I.MX8QMax -- How to Compile QT Cpp code
1,917件の閲覧回数
santhosh2
How to cross compile simple QT Cpp code for I.MX8QMax.
I did below steps
export PATH=/opt/fsl-imx-x11/4.9.51-mx8-beta/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux/:$PATH
export CROSS_COMPILE=aarch64-poky-linux-
export ARCH=arm64
export LDFLAGS=""
source /opt/fsl-imx-x11/4.9.51-mx8-beta/environment-setup-aarch64-poky-linux
LDFLAGS="" CC="$CC"
export GCC=$CXX
Buts its getting compiled to x86-64
(Attached the snap )
Santhosh Kumar S
1,855件の閲覧回数
Bio_TICFSL
Hello Santosh,
The following links may help you:
Qt5.6.3 Build issue with ARM64 | Qt Forum
Building Qt Sources | Qt 5.14
1,855件の閲覧回数
santhosh2
No the links didnt help, Can you help me with steps
regards
santhosh
