: 0ms
10-29 06:10:05.118 3121 3121 I SystemServer: StartJobScheduler
10-29 06:10:05.118 3121 3121 I SystemServiceManager: Starting com.android.server.job.JobSchedulerService
10-29 06:10:05.121 3121 3121 D JobStore: Start tag: job-info
10-29 06:10:05.123 3121 3121 I JobStore: Read 2 jobs
10-29 06:10:05.130 3121 3121 D SystemServerTiming: StartJobScheduler took to complete: 12ms
10-29 06:10:05.130 3121 3121 I SystemServer: StartSoundTrigger
10-29 06:10:05.130 3121 3121 I SystemServiceManager: Starting com.android.server.soundtrigger.SoundTriggerService
10-29 06:10:05.131 1 1 W init : type=1400 audit(0.0:2353): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:05.131 3121 3121 D SystemServerTiming: StartSoundTrigger took to complete: 1ms
10-29 06:10:05.131 3121 3121 I SystemServer: StartTrustManager
10-29 06:10:05.131 3121 3121 I SystemServiceManager: Starting com.android.server.trust.TrustManagerService
10-29 06:10:05.132 2956 2956 D libEGL : loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
10-29 06:10:05.132 3121 3121 D SystemServerTiming: StartTrustManager took to complete: 1ms
10-29 06:10:05.132 3121 3121 I SystemServer: StartBackupManager
10-29 06:10:05.132 3121 3121 I SystemServiceManager: Starting com.android.server.backup.BackupManagerService$Lifecycle
10-29 06:10:05.137 3121 3121 D SystemServerTiming: StartBackupManager took to complete: 4ms
10-29 06:10:05.137 3121 3121 I SystemServer: StartAppWidgerService
10-29 06:10:05.137 3121 3121 I SystemServiceManager: Starting com.android.server.appwidget.AppWidgetService
10-29 06:10:05.138 3121 3121 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:05.140 3121 3121 D SystemServerTiming: StartAppWidgerService took to complete: 3ms
10-29 06:10:05.140 3121 3121 I SystemServer: StartVoiceRecognitionManager
10-29 06:10:05.140 3121 3121 I SystemServiceManager: Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
10-29 06:10:05.141 3121 3121 D SystemServerTiming: StartVoiceRecognitionManager took to complete: 1ms
10-29 06:10:05.141 3121 3121 I SystemServer: StartGestureLauncher
10-29 06:10:05.141 3121 3121 I SystemServiceManager: Starting com.android.server.GestureLauncherService
10-29 06:10:05.141 3121 3121 D SystemServerTiming: StartGestureLauncher took to complete: 0ms
10-29 06:10:05.141 3121 3121 I SystemServer: StartSensorNotification
10-29 06:10:05.141 3121 3121 I SystemServiceManager: Starting com.android.server.SensorNotificationService
10-29 06:10:05.141 3121 3121 D SystemServerTiming: StartSensorNotification took to complete: 0ms
10-29 06:10:05.142 3121 3121 I SystemServer: StartContextHubSystemService
10-29 06:10:05.142 3121 3121 I SystemServiceManager: Starting com.android.server.ContextHubSystemService
10-29 06:10:05.142 3121 3121 D SystemServerTiming: StartContextHubSystemService took to complete: 0ms
10-29 06:10:05.142 3121 3121 I SystemServer: StartDiskStatsService
10-29 06:10:05.144 3121 3121 D SystemServerTiming: StartDiskStatsService took to complete: 2ms
10-29 06:10:05.144 3121 3121 I SystemServer: StartNetworkTimeUpdateService
10-29 06:10:05.145 3121 3121 D SystemServerTiming: StartNetworkTimeUpdateService took to complete: 1ms
10-29 06:10:05.145 3121 3121 I SystemServer: StartCommonTimeManagementService
10-29 06:10:05.146 3121 3121 D SystemServerTiming: StartCommonTimeManagementService took to complete: 1ms
10-29 06:10:05.147 3121 3121 I SystemServer: CertBlacklister
10-29 06:10:05.147 3121 3121 D SystemServerTiming: CertBlacklister took to complete: 0ms
10-29 06:10:05.147 3121 3121 I SystemServer: StartEmergencyAffordanceService
10-29 06:10:05.147 3121 3121 I SystemServiceManager: Starting com.android.server.emergency.EmergencyAffordanceService
10-29 06:10:05.148 3121 3121 D SystemServerTiming: StartEmergencyAffordanceService took to complete: 0ms
10-29 06:10:05.148 3121 3121 I SystemServer: StartDreamManager
10-29 06:10:05.148 3121 3121 I SystemServiceManager: Starting com.android.server.dreams.DreamManagerService
10-29 06:10:05.149 3121 3121 D SystemServerTiming: StartDreamManager took to complete: 1ms
10-29 06:10:05.149 3121 3121 I SystemServer: AddGraphicsStatsService
10-29 06:10:05.154 3121 3121 D SystemServerTiming: AddGraphicsStatsService took to complete: 6ms
10-29 06:10:05.155 3121 3121 I SystemServer: StartPrintManager
10-29 06:10:05.156 3121 3121 I SystemServiceManager: Starting com.android.server.print.PrintManagerService
10-29 06:10:05.156 3121 3176 D SystemServerInitThreadPool: Started executing Init ContextHubSystemService
10-29 06:10:05.157 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IContexthub/default in either framework or device manifest.
10-29 06:10:05.158 3121 3121 D SystemServerTiming: StartPrintManager took to complete: 2ms
10-29 06:10:05.158 3121 3121 I SystemServer: StartCompanionDeviceManager
10-29 06:10:05.159 3121 3121 I SystemServiceManager: Starting com.android.server.companion.CompanionDeviceManagerService
10-29 06:10:05.160 3121 3121 D SystemServerTiming: StartCompanionDeviceManager took to complete: 1ms
10-29 06:10:05.160 3121 3121 I SystemServer: StartRestrictionManager
10-29 06:10:05.160 3121 3121 I SystemServiceManager: Starting com.android.server.restrictions.RestrictionsManagerService
10-29 06:10:05.161 3121 3121 D SystemServerTiming: StartRestrictionManager took to complete: 1ms
10-29 06:10:05.161 3121 3121 I SystemServer: StartMediaSessionService
10-29 06:10:05.161 3121 3121 I SystemServiceManager: Starting com.android.server.media.MediaSessionService
10-29 06:10:05.163 3121 3121 D SystemServerTiming: StartMediaSessionService took to complete: 2ms
10-29 06:10:05.163 3121 3121 I SystemServer: StartMediaUpdateService
10-29 06:10:05.163 3121 3121 I SystemServiceManager: Starting com.android.server.media.MediaUpdateService
10-29 06:10:05.164 3121 3121 D SystemServerTiming: StartMediaUpdateService took to complete: 1ms
10-29 06:10:05.164 3121 3121 I SystemServer: StartMediaResourceMonitor
10-29 06:10:05.164 3121 3121 I SystemServiceManager: Starting com.android.server.media.MediaResourceMonitorService
10-29 06:10:05.165 3121 3121 D SystemServerTiming: StartMediaResourceMonitor took to complete: 0ms
10-29 06:10:05.165 3121 3121 I SystemServer: StartMediaRouterService
10-29 06:10:05.166 3121 3121 D SystemServerTiming: StartMediaRouterService took to complete: 1ms
10-29 06:10:05.166 3121 3121 I SystemServer: StartBackgroundDexOptService
10-29 06:10:05.166 3121 3121 W BackgroundDexOptService: SysProp pm.dexopt.downgrade_after_inactive_days not set
10-29 06:10:05.167 3121 3121 D SystemServerTiming: StartBackgroundDexOptService took to complete: 1ms
10-29 06:10:05.167 3121 3121 I SystemServer: StartPruneInstantAppsJobService
10-29 06:10:05.167 3121 3121 D SystemServerTiming: StartPruneInstantAppsJobService took to complete: 0ms
10-29 06:10:05.167 3121 3121 I SystemServer: StartShortcutServiceLifecycle
10-29 06:10:05.167 3121 3121 I SystemServiceManager: Starting com.android.server.pm.ShortcutService$Lifecycle
10-29 06:10:05.169 3121 3121 D SystemServerTiming: StartShortcutServiceLifecycle took to complete: 3ms
10-29 06:10:05.169 3121 3121 I SystemServer: StartLauncherAppsService
10-29 06:10:05.170 3121 3121 I SystemServiceManager: Starting com.android.server.pm.LauncherAppsService
10-29 06:10:05.170 3121 3121 D SystemServerTiming: StartLauncherAppsService took to complete: 0ms
10-29 06:10:05.170 3121 3121 I SystemServer: StartCrossProfileAppsService
10-29 06:10:05.170 3121 3121 I SystemServiceManager: Starting com.android.server.pm.CrossProfileAppsService
10-29 06:10:05.171 1 1 I chatty : uid=0(root) /init expire 2 lines
10-29 06:10:05.171 1 1 W init : type=1400 audit(0.0:2356): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:05.171 3121 3121 D SystemServerTiming: StartCrossProfileAppsService took to complete: 1ms
10-29 06:10:05.171 3121 3121 I SystemServer: StartMediaProjectionManager
10-29 06:10:05.171 3121 3121 I SystemServiceManager: Starting com.android.server.media.projection.MediaProjectionManagerService
10-29 06:10:05.172 3121 3121 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:05.173 3121 3121 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:05.173 3121 3121 D SystemServerTiming: StartMediaProjectionManager took to complete: 3ms
10-29 06:10:05.173 3121 3121 I SystemServer: StartSliceManagerService
10-29 06:10:05.174 3121 3121 I SystemServiceManager: Starting com.android.server.slice.SliceManagerService$Lifecycle
10-29 06:10:05.175 1 1 W init : type=1400 audit(0.0:2357): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
10-29 06:10:05.175 3121 3176 I ContextHubService: Context Hub HAL service not found
10-29 06:10:05.175 3121 3176 D SystemServerInitThreadPool: Finished executing Init ContextHubSystemService
10-29 06:10:05.176 3121 3121 D SystemServerTiming: StartSliceManagerService took to complete: 2ms
10-29 06:10:05.176 3121 3121 I SystemServer: StartCameraServiceProxy
10-29 06:10:05.176 3121 3121 I SystemServiceManager: Starting com.android.server.camera.CameraServiceProxy
10-29 06:10:05.179 3121 3121 D SystemServerTiming: StartCameraServiceProxy took to complete: 3ms
10-29 06:10:05.179 3121 3121 I SystemServer: StartStatsCompanionService
10-29 06:10:05.179 3121 3121 I SystemServiceManager: Starting com.android.server.stats.StatsCompanionService$Lifecycle
10-29 06:10:05.180 3121 3121 E KernelUidCpuFreqTimeReader: Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
10-29 06:10:05.180 3121 3121 D SystemServerTiming: StartStatsCompanionService took to complete: 2ms
10-29 06:10:05.181 3121 3121 I WindowManager: SAFE MODE not enabled
10-29 06:10:05.181 3121 3121 I SystemServer: StartJitCompilation
10-29 06:10:05.181 3121 3121 D SystemServerTiming: StartJitCompilation took to complete: 0ms
10-29 06:10:05.181 3121 3121 I SystemServer: StartMmsService
10-29 06:10:05.181 3121 3121 I SystemServiceManager: Starting com.android.server.MmsServiceBroker
10-29 06:10:05.182 3121 3121 D SystemServerTiming: StartMmsService took to complete: 1ms
10-29 06:10:05.182 3121 3121 I SystemServer: StartAutoFillService
10-29 06:10:05.182 3121 3121 I SystemServiceManager: Starting com.android.server.autofill.AutofillManagerService
10-29 06:10:05.183 3121 3121 I AutofillManagerService: Setting debug to true
10-29 06:10:05.184 3121 3121 D SystemServerTiming: StartAutoFillService took to complete: 2ms
10-29 06:10:05.184 3121 3121 I SystemServer: MakeVibratorServiceReady
10-29 06:10:05.186 3121 3121 D SystemServerTiming: MakeVibratorServiceReady took to complete: 1ms
10-29 06:10:05.186 3121 3121 I SystemServer: MakeLockSettingsServiceReady
10-29 06:10:05.207 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IWeaver/default in either framework or device manifest.
10-29 06:10:05.207 3121 3121 I SyntheticPasswordManager: Device does not support weaver
10-29 06:10:05.208 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IAuthSecret/default in either framework or device manifest.
10-29 06:10:05.208 3121 3121 I LockSettingsService: Device doesn't implement AuthSecret HAL
10-29 06:10:05.210 3121 3121 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory)
10-29 06:10:05.210 3121 3127 W system_server: Receiving file descriptor from ADB failed (socket 38): Success
10-29 06:10:05.210 3121 3127 E system_server: Something went wrong getting fds from adb. Retry!: Success
10-29 06:10:05.210 2984 3051 I [email protected]: event=1 on fd=15
10-29 06:10:05.210 3121 3121 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
10-29 06:10:05.211 3121 3121 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory)
10-29 06:10:05.211 3121 3121 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
10-29 06:10:05.211 3121 3121 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
10-29 06:10:05.211 3121 3121 D SystemServerTiming: MakeLockSettingsServiceReady took to complete: 26ms
10-29 06:10:05.212 3121 3121 I SystemServer: StartBootPhaseLockSettingsReady
10-29 06:10:05.212 3121 3121 I SystemServiceManager: Starting phase 480
10-29 06:10:05.222 3121 3121 I DevicePolicyManager: Set ro.device_owner property to false
10-29 06:10:05.223 3121 3175 D SystemServerInitThreadPool: Started executing DevicePolicyManager
10-29 06:10:05.223 3121 3175 D SystemServerInitThreadPool: Finished executing DevicePolicyManager
10-29 06:10:05.225 3121 3121 D SystemServerTiming: StartBootPhaseLockSettingsReady took to complete: 13ms
10-29 06:10:05.225 3121 3121 I SystemServer: StartBootPhaseSystemServicesReady
10-29 06:10:05.225 3121 3121 I SystemServiceManager: Starting phase 500
10-29 06:10:05.226 3121 3121 D AppStandbyController: Setting app idle enabled state
10-29 06:10:05.230 3121 3121 I VrManagerService: No default vr listener service found.
10-29 06:10:05.235 3121 3121 I WifiService: WifiService starting up with Wi-Fi disabled
10-29 06:10:05.241 3121 3207 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IServiceManager
10-29 06:10:05.242 3121 3177 D HalDevMgr: IWifi registration notification: [email protected]::IWifi, name=default, preexisting=true
10-29 06:10:05.245 3121 3177 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::IWifi
10-29 06:10:05.246 3121 3207 D WificondControl: tearing down interfaces in wificond
10-29 06:10:05.250 3121 3121 I WifiScanningService: Starting wifiscanner
10-29 06:10:05.250 2956 2956 D libEGL : loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
10-29 06:10:05.255 3121 3121 I EthernetServiceImpl: Starting Ethernet service
10-29 06:10:05.261 3121 3121 D Ethernet: Registering NetworkFactory
10-29 06:10:05.261 3121 3212 D ConnectivityService: Got NetworkFactory Messenger for Ethernet
10-29 06:10:05.261 3121 3234 D Ethernet: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:05.262 3121 3121 E IpConfigStore: Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
10-29 06:10:05.266 3121 3234 I EthernetTracker: maybeTrackInterface eth0
10-29 06:10:05.267 2954 3021 D CommandListener: Setting iface cfg
10-29 06:10:05.267 2954 3021 D CommandListener: Trying to bring up eth0
10-29 06:10:05.269 2984 2984 W libc : Unable to set property "sys.usb.ffs.ready" to "0": error code: 0x18
10-29 06:10:05.270 2984 3051 I [email protected]: event=1 on fd=16
10-29 06:10:05.270 2984 2984 I [email protected]: mMonitor destroyed
10-29 06:10:05.274 2988 3088 D PermissionCache: checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (89 us)
10-29 06:10:05.274 3121 3121 W SoundTriggerHelper: listModules status=0, # of modules=0
10-29 06:10:05.275 3121 3121 D ContextHubSystemService: onBootPhase: PHASE_SYSTEM_SERVICES_READY
10-29 06:10:05.276 3121 3121 D SystemServerTiming: StartBootPhaseSystemServicesReady took to complete: 51ms
10-29 06:10:05.276 3121 3121 I SystemServer: MakeWindowManagerServiceReady
10-29 06:10:05.280 3121 3121 I android_os_HwBinder: HwBinder: Starting thread pool for default::[email protected]::ISurfaceFlingerConfigs
10-29 06:10:05.280 3121 3121 D SystemServerTiming: MakeWindowManagerServiceReady took to complete: 5ms
10-29 06:10:05.281 3121 3121 I SystemServer: MakePowerManagerServiceReady
10-29 06:10:05.282 2954 3021 E CommandListener: Error upping interface
10-29 06:10:05.283 3121 3234 E EthernetTracker: Error upping interface eth0
10-29 06:10:05.283 3121 3234 E EthernetTracker: java.lang.IllegalStateException: command '3 interface setcfg eth0 0.0.0.0 0 broadcast up multicast' failed with '400 3 Failed to up interface (No such device)'
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:1066)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceUp(NetworkManagementService.java:1083)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.addInterface(EthernetTracker.java:178)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.maybeTrackInterface(EthernetTracker.java:252)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.trackAvailableInterfaces(EthernetTracker.java:259)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.ethernet.EthernetTracker.lambda$7ZSuSvoSqcExye5DLwv_gyq6gyM(Unknown Source:0)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.ethernet.-$$Lambda$EthernetTracker$7ZSuSvoSqcExye5DLwv_gyq6gyM.run(Unknown Source:2)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at android.os.Handler.handleCallback(Handler.java:873)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at android.os.Handler.dispatchMessage(Handler.java:99)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at android.os.Looper.loop(Looper.java:193)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:10:05.283 3121 3234 E EthernetTracker: Caused by: com.android.server.NativeDaemonConnector$NativeDaemonFailureException: command '3 interface setcfg eth0 0.0.0.0 0 broadcast up multicast' failed with '400 3 Failed to up interface (No such device)'
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NativeDaemonConnector.executeForList(NativeDaemonConnector.java:515)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:411)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:406)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NativeDaemonConnector.execute(NativeDaemonConnector.java:391)
10-29 06:10:05.283 3121 3234 E EthernetTracker: at com.android.server.NetworkManagementService.setInterfaceConfig(NetworkManagementService.java:1064)
10-29 06:10:05.283 3121 3234 E EthernetTracker: ... 10 more
10-29 06:10:05.284 3121 3234 E EthernetTracker: Null interface config for eth0. Bailing out.
10-29 06:10:05.284 3121 3234 I EthernetTracker: maybeTrackInterface ip6_vti0
10-29 06:10:05.284 3121 3234 I EthernetTracker: maybeTrackInterface ip6tnl0
10-29 06:10:05.284 3121 3234 I EthernetTracker: maybeTrackInterface ip_vti0
10-29 06:10:05.284 3121 3234 I EthernetTracker: maybeTrackInterface lo
10-29 06:10:05.284 3121 3234 I EthernetTracker: maybeTrackInterface sit0
10-29 06:10:05.291 3121 3146 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
10-29 06:10:05.294 3121 3121 D SystemServerTiming: MakePowerManagerServiceReady took to complete: 13ms
10-29 06:10:05.294 3121 3121 I SystemServer: MakePackageManagerServiceReady
10-29 06:10:05.306 3121 3207 D WifiStateMachinePrime: received a message in WifiDisabledState: { when=-1ms what=3 target=com.android.internal.util.StateMachine$SmHandler }
10-29 06:10:05.306 3121 3207 D WifiStateMachinePrime: Switching from WifiDisabledState to WifiDisabled
10-29 06:10:05.306 3121 3207 D WifiStateMachinePrime: Entering WifiDisabledState
10-29 06:10:05.307 3121 3207 D ActiveModeManager: sending scan available broadcast: false
10-29 06:10:05.307 3121 3121 V UserDataPreparer: Found /data/user_de/0 with serial number 0
10-29 06:10:05.308 3121 3121 V UserDataPreparer: Found /data/user/0 with serial number 0
10-29 06:10:05.308 3121 3121 V UserDataPreparer: Found /data/system_de/0 with serial number 0
10-29 06:10:05.308 3121 3121 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
10-29 06:10:05.308 3121 3121 V UserDataPreparer: Found /data/misc_ce/0 with serial number 0
10-29 06:10:05.309 3121 3121 D SystemServerTiming: MakePackageManagerServiceReady took to complete: 15ms
10-29 06:10:05.309 3121 3121 I SystemServer: MakeDisplayManagerServiceReady
10-29 06:10:05.310 3121 3121 D SystemServerTiming: MakeDisplayManagerServiceReady took to complete: 1ms
10-29 06:10:05.310 3121 3121 I SystemServer: StartDeviceSpecificServices
10-29 06:10:05.310 3121 3121 D SystemServerTiming: StartDeviceSpecificServices took to complete: 0ms
10-29 06:10:05.310 3121 3121 I SystemServer: StartBootPhaseDeviceSpecificServicesReady
10-29 06:10:05.311 3121 3121 I SystemServiceManager: Starting phase 520
10-29 06:10:05.311 3121 3121 D SystemServerTiming: StartBootPhaseDeviceSpecificServicesReady took to complete: 0ms
10-29 06:10:05.312 3121 3121 W UsageStatsService: Event reported without a package name
10-29 06:10:05.313 3121 3121 I AppOps : Pruning old package system/com.android.server.AppOpsService$UidState@9e22cb9: new uid=-1
10-29 06:10:05.314 3121 3121 I ActivityManager: System now ready
10-29 06:10:05.323 3121 3121 I SystemServer: Making services ready
10-29 06:10:05.323 3121 3121 I SystemServer: StartActivityManagerReadyPhase
10-29 06:10:05.323 3121 3121 I SystemServiceManager: Starting phase 550
10-29 06:10:05.325 3121 3121 W ActivityManager: Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
10-29 06:10:05.326 3121 3121 W ActivityManager: Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
10-29 06:10:05.351 2956 2956 I Zygote : Preloading shared libraries...
10-29 06:10:05.354 3121 3121 D BluetoothManagerService: Bluetooth boot completed
10-29 06:10:05.355 3121 3121 D BluetoothManagerService: Getting adapter name and address
10-29 06:10:05.355 3121 3143 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
10-29 06:10:05.355 3121 3143 D BluetoothManagerService: Binding to service to get name and address
10-29 06:10:05.358 2956 2956 I Zygote : Uninstalled ICU cache reference pinning...
10-29 06:10:05.360 2956 2956 I Zygote : Installed AndroidKeyStoreProvider in 1ms.
10-29 06:10:05.378 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.380 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06[ 68.883791] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
:10:05.385 2956 2956 I Zygote : Warmed up JCA providers in 25ms.
10-29 06:10:05.385 2956 2956 D Zygote : end preload
10-29 06:10:05.385 3121 3134 D SystemServerTimingAsync: SecondaryZygotePreload took to complete: 987ms
10-29 06:10:05.385 3121 3134 D SystemServerInitThreadPool: Finished executing SecondaryZygotePreload
10-29 06:10:05.391 3239 3240 I adbd : initializing functionfs
10-29 06:10:05.391 3239 3240 I adbd : opening control endpoint /dev/usb-ffs/adb/ep0
10-29 06:10:05.397 3121 3138 I ActivityManager: Start proc 3241:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
10-29 06:10:05.400 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.404 3239 3240 I adbd : functionfs successfully initialized
10-29 06:10:05.404 3239 3240 I adbd : registering usb transport
10-29 06:10:05.421 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.441 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.441 3241 3241 I droid.bluetoot: The ClassLoaderContext is a special shared library.
10-29 06:10:05.456 3121 3121 W SystemServiceManager: Service com.android.server.InputMethodManagerService$Lifecycle took 98 ms in onBootPhase
10-29 06:10:05.456 3121 3199 D StorageManagerService: Thinking about init, mSystemReady=true, mDaemonConnected=true
10-29 06:10:05.456 3121 3199 D StorageManagerService: Thinking about reset, mSystemReady=true, mDaemonConnected=true
10-29 06:10:05.457 3121 3136 I ActivityManager: Force stopping com.android.providers.media appid=10006 user=-1: vold reset
10-29 06:10:05.462 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.462 3241 3241 I droid.bluetoot: The ClassLoaderContext is a special shared library.
10-29 06:10:05.466 3121 3133 V StorageManagerService: Found primary storage at VolumeInfo{emulated}:
10-29 06:10:05.466 3121 3133 V StorageManagerService: type=EMULATED diskId=null partGuid= mountFlags=0 mountUserId=-1
10-29 06:10:05.466 3121 3133 V StorageManagerService: state=UNMOUNTED
10-29 06:10:05.466 3121 3133 V StorageManagerService: fsType=null fsUuid=null fsLabel=null
10-29 06:10:05.466 3121 3133 V StorageManagerService: path=null internalPath=null
10-29 06:10:05.469 3121 3121 I WallpaperManagerService: No static wallpaper imagery; defaults will be shown
10-29 06:10:05.470 2884 2890 V vold : Waiting for FUSE to spin up...
10-29 06:10:05.473 3121 3138 I ActivityManager: Start proc 3259:com.android.inputmethod.latin/u0a47 for service com.android.inputmethod.latin/.LatinIME[ 69.129685] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
10-29 06:10:05.476 3121 3121 E BitmapFactory: Unable to decod[ 69.143663] type=1400 audit(1572329456.503:3729): avc: denied { dac_read_search } for pid=4045 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
e stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or dir[ 69.170695] type=1400 audit(1572329460.019:3730): avc: denied { read } for pid=2977 comm="[email protected]" name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
ectory)
10-29 06:10:05.476 3121 3121 W WallpaperManagerService: Invalid wallpaper data
10-29 06:10:05.476 3121 3121 E WallpaperManagerService: Unable to apply new wallpaper
10-29 06:10:05.478 2965 3091 D audio_hw_primary: adev_set_parameters: enter: A2dpSuspended=false
10-29 06:10:05.478 2965 3091 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:10:05.479 3121 3220 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
10-29 06:10:05.479 2965 3091 D audio_hw_primary: adev_set_parameters: enter: BT_SCO=off
10-29 06:10:05.479 2965 3091 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:10:05.480 3121 3220 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:10:05.481 3121 3121 D SystemServerTiming: StartActivityManagerReadyPhase took to complete: 158ms
10-29 06:10:05.481 3121 3121 I SystemServer: StartObservingNativeCrashes
10-29 06:10:05.481 3121 3220 E BluetoothHearingAid: Could not bind to Bluetooth Hearing Aid Service with Intent { act=android.bluetooth.IBluetoothHearingAid }
10-29 06:10:05.482 2984 3029 I [email protected]: port0
10-29 06:10:05.482 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.482 3121 3121 D SystemServerTiming: StartObservingNativeCrashes took to complete: 0ms
10-29 06:10:05.482 2984 3029 I [email protected]: connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
10-29 06:10:05.483 2988 3088 I AudioFlinger: systemReady
10-29 06:10:05.488 3121 3121 I SystemServer: StartSystemUI
10-29 06:10:05.488 3121 3177 I UsbPortManager: ClientCallback: port0
10-29 06:10:05.490 3121 3171 D SystemServerInitThreadPool: Started executing WebViewFactoryPreparation
10-29 06:10:05.490 3121 3171 I SystemServer: WebViewFactoryPreparation
10-29 06:10:05.490 3121 3142 I UsbPortManager: USB port added: port=UsbPort{id=port0, supportedModes=dual}, status=UsbPortStatus{connected=true, currentMode=ufp, currentPowerRole=sink, currentDataRole=device, supportedRoleCombinations=[source:host, sink:device]}, canChangeMode=true, canChangePowerRole=false, canChangeDataRole=false
10-29 06:10:05.492 3121 3270 I UsbDescriptorParser: Unknown Descriptor len: 6 type:0x30
10-29 06:10:05.497 3121 3270 D UsbHostManager: USB device attached: vidpid 17ef:6019 mfg/product/ver/serial PixArt/Lenovo Optical USB Mouse/1.00/null hasAudio/HID/Storage: false/true/false
10-29 06:10:05.500 3121 3121 D SystemServerTiming: StartSystemUI took to complete: 12ms
10-29 06:10:05.500 3121 3121 I SystemServer: MakeNetworkManagementServiceReady
10-29 06:10:05.501 3121 3270 D UsbDeviceDescriptor: 1 configs
10-29 06:10:05.501 3121 3121 D NetworkManagement: enabling bandwidth control
10-29 06:10:05.502 3121 3270 D UsbHostManager: Added device UsbDevice[mName=/dev/bus/usb/001/002,mVendorId=6127,mProductId=24601,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=PixArt,mProductName=Lenovo Optical USB Mouse,mVersion=1.00,mSerialNumber=null,mConfigurations=[
10-29 06:10:05.502 3121 3270 D UsbHostManager: UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
10-29 06:10:05.502 3121 3270 D UsbHostManager: UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
10-29 06:10:05.502 3121 3270 D UsbHostManager: UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=4,mInterval=10]]]]
10-29 06:10:05.503 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.505 3264 3264 W sdcard : Device explicitly enabled sdcardfs
10-29 06:10:05.508 3121 3171 D WebViewLibraryLoader: Setting new address space to 147551200
10-29 06:10:05.520 3121 3171 D SystemServerTimingAsync: WebViewFactoryPreparation took to complete: 30ms
10-29 06:10:05.520 3121 3171 D SystemServerInitThreadPool: Finished executing WebViewFactoryPreparation
10-29 06:10:05.521 2884 2890 V vold : Waiting for FUSE to spin up...
10-29 06:10:05.524 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.531 3121 3138 I ActivityManager: Start proc 3282:com.android.systemui/u0a31 for service com.android.systemui/.SystemUIService
10-29 06:10:05.544 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.550 3241 3241 V AdapterServiceConfig: Adding HeadsetService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding A2dpService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding HidHostService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding HealthService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding PanService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding GattService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding BluetoothMapService
10-29 06:10:05.552 3241 3241 V AdapterServiceConfig: Adding AvrcpTargetService
10-29 06:10:05.553 3241 3241 V AdapterServiceConfig: Adding HidDeviceService
10-29 06:10:05.553 3241 3241 V AdapterServiceConfig: Adding BluetoothOppService
10-29 06:10:05.553 3241 3241 V AdapterServiceConfig: Adding BluetoothPbapService
10-29 06:10:05.560 2998 3063 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/.) Is a directory
10-29 06:10:05.564 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.571 2884 2890 V vold : Waiting for FUSE to spin up...
10-29 06:10:05.582 2998 3063 E linker : library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
10-29 06:10:05.582 2998 3063 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/..) Invalid argument
10-29 06:10:05.585 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.596 3241 3241 I : [1029/061005.596072:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0xf26b8ceef430, handle=0xbdadfcb3c371127d
10-29 06:10:05.596 3241 3241 D BluetoothAdapterService: onCreate()
10-29 06:10:05.601 3241 3241 D AdapterState: make() - Creating AdapterState
10-29 06:10:05.601 2998 3063 E MediaExtractorFactory: couldn't opendir(/vendor/lib64/extractors)
10-29 06:10:05.603 3241 3241 I bt_btif : init
10-29 06:10:05.603 3241 3241 D bt_osi_allocation_tracker: canary initialized
10-29 06:10:05.603 3241 3301 I AdapterState: OFF : entered
10-29 06:10:05.603 3241 3301 D AdapterProperties: Setting state to OFF
10-29 06:10:05.604 3241 3302 I bt_osi_thread: run_thread: thread id 3302, thread name stack_manager started
10-29 06:10:05.604 3241 3302 I bt_stack_manager: event_init_stack is initializing the stack
10-29 06:10:05.605 3241 3302 E bt_btif_config: Config is missing adapter section
10-29 06:10:05.605 3241 3302 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
10-29 06:10:05.605 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.605 3241 3302 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
10-29 06:10:05.606 3241 3302 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
10-29 06:10:05.606 3241 3302 E bt_btif_config: init unable to transcode legacy file; creating empty config.
10-29 06:10:05.606 3241 3305 I bt_osi_thread: run_thread: thread id 3305, thread name alarm_default_ca started
10-29 06:10:05.607 3241 3306 I bt_osi_thread: run_thread: thread id 3306, thread name alarm_dispatcher started
10-29 06:10:05.608 3241 3302 I bt_btif_core: btif_init_bluetooth entered
10-29 06:10:05.608 3241 3302 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
10-29 06:10:05.610 2990 3069 D StagefrightPluginLoader: Failed to load library: libstagefright_ccodec.so (dlopen failed: library "libstagefright_ccodec.so" not found)
10-29 06:10:05.610 2990 3069 D StagefrightPluginLoader: Handle or CreateInputSurface symbol is null
10-29 06:10:05.610 3241 3308 I bt_osi_thread: run_thread: thread id 3308, thread name bt_jni_workqueue started
10-29 06:10:05.610 2990 3069 D StagefrightPluginLoader: Handle or CreateBuilder symbol is null
10-29 06:10:05.611 3241 3302 I bt_btif_core: btif_init_bluetooth finished
10-29 06:10:05.611 3241 3302 I bt_stack_manager: event_init_stack finished
10-29 06:10:05.611 3241 3308 I bt_btif_core: run_message_loop entered
10-29 06:10:05.611 3241 3241 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
10-29 06:10:05.611 3241 3241 I bt_btif : get_profile_interface: id = socket
10-29 06:10:05.611 3241 3308 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
10-29 06:10:05.611 3241 3308 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
10-29 06:10:05.612 3241 3241 I bt_btif : get_profile_interface: id = sdp
10-29 06:10:05.613 3241 3308 D AdapterProperties: Name is: iMX8
10-29 06:10:05.613 3241 3308 D AdapterProperties: BT Class:5a020c
10-29 06:10:05.615 3241 3241 I BluetoothAdapterService: Phone policy enabled
10-29 06:10:05.617 3241 3241 D BluetoothActiveDeviceManager: start()
10-29 06:10:05.620 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.620 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.aac.decoder) in [email protected] process
10-29 06:10:05.623 3241 3310 D BluetoothActiveDeviceManager: onAudioDevicesAdded
10-29 06:10:05.623 3241 3241 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@d9a30a9
10-29 06:10:05.623 3241 3310 D BluetoothActiveDeviceManager: Audio device added: EVK_8MQ type: 2
10-29 06:10:05.623 3241 3310 D BluetoothActiveDeviceManager: Audio device added: EVK_8MQ type: 15
10-29 06:10:05.626 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.626 3241 3241 D BluetoothAdapterService: onBind()
10-29 06:10:05.632 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.632 3003 3319 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in [email protected] process
10-29 06:10:05.639 3003 3319 I OMXPlayer: Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
10-29 06:10:05.639 3003 3319 I OMXPlayer: dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
10-29 06:10:05.641 3121 3128 W JHwRemoteBinder: BinderProxy is being destroyed but the application did not call unlinkToDeath to unlink all of its death recipients beforehand. Releasing leaked death recipient: com.android.server.usb.UsbDeviceManager$UsbHandlerHal$UsbGadgetDeathRecipient
10-29 06:10:05.641 3121 3131 I system_server: Background concurrent copying GC freed 29389(2MB) AllocSpace objects, 14(424KB) LOS objects, 42% free, 4MB/8MB, paused 224us total 223.192ms
10-29 06:10:05.646 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.646 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.646 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amrnb.sw-based) in [email protected] process
10-29 06:10:05.655 3003 3319 I OMXPlayer: SetRoleFormat AMR NB mode.
10-29 06:10:05.658 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.658 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.amrnb.decoder) in [email protected] process
10-29 06:10:05.666 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.668 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.668 3003 3319 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in [email protected] process
10-29 06:10:05.673 3003 3003 I OMXPlayer: SetRoleFormat AMR WB mode.
10-29 06:10:05.676 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.676 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.amrwb.decoder) in [email protected] process
10-29 06:10:05.680 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.680 3003 3065 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in [email protected] process
10-29 06:10:05.687 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.689 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.689 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.g711.alaw.decoder) in [email protected] process
10-29 06:10:05.695 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.695 3003 3319 I OMXMaster: makeComponentInstance(OMX.google.g711.mlaw.decoder) in [email protected] process
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: returned from zygote!
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: done updating battery stats
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: building log message
10-29 06:10:05.696 3121 3138 I ActivityManager: Start proc 3335:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: starting to update pids map
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: done updating pids map
10-29 06:10:05.696 3121 3138 W ActivityManager: Slow operation: 176ms so far, now at startProcess: asking zygote to start proc
10-29 06:10:05.699 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.699 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.gsm.decoder) in [email protected] process
10-29 06:10:05.700 3335 3335 W WebViewLoader-: Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
10-29 06:10:05.707 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.707 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.708 3003 3003 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in [email protected] process
10-29 06:10:05.712 3121 3281 W ZygoteProcess: Got error connecting to zygote, retrying. msg= Connection refused
10-29 06:10:05.721 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.722 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.mp3.decoder) in [email protected] process
10-29 06:10:05.723 3335 3335 V WebViewLibraryLoader: RelroFileCreator (64bit = false), lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so
10-29 06:10:05.724 3351 3351 I WebViewZygoteInit: Starting WebViewZygoteInit
10-29 06:10:05.724 3351 3351 I WebViewZygoteInit: --zygote-socket=com.android.internal.os.WebViewZygoteInit/ee4ba3c9-597c-43e7-8546-fba3bb0473f5
10-29 06:10:05.727 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.728 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.728 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.opus.decoder) in [email protected] process
10-29 06:10:05.730 3121 3138 W ActivityManager: Slow operation: 210ms so far, now at startProcess: returned from zygote!
10-29 06:10:05.730 3121 3138 W ActivityManager: Slow operation: 210ms so far, now at startProcess: done updating battery stats
10-29 06:10:05.730 3121 3138 W ActivityManager: Slow operation: 210ms so far, now at startProcess: building log message
10-29 06:10:05.730 3121 3138 I ActivityManager: Start proc 3367:WebViewLoader-arm64-v8a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
10-29 06:10:05.730 3121 3138 W ActivityManager: Slow operation: 210ms so far, now at startProcess: starting to update pids map
10-29 06:10:05.730 3121 3138 W ActivityManager: Slow operation: 210ms so far, now at startProcess: done updating pids map
10-29 06:10:05.737 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.737 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.raw.decoder) in [email protected] process
10-29 06:10:05.748 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.749 3367 3367 V WebViewLibraryLoader: RelroFileCreator (64bit = true), lib: /system/app/webview/webview.apk!/lib/arm64-v8a/libwebviewchromium.so
10-29 06:10:05.760 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.760 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:05.768 2984 2984 E libc : Access denied finding property "sys.usb.ffs.ready"
10-29 06:10:05.788 2984 2984 I [email protected]: setCurrentUsbFunctions Adb
10-29 06:10:05.789 2984 2984 I [email protected]: Service started
10-29 06:10:05.819 3335 3335 I WebViewLoader-: System.exit called, status: 0
10-29 06:10:05.819 3335 3335 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:10:05.833 3121 3309 I ActivityManager: Process WebViewLoader-armeabi-v7a (pid 3335) has died: psvc PER
10-29 06:10:05.833 3121 3139 W libprocessgroup: kill(-3335, 9) failed: No such process
10-29 06:10:05.834 2956 2956 I Zygote : Process 3335 exited cleanly (0)
10-29 06:10:05.839 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.839 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.aac.encoder) in [email protected] process
10-29 06:10:05.849 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.849 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.amrnb.encoder) in [email protected] process
10-29 06:10:05.878 3121 3139 W libprocessgroup: kill(-3335, 9) failed: No such process
10-29 06:10:05.878 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 3335 in 44ms
10-29 06:10:05.890 3121 3121 W NetworkManagement: setDataSaverMode(): already false
10-29 06:10:05.891 3121 3261 W system_server: Long monitor contention with owner main (3121) at void java.lang.Object.wait(long, int)(Object.java:-2) waiters=1 in void com.android.server.NetworkManagementService.setUidCleartextNetworkPolicy(int, int) for 310ms
10-29 06:10:05.892 3121 3121 D SystemServerTiming: MakeNetworkManagementServiceReady took to complete: 391ms
10-29 06:10:05.892 3121 3121 I SystemServer: MakeIpSecServiceReady
10-29 06:10:05.894 3121 3121 D IpSecService: IpSecService is ready
10-29 06:10:05.894 3121 3121 D SystemServerTiming: MakeIpSecServiceReady took to complete: 2ms
10-29 06:10:05.894 3121 3140 E BatteryExternalStatsWorker: no controller energy info supplied for wifi
10-29 06:10:05.894 3121 3121 I SystemServer: MakeNetworkStatsServiceReady
10-29 06:10:05.894 3121 3140 E BatteryExternalStatsWorker: no controller energy info supplied for telephony
10-29 06:10:05.903 3121 3121 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:05.909 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.909 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.amrwb.encoder) in [email protected] process
10-29 06:10:05.910 3121 3204 W NetworkPolicy: setRestrictBackgroundUL: already false
10-29 06:10:05.914 3121 3121 D SystemServerTiming: MakeNetworkStatsServiceReady took to complete: 20ms
10-29 06:10:05.914 3121 3121 I SystemServer: MakeConnectivityServiceReady
10-29 06:10:05.916 3121 3234 D Ethernet: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:05.916 3121 3121 D PermissionMonitor: Monitoring
10-29 06:10:05.921 3121 3121 D PermissionMonitor: Users: 1, Apps: 72
10-29 06:10:05.923 3121 3204 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:05.924 3121 3121 D SystemServerTiming: MakeConnectivityServiceReady took to complete: 10ms
10-29 06:10:05.924 3121 3121 I SystemServer: MakeNetworkPolicyServiceReady
10-29 06:10:05.926 3259 3259 I putmethod.lati: The ClassLoaderContext is a special shared library.
10-29 06:10:05.926 3121 3121 D SystemServerTiming: MakeNetworkPolicyServiceReady took to complete: 3ms
10-29 06:10:05.927 3121 3121 I SystemServer: StartWatchdog
10-29 06:10:05.927 3121 3121 D SystemServerTiming: StartWatchdog took to complete: 0ms
10-29 06:10:05.927 3121 3121 I SystemServer: PhaseThirdPartyAppsCanStart
10-29 06:10:05.927 3121 3121 I SystemServiceManager: Starting phase 600
10-29 06:10:05.930 3121 3121 E LightsService: Light requested not available on this device. 4
10-29 06:10:05.931 3121 3121 V WallpaperManagerService: bindWallpaperComponentLocked: componentName=ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
10-29 06:10:05.939 3121 3203 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:05.944 3121 3203 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:05.946 3121 3204 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:05.948 3367 3367 I WebViewLoader-: System.exit called, status: 0
10-29 06:10:05.948 3367 3367 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:10:05.950 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.950 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.flac.encoder) in [email protected] process
10-29 06:10:05.955 3282 3282 I ndroid.systemu: The ClassLoaderContext is a special shared library.
10-29 06:10:05.959 3121 3121 I StatsCompanionService: Told statsd that StatsCompanionService is alive.
10-29 06:10:05.959 3121 3121 D SystemServerTiming: PhaseThirdPartyAppsCanStart took to complete: 32ms
10-29 06:10:05.959 3121 3121 I SystemServer: MakeLocationServiceReady
10-29 06:10:05.963 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IGnss/default in either framework or device manifest.
10-29 06:10:05.964 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.964 3003 3065 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in [email protected] process
10-29 06:10:05.964 3121 3121 D GnssLocationProvider: gnssHal 1.1 was null, trying 1.0
10-29 06:10:05.965 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IGnss/default in either framework or device manifest.
10-29 06:10:05.967 3121 3121 W LocationManagerService: no network location provider found
10-29 06:10:05.971 3259 3259 I putmethod.lati: The ClassLoaderContext is a special shared library.
10-29 06:10:05.971 3121 3121 E LocationManagerService: no geocoder provider found
10-29 06:10:05.972 3121 3121 D LocationManagerService: Unable to bind FLP Geofence proxy.
10-29 06:10:05.972 3121 3121 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. class_init is effectively a no-op
10-29 06:10:05.972 3121 3121 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. is_supported is effectively a no-op
10-29 06:10:05.972 3121 3121 D LocationManagerService: Hardware Activity-Recognition not supported.
10-29 06:10:05.973 3121 3121 E ActivityRecognitionProxy: ServiceWatcher could not start.
10-29 06:10:05.973 3121 3121 D LocationManagerService: Unable to bind ActivityRecognitionProxy.
10-29 06:10:05.975 3121 3261 I ActivityManager: Process WebViewLoader-arm64-v8a (pid 3367) has died: psvc PER
10-29 06:10:05.975 3121 3139 W libprocessgroup: kill(-3367, 9) failed: No such process
10-29 06:10:05.976 2955 2955 I Zygote : Process 3367 exited cleanly (0)
10-29 06:10:05.978 3121 3121 D SystemServerTiming: MakeLocationServiceReady took to complete: 18ms
10-29 06:10:05.978 3121 3121 I SystemServer: MakeCountryDetectionServiceReady
10-29 06:10:05.978 3121 3121 D SystemServerTiming: MakeCountryDetectionServiceReady took to complete: 0ms
10-29 06:10:05.978 3121 3121 I SystemServer: MakeNetworkTimeUpdateReady
10-29 06:10:05.983 3121 3121 D ConnectivityService: requestNetwork for uid/pid:1000/3121 NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ]
10-29 06:10:05.984 3121 3121 D SystemServerTiming: MakeNetworkTimeUpdateReady took to complete: 5ms
10-29 06:10:05.984 3121 3234 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:10:05.984 3121 3121 I SystemServer: MakeCommonTimeManagementServiceReady
10-29 06:10:05.984 3121 3121 I CommonTimeManagementService: No common time service detected on this platform. Common time services will be unavailable.
10-29 06:10:05.984 3121 3121 D SystemServerTiming: MakeCommonTimeManagementServiceReady took to complete: 1ms
10-29 06:10:05.984 3121 3121 I SystemServer: MakeInputManagerServiceReady
10-29 06:10:05.986 3121 3121 D SystemServerTiming: MakeInputManagerServiceReady took to complete: 1ms
10-29 06:10:05.986 3121 3121 I SystemServer: MakeTelephonyRegistryReady
10-29 06:10:05.986 3121 3121 D SystemServerTiming: MakeTelephonyRegistryReady took to complete: 0ms
10-29 06:10:05.986 3121 3121 I SystemServer: MakeMediaRouterServiceReady
10-29 06:10:05.987 3121 3121 D SystemServerTiming: MakeMediaRouterServiceReady took to complete: 1ms
10-29 06:10:05.987 3121 3121 I SystemServer: MakeMmsServiceReady
10-29 06:10:05.987 3121 3121 I MmsServiceBroker: Delay connecting to MmsService until an API is called
10-29 06:10:05.987 3121 3121 D SystemServerTiming: MakeMmsServiceReady took to complete: 0ms
10-29 06:10:05.987 3121 3121 I SystemServer: IncidentDaemonReady
10-29 06:10:05.990 3121 3121 D SystemServerTiming: IncidentDaemonReady took to complete: 3ms
10-29 06:10:05.990 3121 3121 I SystemServiceManager: Calling onStartUser u0
10-29 06:10:05.991 3121 3121 W VoiceInteractionManagerService: no available voice interaction services found for user 0
10-29 06:10:05.991 3121 3121 W VoiceInteractionManagerService: no available voice recognition services found for user 0
10-29 06:10:05.992 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:05.993 3003 3330 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:05.993 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:05.994 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:05.994 3003 3330 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback
10-29 06:10:05.994 3003 3330 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:05.995 3121 3121 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
10-29 06:10:05.996 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:05.997 3003 3330 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based.secure) in [email protected] process
10-29 06:10:05.998 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:05.999 3003 3330 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:05.999 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:05.999 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.000 3003 3330 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.avc.v3.hw-based.secure] component does not support metadata mode; using fallback
10-29 06:10:06.001 3003 3330 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.avc.v3.hw-based.secure, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.004 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.004 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.h264.decoder) in [email protected] process
10-29 06:10:06.006 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000020
10-29 06:10:06.014 3003 3330 E OMXNodeInstance: getExtensionIndex(0xec2a8080:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.014 3003 3330 E OMXNodeInstance: getExtensionIndex(0xec2a8080:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.016 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.016 3003 3330 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div3.hw-based) in [email protected] process
10-29 06:10:06.018 3003 3065 E OMXNodeInstance: getParameter(0xeb890a04:Freescale.std._decoder.div3.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.018 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.019 3003 3065 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.019 3003 3065 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.019 3003 3065 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.019 3003 3065 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.div3.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.019 3121 3139 W libprocessgroup: kill(-3367, 9) failed: No such process
10-29 06:10:06.019 3003 3065 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.019 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 1037 pid 3367 in 43ms
10-29 06:10:06.021 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.022 3003 3330 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div4.hw-based) in [email protected] process
10-29 06:10:06.023 3003 3330 E OMXNodeInstance: getParameter(0xebe9b404:Freescale.std._decoder.div4.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.023 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.024 3003 3330 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.024 3003 3330 E OMXNodeInstance: setParameter(0xebe9b404:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.024 3003 3330 E OMXNodeInstance: setParameter(0xebe9b404:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.024 3003 3330 W OMXNodeInstance: [0xebe9b404:Freescale.std._decoder.div4.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.024 3003 3330 E OMXNodeInstance: getExtensionIndex(0xebe9b404:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.026 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.026 3003 3330 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.divx.hw-based) in [email protected] process
10-29 06:10:06.027 3003 3330 E OMXNodeInstance: getParameter(0xebe9b404:Freescale.std._decoder.divx.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.028 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.028 3003 3330 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.028 3003 3330 E OMXNodeInstance: setParameter(0xebe9b404:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.028 3003 3330 E OMXNodeInstance: setParameter(0xebe9b404:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.028 3003 3330 W OMXNodeInstance: [0xebe9b404:Freescale.std._decoder.divx.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.028 3003 3330 E OMXNodeInstance: getExtensionIndex(0xebe9b404:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.031 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.031 3003 3065 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in [email protected] process
10-29 06:10:06.032 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.033 3003 3065 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.033 3003 3065 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.033 3003 3065 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.033 3003 3065 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.033 3003 3065 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.038 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.038 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.h263.decoder) in [email protected] process
10-29 06:10:06.043 3003 3065 E OMXNodeInstance: getExtensionIndex(0xec2a8140:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.043 3003 3065 E OMXNodeInstance: getExtensionIndex(0xec2a8140:google.h263.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.045 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.045 3003 3065 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based) in [email protected] process
10-29 06:10:06.047 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.048 3003 3065 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.048 3003 3065 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.048 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.048 3003 3330 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.hevc.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.048 3003 3330 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.050 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.051 3003 3330 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based.secure) in [email protected] process
10-29 06:10:06.052 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.053 3003 3330 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.053 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.053 3003 3330 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.053 3003 3330 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.hevc.hw-based.secure] component does not support metadata mode; using fallback
10-29 06:10:06.053 3003 3330 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.hevc.hw-based.secure, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.054 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.055 3003 3330 I OMXMaster: makeComponentInstance(OMX.google.hevc.decoder) in [email protected] process
10-29 06:10:06.064 3003 3319 E OMXNodeInstance: getExtensionIndex(0xec2a7cc0:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.065 3003 3319 E OMXNodeInstance: getExtensionIndex(0xec2a7cc0:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.071 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.071 3003 3319 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in [email protected] process
10-29 06:10:06.072 3003 3319 E OMXNodeInstance: getParameter(0xeb890a04:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.073 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.073 3003 3319 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.073 3003 3319 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.073 3003 3319 E OMXNodeInstance: setParameter(0xeb890a04:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.073 3003 3319 W OMXNodeInstance: [0xeb890a04:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.073 3003 3319 E OMXNodeInstance: getExtensionIndex(0xeb890a04:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.075 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.075 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in [email protected] process
10-29 06:10:06.077 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.077 3003 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.077 3003 3064 E OMXNodeInstance: setParameter(0xebe9ac84:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.078 3003 3330 E OMXNodeInstance: setParameter(0xebe9ac84:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.078 3003 3330 W OMXNodeInstance: [0xebe9ac84:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.078 3003 3319 E OMXNodeInstance: getExtensionIndex(0xebe9ac84:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.080 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.080 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in [email protected] process
10-29 06:10:06.084 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.085 3003 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.085 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.085 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.086 3003 3064 W OMXNodeInstance: [0xebe9af04:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.086 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe9af04:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.086 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000010
10-29 06:10:06.087 3121 3121 I ActivityManager: Loaded persisted task ids for user 0
10-29 06:10:06.089 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.089 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.decoder) in [email protected] process
10-29 06:10:06.091 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe91120:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.092 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe91120:google.mpeg4.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.094 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.094 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.hw-based) in [email protected] process
10-29 06:10:06.095 3003 3064 E OMXNodeInstance: getParameter(0xebe9af04:Freescale.std._decoder.sorenson.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.096 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.096 3003 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.096 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.096 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.096 3003 3064 W OMXNodeInstance: [0xebe9af04:Freescale.std._decoder.sorenson.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.097 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe9af04:Freescale.std._decoder.sorenson.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.098 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.099 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.vp8.hw-based) in [email protected] process
10-29 06:10:06.101 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.101 3003 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.102 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.102 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.102 3003 3064 W OMXNodeInstance: [0xebe9af04:Freescale.std._decoder.vp8.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.102 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe9af04:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.104 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.104 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.vp8.decoder) in [email protected] process
10-29 06:10:06.111 3003 3319 E OMXNodeInstance: getExtensionIndex(0xebe91300:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.112 3003 3319 E OMXNodeInstance: getExtensionIndex(0xebe91300:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.114 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.115 3003 3319 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.vp9.hw-based) in [email protected] process
10-29 06:10:06.117 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.117 3003 3319 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.117 3003 3319 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.117 3003 3319 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.118 3003 3319 W OMXNodeInstance: [0xebe9af04:Freescale.std._decoder.vp9.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.118 3003 3319 E OMXNodeInstance: getExtensionIndex(0xebe9af04:Freescale.std._decoder.vp9.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.120 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.120 3003 3319 I OMXMaster: makeComponentInstance(OMX.google.vp9.decoder) in [email protected] process
10-29 06:10:06.122 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe91180:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.122 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe91180:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.124 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.124 3003 3064 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.xvid.hw-based) in [email protected] process
10-29 06:10:06.125 3003 3064 E OMXNodeInstance: getParameter(0xebe9af04:Freescale.std._decoder.xvid.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.126 2990 3069 W OMXUtils: do not know color format 0x7f000003 = 2130706435
10-29 06:10:06.126 3003 3064 E OMXFSLPlugin: Failed to make GMDecoder Wrapper.
10-29 06:10:06.126 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
10-29 06:10:06.126 3003 3064 E OMXNodeInstance: setParameter(0xebe9af04:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.allocateNativeHandle(0x7f00004b): Output:1 en=0) ERROR: UnsupportedIndex(0x8000101a)
10-29 06:10:06.126 3003 3064 W OMXNodeInstance: [0xebe9af04:Freescale.std._decoder.xvid.hw-based] component does not support metadata mode; using fallback
10-29 06:10:06.127 3003 3064 E OMXNodeInstance: getExtensionIndex(0xebe9af04:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.prepareForAdaptivePlayback) ERROR: NotImplemented(0x80001006)
10-29 06:10:06.129 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.129 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.h264.encoder) in [email protected] process
10-29 06:10:06.135 2990 3069 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:10:06.137 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.137 3003 3319 I OMXMaster: makeComponentInstance(OMX.google.h263.encoder) in [email protected] process
10-29 06:10:06.141 3003 3319 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
10-29 06:10:06.142 2990 3069 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:10:06.143 3003 3064 E OMXNodeInstance: getConfig(0xec2a7c60:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:10:06.144 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.145 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.encoder) in [email protected] process
10-29 06:10:06.145 3003 3064 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
10-29 06:10:06.147 2990 3069 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:10:06.147 3003 3064 E OMXNodeInstance: getConfig(0xec2a7c60:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:10:06.149 2990 3069 I OMXClient: IOmx service obtained
10-29 06:10:06.149 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.vp8.encoder) in [email protected] process
10-29 06:10:06.159 3121 3121 W system_server: Framework Matrix: Ignore file /system/etc/vintf/manifest.xml:
10-29 06:10:06.161 2990 3069 W OMXUtils: do not know color format 0x7f000789 = 2130708361
10-29 06:10:06.162 3003 3319 E OMXNodeInstance: getConfig(0xec2a7c60:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
10-29 06:10:06.163 2990 3069 D MediaCodecList: ignored a null builder
10-29 06:10:06.168 3121 3307 I OMXClient: IOmx service obtained
10-29 06:10:06.169 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.171 3003 3319 E OMXNodeInstance: getConfig(0xebe91420:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.173 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.195 2963 2963 I chatty : uid=1000(system) [email protected] identical 10 lines
10-29 06:10:06.195 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.209 3121 3121 D SystemServerTiming: ActivityManagerStartApps took to complete: 219ms
10-29 06:10:06.209 3121 3121 D SystemServerTiming: PhaseActivityManagerReady took to complete: 897ms
10-29 06:10:06.210 3121 3137 W system_server: Long monitor contention with owner main (3121) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=0 in void com.android.server.am.ActivityManagerService.dispatchUidsChanged() for 216ms
10-29 06:10:06.210 3121 3137 W Looper : Slow dispatch took 218ms android.ui h=com.android.server.am.ActivityManagerService$UiHandler c=null m=53
10-29 06:10:06.211 3121 3138 W ActivityManager: Slow operation: 218ms so far, now at startProcess: asking zygote to start proc
10-29 06:10:06.211 3121 3121 D SystemServerInitThreadPool: Shutdown successful
10-29 06:10:06.211 3121 3121 D SystemServerTiming: StartServices took to complete: 2713ms
10-29 06:10:06.212 3121 3261 W system_server: Long monitor contention with owner main (3121) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=2 in void com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread, java.util.List) for 209ms
10-29 06:10:06.212 3121 3136 W system_server: Long monitor contention with owner main (3121) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=4 in void com.android.server.am.TaskChangeNotificationController.forAllRemoteListeners(com.android.server.am.TaskChangeNotificationController$TaskStackConsumer, android.os.Message) for 124ms
10-29 06:10:06.213 3121 3121 W Looper : Slow delivery took 1849ms main h=android.os.Handler c=com.android.server.-$$Lambda$BatteryService$2x73lvpB0jctMSVP4qb9sHAqRPw@d13ce3c m=0
10-29 06:10:06.215 3282 3282 W AlarmManager: Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@46f27c4
10-29 06:10:06.223 3475 3475 W main : type=1400 audit(0.0:2417): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:06.223 3475 3475 W main : type=1400 audit(0.0:2418): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:06.223 3475 3475 I chatty : uid=1001(radio) com.android.phone identical 1 line
10-29 06:10:06.223 3475 3475 W main : type=1400 audit(0.0:2420): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:06.233 3121 3138 W ActivityManager: Slow operation: 240ms so far, now at startProcess: returned from zygote!
10-29 06:10:06.250 3121 3477 I OMXClient: IOmx service obtained
10-29 06:10:06.250 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.257 3259 3259 I LatinIME: Hardware accelerated drawing: true
10-29 06:10:06.258 3003 3064 E OMXNodeInstance: getConfig(0xec2a8080:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.263 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.264 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:10:06.264 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.266 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.267 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:10:06.267 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.293 2976 3083 E display : threadLoop invalid uevent change@/devices/platform/usb@38100000/38100000.dwc3/udc/38100000.dwc3
10-29 06:10:06.295 2984 3385 I [email protected]: GADGET pulled up
10-29 06:10:06.295 2984 2984 I [email protected]: monitorFfs signalled true
10-29 06:10:06.295 2984 2984 I [email protected]: Usb Gadget setcurrent functions called successfully
10-29 06:10:06.296 3121 3177 E UsbDeviceManager: notifyCurrentFunction request:1 status:0
10-29 06:10:06.296 3121 3142 E UsbDeviceManager: prcessing MSG_GET_CURRENT_USB_FUNCTIONS
10-29 06:10:06.296 3121 3142 E UsbDeviceManager: updating mCurrentFunctions
10-29 06:10:06.296 3121 3142 E UsbDeviceManager: mCurrentFunctions:0applied:1
10-29 06:10:06.311 3121 3497 I OMXClient: IOmx service obtained
10-29 06:10:06.311 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.313 3003 3065 E OMXNodeInstance: getConfig(0xec2a8200:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.315 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.318 3121 3138 W ActivityManager: Slow operation: 325ms so far, now at startProcess: done updating battery stats
10-29 06:10:06.318 3121 3138 W ActivityManager: Slow operation: 325ms so far, now at startProcess: building log message
10-29 06:10:06.318 3121 3138 I ActivityManager: Start proc 3475:com.android.phone/1001 for added application com.android.phone
10-29 06:10:06.318 3121 3138 W ActivityManager: Slow operation: 325ms so far, now at startProcess: starting to update pids map
10-29 06:10:06.318 3121 3138 W ActivityManager: Slow operation: 325ms so far, now at startProcess: done updating pids map
10-29 06:10:06.318 3121 3138 W ActivityManager: Slow operation: 225ms so far, now at startProcess: asking zygote to start proc
10-29 06:10:06.319 2963 2963 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:10:06.320 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.324 3121 3121 W Looper : Slow dispatch took 108ms main h=android.service.notification.ConditionProviderService$H c=null m=1
10-29 06:10:06.324 3121 3121 D ConditionProviders.SCP: onConnected
10-29 06:10:06.325 3121 3121 D ConditionProviders: Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
10-29 06:10:06.325 3121 3121 D ConditionProviders: Subscribing to condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
10-29 06:10:06.337 3121 3138 W ActivityManager: Slow operation: 244ms so far, now at startProcess: returned from zygote!
10-29 06:10:06.338 3121 3138 W ActivityManager: Slow operation: 245ms so far, now at startProcess: done updating battery stats
10-29 06:10:06.338 3121 3138 W ActivityManager: Slow operation: 245ms so far, now at startProcess: building log message
10-29 06:10:06.338 3121 3138 I ActivityManager: Start proc 3500:com.android.settings/1000 for activity com.android.settings/.FallbackHome
10-29 06:10:06.338 3121 3138 W ActivityManager: Slow operation: 245ms so far, now at startProcess: starting to update pids map
10-29 06:10:06.338 3121 3138 W ActivityManager: Slow operation: 245ms so far, now at startProcess: done updating pids map
10-29 06:10:06.339 3500 3500 W main : type=1400 audit(0.0:2421): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:06.339 2998 3474 V MediaExtractorUpdateService: loadPlugins /vendor/app/ExtractorPkg/ExtractorPkg.apk
10-29 06:10:06.341 2998 3474 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/.) Is a directory
10-29 06:10:06.343 2998 3474 E linker : library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
10-29 06:10:06.343 2998 3474 W MediaExtractorFactory: couldn't dlopen(/system/lib64/extractors/..) Is a directory
10-29 06:10:06.343 3475 3475 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:10:06.344 2998 3474 E MediaExtractorFactory: couldn't opendir(/vendor/lib64/extractors)
10-29 06:10:06.379 3282 3282 V SystemUIService: Starting SystemUI services for user 0.
10-29 06:10:06.391 3121 3210 I WifiScanningService: wifi driver unloaded
10-29 06:10:06.392 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.Dependency took to complete: 13ms
10-29 06:10:06.397 3121 3121 V SettingsProvider: Notifying for 0: content://settings/secure/location_providers_allowed
10-29 06:10:06.398 3121 3121 V SettingsProvider: Notifying for 0: content://settings/global/location_global_kill_switch
10-29 06:10:06.400 3121 3210 I WifiScanningService: wifi driver unloaded
10-29 06:10:06.410 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.util.NotificationChannels took to complete: 16ms
10-29 06:10:06.410 3259 3259 W InputAttributes: No editor info for this field. Bug?
10-29 06:10:06.412 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.statusbar.CommandQueue$CommandQueueStart took to complete: 2ms
10-29 06:10:06.414 2998 3474 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.419 3282 3282 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:06.423 3121 3508 I OMXClient: IOmx service obtained
10-29 06:10:06.424 3003 3064 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.425 3282 3282 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:06.425 3003 3064 E OMXNodeInstance: getConfig(0xec2a8200:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.427 3475 3475 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:10:06.427 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.432 2963 2963 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:10:06.432 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.437 3259 3509 I LatinIME:LogUtils: Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1572329406 ; date = ?
10-29 06:10:06.440 3259 3509 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 1572329406 ; date = ?
10-29 06:10:06.447 3259 3509 E ActivityThread: Failed to find provider info for user_dictionary
10-29 06:10:06.505 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:06.505 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.515 3121 3522 I OMXClient: IOmx service obtained
10-29 06:10:06.515 3003 3319 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.517 3500 3500 I ndroid.setting: The ClassLoaderContext is a special shared library.
10-29 06:10:06.517 3003 3319 E OMXNodeInstance: getConfig(0xec2a8200:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.519 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.522 2963 2963 I chatty : uid=1000(system) [email protected] identical 4 lines
10-29 06:10:06.523 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.523 3282 3282 W SoundPool: Use of stream types is deprecated for operations other than volume control
10-29 06:10:06.523 3282 3282 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
10-29 06:10:06.524 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.530 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.keyguard.KeyguardViewMediator took to complete: 118ms
10-29 06:10:06.532 3121 3121 W Looper : Slow dispatch took 133ms main h=android.app.ActivityThread$H c=null m=114
10-29 06:10:06.533 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.548 2976 3083 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:10:06.549 3282 3527 I OMXClient: IOmx service obtained
10-29 06:10:06.550 3003 3065 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.552 3121 3142 D UsbDeviceManager: push notification:Charging this device via USB
10-29 06:10:06.553 3003 3319 E OMXNodeInstance: getConfig(0xec2a82c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.555 3121 3121 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:10:06.557 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.560 3500 3500 I ndroid.setting: The ClassLoaderContext is a special shared library.
10-29 06:10:06.567 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.567 2963 2963 I chatty : uid=1000(system) [email protected] identical 1 line
10-29 06:10:06.568 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.568 3475 3475 I m.android.phon: The ClassLoaderContext is a special shared library.
10-29 06:10:06.569 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.570 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:10:06.571 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.575 3121 3532 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
10-29 06:10:06.579 3282 3282 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:06.580 3121 3121 I Telecom : SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@6a7be51: TS.init@AAA
10-29 06:10:06.592 3259 3509 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
10-29 06:10:06.595 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.596 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:10:06.596 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.602 2976 3083 E display : threadLoop invalid uevent change@/devices/virtual/android_usb/android0
10-29 06:10:06.611 3121 3536 I Telecom : Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentSpeakerRoute
10-29 06:10:06.611 3121 3536 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
10-29 06:10:06.614 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.618 3121 3541 I Telecom : CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
10-29 06:10:06.621 3121 3121 I Telecom : MissedCallNotifierImpl: reloadFromDatabase: Boot not yet complete -- call log db may not be available. Deferring loading until boot complete for user 0: TS.init@AAA
10-29 06:10:06.624 3475 3475 D TelephonyProvider: dbh.onOpen: ok, queried table=siminfo
10-29 06:10:06.624 3121 3121 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:10:06.624 3475 3475 D TelephonyProvider: dbh.onOpen: ok, queried table=carriers
10-29 06:10:06.634 3475 3475 D CarrierIdProvider: onCreate
10-29 06:10:06.635 3121 3543 I OMXClient: IOmx service obtained
10-29 06:10:06.635 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.638 3003 3003 E OMXNodeInstance: getConfig(0xebe91000:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.639 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.640 3121 3121 I Telecom : Class: TelecomSystem.INSTANCE being set
10-29 06:10:06.641 3121 3121 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:197 com.android.server.telecom.components.TelecomService.onBind:67 android.app.ActivityThread.handleBindService:3597
10-29 06:10:06.642 3121 3121 W Looper : Slow dispatch took 111ms main h=android.app.ActivityThread$H c=null m=121
10-29 06:10:06.643 3121 3121 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 com.android.server.content.SyncManager$14.run:756 android.os.Handler.handleCallback:873 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:193
10-29 06:10:06.643 2963 2963 I chatty : uid=1000(system) [email protected] identical 6 lines
10-29 06:10:06.644 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.646 3121 3121 D BluetoothManagerService: Bluetooth Adapter name changed to iMX8
10-29 06:10:06.646 3121 3121 D BluetoothManagerService: Stored Bluetooth name: iMX8
10-29 06:10:06.647 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.648 2996 3183 D installd: Found quota mount /dev/block/by-name/userdata at /data
10-29 06:10:06.648 2996 3183 D installd: Found storage mount /data/media at /mnt/runtime/default/emulated
10-29 06:10:06.649 3121 3121 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
10-29 06:10:06.650 3121 3143 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
10-29 06:10:06.650 3121 3121 V SettingsProvider: Notifying for 0: content://settings/global/boot_count
10-29 06:10:06.650 3121 3143 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
10-29 06:10:06.652 3121 3143 D BluetoothManagerService: Stored Bluetooth name: iMX8
10-29 06:10:06.652 3121 3143 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@52db381 mBinding = false mUnbinding = false
10-29 06:10:06.654 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.655 3475 3475 D CarrierIdProvider: update database from pb file
10-29 06:10:06.655 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.655 2963 2963 I chatty : uid=1000(system) [email protected] identical 1 line
10-29 06:10:06.656 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.657 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:06.664 3241 3241 D BluetoothAdapterService: onUnbind() - calling cleanup
10-29 06:10:06.665 3241 3241 D BluetoothAdapterService: cleanup()
10-29 06:10:06.669 3241 3241 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
10-29 06:10:06.670 3241 3241 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
10-29 06:10:06.670 3241 3241 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
10-29 06:10:06.670 3121 3121 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:10:06.671 3241 3302 I bt_stack_manager: event_clean_up_stack is cleaning up the stack
10-29 06:10:06.671 3241 3302 I bt_btif_core: btif_cleanup_bluetooth entered
10-29 06:10:06.671 3241 3302 E bt_btif : do_in_bta_thread: MessageLooper not initialized
10-29 06:10:06.671 3241 3302 E BluetoothServiceJni: Callback: 'callback_thread_event' is not called on the correct thread
10-29 06:10:06.672 3241 3302 I bt_btif_queue: btif_queue_release
10-29 06:10:06.672 3241 3308 I bt_btif_core: run_message_loop finished
10-29 06:10:06.672 3241 3308 W bt_osi_thread: run_thread: thread id 3308, thread name bt_jni_workqueue exited
10-29 06:10:06.672 3241 3302 I bt_core_module: module_clean_up Cleaning up module "stack_config_module"
10-29 06:10:06.672 3241 3302 I bt_core_module: module_clean_up Cleanup of module "stack_config_module" completed
10-29 06:10:06.673 3241 3302 I bt_core_module: module_clean_up Cleaning up module "interop_module"
10-29 06:10:06.673 3241 3302 I bt_core_module: module_clean_up Cleanup of module "interop_module" completed
10-29 06:10:06.673 3241 3302 I bt_btif_core: btif_cleanup_bluetooth finished
10-29 06:10:06.673 3241 3302 I bt_core_module: module_clean_up Cleaning up module "btif_config_module"
10-29 06:10:06.674 3121 3133 W ActivityManager: Unable to start service Intent { act=android.intent.action.QUICKSTEP_SERVICE pkg=com.android.launcher3 } U=0: not found
10-29 06:10:06.674 3282 3282 W OverviewProxyService: Failed to connect on attempt 1 will try again in 5000ms
10-29 06:10:06.677 3282 3552 I OMXClient: IOmx service obtained
10-29 06:10:06.677 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.679 3003 3330 E OMXNodeInstance: getConfig(0xebe91000:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.681 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.683 2963 2963 I chatty : uid=1000(system) [email protected] identical 3 lines
10-29 06:10:06.685 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.686 3475 3475 E CarrierIdProvider: read carrier list from ota pb failure: java.io.FileNotFoundException: /data/misc/carrierid/carrier_list.pb (No such file or directory)
10-29 06:10:06.686 3475 3475 D CarrierIdProvider: latest version: 4 need update: false
10-29 06:10:06.686 3241 3302 I bt_core_module: module_clean_up Cleanup of module "btif_config_module" completed
10-29 06:10:06.686 3241 3302 I bt_core_module: module_clean_up Cleaning up module "bt_utils_module"
10-29 06:10:06.686 3241 3302 I bt_core_module: module_clean_up Cleanup of module "bt_utils_module" completed
10-29 06:10:06.686 3241 3302 I bt_core_module: module_clean_up Cleaning up module "osi_module"
10-29 06:10:06.686 3241 3306 D bt_osi_alarm: callback_dispatch Callback thread exited
10-29 06:10:06.686 3241 3306 W bt_osi_thread: run_thread: thread id 3306, thread name alarm_dispatcher exited
10-29 06:10:06.687 3241 3305 W bt_osi_thread: run_thread: thread id 3305, thread name alarm_default_ca exited
10-29 06:10:06.687 3241 3302 I bt_core_module: module_clean_up Cleanup of module "osi_module" completed
10-29 06:10:06.687 3241 3302 I bt_stack_manager: event_clean_up_stack finished
10-29 06:10:06.687 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.687 3241 3241 I BluetoothServiceJni: cleanupNative: return from cleanup
10-29 06:10:06.688 3475 3475 D CarrierProvider: onCreate
10-29 06:10:06.688 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.690 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.690 3241 3241 D BluetoothActiveDeviceManager: cleanup()
10-29 06:10:06.691 3241 3241 D BluetoothAdapterService: onDestroy()
10-29 06:10:06.694 3241 3241 I BluetoothAdapterService: Force exit to cleanup internal state in Bluetooth stack
10-29 06:10:06.703 3475 3475 I ImsResolver: ImsResolver initialized with static binding.
10-29 06:10:06.704 3475 3475 I ImsResolver: Initializing cache and binding.
10-29 06:10:06.710 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.711 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:10:06.711 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.718 3500 3500 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:06.722 3241 3241 I droid.bluetoot: System.exit called, status: 0
10-29 06:10:06.722 3241 3241 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
10-29 06:10:06.725 3121 3281 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/ee4ba3c9-597c-43e7-8546-fba3bb0473f5 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
10-29 06:10:06.725 3121 3281 D WebViewZygote: Preloading package /system/app/webview/webview.apk /system/app/webview/lib/arm:/system/app/webview/webview.apk!/lib/armeabi-v7a
10-29 06:10:06.729 3121 3121 V WiredAccessoryManager: init()
10-29 06:10:06.732 3121 3121 V WiredAccessoryManager: state_cable 16
10-29 06:10:06.732 3500 3560 E libEGL : error mmaping cache file: Invalid argument (22)
10-29 06:10:06.733 3121 3121 V WiredAccessoryManager: newName=extcon0 newState=16 headsetState=16 prev headsetState=0
10-29 06:10:06.734 3121 3121 I WiredAccessoryManager: MSG_NEW_DEVICE_STATE
10-29 06:10:06.735 3121 3121 W WiredAccessoryManager: /sys/class/extcon/extcon1/state not found while attempting to determine initial switch state
10-29 06:10:06.736 3121 3281 I Zygote : Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/ee4ba3c9-597c-43e7-8546-fba3bb0473f5 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
10-29 06:10:06.748 3351 3351 I WebViewZygoteInit: Beginning package preload
10-29 06:10:06.759 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:10:06.777 3121 3121 D AccessibilityManagerService: Ignoring non-encryption-aware service ComponentInfo{com.koushikdutta.vysor/com.koushikdutta.vysor.AudioEnablerService}
10-29 06:10:06.780 3500 3560 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:06.780 3500 3560 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:06.780 3500 3560 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:10:06.780 3500 3560 D OpenGLRenderer: Swap behavior 2
10-29 06:10:06.781 3121 3121 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
10-29 06:10:06.781 3121 3121 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:10:06.788 3121 3121 W ActivityManager: Unable to start service Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener } U=0: not found
10-29 06:10:06.788 3121 3121 W NotificationListeners: Unable to bind notification listener service: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:10:06.789 3121 3121 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:10:06.789 3121 3121 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
10-29 06:10:06.792 3282 3568 I OMXClient: IOmx service obtained
10-29 06:10:06.793 3003 3003 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:10:06.795 3003 3003 E OMXNodeInstance: getConfig(0xec2a7b40:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:10:06.800 3351 3351 I webview_zygote: The ClassLoaderContext is a special shared library.
10-29 06:10:06.801 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.recents.Recents took to complete: 271ms
10-29 06:10:06.803 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.806 3500 3560 I display : open gpu gralloc module!
10-29 06:10:06.806 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.807 3121 3132 I ActivityManager: Process com.android.bluetooth (pid 3241) has died: fore SVC
10-29 06:10:06.808 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.809 3121 3139 W libprocessgroup: kill(-3241, 9) failed: No such process
10-29 06:10:06.809 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 3241 in 0ms
10-29 06:10:06.810 2955 2955 I Zygote : Process 3241 exited cleanly (0)
10-29 06:10:06.812 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.814 2963 2963 I chatty : uid=1000(system) [email protected] identical 1 line
10-29 06:10:06.815 3121 3138 I ActivityManager: Start proc 3572:android.ext.services/u0a25 for service android.ext.services/.notification.Assistant
10-29 06:10:06.816 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.816 2965 3091 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:10:06.817 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.817 2965 3091 W DeviceHAL: Error from HAL Device in function set_mic_mute: Function not implemented
10-29 06:10:06.819 3282 3282 I vol.Events: writeEvent collection_started
10-29 06:10:06.828 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.829 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.849 3121 3144 I ActivityManager: Displayed com.android.settings/.FallbackHome: +753ms
10-29 06:10:06.850 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:10:06.854 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.854 3121 3121 D ConditionProviders.SCP: onSubscribe condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true
10-29 06:10:06.855 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:10:06.855 3121 3121 D ConditionProviders.SCP: setRegistered true
10-29 06:10:06.859 3282 3579 I vol.Events: writeEvent external_ringer_mode_changed normal
10-29 06:10:06.859 3282 3579 I vol.Events: writeEvent internal_ringer_mode_changed normal
10-29 06:10:06.863 3121 3121 D ConditionProviders.SCP: evaluateSubscriptionLocked cal=ScheduleCalendar[mDays={1, 2, 3, 4, 5, 6, 7}, mSchedule=ScheduleInfo{days=[1, 2, 3, 4, 5, 6, 7], startHour=22, startMinute=0, endHour=7, endMinute=0, exitAtAlarm=true, nextAlarm=Thu Jan 01 00:00:00 GMT 1970 (0)}], now=Tue Oct 29 06:10:06 GMT 2019 (1572329406855), nextUserAlarmTime=Thu Jan 01 00:00:00 GMT 1970 (0)
10-29 06:10:06.864 3121 3136 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
10-29 06:10:06.864 3121 3121 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true STATE_TRUE reason=meetsSchedule
10-29 06:10:06.873 3121 3121 D ConditionProviders.SCP: Scheduling evaluate for Tue Oct 29 07:00:00 GMT 2019 (1572332400000), in +49m53s145ms, now=Tue Oct 29 06:10:06 GMT 2019 (1572329406855)
10-29 06:10:06.876 3121 3309 W UsageStatsService: Event reported without a package name
10-29 06:10:06.881 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:10:06.893 3121 3121 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
10-29 06:10:06.895 3351 3351 I WebViewZygoteInit: Package preload done
10-29 06:10:06.896 3121 3121 D MediaSessionService: Global priority session is changed from null to com.android.server.telecom/HeadsetMediaButton (userId=0)
10-29 06:10:06.903 3121 3132 I DefaultPermGrantPolicy: Revoking permissions from disabled data services for user:0
10-29 06:10:06.903 3121 3218 E ActivityThread: Failed to find provider info for com.android.calendar
10-29 06:10:06.905 3121 3238 I SyncManager: Got SyncJobService instance.
10-29 06:10:06.906 3121 3132 I DefaultPermGrantPolicy: Granting permissions to enabled data services for user:0
10-29 06:10:06.908 3121 3121 V WiredAccessoryManager: headsetName: connected
10-29 06:10:06.908 3121 3218 E ActivityThread: Failed to find provider info for com.android.calendar
10-29 06:10:06.909 3572 3572 I id.ext.service: The ClassLoaderContext is a special shared library.
10-29 06:10:06.910 3121 3121 D AutofillManagerService: Autofill restriction did not change for user 0
10-29 06:10:06.911 2965 3091 D audio_hw_primary: adev_set_parameters: enter: connect=1024
10-29 06:10:06.911 2965 3091 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:10:06.912 2988 3289 I AudioFlinger: openOutput() this 0xf443e000, module 10 Device 0x400, SamplingRate 0, Format 00000000, Channels 0, flags 0x1
10-29 06:10:06.912 2965 2965 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(0) channel_mask(0) format(0) devices(0x400) flags(0x1), address()
10-29 06:10:06.912 2965 2965 W audio_hw_primary: adev_open_output_stream() HDMI multichannel
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_channel_masks() card 3 got 2 sup channels
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 32000 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 44100 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 48000 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 88200 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 96000 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 176400 sup rates
10-29 06:10:06.912 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 192000 sup rates
10-29 06:10:06.912 2965 2965 I audio_hw_primary: adev_open_output_stream: exit: output_type 2, output 0xe95d1500
10-29 06:10:06.920 2988 3289 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 192 frames
10-29 06:10:06.922 3121 3121 I FusedLocation: engine started (com.android.location.fused)
10-29 06:10:06.922 3121 3121 W Looper : Drained
10-29 06:10:06.926 2965 2965 W audio_hw_primary: out get parameters query format=1;sup_channels=, reply sup_channels=AUDIO_CHANNEL_OUT_STEREO
10-29 06:10:06.927 2988 3602 I AudioFlinger: AudioFlinger's thread 0xf3c47000 tid=3602 ready to run
10-29 06:10:06.928 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: closing=true
10-29 06:10:06.929 2965 2965 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:06.929 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: exiting=1
10-29 06:10:06.930 2965 2965 W audio_hw_primary: adev_close_output_stream...0xe95d1500
10-29 06:10:06.930 2988 3289 I AudioFlinger: openOutput() this 0xf443e000, module 10 Device 0x400, SamplingRate 32000, Format 0x000001, Channels 0x3, flags 0x1
10-29 06:10:06.930 2965 2965 I audio_hw_primary: adev_open_output_stream: enter: sample_rate(32000) channel_mask(0x3) format(0x1) devices(0x400) flags(0x1), address()
10-29 06:10:06.930 2965 2965 W audio_hw_primary: adev_open_output_stream() HDMI multichannel
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_channel_masks() card 3 got 2 sup channels
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 32000 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 44100 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 48000 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 88200 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 96000 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 176400 sup rates
10-29 06:10:06.930 2965 2965 W audio_hw_primary: out_read_hdmi_rates() card 3 got 192000 sup rates
10-29 06:10:06.931 2965 2965 I audio_hw_primary: adev_open_output_stream: exit: output_type 2, output 0xe95d1500
10-29 06:10:06.931 2988 3289 I AudioFlinger: HAL output buffer size 192 frames, normal sink buffer size 192 frames
10-29 06:10:06.932 2988 3603 I AudioFlinger: AudioFlinger's thread 0xf3c47000 tid=3603 ready to run
10-29 06:10:06.933 3121 3131 I system_server: Background concurrent copying GC freed 33892(3MB) AllocSpace objects, 28(776KB) LOS objects, 42% free, 5MB/10MB, paused 164us total 418.319ms
10-29 06:10:06.943 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: closing=true
10-29 06:10:06.943 2965 2965 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:06.944 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: exiting=1
10-29 06:10:06.944 2965 2965 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:06.944 2965 2965 W audio_hw_primary: adev_close_output_stream...0xe95d1500
10-29 06:10:06.945 2965 3091 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=0
10-29 06:10:06.945 2965 3091 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:06.948 3121 3121 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
10-29 06:10:06.948 3121 3121 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:06.949 3121 3121 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAI
10-29 06:10:06.951 3572 3604 D ExtAssistant: File doesn't exist or isn't readable yet
10-29 06:10:06.960 3282 3579 I vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
10-29 06:10:06.961 3282 3579 I vol.Events: writeEvent level_changed STREAM_SYSTEM 5
10-29 06:10:06.963 3282 3579 I vol.Events: writeEvent level_changed STREAM_MUSIC 5
10-29 06:10:06.965 3121 3216 D NotificationSQLiteLog: Pruned event entries: 0
10-29 06:10:06.966 3282 3579 I vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
10-29 06:10:06.991 2995 2995 D incidentd: Start uploading backlogs in /data/misc/incidents/
10-29 06:10:06.992 2995 2995 D incidentd: Successfully uploaded 0 files to Dropbox.
10-29 06:10:06.995 3282 3579 I vol.Events: writeEvent level_changed STREAM_RING 5
10-29 06:10:06.997 3282 3579 I vol.Events: writeEvent level_changed STREAM_ALARM 6
10-29 06:10:07.001 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.volume.VolumeUI took to complete: 199ms
10-29 06:10:07.004 3282 3579 I vol.Events: writeEvent zen_mode_config_changed [disallowAlarms=false disallowMedia=false disallowSystem=true disallowRinger=false]
10-29 06:10:07.006 3475 3475 D PhoneSwitcherNetworkRequstListener: Registering NetworkFactory
10-29 06:10:07.007 3121 3212 D ConnectivityService: Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
10-29 06:10:07.013 3121 3212 D ConnectivityService: Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
10-29 06:10:07.021 3282 3608 E libEGL : error mmaping cache file: Invalid argument (22)
10-29 06:10:07.024 3475 3609 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:10:07.025 3475 3609 W CallerInfoCache: cursor is null
10-29 06:10:07.030 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.stackdivider.Divider took to complete: 29ms
10-29 06:10:07.030 3475 3475 D CarrierConfigLoader: CarrierConfigLoader has started
10-29 06:10:07.034 3121 3132 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
10-29 06:10:07.045 3475 3475 I TelecomFramework: TtyManager: updateUiTtyMode -1 -> 0
10-29 06:10:07.052 3475 3475 D ImsResolver: maybeAddedImsService, packageName: null
10-29 06:10:07.052 3475 3475 I ImsResolver: Adding newly added ImsService to cache: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:10:07.054 3475 3475 I ImsResolver: Binding ImsService: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver} with features: [{s=0, f=0}, {s=0, f=1}]
10-29 06:10:07.054 3475 3475 I ImsServiceController: Granting Runtime permissions to:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:10:07.055 3121 3571 I DefaultPermGrantPolicy: Granting permissions to enabled ImsServices for user:0
10-29 06:10:07.055 3475 3475 I ImsServiceController: Binding ImsService:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
10-29 06:10:07.057 3121 3571 I WifiService: getWifiServiceMessenger uid=10031
10-29 06:10:07.060 3121 3132 D ConnectivityService: requestNetwork for uid/pid:10031/3282 NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ]
10-29 06:10:07.061 3121 3234 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:10:07.066 3121 3204 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:07.067 3121 3204 W BestClock: java.time.DateTimeException: Missing NTP fix
10-29 06:10:07.070 3475 3475 D ServiceStateProvider: subId=-2
10-29 06:10:07.072 3121 3132 I WifiService: WifiService trying to set country code to
10-29 06:10:07.072 3121 3132 I WifiService: setCountryCode uid=1001
10-29 06:10:07.078 3475 3475 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:07.078 3475 3475 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:10:07.078 3475 3475 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:07.078 3475 3475 D TelephonyDebugService: TelephonyDebugService()
10-29 06:10:07.080 3475 3475 D CarrierConfigLoader: mHandler: 12 phoneId: 0
10-29 06:10:07.080 3475 3475 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:10:07.083 3475 3475 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
10-29 06:10:07.089 3475 3475 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:07.092 3121 3309 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAY
10-29 06:10:07.092 3475 3475 I TelecomFramework: AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub Audio Routes: BESW Schemes: tel voicemail Extras: Bundle[{android.telecom.extra.SUPPORTS_VIDEO_CALLING_FALLBACK=true}] GroupId: ***] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0}
10-29 06:10:07.093 3475 3475 I TelecomFramework: PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {8cba923}
10-29 06:10:07.098 3475 3475 I TelecomFramework: PstnPhoneCapabilitiesNotifier: handleVideoCapabilitesChanged. Video capability - false
10-29 06:10:07.099 3475 3475 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
10-29 06:10:07.106 3121 3309 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAk
10-29 06:10:07.138 3121 3309 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
10-29 06:10:07.138 3121 3309 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
10-29 06:10:07.144 3282 3282 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:10:07.146 3121 3309 I StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@9cc7aa2
10-29 06:10:07.273 3282 3282 I CameraManagerGlobal: Connecting to camera service
10-29 06:10:07.391 3282 3282 D NotificationEntryMgr: heads up is enabled
10-29 06:10:07.451 3282 3282 D BluetoothHidDevice: Bound to HID Device Service
10-29 06:10:07.452 3282 3282 D LocalBluetoothProfileManager: Adding local MAP profile
10-29 06:10:07.453 3282 3282 D BluetoothMap: Create BluetoothMap proxy object
10-29 06:10:07.454 3282 3282 D LocalBluetoothProfileManager: Adding local PBAP profile
10-29 06:10:07.456 3282 3282 D LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
10-29 06:10:07.471 3282 3282 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@48b3e2f, handler=Handler (android.os.Handler) {395fc3c}
10-29 06:10:07.472 3282 3610 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
10-29 06:10:07.473 3282 3610 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
10-29 06:10:07.480 3282 3608 D OpenGLRenderer: profile bars disabled
10-29 06:10:07.481 3282 3608 D OpenGLRenderer: ambientRatio = 1.50
10-29 06:10:07.494 3282 3282 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:10:07.512 3282 3282 V WifiManager: registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@48b3e2f, handler=Handler (android.os.Handler) {395fc3c}
10-29 06:10:07.512 3282 3610 V WifiManager: SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
10-29 06:10:07.513 3282 3610 V WifiManager: SoftApCallbackProxy: onNumClientsChanged: numClients=0
10-29 06:10:07.522 3282 3625 I SecurityController: could not bind to KeyChainService
10-29 06:10:07.544 3282 3617 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:10:07.548 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.SystemBars took to complete: 518ms
10-29 06:10:07.553 3282 3282 D StorageNotification: Notifying about private volume: VolumeInfo{private}:
10-29 06:10:07.553 3282 3282 D StorageNotification: type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
10-29 06:10:07.553 3282 3282 D StorageNotification: state=MOUNTED
10-29 06:10:07.553 3282 3282 D StorageNotification: fsType=null fsUuid=null fsLabel=null
10-29 06:10:07.553 3282 3282 D StorageNotification: path=/data internalPath=null
10-29 06:10:07.555 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.usb.StorageNotification took to complete: 6ms
10-29 06:10:07.561 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.power.PowerUI took to complete: 5ms
10-29 06:10:07.562 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.media.RingtonePlayer took to complete: 2ms
10-29 06:10:07.563 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.keyboard.KeyboardUI took to complete: 1ms
10-29 06:10:07.575 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.pip.PipUI took to complete: 11ms
10-29 06:10:07.576 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.shortcut.ShortcutKeyDispatcher took to complete: 1ms
10-29 06:10:07.576 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.VendorServices took to complete: 0ms
10-29 06:10:07.577 3282 3282 V GarbageMonitor: Now tracking processes: 3282
10-29 06:10:07.577 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.util.leak.GarbageMonitor$Service took to complete: 2ms
10-29 06:10:07.578 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.LatencyTester took to complete: 1ms
10-29 06:10:07.581 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.globalactions.GlobalActionsComponent took to complete: 2ms
10-29 06:10:07.591 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.ScreenDecorations took to complete: 10ms
10-29 06:10:07.592 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.fingerprint.FingerprintDialogImpl took to complete: 0ms
10-29 06:10:07.593 3282 3282 D SystemUIBootTiming: StartServicescom.android.systemui.SliceBroadcastRelayHandler took to complete: 2ms
10-29 06:10:07.593 3282 3282 D SystemUIBootTiming: StartServices took to complete: 1215ms
10-29 06:10:07.601 3282 3282 V MediaRouter: Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
10-29 06:10:07.602 3282 3282 V MediaRouter: Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
10-29 06:10:07.620 3282 3282 I Choreographer: Skipped 35 frames! The application may be doing too much work on its main thread.
10-29 06:10:07.641 3282 3282 D ViewRootImpl[StatusBar]: changeCanvasOpacity: opaque=true
10-29 06:10:07.664 3282 3625 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:10:07.665 3282 3608 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:07.665 3282 3608 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:07.665 3282 3608 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:10:07.665 3282 3608 D OpenGLRenderer: Swap behavior 2
10-29 06:10:07.689 3282 3608 I display : open gpu gralloc module!
10-29 06:10:07.693 3282 3617 E ActivityThread: Failed to find provider info for com.android.contacts
10-29 06:10:07.763 3121 3206 D WifiService: New client listening to asynchronous messages
10-29 06:10:08.186 3282 3282 D StatusBar: disable<e i a s b H!R!c s > disable2<q i n >
10-29 06:10:08.359 3282 3282 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:10:08.369 2884 2890 E Cryptfs : cryptfs_get_password not valid for file encryption
10-29 06:10:08.400 3121 3191 I InputReader: Reconfiguring input devices. changes=0x00000004
10-29 06:10:08.422 3282 3282 I Choreographer: Skipped 47 frames! The application may be doing too much work on its main thread.
10-29 06:10:08.455 3282 3608 I OpenGLRenderer: Davey! duration=821ms; Flags=0, IntendedVsync=16650964901, Vsync=17434298203, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=17440811796, AnimationStart=17440842396, PerformTraversalsStart=17441732196, DrawStart=17445364236, SyncQueued=17455851757, SyncStart=17457169117, IssueDrawCommandsStart=17457299437, SwapBuffers=17472356317, FrameCompleted=17473662638, DequeueBufferDuration=612000, QueueBufferDuration=160000,
10-29 06:10:08.476 3121 3144 W WindowManager: App freeze timeout expired.
10-29 06:10:08.482 2965 3091 D audio_hw_primary: adev_set_parameters: enter: A2dpSuspended=false
10-29 06:10:08.482 2965 3091 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:10:08.483 3121 3220 I AudioService: setBluetoothScoOnInt: false resetBluetoothSco
10-29 06:10:08.483 2965 3091 D audio_hw_primary: adev_set_parameters: enter: BT_SCO=off
10-29 06:10:08.483 2965 3091 D audio_hw_primary: adev_set_parameters: exit with code(0)
10-29 06:10:08.574 3282 3608 I OpenGLRenderer: Davey! duration=939ms; Flags=0, IntendedVsync=16650964901, Vsync=17434298203, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=17440811796, AnimationStart=17440842396, PerformTraversalsStart=17441732196, DrawStart=17526278680, SyncQueued=17528407960, SyncStart=17530920400, IssueDrawCommandsStart=17531075200, SwapBuffers=17590914162, FrameCompleted=17593115322, DequeueBufferDuration=1107000, QueueBufferDuration=311000,
10-29 06:10:08.672 3121 3144 I WindowManager: ******* TELLING SURFACE FLINGER WE ARE BOOTED!
10-29 06:10:08.672 2986 3046 I SurfaceFlinger: Boot is finished (7988 ms)
10-29 06:10:08.673 3282 3282 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:10:08.678 3121 3144 I SystemServiceManager: Starting phase 1000
10-29 06:10:08.691 3121 3144 D ActivityManager: Finishing user boot 0
10-29 06:10:08.692 3121 3144 I ActivityManager: User 0 state changed from BOOTING to RUNNING_LOCKED
10-29 06:10:08.692 3282 3282 I chatty : uid=10031(com.android.systemui) identical 2 lines
10-29 06:10:08.694 2884 2890 D vold : e4crypt_unlock_user_key 0 serial=0 token_present=0
10-29 06:10:08.694 3282 3282 I ImageWallpaper: Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
10-29 06:10:08.699 2884 2890 D vold : Skipping non-key .
10-29 06:10:08.699 2884 2890 D vold : Skipping non-key ..
10-29 06:10:08.699 2884 2890 D vold : Trying user CE key /data/misc/vold/user_keys/ce/0/current
10-29 06:10:08.704 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::IKeymasterDevice/default in either framework or device manifest.
10-29 06:10:08.707 2884 2890 I vold : List of Keymaster HALs found:
10-29 06:10:08.707 2884 2890 I vold : Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: [email protected]::IKeymasterDevice/default
10-29 06:10:08.707 2884 2890 I vold : Using SoftwareKeymasterDevice from Google for encryption. Security level: SOFTWARE, HAL: [email protected]::IKeymasterDevice/default
10-29 06:10:08.709 2884 2890 D vold : Successfully retrieved key
10-29 06:10:08.709 2884 2890 D vold : Added key 912188264 (ext4:e5c0a18cb8418c01) to keyring 1040619598 in process 2884
10-29 06:10:08.709 2884 2890 D vold : Added key 719207202 (f2fs:e5c0a18cb8418c01) to keyring 1040619598 in process 2884
10-29 06:10:08.709 2884 2890 D vold : Added key 917579865 (fscrypt:e5c0a18cb8418c01) to keyring 1040619598 in process 2884
10-29 06:10:08.709 2884 2890 D vold : Installed ce key for user 0
10-29 06:10:08.709 3121 3144 D ActivityManager: Started unlocking user 0
10-29 06:10:08.709 3121 3144 D ActivityManager: Unlocking user 0 progress 0
10-29 06:10:08.710 3121 3144 D ActivityManager: Unlocking user 0 progress 5
10-29 06:10:08.719 2884 2884 W Binder:2884_3: type=1400 audit(0.0:2430): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
10-29 06:10:08.722 2884 2890 D vold : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
10-29 06:10:08.722 2884 2890 D vold : Preparing: /data/system_ce/0
10-29 06:10:08.723 2884 2890 D vold : Preparing: /data/misc_ce/0
10-29 06:10:08.723 2884 2890 D vold : Preparing: /data/vendor_ce/0
10-29 06:10:08.730 3121 3207 D WifiConfigStore: Reading from stores completed in 0 ms.
10-29 06:10:08.731 3121 3207 W WifiConfigManager: No stored networks found.
10-29 06:10:08.735 3121 3207 D WIFI : Registering NetworkFactory
10-29 06:10:08.735 3121 3212 D ConnectivityService: Got NetworkFactory Messenger for WIFI
10-29 06:10:08.736 3121 3207 D WIFI_UT : Registering NetworkFactory
10-29 06:10:08.736 3121 3212 D ConnectivityService: Got NetworkFactory Messenger for WIFI_UT
10-29 06:10:08.736 3121 3207 D WIFI : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:08.736 3121 3207 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI_UT : got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 1000] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI_UT : got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
10-29 06:10:08.737 3121 3207 D WIFI_UT : got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted: Uid: 10031] ] with score 0
10-29 06:10:08.767 3636 3636 W main : type=1400 audit(0.0:2431): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:08.767 2884 2884 W Binder:2884_3: type=1400 audit(0.0:2432): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
10-29 06:10:08.767 2884 2884 I chatty : uid=0(root) Binder:2884_2 identical 1 line
10-29 06:10:08.767 2884 2884 W Binder:2884_3: type=1400 audit(0.0:2434): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
10-29 06:10:08.770 2884 2890 D vold : Preparing: /data/media/0
10-29 06:10:08.771 2884 2890 D vold : Preparing: /data/data
10-29 06:10:08.774 3121 3138 I ActivityManager: Start proc 3636:com.android.deskclock/u0a48 for broadcast com.android.deskclock/.AlarmInitReceiver
10-29 06:10:08.782 3282 3282 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:10:08.787 3282 3282 I chatty : uid=10031(com.android.systemui) identical 1 line
10-29 06:10:08.804 2884 2890 I vold : Found policy e5c0a18cb8418c01 at /data/system_ce/0 which matches expected value
10-29 06:10:08.811 3282 3282 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:10:08.819 3636 3636 I droid.deskcloc: The ClassLoaderContext is a special shared library.
10-29 06:10:08.833 2884 2890 I vold : Found policy e5c0a18cb8418c01 at /data/misc_ce/0 which matches expected value
10-29 06:10:08.833 2884 2890 I vold : Policy for /data/vendor_ce/0 set to e5c0a18cb8418c01 modes 1/4
10-29 06:10:08.835 2884 2890 I vold : Found policy e5c0a18cb8418c01 at /data/media/0 which matches expected value
10-29 06:10:08.835 2884 2890 I vold : Found policy e5c0a18cb8418c01 at /data/data which matches expected value
10-29 06:10:08.835 2884 2890 V vold : Starting restorecon of /data/system_ce/0
10-29 06:10:08.844 3636 3636 I droid.deskcloc: The ClassLoaderContext is a special shared library.
10-29 06:10:08.877 3648 3648 I bootstat: Service started: /system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l
10-29 06:10:08.893 3282 3282 W StatusBar/NavBarView: *** Invalid layout in navigation bar (sizeChanged this=1920x64 cur=1898x64)
10-29 06:10:08.898 3282 3282 D android.widget.GridLayout: vertical constraints: y1-y0>=35, y1-y0<=32 are inconsistent; permanently removing: y1-y0<=32.
10-29 06:10:08.906 3636 3636 I AlarmClock: AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
10-29 06:10:08.913 3636 3658 I AlarmClock: Fixing alarm instances
10-29 06:10:08.923 2884 2890 V vold : Finished restorecon of /data/system_ce/0
10-29 06:10:08.923 2884 2890 V vold : Starting restorecon of /data/misc_ce/0
10-29 06:10:08.948 2884 2890 V vold : Finished restorecon of /data/misc_ce/0
10-29 06:10:08.948 2884 2890 V vold : /system/bin/vold_prepare_subdirs
10-29 06:10:08.948 2884 2890 V vold : prepare
10-29 06:10:08.949 2884 2890 V vold :
10-29 06:10:08.949 2884 2890 V vold : 0
10-29 06:10:08.949 2884 2890 V vold : 2
10-29 06:10:08.960 3648 3648 I bootstat: Battery level at startup 85%
10-29 06:10:08.961 3648 3648 I bootstat: Canonical boot reason: cold
10-29 06:10:08.962 3648 3648 E bootstat: Failed to read /data/misc/bootstat/post_decrypt_time_elapsed: No such file or directory
10-29 06:10:08.962 3648 3648 E bootstat: Failed to parse boot time record: /data/misc/bootstat/post_decrypt_time_elapsed
10-29 06:10:08.987 2884 2890 I vold_prepare_subdirs: SELinux: Loaded file_contexts
10-29 06:10:08.988 3282 3282 W View : requestLayout() improperly called by com.android.keyguard.CarrierText{8dd2fa8 V.ED..... ......ID 32,0-1764,80 #7f0a018a app:id/keyguard_carrier_text} during layout: running second layout pass
10-29 06:10:08.988 3636 3658 V AlarmClock: AlarmInitReceiver finished
10-29 06:10:08.991 3660 3660 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_ce/0/vold
10-29 06:10:08.992 3660 3660 D vold_prepare_subdirs: Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_ce/0/storaged
10-29 06:10:08.994 3121 3142 V UserDataPreparer: Found /data/user/0 with serial number 0
10-29 06:10:08.995 3121 3142 V UserDataPreparer: Found /data/system_ce/0 with serial number 0
10-29 06:10:08.995 3121 3142 D UserDataPreparer: Setting property: sys.user.0.ce_available=true
10-29 06:10:08.996 3121 3142 V PackageManager: reconcileAppsData for null u0 0x2 migrateAppData=false
10-29 06:10:08.997 3121 3135 I android.os.Debug: using rollup pss collection
10-29 06:10:09.275 3121 3142 V PackageManager: reconcileAppsData finished 89 packages
10-29 06:10:09.275 3121 3142 I ActivityManager: User 0 state changed from RUNNING_LOCKED to RUNNING_UNLOCKING
10-29 06:10:09.275 3121 3142 D ActivityManager: Unlocking user 0 progress 20
10-29 06:10:09.276 3121 3136 I SystemServiceManager: Calling onUnlockUser u0
10-29 06:10:09.276 3121 3136 D BluetoothManagerService: User 0 unlocked
10-29 06:10:09.276 3121 3136 D StorageManagerService: onUnlockUser 0
10-29 06:10:09.277 3121 3143 D BluetoothManagerService: MESSAGE_USER_UNLOCKED
10-29 06:10:09.277 3121 3142 W Looper : Slow dispatch took 556ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@bf64fde m=0
10-29 06:10:09.278 3121 3142 W Looper : Slow delivery took 541ms android.fg h=com.android.server.AppStateTracker$MyHandler c=null m=14
10-29 06:10:09.278 2884 2890 D vold : Linking /storage/emulated/0 to /mnt/user/0/primary
10-29 06:10:09.292 3121 3142 W Looper : Drained
10-29 06:10:09.292 3121 3199 D StorageManagerService: Volume emulated broadcasting mounted to UserHandle{0}
10-29 06:10:09.295 3121 3207 D WifiConfigStore: Reading from user store completed in 1 ms.
10-29 06:10:09.295 3121 3136 W VoiceInteractionManagerService: no available voice interaction services found for user 0
10-29 06:10:09.295 3121 3207 D WakeupConfigStoreData: WifiWake user data has been read
10-29 06:10:09.295 3121 3136 W VoiceInteractionManagerService: no available voice recognition services found for user 0
10-29 06:10:09.297 3121 3136 D AutofillManagerServiceImpl: Reset component for user 0 ()
10-29 06:10:09.297 3121 3137 D AutofillUI: destroySaveUiUiThread(): already destroyed
10-29 06:10:09.297 3121 3136 D FieldClassificationStrategy: reset(): service is not bound. Do nothing.
10-29 06:10:09.297 3121 3136 I ActivityManager: User 0 state changed from RUNNING_UNLOCKING to RUNNING_UNLOCKED
10-29 06:10:09.298 3121 3136 D SystemServerTiming: SystemUserUnlock took to complete: 588ms
10-29 06:10:09.298 3121 3668 V BackupManagerService: Starting with transport android/com.android.internal.backup.LocalTransport
10-29 06:10:09.299 3121 3142 I ActivityManager: Loading recents for user 0 into memory.
10-29 06:10:09.314 3121 3207 D WifiConfigStore: Writing to stores completed in 18 ms.
10-29 06:10:09.323 3121 3668 I SELinux : SELinux: Loaded file_contexts
10-29 06:10:09.328 3259 3259 I InputAttributes: InputType.TYPE_NULL is specified
10-29 06:10:09.329 3121 3138 I ActivityManager: Start proc 3671:com.android.se/1068 for added application com.android.se
10-29 06:10:09.346 3121 3668 E BackupPasswordManager: Unable to read backup pw version
10-29 06:10:09.346 3121 3668 E BackupPasswordManager: Unable to read saved backup pw hash
10-29 06:10:09.379 3121 3668 V BackupManagerService: No ancestral data
10-29 06:10:09.397 3671 3671 I com.android.se: The ClassLoaderContext is a special shared library.
10-29 06:10:09.411 3121 3668 I BackupManagerService: Unlocking system user; mService=com.android.server.backup.BackupManagerService@b4e64cb
10-29 06:10:09.412 3121 3668 I BackupManagerService: Backup enabled => false
10-29 06:10:09.414 3671 3671 I SecureElementService: main onCreate
10-29 06:10:09.418 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISecureElement/eSE1 in either framework or device manifest.
10-29 06:10:09.419 3671 3671 I SecureElementService: No HAL implementation for eSE1
10-29 06:10:09.420 2873 2873 W hwservicemanager: getTransport: Cannot find entry [email protected]::ISecureElement/SIM1 in either framework or device manifest.
10-29 06:10:09.421 3671 3671 I SecureElementService: No HAL implementation for SIM1
10-29 06:10:09.437 3121 3668 V BackupManagerConstants: getKeyValueBackupIntervalMilliseconds(...) returns 14400000
10-29 06:10:09.438 3121 3668 V BackupManagerConstants: getKeyValueBackupFuzzMilliseconds(...) returns 600000
10-29 06:10:09.438 3121 3668 V BackupManagerConstants: getKeyValueBackupRequiredNetworkType(...) returns 1
10-29 06:10:09.438 3121 3668 V BackupManagerConstants: getKeyValueBackupRequireCharging(...) returns true
10-29 06:10:09.438 3121 3668 V KeyValueBackupJob: Scheduling k/v pass in 244 minutes
10-29 06:10:09.448 3121 3136 I AppWidgetServiceImpl: Processing of handleUserUnlocked u0 took 138 ms
10-29 06:10:09.448 3121 3136 I ActivityManager: Sending BOOT_COMPLETE user #0
10-29 06:10:09.466 3121 3121 V NotificationListeners: enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
10-29 06:10:09.468 3500 3500 D FallbackHome: User unlocked and real home found; let's go!
10-29 06:10:09.469 3475 3475 D CarrierSvcBindHelper: Received android.intent.action.USER_UNLOCKED
10-29 06:10:09.469 3121 3121 V NotificationListeners: binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
10-29 06:10:09.470 3475 3475 E PhoneInterfaceManager: [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
10-29 06:10:09.470 3475 3475 D CarrierSvcBindHelper: No carrier app for: 0
10-29 06:10:09.471 3121 3121 V NotificationAssistants: disabling notification assistant for user 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:10:09.471 3121 3121 D NotificationListeners: Removing active service ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:10:09.487 3121 3121 V NotificationAssistants: enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
10-29 06:10:09.487 3121 3138 I ActivityManager: Start proc 3692:android.process.media/u0a6 for broadcast com.android.providers.downloads/.DownloadReceiver
10-29 06:10:09.490 3121 3121 V NotificationAssistants: binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
10-29 06:10:09.523 3121 3133 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0
10-29 06:10:09.556 3121 3121 I AccountManagerService: User 0 is unlocked - opening CE database
10-29 06:10:09.577 3121 3521 W ActivityManager: Slow operation: 106ms so far, now at startProcess: done updating battery stats
10-29 06:10:09.577 3121 3521 W ActivityManager: Slow operation: 107ms so far, now at startProcess: building log message
10-29 06:10:09.577 3121 3521 I ActivityManager: Start proc 3707:com.android.launcher3/u0a11 for service com.android.launcher3/.notification.NotificationListener
10-29 06:10:09.577 3121 3521 W ActivityManager: Slow operation: 107ms so far, now at startProcess: starting to update pids map
10-29 06:10:09.577 3121 3521 W ActivityManager: Slow operation: 107ms so far, now at startProcess: done updating pids map
10-29 06:10:09.617 3707 3707 I droid.launcher: The ClassLoaderContext is a special shared library.
10-29 06:10:09.622 3121 3121 W Looper : Slow dispatch took 117ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@943b195 m=0
10-29 06:10:09.625 3572 3723 D ExtAssistant: File doesn't exist or isn't readable yet
10-29 06:10:09.625 3121 3238 I SyncManager: Loaded persisted syncs: 0 periodic syncs, 0 oneshot syncs, 10 total system server jobs, JobStats: FirstLoad: 2/2/0 LastSave: -1/-1/-1
10-29 06:10:09.657 3692 3692 I d.process.medi: The ClassLoaderContext is a special shared library.
10-29 06:10:09.691 3692 3692 I d.process.medi: The ClassLoaderContext is a special shared library.
10-29 06:10:09.724 3121 3132 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
10-29 06:10:09.724 3121 3132 W WallpaperManagerService: Cannot get theme colors because WallpaperColors is null.
10-29 06:10:09.725 3707 3707 V Launcher: LauncherAppState initiated
10-29 06:10:09.740 3707 3707 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:09.822 3692 3692 D MediaScannerReceiver: action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
10-29 06:10:09.843 3741 3741 W main : type=1400 audit(0.0:3670): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:09.843 3741 3741 I chatty : uid=0(root) com.android.quicksearchbox identical 2 lines
10-29 06:10:09.843 3741 3741 W main : type=1400 audit(0.0:3673): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:09.852 3121 3138 I ActivityManager: Start proc 3741:com.android.quicksearchbox/u0a33 for broadcast com.android.quicksearchbox/.SearchWidgetProvider
10-29 06:10:09.904 3741 3741 I .quicksearchbo: The ClassLoaderContext is a special shared library.
10-29 06:10:09.917 3741 3741 I .quicksearchbo: The ClassLoaderContext is a special shared library.
10-29 06:10:10.074 3121 3762 I RecoverySystem: No recovery log file
10-29 06:10:10.088 3121 3762 I BootReceiver: Copying audit failures to DropBox
10-29 06:10:10.088 3121 3762 I BootReceiver: Checking for fsck errors
10-29 06:10:10.090 3121 3762 I BootReceiver: fs_stat, partition:userdata stat:0xb
10-29 06:10:10.091 3763 3763 W main : type=1400 audit(0.0:3674): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:10.095 3121 3138 I ActivityManager: Start proc 3763:com.android.dialer/u0a16 for broadcast com.android.dialer/.app.calllog.CallLogReceiver
10-29 06:10:10.102 3121 3136 W ActivityManager: Activity pause timeout for ActivityRecord{5006087 u0 com.android.launcher3/.Launcher t2}
10-29 06:10:10.112 3707 3730 D LoaderTask: loadWorkspace: loading default favorites
10-29 06:10:10.157 3707 3776 E libEGL : error mmaping cache file: Invalid argument (22)
10-29 06:10:10.184 3763 3763 I .android.diale: The ClassLoaderContext is a special shared library.
10-29 06:10:10.196 3121 3138 I ActivityManager: Start proc 3779:com.android.printspooler/u0a45 for service com.android.printspooler/.model.PrintSpoolerService
10-29 06:10:10.245 3692 3740 V MediaProvider: pruneThumbnails
10-29 06:10:10.246 3707 3707 D TouchInteractionService: Touch service connected
10-29 06:10:10.266 3692 3740 V MediaProvider: /pruneDeadThumbnailFiles...
10-29 06:10:10.276 3707 3718 I droid.launcher: Background concurrent copying GC freed 24112(2MB) AllocSpace objects, 7(136KB) LOS objects, 49% free, 2MB/4MB, paused 99us total 152.217ms
10-29 06:10:10.296 3763 3763 I .android.diale: The ClassLoaderContext is a special shared library.
10-29 06:10:10.309 3121 3131 I system_server: Background concurrent copying GC freed 45023(3MB) AllocSpace objects, 44(1456KB) LOS objects, 42% free, 5MB/9MB, paused 2.052ms total 234.892ms
10-29 06:10:10.316 3779 3779 I id.printspoole: The ClassLoaderContext is a special shared library.
10-29 06:10:10.332 3707 3776 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:10.333 3707 3776 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:10.333 3707 3776 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:10:10.333 3707 3776 D OpenGLRenderer: Swap behavior 2
10-29 06:10:10.349 3763 3763 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:10:10.357 3763 3763 I Dialer : CallLogFramework.registerContentObservers - enter
10-29 06:10:10.359 3707 3776 I display : open gpu gralloc module!
10-29 06:10:10.360 3763 3763 I Dialer : CallLogFramework.registerContentObservers - not registering content observers
10-29 06:10:10.364 3763 3763 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:10:10.394 3763 3763 I Dialer : DialerExecutorModule.newThread - creating low priority thread
10-29 06:10:10.395 3763 3807 I Dialer : VisualVoicemailUpdateTask.updateNotification - enter
10-29 06:10:10.404 3121 3138 I ActivityManager: Start proc 3809:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
10-29 06:10:10.432 3121 3138 I ActivityManager: Start proc 3817:android.process.acore/u0a10 for content provider com.android.providers.contacts/.CallLogProvider
10-29 06:10:10.473 3809 3809 I ndroid.keychai: The ClassLoaderContext is a special shared library.
10-29 06:10:10.486 3817 3817 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:10:10.494 3707 3707 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:10:10.566 3817 3817 I ContactsPerf: VoicemailContentProvider.onCreate start
10-29 06:10:10.578 3817 3817 I ContactsPerf: VoicemailContentProvider.onCreate finish
10-29 06:10:10.602 3817 3817 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:10:10.605 3282 3282 I vol.Events: writeEvent dismiss_dialog timeout
10-29 06:10:10.635 3817 3817 I d.process.acor: The ClassLoaderContext is a special shared library.
10-29 06:10:10.657 3817 3843 D ContactsDatabaseHelper: WAL enabled for contacts2.db: true
10-29 06:10:10.701 3817 3843 I ContactLocale: AddressBook Labels [[en_US]]: […, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, …, А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, …, א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, …, ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, …, ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, …, ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, …, あ, か, さ, た, な, は, ま, や, ら, わ, #, …]
10-29 06:10:10.723 3817 3843 D ContactsDatabaseHelper: WAL enabled for profile.db: false
10-29 06:10:10.742 3763 3807 I Dialer : VisualVoicemailUpdateTask.updateNotification - no voicemails to notify about
10-29 06:10:10.744 3763 3807 I Dialer : VisualVoicemailNotifier.cancelAllVoicemailNotifications - enter
10-29 06:10:10.745 3763 3807 I Dialer : VoicemailNotificationJobService.scheduleJob - job canceled
10-29 06:10:10.746 3763 3763 I Dialer : VisualVoicemailUpdateTask.scheduleTask - update successful
10-29 06:10:11.338 3259 3259 I LatinIME: Timeout waiting for dictionary load
10-29 06:10:15.747 3121 3121 D WifiService: boot completed do start wifi
10-29 06:10:15.748 3121 3121 W Looper : Slow dispatch took 5001ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@e51b4d4 m=0
10-29 06:10:15.748 3121 3121 W Looper : Slow delivery took 5000ms main h=com.android.server.job.JobSchedulerService$JobHandler c=null m=4
10-29 06:10:15.763 3121 3121 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now com.android.dialer: DDC.oR@AA8
10-29 06:10:15.764 3121 3121 I TransportClient: LocalTransportService#0: Notifying [TransportManager.registerTransport()] transport = IBackupTransport
10-29 06:10:15.765 3121 3121 W Looper : Drained
10-29 06:10:15.765 3121 3121 I Telecom : MissedCallNotifierImpl: reloadAfterBootComplete: user=0: TSBCR.oR@ABA
10-29 06:10:15.767 3475 3475 D CarrierConfigLoader: mHandler: 13 phoneId: 0
10-29 06:10:15.768 3121 3668 D BackupTransportManager: Transport android/com.android.internal.backup.LocalTransportService registered
10-29 06:10:15.768 3121 3668 D BackupManagerService: Transport android/com.android.internal.backup.LocalTransport registered 6358ms after first request (delay = 3000ms)
10-29 06:10:15.779 3121 3668 I BackupManagerService: Found stale backup journal, scheduling
10-29 06:10:15.784 3475 3853 D SIP : [SipPreferences] isReceivingCallsEnabled, option not set; use default value, exception: android.provider.Settings$SettingNotFoundException: sip_receive_calls
10-29 06:10:15.787 3854 3854 W main : type=1400 audit(0.0:3690): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:15.787 3854 3854 I chatty : uid=10055(com.android.calendar) identical 2 lines
10-29 06:10:15.787 3854 3854 W main : type=1400 audit(0.0:3693): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:15.802 3121 3668 I chatty : uid=1000(system) backup identical 61 lines
10-29 06:10:15.802 3121 3668 I BackupManagerService: Found stale backup journal, scheduling
10-29 06:10:15.802 3121 3138 I ActivityManager: Start proc 3854:com.android.calendar/u0a55 for broadcast com.android.calendar/.alerts.AlertReceiver
10-29 06:10:15.804 3121 3668 I BackupManagerService: Found stale backup journal, scheduling
10-29 06:10:15.833 3854 3854 I ndroid.calenda: The ClassLoaderContext is a special shared library.
10-29 06:10:15.844 3854 3854 I ndroid.calenda: The ClassLoaderContext is a special shared library.
10-29 06:10:15.867 3854 3854 D ExtensionsFactory: No custom extensions.
10-29 06:10:15.869 3854 3854 D AlertReceiver: onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
10-29 06:10:15.883 3877 3877 W main : type=1400 audit(0.0:3694): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:15.888 3121 3138 I ActivityManager: Start proc 3877:com.android.cellbroadcastreceiver/u0a19 for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver
10-29 06:10:15.935 3854 3875 D AlertService: 0 Action = android.intent.action.BOOT_COMPLETED
10-29 06:10:15.942 3854 3875 D AlertService: Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
10-29 06:10:15.958 3877 3877 I oadcastreceive: The ClassLoaderContext is a special shared library.
10-29 06:10:15.968 3121 3138 I ActivityManager: Start proc 3894:com.android.providers.calendar/u0a24 for content provider com.android.providers.calendar/.CalendarProvider2
10-29 06:10:15.991 3877 3877 D CellBroadcastReceiver: onReceive Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.cellbroadcastreceiver/.CellBroadcastReceiver (has extras) }
10-29 06:10:15.992 3877 3877 D CellBroadcastReceiver: Start Cell Broadcast configuration.
10-29 06:10:15.996 3877 3877 D CellBroadcastReceiver: Default interval 0 did not change.
10-29 06:10:16.014 3121 3138 I ActivityManager: Start proc 3913:com.android.contacts/u0a27 for broadcast com.android.contacts/.interactions.OnBootOrUpgradeReceiver
10-29 06:10:16.022 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.022 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4370 to 4370 from client com.android.cellbroadcastreceiver
10-29 06:10:16.025 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:10:16.026 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4096 to 4096 from client com.android.cellbroadcastreceiver
10-29 06:10:16.028 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.029 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4383 to 4383 from client com.android.cellbroadcastreceiver
10-29 06:10:16.029 3894 3894 I viders.calenda: The ClassLoaderContext is a special shared library.
10-29 06:10:16.034 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.034 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4371 to 4372 from client com.android.cellbroadcastreceiver
10-29 06:10:16.036 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:10:16.036 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4097 to 4097 from client com.android.cellbroadcastreceiver
10-29 06:10:16.038 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.039 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4384 to 4385 from client com.android.cellbroadcastreceiver
10-29 06:10:16.046 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.047 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4373 to 4378 from client com.android.cellbroadcastreceiver
10-29 06:10:16.050 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:10:16.050 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4098 to 4098 from client com.android.cellbroadcastreceiver
10-29 06:10:16.054 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.055 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4386 to 4391 from client com.android.cellbroadcastreceiver
10-29 06:10:16.057 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.058 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4379 to 4379 from client com.android.cellbroadcastreceiver
10-29 06:10:16.060 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
10-29 06:10:16.060 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4099 to 4099 from client com.android.cellbroadcastreceiver
10-29 06:10:16.064 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.064 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4392 to 4392 from client com.android.cellbroadcastreceiver
10-29 06:10:16.069 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4380 to 4380 from client com.android.cellbroadcastreceiver
10-29 06:10:16.073 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove cdma broadcast subscription for MID range 4100 to 4100 from client com.android.cellbroadcastreceiver
10-29 06:10:16.076 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4393 to 4393 from client com.android.cellbroadcastreceiver
10-29 06:10:16.078 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4381 to 4381 from client com.android.cellbroadcastreceiver
10-29 06:10:16.082 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4394 to 4394 from client com.android.cellbroadcastreceiver
10-29 06:10:16.085 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4382 to 4382 from client com.android.cellbroadcastreceiver
10-29 06:10:16.087 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4395 to 4395 from client com.android.cellbroadcastreceiver
10-29 06:10:16.091 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.091 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4352 to 4354 from client com.android.cellbroadcastreceiver
10-29 06:10:16.094 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
10-29 06:10:16.095 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4356 to 4356 from client com.android.cellbroadcastreceiver
10-29 06:10:16.097 3475 3616 D IccSmsInterfaceManager: [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4355 to 4355 from client com.android.cellbroadcastreceiver
10-29 06:10:16.102 3913 3913 I ndroid.contact: The ClassLoaderContext is a special shared library.
10-29 06:10:16.123 3894 3894 I CalendarProvider2: Created com.android.providers.calendar.CalendarAlarmManager@5833573(com.android.providers.calendar.CalendarProvider2@d18fc30)
10-29 06:10:16.143 3636 3636 I AlarmClock: AlarmInitReceiver android.intent.action.BOOT_COMPLETED
10-29 06:10:16.152 3636 3658 I AlarmClock: Fixing alarm instances
10-29 06:10:16.157 3121 3133 D ActivityManager: Raise procstate to external provider: ProcessRecord{1f991b3 3817:android.process.acore/u0a10}
10-29 06:10:16.161 3121 3133 W Binder : Outgoing transactions from this process must be FLAG_ONEWAY
10-29 06:10:16.161 3121 3133 W Binder : java.lang.Throwable
10-29 06:10:16.161 3121 3133 W Binder : at android.os.BinderProxy.transact(Binder.java:1114)
10-29 06:10:16.161 3121 3133 W Binder : at android.content.ContentProviderProxy.getType(ContentProviderNative.java:451)
10-29 06:10:16.161 3121 3133 W Binder : at com.android.server.am.ActivityManagerService.getProviderMimeType(ActivityManagerService.java:13064)
10-29 06:10:16.161 3121 3133 W Binder : at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:1416)
10-29 06:10:16.161 3121 3133 W Binder : at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:3291)
10-29 06:10:16.161 3121 3133 W Binder : at android.os.Binder.execTransact(Binder.java:731)
10-29 06:10:16.162 3636 3658 V AlarmClock: AlarmInitReceiver finished
10-29 06:10:16.172 3763 3763 I Dialer : VoicemailModule.provideVoicemailClient - providing VoicemailClientImpl
10-29 06:10:16.173 3763 3763 I Dialer : VvmOmtpService - onBoot
10-29 06:10:16.187 3854 3875 D AlarmScheduler: No events found starting within 1 week.
10-29 06:10:16.196 3121 3138 I ActivityManager: Start proc 3935:com.android.email/u0a63 for broadcast com.android.email/.service.EmailBroadcastReceiver
10-29 06:10:16.232 3935 3935 I m.android.emai: The ClassLoaderContext is a special shared library.
10-29 06:10:16.249 3935 3935 I m.android.emai: The ClassLoaderContext is a special shared library.
10-29 06:10:16.291 3121 3133 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.302 3935 3952 D ActivityThread: Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
10-29 06:10:16.303 3121 3133 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.330 3259 3259 I SystemBroadcastReceiver: Boot has been completed
10-29 06:10:16.330 3259 3259 I SystemBroadcastReceiver: toggleAppIcon() : FLAG_SYSTEM = true
10-29 06:10:16.354 3121 3138 I ActivityManager: Start proc 3960:com.android.managedprovisioning/u0a14 for broadcast com.android.managedprovisioning/.preprovisioning.BootReminder
10-29 06:10:16.413 3960 3960 I gedprovisionin: The ClassLoaderContext is a special shared library.
10-29 06:10:16.443 3121 3571 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
10-29 06:10:16.443 3121 3309 W ActivityManager: Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
10-29 06:10:16.444 3121 3309 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.447 3121 3138 I ActivityManager: Start proc 3976:com.android.onetimeinitializer/u0a20 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
10-29 06:10:16.451 3121 3309 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.452 3121 3309 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.454 3935 3935 E ActivityThread: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@518b6de that was originally bound here
10-29 06:10:16.454 3935 3935 E ActivityThread: android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@518b6de that was originally bound here
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1610)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1502)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1659)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.app.ContextImpl.bindService(ContextImpl.java:1612)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.content.ContextWrapper.bindService(ContextWrapper.java:698)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
10-29 06:10:16.454 3935 3935 E ActivityThread: at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.os.Looper.loop(Looper.java:193)
10-29 06:10:16.454 3935 3935 E ActivityThread: at android.os.HandlerThread.run(HandlerThread.java:65)
10-29 06:10:16.456 3121 3133 W ActivityManager: Unbind failed: could not find connection for android.os.BinderProxy@f7d2a21
10-29 06:10:16.468 3121 3133 W ActivityManager: Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
10-29 06:10:16.472 3935 3978 I Email : Observing account changes for notifications
10-29 06:10:16.488 3976 3976 I timeinitialize: The ClassLoaderContext is a special shared library.
10-29 06:10:16.498 3976 3976 V OneTimeInitializerReceiver: OneTimeInitializerReceiver.onReceive
10-29 06:10:16.520 3121 3138 I ActivityManager: Start proc 3995:com.android.packageinstaller/u0a23 for broadcast com.android.packageinstaller/.TemporaryFileManager
10-29 06:10:16.582 3995 3995 I ackageinstalle: The ClassLoaderContext is a special shared library.
10-29 06:10:16.612 3475 3475 I VvmSimStateTracker: android.intent.action.BOOT_COMPLETED
10-29 06:10:16.761 3121 3138 I ActivityManager: Start proc 4013:com.android.traceur/u0a41 for broadcast com.android.traceur/.Receiver
10-29 06:10:16.799 4013 4013 I android.traceu: The ClassLoaderContext is a special shared library.
10-29 06:10:16.811 4013 4013 I android.traceu: The ClassLoaderContext is a special shared library.
10-29 06:10:16.863 3121 3133 I ActivityManager: Finished processing BOOT_COMPLETED for u0
10-29 06:10:17.167 3692 4012 W MediaScanner: Error opening directory '/oem/media/', skipping: No such file or directory.
10-29 06:10:17.167 3692 4012 W MediaScanner: Error opening directory '/product/media/', skipping: No such file or directory.
10-29 06:10:17.180 3692 4012 V MediaProvider: pruneThumbnails
10-29 06:10:17.182 3692 4012 V MediaProvider: /pruneDeadThumbnailFiles...
10-29 06:10:17.483 3121 3236 E LightsService: Light requested not available on this device. 0
10-29 06:10:30.948 3121 3136 I ActivityManager: Waited long enough for: ServiceRecord{e2a14ca u0 com.android.calendar/.alerts.InitAlarmsService}
10-29 06:10:17.999 3121 3236 I chatty : uid=1000(system) PhotonicModulat identical 31 lines
10-29 06:10:18.016 3121 3236 E LightsService: Light requested not available on this device. 0
10-29 06:10:32.443 3121 3144 I display : open gpu gralloc module!
10-29 06:10:33.416 3121 3236 E LightsService: Light requested not available on this device. 0
10-29 06:10:33.933 3121 3236 I chatty : uid=1000(system) PhotonicModulat identical 31 lines
10-29 06:10:33.949 3121 3236 E LightsService: Light requested not available on this device. 0
10-29 06:10:34.077 3282 3282 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:10:34.274 3121 3144 I ActivityManager: Displayed com.android.launcher3/.Launcher: +24s676ms
10-29 06:10:34.275 3282 3282 D StatusBar: disable<e i a s b H R c s > disable2<q i n >
10-29 06:10:34.275 3707 3707 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:10:34.280 3282 3520 W AudioTrack: AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 -> 8329
10-29 06:10:34.282 2965 2965 D audio_hw_primary: out_set_parameters: enter: kvpairs: routing=1024
10-29 06:10:34.282 2965 2965 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:10:34.282 2965 2965 D audio_hw_primary: out_set_parameters: exit: code(0)
10-29 06:10:34.314 3282 3282 D StatusBar: disable<e i a s b h!r!c s > disable2<q i n >
10-29 06:10:34.410 3707 3707 E SchedPolicy: set_timerslack_ns write failed: Operation not permitted
10-29 06:10:34.434 3121 3571 W UsageStatsService: Event reported without a package name
10-29 06:10:34.434 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:10:34.434 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:10:34.440 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:10:34.440 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:10:34.561 3282 3282 D ViewRootImpl[StatusBar]: updatePointerIcon called with position out of bounds
10-29 06:10:37.615 2965 3091 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:10:45.983 3854 3892 D InitAlarmsService: Clearing and rescheduling alarms.
10-29 06:10:56.439 3121 3309 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.calculator2/.Calculator bnds=[332,115][646,279]} from uid 10011
10-29 06:10:56.439 3121 3220 I AudioTrack: AUDIO_OUTPUT_FLAG_FAST successful; frameCount 0 -> 4512
10-29 06:10:56.440 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:10:56.440 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:10:56.444 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:10:56.444 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:10:56.471 3121 3173 W System : ClassLoader referenced unknown path:
10-29 06:10:56.506 3121 3138 I ActivityManager: Start proc 4045:com.android.calculator2/u0a60 for activity com.android.calculator2/.Calculator
10-29 06:10:56.503 4045 4045 W main : type=1400 audit(0.0:3726): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:56.503 4045 4045 I chatty : uid=10060(com.android.calculator2) identical 2 lines
10-29 06:10:56.503 4045 4045 W main : type=1400 audit(0.0:3729): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:10:56.594 4045 4045 I oid.calculator: The ClassLoaderContext is a special shared library.
10-29 06:10:56.601 2986 3148 W ServiceManager: Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10011 pid=3707
10-29 06:10:56.602 2986 3148 D PermissionCache: checking android.permission.ACCESS_SURFACE_FLINGER for uid=10011 => denied (1187 us)
10-29 06:10:56.742 4045 4045 V Calculator: Setting locale to: en-US
10-29 06:10:56.754 4045 4045 D OpenGLRenderer: Skia GL Pipeline
10-29 06:10:56.924 4045 4065 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:10:56.925 4045 4065 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:10:56.926 4045 4065 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:10:56.926 4045 4065 D OpenGLRenderer: Swap behavior 2
10-29 06:10:56.960 4045 4065 I display : open gpu gralloc module!
10-29 06:10:57.124 3121 3144 I ActivityManager: Displayed com.android.calculator2/.Calculator: +645ms
10-29 06:10:57.290 2986 3661 W SurfaceFlinger: Attempting to set client state on removed layer: Splash Screen com.android.calculator2#0
10-29 06:10:57.290 2986 3661 W SurfaceFlinger: Attempting to destroy on removed layer: Splash Screen com.android.calculator2#0
10-29 06:11:00.022 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:11:00.065 3121 3237 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
10-29 06:11:00.019 2977 2977 W [email protected]: type=1400 audit(0.0:3730): avc: denied { read } for name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:11:02.013 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=29, bufHeight=37, front.active.{w=33, h=33}
10-29 06:11:04.361 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:11:04.359 2977 2977 W [email protected]: type=1400 audit(0.0:3731): avc: denied { read } for name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:11:04.362 3001 3061 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:11:05.192 3121 4073 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:11:05.466 3121 4073 I chatty : uid=1000 system_server identical 29 lines
10-29 06:11:05.470 3121 4073 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:11:05.472 3121 3131 I system_server: Background concurrent copying GC freed 40048(2MB) AllocSpace objects, 27(1384KB) LOS objects, 42% free, 5MB/9MB, paused 123us total 144.101ms
10-29 06:11:05.477 3121 4073 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:11:05.774 3121 4073 I chatty : uid=1000 system_server identical 44 lines
10-29 06:11:05.785 3121 4073 I system_server: The ClassLoaderContext is a special shared library.
10-29 06:11:05.786 3121 4073 I BackgroundDexOptService: Pinning optimized code {}
10-29 06:11:10.813 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=29, bufHeight=37, front.active.{w=33, h=33}
10-29 06:11:14.091 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:11:27.078 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=33, bufHeight=33, front.active.{w=29, h=37}
10-29 06:11:29.628 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=29, bufHeight=37, front.active.{w=33, h=33}
10-29 06:11:29.785 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:11:29.785 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:11:29.789 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:11:29.789 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:11:32.964 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:11:33.025 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:11:33.025 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:11:33.027 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:11:33.027 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:11:36.197 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:11:43.060 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=29, bufHeight=37, front.active.{w=33, h=33}
10-29 06:11:46.460 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=29, bufHeight=37, front.active.{w=33, h=33}
10-29 06:11:47.367 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:11:47.367 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:11:47.372 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:11:47.372 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:11:47.472 3121 3137 D AutofillManagerService: onBackKeyPressed()
10-29 06:11:47.491 3121 3133 I ActivityManager: Killing 3741:com.android.quicksearchbox/u0a33 (adj 906): empty #17
10-29 06:11:47.493 3121 3139 W libprocessgroup: kill(-3741, 9) failed: No such process
10-29 06:11:47.538 3121 3139 W libprocessgroup: kill(-3741, 9) failed: No such process
10-29 06:11:47.551 2986 3046 D PermissionCache: checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (294 us)
10-29 06:11:47.558 2955 2955 I Zygote : Process 3741 exited due to signal (9)
10-29 06:11:47.582 3121 3139 W libprocessgroup: kill(-3741, 9) failed: No such process
10-29 06:11:47.582 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 10033 pid 3741 in 89ms
10-29 06:11:47.720 3282 3297 I ndroid.systemu: NativeAlloc concurrent copying GC freed 24471(1476KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 4MB/9MB, paused 4.189ms total 128.325ms
10-29 06:11:48.090 3121 4081 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:11:48.090 3121 4081 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:11:48.090 3121 4081 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:11:48.091 3121 4081 D OpenGLRenderer: Swap behavior 2
10-29 06:11:50.553 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:11:51.143 3121 3237 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
[ 128.883248] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[ 129.130571] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
10-29 06:12:00.019 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:12:00.014 2977 2977 W [email protected]: type=1400 audit(0.0:3732): avc: denied { read } for name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:12:04.363 2977 2977 E /vendor/bin/hw/[email protected]: /sys/block/mmcblk0/stat: ReadFileToString failed.
10-29 06:12:04.363 3001 3061 E storaged: getDiskStats failed with result NOT_SUPPORTED and size 0
10-29 06:12:04.362 2977 2977 W [email protected]: type=1400 audit(0.0:3733): avc: denied { read } for name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
10-29 06:12:28.274 3121 3496 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher bnds=[960,115][1274,279]} from uid 10011
10-29 06:12:28.276 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:12:28.276 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:12:28.285 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:12:28.285 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
[ 157.457137] type=1400 audit(1572329524.362:3733): avc: denied { read } for pid=2977 comm="[email protected]" name="stat" dev="sysfs" ino=21332 scontext=u:r:hal_health_default:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0 duplicate messages suppressed
10-29 06:12:28.338 3121 3138 I [ 157.484657] type=1400 audit(1572329548.334:3734): avc: denied { dac_read_search } for pid=4084 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
ActivityManager: Start proc 4084:com.android.camera2/u0a51 for activity com.android.camera2/com.android.camera.CameraLauncher
10-29 06:12:28.334 4084 4084 W main : type=1400 audit(0.0:3734): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:12:28.358 4084 4084 I chatty : uid=10051(com.android.camera2) identical 2 lines
10-29 06:12:28.358 4084 4084 W main : type=1400 audit(0.0:3737): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:12:28.421 4084 4084 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:28.425 4084 4084 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:28.458 4084 4084 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraApp onCreate() - START
10-29 06:12:28.458 4084 4084 V CAM_Profiler: [ 0.000ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - START
10-29 06:12:28.461 4084 4084 V CAM_Profiler: [ 2.299ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 2.299ms] PreferenceManager.getDefaultSharedPreferences
10-29 06:12:28.463 4084 4084 V CAM_Profiler: [ 4.382ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 2.082ms] preferences.getLong
10-29 06:12:28.465 4084 4084 V CAM_Profiler: [ 6.215ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.833ms] getSharedPreferences
10-29 06:12:28.467 4084 4084 V CAM_Profiler: [ 8.633ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 2.418ms] preferences.edit()
10-29 06:12:28.467 4084 4084 V CAM_Profiler: [ 8.967ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - STOP
10-29 06:12:28.467 4084 4084 V CAM_Profiler: [ 11.989ms][ui] GUARD: CameraApp onCreate() - [11.989ms] initializeTimeOfFirstRun
10-29 06:12:28.468 4084 4084 V CAM_Profiler: [ 12.369ms][ui] GUARD: CameraApp onCreate() - [ 0.380ms] UsageStatistics.initialize
10-29 06:12:28.469 4084 4084 V CAM_Profiler: [ 13.526ms][ui] GUARD: CameraApp onCreate() - [ 1.157ms] clearNotifications
10-29 06:12:28.469 4084 4084 V CAM_Profiler: [ 13.526ms][ui] GUARD: CameraApp onCreate() - STOP
10-29 06:12:28.495 4084 4084 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@5833573
10-29 06:12:28.495 4084 4084 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
10-29 06:12:28.496 4084 4084 D CAM_LocationManager: Using legacy location provider.
10-29 06:12:28.518 4084 4084 D CAM_MemoryManagerImpl: Max native memory: 358 MB
10-29 06:12:28.522 4084 4084 W SoundPool: Use of stream types is deprecated for operations other than volume control
10-29 06:12:28.522 4084 4084 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
10-29 06:12:28.522 4084 4084 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
10-29 06:12:28.527 3121 3496 I ActivityManager: START u0 {cmp=com.android.camera2/com.android.camera.PermissionsActivity} from uid 10051
10-29 06:12:28.537 2986 3578 D SurfaceFlinger: duplicate layer name: changing Letterbox - bottom to Letterbox - bottom#1
10-29 06:12:28.538 2986 3578 D SurfaceFlinger: duplicate layer name: changing Letterbox - right to Letterbox - right#1
10-29 06:12:28.557 4084 4084 V CAM_Profiler: [ 62.295ms][ui] GUARD: CameraActivity.onCreateTasks - [11.604ms] Glide.setup
10-29 06:12:28.560 4084 4084 V CAM_Profiler: [ 64.909ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.615ms] OneCameraManager.get
10-29 06:12:28.571 4084 4084 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
10-29 06:12:28.572 4084 4084 I CameraManagerGlobal: Connecting to camera service
10-29 06:12:28.578 4084 4084 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:28.578 4084 4084 E CameraBase: In CameraBase.cpp getCameraService value = 0
10-29 06:12:28.579 4084 4084 E CameraBase: In CameraBase.cpp getCameraService after interface binder
10-29 06:12:28.579 4084 4084 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:28.579 4084 4084 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:28.579 4084 4084 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:28.579 4084 4084 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:28.580 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:12:28.581 4084 4084 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:28.581 4084 4084 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:28.581 4084 4084 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:28.581 4084 4084 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:28.581 4084 4084 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:28.595 4084 4115 I OMXClient: IOmx service obtained
10-29 06:12:28.597 3003 3537 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:12:28.601 3003 3537 E OMXNodeInstance: getConfig(0xec2a7b40:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:12:28.605 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:28.615 4084 4084 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:28.615 4084 4084 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:28.615 4084 4084 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:28.615 4084 4084 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:28.615 4084 4084 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:28.616 4084 4084 V CAM_Profiler: [120.882ms][ui] GUARD: CameraActivity.onCreateTasks - [ 1.378ms] computePictureSizes
10-29 06:12:28.618 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:28.623 2963 2963 I chatty : uid=1000(system) [email protected] identical 5 lines
10-29 06:12:28.624 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:28.666 4084 4084 D OpenGLRenderer: Skia GL Pipeline
10-29 06:12:28.692 4084 4084 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
10-29 06:12:28.879 4084 4084 I CAM_Profiler: [384.000ms][ui] GUARD: CameraActivity.onCreateTasks - [260.224ms] setContentView()
10-29 06:12:28.901 4084 4084 I CAM_Profiler: [405.719ms][ui] GUARD: CameraActivity.onCreateTasks - [21.720ms] Configure Camera UI
10-29 06:12:28.912 4084 4084 V CAM_CameraController: Closing camera
10-29 06:12:28.913 4084 4105 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
10-29 06:12:28.91[ 158.135085] binder: 2998:3473 transaction failed 29189/-22, size 60-0 line 3012
3 4084 4084 V CAM_ModulesInfo: EnableCaptureModule = true
10-29 06:12:28.915 4084 4084 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
10-29 06:12:28.919 4084 4084 V CA[ 158.158620] type=1400 audit(1572329548.358:3737): avc: denied { dac_read_search } for pid=4084 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
M_Profiler: [ 3.734ms][ui] GUARD[ 158.158902] audit: audit_lost=3640 audit_rate_limit=5 audit_backlog_limit=64
: new CaptureModule - STOP
10-29[ 158.182840] type=1400 audit(1572329549.034:3738): avc: denied { dac_read_search } for pid=4132 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
06:12:28.920 4084 4084 V CAM_S[ 158.190488] audit: rate limit exceeded
ettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546]
10-29 06:12:28.927 4084 4084 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546, com.android.camera.ButtonManager@2378a3]
10-29 06:12:28.927 4084 4084 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546, com.android.camera.ButtonManager@2378a3, com.android.camera.widget.IndicatorIconController@6209f59]
10-29 06:12:28.928 4084 4084 V CAM_Profiler: [432.396ms][ui] GUARD: CameraActivity.onCreateTasks - [ 7.953ms] Init Current Module UI
10-29 06:12:28.928 4084 4084 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
10-29 06:12:28.928 4084 4084 D CAM_CaptureModule: init UseAutotransformUiLayout = false
10-29 06:12:28.934 4084 4084 D AndroidRuntime: Shutting down VM
--------- beginning of crash
10-29 06:12:28.935 4084 4084 E AndroidRuntime: FATAL EXCEPTION: main
10-29 06:12:28.935 4084 4084 E AndroidRuntime: Process: com.android.camera2, PID: 4084
10-29 06:12:28.935 4084 4084 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2951)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3086)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: Caused by: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.ex.camera2.portability.AndroidCameraAgentImpl$AndroidCameraDeviceInfo.getCharacteristics(AndroidCameraAgentImpl.java:177)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.camera.app.CameraController.getCharacteristics(CameraController.java:112)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.camera.CaptureModule.getFacingFromCameraId(CaptureModule.java:1542)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.camera.CaptureModule.init(CaptureModule.java:415)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.camera.CameraActivity.onCreateTasks(CameraActivity.java:1627)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at com.android.camera.util.QuickActivity.onCreate(QuickActivity.java:114)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7144)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7135)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2931)
10-29 06:12:28.935 4084 4084 E AndroidRuntime: ... 11 more
10-29 06:12:28.946 4084 4084 I Process : Sending signal. PID: 4084 SIG: 9
10-29 06:12:29.015 2955 2955 I Zygote : Process 4084 exited due to signal (9)
10-29 06:12:29.016 3121 3133 I ActivityManager: Process com.android.camera2 (pid 4084) has died: fore TOP
10-29 06:12:29.017 3121 3139 W libprocessgroup: kill(-4084, 9) failed: No such process
10-29 06:12:29.017 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 10051 pid 4084 in 0ms
10-29 06:12:29.040 3121 3138 I ActivityManager: Start proc 4132:com.android.camera2/u0a51 for activity com.android.camera2/com.android.camera.PermissionsActivity
10-29 06:12:29.034 4132 4132 W main : type=1400 audit(0.0:3738): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:12:29.150 4132 4132 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:29.152 4132 4132 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:29.167 4132 4132 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraApp onCreate() - START
10-29 06:12:29.168 4132 4132 V CAM_Profiler: [ 0.000ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - START
10-29 06:12:29.168 4132 4132 V CAM_Profiler: [ 0.759ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 0.759ms] PreferenceManager.getDefaultSharedPreferences
10-29 06:12:29.169 4132 4132 V CAM_Profiler: [ 1.690ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 0.931ms] preferences.getLong
10-29 06:12:29.170 4132 4132 V CAM_Profiler: [ 1.978ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - STOP
10-29 06:12:29.170 4132 4132 V CAM_Profiler: [ 3.937ms][ui] GUARD: CameraApp onCreate() - [ 3.937ms] initializeTimeOfFirstRun
10-29 06:12:29.170 4132 4132 V CAM_Profiler: [ 4.281ms][ui] GUARD: CameraApp onCreate() - [ 0.344ms] UsageStatistics.initialize
10-29 06:12:29.172 4132 4132 V CAM_Profiler: [ 5.821ms][ui] GUARD: CameraApp onCreate() - [ 1.540ms] clearNotifications
10-29 06:12:29.172 4132 4132 V CAM_Profiler: [ 5.821ms][ui] GUARD: CameraApp onCreate() - STOP
10-29 06:12:29.194 4132 4132 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.209 4132 4132 D CAM_MemoryManagerImpl: Max native memory: 358 MB
10-29 06:12:29.214 4132 4132 V CAM_QuickActivity: END onCreate: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.218 4132 4132 V CAM_QuickActivity: START onStart: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.218 4132 4132 V CAM_QuickActivity: END onStart: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.218 4132 4132 V CAM_QuickActivity: START onResume: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.218 4132 4132 V CAM_QuickActivity: onResume(): isKeyguardLocked() = false
10-29 06:12:29.219 4132 4132 V CAM_QuickActivity: onResume --> onResumeTasks()
10-29 06:12:29.220 4132 4132 V CAM_PermissionsActivity: requestPermissions count: 1
10-29 06:12:29.221 3121 4131 I ActivityManager: START u0 {act=android.content.pm.action.REQUEST_PERMISSIONS pkg=com.android.packageinstaller cmp=com.android.packageinstaller/.permission.ui.GrantPermissionsActivity (has extras)} from uid 10051
10-29 06:12:29.236 4132 4132 V CAM_QuickActivity: END onResume: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.237 4132 4132 D OpenGLRenderer: Skia GL Pipeline
10-29 06:12:29.275 4132 4132 V CAM_QuickActivity: START onPause: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.275 4132 4132 V CAM_QuickActivity: onPause --> onPauseTasks()
10-29 06:12:29.275 4132 4132 V CAM_QuickActivity: END onPause: Activity = com.android.camera.PermissionsActivity@5833573
10-29 06:12:29.279 3995 3995 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@46f27c4
10-29 06:12:29.321 4132 4150 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:12:29.321 4132 4150 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:12:29.321 4132 4150 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:12:29.321 4132 4150 D OpenGLRenderer: Swap behavior 2
10-29 06:12:29.347 4132 4150 I display : open gpu gralloc module!
10-29 06:12:29.468 3995 3995 D OpenGLRenderer: Skia GL Pipeline
10-29 06:12:29.492 3282 3282 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:12:29.528 3995 4153 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
10-29 06:12:29.529 3995 4153 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
10-29 06:12:29.529 3995 4153 I OpenGLRenderer: Initialized EGL, version 1.4
10-29 06:12:29.529 3995 4153 D OpenGLRenderer: Swap behavior 2
10-29 06:12:29.530 2986 3578 W SurfaceFlinger: Attempting to set client state on removed layer: Splash Screen com.android.camera2#0
10-29 06:12:29.530 2986 3578 W SurfaceFlinger: Attempting to destroy on removed layer: Splash Screen com.android.camera2#0
10-29 06:12:29.552 3995 4153 I display : open gpu gralloc module!
10-29 06:12:29.687 3121 3144 I ActivityManager: Displayed com.android.packageinstaller/.permission.ui.GrantPermissionsActivity: +401ms (total +1s365ms)
10-29 06:12:30.347 3707 3707 W ViewRootImpl[Launcher]: Cancelling event due to no window focus: MotionEvent { action=ACTION_CANCEL, actionButton=0, id[0]=0, x[0]=1121.2249, y[0]=182.88977, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=159357, downTime=157061, deviceId=2, source=0x2002 }
10-29 06:12:31.469 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:12:31.535 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:12:31.535 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:12:31.538 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:12:31.538 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:12:31.558 4132 4132 V CAM_PermissionsActivity: onPermissionsResult counts: 1:1
10-29 06:12:31.557 3282 3282 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
10-29 06:12:30.347 3707 3707 I chatty : uid=10011(com.android.launcher3) identical 2 lines
10-29 06:12:30.348 3707 3707 W ViewRootImpl[Launcher]: Cancelling event due to no window focus: MotionEvent { action=ACTION_CANCEL, actionButton=0, id[0]=0, x[0]=1121.2249, y[0]=182.88977, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=159357, downTime=157061, deviceId=2, source=0x2002 }
10-29 06:12:31.572 3121 4131 I ActivityManager: START u0 {cmp=com.android.camera2/com.android.camera.CameraActivity} from uid 10051
10-29 06:12:31.610 3121 4131 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:31.612 4132 4132 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@ed27f78
10-29 06:12:31.626 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:31.628 4132 4132 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@3972a45
10-29 06:12:31.629 4132 4132 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
10-29 06:12:31.630 4132 4132 D CAM_LocationManager: Using legacy location provider.
10-29 06:12:31.638 4132 4132 W SoundPool: Use of stream types is deprecated for operations other than volume control
10-29 06:12:31.639 4132 4132 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
10-29 06:12:31.639 4132 4132 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
10-29 06:12:31.654 4132 4132 V CAM_Profiler: [ 25.563ms][ui] GUARD: CameraActivity.onCreateTasks - [13.048ms] Glide.setup
10-29 06:12:31.658 4132 4132 V CAM_Profiler: [ 28.906ms][ui] GUARD: CameraActivity.onCreateTasks - [ 3.343ms] OneCameraManager.get
10-29 06:12:31.671 4132 4132 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
10-29 06:12:31.672 4132 4132 I CameraManagerGlobal: Connecting to camera service
10-29 06:12:31.674 4132 4132 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:31.675 4132 4132 E CameraBase: In CameraBase.cpp getCameraService value = 0
10-29 06:12:31.675 4132 4132 E CameraBase: In CameraBase.cpp getCameraService after interface binder
10-29 06:12:31.675 4132 4132 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:31.675 4132 4132 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:31.676 4132 4132 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:31.676 4132 4132 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:31.678 4132 4132 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:31.679 4132 4132 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:31.679 4132 4132 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:31.679 4132 4132 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:31.679 4132 4132 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:31.681 4132 4132 V CAM_Profiler: [ 51.992ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.152ms] computePictureSizes
10-29 06:12:31.686 2998 3473 I FslExtractor: FslExtractor Sniff
10-29 06:12:31.716 4132 4166 I OMXClient: IOmx service obtained
10-29 06:12:31.716 3003 3537 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:12:31.718 3003 3537 E OMXNodeInstance: getConfig(0xec2a7b40:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:12:31.720 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:31.730 4132 4132 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
10-29 06:12:31.752 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:31.759 2963 2963 I chatty : uid=1000(system) [email protected] identical 5 lines
10-29 06:12:31.759 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:31.790 2986 3578 W SurfaceFlinger: Attempting to set client state on removed layer: Dim Layer for - Task=4#0
10-29 06:12:31.790 2986 3578 W SurfaceFlinger: Attempting to destroy on removed layer: Dim Layer for - Task=4#0
10-29 06:12:31.861 3995 4153 D OpenGLRenderer: endAllActiveAnimators on 0xf26b995eb300 (RippleDrawable) with handle 0xf26b7a524940
10-29 06:12:31.855 3121 3173 I chatty : uid=1000(system) android.anim identical 10 lines
10-29 06:12:31.878 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:31.894 3121 3521 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:31.912 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:31.936 4132 4132 I CAM_Profiler: [307.682ms][ui] GUARD: CameraActivity.onCreateTasks - [253.451ms] setContentView()
10-29 06:12:31.956 4132 4132 I CAM_Profiler: [327.678ms][ui] GUARD: CameraActivity.onCreateTasks - [19.996ms] Configure Camera UI
10-29 06:12:31.966 4132 4132 V CAM_CameraController: Closing camera
10-29 06:12:31.967 4132 4160 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
10-29 06:12:31.968 4132 4132 V CAM_ModulesInfo: EnableC[ 161.188224] binder: 2998:3474 transaction failed 29189/-22, size 60-0 line 3012
aptureModule = true
10-29 06:12:31.970 4132 4132 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
10-29 06:12:31.973 4132 4132 V CAM_Profiler: [ 2.907ms][ui] GUARD: new CaptureModule - STOP
10-29 06:12:31.973 4132 4132 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@dc0f23d]
10-29 06:12:31.980 4132 4132 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@dc0f23d, com.android.camera.ButtonManager@22777e]
10-29 06:12:31.980 4132 4132 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@dc0f23d, com.android.camera.ButtonManager@22777e, com.android.camera.widget.IndicatorIconController@79ce52c]
10-29 06:12:31.981 4132 4132 V CAM_Profiler: [351.980ms][ui] GUARD: CameraActivity.onCreateTasks - [ 7.683ms] Init Current Module UI
10-29 06:12:31.981 4132 4132 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
10-29 06:12:31.981 4132 4132 D CAM_CaptureModule: init UseAutotransformUiLayout = false
10-29 06:12:31.986 4132 4132 D AndroidRuntime: Shutting down VM
10-29 06:12:31.989 4132 4132 E AndroidRuntime: FATAL EXCEPTION: main
10-29 06:12:31.989 4132 4132 E AndroidRuntime: Process: com.android.camera2, PID: 4132
10-29 06:12:31.989 4132 4132 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2951)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3086)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: Caused by: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.ex.camera2.portability.AndroidCameraAgentImpl$AndroidCameraDeviceInfo.getCharacteristics(AndroidCameraAgentImpl.java:177)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.camera.app.CameraController.getCharacteristics(CameraController.java:112)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.camera.CaptureModule.getFacingFromCameraId(CaptureModule.java:1542)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.camera.CaptureModule.init(CaptureModule.java:415)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.camera.CameraActivity.onCreateTasks(CameraActivity.java:1627)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at com.android.camera.util.QuickActivity.onCreate(QuickActivity.java:114)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7144)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7135)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2931)
10-29 06:12:31.989 4132 4132 E AndroidRuntime: ... 11 more
10-29 06:12:31.986 3121 3173 I chatty : uid=1000(system) android.anim identical 5 lines
10-29 06:12:32.005 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.005 3121 3521 W ActivityManager: Force finishing activity com.android.camera2/com.android.camera.CameraActivity
10-29 06:12:32.019 3121 3521 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.021 4132 4132 I Process : Sending signal. PID: 4132 SIG: 9
10-29 06:12:32.034 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.066 3121 3190 W InputDispatcher: channel 'c6d0d9b com.android.camera2/com.android.camera.PermissionsActivity (server)' ~ Consumer closed input channel or an error occurred. events=0xd
10-29 06:12:32.066 3121 3190 E InputDispatcher: channel 'c6d0d9b com.android.camera2/com.android.camera.PermissionsActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
10-29 06:12:32.053 3121 3173 I chatty : uid=1000(system) android.anim identical 1 line
10-29 06:12:32.066 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.068 3121 3133 I WindowManager: WIN DEATH: Window{c6d0d9b u0 com.android.camera2/com.android.camera.PermissionsActivity}
10-29 06:12:32.069 3121 3133 W InputDispatcher: Attempted to unregister already unregistered input channel 'c6d0d9b com.android.camera2/com.android.camera.PermissionsActivity (server)'
10-29 06:12:32.069 3121 3309 I ActivityManager: Process com.android.camera2 (pid 4132) has died: fore TOP
10-29 06:12:32.070 3121 3139 W libprocessgroup: kill(-4132, 9) failed: No such process
10-29 06:12:32.070 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 10051 pid 4132 in 0ms
10-29 06:12:32.070 2955 2955 I Zygote : Process 4132 exited due to signal (9)
10-29 06:12:32.077 3121 3133 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.088 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.102 2986 3148 W SurfaceFlinger: Attempting to set client state on removed layer: com.android.camera2/com.android.camera.PermissionsActivity#0
10-29 06:12:32.102 2986 3148 W SurfaceFlinger: Attempting to destroy on removed layer: com.android.camera2/com.android.camera.PermissionsActivity#0
10-29 06:12:32.100 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.112 3121 3309 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.132 3121 3309 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.143 3121 3261 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.154 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.155 3121 3144 W ActivityManager: setHasOverlayUi called on unknown pid: 4132
10-29 06:12:32.165 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.176 3121 3133 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.191 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.301 2986 3661 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{a30687f token=Token{744759e ActivityRecord{5a017d9 u0 com.android.packageinstaller/.permission.ui.GrantPermissionsActivity t4}}}#0
10-29 06:12:32.208 3121 3173 I chatty : uid=1000(system) android.anim identical 1 line
10-29 06:12:32.221 3121 3173 E WindowManager: Performed 6 layouts in a row. Skipping
10-29 06:12:32.931 3121 3237 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
10-29 06:12:34.707 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:12:37.348 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:12:37.348 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:12:37.350 3121 4176 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher bnds=[960,115][1274,279]} from uid 10011
10-29 06:12:37.350 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:12:37.350 2965 4036 W audio_hw_primary: rate 48000, chann[ 166.522983] type=1400 audit(1572329549.034:3740): avc: denied { dac_read_search } for pid=4132 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
[ 166.545315] type=1400 audit(1572329557.398:3742): avc: denied { dac_read_search } for pid=4179 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:12:37.404 3121 3138 I ActivityManager: Start proc 4179:com.android.camera2/u0a51 for activity com.android.camera2/com.android.camera.CameraLauncher
10-29 06:12:37.398 4179 4179 W main : type=1400 audit(0.0:3742): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
10-29 06:12:37.443 4179 4179 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:37.448 4179 4179 I android.camera: The ClassLoaderContext is a special shared library.
10-29 06:12:37.467 4179 4179 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraApp onCreate() - START
10-29 06:12:37.468 4179 4179 V CAM_Profiler: [ 0.000ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - START
10-29 06:12:37.469 4179 4179 V CAM_Profiler: [ 1.079ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.079ms] PreferenceManager.getDefaultSharedPreferences
10-29 06:12:37.470 4179 4179 V CAM_Profiler: [ 2.236ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.157ms] preferences.getLong
10-29 06:12:37.470 4179 4179 V CAM_Profiler: [ 2.532ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - STOP
10-29 06:12:37.470 4179 4179 V CAM_Profiler: [ 4.679ms][ui] GUARD: CameraApp onCreate() - [ 4.679ms] initializeTimeOfFirstRun
10-29 06:12:37.471 4179 4179 V CAM_Profiler: [ 4.994ms][ui] GUARD: CameraApp onCreate() - [ 0.315ms] UsageStatistics.initialize
10-29 06:12:37.472 4179 4179 V CAM_Profiler: [ 6.411ms][ui] GUARD: CameraApp onCreate() - [ 1.417ms] clearNotifications
10-29 06:12:37.472 4179 4179 V CAM_Profiler: [ 6.411ms][ui] GUARD: CameraApp onCreate() - STOP
10-29 06:12:37.499 4179 4179 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@5833573
10-29 06:12:37.500 4179 4179 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
10-29 06:12:37.500 4179 4179 D CAM_LocationManager: Using legacy location provider.
10-29 06:12:37.512 4179 4179 D CAM_MemoryManagerImpl: Max native memory: 358 MB
10-29 06:12:37.518 4179 4179 W SoundPool: Use of stream types is deprecated for operations other than volume control
10-29 06:12:37.518 4179 4179 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
10-29 06:12:37.518 4179 4179 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
10-29 06:12:37.533 4179 4179 V CAM_Profiler: [ 33.382ms][ui] GUARD: CameraActivity.onCreateTasks - [13.230ms] Glide.setup
10-29 06:12:37.536 4179 4179 V CAM_Profiler: [ 35.990ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.608ms] OneCameraManager.get
10-29 06:12:37.548 4179 4179 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
10-29 06:12:37.550 4179 4179 I CameraManagerGlobal: Connecting to camera service
10-29 06:12:37.552 2998 3474 I FslExtractor: FslExtractor Sniff
10-29 06:12:37.553 4179 4179 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:37.553 4179 4179 E CameraBase: In CameraBase.cpp getCameraService value = 0
10-29 06:12:37.554 4179 4179 E CameraBase: In CameraBase.cpp getCameraService after interface binder
10-29 06:12:37.554 4179 4179 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:37.554 4179 4179 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:37.554 4179 4179 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:37.554 4179 4179 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:37.558 4179 4179 I Camera-JNI: In JNI android_hardware_Camera_getNumberOfCameras
10-29 06:12:37.558 4179 4179 E CameraBase: In CameraBase.cpp getCameraService return #2
10-29 06:12:37.558 4179 4179 E CameraBase: In CameraBase.cpp getCameraService success
10-29 06:12:37.558 4179 4179 E CameraBase: In CameraBase.cpp res is ok getNumberOfCameras count = 0
10-29 06:12:37.559 4179 4179 E CAM2PORT_AndCamAgntImp: In AndroidCameraAgentImpl numberOfCameras = 0
10-29 06:12:37.559 4179 4179 V CAM_Profiler: [ 59.692ms][ui] GUARD: CameraActivity.onCreateTasks - [ 1.467ms] computePictureSizes
10-29 06:12:37.577 4179 4179 D OpenGLRenderer: Skia GL Pipeline
10-29 06:12:37.587 4179 4205 I OMXClient: IOmx service obtained
10-29 06:12:37.588 3003 3319 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in [email protected] process
10-29 06:12:37.594 3003 3319 E OMXNodeInstance: getConfig(0xebe91060:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
10-29 06:12:37.597 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:37.607 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:12:37.608 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:37.610 4179 4179 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
10-29 06:12:37.611 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:37.614 2963 2963 I chatty : uid=1000(system) [email protected] identical 2 lines
10-29 06:12:37.615 2963 2963 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0xf6918a22c100, 32768)
10-29 06:12:37.814 4179 4179 I CAM_Profiler: [314.484ms][ui] GUARD: CameraActivity.onCreateTasks - [252.166ms] setContentView()
10-29 06:12:37.850 4179 4179 I CAM_Profiler: [349.512ms][ui] GUARD: CameraActivity.onCreateTasks - [35.028ms] Configure Camera UI
10-29 06:12:37.863 4179 4179 V CAM_CameraController: Closing camera
10-29 06:12:37.865 4179 4198 W CAM2PORT_AndCamAgntImp[ 167.070207] binder: 2998:3473 transaction failed 29189/-22, size 60-0 line 3012
10-29 06:12:37.866 4179 4179 V CAM_ModulesInfo: EnableCaptureModule = true
10-29 06:12:37.868 4179 4179 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
10-29 06:12:37.872 4179 4179 V CAM_Profiler: [ 3.566ms][ui] GUARD: new CaptureModule - STOP
10-29 06:12:37.872 4179 4179 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546]
10-29 06:12:37.882 4179 4179 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546, com.android.camera.ButtonManager@2378a3]
10-29 06:12:37.882 4179 4179 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@63cb546, com.android.camera.ButtonManager@2378a3, com.android.camera.widget.IndicatorIconController@6209f59]
10-29 06:12:37.883 4179 4179 V CAM_Profiler: [383.069ms][ui] GUARD: CameraActivity.onCreateTasks - [10.812ms] Init Current Module UI
10-29 06:12:37.883 4179 4179 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
10-29 06:12:37.883 4179 4179 D CAM_CaptureModule: init UseAutotransformUiLayout = false
10-29 06:12:37.887 4179 4179 D AndroidRuntime: Shutting down VM
10-29 06:12:37.888 4179 4179 E AndroidRuntime: FATAL EXCEPTION: main
10-29 06:12:37.888 4179 4179 E AndroidRuntime: Process: com.android.camera2, PID: 4179
10-29 06:12:37.888 4179 4179 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2951)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3086)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: Caused by: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.ex.camera2.portability.AndroidCameraAgentImpl$AndroidCameraDeviceInfo.getCharacteristics(AndroidCameraAgentImpl.java:177)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.camera.app.CameraController.getCharacteristics(CameraController.java:112)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.camera.CaptureModule.getFacingFromCameraId(CaptureModule.java:1542)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.camera.CaptureModule.init(CaptureModule.java:415)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.camera.CameraActivity.onCreateTasks(CameraActivity.java:1627)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at com.android.camera.util.QuickActivity.onCreate(QuickActivity.java:114)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7144)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7135)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2931)
10-29 06:12:37.888 4179 4179 E AndroidRuntime: ... 11 more
10-29 06:12:37.893 3121 3309 W ActivityManager: Force finishing activity com.android.camera2/com.android.camera.CameraLauncher
10-29 06:12:37.900 4179 4179 I Process : Sending signal. PID: 4179 SIG: 9
10-29 06:12:37.951 3121 3258 I ActivityManager: Process com.android.camera2 (pid 4179) has died: fore TOP
10-29 06:12:37.951 3121 3139 W libprocessgroup: kill(-4179, 9) failed: No such process
10-29 06:12:37.951 3121 3139 I libprocessgroup: Successfully killed process cgroup uid 10051 pid 4179 in 0ms
10-29 06:12:37.961 2955 2955 I Zygote : Process 4179 exited due to signal (9)
10-29 06:12:38.012 2986 3046 W SurfaceFlinger: Attempting to destroy on removed layer: Task=5#0
10-29 06:12:38.012 2986 3046 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{ca2434b token=Token{7750c1a ActivityRecord{a8b4ac5 u0 com.android.camera2/com.android.camera.CameraLauncher t5}}}#0
10-29 06:12:40.532 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
10-29 06:12:41.284 2965 4036 I audio_hw_primary: start_output_stream_primary... 0xe95d1000, device 1024, address , mode 0
10-29 06:12:41.284 2965 4036 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 0, earpiece 0,
10-29 06:12:41.289 2965 4036 W audio_hw_primary: card 3, port 0 device 0x400
10-29 06:12:41.289 2965 4036 W audio_hw_primary: rate 48000, channel 2 period_size 0xc0
10-29 06:12:41.416 3121 3137 D AutofillManagerService: onBackKeyPressed()
10-29 06:12:41.483 3121 3237 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
10-29 06:12:41.656 2986 2986 E SurfaceFlinger: [Sprite#0] rejecting buffer: bufWidth=33, bufHeight=33, front.active.{w=29, h=37}
10-29 06:12:44.469 2965 2965 W audio_hw_primary: do_out_standby... 0xe95d1000
25,132件の閲覧回数
xu_ji1
:18.663 2973 2973 I FslCameraHAL: getNodeName: dev path:/dev/video1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName: node name:mx6s-csi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video1 failed
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeNames: node name:mx6s-csi,i.MX6S_CSI
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName: dev path:/dev/video0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: getNodeName CHIP_IDENT dev path:/dev/video0 failed
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchPropertyName: index:0, max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: index:0, propName:max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:0
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchPropertyName: index:1, max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: index:1, propName:max9286_mipi
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video1, node:max9286_mipi, index:1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: matchNodeName: sensor:mx6s-csi,i.MX6S_CSI, dev:/dev/video0, node:max9286_mipi, index:1
10-29 06:02:18.663 2973 2973 I FslCameraHAL: camera number is 0
It seems the name not match,pls check this logic in your source
25,132件の閲覧回数
jack-cap
Hi Xu Ji
I have changed the name,But it seem that after the max9286 driver was insmod,it did not generate any video sys node.
It's why ?
BRs
thanks
25,132件の閲覧回数
xu_ji1
hello,
If your camera driver not probe success there will be no video sys node created.
25,132件の閲覧回数
jack-cap
Hi Xu Ji
it seems the max9286 driver probe successfully,the video sys node still isn't be register.
Could you share your max9286 driver for me ?
my email:[email protected]
thanks
BRs
25,132件の閲覧回数
xu_ji1
Sorry,
For security ,we can not send out code in company
25,132件の閲覧回数
jack-cap
hi Xu ji,
Can you open four cameras at the same time On imx8qm Android OS.
I found closing the second camera would fail. Do you have the same error on closing the second camera ?
25,132件の閲覧回数
xu_ji1
hello,yingjin
I open 4 cameras at same time,and how about close second camera?
what is your reproduced step?
25,132件の閲覧回数
jack-cap
Hi Xu ji,
   First  I turn on 4 cameras with an apk.
   Then I start turn off the four cameras in sequence. The first camera can be closed successfully. but the second camera fails to turn off.
some logs as follow:
02-22 03:49:30.919 I/FslCameraHAL( 3233): closeDev:0: Closing camera device
02-22 03:49:30.919 I/FslCameraHAL( 3233): onDeviceStopLocked
02-22 03:49:30.919 I/Camera3-Device( 3260): disconnect: X
02-22 03:49:30.920 I/Camera3-Device( 3260): disconnect: E
02-22 03:49:30.924 I/CameraService( 3260): disconnect: Disconnected client for camera 0 for PID 4679
02-22 03:49:30.925 I/Camera2Client( 3260): Camera 0: Closed
02-22 03:49:30.925 D/ygl     ( 4679): camera1 stopPreview() release()
02-22 03:49:30.925 D/ygl     ( 4679): onPause camera2android.hardware.Camera@a2ced20
02-22 03:49:30.925 I/FslCameraHAL( 3233): flushDev:1: Flushing camera device
02-22 03:49:30.926 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.926 I/Camera2ClientBase( 3260): Closed Camera 0. Client was: com.neolix.videoRecorder (PID 4679, UID 10076)
25,132件の閲覧回数
xu_ji1
hi,
I test four cameras with EVS app,what is your apk?is it support multi-camera?
25,109件の閲覧回数
jack-cap
Do you test recording multiple videos on Android OS?
25,119件の閲覧回数
jack-cap
I test four cameras with my own apk, It support 4 cameras!
